[petsc-dev] [mpich-trac] #2321: mpich-3.2 is not valgrind clean with petsc examples
mpich noreply at mpich.org
Fri Dec 18 14:32:41 CST 2015
 Reporter:  balay  |       Type:  bug
   Status:  new    |   Priority:  major
Milestone:         |  Component:  mpich
 Keywords:         |
 When petsc switched from 3.1.3 to 3.2 - we started seeing valgrind
 messages from MPICH.
 Could you take a look at this? I can help with running petsc examples that
 produce these messages.
 valgrind clean log with mpich-3.1.3
 http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/12/12
 /examples_master_arch-linux-pkgs-valgrind_grind.log
 same build log with mpich-3.2
 http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/12/13
 mpich configured with:
 ./configure --prefix=/sandbox/petsc/petsc.clone/arch-linux-pkgs-valgrind
 MAKE=/usr/bin/make --libdir=/sandbox/petsc/petsc.clone/arch-linux-pkgs-
 valgrind/lib CC="gcc" CFLAGS="-fPIC -g3" AR="/usr/bin/ar" ARFLAGS="cr"
 CXX="g++" CXXFLAGS="-g -fPIC -std=c++11" F77="gfortran" FFLAGS="-fPIC
 -ffree-line-length-0 -g" FC="gfortran" FCFLAGS="-fPIC -ffree-line-length-0
 -g" --enable-shared --with-device=ch3:sock --with-pm=hydra --enable-
 fast=no --enable-g=meminit
Ticket URL: <http://trac.mpich.org/projects/mpich/ticket/2321>
