[petsc-dev] [OMPI users] potential bug with MPI_Win_fence() in	openmpi-1.8.4
    George Bosilca
    bosilca at icl.utk.edu
    Thu Apr 30 14:33:31 CDT 2015
In the packed representation we store not MPI_Datatypes but a handcrafted
id for each one. The 2 codes should have been in sync. I'm looking at
another issue right now, and I'll come back to this one right after.
Thanks for paying attention to the code.
  George.
On Thu, Apr 30, 2015 at 3:13 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Thanks for checking and getting a more appropriate fix in.
> I've just tried this out - and the PETSc test code runs fine with it.
> BTW: There is one inconsistancy in ompi/datatype/ompi_datatype_args.c
> [that I noticed] - that you might want to check.
> Perhaps the second line should be  "(DC) * sizeof(MPI_Datatype)"?
>         int length = sizeof(ompi_datatype_args_t) + (IC) * sizeof(int) + \
>             (AC) * sizeof(OPAL_PTRDIFF_TYPE) + (DC) *
> sizeof(MPI_Datatype); \
>        pArgs->total_pack_size = (4 + (IC)) * sizeof(int) +             \
>             (AC) * sizeof(OPAL_PTRDIFF_TYPE) + (DC) * sizeof(int);      \
> Satish
> On Thu, 30 Apr 2015, Matthew Knepley wrote:
> > On Fri, May 1, 2015 at 4:55 AM, Jeff Squyres (jsquyres) <
> jsquyres at cisco.com>
> > wrote:
> > > Thank you!
> > > George reviewed your patch and adjusted it a bit.  We applied it to
> master
> > > and it's pending to the release series (v1.8.x).
> > Was this identified by IBM?
> https://github.com/open-mpi/ompi/commit/015d3f56cf749ee5ad9ea4428d2f5da72f9bbe08
> >      Matt
> > > Would you mind testing a nightly master snapshot?  It should be in
> > > tonight's build:
> > >     http://www.open-mpi.org/nightly/master/
> > > > On Apr 30, 2015, at 12:50 AM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > > OpenMPI developers,
> > > > We've had issues (memory errors) with OpenMPI - and code in PETSc
> > > > library that uses MPI_Win_fence().
> > > > Vagrind shows memory corruption deep inside OpenMPI function stack.
> > > > I'm attaching a potential patch that appears to fix this issue for
> us.
> > > > [the corresponding valgrind trace is listed in the patch header]
> > > > Perhaps there is a more appropriate fix for this memory corruption.
> Could
> > > > you check on this?
> > > > [Sorry I don't have a pure MPI test code to demonstrate this error -
> > > > but a PETSc test example code consistantly reproduces this issue]
> > > > Thanks,
> > > > Satish<openmpi-1.8.4.patch>
> > > Jeff Squyres
> > > For corporate legal information go to:
> > > http://www.cisco.com/web/about/doing_business/legal/cri/
> users mailing list
> users at open-mpi.org
> Subscription: http://www.open-mpi.org/mailman/listinfo.cgi/users
> Link to this post:
> http://www.open-mpi.org/community/lists/users/2015/04/26823.php
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150430/8ea64487/attachment.html>
