[petsc-dev] build petsc in eclipse
Barry Smith
bsmith at mcs.anl.gov
Mon Sep 22 07:10:59 CDT 2014
On Sep 22, 2014, at 5:25 AM, 李震 <lizhen_dlut at 163.com> wrote:
> On the P185 of the manual
> "and then the libraries, in my case:
> m, petsc, stdc++, mpichxx, mpich, lapack, blas, gfortran, dl, rt,gcc_s, pthread …."
No, this is not the exact list of libraries. The exact list of libraries is machine and configuration dependent. Run
make getlinklibs
for your machine. For example for me
~/Src/petsc/src/ksp/ksp/examples/tutorials barry/feature-enhanced-binary-viewers $ make getlinklibs
-L/Users/barrysmith/Src/petsc/arch-basic/lib -L/Users/barrysmith/Src/petsc/arch-basic/lib -L/Users/barrysmith/Src/petsc/arch-basic/lib -lpetsc -llapack -lblas -L/opt/X11/lib -lX11 -lhwloc -lpthread -lssl -lcrypto -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lmpichf90 -lgfortran -L/usr/local/lib/gcc/x86_64-apple-darwin12.3.0/4.8.1 -L/usr/local/lib -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lclang_rt.osx -lmpichcxx -lc++ -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -L/Users/barrysmith/Src/petsc/arch-basic/lib -ldl -lpmpich -lmpich -lopa -lmpl -lpthread -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
> after the "pthread, .." line, the parameters is not complete, I think it is a problem of compiling the PDF file.
> 李震
> 发件人: Barry Smith
> 发送时间: 2014-09-22 18:16
> 收件人: 李震
> 抄送: petsc-dev
> 主题: Re: [petsc-dev] build petsc in eclipse
> The users manual http://www.mcs.anl.gov/petsc/petsc-current/docs/manual.pdf on page 185 contains all the information we know about using Eclipse with PETSc. I hope this helps. If you figure out any additional information please send it to us and we’ll add it to the documentation.
> Barry
> On Sep 22, 2014, at 5:05 AM, 李震 <lizhen_dlut at 163.com> wrote:
> > Dear Mr,
> > I want to know the method that set up the PETSc in Eclipse. Can you give me some advice?
> > Sincerely yours,
> > Zhen Li
> > Dalina University of Technology
