[petsc-dev] How to do LU factorization using SuperLU_dist and reuse the factorization?
Stefano Zampini stefano.zampini at gmail.com
Fri Nov 7 07:43:33 CST 2014
If you could use MUMPS, you can use MatSolves
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141107/a1530471/attachment.html>
