[petsc-dev] [GPU - slepc] Hands-on exercise 4 (SVD) not working with GPU and default configurations
Leoni, Massimiliano Massimiliano.Leoni at Rolls-Royce.com
Mon Aug 10 05:45:40 CDT 2015
Good, it is running now, but performances are really poor: I tried on 3 nodes with 2 GPUs and 12 CPU threads each, MPI+CUDA performs much worse than pure MPI.
I have a few thoughts on why this might be happening:
·         My problem has dense matrices but on GPU I use –mat_type aijcusp
·         I did something wrong in setting the problem up, that causes a bunch of useless memory traffic I could avoid
·         The real power of GPUs might show up only eventually as the problem gets bigger [I tested a 100000x200 matrix]
Is any of these likely to be causing this poor performance?
There is also the banner on PETSc’s website saying that using GPUs effectively is not that easy. Can anyone point me to further reference on how to improve this?
I suspect that I can achieve more by choosing proper solution methods and other options of PETSc/SLEPc.
Any hint highly appreciated.
Massimiliano
> -----Original Message-----
> From: Jose E. Roman [mailto:jroman at dsic.upv.es]
> Sent: 07 August 2015 18:44
> To: Leoni, Massimiliano
> Cc: petsc-dev at mcs.anl.gov; slepc-maint at upv.es
> Subject: Re: [petsc-dev] [GPU - slepc] Hands-on exercise 4 (SVD) not working
> Yes, there seems to be a problem with the default SVD solver (SVDCROSS). I
> will fix it in the master branch in the next days. Meanwhile, you can run the
> example with -svd_type trlanczos
> Thanks for reporting this.
> Jose
> > El 7/8/2015, a las 16:31, Leoni, Massimiliano <Massimiliano.Leoni at Rolls-<mailto:Massimiliano.Leoni at Rolls-Royce.com>
> Royce.com<mailto:Massimiliano.Leoni at Rolls-Royce.com>> escribió:
> > Hi everybody!
> > I kept experimenting with slepc and GPUs, and when I turned to SVD I
> found out that the hands-on exercise on SVD [#4] doesn’t run properly.
> > If I run it on CPU it works fine, whereas… $ mpirun -np 1 slepcSVD
> > -file $SLEPC_DIR/share/slepc/datafiles/matrices/rdb200.petsc -bv_type
> > vecs -mat_type aijcusp -on_error_abort
> > Singular value problem stored in file.
> > Reading REAL matrix from a binary file...
> > [0]PETSC ERROR: BVScaleColumn() line 380 in
> > /gpfs/rrcfd/rruk-students/apps/slepc/src/sys/classes/bv/interface/bvop
> > s.c Scalar value must be same on all processes, argument # 3 [0]PETSC
> > ERROR:
> > -- [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
> > Violation, probably memory access out of range [0]PETSC ERROR: Try
> > option -start_in_debugger or -on_error_attach_debugger [0]PETSC ERROR:
> > or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> > OS X to find memory corruption errors [0]PETSC ERROR: likely location
> > of problem given in stack below [0]PETSC ERROR: ---------------------
> > Stack Frames ------------------------------------
> > [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> > [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> > [0]PETSC ERROR:       is given.
> > [0]PETSC ERROR: [0] PetscAbortErrorHandler line 56
> > /gpfs/rrcfd/rruk-students/apps/petsc/src/sys/error/errabort.c
> > [0]PETSC ERROR: [0] PetscError line 363
> > /gpfs/rrcfd/rruk-students/apps/petsc/src/sys/error/err.c
> > [0]PETSC ERROR: [0] BVScaleColumn line 377
> > s.c [0]PETSC ERROR: [0] EPSFullLanczos line 357
> > /gpfs/rrcfd/rruk-students/apps/slepc/src/eps/impls/krylov/epskrylov.c
> > [0]PETSC ERROR: [0] EPSSolve_KrylovSchur_Symm line 41
> > /gpfs/rrcfd/rruk-students/apps/slepc/src/eps/impls/krylov/krylovschur/
> > ks-symm.c [0]PETSC ERROR: [0] EPSSolve line 83
> > /gpfs/rrcfd/rruk-students/apps/slepc/src/eps/interface/epssolve.c
> > [0]PETSC ERROR: [0] SVDSolve_Cross line 155
> > /gpfs/rrcfd/rruk-students/apps/slepc/src/svd/impls/cross/cross.c
> > [0]PETSC ERROR: [0] SVDSolve line 92
> > /gpfs/rrcfd/rruk-students/apps/slepc/src/svd/interface/svdsolve.c
> > [0]PETSC ERROR: User provided function() line 0 in  unknown file
> > (null)
> > ---- mpirun noticed that process rank 0 with PID 11264 on node gpu3
> > exited on signal 11 (Segmentation fault).
> > I am using the same command line options that work just fine on hands-on
> exercises 1 and 2, which feature EPS solvers.
> > Any hint appreciated.
> > Best regards,
> > Massimiliano Leoni
> > The data contained in, or attached to, this e-mail, may contain confidential
> information. If you have received it in error you should notify the sender
> immediately by reply e-mail, delete the message from your system and
> contact +44 (0) 1332 622800(Security Operations Centre) if you need
> assistance. Please do not copy it for any purpose, or disclose its contents to
> any other person.
> > An e-mail response to this address may be subject to interception or
> monitoring for operational reasons or for lawful business practices.
> > (c) 2015 Rolls-Royce plc
> > Registered office: 62 Buckingham Gate, London SW1E 6AT Company
> number: 1003142. Registered in England.
The data contained in, or attached to, this e-mail, may contain confidential information. If you have received it in error you should notify the sender immediately by reply e-mail, delete the message from your system and contact +44 (0) 1332 622800(Security Operations Centre) if you need assistance. Please do not copy it for any purpose, or disclose its contents to any other person.
An e-mail response to this address may be subject to interception or monitoring for operational reasons or for lawful business practices.
Registered office: 62 Buckingham Gate, London SW1E 6AT Company number: 1003142. Registered in England.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150810/892b06c8/attachment.html>
