[petsc-dev] Why do we pass -L/usr/lib ?
Jed Brown jed at jedbrown.org
Thu Nov 6 14:57:53 CST 2014
Satish Balay <balay at mcs.anl.gov> writes:
> I don't think we (configure) can easily deal with multiple copies of libraries.
> /usr/lib doesn't matter. It could be /foo/bar and /abc/xyz/. Its
> possible for configure to test for package 'a' in the first location -
> and test for package 'b' in the second location - but when the link
> line is assembled - one of the packages from the wrong location can be
> picked up.
I'm aware of that; I'm complaining about the order-dependence.  In this
case, I would get a correct build if all the -L options were removed
(because with these mpicc wrappers, /opt/mpich/lib/ is searched before
/usr/lib/).  I'm afraid I don't know how to test for this and passing
/opt/mpich/lib/libparmetis.so /usr/lib/libmetis.so ... is not a solution
because it just defers link resolution to the ordering of rpath
processing.
> And wrt --with-package-dir=/usr - if thats what the user wants to do
> [and not rely on compiler default search paths using --with-package=1
> option] - we should respect that.. [and present errors if they occur].
Configure never even tries linking -lmetis.
                              Pushing language C
                              Popping language C
                              Pushing language CUDA
                              Popping language CUDA
                              Pushing language Cxx
                              Popping language Cxx
                              Pushing language FC
                              Popping language FC
Starting Configure Run at Thu Nov  6 23:43:15 2014
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --with-metis=1 --with-mpi-dir=/opt/mpich PETSC_ARCH=mpich-test
Working directory: /home/jed/petsc
Machine platform:
('Linux', 'batura', '3.17.2-1-ARCH', '#1 SMP PREEMPT Thu Oct 30 20:49:39 CET 2014', 'x86_64', '')
Python version:
2.7.8 (default, Sep 24 2014, 18:26:21)
[GCC 4.9.1 20140903 (prerelease)]
          Pushing language C
          Popping language C
          Pushing language FC
          Popping language FC
TEST configureExternalPackagesDir from config.framework(/home/jed/petsc/config/BuildSystem/config/framework.py:823)
TESTING: configureExternalPackagesDir from config.framework(config/BuildSystem/config/framework.py:823)
TEST configureDebuggers from config.utilities.debuggers(/home/jed/petsc/config/BuildSystem/config/utilities/debuggers.py:22)
TESTING: configureDebuggers from config.utilities.debuggers(config/BuildSystem/config/utilities/debuggers.py:22)
  Find a default debugger and determine its arguments
Checking for program /home/jed/bin/gdb...not found
Checking for program /usr/bin/gdb...found
            Defined make macro "GDB" to "/usr/bin/gdb"
Checking for program /home/jed/bin/dbx...not found
Checking for program /usr/bin/dbx...not found
Checking for program /usr/lib/mailman/bin/dbx...not found
Checking for program /opt/mpich/bin/dbx...not found
Checking for program /usr/bin/site_perl/dbx...not found
Checking for program /usr/bin/vendor_perl/dbx...not found
Checking for program /usr/bin/core_perl/dbx...not found
Checking for program /opt/visit/bin/dbx...not found
Checking for program /home/jed/dbx...not found
Checking for program /home/jed/bin/xdb...not found
Checking for program /usr/bin/xdb...not found
Checking for program /usr/lib/mailman/bin/xdb...not found
Checking for program /opt/mpich/bin/xdb...not found
Checking for program /usr/bin/site_perl/xdb...not found
Checking for program /usr/bin/vendor_perl/xdb...not found
Checking for program /usr/bin/core_perl/xdb...not found
Checking for program /opt/visit/bin/xdb...not found
Checking for program /home/jed/xdb...not found
Checking for program /home/jed/bin/dsymutil...not found
Checking for program /usr/bin/dsymutil...not found
Checking for program /usr/lib/mailman/bin/dsymutil...not found
Checking for program /opt/mpich/bin/dsymutil...not found
Checking for program /usr/bin/site_perl/dsymutil...not found
Checking for program /usr/bin/vendor_perl/dsymutil...not found
Checking for program /usr/bin/core_perl/dsymutil...not found
Checking for program /opt/visit/bin/dsymutil...not found
Checking for program /home/jed/dsymutil...not found
          Defined make macro "DSYMUTIL" to "true"
          Defined "USE_GDB_DEBUGGER" to "1"
TEST configureGit from config.sourceControl(/home/jed/petsc/config/BuildSystem/config/sourceControl.py:24)
TESTING: configureGit from config.sourceControl(config/BuildSystem/config/sourceControl.py:24)
  Find the Git executable
Checking for program /home/jed/bin/git...not found
Checking for program /usr/bin/git...found
            Defined make macro "GIT" to "git"
Executing: git --version
stdout: git version 2.1.3
TEST configureMercurial from config.sourceControl(/home/jed/petsc/config/BuildSystem/config/sourceControl.py:35)
TESTING: configureMercurial from config.sourceControl(config/BuildSystem/config/sourceControl.py:35)
  Find the Mercurial executable
Checking for program /home/jed/bin/hg...not found
Checking for program /usr/bin/hg...found
            Defined make macro "HG" to "hg"
Executing: hg version -q
stdout: Mercurial Distributed SCM (version 3.1.2)
TEST configureCVS from config.sourceControl(/home/jed/petsc/config/BuildSystem/config/sourceControl.py:46)
TESTING: configureCVS from config.sourceControl(config/BuildSystem/config/sourceControl.py:46)
  Find the CVS executable
Checking for program /home/jed/bin/cvs...not found
Checking for program /usr/bin/cvs...found
            Defined make macro "CVS" to "cvs"
Executing: cvs --version
stdout:
Concurrent Versions System (CVS) 1.11.23 (client/server)
Copyright (C) 2006 Free Software Foundation, Inc.
Senior active maintainers include Larry Jones, Derek R. Price,
and Mark D. Baushke.  Please see the AUTHORS and README files from the CVS
distribution kit for a complete list of contributors and copyrights.
CVS may be copied only under the terms of the GNU General Public License,
a copy of which can be found with the CVS distribution kit.
Specify the --help option for further information about CVS
TEST configureSubversion from config.sourceControl(/home/jed/petsc/config/BuildSystem/config/sourceControl.py:55)
TESTING: configureSubversion from config.sourceControl(config/BuildSystem/config/sourceControl.py:55)
  Find the Subversion executable
Checking for program /home/jed/bin/svn...not found
Checking for program /usr/bin/svn...found
            Defined make macro "SVN" to "svn"
Executing: svn --version -q
stdout: 1.8.10
TEST configureCLanguage from PETSc.options.languages(/home/jed/petsc/config/PETSc/options/languages.py:27)
TESTING: configureCLanguage from PETSc.options.languages(config/PETSc/options/languages.py:27)
  Choose whether to compile the PETSc library using a C or C++ compiler
        C language is C
          Defined "CLANGUAGE_C" to "1"
TEST configureDirectories from PETSc.options.petscdir(/home/jed/petsc/config/PETSc/options/petscdir.py:23)
TESTING: configureDirectories from PETSc.options.petscdir(config/PETSc/options/petscdir.py:23)
  Checks PETSC_DIR and sets if not set
        Version Information:
        #define PETSC_VERSION_RELEASE    0
        #define PETSC_VERSION_MAJOR      3
        #define PETSC_VERSION_MINOR      5
        #define PETSC_VERSION_SUBMINOR   2
        #define PETSC_VERSION_PATCH      0
        #define PETSC_VERSION_DATE       "unknown"
        #define PETSC_VERSION_GIT        "unknown"
        #define PETSC_VERSION_DATE_GIT   "unknown"
        #define PETSC_VERSION_(MAJOR,MINOR,SUBMINOR) \
        #define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR)          \
        #define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
        #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
        #define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
          Defined make macro "DIR" to "/home/jed/petsc"
TEST configureInstallationMethod from PETSc.options.petscclone(/home/jed/petsc/config/PETSc/options/petscclone.py:15)
TESTING: configureInstallationMethod from PETSc.options.petscclone(config/PETSc/options/petscclone.py:15)
        bin/maint exists. This appears to be a repository clone
          Defined "VERSION_GIT" to ""v3.5.2-939-geeb4e01""
          Defined "VERSION_DATE_GIT" to ""2014-11-05 15:13:20 -0600""
          Defined "VERSION_BRANCH_GIT" to ""master""
TEST getDatafilespath from PETSc.options.dataFilesPath(/home/jed/petsc/config/PETSc/options/dataFilesPath.py:29)
TESTING: getDatafilespath from PETSc.options.dataFilesPath(config/PETSc/options/dataFilesPath.py:29)
  Checks what DATAFILESPATH should be
TEST configureArchitecture from PETSc.options.arch(/home/jed/petsc/config/PETSc/options/arch.py:25)
TESTING: configureArchitecture from PETSc.options.arch(config/PETSc/options/arch.py:25)
  Checks PETSC_ARCH and sets if not set
                Warning: PETSC_ARCH from environment does not match command-line or name of script.
