[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Mark Adams
mfadams at lbl.gov
Fri Aug 28 06:02:05 CDT 2015
Is there a good way to get a deterministic rand wrt number of processors?
Seeding rand for each entry, with its global ID would work I assume.
If drand48 is just one line then why not just copy it tweak it as desired?
Cheby is otherwise deterministic, with a deterministic PC, and we have
equation numbers to make this work. Eigen estimates are a real pain and the
source of a lot of time consuming AMG errors. It would be nice to have it
not depend in any way on processor count.
On Thu, Aug 27, 2015 at 10:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Aug 27, 2015, at 5:35 PM, Jed Brown <jed at jedbrown.org> wrote:
> > Barry Smith <bsmith at mcs.anl.gov> writes:
> >> This is the default behavior if one just creates a PetscRandom and
> uses it, so don't be going and setting seeds inside GAMG or Chebyshev.
> Yikes, you are right all three of our current random number generators
> have global state! What a mess. We should remove all them completely and we
> can complement Matt's by adding in a more modern version of Sprng that does
> not use global state. (Stupid Sprng fucks changed to C++)
> Barry
> > You're right (my mistake), but the consequences are dangerous if the
> > user is holding a PetscRandom across calls to GAMG (or anything that
> > creates new PetscRandom instances). The reason is that merely creating
> > a PetscRandom reseeds the global PRNG. (What moron thought a global
> > seed was a good idea?) Seems to me we should avoid drand48 always so we
> > don't disrupt the user's source of randomness (leading to really
> > confusing incorrect results). We could use the non-disastrous
> > drand48_r, but it's a GNU extension so we'd need an alternative anyway.
> > If Matt changes "rander48" to the rand48_r (or erand48_r) interface,
> > then we'd be okay. This would also remove the internal variables that
> > Matt forget to make static.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150828/72d36c42/attachment.html>
