[petsc-dev] how did this buggy mess get into master?
Tue Apr 7 17:07:50 CDT 2015
  Matt,
    How could you have moved this into master? The ex2.c example didn't compile for complex and was totally incorrectly formatted. The makefile had missing tabs so the rules runex2_basic and runex2_window didn't even run plus the $ was missing around MPIEXEC so even if they had run they couldn't run plus
   it also appears that runex2_window doesn't even work.
$ make runex2_window
10,25c10,35
< Vec Object: 2 MPI processes
<   type: mpi
< Process [0]
< 0
< 1
< Process [1]
< 1
< 0
<   type: mpi
< Process [0]
< 10
< 11
< Process [1]
< 11
< 10
> [0]PETSC ERROR: #1 PetscSFBcastBegin_Window() line 495 in /Users/barrysmith/Src/PETSc/src/vec/is/sf/impls/window/sfwindow.c
> [0]PETSC ERROR: #2 PetscSFBcastBegin() line 924 in /Users/barrysmith/Src/PETSc/src/vec/is/sf/interface/sf.c
> [0]PETSC ERROR: #3 main() line 69 in /Users/barrysmith/Src/petsc/src/vec/is/sf/examples/tutorials/ex2.c
> [0]PETSC ERROR: PETSc Option Table entries:
> [1]PETSC ERROR: #1 PetscSFBcastBegin_Window() line 495 in /Users/barrysmith/Src/PETSc/src/vec/is/sf/impls/window/sfwindow.c
> [0]PETSC ERROR: -sf_type window
> [1]PETSC ERROR: #2 PetscSFBcastBegin() line 924 in /Users/barrysmith/Src/PETSc/src/vec/is/sf/interface/sf.c
> [1]PETSC ERROR: #3 main() line 69 in /Users/barrysmith/Src/petsc/src/vec/is/sf/examples/tutorials/ex2.c
> [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
> [1]PETSC ERROR: PETSc Option Table entries:
> [1]PETSC ERROR: -sf_type window
> [1]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
> application called MPI_Abort(MPI_COMM_WORLD, 539079184) - process 0
> [cli_0]: aborting job:
> application called MPI_Abort(MPI_COMM_WORLD, 270643728) - process 1
> [cli_1]: aborting job:
> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> =   PID 7675 RUNNING AT Barrys-MacBook-Pro.local
> =   EXIT CODE: 16
> =   CLEANING UP REMAINING PROCESSES
> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
Possible problem with ex2_window, diffs above
  I have cleaned up the code in master in commit e669faa but it still means there is a bug (or an error in the example) in master that needs fixing.
  Barry
> commit f0bcadac1e65793affc0f38311a11fa02852c8a6
> Merge: 2ad7bfe 45038af
> Author: Matthew G. Knepley <knepley at gmail.com>
> Date:   Mon Apr 6 09:30:20 2015 -0500
>    Merge branch 'pr255/mapdes/sf-multiple-in-flight/master'
>    * pr255/mapdes/sf-multiple-in-flight/master:
>      SF: fix multiple in flight comm rounds for basic SFType
