[petsc-dev] Seeming performance regression with GAMG
    Lawrence Mitchell
    lawrence.mitchell at imperial.ac.uk
    Mon Apr 27 10:06:30 CDT 2015
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Dear all,
we recently noticed a slowdown when using GAMG that I'm trying to
track down in a little more detail.  I'm solving an Hdiv-L2
"helmholtz" pressure correction using a schur complement.  I
precondition the schur complement with 'selfp', which morally looks
like a normal Helmholtz operator (except in the DG space).  The domain
is very anisotropic (a thin atmospheric shell), so getting round to
trying Toby's column-based coarsening plugin is on the horizon but I
haven't done it yet.
I don't have a good feel for exactly when things go worse, but here
are two data points:
A recentish master (e4b003c), and master from 26th Feb (30ab49e4).  I
notice in the former that MatPtAP takes significantly longer (full
logs below), different coarsening maybe?  As a point of comparison,
the PCSetup for Hypre takes ballpark half a second on the same operator.
I test with KSP ex6 (with a constant RHS):
Any ideas?
Cheers,
Lawrence
$ ./ex6-e4b003c -f helmholtz-sphere.dat  -ksp_type cg
- -ksp_convergence_test skip -ksp_max_it 2  -ksp_monitor -table
- -pc_type gamg  -log_summary -ksp_view
  0 KSP Residual norm 3.676132751311e-11
  1 KSP Residual norm 1.764616084171e-14
  2 KSP Residual norm 9.253867842133e-14
KSP Object: 1 MPI processes
  type: cg
  maximum iterations=2, initial guess is zero
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: gamg
    MG: type is MULTIPLICATIVE, levels=5 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
      GAMG specific options
        Threshold for dropping small values from graph 0
        AGG specific options
          Symmetric graph false
  Coarse grid solver -- level -------------------------------
    KSP Object:    (mg_coarse_)     1 MPI processes
      type: gmres
        GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
        GMRES: happy breakdown tolerance 1e-30
      maximum iterations=1, initial guess is zero
      using NONE norm type for convergence test
    PC Object:    (mg_coarse_)     1 MPI processes
      type: bjacobi
        block Jacobi: number of blocks = 1
        Local solve is same for all blocks, in the following KSP and
PC objects:
        KSP Object:        (mg_coarse_sub_)         1 MPI processes
          type: preonly
        PC Object:        (mg_coarse_sub_)         1 MPI processes
          type: lu
            LU: out-of-place factorization
            tolerance for zero pivot 2.22045e-14
            using diagonal shift on blocks to prevent zero pivot
[INBLOCKS]
            matrix ordering: nd
            factor fill ratio given 5, needed 1
              Factored matrix follows:
                Mat Object:                 1 MPI processes
                  type: seqaij
                  rows=3, cols=3
                  package used to perform factorization: petsc
                  total: nonzeros=9, allocated nonzeros=9
                  total number of mallocs used during MatSetValues
calls =0
                    using I-node routines: found 1 nodes, limit used is 5
          linear system matrix = precond matrix:
            type: seqaij
            rows=3, cols=3
            total number of mallocs used during MatSetValues calls =0
        type: seqaij
        rows=3, cols=3
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object:    (mg_levels_1_)     1 MPI processes
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = 0.0999929, max = 1.09992
        Chebyshev: eigenvalues estimated using gmres with translations
 [0 0.1; 0 1.1]
        KSP Object:        (mg_levels_1_esteig_)         1 MPI processes
          type: gmres
Gram-Schmidt Orthogonalization with no iterative refinement
          maximum iterations=10
          using nonzero initial guess
    PC Object:    (mg_levels_1_)     1 MPI processes
