[petsc-dev] related to compiling your source code
    Mark Adams
    mfadams at lbl.gov
    Tue Apr 14 16:30:47 CDT 2015
> How about when they copy their .bashrc file - which might include
> PETSC_OPTIONS env variable?  [or LD_LIBRARY_PATH to wrong version of
> libraries]
This has never been a problem.  Perhaps everyone know about .bashrc and
must deal with it, but .petscrc falls of the radar and they/we forget about
it ...
> Is the current thought to remove PETSC_OPTIONS env variable aswell?
Perhaps ~/.petscrc things can go into .bashrc somehow?
> How about PWD/.petscrc and PWD/petscrc? remove them aswell?
These are the "normal" rc files that are really used to augment the command
line.  And in the case of FORTRAN codes, which don't add an arg parser of
some sort, it is the command line.
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150414/c01cc08d/attachment.html>
