[petsc-dev] 'master' RESET after bad merge! - 'tisaac/thplex' was based on 'next'
Jed Brown jed at jedbrown.org
Thu Sep 4 12:09:32 CDT 2014
Matthew Knepley <knepley at gmail.com> writes:
> And I do not believe that there is "no way" that this check would not
> be missed.  I know you do. I think you suffer from lack of
> imagination. This is a fatal flaw when designing fault tolerant
> systems.
How close have you been to a live bear?  They are not known for
discreetness.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140904/1de63111/attachment.sig>
