[petsc-dev] failed nightly
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Apr 29 20:22:42 CDT 2015
  Well ok. Report to the OpenMP developers and have --download-openmp use your patched version.
   Barry
> On Apr 29, 2015, at 7:06 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> The following change to openmpi appears to get rid of this error [and valgrind messages]
> I haven't checked closely to see what the actual bug is though..
> Satish
> $ diff -Nru ompi/datatype/ompi_datatype_args.c~ ompi/datatype/ompi_datatype_args.c
> --- ompi/datatype/ompi_datatype_args.c~         2014-10-03 15:32:23.000000000 -0500
> +++ ompi/datatype/ompi_datatype_args.c          2015-04-29 19:00:03.425618061 -0500
> @@ -84,7 +84,7 @@
>     do {        \
>         int length = sizeof(ompi_datatype_args_t) + (IC) * sizeof(int) + \
>             (AC) * sizeof(OPAL_PTRDIFF_TYPE) + (DC) * sizeof(MPI_Datatype); \
> -        char* buf = (char*)malloc( length );                            \
> +        char* buf = (char*)malloc( length+8 );                           \
>         ompi_datatype_args_t* pArgs = (ompi_datatype_args_t*)buf;       \
>         pArgs->ci = (IC);                                               \
>         pArgs->ca = (AC);                                               \
> On Fri, 10 Apr 2015, Barry Smith wrote:
>>  Not testing something that doesn't work in order to not have an error in the tests doesn't seem right to me. Shouldn't the window stuff be fixed or removed rather than leaving buggy code?
>>  barry
>>> On Apr 10, 2015, at 2:45 AM, Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk> wrote:
>>> (cc'ing petsc-dev as well)
>>>> On 10 Apr 2015, at 00:51, Satish Balay <balay at mcs.anl.gov> wrote:
>>>> Its likely a codebug some where. MPICH build also gives a valgrind trace.
>>> It's probable that the OMPI implementation is buggy enough to completely not work.  I'm a little confused by the MPICH issue.  I don't understand enough about the datatype implementation in the window SF type to know if this is a PETSc issue, or an MPICH one.  I note in passing that all the ex1 tests exhibit a similar valgrind trace.
>>> For ex2 at least, maybe the simplest option is to turn off the window test entirely.  Like this:
>>> diff --git a/src/vec/is/sf/examples/tutorials/makefile b/src/vec/is/sf/examples/tutorials
>>> index aeaf1e4..e7774c5 100644
>>> --- a/src/vec/is/sf/examples/tutorials/makefile
>>> +++ b/src/vec/is/sf/examples/tutorials/makefile
>>> @@ -86,7 +86,7 @@ runex2_window:
>>>          ${RM} -f ex2.tmp
>>> TESTEXAMPLES_C             = ex1.PETSc runex1_basic runex1_2_basic runex1_3_basic runex1
>>> -                                ex2.PETSc runex2_basic runex2_window ex2.rm
>>> +                                ex2.PETSc runex2_basic ex2.rm
>>> TESTEXAMPLES_C_X           =
>>> TESTEXAMPLES_FORTRAN       =
>>> TESTEXAMPLES_FORTRAN_MPIUNI =
>>> Lawrence
>>>> Satish
>>>> balay at asterix /home/balay/petsc/src/vec/is/sf/examples/tutorials (master=)
>>>> $ mpiexec -n 2 valgrind --tool=memcheck -q --dsymutil=yes --num-callers=40 --track-origins=yes ./ex2 -sf_type window
>>>> PetscSF Object: 2 MPI processes
>>>> type: window
>>>>  synchronization=FENCE sort=rank-order
>>>> [0] Number of roots=1, leaves=2, remote ranks=2
>>>> [0] 0 <- (0,0)
>>>> [0] 1 <- (1,0)
>>>> [1] Number of roots=1, leaves=2, remote ranks=2
>>>> [1] 0 <- (1,0)
>>>> [1] 1 <- (0,0)
