[petsc-dev] so Bitbucket and git suck once again
Thu Sep 11 22:14:49 CDT 2014
On Sep 11, 2014, at 8:37 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
  Patrick,
    Never mind. I just need to change the git@ to access the repository. I’ll start on it tomorrow when my brain is fresh.
  Barry
>  Patrick,
>    Could you please give us read access to your repository so we can fetch it?
>   Thanks
>     Barry
>  git fetch git at bitbucket.org:psanan/petsc psanan/ksp-fcg:psanan/ksp-fcg
> conq: repository does not exist.
> fatal: Could not read from remote repository.
> Please make sure you have the correct access rights
> and the repository exists.
> On Sep 11, 2014, at 7:05 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>> Jed
>>> So, I am in my PETSc repository and want to try out Patrick Sanan’s FCG since it is cool and we ignored it too long and need to get it into the repository. He’s made a nice pull request; great. So I do
>>> ~/Src/petsc  master $ git checkout psanan/ksp-fcg
>>> error: pathspec 'psanan/ksp-fcg' did not match any file(s) known to git.
>> The branch is in his repository, not ours.  Bitbucket has a major
>> pull-request permissions problem in that he can make a PR to our
>> repository without giving us read access to his repository.  This sounds
>> crazy and it is.  Supposedly we would be able to merge using the web
>> interface (if not for merge conflicts), but we can't even read the
>> commits on the web:
>> https://bitbucket.org/petsc/petsc/pull-request/197/kspfcg/commits
>> If we had read access to his repository, I would run:
>> to create a local branch in my repository named psanan/ksp-fcg.  I would
>> then
>> ... browse, run tests, etc
>> git push -u origin psanan/ksp-fcg
>> and merge if it looks good.
>>> Then I fucking give up.
>>> Why doesn’t bitbucket produce useful information to get his branch without being a git guru? It should show the exact magical git incantation to pull his branch.
>>> 1) How do I pull his branch into my repository
>>> 2) How do I know in the future when I want to do this again, how to pull his branch in when my long term memory is shot?
>> Bitbucket is seriously dropping the ball on this interface.  GitHub
>> email notifications include the command to pull (merging into the
>> current branch, so not quite what we want) and have solved the
>> permissions problem.  They also makes the PR branches available under
>> refs/pull/*, so that you can get them without using the URL for the
>> contributor's repo.
>> Patrick, you have write access to the PETSc repository.  Can you just
>> push your branches there instead of your personal repo when creating a
>> PR?
