[petsc-dev] clang --analyze messages on PETSc
    Lisandro Dalcin
    dalcinl at gmail.com
    Tue Apr 14 03:33:34 CDT 2015
On 14 April 2015 at 02:46, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Apr 13, 2015 at 5:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> When I run clang --analyze on PETSc on getting warnings of the type below,
>> any idea how to deal with them? Clearly these things are usually not null
>> pointers or PETSc would crash everywhere.
> Lisandro brought this up.
> This is a problem with the analyzer. Anything that uses PetscMallocK() will
> be wrong since it can
> possibly be NULL. The limitations of static analysis are stark.
There is a way to silent many of these false positives:
1) First we need to solve the differences between PetscMalloc() and
PetscMallocK() regarding zero-size allocations.
2) PetscMalloc1() is by far the most used of all the PetscMallocK()
routines. So we should make PetscMalloc1() a direct call to
PetscMalloc() (no checks for zero-sized allocs) and modify
PetscMalloc() to handle zero-sized allocations by setting the pointer
to NULL.
These simple changes will remove tons of "null pointer dereference"
false positives, and also fix the inconsistent behavior between
PetscMalloc() and PetscMallocK().
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Numerical Porous Media Center (NumPor)
King Abdullah University of Science and Technology (KAUST)
http://numpor.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 4332
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