>>>> ==29265== Syscall param writev(vector[...]) points to uninitialised byte(s)
>>>> ==29265==    at 0x8F474E7: writev (in /usr/lib64/libc-2.20.so)
>>>> ==29265==    by 0x894AD87: MPL_large_writev (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29265==    by 0x8941A48: MPIDU_Sock_writev (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29265==    by 0x892AC7D: MPIDI_CH3_iStartMsgv (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29265==    by 0x8911D08: recv_rma_msg (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29265==    by 0x8913D46: MPIDI_Win_fence (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29265==    by 0x88C91EB: PMPI_Win_fence (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29265==    by 0x50FB025: PetscSFRestoreWindow (sfwindow.c:348)
>>>> ==29265==    by 0x50FD4BF: PetscSFBcastEnd_Window (sfwindow.c:510)
>>>> ==29265==    by 0x5123CD9: PetscSFBcastEnd (sf.c:957)
>>>> ==29265==    by 0x401CAF: main (ex2.c:81)
>>>> ==29265==  Address 0x99436ec is 108 bytes inside a block of size 208 alloc'd
>>>> ==29265==    at 0x4C29BCF: malloc (in /usr/lib64/valgrind/vgpreload_memcheck-amd64-linux.so)
>>>> ==29265==    by 0x890DA35: MPIDI_Get (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29265==    by 0x88C406A: PMPI_Get (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29265==    by 0x50FD0DA: PetscSFBcastBegin_Window (sfwindow.c:495)
>>>> ==29265==    by 0x51235B5: PetscSFBcastBegin (sf.c:924)
>>>> ==29265==    by 0x401BD3: main (ex2.c:79)
>>>> ==29265==  Uninitialised value was created by a heap allocation
>>>> ==29265==
>>>> ==29266== Syscall param writev(vector[...]) points to uninitialised byte(s)
>>>> ==29266==    at 0x8F474E7: writev (in /usr/lib64/libc-2.20.so)
>>>> ==29266==    by 0x894AD87: MPL_large_writev (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29266==    by 0x8941A48: MPIDU_Sock_writev (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29266==    by 0x892AC7D: MPIDI_CH3_iStartMsgv (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29266==    by 0x8911D08: recv_rma_msg (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29266==    by 0x8913D46: MPIDI_Win_fence (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29266==    by 0x88C91EB: PMPI_Win_fence (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29266==    by 0x50FB025: PetscSFRestoreWindow (sfwindow.c:348)
>>>> ==29266==    by 0x50FD4BF: PetscSFBcastEnd_Window (sfwindow.c:510)
>>>> ==29266==    by 0x5123CD9: PetscSFBcastEnd (sf.c:957)
>>>> ==29266==    by 0x401CAF: main (ex2.c:81)
>>>> ==29266==  Address 0x98d16dc is 108 bytes inside a block of size 208 alloc'd
>>>> ==29266==    at 0x4C29BCF: malloc (in /usr/lib64/valgrind/vgpreload_memcheck-amd64-linux.so)
>>>> ==29266==    by 0x890DA35: MPIDI_Get (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29266==    by 0x88C406A: PMPI_Get (in /home/balay/soft/mpich-3.1.3/lib/libmpi.so.12.0.4)
>>>> ==29266==    by 0x50FD0DA: PetscSFBcastBegin_Window (sfwindow.c:495)
>>>> ==29266==    by 0x51235B5: PetscSFBcastBegin (sf.c:924)
>>>> ==29266==    by 0x401BD3: main (ex2.c:79)
>>>> ==29266==  Uninitialised value was created by a heap allocation
>>>> ==29266==
>>>> Vec Object: 2 MPI processes
>>>> type: mpi
>>>> Process [0]
>>>> 0
>>>> 1
>>>> Process [1]
>>>> 1
>>>> 0
>>>> type: mpi
>>>> Process [0]
>>>> 10
>>>> 11
>>>> Process [1]
>>>> 11
>>>> 10
>>>> On Thu, 9 Apr 2015, Satish Balay wrote:
>>>>> here is a better valgrind trace..
