[petsc-dev] DMGetDS in fortran
Adrian Croucher
a.croucher at auckland.ac.nz
Sun Nov 30 16:40:42 CST 2014
hi
On 29/11/14 01:43, Matthew Knepley wrote:
> Every time we add a type to PETSc, we have to tell the Fortran stub
> generator about it. This is a clunky part of the
> design, but there is not enough momentum to change it. Can you try
> deleting your PETSC_ARCH directory and
> reconfiguring? FIRST,
> cd $PETSC_DIR
> mv $PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py .
> so that you can get the same configuration.
Thanks, that has done the trick! I must remember that in case I run into
it again.
> Also, any chance of a fortran interface to DMPlexCreateFromFile()?
> It appears to be missing at the moment.
> Yes, I can add this.
Thanks again, much appreciated.
Cheers, Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 84611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141201/f6a682df/attachment.html>
