[petsc-dev] related to compiling your source code
    Matthew Knepley
    knepley at gmail.com
    Tue Apr 14 15:47:01 CDT 2015
On Tue, Apr 14, 2015 at 3:31 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Hm - for one - we rely on ~/.petscrc for our nightly builds.
> petsc at petsc:~$ cat ~/.petscrc
> -malloc_dump
> -display 140.221.10.20:0.0
> #-nox
> #-nox_warning
> petsc at petsc:~$
We can move these to the environment variable. I did this for myself
already.
> And secondly we have an option -skip_petscrc that would skip it.
I agree this is sensible, and that having that option is idiotic. I am also
very
willing to believe that many of our users are idiots, and we sometimes need
to cripple the design for this reason.
   Matt
> using "-pc_type_hypre" in ~/.petscrc is a bad practice. [it makes
> sense only for global options that are useful for multiple petsc
> applications - like -malloc_dump]
> We also read in $PWD/.petscrc and $PWD/petscrc
> Satish
> On Tue, 14 Apr 2015, Barry Smith wrote:
> >    Mark,
> >    Ok, you convinced me.
> >   Satish,
> >     Can you please rip out all the checking for .petscrc in the home
> directory.
> >    Thanks
> >     Barry
> >    Theoretically it is a great feature but no one uses it and those who
> do use it forget that they used it.
> > > On Apr 14, 2015, at 7:41 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > > PETSc's design of looking for RC files in the users home directory
> really sucks.  I've complained about this before a few years ago and am
> going to again.
> > > A perfectly reasonable apps person had a .petscrc file in his home
> directory with at "%-pc_type_hypre" in it.  This gave an error but he could
> not figure out where PETSc got this thing.  (The error message was garbled
> for some reason, which slowed things down. As soon as I saw
> "%-pc_type_hypre" I knew what the problem was.)  As you can see below he
> spent a day doing this.
> > > I spent a day with another apps person on this same project a few
> years ago with this same problem.  This is an error prone construct and it
> does not show up until you have used PETSc for a few years and have
> forgotten that you have a .petscrc file in your home directory. Very bad.
> > > Also, this code specified that RC file name as "petsc.rc".  It looks
> like PETSc is still picking up a .petscrc file anyway!!!  At the very least
> we should scrub ".petscrc" if the user supplies another name.
> > > I think we should dump this design and stop looking at home
> directories and just tell users to change, as we always do when we improve
> the design.
> > > Thanks,
> > > Mark
> > > ---------- Forwarded message ----------
> > > From: Yoon, Eisung <yoone at rpi.edu>
> > > Date: Mon, Apr 13, 2015 at 11:00 PM
> > > Subject: RE: related to compiling your source code
> > > To: Mark Adams <mfadams at lbl.gov>, Robert Hager <rhager at pppl.gov>
> > > Cc: Choong-Seock Chang <cschang at pppl.gov>, Mark Shephard <
> shephard at rpi.edu>, Seung-Hoe Ku <sku at pppl.gov>
> > > WARNING: At least one of the links in the message below goes to an IP
> address (e.g.10.1.1.1), which could be malicious. To learn how to protect
> yourself, please go here: https://commons.lbl.gov/x/_591B
> > > Dear Mark and Robert,
> > > Wow! Thank you so much for all your comments and helps. After I spent
> a whole day, I am about to give up resolving this issue.
> > > I confirmed that the file which has %-pc_type hypre is located at my
> home directory! But the file name caused the problem is not petsc.rc but
> .petscrc, which I guess I copied a long time ago. The source code directory
> where the XGC execution file is located has a petsc.rc which does not
> contain %-pc_type hypre and does not have .petscrc file in the directory.
> > > In summary, three directories were involved for running XGC; A source
> code directory where the XGC execution file is located, working directory
> where job is submitted, and just my home directory. And the problem was
> from my home directory.
> > > In addition, it is quite interesting that petscinitialize subroutine
> passes "./petsc.rc" in the XGC source code, while petsc tried to find a
> DEFAULT file ".petscrc"  in my HOME directory!!!
> > > I currently have removed .petscrc and submitted the job to see if XGC
> runs.
