[petsc-dev] Issues trying to DM-ificate PetIGA
Jed Brown
jed at jedbrown.org
Wed Aug 26 10:04:59 CDT 2015
Barry Smith <bsmith at mcs.anl.gov> writes:
> Another alternative is to have inside the DMKSP a pointer to the
> "active" KSP (make it a void pointer so that there is no circular
> dependencies)
DMKSP is in the KSP package, so there is no problem with circular dependencies.
> and only use the DMKSP functions if the current KSP is the "active"
> KSP. Of course now we still need to set this pointer to the
> appropriate KSP (the first one set with KSPSetDM()? by default). Is
> there any advantage to this? (Same for snes also).
I think it's cosmetic except that a DM field is more permissive in that
it could have a different DM. I can't think of a reason to want that.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150826/ea38c422/attachment.sig>
