[petsc-dev] major git problem!
Mon Feb 16 17:44:50 CST 2015
$ git pull
error: There are still logs under '.git/logs/refs/remotes/origin/balay/update-scotch_6.0.3'
From bitbucket.org:petsc/petsc
 ! [new branch]      balay/update-scotch_6.0.3 -> origin/balay/update-scotch_6.0.3  (unable to update local ref)
If I delete that directory .git/logs/refs/remotes/origin/balay/update-scotch_6.0.3 I still get the error message again