>>>>> satish
>>>>> $ /home/balay/petsc/arch-ompi/bin/mpiexec -n 2 valgrind --tool=memcheck -q --dsymutil=yes --num-callers=40 --track-origins=yes ./ex2 -sf_type window
>>>>> type: window
>>>>> [0] 0 <- (0,0)
>>>>> [0] 1 <- (1,0)
>>>>> [1] 0 <- (1,0)
>>>>> [1] 1 <- (0,0)
>>>>> ==14815== Invalid write of size 2
>>>>> ==14815==    at 0x4C2E36B: memcpy@@GLIBC_2.14 (in /usr/lib64/valgrind/vgpreload_memcheck-amd64-linux.so)
>>>>> ==14815==    by 0x8AFDABD: ompi_datatype_set_args (ompi_datatype_args.c:167)
>>>>> ==14815==    by 0x8AFF0F3: __ompi_datatype_create_from_args (ompi_datatype_args.c:718)
>>>>> ==14815==    by 0x8AFEC0E: __ompi_datatype_create_from_packed_description (ompi_datatype_args.c:649)
>>>>> ==14815==    by 0x8AFF5D6: ompi_datatype_create_from_packed_description (ompi_datatype_args.c:788)
>>>>> ==14815==    by 0xF727F0E: ompi_osc_base_datatype_create (osc_base_obj_convert.h:52)
>>>>> ==14815==    by 0xF728424: datatype_create (osc_rdma_data_move.c:333)
>>>>> ==14815==    by 0xF72887D: process_get (osc_rdma_data_move.c:536)
>>>>> ==14815==    by 0xF72A856: process_frag (osc_rdma_data_move.c:1593)
>>>>> ==14815==    by 0xF72AA35: ompi_osc_rdma_callback (osc_rdma_data_move.c:1656)
>>>>> ==14815==    by 0xECCF0DD: ompi_request_complete (request.h:402)
>>>>> ==14815==    by 0xECCF4EA: recv_request_pml_complete (pml_ob1_recvreq.h:181)
>>>>> ==14815==    by 0xECCFF87: mca_pml_ob1_recv_frag_callback_match (pml_ob1_recvfrag.c:243)
>>>>> ==14815==    by 0xE68F875: mca_btl_vader_check_fboxes (btl_vader_fbox.h:220)
>>>>> ==14815==    by 0xE690D82: mca_btl_vader_component_progress (btl_vader_component.c:695)
>>>>> ==14815==    by 0x9A9E9F2: opal_progress (opal_progress.c:187)
>>>>> ==14815==    by 0xECCA70A: opal_condition_wait (condition.h:78)
>>>>> ==14815==    by 0xECCA7F4: ompi_request_wait_completion (request.h:381)
>>>>> ==14815==    by 0xECCAF69: mca_pml_ob1_recv (pml_ob1_irecv.c:109)
>>>>> ==14815==    by 0xFD8938D: ompi_coll_tuned_reduce_intra_basic_linear (coll_tuned_reduce.c:677)
>>>>> ==14815==    by 0xFD79C26: ompi_coll_tuned_reduce_intra_dec_fixed (coll_tuned_decision_fixed.c:386)
>>>>> ==14815==    by 0xF0F3B91: mca_coll_basic_reduce_scatter_block_intra (coll_basic_reduce_scatter_block.c:96)
>>>>> ==14815==    by 0xF72BC58: ompi_osc_rdma_fence (osc_rdma_active_target.c:140)
>>>>> ==14815==    by 0x8B47078: PMPI_Win_fence (pwin_fence.c:59)
>>>>> ==14815==    by 0x5106D8F: PetscSFRestoreWindow (sfwindow.c:348)
>>>>> ==14815==    by 0x51092DA: PetscSFBcastEnd_Window (sfwindow.c:510)
>>>>> ==14815==    by 0x51303D6: PetscSFBcastEnd (sf.c:957)
>>>>> ==14815==    by 0x401DD3: main (ex2.c:81)
>>>>> ==14815==  Address 0x101c3b98 is 0 bytes after a block of size 72 alloc'd
>>>>> ==14815==    at 0x4C29BCF: malloc (in /usr/lib64/valgrind/vgpreload_memcheck-amd64-linux.so)
>>>>> ==14815==    by 0x8AFD755: ompi_datatype_set_args (ompi_datatype_args.c:123)
>>>>> ==14815==
>>>>> ==14816== Invalid write of size 2
>>>>> ==14816==    at 0x4C2E36B: memcpy@@GLIBC_2.14 (in /usr/lib64/valgrind/vgpreload_memcheck-amd64-linux.so)
>>>>> ==14816==    by 0x8AFDABD: ompi_datatype_set_args (ompi_datatype_args.c:167)
>>>>> ==14816==    by 0x8AFF0F3: __ompi_datatype_create_from_args (ompi_datatype_args.c:718)
>>>>> ==14816==    by 0x8AFEC0E: __ompi_datatype_create_from_packed_description (ompi_datatype_args.c:649)