                Warning: Using from command-line or name of script: mpich-test, ignoring environment: mpich
          Defined "ARCH" to ""mpich-test""
TEST setInstallDir from PETSc.options.installDir(/home/jed/petsc/config/PETSc/options/installDir.py:34)
TESTING: setInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:34)
   setup installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH
TEST saveReconfigure from PETSc.options.installDir(/home/jed/petsc/config/PETSc/options/installDir.py:73)
TESTING: saveReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:73)
TEST cleanInstallDir from PETSc.options.installDir(/home/jed/petsc/config/PETSc/options/installDir.py:66)
TESTING: cleanInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:66)
TEST configureInstallDir from PETSc.options.installDir(/home/jed/petsc/config/PETSc/options/installDir.py:50)
TESTING: configureInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:50)
  Makes  installDir subdirectories if it does not exist for both prefix install location and PETSc work install location
        Changed persistence directory to /home/jed/petsc/mpich-test/conf
TEST restoreReconfigure from PETSc.options.installDir(/home/jed/petsc/config/PETSc/options/installDir.py:86)
TESTING: restoreReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:86)
TEST setExternalPackagesDir from PETSc.options.externalpackagesdir(/home/jed/petsc/config/PETSc/options/externalpackagesdir.py:15)
TESTING: setExternalPackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:15)
TEST cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/home/jed/petsc/config/PETSc/options/externalpackagesdir.py:22)
TESTING: cleanExternalpackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:22)
TEST printEnvVariables from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:1533)
TESTING: printEnvVariables from config.setCompilers(config/BuildSystem/config/setCompilers.py:1533)
        **** printenv ****
MATLAB_PATH=/home/jed/usr/share/matlab
LESS=--ignore-case --hilite-unread --long-prompt --RAW-CONTROL-CHARS --quit-if-one-screen --no-init
EMAIL=Jed Brown <jed at 59A2.org>
SHELL=/bin/bash
COLORFGBG=0;15
XDG_DATA_DIRS=/usr/local/share:/usr/share
TAO_DIR=/home/jed/tao
MANPATH=:/home/jed/usr/share/man:/home/oracle/SolarisStudio12.3-linux-x86-bin/solarisstudio12.3/share/man:/opt/mpich/share/man
PETSC_OPTIONS=-malloc_test
TIMEFORMAT=%3R real   %3U user   %3S sys   %P cpu
PETSC_DIR=/home/jed/petsc
METHOD=dbg
XDG_RUNTIME_DIR=/run/user/1000
PYTHONPATH=/home/jed/usr/lib/python2.7/site-packages:/home/jed/petsc/bin/pythonscripts
VPPFORM=A4.DUPLEX
SCONSFLAGS=-Q
DOHP_DIR=/home/jed/dohp
XDG_SESSION_ID=c1
DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-0D8QwdOptq,guid=ed75c3e9a1da282782535ffb545b1498
GTK_MODULES=canberra-gtk-module
DESKTOP_SESSION=xfce
MOZ_PLUGIN_PATH=/usr/lib/mozilla/plugins
PATH_SAVE=/home/jed/bin:/usr/bin:/usr/lib/mailman/bin:/opt/mpich/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/opt/visit/bin
PETSC_ARCH=mpich
SLEPC_DIR=/home/jed/slepc
MAIL=/var/spool/mail/jed
XAUTHORITY=/home/jed/.Xauthority
GOROOT=/home/jed/src/golang
CDR_DEVICE=/dev/cdrw
USER=jed
XDG_VTNR=1
HG=/usr/bin/hg
VPPDEV=PTS
XAPIAN_CONFIG=/usr/bin/xapian-config
SHLVL=7
DISPLAY=:0.0
WINDOWID=62914569
GOARCH=amd64
EDITOR=emacsclient -t
GPG_AGENT_INFO=/home/jed/.gnupg/S.gpg-agent:2885:1
IREL_DIR=/home/jed/usr/itaps-ompi
PYTHONPATH_SAVE=/home/jed/usr/lib/python2.7/site-packages:/home/jed/petsc/bin/pythonscripts
XAPPLRESDIR=/home/jed/.app-defaults
DATAFILESPATH=/home/jed/petsc/datafiles
TMUX=/tmp/tmux-1000/default,3203,0
XDG_MENU_PREFIX=xfce-
PKG_CONFIG_PATH=/home/jed/usr/lib/pkgconfig:/opt/mpich/lib/pkgconfig
_=/usr/bin/python2
BROWSER=google-chrome --enable-plugins
GREP_OPTIONS=--binary-files=without-match --directories=skip --color=auto
XDG_CONFIG_DIRS=/etc/xdg
DARCS_EMAIL=Jed Brown <jed at 59A2.org>
CTEST_OUTPUT_ON_FAILURE=1
COLORTERM=rxvt
LIBMESH_DIR=/home/jed/usr/libmesh-mpich
ADIC_ARCH=linux
PAGER=less
ACK_OPTIONS=--pager=less --nohtml
IGEOM_DIR=/home/jed/usr/itaps-ompi
PS_PERSONALITY=linux
HOME=/home/jed
LD_LIBRARY_PATH=:/home/jed/usr/paraview/lib:/usr/lib/R/lib
MOOSE_DEV=true
LANG=en_US.UTF-8
VPPDEST=vawa19
MPIHOME=/usr
FIREFOX_DSP=aoss
TERMINFO=/usr/share/terminfo
ROSE_SOURCE_DIR=/home/jed/src/ad/rose
VISUAL=emacsclient -t
ADIC=/home/jed/usr/adic-1.2.0
KDEDIRS=/home/jed/usr/kde-dev:/usr
OMPI_MCA_mpi_yield_when_idle=1
TMUX_PANE=%20
OPENSSL_LIBS=-lssl -lcrypto
GLADE_PIXMAP_PATH=:
ALTERNATE_EDITOR=emacs-quick
LOGNAME=jed
XDG_SEAT=seat0
PATH=/home/jed/bin:/usr/bin:/usr/lib/mailman/bin:/opt/mpich/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/opt/visit/bin
SSH_AGENT_PID=2885
TERM=screen-256color
ROSE_INST_DIR=/home/jed/usr/rose
KRB5_CONFIG=/home/jed/.krb5.conf
WINDOWPATH=1
GLADE_CATALOG_PATH=:
ROSE_BUILD_DIR=/home/jed/src/ad/rose/build-gcc
GLADE_MODULE_PATH=:
OOO_FORCE_DESKTOP=gnome
SSH_AUTH_SOCK=/home/jed/.gnupg/S.gpg-agent.ssh
GOOS=linux
IMESH_DIR=/home/jed/usr/itaps-ompi
OLDPWD=/home/jed
SESSION_MANAGER=local/batura:@/tmp/.ICE-unix/2872,unix/batura:/tmp/.ICE-unix/2872
PWD=/home/jed/petsc
TEST resetEnvCompilers from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:1540)
TESTING: resetEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1540)
TEST checkMPICompilerOverride from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:1505)
TESTING: checkMPICompilerOverride from config.setCompilers(config/BuildSystem/config/setCompilers.py:1505)
  Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
    This usually prevents mpi compilers from being used - so issue a warning
TEST requireMpiLdPath from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:1524)
TESTING: requireMpiLdPath from config.setCompilers(config/BuildSystem/config/setCompilers.py:1524)
  OpenMPI wrappers require LD_LIBRARY_PATH set
TEST checkVendor from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:398)
TESTING: checkVendor from config.setCompilers(config/BuildSystem/config/setCompilers.py:398)
  Determine the compiler vendor
        Compiler vendor is ""
TEST checkInitialFlags from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:408)
TESTING: checkInitialFlags from config.setCompilers(config/BuildSystem/config/setCompilers.py:408)
  Initialize the compiler and linker flags
          Pushing language C
        Initialized CFLAGS to
        Initialized LDFLAGS to
          Popping language C
        Initialized CUDAFLAGS to
        Initialized CXXFLAGS to
        Initialized CXX_CXXFLAGS to
          Pushing language FC
        Initialized FFLAGS to
          Popping language FC
        Initialized CPPFLAGS to
        Initialized CUDAPPFLAGS to
        Initialized CXXCPPFLAGS to
        Initialized CC_LINKER_FLAGS to []
        Initialized CXX_LINKER_FLAGS to []
        Initialized FC_LINKER_FLAGS to []
        Initialized CUDAC_LINKER_FLAGS to []
        Initialized sharedLibraryFlags to []
        Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:534)
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:534)
  Locate a functional C compiler
Checking for program /opt/mpich/bin/mpicc...found
            Defined make macro "CC" to "/opt/mpich/bin/mpicc"
            Pushing language C
                        All intermediate test results are stored in /tmp/petsc-lhuj9c
                      All intermediate test results are stored in /tmp/petsc-lhuj9c/config.setCompilers
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers   /tmp/petsc-lhuj9c/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                            Pushing language C
                                            Popping language C
                                            Pushing language FC
                                            Popping language FC
                    Pushing language C
                    Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    /tmp/petsc-lhuj9c/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    /tmp/petsc-lhuj9c/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
collect2: error: ld returned 1 exit status
Successful compile:
Source:
int main() {
  return 0;
                        Pushing language C
                        Popping language C
Testing executable /tmp/petsc-lhuj9c/config.setCompilers/conftest to see if it can be run
Executing: /tmp/petsc-lhuj9c/config.setCompilers/conftest
            Popping language C
TEST checkCPreprocessor from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:568)
TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:568)
  Locate a functional C preprocessor
            Defined make macro "CPP" to "/opt/mpich/bin/mpicc -E"
          Pushing language C
Executing: /opt/mpich/bin/mpicc -E  -I/tmp/petsc-lhuj9c/config.setCompilers  /tmp/petsc-lhuj9c/config.setCompilers/conftest.c
stdout:
# 1 "/tmp/petsc-lhuj9c/config.setCompilers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-lhuj9c/config.setCompilers/confdefs.h" 1
# 2 "/tmp/petsc-lhuj9c/config.setCompilers/conftest.c" 2
# 1 "/tmp/petsc-lhuj9c/config.setCompilers/conffix.h" 1
# 3 "/tmp/petsc-lhuj9c/config.setCompilers/conftest.c" 2
# 1 "/usr/include/stdlib.h" 1 3 4
# 24 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 395 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 396 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 25 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 324 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef int wchar_t;
# 33 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitflags.h" 1 3 4
# 42 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitstatus.h" 1 3 4
# 64 "/usr/include/bits/waitstatus.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 27 "/usr/include/bits/byteswap.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 28 "/usr/include/bits/byteswap.h" 2 3 4
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 65 "/usr/include/bits/waitstatus.h" 2 3 4
union wait
    int w_status;
    struct
 unsigned int __w_termsig:7;
 unsigned int __w_coredump:1;
 unsigned int __w_retcode:8;
 unsigned int:16;
      } __wait_terminated;
    struct
 unsigned int __w_stopval:8;
 unsigned int __w_stopsig:8;
 unsigned int:16;
      } __wait_stopped;
# 43 "/usr/include/stdlib.h" 2 3 4
# 67 "/usr/include/stdlib.h" 3 4
typedef union
    union wait *__uptr;
    int *__iptr;
  } __WAIT_STATUS __attribute__ ((__transparent_union__));
# 95 "/usr/include/stdlib.h" 3 4
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
# 139 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (const char *__nptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
__extension__ extern long long int atoll (const char *__nptr)
extern double strtod (const char *__restrict __nptr,
        char **__restrict __endptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern float strtof (const char *__restrict __nptr,
       char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long double strtold (const char *__restrict __nptr,
extern long int strtol (const char *__restrict __nptr,
   char **__restrict __endptr, int __base)
extern unsigned long int strtoul (const char *__restrict __nptr,
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
# 305 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (const char *__s)
# 1 "/usr/include/sys/types.h" 1 3 4
# 27 "/usr/include/sys/types.h" 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 60 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 98 "/usr/include/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 132 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/time.h" 1 3 4
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 133 "/usr/include/sys/types.h" 2 3 4
# 146 "/usr/include/sys/types.h" 3 4
# 147 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 194 "/usr/include/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 219 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/sigset.h" 1 3 4
# 22 "/usr/include/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
# 44 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 46 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 64 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 96 "/usr/include/sys/select.h" 3 4
# 106 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 118 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 131 "/usr/include/sys/select.h" 3 4
# 220 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/sysmacros.h" 1 3 4
# 24 "/usr/include/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 58 "/usr/include/sys/sysmacros.h" 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 270 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 271 "/usr/include/sys/types.h" 2 3 4
# 315 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
   size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
       int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
   size_t __statelen,
   struct random_data *__restrict __buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    __extension__ unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
        double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
        long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
       struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void cfree (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/alloca.h" 1 3 4
# 24 "/usr/include/alloca.h" 3 4
# 25 "/usr/include/alloca.h" 2 3 4
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
# 493 "/usr/include/stdlib.h" 2 3 4
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 513 "/usr/include/stdlib.h" 3 4
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 530 "/usr/include/stdlib.h" 3 4
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 578 "/usr/include/stdlib.h" 3 4
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 606 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 619 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 641 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 662 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 711 "/usr/include/stdlib.h" 3 4
extern int system (const char *__command) ;
# 733 "/usr/include/stdlib.h" 3 4
extern char *realpath (const char *__restrict __name,
         char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
typedef int (*__compar_fn_t) (const void *, const void *);
# 751 "/usr/include/stdlib.h" 3 4
extern void *bsearch (const void *__key, const void *__base,
        size_t __nmemb, size_t __size, __compar_fn_t __compar)
     __attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
     __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 774 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
        long long int __denom)
# 811 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign, char *__restrict __buf,
     size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign,
