[petsc-dev] bullshit in Plex example under complex
    Jed Brown
    jed at jedbrown.org
    Sat Aug 29 17:47:13 CDT 2015
Tobin Isaac <tisaac at ices.utexas.edu> writes:
> How am I supposed to add a test to the intersection of a package
> (testexamples_TRIANGLE) and a scalar type (testexamples_C_NoComplex).
> It's pretty frustrating, given how obvious this would be with
> something like sharness [1], that I couldn't easily figure this out.
I've used sharness a reasonable amount and generally like it, especially
when paired with "prove".  A couple years ago, I did some exploratory
work to parse PETSc makefile tests and generate sharness-style tests.  I
still don't think it's a bad idea and might yet be able to get back to
it.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150829/0e0b8315/attachment.sig>
