[petsc-dev] clang --analyze messages on PETSc
    Matthew Knepley
    knepley at gmail.com
    Tue Apr 14 19:28:10 CDT 2015
On Tue, Apr 14, 2015 at 7:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Apr 14, 2015, at 6:13 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Tue, Apr 14, 2015 at 6:00 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > On Apr 14, 2015, at 5:40 PM, Jed Brown <jed at jedbrown.org> wrote:
> > > Matthew Knepley <knepley at gmail.com> writes:
> > >> I really do not want that. I am especially unwilling to do that just
> to
> > >> appease static analysis.
> > > I think it's actually better for debuggability and
> > > strictness/normalization within the code, but we had this argument a
> > > year ago and if you still insist, I'm not going to dig it up.
> >   But I did. So Matt's argument is that having a pointer you are not
> allowed to use be anything but NULL is dangerous because it could be used
> wrong and no one would know.
> >    BTW how come all the code  (!(m1) ? (*(r1) = 0,0) : 0)  stuff uses 0
> instead of NULL? Wouldn't it be clearer to use NULL when one means NULL?
>    I understand what you wrote below. My question is why there are a bunch
> of symbols 0 in the PetscMalloc() macros; shouldn't they be NULL for
> clarity.
>     0.0  for float, 0 for integer, and NULL for pointer?  That's all.
I am fine for NULL. I was just using 0 since its equivalent and short.
  Matt
> > I am arguing for uniformity. With the current system, all internal PETSc
> mallocs (we are supposed to use PetscMallocK everywhere)
> > will return NULL for 0 size argument. On the other hand, if you just
> forward the request to malloc, the standard says it can return
> > a valid pointer OR NULL, so now we have different behavior. What is
> worse is that this "valid" pointer can be freed, but it cannot
> > be dereferenced, and there is no way to determine that it cannot be
> dereferenced, unlike NULL. I see absolutely no good argument
> > for this situation.
> >    Matt
> >   Barry
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150414/4955fcb0/attachment.html>