>>>>> ==14816==    by 0x8AFF5D6: ompi_datatype_create_from_packed_description (ompi_datatype_args.c:788)
>>>>> ==14816==    by 0xF727F0E: ompi_osc_base_datatype_create (osc_base_obj_convert.h:52)
>>>>> ==14816==    by 0xF728424: datatype_create (osc_rdma_data_move.c:333)
>>>>> ==14816==    by 0xF72887D: process_get (osc_rdma_data_move.c:536)
>>>>> ==14816==    by 0xF72A856: process_frag (osc_rdma_data_move.c:1593)
>>>>> ==14816==    by 0xF72AA35: ompi_osc_rdma_callback (osc_rdma_data_move.c:1656)
>>>>> ==14816==    by 0xECCF0DD: ompi_request_complete (request.h:402)
>>>>> ==14816==    by 0xECCF4EA: recv_request_pml_complete (pml_ob1_recvreq.h:181)
>>>>> ==14816==    by 0xECCFF87: mca_pml_ob1_recv_frag_callback_match (pml_ob1_recvfrag.c:243)
>>>>> ==14816==    by 0xE68F875: mca_btl_vader_check_fboxes (btl_vader_fbox.h:220)
>>>>> ==14816==    by 0xE690D82: mca_btl_vader_component_progress (btl_vader_component.c:695)
>>>>> ==14816==    by 0x9A9E9F2: opal_progress (opal_progress.c:187)
>>>>> ==14816==    by 0xECCA70A: opal_condition_wait (condition.h:78)
>>>>> ==14816==    by 0xECCA7F4: ompi_request_wait_completion (request.h:381)
>>>>> ==14816==    by 0xECCAF69: mca_pml_ob1_recv (pml_ob1_irecv.c:109)
>>>>> ==14816==    by 0xFD8D951: ompi_coll_tuned_scatter_intra_basic_linear (coll_tuned_scatter.c:231)
>>>>> ==14816==    by 0xFD7A66D: ompi_coll_tuned_scatter_intra_dec_fixed (coll_tuned_decision_fixed.c:769)
>>>>> ==14816==    by 0xF0F3BDB: mca_coll_basic_reduce_scatter_block_intra (coll_basic_reduce_scatter_block.c:102)
>>>>> ==14816==    by 0xF72BC58: ompi_osc_rdma_fence (osc_rdma_active_target.c:140)
>>>>> ==14816==    by 0x8B47078: PMPI_Win_fence (pwin_fence.c:59)
>>>>> ==14816==    by 0x5106D8F: PetscSFRestoreWindow (sfwindow.c:348)
>>>>> ==14816==    by 0x51092DA: PetscSFBcastEnd_Window (sfwindow.c:510)
>>>>> ==14816==    by 0x51303D6: PetscSFBcastEnd (sf.c:957)
>>>>> ==14816==    by 0x401DD3: main (ex2.c:81)
>>>>> ==14816==  Address 0x101bb398 is 0 bytes after a block of size 72 alloc'd
>>>>> ==14816==    at 0x4C29BCF: malloc (in /usr/lib64/valgrind/vgpreload_memcheck-amd64-linux.so)
>>>>> ==14816==    by 0x8AFD755: ompi_datatype_set_args (ompi_datatype_args.c:123)
>>>>> ==14816==
>>>>> type: mpi
>>>>> Process [0]
>>>>> 0
>>>>> 1
>>>>> Process [1]
>>>>> 1
>>>>> 0
>>>>> type: mpi
>>>>> Process [0]
>>>>> 10
>>>>> 11
>>>>> Process [1]
>>>>> 11
>>>>> 10
>>>>> On Thu, 9 Apr 2015, Barry Smith wrote:
>>>>>> Satish,
>>>>>> Why are you telling me :-). Tell the person who's been pushing this stuff into PETSc and he can debug it.
>>>>>> Barry
>>>>>> This is why "my part" of PETSc only uses MPI 1.1 :-)
>>>>>>> On Apr 9, 2015, at 5:48 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>>>>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/08/examples_master_arch-linux-pkgs-opt_crank.log
>>>>>>> The following test is hanging - perhaps --download-openmpi is the trigger.
>>>>>>> petsc    14547  0.0  0.0  12312  1220 ?        S    13:56   0:00 /bin/sh -c /sandbox/petsc/petsc.clone/arch-linux-pkgs-opt/bin/mpiexec -n 2 ./ex2 -sf_type window > ex2.tmp 2>&1; \?          /usr/bin/diff -w output/ex2_window.out ex2.tmp || printf "/sandbox/petsc/petsc.clone/src/vec/is/sf/examples/tutorials\nPossible problem with ex2_window, diffs above\n=========================================\n"; \?          /bin/rm -f -f ex2.tmp
>>>>>>> I can reproduce on my laptop [with the following trace].
