[petsc-dev] PETSc blame digest (next) 2015-04-08
    Matthew Knepley
    knepley at gmail.com
    Wed Apr  8 09:29:52 CDT 2015
On Wed, Apr 8, 2015 at 9:08 AM, Jed Brown <jed at jedbrown.org> wrote:
> PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> writes:
> > warnings attributed to commit ac76247 Point-to-point PetscSF: bcast and
> reduce, still need fetch-and-op, ref #9
> >   src/vec/is/sf/impls/basic/sfbasic.c:816
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/08/build_next_arch-opensolaris-cmplx-pkgs-dbg_n-gage.log
>  "/export/home/petsc/petsc.clone-3/src/vec/is/sf/impls/basic/sfbasic.c",
> line 816: warning: loop not entered at top
> How do we fix this?  If I remove the final (unreached)
> PetscFunctionReturn(0) then the code is invalid when not
> PETSC_USE_ERRORCHECKING (no return statement in function returning
> non-void).  But as long as error checking is on, we don't reach that
> statement.  Can we tune the warning flags to avoid this noise?
> static PetscErrorCode PetscSFBasicGetPackInUse(PetscSF sf,MPI_Datatype
> unit,const void *key,PetscCopyMode cmode,PetscSFBasicPack *mylink)
>   PetscSF_Basic    *bas = (PetscSF_Basic*)sf->data;
>   PetscErrorCode   ierr;
>   PetscSFBasicPack link,*p;
>   PetscFunctionBegin;
>   /* Look for types in cache */
>   for (p=&bas->inuse; (link=*p); p=&link->next) {
>     PetscBool match;
>     ierr = MPIPetsc_Type_compare(unit,link->unit,&match);CHKERRQ(ierr);
>     if (match && (key == link->key)) {
>       switch (cmode) {
>       case PETSC_OWN_POINTER: *p = link->next; break; /* Remove from inuse
> list */
>       case PETSC_USE_POINTER: break;
>       default: SETERRQ(PETSC_COMM_SELF,PETSC_ERR_ARG_INCOMP,"invalid
> cmode");
>       *mylink = link;
>       PetscFunctionReturn(0);
>   SETERRQ(PetscObjectComm((PetscObject)sf),PETSC_ERR_ARG_WRONGSTATE,"Could
> not find pack");
I think you need an if () to make the compiler quit whining.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150408/89cce86d/attachment.html>
