[petsc-dev] configure error on Edison
Mark Adams
mfadams at lbl.gov
Mon Feb 9 16:40:20 CST 2015
FYI, this is what NERSC tells me. I tired cmake/3.0.0 but I got an error
from PETSc I think saying Metis needs v2.8. (This should probably be
fixed.) The CRAYPE_LINK_TYPE=dynamic did not seem to play nice with my
configuration ('--with-shared-libraries=0') but cmake/2.8.11.2 seems to be
working.
Thanks for the additional details - indeed, it is the -rdynamic flag being
used in the config tests that is causing problems. One way to to get around
that is setting CRAYPE_LINK_TYPE to dynamic (that way -rdynamic won't
fail), and the other is to use 2.8.11.2 (not 2.8.12.2 or 3.0.0) which does
not add -rdynamic on the link line when building config tests. Would either
of these workaround be ok for your use case?
Many thanks,
Scott French
NERSC User Services
On Sun, Feb 8, 2015 at 1:37 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Damn, this was working a week ago. I've tried many things and am now
> just doing a 'make config' in metis and see this -rdynamic thing. I will
> ask NERSC.
> Thanks,
> Mark
> On Sun, Feb 8, 2015 at 10:34 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Sat, 7 Feb 2015, Mark Adams wrote:
>> > I am getting errors again with metis. This has come up on Hopper but
>> this
>> > looks different.
>> > Mark
>> -- Check for working C compiler: /opt/cray/craype/2.2.1/bin/cc -- broken
>> /opt/cray/craype/2.2.1/bin/cc -fast -no-ipo
>> CMakeFiles/cmTryCompileExec1628815744.dir/testCCompiler.c.o -o
>> cmTryCompileExec1628815744 -rdynamic
>> /usr/bin/ld: dynamic STT_GNU_IFUNC symbol `strcmp' with pointer
>> equality in
>> `/usr/lib64/gcc/x86_64-suse-linux/4.3/../../../../lib64/libc.a(strcmp.o)'
>> can not be used when making an executable; recompile with -fPIE and
>> relink
>> with -pie
>> I have no idea why cmake is using -rdynamic here. [or how to tell it not
>> to do that..]
>> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150209/76b30143/attachment.html>
