[petsc-dev] Error on large problems.
Mark Adams
mfadams at lbl.gov
Mon Apr 6 09:05:32 CDT 2015
And added squaring the matrix (A^T * A), which uses a matrix matrix
product. And get the error. (recall this did run without the square graph,
which is where it dies here). I can run this about every two weeks if you
want me to run with some other branch or parameters (-info ?).
[0]PCSetFromOptions_GAMG threshold set -5.000000e-03
[0]PCSetUp_GAMG level 0 N=0, n data rows=1, n data cols=1, nnz/row
(ave)=26, np=131072
[0]PCGAMGFilterGraph 100% nnz after filtering, with threshold -0.005,
26.9649 nnz ave. (N=0)
[0]PCGAMGCoarsen_AGG square graph
MPICH2 ERROR [Rank 48173] [job id 11540278] [Sun Apr 5 22:11:13 2015]
[c0-1c0s10n3] [nid01579] - MPID_nem_gni_check_localCQ():
GNI_CQ_EVENT_TYPE_POST had error (SOURCE_SSID:AT_MDD_INV:CPLTN_SRSP)
[48173]PETSC ERROR: #1 MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line
1757 in
/global/u2/m/madams/petsc_maint/src/mat/impls/aij/mpi/mpimatmatmult.c
[48173]PETSC ERROR: #2 MatTransposeMatMult_MPIAIJ_MPIAIJ() line 881 in
[48173]PETSC ERROR: #3 MatTransposeMatMult() line 8977 in
/global/u2/m/madams/petsc_maint/src/mat/interface/matrix.c
[48173]PETSC ERROR: #4 PCGAMGCoarsen_AGG() line 991 in
/global/u2/m/madams/petsc_maint/src/ksp/pc/impls/gamg/agg.c
[48173]PETSC ERROR: #5 PCSetUp_GAMG() line 596 in
/global/u2/m/madams/petsc_maint/src/ksp/pc/impls/gamg/gamg.c
[48173]PETSC ERROR: #6 PCSetUp() line 902 in
/global/u2/m/madams/petsc_maint/src/ksp/pc/interface/precon.c
[48173]PETSC ERROR: #7 KSPSetUp() line 306 in
/global/u2/m/madams/petsc_maint/src/ksp/ksp/interface/itfunc.c
[48
On Sat, Mar 28, 2015 at 1:21 PM, Mark Adams <mfadams at lbl.gov> wrote:
> It works for a stripped down GAMG solve (no smoothing and no square
> graph). I will try adding the square graph back in ...
> On Wed, Mar 25, 2015 at 7:24 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> On Sat, Mar 7, 2015 at 5:49 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> > On Mar 7, 2015, at 4:27 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> > On Sat, Mar 7, 2015 at 3:11 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>> > Hmm, my first guess is a mixup between PetscMPIInt and PetscInt
>>> arrays or MPIU_INT somewhere. (But compilers catch most of these)
>>> > I have a run with ~9K eq/core 128K cores many times but have never
>>> gotten the 32K/core (4B eq.) run to work. So it looks like an int overflow
>>> issue.
>>> Well in theory if we have done everything write with 64 bit indices
>>> there should never be an integer overflow (though of course there could be
>>> mistake somewhere but generally the compiler will detect if we are trying
>>> to stick a 64 bit int into a 32 bit slot.
>>> Can you try the same example without GAMG (say with hypre instead);
>>> if it goes through ok it might indicate an int issue either in gamg or the
>>> code that gamg calls?
>> Good idea, Jacobi works. I will try a stripped down GAMG next.
>>> Barry
>>> > Another possibility is bug in the MPI for many large messages; any
>>> chance you can run the same thing on a very different system? Mira?
>>> > Not soon, but I have Chombo and PETSc built on Mira and it would not
>>> be hard to get this code setup and try it.
>>> > This is for SCE15 so I will turn the PETSc test off unless someone has
>>> any ideas on something to try. I am using maint perhaps I should use
>>> master.
>>> > Mark
>>> > Barry
>>> > > On Mar 7, 2015, at 1:21 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> > > I seem to be getting this error on Edison with 128K cores and ~4
>>> Billion equations. I've seen this error several time. I've attached a
>>> recent output from this. I wonder if it is an integer overflow. This
>>> built with 64 bit integers, but I notice that GAMG prints out N and I see
>>> N=0 for the finest level.
>>> > > Mark
>>> > > <out.131072.uniform.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150406/f5303740/attachment.html>
