[petsc-dev] 4e9ba7ee src/ts/interface/ts.c (Matthew Knepley 2014-04-08 14:37:03 -0500 2627) ierr = VecViewFromOptions(ts->vec_sol, ((PetscObject) ts)->prefix, "-ts_view_solution"); CHKERRQ(ierr);
Jed Brown jed at jedbrown.org
Sat Feb 7 09:16:35 CST 2015
Matthew Knepley <knepley at gmail.com> writes:
> So you want me to change -ts_view_solution to -ts_monitor_solution? Fine.
> Why didn't you just do that? As you may know,
> this is what all of the known scientific and engineering world does, output
> the solution on each timestep.
Some steps, but definitely not all.  If they did, solver performance
wouldn't matter.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150207/9079ebc1/attachment.sig>