      type: sor
        SOR: type = local_symmetric, iterations = 1, local iterations
= 1, omega = 1
        type: seqaij
        rows=93, cols=93
        total: nonzeros=8649, allocated nonzeros=8649
          using I-node routines: found 19 nodes, limit used is 5
  Up solver (post-smoother) same as down solver (pre-smoother)
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object:    (mg_levels_2_)     1 MPI processes
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = 0.0998389, max = 1.09823
 [0 0.1; 0 1.1]
        KSP Object:        (mg_levels_2_esteig_)         1 MPI processes
          type: gmres
    PC Object:    (mg_levels_2_)     1 MPI processes
      type: sor
= 1, omega = 1
        type: seqaij
        rows=2991, cols=2991
        total: nonzeros=8.94608e+06, allocated nonzeros=8.94608e+06
          using I-node routines: found 599 nodes, limit used is 5
  Down solver (pre-smoother) on level 3 -------------------------------
    KSP Object:    (mg_levels_3_)     1 MPI processes
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = 0.0998975, max = 1.09887
 [0 0.1; 0 1.1]
        KSP Object:        (mg_levels_3_esteig_)         1 MPI processes
          type: gmres
    PC Object:    (mg_levels_3_)     1 MPI processes
      type: sor
= 1, omega = 1
        type: seqaij
        rows=35419, cols=35419
        total: nonzeros=1.55936e+07, allocated nonzeros=1.55936e+07
        total number of mallocs used during MatSetValues calls =1
          not using I-node routines
  Down solver (pre-smoother) on level 4 -------------------------------
    KSP Object:    (mg_levels_4_)     1 MPI processes
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = 0.1, max = 1.1
 [0 0.1; 0 1.1]
        KSP Object:        (mg_levels_4_esteig_)         1 MPI processes
          type: gmres
    PC Object:    (mg_levels_4_)     1 MPI processes
      type: sor
= 1, omega = 1
        type: seqaij
        rows=327680, cols=327680
        total: nonzeros=3.25828e+06, allocated nonzeros=3.25828e+06
    type: seqaij
helmholt   2 9e+03  gamg
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r
- -fCourier9' to print this document            ***
- ---------------------------------------------- PETSc Performance
Summary: ----------------------------------------------
./ex6-master on a arch-linux2-c-opt named yam.doc.ic.ac.uk with 1
processor, by lmitche1 Mon Apr 27 16:03:36 2015
Using Petsc Development GIT revision: v3.5.3-2602-ga9b180a  GIT Date:
2015-04-07 20:34:49 -0500
                         Max       Max/Min        Avg      Total
Time (sec):           1.072e+02      1.00000   1.072e+02
Objects:              2.620e+02      1.00000   2.620e+02
Flops:                4.582e+10      1.00000   4.582e+10  4.582e+10
Flops/sec:            4.275e+08      1.00000   4.275e+08  4.275e+08
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
Flop counting convention: 1 flop = 1 real number operation of type
(multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length
N --> 2N flops
                            and VecAXPY() for complex vectors of
length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  ---
Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts
%Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.0898e-01   0.1%  7.4996e+06   0.0%  0.000e+00
 0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 1:       mystage 1: 1.0466e+02  97.6%  4.2348e+10  92.4%  0.000e+00
 2:       mystage 2: 2.4395e+00   2.3%  3.4689e+09   7.6%  0.000e+00
See the 'Profiling' chapter of the users' manual for details on
interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush()
and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in
this phase
      %M - percent messages in this phase     %L - percent message
lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
Event                Count      Time (sec)     Flops
           --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg
len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
- --- Event Stage 0: Main Stage
ThreadCommRunKer       2 1.0 1.9073e-06 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult                1 1.0 4.4990e-03 1.0 6.19e+06 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   4 83  0  0  0  1376
MatAssemblyBegin       1 1.0 1.1921e-06 1.0 0.00e+00 0.0 0.0e+00
MatAssemblyEnd         1 1.0 1.0468e-02 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0  10  0  0  0  0     0
MatLoad                1 1.0 9.3672e-02 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0  86  0  0  0  0     0
VecNorm                1 1.0 9.1791e-05 1.0 6.55e+05 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  9  0  0  0  7140
VecSet                 5 1.0 3.1860e-03 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   3  0  0  0  0     0
VecAXPY                1 1.0 3.9697e-04 1.0 6.55e+05 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  9  0  0  0  1651
- --- Event Stage 1: mystage 1
MatMult               40 1.0 3.5990e-01 1.0 5.52e+08 1.0 0.0e+00
0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1535
MatConvert             4 1.0 1.2038e-01 1.0 0.00e+00 0.0 0.0e+00
MatScale              12 1.0 8.2839e-02 1.0 7.21e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   870
MatAssemblyBegin      31 1.0 1.4067e-05 1.0 0.00e+00 0.0 0.0e+00
MatAssemblyEnd        31 1.0 1.0995e-01 1.0 0.00e+00 0.0 0.0e+00
MatGetRow        1464732 1.0 8.5680e-02 1.0 0.00e+00 0.0 0.0e+00
MatCoarsen             4 1.0 2.4768e-02 1.0 0.00e+00 0.0 0.0e+00
MatAXPY                4 1.0 8.1362e-02 1.0 0.00e+00 0.0 0.0e+00
MatMatMult             4 1.0 6.0399e-01 1.0 6.39e+07 1.0 0.0e+00
0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   106
MatMatMultSym          4 1.0 4.4536e-01 1.0 0.00e+00 0.0 0.0e+00
MatMatMultNum          4 1.0 1.5859e-01 1.0 6.39e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   403
MatPtAP                4 1.0 1.0255e+02 1.0 4.15e+10 1.0 0.0e+00
0.0e+00 0.0e+00 96 91  0  0  0  98 98  0  0  0   405
MatPtAPSymbolic        4 1.0 6.1707e+01 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00 58  0  0  0  0  59  0  0  0  0     0
MatPtAPNumeric         4 1.0 4.0840e+01 1.0 4.15e+10 1.0 0.0e+00
0.0e+00 0.0e+00 38 91  0  0  0  39 98  0  0  0  1017
MatTrnMatMult          1 1.0 1.9648e-01 1.0 2.34e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   119
MatTrnMatMultSym       1 1.0 1.3640e-01 1.0 0.00e+00 0.0 0.0e+00
MatTrnMatMultNum       1 1.0 6.0079e-02 1.0 2.34e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   389
MatGetSymTrans         5 1.0 8.4374e-02 1.0 0.00e+00 0.0 0.0e+00
VecMDot               40 1.0 1.5124e-02 1.0 4.03e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2663
VecNorm               44 1.0 1.1821e-03 1.0 8.06e+06 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  6815
VecScale              44 1.0 1.4737e-03 1.0 4.03e+06 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2733
VecCopy                4 1.0 3.2711e-04 1.0 0.00e+00 0.0 0.0e+00
VecSet               143 1.0 2.7236e-02 1.0 0.00e+00 0.0 0.0e+00
VecAXPY                4 1.0 3.9601e-04 1.0 7.32e+05 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1849
VecMAXPY              44 1.0 1.9676e-02 1.0 4.76e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2419
VecAssemblyBegin       4 1.0 1.9073e-06 1.0 0.00e+00 0.0 0.0e+00
VecAssemblyEnd         4 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00
VecPointwiseMult      44 1.0 7.9026e-03 1.0 4.03e+06 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   510
VecSetRandom           4 1.0 3.6092e-03 1.0 0.00e+00 0.0 0.0e+00
VecNormalize          44 1.0 2.6934e-03 1.0 1.21e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4486
KSPGMRESOrthog        40 1.0 3.1765e-02 1.0 8.06e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2536
KSPSetUp              10 1.0 1.1930e-02 1.0 0.00e+00 0.0 0.0e+00