> > > Best,
> > > Eisung Yoon
> > > From: Mark Adams [mfadams at lbl.gov]
> > > Sent: Monday, April 13, 2015 10:19 PM
> > > To: Robert Hager
> > > Cc: Yoon, Eisung; Choong-Seock Chang; Mark Shephard; Seung-Hoe Ku
> > > Subject: Re: related to compiling your source code
> > > Good try Robert :)
> > > I'll bet Eisung has a petsc.rc file in his home directory.  Let me
> know.  I will use this as another data point to support my opinion that
> looking in your home directory is a bad idea.
> > > BTW, Seung-Hoe (cc'ed) and I had this same problem a few years ago and
> it took us hours to figure it out,
> > > Mark
> > > On Mon, Apr 13, 2015 at 9:21 PM, Robert Hager <rhager at pppl.gov> wrote:
> > >> It seems Petsc is looking at a certain directory, but cannot check
> where it is.
> > > This may be a clue. I always copy the executable to my run directory
> and call something like
> > > aprun ...  ./xgca
> > > In one of your earlier e-mails, I saw that you call
> > > aprun ... {PATH_TO_XGCa_SOURCE}/xgca
> > > If PETSc looks for petsc.rc in the directory of the executable, it
> will try to read a very old petsc.rc file that certainly does not work.
> Could you try with the executable to your run directory?
> > > Best
> > > Robert
> > > On Apr 13, 2015, at 8:58 PM, Yoon, Eisung wrote:
> > >> I attach the requested files.
> > >> I tried PETSc and petsc.rc file in the XGC1 example suggested by Mark
> as well as the original input files in xgc_chang-hinton_test.tar. Also I
> checked language options which are same with yours and tried sed command,
> but all failed with almost same messages.
> > >> There were rarely interesting error messages, which can be a clue to
> resolve this issue. The error messages showed "Unknown statement in options
> file: (%-pc_type hypre )" even though my petsc.rc doesn't have that line. I
> checked petsc.rc files in XGC source file directory as well as
> working(running) directory, but that line doesn't exist. Also the default
> .petscrc doesn't exist in both directories. It seems Petsc is looking at a
> certain directory, but cannot check where it is.
> > >> Best,
> > >> Eisung Yoon
> > >> From: Robert Hager [rhager at pppl.gov]
> > >> Sent: Monday, April 13, 2015 5:31 PM
> > >> To: Yoon, Eisung
> > >> Cc: Choong-Seock Chang; Mark Adams; Mark Shephard
> > >> That looks ok.
> > >> I unpacked the tar-file I gave you and ran a diff with the petsc.rc
> that is still working for me and found that they are identical.
> > >> Did you edit any of the files (possibly in a Microsoft environment)?
> Or maybe your shell misinterprets characters. Did you specify any language
> in your shell setup?
> > >> In case something added any control characters to the petsc.rc file,
> you can run
> > >> sed -e 's/[^[:print:]]//g'
> > >> to remove them.
> > >> My language settings are
> > >> rhager at edison02:~/w/xgca_chang-hinton_test3> locale
> > >> LANG=
> > >> LC_CTYPE="POSIX"
> > >> LC_NUMERIC="POSIX"
> > >> LC_TIME="POSIX"
> > >> LC_COLLATE="POSIX"
> > >> LC_MONETARY="POSIX"
> > >> LC_MESSAGES="POSIX"
> > >> LC_PAPER="POSIX"
> > >> LC_NAME="POSIX"
> > >> LC_ADDRESS="POSIX"
> > >> LC_TELEPHONE="POSIX"
> > >> LC_MEASUREMENT="POSIX"
> > >> LC_IDENTIFICATION="POSIX"
> > >> LC_ALL=
> > >>  Could you send your makefile, defs.mk and rules.mk (possibly
> rules_edison.mk) anyway, please?