>>>>>>> Satish
>>>>>>> $ /home/balay/petsc/arch-ompi/bin/mpiexec -n 2 ./ex2 -sf_type window
>>>>>>> type: window
>>>>>>> [0] 0 <- (0,0)
>>>>>>> [0] 1 <- (1,0)
>>>>>>> [1] 0 <- (1,0)
>>>>>>> [1] 1 <- (0,0)
>>>>>>> *** Error in `./ex2': free(): invalid next size (fast): 0x0000000002395ed0 ***
>>>>>>> [asterix:14290] *** Process received signal ***
>>>>>>> [asterix:14290] Signal: Aborted (6)
>>>>>>> [asterix:14290] Signal code:  (-6)
>>>>>>> ======= Backtrace: =========
>>>>>>> /lib64/libc.so.6(+0x77d9e)[0x[asterix:14290] [ 0] /lib64/libpthread.so.0(+0x100d0)[0x7f331fac10d0]
>>>>>>> [asterix:14290] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x7f331f7288d7]
>>>>>>> [asterix:14290] [ 2] /home/balay/petsc/arch-ompi/lib/libmpi.so.1(ompi_datatype_release_args/lib64/libc.so.6(abort+0x16a)[0x7f331f72a53a]
>>>>>>> [asterix:14290] [ 3] /home/balay/petsc/arch-ompi/lib/libmpi.so.1(/lib64/libc.so.6(+0x77da3)[0x7f331f76bda3]
>>>>>>> [asterix:14290] [ 4] +0x508e3)[0x7f9018c898e3]
>>>>>>> /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0x11773/lib64/libc.so.6(cfree+0x5b5)[0x7f331f7779f5]
>>>>>>> [asterix:14290] [ 5] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0x12ece)[0x7f900f73aece]
>>>>>>> /home/balay/petsc/arch-ompi/lib/openmpi/mca_osc_rdma.so(+0x862a)[0x7f900ecdb62a]
>>>>>>> /home/balay/petsc/arch-ompi/lib/openmpi/mca_osc_rdma.so(+0x8a15/home/balay/petsc/arch-ompi/lib/libmpi.so.1(ompi_datatype_release_args+0x12b)[0x7f331ff33627]
>>>>>>> [asterix:14290] [ 6] /home/balay/petsc/arch-ompi/lib/openmpi/mca_osc_rdma.so(+0xbac7)[0x7f900ecdeac7]
>>>>>>> /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0xc0de)[0x7f900f7340de]
>>>>>>> /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0xc4eb)[0x7f900f7344eb]
>>>>>>> /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(mca_pml_ob1_recv_frag_callback_match+0x2ed)[0x7f900f734f88]
>>>>>>> /home/balay/petsc/arch-ompi/lib/openmpi/mca_btl_vader.so(+0x3876)[0x7f9014009876]
>>>>>>> /home/balay/petsc/arch-ompi/lib/openmpi/mca_btl_vader.so(+0x4d83)[0x7f901400ad83]
>>>>>>> /home/balay/petsc/arch-ompi/lib/libopen-pal.so.6(opal_progress+0xa2)[0x7f9017cca9f3]
>>>>>>> /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0x770b)[0x7f900f72f70b]
>>>>>>> /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0x77f5)[0x7f900f72f7f5]
>>>>>>> /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(mca_pml_ob1_recv+0x1c6)[0x7f900f72ff6a]
>>>>>>> /home/balay/petsc/arch-ompi/lib/openmpi/mca_coll_tuned.so(ompi_coll_tuned_scatter_intra_basic_linear+0x76)[0x7f900e689952]
>>>>>>> /home/balay/petsc/arch-ompi/lib/openmpi/mca_coll_tuned.so(ompi_coll_tuned_scatter_intra_dec_fixed+0x112)[0x7f900e67666e]
>>>>>>> /home/balay/petsc/arch-ompi/lib/openmpi/mca_coll_basic.so(mca_coll_basic_reduce_scatter_block_intra+0x188)[0x7f900f319bdc]
>>>>>>> /home/balay/petsc/arch-ompi/lib/openmpi/mca_osc_rdma.so(ompi_osc_rdma_fence+0x125)[0x7f900ecdfc59]
>>>>>>> /home/balay/petsc/arch-ompi/lib/libmpi.so.1(MPI_Win_fence+0x116)[0x7f9018cd1079]
>>>>>>> /home/balay/petsc/arch-ompi/lib/libmpi.so.1(+0x508e3)[0x7f331ff348e3]