      char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int mbtowc (wchar_t *__restrict __pwc,
     const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__));
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
extern size_t wcstombs (char *__restrict __s,
   const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 898 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
        char *const *__restrict __tokens,
        char **__restrict __valuep)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 950 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 1 "/usr/include/bits/stdlib-float.h" 1 3 4
# 955 "/usr/include/stdlib.h" 2 3 4
# 967 "/usr/include/stdlib.h" 3 4
          Popping language C
TEST checkCUDACompiler from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:606)
TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:606)
  Locate a functional CUDA compiler
Checking for program /home/jed/bin/nvcc...not found
Checking for program /usr/bin/nvcc...not found
Checking for program /usr/lib/mailman/bin/nvcc...not found
Checking for program /opt/mpich/bin/nvcc...not found
Checking for program /usr/bin/site_perl/nvcc...not found
Checking for program /usr/bin/vendor_perl/nvcc...not found
Checking for program /usr/bin/core_perl/nvcc...not found
Checking for program /opt/visit/bin/nvcc...not found
Checking for program /home/jed/nvcc...not found
Checking for program /home/jed/petsc/bin/win32fe/nvcc...not found
TEST checkCUDAPreprocessor from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:646)
TESTING: checkCUDAPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:646)
  Locate a functional CUDA preprocessor
TEST checkCxxCompiler from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:758)
TESTING: checkCxxCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:758)
  Locate a functional Cxx compiler
Checking for program /opt/mpich/bin/mpicxx...found
            Defined make macro "CXX" to "/opt/mpich/bin/mpicxx"
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers     /tmp/petsc-lhuj9c/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                            Pushing language C
                                            Popping language C
                                            Pushing language FC
                                            Popping language FC
                    Pushing language CXX
                    Popping language CXX
Executing: /opt/mpich/bin/mpicxx  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    /tmp/petsc-lhuj9c/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
Executing: /opt/mpich/bin/mpicxx  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    /tmp/petsc-lhuj9c/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
TEST checkCxxPreprocessor from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:797)
TESTING: checkCxxPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:797)
  Locate a functional Cxx preprocessor
            Defined make macro "CXXCPP" to "/opt/mpich/bin/mpicxx -E"
Executing: /opt/mpich/bin/mpicxx -E  -I/tmp/petsc-lhuj9c/config.setCompilers   /tmp/petsc-lhuj9c/config.setCompilers/conftest.cc
stdout:
# 1 "/tmp/petsc-lhuj9c/config.setCompilers/conftest.cc"
# 1 "<built-in>"
# 2 "/tmp/petsc-lhuj9c/config.setCompilers/conftest.cc" 2
extern "C" {
# 3 "/tmp/petsc-lhuj9c/config.setCompilers/conftest.cc" 2
# 1 "/usr/include/c++/4.9.1/cstdlib" 1 3
# 39 "/usr/include/c++/4.9.1/cstdlib" 3
# 40 "/usr/include/c++/4.9.1/cstdlib" 3
# 1 "/usr/include/c++/4.9.1/x86_64-unknown-linux-gnu/bits/c++config.h" 1 3
# 186 "/usr/include/c++/4.9.1/x86_64-unknown-linux-gnu/bits/c++config.h" 3
namespace std
  typedef long int ptrdiff_t;
# 430 "/usr/include/c++/4.9.1/x86_64-unknown-linux-gnu/bits/c++config.h" 3
# 1 "/usr/include/c++/4.9.1/x86_64-unknown-linux-gnu/bits/os_defines.h" 1 3
# 39 "/usr/include/c++/4.9.1/x86_64-unknown-linux-gnu/bits/os_defines.h" 3
# 40 "/usr/include/c++/4.9.1/x86_64-unknown-linux-gnu/bits/os_defines.h" 2 3
# 431 "/usr/include/c++/4.9.1/x86_64-unknown-linux-gnu/bits/c++config.h" 2 3
# 1 "/usr/include/c++/4.9.1/x86_64-unknown-linux-gnu/bits/cpu_defines.h" 1 3
# 434 "/usr/include/c++/4.9.1/x86_64-unknown-linux-gnu/bits/c++config.h" 2 3
# 42 "/usr/include/c++/4.9.1/cstdlib" 2 3
# 72 "/usr/include/c++/4.9.1/cstdlib" 3
# 32 "/usr/include/stdlib.h" 3 4
extern "C" {
union wait
    int w_status;
    struct
 unsigned int:16;
    struct
 unsigned int:16;
      } __wait_stopped;
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
    long long int quot;
    long long int rem;
  } lldiv_t;
extern size_t __ctype_get_mb_cur_max (void) throw () ;
     throw () __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
     throw () __attribute__ ((__nonnull__ (1)));
       char **__restrict __endptr) throw () __attribute__ ((__nonnull__ (1)));
__extension__
__extension__
__extension__
__extension__
# 235 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/xlocale.h" 1 3 4
# 27 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 236 "/usr/include/stdlib.h" 2 3 4
extern long int strtol_l (const char *__restrict __nptr,
     char **__restrict __endptr, int __base,
     __locale_t __loc) throw () __attribute__ ((__nonnull__ (1, 4)));
extern unsigned long int strtoul_l (const char *__restrict __nptr,
        int __base, __locale_t __loc)
__extension__
extern long long int strtoll_l (const char *__restrict __nptr,
    __locale_t __loc)
__extension__
extern unsigned long long int strtoull_l (const char *__restrict __nptr,
extern double strtod_l (const char *__restrict __nptr,
   char **__restrict __endptr, __locale_t __loc)
     throw () __attribute__ ((__nonnull__ (1, 3)));
extern float strtof_l (const char *__restrict __nptr,
extern long double strtold_l (const char *__restrict __nptr,
         __locale_t __loc)
extern char *l64a (long int __n) throw () ;
extern "C" {
typedef __ino64_t ino64_t;
typedef __off64_t off64_t;
typedef __useconds_t useconds_t;
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
struct timeval
    __time_t tv_sec;
# 54 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
extern "C" {
extern "C" {
__extension__
     throw () __attribute__ ((__const__));
__extension__
__extension__
# 262 "/usr/include/sys/types.h" 3 4
typedef __blkcnt64_t blkcnt64_t;
typedef __fsblkcnt64_t fsblkcnt64_t;
typedef __fsfilcnt64_t fsfilcnt64_t;
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
extern long int random (void) throw ();
extern void srandom (unsigned int __seed) throw ();
   size_t __statelen) throw () __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) throw () __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
       int32_t *__restrict __result) throw () __attribute__ ((__nonnull__ (1, 2)));
   size_t __statelen,
     throw () __attribute__ ((__nonnull__ (2, 4)));
extern int rand (void) throw ();
extern void srand (unsigned int __seed) throw ();
extern int rand_r (unsigned int *__seed) throw ();
extern double drand48 (void) throw ();
extern double erand48 (unsigned short int __xsubi[3]) throw () __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) throw ();
extern long int mrand48 (void) throw ();
extern void srand48 (long int __seedval) throw ();
extern void lcong48 (unsigned short int __param[7]) throw () __attribute__ ((__nonnull__ (1)));
struct drand48_data
        double *__restrict __result) throw () __attribute__ ((__nonnull__ (1, 2)));
       struct drand48_data *__buffer) throw () __attribute__ ((__nonnull__ (1, 2)));
extern void *malloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
     throw () __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) throw ();
extern void cfree (void *__ptr) throw ();
extern "C" {
extern void *alloca (size_t __size) throw ();
extern void *valloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
     throw () __attribute__ ((__nonnull__ (1))) ;
extern void *aligned_alloc (size_t __alignment, size_t __size)
     throw () __attribute__ ((__malloc__)) __attribute__ ((__alloc_size__ (2))) ;
extern void abort (void) throw () __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) throw () __attribute__ ((__nonnull__ (1)));
extern "C++" int at_quick_exit (void (*__func) (void))
     throw () __asm ("at_quick_exit") __attribute__ ((__nonnull__ (1)));
extern void exit (int __status) throw () __attribute__ ((__noreturn__));
extern void quick_exit (int __status) throw () __attribute__ ((__noreturn__));
extern void _Exit (int __status) throw () __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) throw () __attribute__ ((__nonnull__ (1))) ;
extern char *secure_getenv (const char *__name)
extern int putenv (char *__string) throw () __attribute__ ((__nonnull__ (1)));
extern int unsetenv (const char *__name) throw () __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) throw ();
extern char *mktemp (char *__template) throw () __attribute__ ((__nonnull__ (1)));
# 629 "/usr/include/stdlib.h" 3 4
extern int mkstemp64 (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 651 "/usr/include/stdlib.h" 3 4
extern int mkstemps64 (char *__template, int __suffixlen)
extern char *mkdtemp (char *__template) throw () __attribute__ ((__nonnull__ (1))) ;
# 673 "/usr/include/stdlib.h" 3 4
extern int mkostemp (char *__template, int __flags) __attribute__ ((__nonnull__ (1))) ;
# 683 "/usr/include/stdlib.h" 3 4
extern int mkostemp64 (char *__template, int __flags) __attribute__ ((__nonnull__ (1))) ;
# 693 "/usr/include/stdlib.h" 3 4
extern int mkostemps (char *__template, int __suffixlen, int __flags)
# 705 "/usr/include/stdlib.h" 3 4
extern int mkostemps64 (char *__template, int __suffixlen, int __flags)
extern char *canonicalize_file_name (const char *__name)
         char *__restrict __resolved) throw () ;
typedef __compar_fn_t comparison_fn_t;
typedef int (*__compar_d_fn_t) (const void *, const void *, void *);
extern void qsort_r (void *__base, size_t __nmemb, size_t __size,
       __compar_d_fn_t __compar, void *__arg)
extern int abs (int __x) throw () __attribute__ ((__const__)) ;
extern long int labs (long int __x) throw () __attribute__ ((__const__)) ;
     int *__restrict __sign) throw () __attribute__ ((__nonnull__ (3, 4))) ;
     throw () __attribute__ ((__nonnull__ (3))) ;
     size_t __len) throw () __attribute__ ((__nonnull__ (3, 4, 5)));
extern int mblen (const char *__s, size_t __n) throw ();
     const char *__restrict __s, size_t __n) throw ();
extern int wctomb (char *__s, wchar_t __wchar) throw ();
     throw ();
extern int rpmatch (const char *__response) throw () __attribute__ ((__nonnull__ (1))) ;
     throw () __attribute__ ((__nonnull__ (1, 2, 3))) ;
extern void setkey (const char *__key) throw () __attribute__ ((__nonnull__ (1)));
extern int posix_openpt (int __oflag) ;
extern int grantpt (int __fd) throw ();
extern int unlockpt (int __fd) throw ();
extern char *ptsname (int __fd) throw () ;
extern int ptsname_r (int __fd, char *__buf, size_t __buflen)
extern int getpt (void);
# 73 "/usr/include/c++/4.9.1/cstdlib" 2 3
# 114 "/usr/include/c++/4.9.1/cstdlib" 3
namespace std __attribute__ ((__visibility__ ("default")))
  using ::div_t;
  using ::ldiv_t;
  using ::abort;
  using ::abs;
  using ::atexit;
  using ::atof;
  using ::atoi;
  using ::atol;
  using ::bsearch;
  using ::calloc;
  using ::div;
  using ::exit;
  using ::free;
  using ::getenv;
  using ::labs;
  using ::ldiv;
  using ::malloc;
  using ::mblen;
  using ::mbstowcs;
  using ::mbtowc;
  using ::qsort;
  using ::rand;
  using ::realloc;
  using ::srand;
  using ::strtod;
  using ::strtol;
  using ::strtoul;
  using ::system;
  using ::wcstombs;
  using ::wctomb;
  inline long
  abs(long __i) { return __builtin_labs(__i); }
  inline ldiv_t
  div(long __i, long __j) { return ldiv(__i, __j); }
  inline long long
  abs(long long __x) { return __builtin_llabs (__x); }
  inline __int128
  abs(__int128 __x) { return __x >= 0 ? __x : -__x; }
# 196 "/usr/include/c++/4.9.1/cstdlib" 3
namespace __gnu_cxx __attribute__ ((__visibility__ ("default")))
  using ::lldiv_t;
  using ::_Exit;
  using ::llabs;
  inline lldiv_t
  div(long long __n, long long __d)
  { lldiv_t __q; __q.quot = __n / __d; __q.rem = __n % __d; return __q; }
  using ::lldiv;
# 228 "/usr/include/c++/4.9.1/cstdlib" 3
  using ::atoll;
  using ::strtoll;
  using ::strtoull;
  using ::strtof;
  using ::strtold;
namespace std
  using ::__gnu_cxx::lldiv_t;
  using ::__gnu_cxx::_Exit;
  using ::__gnu_cxx::llabs;
  using ::__gnu_cxx::div;
  using ::__gnu_cxx::lldiv;
  using ::__gnu_cxx::atoll;
  using ::__gnu_cxx::strtof;
  using ::__gnu_cxx::strtoll;
  using ::__gnu_cxx::strtoull;
  using ::__gnu_cxx::strtold;
TEST checkFortranCompiler from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:914)
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:914)
  Locate a functional Fortran compiler
Checking for program /opt/mpich/bin/mpif90...found
            Defined make macro "FC" to "/opt/mpich/bin/mpif90"
            Pushing language FC
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers   /tmp/petsc-lhuj9c/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
                                            Pushing language C
                                            Popping language C
                                            Pushing language FC
                                            Popping language FC
                    Pushing language FC
                    Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    /tmp/petsc-lhuj9c/config.setCompilers/conftest.o
Successful compile:
Source:
      program main
      end
                    Pushing language FC
                    Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    /tmp/petsc-lhuj9c/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
      program main
      end
                        Pushing language FC
                        Popping language FC
            Popping language FC
TEST checkFortranComments from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:935)
TESTING: checkFortranComments from config.setCompilers(config/BuildSystem/config/setCompilers.py:935)
  Make sure fortran comment "!" works
          Pushing language FC
Successful compile:
Source:
! comment
      program main
      end
        Fortran comments can use ! in column 1
          Popping language FC
TEST checkPIC from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:998)
TESTING: checkPIC from config.setCompilers(config/BuildSystem/config/setCompilers.py:998)
  Determine the PIC option for each compiler
       - There needs to be a test that checks that the functionality is actually working
          Pushing language C
Executing: /opt/mpich/bin/mpicc --help
stdout:
Usage: gcc [options] file...
