[petsc-dev] Custom reductions
    Håkon Strandenes
    haakon at hakostra.net
    Tue Apr 21 11:25:22 CDT 2015
The MPI_MIN, MPI_MAX and MPI_SUM only indicate that we want to have the
smallest or largest value, or in case of MPI_SUM, the sum of all values
participating in the reduction. It has nothing to do with floting point
or integer types as such, they work with both.
(In addition there is some boolean operations like MPI_LAND, MPI_LOR,
MPI_LXOR, MPI_BAND, MPI_BOR that work with boolean types, and some
operations like MPI_SUM and MPI_PROD can also be used with complex
types, but I don't know if PETSc use this at all.)
Håkon
On 21. april 2015 18:11, Matthew Knepley wrote:
> I understood from Jed that MPIU_MIN and friends are for floating point,
> but here
> https://bitbucket.org/petsc/petsc/src/da407576a5bf29881cba0f2df6c198aa8caa98f0/src/sys/logging/plog.c?at=master#cl-1346
> we use MPI_MIN. Is this wrong?
>    Thanks,
>       Matt
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