PCGAMGGraph_AGG        4 1.0 5.7353e-01 1.0 5.56e+07 1.0 0.0e+00
0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0    97
PCGAMGCoarse_AGG       4 1.0 2.5846e-01 1.0 2.34e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    90
PCGAMGProl_AGG         4 1.0 4.9806e-02 1.0 0.00e+00 0.0 0.0e+00
PCGAMGPOpt_AGG         4 1.0 1.2128e+00 1.0 7.38e+08 1.0 0.0e+00
0.0e+00 0.0e+00  1  2  0  0  0   1  2  0  0  0   608
GAMG: createProl       4 1.0 2.0973e+00 1.0 8.17e+08 1.0 0.0e+00
0.0e+00 0.0e+00  2  2  0  0  0   2  2  0  0  0   389
  Graph                8 1.0 5.7211e-01 1.0 5.56e+07 1.0 0.0e+00
  MIS/Agg              4 1.0 2.4861e-02 1.0 0.00e+00 0.0 0.0e+00
  SA: col data         4 1.0 7.6509e-04 1.0 0.00e+00 0.0 0.0e+00
  SA: frmProl0         4 1.0 4.6539e-02 1.0 0.00e+00 0.0 0.0e+00
  SA: smooth           4 1.0 1.2128e+00 1.0 7.38e+08 1.0 0.0e+00
GAMG: partLevel        4 1.0 1.0255e+02 1.0 4.15e+10 1.0 0.0e+00
PCSetUp                1 1.0 1.0465e+02 1.0 4.23e+10 1.0 0.0e+00
0.0e+00 0.0e+00 98 92  0  0  0 100100  0  0  0   405
- --- Event Stage 2: mystage 2
MatMult              121 1.0 1.0144e+00 1.0 1.61e+09 1.0 0.0e+00
0.0e+00 0.0e+00  1  4  0  0  0  42 47  0  0  0  1592
MatMultAdd            12 1.0 3.1757e-02 1.0 4.95e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   1  1  0  0  0  1558
MatMultTranspose      12 1.0 3.7137e-02 1.0 4.95e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   2  1  0  0  0  1332
MatSolve               6 1.0 9.2983e-06 1.0 9.00e+01 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    10
MatSOR               116 1.0 1.2805e+00 1.0 1.61e+09 1.0 0.0e+00
0.0e+00 0.0e+00  1  4  0  0  0  52 47  0  0  0  1260
MatLUFactorSym         1 1.0 1.5020e-05 1.0 0.00e+00 0.0 0.0e+00
MatLUFactorNum         1 1.0 5.9605e-06 1.0 1.60e+01 1.0 0.0e+00
MatResidual           12 1.0 1.0432e-01 1.0 1.67e+08 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   4  5  0  0  0  1599
MatGetRowIJ            1 1.0 2.1458e-06 1.0 0.00e+00 0.0 0.0e+00
MatGetOrdering         1 1.0 4.2915e-05 1.0 0.00e+00 0.0 0.0e+00
MatView                8 1.0 6.7115e-04 1.0 0.00e+00 0.0 0.0e+00
VecMDot               43 1.0 1.3515e-02 1.0 4.03e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   1  1  0  0  0  2980
VecTDot                4 1.0 1.1048e-03 1.0 2.62e+06 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2373
VecNorm               53 1.0 1.4720e-03 1.0 1.00e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  6809
VecScale              50 1.0 1.4396e-03 1.0 4.03e+06 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2798
VecCopy               21 1.0 3.6387e-03 1.0 0.00e+00 0.0 0.0e+00
VecSet               108 1.0 1.0684e-02 1.0 0.00e+00 0.0 0.0e+00
VecAXPY               15 1.0 2.1303e-03 1.0 4.09e+06 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1918
VecAYPX               97 1.0 1.1820e-02 1.0 1.16e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   985
VecAXPBYCZ            48 1.0 8.2519e-03 1.0 2.20e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0  2663
VecMAXPY              50 1.0 1.6957e-02 1.0 4.76e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   1  1  0  0  0  2807
VecNormalize          50 1.0 2.6865e-03 1.0 1.21e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4498
KSPGMRESOrthog        43 1.0 2.7892e-02 1.0 8.06e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   1  2  0  0  0  2888
KSPSetUp               5 1.0 2.9690e-03 1.0 0.00e+00 0.0 0.0e+00
KSPSolve               1 1.0 2.4374e+00 1.0 3.47e+09 1.0 0.0e+00
0.0e+00 0.0e+00  2  8  0  0  0 100100  0  0  0  1423
PCSetUp                1 1.0 9.3937e-05 1.0 1.60e+01 1.0 0.0e+00
PCSetUpOnBlocks        3 1.0 9.6798e-05 1.0 1.60e+01 1.0 0.0e+00
PCApply                3 1.0 2.4240e+00 1.0 3.45e+09 1.0 0.0e+00
0.0e+00 0.0e+00  2  8  0  0  0  99 99  0  0  0  1423
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants'
Mem.
Reports information only for process 0.
