[petsc-dev] 'master' RESET after bad merge! - 'tisaac/thplex' was based on 'next'
Thu Sep 4 06:03:49 CDT 2014
On Thu, Sep 4, 2014 at 12:56 AM, Tobin Isaac <tisaac at ices.utexas.edu> wrote:
>  My personal opinion is that maintaining a catalog of undesirable commits
>> and detection/enforcement logic is not the best use of maintainer time
>> and will not result in a more efficient system.  But if you want to
>> spend your time on it, give it a shot and maybe others will use it too.
> Funny you should say that.
> https://bitbucket.org/petsc/petsc/commits/a04f2a265ee1457256d59a436256dd
> ce6a927374
> https://bitbucket.org/petsc/petsc/commits/7a9516f4bcf47790ec9d70380d83bb
> 015f0d3e8e
> My idea here is (a) create a dotfile in a commit that only gets merged
> into next, and (b) add a hook to 'make info' that warns you if that
> file is present and your branch isn't named 'next'.  This change
> doesn't help a maintainer, who knows the workflow and can spot
> undesirable commits better than a script, but it does reach out to
> developers who, ehm, may not have read the wiki, and warns them as
> soon as they start to test their changes on a branch that was based on
> 'next'.
Cool, that is what I want.
  Matt
>   Toby
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140904/73e36ee0/attachment.html>
