[petsc-dev] 'master' RESET after bad merge! - 'tisaac/thplex' was based on 'next'
Satish Balay
balay at mcs.anl.gov
Thu Sep 4 09:12:02 CDT 2014
On Thu, 4 Sep 2014, Tobin Isaac wrote:
> > My personal opinion is that maintaining a catalog of undesirable commits
> > and detection/enforcement logic is not the best use of maintainer time
> > and will not result in a more efficient system. But if you want to
> > spend your time on it, give it a shot and maybe others will use it too.
> Funny you should say that.
> https://bitbucket.org/petsc/petsc/commits/a04f2a265ee1457256d59a436256ddce6a927374
> https://bitbucket.org/petsc/petsc/commits/7a9516f4bcf47790ec9d70380d83bb015f0d3e8e
> My idea here is (a) create a dotfile in a commit that only gets merged
> into next, and (b) add a hook to 'make info' that warns you if that
> file is present and your branch isn't named 'next'. This change
> doesn't help a maintainer, who knows the workflow and can spot
> undesirable commits better than a script, but it does reach out to
> developers who, ehm, may not have read the wiki, and warns them as
> soon as they start to test their changes on a branch that was based on
> 'next'.
the nightly builds are done in 'detached' mode - so this warning wil always
printed for these builds.
And when folks hardly look at git messages - I don't thinks they will notice
this message burried in middle of a build. [And most of the time merge/push
is done without a build]. So I don't think this change helps much..
Id rather folks use 'git log ..branch' before 'git merge branch'
Satish