              Viewer     2              2         1520     0
              Matrix     1             10     54702412     0
              Vector     3             97     72154440     0
       Krylov Solver     0             11       146840     0
      Preconditioner     0              7         7332     0
           Index Set     0              3         2400     0
              Viewer     1              0            0     0
              Matrix    22             14    691989068     0
      Matrix Coarsen     4              4         2576     0
              Vector   125             91     67210200     0
       Krylov Solver    15              4       120864     0
      Preconditioner    15              8         7520     0
           Index Set     4              4         3168     0
         PetscRandom     4              4         2560     0
              Matrix     1              0            0     0
              Vector    60              0            0     0
           Index Set     5              2         1592     0
Average time to get PetscTime(): 0
#PETSc Option Table entries:
- -f helmholtz-sphere.dat
- -ksp_max_it 2
- -ksp_monitor
- -ksp_type cg
- -ksp_view
- -log_summary
- -matload_block_size 1
- -pc_type gamg
- -table
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --download-chaco=1 --download-ctetgen=1
- --download-exodusii=1 --download-hdf5=1 --download-hypre=1
- --download-metis=1 --download-ml=1 --download-mumps=1
- --download-netcdf=1 --download-parmetis=1 --download-ptscotch=1
- --download-scalapack=1 --download-superlu=1 --download-superlu_dist=1
- --download-triangle=1 --with-c2html=0 --with-debugging=0
- --with-make-np=32 --with-openmp=0 --with-pthreadclasses=0
- --with-shared-libraries=1 --with-threadcomm=0 PETSC_ARCH=arch-linux2-c-opt
Libraries compiled on Wed Apr  8 10:00:43 2015 on yam.doc.ic.ac.uk
Machine characteristics:
Linux-3.13.0-45-generic-x86_64-with-Ubuntu-14.04-trusty
Using PETSc directory: /data/lmitche1/src/deps/petsc
Using PETSc arch: arch-linux2-c-opt
Using C compiler: mpicc  -fPIC -Wall -Wwrite-strings
- -Wno-strict-aliasing -Wno-unknown-pragmas -O  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -fPIC -Wall -Wno-unused-variable
- -ffree-line-length-0 -Wno-unused-dummy-argument -O   ${FOPTFLAGS}
${FFLAGS}
Using include paths:
- -I/data/lmitche1/src/deps/petsc/arch-linux2-c-opt/include
- -I/data/lmitche1/src/deps/petsc/include
- -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries:
- -Wl,-rpath,/data/lmitche1/src/deps/petsc/arch-linux2-c-opt/lib
- -L/data/lmitche1/src/deps/petsc/arch-linux2-c-opt/lib -lpetsc
- -L/data/lmitche1/src/deps/petsc/arch-linux2-c-opt/lib -lcmumps
- -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lsuperlu_4.3
- -lsuperlu_dist_4.0 -lHYPRE -Wl,-rpath,/usr/lib/openmpi/lib
- -L/usr/lib/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.8
- -L/usr/lib/gcc/x86_64-linux-gnu/4.8
- -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu
- -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpi_cxx
- -lstdc++ -lscalapack -lml -lmpi_cxx -lstdc++ -lexoIIv2for -lexodus
- -llapack -lblas -lparmetis -ltriangle -lnetcdf -lmetis -lchaco
- -lctetgen -lX11 -lptesmumps -lptscotch -lptscotcherr -lscotch
- -lscotcherr -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lssl
- -lcrypto -lm -lmpi_f90 -lmpi_f77 -lgfortran -lm -lgfortran -lm
- -lquadmath -lm -lmpi_cxx -lstdc++ -lrt -lm -lz
- -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib
- -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.8
