[petsc-dev] configuration error: Cannot compile C with mpicc
    Matthew Knepley
    knepley at gmail.com
    Fri Apr 24 14:11:12 CDT 2015
On Fri, Apr 24, 2015 at 1:55 PM, Jin, Shuangshuang <
Shuangshuang.Jin at pnnl.gov> wrote:
> Thanks for the quick fix for the problem. However I came up with a new one
> now and the configure.log is too big to attach..
> It seems to complain about mpif.h when I look at the log file. Here's a
> piece of the error:
> Executing: gfortran -c -o /tmp/petsc-u4h0ot/config.libraries/conftest.o
> -I/tmp/petsc-u4h0ot/config.compilers -I/tmp/petsc-u4h0ot/config.types
> -I/tmp/petsc-u4h0ot/config.setCompilers
> -I/tmp/petsc-u4h0ot/config.libraries  -Wall -Wno-unused-variable
> -ffree-line-length-0 -Wno-unused-dummy-argument -O
> /tmp/petsc-u4h0ot/config.libraries/conftest.F
> Possible ERROR while running compiler: exit code 256
> stderr:
> /tmp/petsc-u4h0ot/config.libraries/conftest.F:2:0: fatal error: mpif.h: No
> such file or directory
>  #include "mpif.h"
> compilation terminated.
> Source:
>       program main
> #include "mpif.h"
>       end
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Fortran error! mpif.h could not be located at: []
> And my configure option is:
> ./configure PETSC_ARCH=arch-complex-opt --with-prefix=./ --with-mpi=1
> --with-cc=mpicc --with-cxx=mpicxx --with-c++-support=1 --with-c-support=0
> --with-fortran=0 --with-scalar-type=complex --with-debugging=0 CFLAGS=-O3
> --download-superlu_dist --download-superlu --download-parmetis
> --download-metis --download-f2cblaslapack=1 --with-clanguage=c++
> --with-shared-libraries=0 --with-x=0 --with-mpirun=mpirun
> --with-mpiexec=mpiexec --download-fblaslapack=1 --download-mumps
> --download-plapack --download-suitesparse
You want --with-fc-0 not with-fortran=0.
This belongs on petsc-maint at mcs.anl.gov
    Matt
> Can you help to take a look again?
> Thanks,
> Shuangshuang
> -----Original Message-----
> From: Barry Smith [mailto:bsmith at mcs.anl.gov]
> Sent: Friday, April 24, 2015 11:35 AM
> To: Jin, Shuangshuang
> Cc: petsc-dev at mcs.anl.gov
> Subject: Re: [petsc-dev] configuration error: Cannot compile C with mpicc
> CFLAGS=-03  should not be a 0 it should be an O for optimize
> > On Apr 24, 2015, at 1:33 PM, Jin, Shuangshuang <
> > Hello, Petsc dev support team,
> > I was trying to install the latest dev version PETSc on a linxu
> computer. I got an error “Cannot compile C with mpicc”. Please see my
> configure.log attached. Could you please help?
> > Thanks,
> > Shuangshuang
> > <configure.log>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150424/4d627c3c/attachment.html>
