[petsc-dev] unwind next branch
Matthew Knepley
knepley at gmail.com
Wed Sep 10 06:14:31 CDT 2014
On Tue, Sep 9, 2014 at 6:33 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 9 Sep 2014, Jed Brown wrote:
> > Satish Balay <balay at mcs.anl.gov> writes:
> > > Jed,
> > > After 3.5 release we have not unwound next branch.
> > > With 3.5.2 out - is it a good time to unwind?
> > > This might need some coordination as there are some old branches that
> > > are not yet merged to master/next.. (so they need rebase?)
> > I'd rather re-merge than rebase unless there was something wrong with
> the original version.
> > > balay at asterix /home/balay/petsc (master)
> > > $ comm -12 <(git branch -r --merged next | sort) <(git branch -r
> --no-merged master | sort)
> > > origin/balay/fix-glibc-2.20_DEFAULT_SOURCE
> > > origin/balay/update-etags
> > > origin/balay/update-hdf5
> > > origin/jed/sr-driver4
> > > origin/jed/vecghostgetvalues
> > > origin/karpeev/fix-ksp-pcgasm
> > > origin/knepley/feature-optcontrol-mg
> > > origin/knepley/feature-plex-nasm
> > > origin/knepley/feature-quadrature-fortran
> > > origin/knepley/fix-quadrature-order
> > > origin/madams/sr-driver4
> > > origin/mlange05/fix-gmsh-coordinates
> > > origin/next
> > > origin/paulmullowney/aijcusp-ellpack-fix
> > > origin/prbrune/sf-examplefix
> > > origin/prbrune/snes-ex19vtkoutput
> > > origin/sarich/fix-tao-linesearch-reset
> > > origin/sarich/fix-tao-pounders-repeating
> > > origin/sarich/tao-add-fortran-stubs
> > > origin/sarich/tao-get-number-ksp-its
> > > origin/sarich/tao-history-store-ksp-its
> > > origin/shri/ts-dae-semi-explicit
> > > origin/shri/ts-is-for-differential-variables
> > > origin/shri/ts-powergrid
> > > origin/stefano_zampini/pcbddc-changeofbasis
> > > origin/stefano_zampini/pcbddc_deluxe
> > > origin/stefano_zampini/pcbddc-primalfixes
> > > origin/tisaac/dm-dim-embed-auto
> > > origin/tisaac/thplex
> > > origin/tisaac/thplex-remove-ksp-loop
> > > [how about branches that got merged from bitbucket web interface?]
> > I hope that didn't happen much. Let's give people some time to comment
> > on these branches. Let's try to graduate those that can in the near
> > future, then reset 'next' and re-merge the left-over branches.
> Ok.
> Also we have quiet a few development branches. Not sure if any
> of them are abandoned [and should be purged..]. Perhaps we
> should review these branches aswell.
> Satish
> $ git branch -r --no-merged origin/next |cat
> origin/HEAD -> origin/master
> origin/adams/zeroDSOR
> origin/balay/atpesc-tutorial-2014-bgq
> origin/balay/giturl-fixes
> origin/barry/add-snespseudo
> origin/barry/august-tutorial
> origin/barry/fix-prefix-installs
> origin/barry/html
> origin/barry/make-petscoptionsobject-nonglobal
> origin/barry/new-test-makefiles
> origin/barry/newhtml
> origin/barry/saws-options
> origin/barry/superlu_mt
> origin/barry/twitter
> origin/dalcinl/dm-destroy
> origin/debo/mat-taij
> origin/debo/ts-irk
> origin/emil/fix-ts-dae
> origin/hzhang/fix-ptaptest
> origin/hzhang/ksp-fminres
> origin/hzhang/ksp-minresqlp
> origin/irving/fe-scalars
> origin/irving/snes-ex12-cleanup
> origin/jed/assembly-perf
> origin/jed/august-tutorial
> origin/jed/chem
> origin/jed/cray-externc
> origin/jed/defined-nocpp
> origin/jed/feature-dmda-section
> origin/jed/feature-sf-local
> origin/jed/ksp-plugin
> origin/jed/mat-eigenvalue-cache
> origin/jed/mat-taij
> origin/jed/next-seaice
> origin/jed/tap
> origin/jed/ts-ex11-union
> origin/jed/ts-heat-plex
> origin/jose/mumps-bugfix
> origin/karpeev/fix-pc-fieldsplit-reset
> origin/klaij/fieldsplit-simple-ex70
> Delete origin/knepley/dmswarm
> Keep origin/knepley/feature-da-repartition
> Merged origin/knepley/feature-ds-fortran-example
> Keep origin/knepley/feature-fe-fv-hybrid
> Merged origin/knepley/fix-mem-init
> Keep origin/knepley/pylith
> Keep origin/knepley/solkx
> Delete origin/knepley/sr-driver
> Keep origin/knepley/swarm
Matt
origin/madams/ex56params
> origin/madams/sor-residual
> origin/madams/sr-driver2
> origin/madams/sr1
> origin/maint
> origin/maint-tao-2.2
> origin/mark/dmshell-ltogmap
> origin/mark/dmshell-test
> origin/mark/fortanenums
> origin/mark/gamg-zerod
> origin/master
> origin/mlange/fix-adjacency-performance
> origin/mlange/plex-distributed-overlap
> origin/mlange/plex-redistribute
> origin/mlange/plex-vertex-partitioning
> origin/peller/threadcomm
> origin/prbrune/matcoloring-creategraph
> origin/prbrune/matcoloring-minpack
> origin/prbrune/matcoloring-misimprovement
> origin/prbrune/matcoloring-zoltan
> origin/prbrune/pcgamg-bootstrap
> origin/prbrune/pcgamg-classicalbootstrap
> origin/prbrune/pcgamg-cr
> origin/prbrune/snes-fasadditive
> origin/prbrune/zoltanupdate
> origin/psanan/ts-bz-examples
> origin/psanan/ts-multiscale
> origin/psanan/ts-rhs-partitions
> origin/psanan/ts-tests
> origin/psanan/vec-mtdot-fix
> origin/sarich/fix-tao-example-warning
> origin/sarich/rnet-all
> origin/sarich/rnet-fix-rebase
> origin/sarich/rnet-import
> origin/sarich/snesvi-subvec-options
> origin/sarich/tao-docs-update
> origin/sarich/tao-lnks
> origin/sarich/tao-separate-state-design
> origin/shri/FTRTDS-project
> origin/shri/external-package-KLU
> origin/shri/feature-dm-circuit
> origin/stefano_zampini/dmda-changeaotype
> origin/stefano_zampini/dmdagetao-memscalable
> origin/stefano_zampini/hypre-ams
> origin/tisaac/fix-gamg-set-coordinates
> origin/tisaac/petsc-next-upstream
> origin/tisaac/thplex-on-master
> origin/tisaac/warn-next-upstream
> origin/xolotl
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140910/cc5b0a83/attachment.html>
