[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Jed Brown
jed at jedbrown.org
Thu Aug 27 16:50:50 CDT 2015
Mark Adams <mfadams at lbl.gov> writes:
> OK, I can put PetscRandom back into GAMG and add a check for DIVERGE_ITS in
> the Cheby solve. Is that necessary and sufficient?
Yes, but use a deterministic seed (that includes the process rank so all
ranks don't produce the same numbers).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150827/c6a4d126/attachment.sig>
