[petsc-dev] major git problem!
Barry Smith
bsmith at mcs.anl.gov
Mon Feb 16 17:59:45 CST 2015
> On Feb 16, 2015, at 5:58 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>> $ git pull
>> error: There are still logs under '.git/logs/refs/remotes/origin/balay/update-scotch_6.0.3'
>> From bitbucket.org:petsc/petsc
>> ! [new branch] balay/update-scotch_6.0.3 -> origin/balay/update-scotch_6.0.3 (unable to update local ref)
>> If I delete that directory .git/logs/refs/remotes/origin/balay/update-scotch_6.0.3 I still get the error message again
> I can't reproduce. Can you "git fetch"?
Same freaking message.
google found a few things but most dated 2010 and not useful though possibly related