>>>>>>> [asterix:14290] [ 7] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0x11773)[0x7f3316910773]
>>>>>>> [asterix:14290] [ 8] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0x12ece)[0x7f3316911ece]
>>>>>>> [asterix:14290] [ 9] /home/balay/petsc/arch-ompi/lib/openmpi/mca_osc_rdma.so(+0x862a)[0x7f3315eb262a]
>>>>>>> [asterix:14290] [10] /home/balay/petsc/arch-ompi/lib/openmpi/mca_osc_rdma.so(+0x8a15)[0x7f3315eb2a15]
>>>>>>> [asterix:14290] [11] /home/balay/petsc/arch-ompi/lib/openmpi/mca_osc_rdma.so(+0xbac7)[0x7f3315eb5ac7]
>>>>>>> [asterix:14290] [12] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0xc0de)[0x7f331690b0de]
>>>>>>> [asterix:14290] [13] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0xc4eb)[0x7f331690b4eb]
>>>>>>> [asterix:14290] [14] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(mca_pml_ob1_recv_frag_callback_match+0x2ed)[0x7f331690bf88]
>>>>>>> [asterix:14290] [15] /home/balay/petsc/arch-ompi/lib/openmpi/mca_btl_vader.so(+0x3876)[0x7f3316f4a876]
>>>>>>> [asterix:14290] [16] /home/balay/petsc/arch-ompi/lib/openmpi/mca_btl_vader.so(+0x4d83)[0x7f3316f4bd83]
>>>>>>> [asterix:14290] [17] /home/balay/petsc/arch-ompi/lib/libopen-pal.so.6(opal_progress+0xa2)[0x7f331ef759f3]
>>>>>>> [asterix:14290] [18] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0x770b)[0x7f331690670b]
>>>>>>> [asterix:14290] [19] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0x77f5)[0x7f33169067f5]
>>>>>>> [asterix:14290] [20] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(mca_pml_ob1_recv+0x1c6)[0x7f3316906f6a]
>>>>>>> [asterix:14290] [21] /home/balay/petsc/arch-ompi/lib/openmpi/mca_coll_tuned.so(ompi_coll_tuned_reduce_intra_basic_linear+0x1cb)[0x7f331585c38e]
>>>>>>> [asterix:14290] [22] /home/balay/petsc/arch-ompi/lib/openmpi/mca_coll_tuned.so(ompi_coll_tuned_reduce_intra_dec_fixed+0x1a6)[0x7f331584cc27]
>>>>>>> [asterix:14290] [23] /home/balay/petsc/arch-ompi/lib/openmpi/mca_coll_basic.so(mca_coll_basic_reduce_scatter_block_intra+0x13e)[0x7f33164f0b92]
>>>>>>> [asterix:14290] [24] /home/balay/petsc/arch-ompi/lib/openmpi/mca_osc_rdma.so(ompi_osc_rdma_fence+0x125)[0x7f3315eb6c59]
>>>>>>> [asterix:14290] [25] /home/balay/petsc/arch-ompi/lib/libmpi.so.1(MPI_Win_fence+0x116)[0x7f331ff7c079]
>>>>>>> [asterix:14290] [26] /home/balay/petsc/arch-ompi/lib/libpetsc.so.3.05(+0x2d1d90)[0x7f3322855d90]
>>>>>>> [asterix:14290] [27] /home/balay/petsc/arch-ompi/lib/libpetsc.so.3.05(PetscSFBcastEnd_Window+0x218)[0x7f33228582db]
>>>>>>> [asterix:14290] [28] /home/balay/petsc/arch-ompi/lib/libpetsc.so.3.05(PetscSFBcastEnd+0x4eb)[0x7f332287f3d7]
>>>>>>> [asterix:14290] [29] ./ex2[0x401dd4]
>>>>>>> [asterix:14290] *** End of error message ***
>>>>>>> [asterix:14291] *** Process received signal ***
>>>>>>> [asterix:14291] Signal: Aborted (6)
>>>>>>> [asterix:14291] Signal code:  (-6)
>>>>>>> [asterix:14291] [ 0] /lib64/libpthread.so.0(+0x100d0)[0x7f90188160d0]
>>>>>>> [asterix:14291] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x7f901847d8d7]
>>>>>>> [asterix:14291] [ 2] /lib64/libc.so.6(abort+0x16a)[0x7f901847f53a]
>>>>>>> [asterix:14291] [ 3] /lib64/libc.so.6(+0x77da3)[0x7f90184c0da3]
