[petsc-dev] Clang Analyzer
Jed Brown
jed at jedbrown.org
Sun Apr 12 19:13:03 CDT 2015
Barry Smith <bsmith at mcs.anl.gov> writes:
> Lisandro,
> More code analysis is always good. We'll figure something out for this particular beast. Note that petscsys.h already uses #if defined(__has_attribute) so maybe we can use
> # if __has_attribute(analyzer_noreturn)
> instead of the #ifdef __clang_analyzer__?
Should we add a PETSC_HAS_ATTRIBUTE(analyzer_noreturn) to make this less
verbose? (It would return 0 if __has_attribute is not available.) I
foresee more use of __has_attribute to reduce the number of tests we
have to run and make petscconf.h more robust to, e.g., minor version
changes in the compiler stack.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150412/ec675f53/attachment.sig>