Options:
  -pass-exit-codes         Exit with highest error code from a phase
  --help                   Display this information
  --target-help            Display target specific command line options
  --help={common|optimizers|params|target|warnings|[^]{joined|separate|undocumented}}[,...]
                           Display specific types of command line options
  (Use '-v --help' to display command line options of sub-processes)
  --version                Display compiler version information
  -dumpspecs               Display all of the built in spec strings
  -dumpversion             Display the version of the compiler
  -dumpmachine             Display the compiler's target processor
  -print-search-dirs       Display the directories in the compiler's search path
  -print-libgcc-file-name  Display the name of the compiler's companion library
  -print-file-name=<lib>   Display the full path to library <lib>
  -print-prog-name=<prog>  Display the full path to compiler component <prog>
  -print-multiarch         Display the target's normalized GNU triplet, used as
                           a component in the library path
  -print-multi-directory   Display the root directory for versions of libgcc
  -print-multi-lib         Display the mapping between command line options and
                           multiple library search directories
  -print-multi-os-directory Display the relative path to OS libraries
  -print-sysroot           Display the target libraries directory
  -print-sysroot-headers-suffix Display the sysroot suffix used to find headers
  -Wa,<options>            Pass comma-separated <options> on to the assembler
  -Wp,<options>            Pass comma-separated <options> on to the preprocessor
  -Wl,<options>            Pass comma-separated <options> on to the linker
  -Xassembler <arg>        Pass <arg> on to the assembler
  -Xpreprocessor <arg>     Pass <arg> on to the preprocessor
  -Xlinker <arg>           Pass <arg> on to the linker
  -save-temps              Do not delete intermediate files
  -save-temps=<arg>        Do not delete intermediate files
  -no-canonical-prefixes   Do not canonicalize paths when building relative
                           prefixes to other gcc components
  -pipe                    Use pipes rather than intermediate files
  -time                    Time the execution of each subprocess
  -specs=<file>            Override built-in specs with the contents of <file>
  -std=<standard>          Assume that the input sources are for <standard>
  --sysroot=<directory>    Use <directory> as the root directory for headers
                           and libraries
  -B <directory>           Add <directory> to the compiler's search paths
  -v                       Display the programs invoked by the compiler
  -###                     Like -v but options quoted and commands not executed
  -E                       Preprocess only; do not compile, assemble or link
  -S                       Compile only; do not assemble or link
  -c                       Compile and assemble, but do not link
  -o <file>                Place the output into <file>
  -pie                     Create a position independent executable
  -shared                  Create a shared library
  -x <language>            Specify the language of the following input files
                           Permissible languages include: c c++ assembler none
                           'none' means revert to the default behavior of
                           guessing the language based on the file's extension
Options starting with -g, -f, -m, -O, -W, or --param are automatically
 passed on to the various sub-processes invoked by gcc.  In order to pass
 other options on to these processes the -W<letter> options must be used.
For bug reporting instructions, please see:
<https://bugs.archlinux.org/>.
        Trying C compiler flag -fPIC
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest  -fPIC   /tmp/petsc-lhuj9c/config.setCompilers/conftest.o
          Valid C linker flag -fPIC
        Adding C compiler flag -fPIC
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC   /tmp/petsc-lhuj9c/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -fPIC
          Popping language C
Executing: /opt/mpich/bin/mpicxx --help
stdout:
Usage: g++ [options] file...
Options:
                           and libraries
 passed on to the various sub-processes invoked by g++.  In order to pass
        Trying Cxx compiler flag -fPIC
Successful compile:
Source:
int main() {
  return 0;
Executing: /opt/mpich/bin/mpicxx  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest  -fPIC   /tmp/petsc-lhuj9c/config.setCompilers/conftest.o
          Valid Cxx linker flag -fPIC
        Adding Cxx compiler flag -fPIC
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers   -fPIC    /tmp/petsc-lhuj9c/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -fPIC
          Pushing language FC
Executing: /opt/mpich/bin/mpif90 --help
stdout:
Usage: gfortran [options] file...
Options:
                           and libraries
 passed on to the various sub-processes invoked by gfortran.  In order to pass
        Trying FC compiler flag -fPIC
Successful compile:
Source:
      program main
      end
                  Pushing language FC
                  Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest  -fPIC   /tmp/petsc-lhuj9c/config.setCompilers/conftest.o
          Valid FC linker flag -fPIC
        Adding FC compiler flag -fPIC
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC   /tmp/petsc-lhuj9c/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -fPIC
          Popping language FC
TEST checkLargeFileIO from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:1031)
TESTING: checkLargeFileIO from config.setCompilers(config/BuildSystem/config/setCompilers.py:1031)
TEST checkArchiver from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:1130)
TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1130)
  Check that the archiver exists and can make a library usable by the compiler
          Pushing language C
Executing: ar -V
stdout:
GNU ar (GNU Binutils) 2.24
Copyright 2013 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License version 3 or (at your option) any later version.
This program has absolutely no warranty.
Executing: ar -V
stdout:
              Defined make macro "FAST_AR_FLAGS" to "Scq"
Successful compile:
Source:
int foo(int a) {
  return a+1;
Checking for program /home/jed/bin/ar...not found
Checking for program /usr/bin/ar...found
            Defined make macro "AR" to "/usr/bin/ar"
Checking for program /home/jed/bin/ranlib...not found
Checking for program /usr/bin/ranlib...found
            Defined make macro "RANLIB" to "/usr/bin/ranlib -c"
Executing: /usr/bin/ar cr /tmp/petsc-lhuj9c/config.setCompilers/libconf1.a /tmp/petsc-lhuj9c/config.setCompilers/conf1.o
Executing: /usr/bin/ranlib -c /tmp/petsc-lhuj9c/config.setCompilers/libconf1.a
Possible ERROR while running ranlib:
stderr:
/usr/bin/ranlib: invalid option -- 'c'
        Ranlib is not functional with your archiver.  Try --with-ranlib=true if ranlib is unnecessary.