>>>>>>> [asterix:14291] [ 4] /lib64/libc.so.6(cfree+0x5b5)[0x7f90184cc9f5]
>>>>>>> [asterix:14291] [ 5] /home/balay/petsc/arch-ompi/lib/libmpi.so.1(ompi_datatype_release_args+0x12b)[0x7f9018c88627]
>>>>>>> [asterix:14291] [ 6] /home/balay/petsc/arch-ompi/lib/libmpi.so.1(+0x508e3)[0x7f9018c898e3]
>>>>>>> [asterix:14291] [ 7] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0x11773)[0x7f900f739773]
>>>>>>> [asterix:14291] [ 8] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0x12ece)[0x7f900f73aece]
>>>>>>> [asterix:14291] [ 9] /home/balay/petsc/arch-ompi/lib/openmpi/mca_osc_rdma.so(+0x862a)[0x7f900ecdb62a]
>>>>>>> [asterix:14291] [10] /home/balay/petsc/arch-ompi/lib/openmpi/mca_osc_rdma.so(+0x8a15)[0x7f900ecdba15]
>>>>>>> [asterix:14291] [11] /home/balay/petsc/arch-ompi/lib/openmpi/mca_osc_rdma.so(+0xbac7)[0x7f900ecdeac7]
>>>>>>> [asterix:14291] [12] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0xc0de)[0x7f900f7340de]
>>>>>>> [asterix:14291] [13] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0xc4eb)[0x7f900f7344eb]
>>>>>>> [asterix:14291] [14] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(mca_pml_ob1_recv_frag_callback_match+0x2ed)[0x7f900f734f88]
>>>>>>> [asterix:14291] [15] /home/balay/petsc/arch-ompi/lib/openmpi/mca_btl_vader.so(+0x3876)[0x7f9014009876]
>>>>>>> [asterix:14291] [16] /home/balay/petsc/arch-ompi/lib/openmpi/mca_btl_vader.so(+0x4d83)[0x7f901400ad83]
>>>>>>> [asterix:14291] [17] /home/balay/petsc/arch-ompi/lib/libopen-pal.so.6(opal_progress+0xa2)[0x7f9017cca9f3]
>>>>>>> [asterix:14291] [18] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0x770b)[0x7f900f72f70b]
>>>>>>> [asterix:14291] [19] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(+0x77f5)[0x7f900f72f7f5]
>>>>>>> [asterix:14291] [20] /home/balay/petsc/arch-ompi/lib/openmpi/mca_pml_ob1.so(mca_pml_ob1_recv+0x1c6)[0x7f900f72ff6a]
>>>>>>> [asterix:14291] [21] /home/balay/petsc/arch-ompi/lib/openmpi/mca_coll_tuned.so(ompi_coll_tuned_scatter_intra_basic_linear+0x76)[0x7f900e689952]
>>>>>>> [asterix:14291] [22] /home/balay/petsc/arch-ompi/lib/openmpi/mca_coll_tuned.so(ompi_coll_tuned_scatter_intra_dec_fixed+0x112)[0x7f900e67666e]
>>>>>>> [asterix:14291] [23] /home/balay/petsc/arch-ompi/lib/openmpi/mca_coll_basic.so(mca_coll_basic_reduce_scatter_block_intra+0x188)[0x7f900f319bdc]
>>>>>>> [asterix:14291] [24] /home/balay/petsc/arch-ompi/lib/openmpi/mca_osc_rdma.so(ompi_osc_rdma_fence+0x125)[0x7f900ecdfc59]
>>>>>>> [asterix:14291] [25] /home/balay/petsc/arch-ompi/lib/libmpi.so.1(MPI_Win_fence+0x116)[0x7f9018cd1079]
>>>>>>> [asterix:14291] [26] /home/balay/petsc/arch-ompi/lib/libpetsc.so.3.05(+0x2d1d90)[0x7f901b5aad90]
>>>>>>> [asterix:14291] [27] /home/balay/petsc/arch-ompi/lib/libpetsc.so.3.05(PetscSFBcastEnd_Window+0x218)[0x7f901b5ad2db]
>>>>>>> [asterix:14291] [28] /home/balay/petsc/arch-ompi/lib/libpetsc.so.3.05(PetscSFBcastEnd+0x4eb)[0x7f901b5d43d7]
>>>>>>> [asterix:14291] [29] ./ex2[0x401dd4]
>>>>>>> [asterix:14291] *** End of error message ***
>>>>>>> mpiexec noticed that process rank 0 with PID 14290 on node asterix exited on signal 6 (Aborted).