- -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl
- -lmpi -lhwloc -lgcc_s -lpthread -ldl
$ ./ex6-30ab49e4
  0 KSP Residual norm 3.679528502747e-11
  1 KSP Residual norm 1.410011347346e-14
  2 KSP Residual norm 2.871653636831e-14
  type: cg
  type: gamg
    MG: type is MULTIPLICATIVE, levels=3 cycles=v
      type: preonly
      type: bjacobi
PC objects:
          type: preonly
          type: lu
[INBLOCKS]
            matrix ordering: nd
                  type: seqaij
                  rows=592, cols=592
                  total: nonzeros=350464, allocated nonzeros=350464
calls =0
                    using I-node routines: found 119 nodes, limit used
is 5
            type: seqaij
            rows=592, cols=592
              using I-node routines: found 119 nodes, limit used is 5
        type: seqaij
        rows=592, cols=592
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = 0.0871826, max = 1.83084
      type: sor
= 1, omega = 1
        type: seqaij
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = 0.099472, max = 2.08891
      type: sor
= 1, omega = 1
        type: seqaij
    type: seqaij
Number of iterations =   2
Residual norm = 8368.22
./ex6-1ddf9fe on a test named yam.doc.ic.ac.uk with 1 processor, by
lmitche1 Mon Apr 27 16:02:36 2015
Using Petsc Release Version 3.5.2, unknown
Time (sec):           2.828e+01      1.00000   2.828e+01
Objects:              1.150e+02      1.00000   1.150e+02
Flops:                1.006e+10      1.00000   1.006e+10  1.006e+10
Flops/sec:            3.559e+08      1.00000   3.559e+08  3.559e+08
N --> 2N flops
 0:      Main Stage: 9.9010e-02   0.4%  7.4996e+06   0.1%  0.000e+00
 1:       mystage 1: 2.6509e+01  93.7%  8.4700e+09  84.2%  0.000e+00
 2:       mystage 2: 1.6704e+00   5.9%  1.5861e+09  15.8%  0.000e+00
Phase summary info:
this phase
ThreadCommRunKer       2 1.0 3.0994e-06 1.0 0.00e+00 0.0 0.0e+00
MatMult                1 1.0 7.2370e-03 1.0 6.19e+06 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   7 83  0  0  0   855
MatAssemblyBegin       1 1.0 1.9073e-06 1.0 0.00e+00 0.0 0.0e+00
MatAssemblyEnd         1 1.0 1.0748e-02 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0  11  0  0  0  0     0
MatLoad                1 1.0 8.5824e-02 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0  87  0  0  0  0     0
VecNorm                1 1.0 9.2983e-05 1.0 6.55e+05 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  9  0  0  0  7048
VecSet                 5 1.0 2.9252e-03 1.0 0.00e+00 0.0 0.0e+00
VecAXPY                1 1.0 4.6611e-04 1.0 6.55e+05 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  9  0  0  0  1406
MatMult               20 1.0 2.8699e-01 1.0 3.73e+08 1.0 0.0e+00
0.0e+00 0.0e+00  1  4  0  0  0   1  4  0  0  0  1301
MatConvert             2 1.0 8.3888e-02 1.0 0.00e+00 0.0 0.0e+00
MatScale               6 1.0 7.1905e-02 1.0 4.85e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0   675
MatAssemblyBegin      20 1.0 1.9789e-05 1.0 0.00e+00 0.0 0.0e+00
MatAssemblyEnd        20 1.0 1.1295e-01 1.0 0.00e+00 0.0 0.0e+00
MatGetRow        1452396 1.0 9.5270e-02 1.0 0.00e+00 0.0 0.0e+00
MatCoarsen             2 1.0 3.0676e-02 1.0 0.00e+00 0.0 0.0e+00
MatAXPY                2 1.0 8.2162e-02 1.0 0.00e+00 0.0 0.0e+00
MatMatMult             2 1.0 4.2625e-01 1.0 4.31e+07 1.0 0.0e+00
0.0e+00 0.0e+00  2  0  0  0  0   2  1  0  0  0   101
MatMatMultSym          2 1.0 3.0257e-01 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatMatMultNum          2 1.0 1.2364e-01 1.0 4.31e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0   349
