[petsc-dev] PETSc 3.5.3 and CMake
Pierre Jolivet jolivet at ann.jussieu.fr
Thu Feb 5 05:59:50 CST 2015
Hello,
I don’t know if Jed is the sole maintainer of the FindPETSc.cmake file available here [1], so sorry in advance for disturbing the rest of you if this is the case.
It appears that with version 3.5.3, FindPETSc.cmake can’t detect PETSc correctly anymore and just returns:
"PETSc could not be found.  Be sure to set PETSC_DIR and PETSC_ARCH."
even though these variables are set. That would be great if you could fix this.
Thank you in advance,
Pierre
[1] https://github.com/jedbrown/cmake-modules/