Executing: ar -V
stdout:
Executing: ar -V
stdout:
Successful compile:
Source:
int foo(int a) {
  return a+1;
            Defined make macro "RANLIB" to "/usr/bin/ranlib"
Executing: /usr/bin/ranlib /tmp/petsc-lhuj9c/config.setCompilers/libconf1.a
Successful compile:
Source:
extern int foo(int);
int main() {
  int b = foo(1);  if (b);
  return 0;
                  Pushing language C
                  Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    -fPIC /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -L/tmp/petsc-lhuj9c/config.setCompilers -lconf1
          Defined make macro "AR_FLAGS" to "cr"
          Defined make macro "AR_LIB_SUFFIX" to "a"
          Popping language C
TEST checkSharedLinker from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:1241)
TESTING: checkSharedLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1241)
  Check that the linker can produce shared libraries
Executing: uname -s
stdout: Linux
        Checking shared linker /opt/mpich/bin/mpicc using flags ['-shared']
            Defined make macro "LD_SHARED" to "/opt/mpich/bin/mpicc"
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest  -shared   -fPIC /tmp/petsc-lhuj9c/config.setCompilers/conftest.o
          Valid C linker flag -shared
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("hello");
return 0;}
                                          Pushing language C
                                          Popping language C
                                          Pushing language CUDA
                                          Popping language CUDA
                                          Pushing language Cxx
                                          Popping language Cxx
                                          Pushing language FC
                                          Popping language FC
                  Pushing language C
                  Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.setCompilers/libconftest.so  -shared  -fPIC /tmp/petsc-lhuj9c/config.setCompilers/conftest.o
Successful compile:
Source:
int foo(void);
int main() {
int ret = foo();
if(ret);;
  return 0;
                  Pushing language C
                  Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    -fPIC /tmp/petsc-lhuj9c/config.setCompilers/conftest.o  -L/tmp/petsc-lhuj9c/config.setCompilers -lconftest
        Using shared linker /opt/mpich/bin/mpicc with flags ['-shared'] and library extension so
Executing: uname -s
stdout: Linux
TEST checkSharedLinkerPaths from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:1319)
TESTING: checkSharedLinkerPaths from config.setCompilers(config/BuildSystem/config/setCompilers.py:1319)
  Determine the shared linker path options
       - IRIX: -rpath
       - Linux, OSF: -Wl,-rpath,
       - Solaris: -R
       - FreeBSD: -Wl,-R,
          Pushing language C
Executing: uname -s
stdout: Linux
Executing: /opt/mpich/bin/mpicc -V
        Trying C linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest  -Wl,-rpath,/home/jed/petsc   -fPIC /tmp/petsc-lhuj9c/config.setCompilers/conftest.o
          Valid C linker flag -Wl,-rpath,/home/jed/petsc
          Popping language C
Executing: uname -s
stdout: Linux
        Trying Cxx linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
  return 0;
Executing: /opt/mpich/bin/mpicxx  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest  -Wl,-rpath,/home/jed/petsc   /tmp/petsc-lhuj9c/config.setCompilers/conftest.o
          Valid Cxx linker flag -Wl,-rpath,/home/jed/petsc
          Pushing language FC
Executing: uname -s
stdout: Linux
        Trying FC linker flag -Wl,-rpath,
Successful compile:
Source:
      program main
      end
                  Pushing language FC
                  Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest  -Wl,-rpath,/home/jed/petsc   -fPIC /tmp/petsc-lhuj9c/config.setCompilers/conftest.o
          Valid FC linker flag -Wl,-rpath,/home/jed/petsc
          Popping language FC
TEST checkLibC from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:1354)
TESTING: checkLibC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1354)
  Test whether we need to explicitly include libc in shared linking
       - Mac OSX requires an explicit reference to libc for shared linking
Successful compile:
Source:
#include <stdlib.h>
int foo(void) {void *chunk = malloc(31); free(chunk); return 0;}
                  Pushing language C
                  Popping language C
        Shared linking does not require an explicit libc reference
TEST checkDynamicLinker from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:1403)
TESTING: checkDynamicLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1403)
  Check that the linker can dynamicaly load shared libraries
Checking for header: dlfcn.h
                      All intermediate test results are stored in /tmp/petsc-lhuj9c/config.headers
Executing: /opt/mpich/bin/mpicc -E  -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.headers  /tmp/petsc-lhuj9c/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-lhuj9c/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "/tmp/petsc-lhuj9c/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/conffix.h" 1
# 3 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
# 1 "/usr/include/dlfcn.h" 1 3 4
# 22 "/usr/include/dlfcn.h" 3 4
# 23 "/usr/include/dlfcn.h" 2 3 4
# 25 "/usr/include/dlfcn.h" 2 3 4
# 1 "/usr/include/bits/dlfcn.h" 1 3 4
# 28 "/usr/include/dlfcn.h" 2 3 4
# 52 "/usr/include/dlfcn.h" 3 4
extern void *dlopen (const char *__file, int __mode) __attribute__ ((__nothrow__));
extern int dlclose (void *__handle) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
extern void *dlsym (void *__restrict __handle,
      const char *__restrict __name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 82 "/usr/include/dlfcn.h" 3 4
extern char *dlerror (void) __attribute__ ((__nothrow__ , __leaf__));
# 188 "/usr/include/dlfcn.h" 3 4
            Defined "HAVE_DLFCN_H" to "1"
            Checking for functions [dlopen dlsym dlclose] in library ['dl'] []
              Pushing language C
                          All intermediate test results are stored in /tmp/petsc-lhuj9c/config.libraries
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.libraries/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC  /tmp/petsc-lhuj9c/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char dlopen();
static void _check_dlopen() { dlopen(); }
char dlsym();
static void _check_dlsym() { dlsym(); }
char dlclose();
static void _check_dlclose() { dlclose(); }
int main() {
_check_dlopen();
_check_dlsym();
_check_dlclose();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC /tmp/petsc-lhuj9c/config.libraries/conftest.o  -ldl
              Defined "HAVE_LIBDL" to "1"
              Popping language C
          Adding ['dl'] to LIBS
Executing: uname -s
stdout: Linux
        Checking dynamic linker /opt/mpich/bin/mpicc using flags ['-shared']
            Defined make macro "DYNAMICLINKER" to "/opt/mpich/bin/mpicc"
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC  /tmp/petsc-lhuj9c/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest  -shared   -fPIC /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -ldl
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("test");return 0;}
                                          Pushing language C
                                          Popping language C
                                          Pushing language FC
                                          Popping language FC
                  Pushing language C
                  Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.setCompilers/libconftest.so  -shared  -fPIC /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -ldl
Possible ERROR while running compiler:
stderr:
/tmp/petsc-lhuj9c/config.setCompilers/conftest.c: In function ?main?:
/tmp/petsc-lhuj9c/config.setCompilers/conftest.c:11:3: warning: incompatible implicit declaration of built-in function ?printf?
   printf("Could not load symbol\n");
/tmp/petsc-lhuj9c/config.setCompilers/conftest.c:15:3: warning: incompatible implicit declaration of built-in function ?printf?
   printf("Invalid return from foo()\n");
/tmp/petsc-lhuj9c/config.setCompilers/conftest.c:19:3: warning: incompatible implicit declaration of built-in function ?printf?
   printf("Could not close library\n");
Source:
#include<dlfcn.h>
int main() {
void *handle = dlopen("/tmp/petsc-lhuj9c/config.setCompilers/libconftest.so", 0);
int (*foo)(void) = (int (*)(void)) dlsym(handle, "foo");
if (!foo) {
  return -1;
if ((*foo)()) {
  return -1;
if (dlclose(handle)) {
  return -1;
  return 0;
                  Pushing language C
                  Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    -fPIC /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -ldl
        Using dynamic linker /opt/mpich/bin/mpicc with flags ['-shared'] and library extension so
TEST output from config.setCompilers(/home/jed/petsc/config/BuildSystem/config/setCompilers.py:1449)
TESTING: output from config.setCompilers(config/BuildSystem/config/setCompilers.py:1449)
  Output module data as defines and substitutions
          Substituting "CC" with "/opt/mpich/bin/mpicc"
          Substituting "CFLAGS" with " -fPIC"
          Defined make macro "CC_LINKER_SLFLAG" to "-Wl,-rpath,"
          Substituting "CPP" with "/opt/mpich/bin/mpicc -E"
          Substituting "CPPFLAGS" with ""
          Substituting "CXX" with "/opt/mpich/bin/mpicxx"
          Substituting "CXX_CXXFLAGS" with " -fPIC"
          Substituting "CXXFLAGS" with ""
          Substituting "CXX_LINKER_SLFLAG" with "-Wl,-rpath,"
          Substituting "CXXCPP" with "/opt/mpich/bin/mpicxx -E"
          Substituting "CXXCPPFLAGS" with ""
          Substituting "FC" with "/opt/mpich/bin/mpif90"
          Substituting "FFLAGS" with " -fPIC"
          Defined make macro "FC_LINKER_SLFLAG" to "-Wl,-rpath,"
          Substituting "LDFLAGS" with ""
          Substituting "LIBS" with "-ldl "
          Substituting "SHARED_LIBRARY_FLAG" with "-shared"
Executing: uname -s
stdout: Linux
TEST checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(/home/jed/petsc/config/PETSc/options/sharedLibraries.py:37)
TESTING: checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:37)
TEST configureSharedLibraries from PETSc.options.sharedLibraries(/home/jed/petsc/config/PETSc/options/sharedLibraries.py:53)
TESTING: configureSharedLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:53)
  Checks whether shared libraries should be used, for which you must
      - Specify --with-shared-libraries
      - Have found a working shared linker
    Defines PETSC_USE_SHARED_LIBRARIES if they are used
          Defined make rule "shared_arch" with dependencies "shared_linux" and code []
          Defined make macro "SONAME_FUNCTION" to "$(1).so.$(2)"
          Defined make macro "SL_LINKER_FUNCTION" to "-shared -Wl,-soname,$(call SONAME_FUNCTION,$(notdir $(1)),$(2))"
          Defined make macro "BUILDSHAREDLIB" to "yes"
          Defined "HAVE_SHARED_LIBRARIES" to "1"
          Defined "USE_SHARED_LIBRARIES" to "1"
TEST configureDynamicLibraries from PETSc.options.sharedLibraries(/home/jed/petsc/config/PETSc/options/sharedLibraries.py:96)
TESTING: configureDynamicLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:96)
  Checks whether dynamic loading is available (with dlfcn.h and libdl)
          Defined "HAVE_DYNAMIC_LIBRARIES" to "1"
TEST configureSerializedFunctions from PETSc.options.sharedLibraries(/home/jed/petsc/config/PETSc/options/sharedLibraries.py:102)
TESTING: configureSerializedFunctions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:102)
    Defines PETSC_SERIALIZE_FUNCTIONS if they are used
    Requires shared libraries
TEST configureCompilerFlags from config.compilerFlags(/home/jed/petsc/config/BuildSystem/config/compilerFlags.py:71)
TESTING: configureCompilerFlags from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:71)
  Get the default compiler flags
          Pushing language C
Executing: /opt/mpich/bin/mpicc --version
stdout:
gcc (GCC) 4.9.1 20140903 (prerelease)
Copyright (C) 2014 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
getCompilerVersion: /opt/mpich/bin/mpicc gcc (GCC) 4.9.1 20140903 (prerelease)
