[petsc-dev] strangness in Chebyshev estimate of eigenvalues
    Jed Brown
    jed at jedbrown.org
    Wed Aug 26 08:44:26 CDT 2015
Mark Adams <mfadams at lbl.gov> writes:
> I've not looked at it, and it would be hard to because it is not a well
> defined problem.  But, if the initial guess is low frequency then it will
> give a poor estimate for the highest eigen value.
This is true.
> It is not clear to me what the relationship is, generally, of an
> initial guess and the solution, spectrally.  Initial guesses will
> change as the problem evolves but we don't update the eigen estimates.
> If the user's initial guess happens to be zero then god knows what
> happens.
The right hand side is used.  You have to explicitly ask to use a
nonzero initial guess.
> (This is actually the case for the XGC1 code!!!)  It adds one more
> variable in debugging AMG, which is hard enough as it is.
I agree that we should be using a random starting vector for spectral
estimates.  I'm not overly concerned whether it's a hash of the global
ID or a deterministic seed, but let's use something that has been
studied.  Your suggested "hash function" is way hokey.  I'm fine with
guaranteeing drand48 and a deterministic seed.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150826/b74d0c9d/attachment.sig>
