[petsc-dev] unwind next branch
Wed Sep 10 10:21:17 CDT 2014
Shri,
You have multiple branches merged to next - but not to master.  And
they appear to be more than a year old..
>  origin/shri/ts-dae-semi-explicit
>  origin/shri/ts-is-for-differential-variables
>  origin/shri/ts-powergrid
Satish
On Wed, 10 Sep 2014, Abhyankar, Shrirang G. wrote:
> You can delete
> origin/shri/external-package-KLU
>   origin/shri/feature-dm-circuit
> Please keep all the other branches.
> Thanks,
> Shri
> -----Original Message-----
> From: satish balay <balay at mcs.anl.gov>
> Date: Tue, 9 Sep 2014 17:50:58 -0500
> To: petsc-dev mailing list <petsc-dev at mcs.anl.gov>
> Subject: [petsc-dev] unwind next branch
> >Jed,
> >After 3.5 release we have not unwound next branch.
> >With 3.5.2 out - is it a good time to unwind?
> >This might need some coordination as there are some old branches that
> >are not yet merged to master/next.. (so they need rebase?)
> >balay at asterix /home/balay/petsc (master)
> >$ comm -12 <(git branch -r --merged next | sort) <(git branch -r
> >--no-merged master | sort)
> >  origin/balay/fix-glibc-2.20_DEFAULT_SOURCE
> >  origin/balay/update-etags
> >  origin/balay/update-hdf5
> >  origin/jed/sr-driver4
> >  origin/jed/vecghostgetvalues
> >  origin/karpeev/fix-ksp-pcgasm
> >  origin/knepley/feature-optcontrol-mg
> >  origin/knepley/feature-plex-nasm
> >  origin/knepley/feature-quadrature-fortran
> >  origin/knepley/fix-quadrature-order
> >  origin/madams/sr-driver4
> >  origin/mlange05/fix-gmsh-coordinates
> >  origin/next
> >  origin/paulmullowney/aijcusp-ellpack-fix
> >  origin/prbrune/sf-examplefix
> >  origin/prbrune/snes-ex19vtkoutput
> >  origin/sarich/fix-tao-linesearch-reset
> >  origin/sarich/fix-tao-pounders-repeating
> >  origin/sarich/tao-add-fortran-stubs
> >  origin/sarich/tao-get-number-ksp-its
> >  origin/sarich/tao-history-store-ksp-its
> >  origin/stefano_zampini/pcbddc-changeofbasis
> >  origin/stefano_zampini/pcbddc_deluxe
> >  origin/stefano_zampini/pcbddc-primalfixes
> >  origin/tisaac/dm-dim-embed-auto
> >  origin/tisaac/thplex
> >  origin/tisaac/thplex-remove-ksp-loop
> >[how about branches that got merged from bitbucket web interface?]
> >I see you [or someone else] did some branch cleanup. Perhaps there are
> >more branches that can be deleted on the server.
> >I see the following branches merged to v3.5 release. perhaps they can
> >be deleted now?
> >Thanks,
> >Satish
> >$ git branch -r --merged v3.5 |egrep -v origin\/\(master\|maint\|next\)
> >  origin/balay/add-ISColoringValue-to-finclude
> >  origin/balay/chk-optflags-in-cflags
> >  origin/balay/fix-multiple-zisltogf.c
> >  origin/balay/fix-win32-printf-2digit-exponent
> >  origin/balay/remove_intel_fast
> >  origin/barry/feature-OSX-example
> >  origin/barry/feature-dmmoab-hdf5-tests
> >  origin/barry/fix-istogeneral_block
> >  origin/barry/fix-matlab-socket
> >  origin/barry/fix-redundant-matrix
> >  origin/barry/vince
> >  origin/bermeo/add-mkl-pardiso
> >  origin/hzhang/mat-inertia
> >  origin/jed/license
> >  origin/knepley/doc-fe-dualspace
> >  origin/knepley/feature-problem-class
> >  origin/knepley/feature-quad-fas
> >  origin/knepley/fix-complex-build
> >  origin/knepley/fix-fe-gpu
> >  origin/sarich/fix-tao-linesearch-counter-view
> >  origin/sarich/tao-purge-dm
> >  origin/shri/ts-events
> >  origin/stefano_zampini/pcbddc-maint