> > >> Best regards
> > >> Robert
> > >> On Apr 13, 2015, at 5:01 PM, Yoon, Eisung wrote:
> > >>> Hi Robert,
> > >>> I added below to .cshrc.ext  as you recommended
> > >>>   module load cray-petsc
> > >>>   module load cray-hdf5-parallel
> > >>>   module load pspline
> > >>>   module load adios/1.6.0
> > >>> and got
> > >>> Currently Loaded Modulefiles:
> > >>>   1) modules/3.2.10.2                       7) intel/15.0.1.133
>                   13) gni-headers/3.0-1.0502.9684.5.2.ari   19)
> PrgEnv-intel/5.2.40                   25) altd/2.0
>     31) adios/1.6.0
> > >>>   2) nsg/1.2.0                              8) cray-libsci/13.0.1
>                 14) xpmem/0.1-2.0502.55507.3.2.ari        20)
> craype-ivybridge                      26) darshan/2.3.0
> > >>>   3) eswrap/1.1.0-1.020200.1130.0           9)
> udreg/2.3.2-1.0502.9275.1.12.ari      15)
> dvs/2.5_0.9.0-1.0502.1873.1.145.ari   21) cray-shmem/7.1.1
>     27) usg-default-modules/1.1
> > >>>   4) switch/1.0-1.0502.54233.2.96.ari      10)
> ugni/5.0-1.0502.9685.4.24.ari         16) alps/5.2.1-2.0502.9041.11.6.ari
>      22) cray-mpich/7.1.1                      28) cray-petsc/3.5.2.1
> > >>>   5) craype-network-aries                  11)
> pmi/5.0.6-1.0000.10439.140.2.ari      17) rca/1.0.0-2.0502.53711.3.127.ari
>     23) torque/5.0.1                          29) cray-hdf5-parallel/1.8.13
> > >>>   6) craype/2.2.1                          12)
> dmapp/7.0.1-1.0502.9501.5.219.ari     18) atp/1.7.5
>      24) moab/8.0.1-2014110616-5c7a394-sles11  30) pspline/nersc1.0
> > >>> I copied Makefile.edison to Makefile, and had no problem with
> compiling and linking. I will try to figure out with the petsc.rc file.
> Thank you!
> > >>> Best,
> > >>> Eisung Yoon
> > >>> Sent: Monday, April 13, 2015 4:55 PM
> > >>> To: Choong-Seock Chang
> > >>> Cc: Yoon, Eisung; Mark Adams; Mark Shephard
> > >>> Hi Eisung,
> > >>> I used this file with XGCa on Edison today. Which modules do you use
> and which set of makefiles?
> > >>> Best
> > >>> Robert
> > >>> On Apr 13, 2015, at 4:44 PM, Choong-Seock Chang wrote:
> > >>>> Please include Mark Adams in the PETSc related e-mails.
> > >>>> He is in charge of PETSc in our project.  He needs to be aware of
> all the conversations.
> > >>>> Thanks,
> > >>>> CS
> > >>>> On Apr 13, 2015, at 4:42 PM, Yoon, Eisung <yoone at rpi.edu> wrote:
> > >>>>> Hi Robert,
> > >>>>> I tried to run XGC in Greene and Edison. Green still has a problem
> with PETSc. Even in edison, XGCa shows an error related to the petsc.rc
> file as below. Considering "invalid argument" in the message, I guess the
> petsc.rc included in the xgca_chang-hinton_test.tar doesn't work.
> Unfortunately, the characters for the unknown option shown in the message
> is broken. Do you have working petsc.rc?
> > >>>>> Thank you!
> > >>>>> ES
> > >>>>> (t_initf) Read in prof_inparam namelist from: input
> > >>>>>  PERF_SETOPTS: PAPI library not linked in. Request to enable PAPI
> ignored.