Executing: /opt/mpich/bin/mpicc -show
stdout: gcc -I/opt/mpich/include -L/opt/mpich/lib -Wl,-rpath -Wl,/opt/mpich/lib -Wl,--enable-new-dtags -lmpi
              Defined make macro "MPICC_SHOW" to "gcc -I/opt/mpich/include -L/opt/mpich/lib -Wl,-rpath -Wl,/opt/mpich/lib -Wl,--enable-new-dtags -lmpi"
Executing: gcc --help
stdout:
Options:
                           and libraries
        Trying C compiler flag -Wall
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall   /tmp/petsc-lhuj9c/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wall
        Trying C compiler flag -Wwrite-strings
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wwrite-strings   /tmp/petsc-lhuj9c/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wwrite-strings
        Trying C compiler flag -Wno-strict-aliasing
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing   /tmp/petsc-lhuj9c/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wno-strict-aliasing
        Trying C compiler flag -Wno-unknown-pragmas
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas   /tmp/petsc-lhuj9c/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wno-unknown-pragmas
        Trying C compiler flag -g3
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3   /tmp/petsc-lhuj9c/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -g3
        Trying C compiler flag -O0
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0   /tmp/petsc-lhuj9c/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -O0
          Popping language C
Executing: /opt/mpich/bin/mpicxx --version
stdout:
g++ (GCC) 4.9.1 20140903 (prerelease)
getCompilerVersion: /opt/mpich/bin/mpicxx g++ (GCC) 4.9.1 20140903 (prerelease)
Executing: /opt/mpich/bin/mpicxx -show
stdout: g++ -I/opt/mpich/include -L/opt/mpich/lib -lmpicxx -Wl,-rpath -Wl,/opt/mpich/lib -Wl,--enable-new-dtags -lmpi
              Defined make macro "MPICXX_SHOW" to "g++ -I/opt/mpich/include -L/opt/mpich/lib -lmpicxx -Wl,-rpath -Wl,/opt/mpich/lib -Wl,--enable-new-dtags -lmpi"
Executing: g++ --help
stdout:
Options:
                           and libraries
        Trying Cxx compiler flag -Wall
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -Wall   -fPIC   /tmp/petsc-lhuj9c/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wall
        Trying Cxx compiler flag -Wwrite-strings
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -Wall -Wwrite-strings   -fPIC   /tmp/petsc-lhuj9c/config.setCompilers/conftest.cc
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Added Cxx compiler flag -Wwrite-strings
        Trying Cxx compiler flag -Wno-strict-aliasing
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing   -fPIC   /tmp/petsc-lhuj9c/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wno-strict-aliasing
        Trying Cxx compiler flag -Wno-unknown-pragmas
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas   -fPIC   /tmp/petsc-lhuj9c/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wno-unknown-pragmas
        Trying Cxx compiler flag -g
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g   -fPIC   /tmp/petsc-lhuj9c/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -g
        Trying Cxx compiler flag -O0
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0   -fPIC   /tmp/petsc-lhuj9c/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -O0
          Pushing language FC
Executing: /opt/mpich/bin/mpif90 --version
stdout:
GNU Fortran (GCC) 4.9.1 20140903 (prerelease)
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
getCompilerVersion: /opt/mpich/bin/mpif90 GNU Fortran (GCC) 4.9.1 20140903 (prerelease)
Executing: /opt/mpich/bin/mpif90 -show
stdout: gfortran -I/opt/mpich/include -I/opt/mpich/include -L/opt/mpich/lib -lmpifort -Wl,-rpath -Wl,/opt/mpich/lib -Wl,--enable-new-dtags -lmpi
              Defined make macro "MPIFC_SHOW" to "gfortran -I/opt/mpich/include -I/opt/mpich/include -L/opt/mpich/lib -lmpifort -Wl,-rpath -Wl,/opt/mpich/lib -Wl,--enable-new-dtags -lmpi"
Executing: gfortran --help
stdout:
Options:
                           and libraries
Executing: gfortran --version
stdout:
stdout:
        Trying FC compiler flag -Wall
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall   /tmp/petsc-lhuj9c/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wall
        Trying FC compiler flag -Wno-unused-variable
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wno-unused-variable   /tmp/petsc-lhuj9c/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wno-unused-variable
        Trying FC compiler flag -ffree-line-length-0
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0   /tmp/petsc-lhuj9c/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -ffree-line-length-0
        Trying FC compiler flag -Wno-unused-dummy-argument
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument   /tmp/petsc-lhuj9c/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wno-unused-dummy-argument
        Trying FC compiler flag -g
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g   /tmp/petsc-lhuj9c/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -g
        Trying FC compiler flag -O0
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /tmp/petsc-lhuj9c/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -O0
          Popping language FC
TEST configureDebugging from PETSc.options.debugging(/home/jed/petsc/config/PETSc/options/debugging.py:25)
TESTING: configureDebugging from PETSc.options.debugging(config/PETSc/options/debugging.py:25)
          Defined "USE_ERRORCHECKING" to "1"
TEST checkRestrict from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:136)
TESTING: checkRestrict from config.compilers(config/BuildSystem/config/compilers.py:136)
  Check for the C/CXX restrict keyword
          Pushing language C
                    All intermediate test results are stored in /tmp/petsc-lhuj9c/config.compilers
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.compilers/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.compilers/conftest.c
Possible ERROR while running compiler: exit code 256
stderr:
/tmp/petsc-lhuj9c/config.compilers/conftest.c: In function ?main?:
/tmp/petsc-lhuj9c/config.compilers/conftest.c:5:18: error: expected ?=?, ?,?, ?;?, ?asm? or ?__attribute__? before ?x?
 float * restrict x;;
/tmp/petsc-lhuj9c/config.compilers/conftest.c:5:18: error: ?x? undeclared (first use in this function)
/tmp/petsc-lhuj9c/config.compilers/conftest.c:5:18: note: each undeclared identifier is reported only once for each function it appears in
Source:
int main() {
  return 0;
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.compilers/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.compilers/conftest.c
stderr:
/tmp/petsc-lhuj9c/config.compilers/conftest.c:5:23: warning: unused variable ?x? [-Wunused-variable]
 float *  __restrict__ x;;
Source:
int main() {
  return 0;
        compilers: Set C restrict keyword to  __restrict__
          Defined "C_RESTRICT" to " __restrict__"
          Popping language C
TEST checkCFormatting from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:309)
TESTING: checkCFormatting from config.compilers(config/BuildSystem/config/compilers.py:309)
  Activate format string checking if using the GNU compilers
TEST checkCStaticInline from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:107)
TESTING: checkCStaticInline from config.compilers(config/BuildSystem/config/compilers.py:107)
  Check for C keyword: static inline
          Pushing language C
Successful compile:
Source:
static inline int foo(int a) {return a;}
int main() {
foo(1);;
  return 0;
        compilers: Set C StaticInline keyword to static inline
          Popping language C
          Defined "C_STATIC_INLINE" to "static inline"
TEST checkDynamicLoadFlag from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:320)
TESTING: checkDynamicLoadFlag from config.compilers(config/BuildSystem/config/compilers.py:320)
  Checks that dlopen() takes RTLD_XXX, and defines PETSC_HAVE_RTLD_XXX if it does
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LAZY);
  return 0;
                  Pushing language C
                  Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.compilers/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.compilers/conftest.o -ldl
          Defined "HAVE_RTLD_LAZY" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_NOW);
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_RTLD_NOW" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LOCAL);
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_RTLD_LOCAL" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_GLOBAL);
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_RTLD_GLOBAL" to "1"
TEST checkCLibraries from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:163)
TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compilers.py:163)
  Determines the libraries needed to link with C
          Pushing language C
Successful compile:
Source:
int main() {
  return 0;
                Pushing language C
                Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.compilers/conftest  -v   -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.compilers/conftest.o -ldl
stdout: mpicc for MPICH version 3.1.3
Possible ERROR while running linker:
stdout:
mpicc for MPICH version 3.1.3stderr:
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/lto-wrapper
Target: x86_64-unknown-linux-gnu
Configured with: /build/gcc-multilib/src/gcc-4.9-20140903/configure --prefix=/usr --libdir=/usr/lib --libexecdir=/usr/lib --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=https://bugs.archlinux.org/ --enable-languages=c,c++,ada,fortran,go,lto,objc,obj-c++ --enable-shared --enable-threads=posix --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-clocale=gnu --disable-libstdcxx-pch --disable-libssp --enable-gnu-unique-object --enable-linker-build-id --enable-cloog-backend=isl --disable-isl-version-check --disable-cloog-version-check --enable-lto --enable-plugin --enable-install-libiberty --with-linker-hash-style=gnu --enable-multilib --disable-werror --enable-checking=release
Thread model: posix
gcc version 4.9.1 20140903 (prerelease) (GCC)
COMPILER_PATH=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/
LIBRARY_PATH=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/:/lib/../lib/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../:/lib/:/usr/lib/
COLLECT_GCC_OPTIONS='-o' '/tmp/petsc-lhuj9c/config.compilers/conftest' '-v' '-fPIC' '-Wall' '-Wwrite-strings' '-Wno-strict-aliasing' '-Wno-unknown-pragmas' '-g3' '-O0' '-I' '/opt/mpich/include' '-L/opt/mpich/lib' '-mtune=generic' '-march=x86-64'
 /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/collect2 -plugin /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/liblto_plugin.so -plugin-opt=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/lto-wrapper -plugin-opt=-fresolution=/tmp/ccYyEgJ9.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s --build-id --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o /tmp/petsc-lhuj9c/config.compilers/conftest /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/crt1.o /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/crti.o /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/crtbegin.o -L/opt/mpich/lib -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../.. /tmp/petsc-lhuj9c/config.compilers/conftest.o -ldl -rpath /opt/mpich/lib --enable-new-dtags -lmpi -lgcc --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s --no-as-needed /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/crtend.o /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/crtn.o
          Popping language C
        compilers: Checking arg mpicc
        compilers: Unknown arg mpicc
        compilers: Checking arg for
        compilers: Unknown arg for
        compilers: Checking arg MPICH
        compilers: Unknown arg MPICH
        compilers: Checking arg version
        compilers: Unknown arg version
        compilers: Checking arg 3.1.3
        compilers: Unknown arg 3.1.3
        compilers: Checking arg Using
        compilers: Unknown arg Using
        compilers: Checking arg built-in
        compilers: Unknown arg built-in
        compilers: Checking arg specs.
        compilers: Unknown arg specs.
