[petsc-dev] strangness in Chebyshev estimate of eigenvalues
    Mark Adams
    mfadams at lbl.gov
    Fri Aug 28 06:05:42 CDT 2015
What should I do if the DIVERGE_ITS test fails?  I assume abort.
And I assume I can put these two items (Cheby solve test and put petsc rand
vectors back in GAMG and Cheby) in one branch.
On Thu, Aug 27, 2015 at 5:50 PM, Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
> > OK, I can put PetscRandom back into GAMG and add a check for DIVERGE_ITS
> in
> > the Cheby solve.  Is that necessary and sufficient?
> Yes, but use a deterministic seed (that includes the process rank so all
> ranks don't produce the same numbers).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150828/cd8b868b/attachment.html>