MatPtAP                2 1.0 2.3871e+01 1.0 7.82e+09 1.0 0.0e+00
0.0e+00 0.0e+00 84 78  0  0  0  90 92  0  0  0   328
MatPtAPSymbolic        2 1.0 1.4329e+01 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00 51  0  0  0  0  54  0  0  0  0     0
MatPtAPNumeric         2 1.0 9.5422e+00 1.0 7.82e+09 1.0 0.0e+00
0.0e+00 0.0e+00 34 78  0  0  0  36 92  0  0  0   819
MatTrnMatMult          2 1.0 9.7712e-01 1.0 8.24e+07 1.0 0.0e+00
0.0e+00 0.0e+00  3  1  0  0  0   4  1  0  0  0    84
MatTrnMatMultSym       2 1.0 5.0258e-01 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
MatTrnMatMultNum       2 1.0 4.7454e-01 1.0 8.24e+07 1.0 0.0e+00
0.0e+00 0.0e+00  2  1  0  0  0   2  1  0  0  0   174
MatGetSymTrans         4 1.0 6.2370e-02 1.0 0.00e+00 0.0 0.0e+00
VecMDot               20 1.0 1.7304e-02 1.0 3.99e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2308
VecNorm               22 1.0 1.3692e-03 1.0 7.99e+06 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  5834
VecScale              22 1.0 1.8549e-03 1.0 3.99e+06 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2153
VecCopy                2 1.0 5.0211e-04 1.0 0.00e+00 0.0 0.0e+00
VecSet                77 1.0 3.6245e-02 1.0 0.00e+00 0.0 0.0e+00
VecAXPY                2 1.0 3.7718e-04 1.0 7.26e+05 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1925
VecMAXPY              22 1.0 2.2252e-02 1.0 4.72e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0  2121
VecAssemblyBegin       2 1.0 9.5367e-07 1.0 0.00e+00 0.0 0.0e+00
VecAssemblyEnd         2 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00
VecPointwiseMult      22 1.0 9.2957e-03 1.0 3.99e+06 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   430
VecSetRandom           2 1.0 8.8599e-03 1.0 0.00e+00 0.0 0.0e+00
VecNormalize          22 1.0 3.2570e-03 1.0 1.20e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3679
KSPGMRESOrthog        20 1.0 3.6396e-02 1.0 7.99e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  2195
KSPSetUp               6 1.0 1.4364e-02 1.0 0.00e+00 0.0 0.0e+00
PCGAMGgraph_AGG        2 1.0 4.8670e-01 1.0 3.77e+07 1.0 0.0e+00
0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0    77
PCGAMGcoarse_AGG       2 1.0 1.0664e+00 1.0 8.24e+07 1.0 0.0e+00
0.0e+00 0.0e+00  4  1  0  0  0   4  1  0  0  0    77
PCGAMGProl_AGG         2 1.0 6.4827e-02 1.0 0.00e+00 0.0 0.0e+00
PCGAMGPOpt_AGG         2 1.0 9.9913e-01 1.0 5.31e+08 1.0 0.0e+00
0.0e+00 0.0e+00  4  5  0  0  0   4  6  0  0  0   532
PCSetUp                1 1.0 2.6505e+01 1.0 8.47e+09 1.0 0.0e+00
0.0e+00 0.0e+00 94 84  0  0  0 100100  0  0  0   320
MatMult               38 1.0 5.6846e-01 1.0 6.85e+08 1.0 0.0e+00
0.0e+00 0.0e+00  2  7  0  0  0  34 43  0  0  0  1204
MatMultAdd             6 1.0 2.7303e-02 1.0 3.25e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   2  2  0  0  0  1189
MatMultTranspose       6 1.0 3.2745e-02 1.0 3.25e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   2  2  0  0  0   991
MatSolve               3 1.0 1.6339e-03 1.0 2.10e+06 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1286
MatSOR                36 1.0 9.4071e-01 1.0 6.79e+08 1.0 0.0e+00
0.0e+00 0.0e+00  3  7  0  0  0  56 43  0  0  0   722
MatLUFactorSym         1 1.0 5.9440e-03 1.0 0.00e+00 0.0 0.0e+00
MatLUFactorNum         1 1.0 4.0792e-02 1.0 1.15e+08 1.0 0.0e+00
0.0e+00 0.0e+00  0  1  0  0  0   2  7  0  0  0  2820
MatResidual            6 1.0 9.2385e-02 1.0 1.13e+08 1.0 0.0e+00
0.0e+00 0.0e+00  0  1  0  0  0   6  7  0  0  0  1224
MatGetRowIJ            1 1.0 1.4091e-04 1.0 0.00e+00 0.0 0.0e+00
