[petsc-dev] configure default to --with-etags=0 ?
Mon Sep 8 22:40:14 CDT 2014
On Mon, 8 Sep 2014, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> > In the first case etags is processing 'makefile' as
> > --language=makefile. But in the second - case - its unable to infer
> > that info :(
> You could report it as a bug, but I think Global is a superior product
> so that's what I use.
Will have to check global at some point. etags has been working on many machines
[without special install].
wrt makefiles - we usually do a tags-search - not find-tag - so this
is not a big regression.
I've pushed my changes to balay/update-etags and merged to next.
Satish
