[petsc-dev] Including petsc.h breaks user code
Matthew Knepley
knepley at gmail.com
Sun Sep 14 18:01:48 CDT 2014
On Sun, Sep 14, 2014 at 5:56 PM, Christophe Prud'homme <
christophe.prudhomme at feelpp.org> wrote:
> Hello
> Pierre and I found this problem occurring using openmpi 1.8.1 petsc 3.5.1
> (this was done on my side using homebrew on osx)
> we haven't checked mpich. However it is disturbing that removing the
> petsc.h header actually solve the problem.
> from the mpi standard, if we understand correctly, we shouldn't have to
> specify the data type for MPI_IN_PLACE scatter/gather operations. To avoid
> either a crash with, deadlock(scatter) or wrong results (gather) with
> boost::mpi we need to specify the data type.
> In our code Feel++ we have added some tests to verify this behavior [1]
> basically
> - mpi alone OK
> - boost::mpi alone OK (boost::mpi is just used as an alternative to
> initialize mpi)
> - mpi+petsc.h with MPI_DATATYPE_NULL in scatter crash
> - mpi+petsc.h+proper datatype OK
> - boost::mpi.h+petsc with MPI_DATATYPE_NULL hangs in scatter
> - boost::mpi.h+petsc+proper datatype OK
> 1.
> https://github.com/feelpp/feelpp/blob/develop/testsuite/feelcore/test_gatherscatter.cpp
1) I think this is an OpenMPI bug
2) I think this because I cannot reproduce with MPICH, and it is not
valgrind clean
3) OpenMPI has lots of bugs. If you guys can reproduce with MPICH, I will
track it
down and fix it.
Matt
> Best regards
> C.
> On Mon, Sep 15, 2014 at 12:37 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Sun, Sep 14, 2014 at 4:16 PM, Pierre Jolivet <jolivet at ann.jussieu.fr>
>> wrote:
>>> Hello,
>>> Could you please explain to me why the following example is not working
>>> properly when <petsc.h> (from master, with OpenMPI 1.8.1) is included ?
>>> $ mpicxx in-place.cpp -I$PETSC_DIR/include
>>> -I$PETSC_DIR/$PETSC_ARCH/include -L$PETSC_DIR/$PETSC_ARCH/lib -lpetsc
>>> $ mpirun -np 2 ./a.out
>>> Done with the scatter !
>>> 0 0 0 0 (this line should be filled with 0)
>>> 1 1 1 1 (this line should be filled with 1)
>>> Done with the gather !
>>> -DPETSC_BUG
>>> [:3367] *** An error occurred in MPI_Type_size
>>> [:3367] *** reported by process [4819779585,140733193388032]
>>> [:3367] *** on communicator MPI_COMM_WORLD
>>> [:3367] *** MPI_ERR_TYPE: invalid datatype
>>> [:3367] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will
>>> now abort,
>>> [:3367] *** and potentially your MPI job)
>> I just built this with MPICH and it runs fine:
>> master:/PETSc3/petsc/petsc-pylith$
>> /PETSc3/petsc/petsc-pylith/arch-pylith-cxx-debug/bin/mpiexec -host
>> localhost -n 2
>> /PETSc3/petsc/petsc-pylith/arch-pylith-cxx-debug/lib/in-place-obj/in-place
>> Will valgrind.
>> Matt
>>> Thank you for looking,
>>> Pierre
>> experiments lead.
>> -- Norbert Wiener
> Feel++ Project Manager
> Professor in Applied Mathematics
> @ Université Joseph Fourier (Grenoble, France)
> @ Université de Strasbourg (France)
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140914/f17e8ddc/attachment.html>