        compilers: Checking arg COLLECT_GCC=gcc
        compilers: Unknown arg COLLECT_GCC=gcc
        compilers: Checking arg COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/lto-wrapper
        compilers: Unknown arg COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/lto-wrapper
        compilers: Checking arg Target:
        compilers: Unknown arg Target:
        compilers: Checking arg x86_64-unknown-linux-gnu
        compilers: Unknown arg x86_64-unknown-linux-gnu
        compilers: Checking arg Configured
        compilers: Unknown arg Configured
        compilers: Checking arg with:
        compilers: Unknown arg with:
        compilers: Checking arg /build/gcc-multilib/src/gcc-4.9-20140903/configure
        compilers: Unknown arg /build/gcc-multilib/src/gcc-4.9-20140903/configure
        compilers: Checking arg --prefix=/usr
        compilers: Unknown arg --prefix=/usr
        compilers: Checking arg --libdir=/usr/lib
        compilers: Unknown arg --libdir=/usr/lib
        compilers: Checking arg --libexecdir=/usr/lib
        compilers: Unknown arg --libexecdir=/usr/lib
        compilers: Checking arg --mandir=/usr/share/man
        compilers: Unknown arg --mandir=/usr/share/man
        compilers: Checking arg --infodir=/usr/share/info
        compilers: Unknown arg --infodir=/usr/share/info
        compilers: Checking arg --with-bugurl=https://bugs.archlinux.org/
        compilers: Unknown arg --with-bugurl=https://bugs.archlinux.org/
        compilers: Checking arg --enable-languages=c,c++,ada,fortran,go,lto,objc,obj-c++
        compilers: Unknown arg --enable-languages=c,c++,ada,fortran,go,lto,objc,obj-c++
        compilers: Checking arg --enable-shared
        compilers: Unknown arg --enable-shared
        compilers: Checking arg --enable-threads=posix
        compilers: Unknown arg --enable-threads=posix
        compilers: Checking arg --with-system-zlib
        compilers: Unknown arg --with-system-zlib
        compilers: Checking arg --enable-__cxa_atexit
        compilers: Unknown arg --enable-__cxa_atexit
        compilers: Checking arg --disable-libunwind-exceptions
        compilers: Unknown arg --disable-libunwind-exceptions
        compilers: Checking arg --enable-clocale=gnu
        compilers: Unknown arg --enable-clocale=gnu
        compilers: Checking arg --disable-libstdcxx-pch
        compilers: Unknown arg --disable-libstdcxx-pch
        compilers: Checking arg --disable-libssp
        compilers: Unknown arg --disable-libssp
        compilers: Checking arg --enable-gnu-unique-object
        compilers: Unknown arg --enable-gnu-unique-object
        compilers: Checking arg --enable-linker-build-id
        compilers: Unknown arg --enable-linker-build-id
        compilers: Checking arg --enable-cloog-backend=isl
        compilers: Unknown arg --enable-cloog-backend=isl
        compilers: Checking arg --disable-isl-version-check
        compilers: Unknown arg --disable-isl-version-check
        compilers: Checking arg --disable-cloog-version-check
        compilers: Unknown arg --disable-cloog-version-check
        compilers: Checking arg --enable-lto
        compilers: Unknown arg --enable-lto
        compilers: Checking arg --enable-plugin
        compilers: Unknown arg --enable-plugin
        compilers: Checking arg --enable-install-libiberty
        compilers: Unknown arg --enable-install-libiberty
        compilers: Checking arg --with-linker-hash-style=gnu
        compilers: Unknown arg --with-linker-hash-style=gnu
        compilers: Checking arg --enable-multilib
        compilers: Unknown arg --enable-multilib
        compilers: Checking arg --disable-werror
        compilers: Unknown arg --disable-werror
        compilers: Checking arg --enable-checking=release
        compilers: Unknown arg --enable-checking=release
        compilers: Checking arg Thread
        compilers: Unknown arg Thread
        compilers: Checking arg model:
        compilers: Unknown arg model:
        compilers: Checking arg posix
        compilers: Unknown arg posix
        compilers: Checking arg gcc
        compilers: Unknown arg gcc
        compilers: Checking arg 4.9.1
        compilers: Unknown arg 4.9.1
        compilers: Checking arg 20140903
        compilers: Unknown arg 20140903
        compilers: Checking arg (prerelease)
        compilers: Unknown arg (prerelease)
        compilers: Checking arg (GCC)
        compilers: Unknown arg (GCC)
        compilers: Checking arg COMPILER_PATH=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/
        compilers: Unknown arg COMPILER_PATH=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/
        compilers: Checking arg LIBRARY_PATH=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/:/lib/../lib/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../:/lib/:/usr/lib/
        compilers: Unknown arg LIBRARY_PATH=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/:/lib/../lib/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../:/lib/:/usr/lib/
        compilers: Checking arg COLLECT_GCC_OPTIONS=
        compilers: Unknown arg COLLECT_GCC_OPTIONS=
        compilers: Checking arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/collect2
        compilers: Unknown arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/collect2
        compilers: Checking arg -plugin
        compilers: Unknown arg -plugin
        compilers: Checking arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/liblto_plugin.so
        compilers: Unknown arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/liblto_plugin.so
        compilers: Checking arg -plugin-opt=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/lto-wrapper
        compilers: Unknown arg -plugin-opt=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/lto-wrapper
        compilers: Checking arg -plugin-opt=-fresolution=/tmp/ccYyEgJ9.res
        compilers: Unknown arg -plugin-opt=-fresolution=/tmp/ccYyEgJ9.res
        compilers: Checking arg -plugin-opt=-pass-through=-lgcc
        compilers: Unknown arg -plugin-opt=-pass-through=-lgcc
        compilers: Checking arg -plugin-opt=-pass-through=-lgcc_s
        compilers: Unknown arg -plugin-opt=-pass-through=-lgcc_s
        compilers: Checking arg -plugin-opt=-pass-through=-lc
        compilers: Unknown arg -plugin-opt=-pass-through=-lc
        compilers: Checking arg --build-id
        compilers: Unknown arg --build-id
        compilers: Checking arg --eh-frame-hdr
        compilers: Unknown arg --eh-frame-hdr
        compilers: Checking arg --hash-style=gnu
        compilers: Unknown arg --hash-style=gnu
        compilers: Checking arg -m
        compilers: Unknown arg -m
        compilers: Checking arg elf_x86_64
        compilers: Unknown arg elf_x86_64
        compilers: Checking arg -dynamic-linker
        compilers: Unknown arg -dynamic-linker
        compilers: Checking arg /lib64/ld-linux-x86-64.so.2
        compilers: Unknown arg /lib64/ld-linux-x86-64.so.2
        compilers: Checking arg -o
        compilers: Unknown arg -o
        compilers: Checking arg /tmp/petsc-lhuj9c/config.compilers/conftest
        compilers: Unknown arg /tmp/petsc-lhuj9c/config.compilers/conftest
        compilers: Checking arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/crt1.o
        compilers: Unknown arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/crt1.o
        compilers: Checking arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/crti.o
        compilers: Unknown arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/crti.o
        compilers: Checking arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/crtbegin.o
        compilers: Unknown arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/crtbegin.o
        compilers: Checking arg -L/opt/mpich/lib
        compilers: Found library directory: -L/opt/mpich/lib
        compilers: Checking arg -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1
        compilers: Found library directory: -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1
        compilers: Checking arg -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib
        compilers: Checking arg -L/lib/../lib
        compilers: Checking arg -L/usr/lib/../lib
        compilers: Checking arg /tmp/petsc-lhuj9c/config.compilers/conftest.o
        compilers: Unknown arg /tmp/petsc-lhuj9c/config.compilers/conftest.o
        compilers: Checking arg -ldl
        compilers: Found library : -ldl
        compilers: Checking arg -rpath
        compilers: Found -rpath library: /opt/mpich/lib
        compilers: Checking arg --enable-new-dtags
        compilers: Unknown arg --enable-new-dtags
        compilers: Checking arg -lmpi
        compilers: Found library : -lmpi
        compilers: Checking arg -lgcc
        compilers: Skipping system library: -lgcc
        compilers: Checking arg --as-needed
        compilers: Unknown arg --as-needed
        compilers: Checking arg -lgcc_s
        compilers: Found library : -lgcc_s
        compilers: Checking arg --no-as-needed
        compilers: Unknown arg --no-as-needed
        compilers: Checking arg -lc
        compilers: Skipping system library: -lc
        compilers: Checking arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/crtend.o
        compilers: Unknown arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/crtend.o
        compilers: Checking arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/crtn.o
        compilers: Unknown arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/crtn.o
        compilers: Libraries needed to link C code with another linker: ['-Wl,-rpath,/opt/mpich/lib', '-L/opt/mpich/lib', '-Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1', '-L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1', '-ldl', '-Wl,-rpath,/opt/mpich/lib', '-lmpi', '-lgcc_s']
        compilers: Check that C libraries can be used from Fortran
            Pushing language FC
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
                    Pushing language FC
                    Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
Successful compile:
Source:
      program main
      end
                    Pushing language FC
                    Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
collect2: error: ld returned 1 exit status
Successful compile:
Source:
      program main
      end
                        Pushing language FC
                        Popping language FC
Testing executable /tmp/petsc-lhuj9c/config.setCompilers/conftest to see if it can be run
Executing: /tmp/petsc-lhuj9c/config.setCompilers/conftest
            Popping language FC
TEST checkDependencyGenerationFlag from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:1327)
TESTING: checkDependencyGenerationFlag from config.compilers(config/BuildSystem/config/compilers.py:1327)
  Check if -MMD works for dependency generation, and add it if it does
          Pushing language C
        Trying C compiler flag -MMD -MP
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 -MMD -MP  /tmp/petsc-lhuj9c/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
          Defined make macro "C_DEPFLAGS" to "-MMD -MP"
          Popping language C
        Trying Cxx compiler flag -MMD -MP
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  -fPIC -MMD -MP   /tmp/petsc-lhuj9c/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
          Defined make macro "CXX_DEPFLAGS" to "-MMD -MP"
          Pushing language FC
        Trying FC compiler flag -MMD -MP
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 -MMD -MP  /tmp/petsc-lhuj9c/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
          Defined make macro "FC_DEPFLAGS" to "-MMD -MP"
          Popping language FC
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.compilers/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  -fPIC   /tmp/petsc-lhuj9c/config.compilers/conftest.cc
stderr:
/tmp/petsc-lhuj9c/config.compilers/conftest.cc: In function ?int main()?:
/tmp/petsc-lhuj9c/config.compilers/conftest.cc:5:18: error: expected initializer before ?x?
Source:
int main() {
  return 0;
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.compilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  -fPIC   /tmp/petsc-lhuj9c/config.compilers/conftest.cc
stderr:
/tmp/petsc-lhuj9c/config.compilers/conftest.cc:5:23: warning: unused variable ?x? [-Wunused-variable]
Source:
int main() {
  return 0;
        compilers: Set Cxx restrict keyword to  __restrict__
          Defined "CXX_RESTRICT" to " __restrict__"
TEST checkCxxNamespace from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:358)
TESTING: checkCxxNamespace from config.compilers(config/BuildSystem/config/compilers.py:358)
  Checks that C++ compiler supports namespaces, and if it does defines HAVE_CXX_NAMESPACE
Successful compile:
Source:
namespace petsc {int dummy;}
int main() {
  return 0;
Successful compile:
Source:
template <class dummy> struct a {};
namespace trouble{
template <class dummy> struct a : public ::a<dummy> {};
trouble::a<int> uugh;
int main() {
  return 0;
        compilers: C++ has namespaces
          Defined "HAVE_CXX_NAMESPACE" to "1"
TEST checkCxxOptionalExtensions from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:333)
TESTING: checkCxxOptionalExtensions from config.compilers(config/BuildSystem/config/compilers.py:333)
  Check whether the C++ compiler (IBM xlC, OSF5) need special flag for .c files which contain C++
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0    -fPIC   /tmp/petsc-lhuj9c/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
class somename { int i; };;
  return 0;
TEST checkCxxStaticInline from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:121)
TESTING: checkCxxStaticInline from config.compilers(config/BuildSystem/config/compilers.py:121)
  Check for C++ keyword: static inline
Successful compile:
Source:
int main() {
foo(1);;
  return 0;
        compilers: Set Cxx StaticInline keyword to static inline
          Defined "CXX_STATIC_INLINE" to "static inline"
TEST checkCxxLibraries from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:412)
TESTING: checkCxxLibraries from config.compilers(config/BuildSystem/config/compilers.py:412)
  Determines the libraries needed to link with C++
Successful compile:
Source:
int main() {
  return 0;
                Pushing language CXX
                Popping language CXX
Executing: /opt/mpich/bin/mpicxx  -o /tmp/petsc-lhuj9c/config.compilers/conftest  -v   -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  /tmp/petsc-lhuj9c/config.compilers/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
stdout: mpicxx for MPICH version 3.1.3
stdout:
mpicxx for MPICH version 3.1.3stderr:
COLLECT_GCC=g++
Thread model: posix
COLLECT_GCC_OPTIONS='-o' '/tmp/petsc-lhuj9c/config.compilers/conftest' '-v' '-Wall' '-Wwrite-strings' '-Wno-strict-aliasing' '-Wno-unknown-pragmas' '-g' '-O0' '-L/opt/mpich/lib' '-L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1' '-I' '/opt/mpich/include' '-L/opt/mpich/lib' '-shared-libgcc' '-mtune=generic' '-march=x86-64'
 /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/collect2 -plugin /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/liblto_plugin.so -plugin-opt=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/lto-wrapper -plugin-opt=-fresolution=/tmp/ccO39Bjc.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --build-id --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o /tmp/petsc-lhuj9c/config.compilers/conftest /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/crt1.o /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/crti.o /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/crtbegin.o -L/opt/mpich/lib -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/opt/mpich/lib -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../.. /tmp/petsc-lhuj9c/config.compilers/conftest.o -rpath /opt/mpich/lib -rpath /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -rpath /opt/mpich/lib -lmpi -lgcc_s -ldl -lmpicxx -rpath /opt/mpich/lib --enable-new-dtags -lmpi -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/crtend.o /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/crtn.o
        compilers: Checking arg mpicxx
        compilers: Unknown arg mpicxx
        compilers: Checking arg COLLECT_GCC=g++
        compilers: Unknown arg COLLECT_GCC=g++
        compilers: Checking arg -plugin-opt=-fresolution=/tmp/ccO39Bjc.res
        compilers: Unknown arg -plugin-opt=-fresolution=/tmp/ccO39Bjc.res
        compilers: Found -rpath library: /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1
        compilers: Found library: -ldl
        Library already in C list so skipping in C++
        compilers: Already in rpathflags, skipping:-rpath
        compilers: Found library: -lmpi
        compilers: Found library: -lgcc_s
        compilers: Checking arg -lmpicxx
        compilers: Found library: -lmpicxx
        compilers: Checking arg -lstdc++
        compilers: Found library: -lstdc++
        compilers: Libraries needed to link Cxx code with another linker: ['-Wl,-rpath,/opt/mpich/lib', '-L/opt/mpich/lib', '-Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1', '-L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1', '-Wl,-rpath,/opt/mpich/lib', '-Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1', '-lmpicxx', '-lstdc++']
        compilers: Check that Cxx libraries can be used from C
            Pushing language C
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -Wl,-rpath,/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lmpicxx -lstdc++ -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -Wl,-rpath,/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lmpicxx -lstdc++ -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
        compilers: Check that Cxx libraries can be used from Fortran
            Pushing language FC
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
                    Pushing language FC
                    Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -Wl,-rpath,/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lmpicxx -lstdc++ -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
Successful compile:
Source:
      program main
      end
                    Pushing language FC
                    Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -Wl,-rpath,/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lmpicxx -lstdc++ -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
      program main
      end
                        Pushing language FC
                        Popping language FC
            Popping language FC
TEST checkCxx11 from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:373)
TESTING: checkCxx11 from config.compilers(config/BuildSystem/config/compilers.py:373)
  Determine the option needed to support the C++11 dialect
    We auto-detect C++11 if the compiler supports it without options,
    otherwise we require with-cxx-dialect=C++11 to try adding flags to
    support it.
