[petsc-dev] Julia Petsc Wrapper
Jared Crean
jcrean01 at gmail.com
Sun Aug 2 17:00:27 CDT 2015
Good to know. I will bring that up with the MPI.jl developers.
Jared Crean
On 7/28/2015 1:22 AM, Jed Brown wrote:
> Jared Crean <jcrean01 at gmail.com> writes:
>> As for the MPI communicator, the julia MPI package uses a C int
>> to store it, so I will typealias to that to ensure consistency. If an
>> MPI implementation uses an 8 byte pointer, MPI.jl will have to change too.
> Open MPI and relatives (like the now-obsolete LAM-MPI) use a pointer for
> all handles. To my knowledge, there is no subset of the MPI interface
> that can reliably be called to determine the binary interface, so you'll
> need access to the headers there too.