> > >>>>>  (t_initf) Using profile_disable= F  profile_timer=           2
> > >>>>>  (t_initf)  profile_depth_limit=       99999
> profile_detail_limit=           1
> > >>>>>  (t_initf)  profile_barrier= F  profile_outpe_num=           1
> > >>>>>  (t_initf)  profile_outpe_stride=           1
> profile_single_file= F
> > >>>>>  (t_initf)  profile_global_stats= T  profile_papi_enable= F
> > >>>>>  call petsc_init
> > >>>>> [0]PETSC ERROR: --------------------- Error Message
> > >>>>> [0]PETSC ERROR: Invalid argument
> > >>>>> [0]PETSC ERROR: Unknown statement in options file: (???~A'^D)
> > >>>>> [0]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> > >>>>> [0]PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
> > >>>>> [0]PETSC ERROR:
> /global/u2/e/eyoon/branch/dev_rhager_esyoon/epsi/XGCa/xgca on a sandybridge
> named nid05677 by eyoon Mon Apr 13 13:31:32 2015
> > >>>>> [0]PETSC ERROR: Configure options --known-mpi-int64_t=0
> --known-bits-per-byte=8 --known-level1-dcache-assoc=0
> --known-level1-dcache-linesize=32 --known-level1-dcache-size=32768
> --known-memcmp-ok=1 --known-mpi-c-double-complex=1
> --known-mpi-long-double=1 --known-mpi-shared-libraries=0
> --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-sizeof-char=1
> --known-sizeof-double=8 --known-sizeof-float=4 --known-sizeof-int=4
> --known-sizeof-long-long=8 --known-sizeof-long=8 --known-sizeof-short=2
> --known-sizeof-size_t=8 --known-sizeof-void-p=8 --with-ar=ar --with-batch=1
> --with-cc=cc --with-clib-autodetect=0 --with-cxx=CC
> --with-cxxlib-autodetect=0 --with-debugging=0 --with-dependencies=0
> --with-fc=ftn --with-fortran-datatypes=0 --with-fortran-interfaces=0
> --with-fortranlib-autodetect=0 --with-ranlib=ranlib --with-scalar-type=real
> --with-shared-ld=ar --with-etags=0 --with-dependencies=0
> --with-mpi-dir=/opt/cray/mpt/7.0.0/gni/mpich2-intel/140 --with-superlu=1
> --with-superlu-include=/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/include
> --with-superlu-lib=/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/lib/libsuperlu.a
> --with-superlu_dist=1
> --with-superlu_dist-include=/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/include
> --with-superlu_dist-lib=/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/lib/libsuperlu_dist.a
> --with-parmetis=1
> --with-parmetis-include=/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/include
> --with-parmetis-lib=/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/lib/libparmetis.a
> --with-metis=1
> --with-metis-include=/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/include
> --with-metis-lib=/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/lib/libmetis.a
> --with-ptscotch=1
> --with-ptscotch-include=/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/include
> --with-ptscotch-lib="-L/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/lib
> -lptscotch -lscotch -lptscotcherr -lscotcherr" --with-scalapack=1
> --with-scalapack-include=/opt/cray/libsci/13.0.0/INTEL/140/sandybridge/include
> --with-scalapack-lib="-L/opt/cray/libsci/13.0.0/INTEL/140/sandybridge/lib
> -lsci_intel_mpi_mp -lsci_intel_mp" --with-mumps=1
> --with-mumps-include=/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/include
> --with-mumps-lib="-L/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/lib -lcmumps
> -ldmumps -lesmumps -lsmumps -lzmumps -lmumps_common -lptesmumps -lpord"
> --CFLAGS="-xavx -openmp -O3 " --CXXFLAGS="-xavx -openmp -O3  "
> --FFLAGS="-xavx -openmp -O3  " --LIBS=-lstdc++ --CXX_LINKER_FLAGS=
> --PETSC_ARCH=sandybridge --prefix=/opt/cray/petsc/
> 3.5.2.1/real/INTEL/140/sandybridge --with-hypre=1
> --with-hypre-include=/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/include
> --with-hypre-lib=/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/lib/libHYPRE.a
> --with-sundials=1
> --with-sundials-include=/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/include
> --with-sundials-lib="-L/opt/cray/tpsl/1.4.3/INTEL/140/sandybridge/lib
> -lsundials_cvode -lsundials_cvodes -lsundials_ida -lsundials_idas
> -lsundials_kinsol -lsundials_nvecparallel -lsundials_nvecserial"
> > >>>>> [0]PETSC ERROR: #1 PetscOptionsInsertFile() line 534 in
> /b/cray-petsc/.cray-build/INTEL/140/sandybridge/cray-petsc-base-dynamic/petsc-3.5.2/src/sys/objects/options.c
> > >>>>> [0]PETSC ERROR: #2 PetscOptionsInsert() line 716 in
> > >>>>> [0]PETSC ERROR: PetscInitialize:Creating options database
> > >>>>> PETSC ERROR: Logging has not been enabled.