MatGetOrdering         1 1.0 2.3508e-04 1.0 0.00e+00 0.0 0.0e+00
MatView                6 1.0 5.8508e-04 1.0 0.00e+00 0.0 0.0e+00
VecTDot                4 1.0 1.4160e-03 1.0 2.62e+06 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1851
VecNorm                3 1.0 3.5286e-04 1.0 1.97e+06 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  5572
VecCopy                8 1.0 1.1313e-02 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecSet                22 1.0 4.3163e-03 1.0 0.00e+00 0.0 0.0e+00
VecAXPY                4 1.0 1.6727e-03 1.0 2.62e+06 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1567
VecAYPX               49 1.0 1.7958e-02 1.0 1.15e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   1  1  0  0  0   643
VecAXPBYCZ            24 1.0 1.3117e-02 1.0 2.18e+07 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   1  1  0  0  0  1661
KSPSetUp               2 1.0 9.2983e-06 1.0 0.00e+00 0.0 0.0e+00
KSPSolve               1 1.0 1.6690e+00 1.0 1.59e+09 1.0 0.0e+00
0.0e+00 0.0e+00  6 16  0  0  0 100100  0  0  0   950
PCSetUp                1 1.0 4.7009e-02 1.0 1.15e+08 1.0 0.0e+00
0.0e+00 0.0e+00  0  1  0  0  0   3  7  0  0  0  2447
PCSetUpOnBlocks        3 1.0 4.7014e-02 1.0 1.15e+08 1.0 0.0e+00
PCApply                3 1.0 1.6409e+00 1.0 1.57e+09 1.0 0.0e+00
0.0e+00 0.0e+00  6 16  0  0  0  98 99  0  0  0   954
Mem.
              Viewer     1              1          760     0
              Matrix     1              6     58874852     0
              Vector     3             20     27954224     0
       Krylov Solver     0              5        23360     0
      Preconditioner     0              5         5332     0
           Index Set     0              3         7112     0
              Viewer     1              0            0     0
              Matrix    14             10    477163156     0
      Matrix Coarsen     2              2         1288     0
              Vector    69             52     66638640     0
       Krylov Solver     7              2        60432     0
      Preconditioner     7              2         2096     0
           Index Set     2              2         1584     0
         PetscRandom     2              2         1280     0
              Matrix     1              0            0     0
           Index Set     5              2         2536     0
- -ksp_max_it 2
- -ksp_monitor
- -ksp_type cg
- -ksp_view
- -log_summary
- -pc_type gamg
Configure options: PETSC_ARCH=test --with-debugging=0
Libraries compiled on Mon Apr 27 10:49:24 2015 on yam.doc.ic.ac.uk
Using PETSc arch: test
${FFLAGS}
Using include paths: -I/data/lmitche1/src/deps/petsc/test/include
- -I/data/lmitche1/src/deps/petsc/test/include
Using libraries: -Wl,-rpath,/data/lmitche1/src/deps/petsc/test/lib
- -L/data/lmitche1/src/deps/petsc/test/lib -lpetsc -llapack -lblas -lX11
- -lssl -lcrypto -lpthread -lm -Wl,-rpath,/usr/lib/openmpi/lib
- -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpi_f90
- -lmpi_f77 -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpi_cxx
- -lstdc++ -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iQEcBAEBAgAGBQJVPlBxAAoJECOc1kQ8PEYv4p4IAJKGFsnbkyUfA45gQgMSoF/p
Ox+0tD3iIJ8bLXFBh30b6/Y8UuJD1jown7iOkc6xE7DZFPZCdVXKqKI7G+0yHkPI
0f5f1cMEuAD/N+zsN7ls9/CsB3YIiSEF4xAOenvLCQ3cai5KFZtv/V1PS/67+npS
3w7iWTE6ylJxi/rrtGzOVFhhR9e+Kf4w7dez11+tra6pfX6sQZvH/2sZ46yzP8td
SvbSmdNtVoXLIMIUWGbVYHOs8qg6IqvyorYYjwll6WOe+9oPgz2s9XFNPVCV7N5G
sKJgezt1ClLEKwLD3DS0Z81lpjFJUGYQC3VMtrLLOujyLxX7gp6RX6Xh/rMfo7g=
=Clvj
-----END PGP SIGNATURE-----