>>>>>>> $ /home/balay/petsc/arch-ompi/bin/mpiexec -n 2 valgrind --tool=memcheck -q ./ex2 -sf_type window
>>>>>>> type: window
>>>>>>> [0] 0 <- (0,0)
>>>>>>> [0] 1 <- (1,0)
>>>>>>> [1] 0 <- (1,0)
>>>>>>> [1] 1 <- (0,0)
>>>>>>> ==14349== Invalid write of size 2
>>>>>>> ==14349==    at 0x4C2E36B: memcpy@@GLIBC_2.14 (in /usr/lib64/valgrind/vgpreload_memcheck-amd64-linux.so)
>>>>>>> ==14349==    by 0x8AFDABD: ompi_datatype_set_args (ompi_datatype_args.c:167)
>>>>>>> ==14349==    by 0x8AFF0F3: __ompi_datatype_create_from_args (ompi_datatype_args.c:718)
>>>>>>> ==14349==    by 0x8AFEC0E: __ompi_datatype_create_from_packed_description (ompi_datatype_args.c:649)
>>>>>>> ==14349==    by 0x8AFF5D6: ompi_datatype_create_from_packed_description (ompi_datatype_args.c:788)
>>>>>>> ==14349==    by 0xF727F0E: ompi_osc_base_datatype_create (osc_base_obj_convert.h:52)
>>>>>>> ==14349==    by 0xF728424: datatype_create (osc_rdma_data_move.c:333)
>>>>>>> ==14349==    by 0xF72887D: process_get (osc_rdma_data_move.c:536)
>>>>>>> ==14349==    by 0xF72A856: process_frag (osc_rdma_data_move.c:1593)
>>>>>>> ==14349==    by 0xF72AA35: ompi_osc_rdma_callback (osc_rdma_data_move.c:1656)
>>>>>>> ==14349==    by 0xECCF0DD: ompi_request_complete (request.h:402)
>>>>>>> ==14349==    by 0xECCF4EA: recv_request_pml_complete (pml_ob1_recvreq.h:181)
>>>>>>> ==14349==  Address 0x101bf188 is 0 bytes after a block of size 72 alloc'd
>>>>>>> ==14349==    at 0x4C29BCF: malloc (in /usr/lib64/valgrind/vgpreload_memcheck-amd64-linux.so)
>>>>>>> ==14349==    by 0x8AFD755: ompi_datatype_set_args (ompi_datatype_args.c:123)
>>>>>>> ==14349==
>>>>>>> ==14348== Invalid write of size 2
>>>>>>> ==14348==    at 0x4C2E36B: memcpy@@GLIBC_2.14 (in /usr/lib64/valgrind/vgpreload_memcheck-amd64-linux.so)
>>>>>>> ==14348==    by 0x8AFDABD: ompi_datatype_set_args (ompi_datatype_args.c:167)
>>>>>>> ==14348==    by 0x8AFF0F3: __ompi_datatype_create_from_args (ompi_datatype_args.c:718)
>>>>>>> ==14348==    by 0x8AFEC0E: __ompi_datatype_create_from_packed_description (ompi_datatype_args.c:649)
>>>>>>> ==14348==    by 0x8AFF5D6: ompi_datatype_create_from_packed_description (ompi_datatype_args.c:788)
>>>>>>> ==14348==    by 0xF727F0E: ompi_osc_base_datatype_create (osc_base_obj_convert.h:52)
>>>>>>> ==14348==    by 0xF728424: datatype_create (osc_rdma_data_move.c:333)
>>>>>>> ==14348==    by 0xF72887D: process_get (osc_rdma_data_move.c:536)
>>>>>>> ==14348==    by 0xF72A856: process_frag (osc_rdma_data_move.c:1593)
>>>>>>> ==14348==    by 0xF72AA35: ompi_osc_rdma_callback (osc_rdma_data_move.c:1656)
>>>>>>> ==14348==    by 0xECCF0DD: ompi_request_complete (request.h:402)
>>>>>>> ==14348==    by 0xECCF4EA: recv_request_pml_complete (pml_ob1_recvreq.h:181)
>>>>>>> ==14348==  Address 0x101c71b8 is 0 bytes after a block of size 72 alloc'd
>>>>>>> ==14348==    at 0x4C29BCF: malloc (in /usr/lib64/valgrind/vgpreload_memcheck-amd64-linux.so)
>>>>>>> ==14348==    by 0x8AFD755: ompi_datatype_set_args (ompi_datatype_args.c:123)
>>>>>>> ==14348==
>>>>>>> type: mpi
>>>>>>> Process [0]
>>>>>>> 0
>>>>>>> 1
>>>>>>> Process [1]
>>>>>>> 1
>>>>>>> 0
>>>>>>> type: mpi
>>>>>>> Process [0]
>>>>>>> 10
>>>>>>> 11
>>>>>>> Process [1]
>>>>>>> 11
>>>>>>> 10