> > >>>>> You might have forgotten to call PetscInitialize().
> > >>>>> Rank 0 [Mon Apr 13 13:31:32 2015] [c5-3c1s11n1] application called
> MPI_Abort(MPI_COMM_WORLD, 56) - process 0
> > >>>>> forrtl: error (76): Abort trap signal
> > >>>>> Image              PC                Routine            Line
>   Source
> > >>>>> xgca               0000000003363F21  Unknown
>  Unknown  Unknown
> > >>>>> xgca               0000000003362677  Unknown
>  Unknown  Unknown
> > >>>>> xgca               000000000331A2F4  Unknown
>  Unknown  Unknown
> > >>>>> xgca               000000000331A106  Unknown
>  Unknown  Unknown
> > >>>>> xgca               00000000032AE434  Unknown
>  Unknown  Unknown
> > >>>>> xgca               00000000032B53B1  Unknown
>  Unknown  Unknown
> > >>>>> xgca               0000000002F64B60  Unknown
>  Unknown  Unknown
> > >>>>> xgca               0000000002F64B1B  Unknown
>  Unknown  Unknown
> > >>>>> xgca               0000000003371B11  Unknown
>  Unknown  Unknown
> > >>>>> xgca               0000000003131922  Unknown
>  Unknown  Unknown
> > >>>>> xgca               0000000003100063  Unknown
>  Unknown  Unknown
> > >>>>> xgca               00000000008BD7F0  Unknown
>  Unknown  Unknown
> > >>>>> xgca               00000000008B2241  Unknown
>  Unknown  Unknown
> > >>>>> xgca               00000000008C1B41  Unknown
>  Unknown  Unknown
> > >>>>> xgca               000000000042554B  perf_monitor_mp_p
> 1875  module.F90
> > >>>>> xgca               000000000051F3BE  MAIN__
>  95  main.F90
> > >>>>> xgca               0000000000405DEE  Unknown
>  Unknown  Unknown
> > >>>>> xgca               000000000336B6C1  Unknown
>  Unknown  Unknown
> > >>>>> xgca               0000000000405CD1  Unknown
>  Unknown  Unknown
> > >>>>> _pmiu_daemon(SIGCHLD): [NID 05677] [c5-3c1s11n1] [Mon Apr 13
> 13:31:32 2015] PE RANK 0 exit signal Aborted
> > >>>>> [NID 05677] 2015-04-13 13:31:32 Apid 11750871: initiated
> application termination
> > >>>>> Application 11750871 exit codes: 134
> > >>>>> Application 11750871 exit signals: Killed
> > >>>>> Application 11750871 resources: utime ~60s, stime ~12s, Rss
> ~29844, inblocks ~3174405, outblocks ~8270892
> > >>>>> Sent: Monday, April 13, 2015 2:16 PM
> > >>>>> To: Yoon, Eisung
> > >>>>> Cc: shephard at rpi.edu; cschang at pppl.gov
> > >>>>> Hi Eisung,
> > >>>>> you can use the input in
> > >>>>> /project/projectdirs/m499/rhager/xgca_chang-hinton_test.tar
> > >>>>> Let me know if you have trouble reading the file.
> > >>>>> Best regards
> > >>>>> Robert
> > >>>>> On Apr 13, 2015, at 1:46 PM, Yoon, Eisung wrote:
> > >>>>>> Hi Robert,
> > >>>>>> Thank you for the information and explanation. I attach a text
> file which contains issues of source code with TRIGRID and variable
> collision time.
> > >>>>>> I'm sorry for not telling you previously that I was compiling the
> source code in PPPL server. I've not ready to use XGC  in Edison yet but
> I'm going to work it to be ready right now.
> > >>>>>> Could you send me an input file of XGCa for a collision test in
> Edison?
> > >>>>>> Thanks a lot!!!
> > >>>>>> ES
> > >>>>>> Sent: Monday, April 13, 2015 10:34 AM
> > >>>>>> To: Yoon, Eisung
> > >>>>>> Hi Eisung,
> > >>>>>> the TRIGRID directive should not cause any errors. Can I see the
> error message?
