[petsc-dev] Zoltan 3.81
Michael Lange michael.lange at imperial.ac.uk
Thu Apr 30 10:43:31 CDT 2015
On 30/04/15 14:19, Matthew Knepley wrote:
> On Thu, Apr 30, 2015 at 3:47 PM, Rhodri Davies
> <rhodri.davies at anu.edu.au <mailto:rhodri.davies at anu.edu.au>> wrote:
>     Dear Devs,
>     Would it be possible for you to update the version of Zoltan
>     packaged with PETSc to version 3.8.1? This version upgrades
>     Zoltan's interface to ParMETIS v4 and Scotch v6, which are the
>     versions of these libraries that PETSc currently defaults to.
> I can do this when I get home. Note that we are not really using this
> in PETSc now, do you could just install it if you want.
>     On a related note, is there currently a way to pass the Zoltan
>     configure flag “ -enable-f90interface", to the zoltan build,
>     through PETSc? In Fluidity, we currently depend on these fortran
>     interfaces (.mod files), so this option would be highly desirable
>     for us. If it’s not currently possible, could you add an
>     optional “--with-zoltan-fortran-interfaces” to PETSc configure?
> Yes, this is easy to pass. Note that Michael Lange has recently done
> some great work on expanding
> Fluidity to use DMPlex for PETSc for dynamic rebalancing. Have you
> talked to him? I think it will be
> ready in Fluidity later this year.
Hi Matt,
Unfortunately, Zoltan is used in multiple places in Fluidity, so there
will still be a dependency overlap for a while. A version update would
thus be much appreciated.
Michael
>   Thanks,
>      Matt
>     Best wishes,
>     Rhodri
>     ARC Future Fellow
>     Research School of Earth Sciences
>     The Australian National University
>     Canberra, ACT, 0200, Australia
>     T: +61 (0)2 6125 3643 <tel:%2B61%20%280%292%206125%203643>
>     E: rhodri.davies at anu.edu.au <mailto:rhodri.davies at anu.edu.au>
>     W: http://rses.anu.edu.au/people/dr-rhodri-davies
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150430/5d677e77/attachment.html>
