[petsc-dev] I hate nagupgrade
Karl Rupp
rupp at iue.tuwien.ac.at
Wed Nov 12 01:59:59 CST 2014
Hey,
>> I bet that some Germans would still be very upset about an opt-out
rather than an opt-in (yes, this is a cultural issue...).
>> Is there much value from a nagupgrade check at configure-time? Those who download a fresh copy of PETSc don't have any benefit from the check. After the installation, the check has no effect
> Karl,
> I don't understand? Is there a bug in the current code? If the user has write access to the $PETSC_DIR directory it will print a nag at most once every 24 hours. Otherwise it will print a nag every time they do a make with the PETSc makefiles. Is it not working for you?
Well, it is - but since my usual work flow involves a fresh pull and
configure at the start of the day, I was incorrectly assuming that this
is tied to configure. :-/
Best regards,
Karli