> > >>>>>> I looked at Makefile.edison in your branch. It looks fine. You
> might have to change defs.mk though. There is one include statement to
> import some PETSc variable definitions. Depending on whether you use PETSc
> 3.5 or 3.6, you have to use the first or the second line, respectively.
> > >>>>>> On Edison, I load the following modules in addition to the
> default:
> > >>>>>>    module load pspline
> > >>>>>> The output of module list is
> > >>>>>>   1) modules/3.2.10.2                      13)
> gni-headers/3.0-1.0502.9684.5.2.ari   25) cray-petsc/3.5.2.1
> > >>>>>>   2) nsg/1.2.0                             14)
> xpmem/0.1-2.0502.55507.3.2.ari        26) cray-hdf5-parallel/1.8.13
> > >>>>>>   3) eswrap/1.1.0-1.020200.1130.0          15)
> dvs/2.5_0.9.0-1.0502.1873.1.145.ari   27) pspline/nersc1.0
> > >>>>>>   4) switch/1.0-1.0502.54233.2.96.ari      16)
> alps/5.2.1-2.0502.9041.11.6.ari       28) allineatools/5.0.1
> > >>>>>>   5) craype-network-aries                  17)
> rca/1.0.0-2.0502.53711.3.127.ari      29) idl/8.2
> > >>>>>>   6) craype/2.2.1                          18) atp/1.7.5
>                    30) gv/3.7.3
> > >>>>>>   7) intel/15.0.1.133                      19)
> PrgEnv-intel/5.2.40                   31) latex/2012
> > >>>>>>   8) cray-libsci/13.0.1                    20) craype-ivybridge
>                     32) altd/2.0
> > >>>>>>   9) udreg/2.3.2-1.0502.9275.1.12.ari      21) cray-shmem/7.1.1
>                     33) darshan/2.3.0
> > >>>>>>  10) ugni/5.0-1.0502.9685.4.24.ari         22) cray-mpich/7.1.1
>                     34) usg-default-modules/1.1
> > >>>>>>  11) pmi/5.0.6-1.0000.10439.140.2.ari      23) torque/5.0.1
> > >>>>>>  12) dmapp/7.0.1-1.0502.9501.5.219.ari     24)
> > >>>>>> Last time I tried, the code compiled with these settings. It also
> ran a couple of time steps. But there are still some bugs in the code.
> Making the collision time step variable is a bit complicated because the
> collision operation is usually run together with all other sources like
> heating, etc. Therefore, the distribution function is evaluated only every
> sml_f_source_period time steps. If a collision operation is supposed to run
> at a different time step, f will not be available with the current code.
> However, in order to test whether it is worth to pursue this approach, I
> wanted to implement variable collision time steps in the simplest possible
> way, i.e. sml_f_source_period=0 and all sources except the collision
> operation deactivated. The collision interval must have an upper limit
> which I set to 10 time steps in my test. The interval for load-balancing
> should be a multiple of this upper limit in order to be efficient. If this
> approach helps to improve performance, we can think about how to implement
> variable collision intervals in a cleaner way.
> > >>>>>> Let me know if you have any further problems.
> > >>>>>> Best
> > >>>>>> Robert
> > >>>>>> On Apr 12, 2015, at 2:38 PM, Yoon, Eisung wrote:
> > >>>>>>> Hi Robert,
> > >>>>>>> Thank you for the performance test data. I really appreciate
> your work.
> > >>>>>>> As for variable collision time,  I've made a branch
> "dev_rhager_esyoon" as a copy of your source code, "dev_rhager". I've read
> your modification for variable collision time in the XGCa folder.
> > >>>>>>> In order to run the code, I currently have trouble with
> compiling the source code. It appears preprocessing directives -DTRIGRID
> causes the error. Could you send me your Makefile to see working compile
> options?
> > >>>>>>> Thank you.
> > >>>>>>> Best,
> > >>>>>>> ES
> > >>>>>> <code_reading.txt>
> > >> <defs.mk><Makefile><rules.mk>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150414/968ecc15/attachment.html>
