[petsc-dev] potential bug with MPI_Win_fence() in openmpi-1.8.4
    Matthew Knepley
    knepley at gmail.com
    Thu Apr 30 13:59:20 CDT 2015
On Fri, May 1, 2015 at 4:55 AM, Jeff Squyres (jsquyres) <jsquyres at cisco.com>
wrote:
> Thank you!
> George reviewed your patch and adjusted it a bit.  We applied it to master
> and it's pending to the release series (v1.8.x).
Was this identified by IBM?
https://github.com/open-mpi/ompi/commit/015d3f56cf749ee5ad9ea4428d2f5da72f9bbe08
     Matt
> Would you mind testing a nightly master snapshot?  It should be in
> tonight's build:
>     http://www.open-mpi.org/nightly/master/
> > On Apr 30, 2015, at 12:50 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > OpenMPI developers,
> > We've had issues (memory errors) with OpenMPI - and code in PETSc
> > library that uses MPI_Win_fence().
> > Vagrind shows memory corruption deep inside OpenMPI function stack.
> > I'm attaching a potential patch that appears to fix this issue for us.
> > [the corresponding valgrind trace is listed in the patch header]
> > Perhaps there is a more appropriate fix for this memory corruption. Could
> > you check on this?
> > [Sorry I don't have a pure MPI test code to demonstrate this error -
> > but a PETSc test example code consistantly reproduces this issue]
> > Thanks,
> > Satish<openmpi-1.8.4.patch>
> Jeff Squyres
> For corporate legal information go to:
> http://www.cisco.com/web/about/doing_business/legal/cri/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150501/3b3a9df4/attachment.html>
