[petsc-dev] More on FV overlap cells and Fortran
Adrian Croucher a.croucher at auckland.ac.nz
Thu Apr 9 18:19:57 CDT 2015
> Is it possible that you have not created the global section yet? I do
> not use the normal interface here, which creates it
> automatically, to speed things up. You can just call
> DMPlexGetDefaultGlobalSection() before the call.
Thanks, it works if I add a call to DMGetDefaultGlobalSection()
beforehand (couldn't find a 'DMPlexGetDefaultGlobalSection()').
What is the 'normal interface' you're referring to here? Just wondering
in case it would be easier for me to use that instead.
Cheers, Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 84611