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0    -fPIC   /tmp/petsc-lhuj9c/config.setCompilers/conftest.cc
stderr:
In file included from /usr/include/c++/4.9.1/random:35:0,
                 from /tmp/petsc-lhuj9c/config.setCompilers/conftest.cc:4:
/usr/include/c++/4.9.1/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
 #error This file requires compiler and library support for the \
/tmp/petsc-lhuj9c/config.setCompilers/conftest.cc:5:11: warning: identifier ?constexpr? is a keyword in C++11 [-Wc++0x-compat]
           template<typename T> constexpr T Cubed( T x ) { return x*x*x; }
/tmp/petsc-lhuj9c/config.setCompilers/conftest.cc:5:32: error: ?constexpr? does not name a type
/tmp/petsc-lhuj9c/config.setCompilers/conftest.cc:5:32: note: C++11 ?constexpr? only available with -std=c++11 or -std=gnu++11
/tmp/petsc-lhuj9c/config.setCompilers/conftest.cc: In function ?int main()?:
/tmp/petsc-lhuj9c/config.setCompilers/conftest.cc:10:11: error: ?random_device? is not a member of ?std?
           std::random_device rd;
/tmp/petsc-lhuj9c/config.setCompilers/conftest.cc:11:11: error: ?mt19937? is not a member of ?std?
           std::mt19937 mt(rd());
/tmp/petsc-lhuj9c/config.setCompilers/conftest.cc:12:11: error: ?normal_distribution? is not a member of ?std?
           std::normal_distribution<double> dist(0,1);
/tmp/petsc-lhuj9c/config.setCompilers/conftest.cc:12:36: error: expected primary-expression before ?double?
/tmp/petsc-lhuj9c/config.setCompilers/conftest.cc:13:33: error: ?mt? was not declared in this scope
           const double x = dist(mt);
/tmp/petsc-lhuj9c/config.setCompilers/conftest.cc:13:35: error: ?dist? was not declared in this scope
/tmp/petsc-lhuj9c/config.setCompilers/conftest.cc:13:24: warning: unused variable ?x? [-Wunused-variable]
Source:
          #include <random>
int main() {
  return 0;
          Rejecting compiler flag  due to nonzero status from link
PETSc Error: No output file produced
TEST checkFortranTypeSizes from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:571)
TESTING: checkFortranTypeSizes from config.compilers(config/BuildSystem/config/compilers.py:571)
  Check whether real*8 is supported and suggest flags which will allow support
          Pushing language FC
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.compilers/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /tmp/petsc-lhuj9c/config.compilers/conftest.F
Successful compile:
Source:
      program main
      real*8 variable
      end
          Popping language FC
TEST checkFortranNameMangling from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:630)
TESTING: checkFortranNameMangling from config.compilers(config/BuildSystem/config/compilers.py:630)
  Checks Fortran name mangling, and defines HAVE_FORTRAN_UNDERSCORE, HAVE_FORTRAN_NOUNDERSCORE, HAVE_FORTRAN_CAPS, or HAVE_FORTRAN_STDCALL
Testing Fortran mangling type underscore with code void d1chk_(void){return;}
            Pushing language C
Successful compile:
Source:
            Popping language C
            Pushing language FC
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.compilers/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /tmp/petsc-lhuj9c/config.compilers/conftest.F
Successful compile:
Source:
      program main
       call d1chk()
      end
                    Pushing language FC
                    Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.compilers/conftest    -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 /tmp/petsc-lhuj9c/config.compilers/conftest.o /tmp/petsc-lhuj9c/config.compilers/confc.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
            Popping language FC
        compilers: Fortran name mangling is underscore
          Defined "HAVE_FORTRAN_UNDERSCORE" to "1"
TEST checkFortranNameManglingDouble from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:667)
TESTING: checkFortranNameManglingDouble from config.compilers(config/BuildSystem/config/compilers.py:667)
  Checks if symbols containing an underscore append an extra underscore, and defines HAVE_FORTRAN_UNDERSCORE_UNDERSCORE if necessary
            Pushing language C
Successful compile:
Source:
void d1_chk__(void){return;}
            Popping language C
            Pushing language FC
Successful compile:
Source:
      program main
       call d1_chk()
      end
                    Pushing language FC
                    Popping language FC
stderr:
/tmp/petsc-lhuj9c/config.compilers/conftest.o: In function `MAIN__':
/tmp/petsc-lhuj9c/config.compilers/conftest.F:2: undefined reference to `d1_chk_'
            Popping language FC
TEST checkFortranPreprocessor from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:677)
TESTING: checkFortranPreprocessor from config.compilers(config/BuildSystem/config/compilers.py:677)
  Determine if Fortran handles preprocessing properly
          Pushing language FC
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0    /tmp/petsc-lhuj9c/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef dummy
       fooey
#endif
      end
          Popping language FC
        compilers: Fortran uses CPP preprocessor
TEST checkFortranDefineCompilerOption from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:698)
TESTING: checkFortranDefineCompilerOption from config.compilers(config/BuildSystem/config/compilers.py:698)
  Check if -WF,-Dfoobar or -Dfoobar is the compiler option to define a macro
          Pushing language FC
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  -DTesting  /tmp/petsc-lhuj9c/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef Testing
       fooey
#endif
      end
          Defined make macro "FC_DEFINE_FLAG" to "-D"
          Popping language FC
        compilers: Fortran uses -D for defining macro
TEST checkFortranLibraries from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:715)
TESTING: checkFortranLibraries from config.compilers(config/BuildSystem/config/compilers.py:715)
  Substitutes for FLIBS the libraries needed to link with Fortran
    This macro is intended to be used in those situations when it is
    necessary to mix, e.g. C++ and Fortran 77, source code into a single
    program or shared library.
    For example, if object files from a C++ and Fortran 77 compiler must
    be linked together, then the C++ compiler/linker must be used for
    linking (since special C++-ish things need to happen at link time
    like calling global constructors, instantiating templates, enabling
    exception support, etc.).
    However, the Fortran 77 intrinsic and run-time libraries must be
    linked in as well, but the C++ compiler/linker does not know how to
    add these Fortran 77 libraries.
    This code was translated from the autoconf macro which was packaged in
    its current form by Matthew D. Langston <langston at SLAC.Stanford.EDU>.
    However, nearly all of this macro came from the OCTAVE_FLIBS macro in
    octave-2.0.13/aclocal.m4, and full credit should go to John W. Eaton
    for writing this extremely useful macro.
          Pushing language FC
Executing: /opt/mpich/bin/mpif90 -V
Successful compile:
Source:
      program main
      end
                Pushing language FC
                Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.compilers/conftest  -v   -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /tmp/petsc-lhuj9c/config.compilers/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
stdout: mpifort for MPICH version 3.1.3
stdout:
mpifort for MPICH version 3.1.3stderr:
Driving: gfortran -o /tmp/petsc-lhuj9c/config.compilers/conftest -v -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 /tmp/petsc-lhuj9c/config.compilers/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl -I/opt/mpich/include -I/opt/mpich/include -L/opt/mpich/lib -lmpifort -Wl,-rpath -Wl,/opt/mpich/lib -Wl,--enable-new-dtags -lmpi -l gfortran -l m -shared-libgcc
COLLECT_GCC=gfortran
Thread model: posix
Reading specs from /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/libgfortran.spec
rename spec lib to liborig
COLLECT_GCC_OPTIONS='-o' '/tmp/petsc-lhuj9c/config.compilers/conftest' '-v' '-fPIC' '-Wall' '-Wno-unused-variable' '-ffree-line-length-0' '-Wno-unused-dummy-argument' '-g' '-O0' '-L/opt/mpich/lib' '-L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1' '-I' '/opt/mpich/include' '-I' '/opt/mpich/include' '-L/opt/mpich/lib' '-shared-libgcc' '-mtune=generic' '-march=x86-64'
 /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/collect2 -plugin /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/liblto_plugin.so -plugin-opt=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/lto-wrapper -plugin-opt=-fresolution=/tmp/ccGxLTX1.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lquadmath -plugin-opt=-pass-through=-lm -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --build-id --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o /tmp/petsc-lhuj9c/config.compilers/conftest /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/crt1.o /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/crti.o /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/crtbegin.o -L/opt/mpich/lib -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/opt/mpich/lib -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../.. /tmp/petsc-lhuj9c/config.compilers/conftest.o -rpath /opt/mpich/lib -rpath /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -rpath /opt/mpich/lib -lmpi -lgcc_s -ldl -lmpifort -rpath /opt/mpich/lib --enable-new-dtags -lmpi -lgfortran -lm -lgcc_s -lgcc -lquadmath -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/crtend.o /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/crtn.o
          Popping language FC
        compilers: Checking arg mpifort
        compilers: Unknown arg mpifort
        compilers: Checking arg Driving:
        compilers: Unknown arg Driving:
        compilers: Checking arg gfortran
        compilers: Unknown arg gfortran
        compilers: Checking arg -v
        compilers: Unknown arg -v
        compilers: Checking arg -fPIC
        compilers: Unknown arg -fPIC
        compilers: Checking arg -Wall
        compilers: Unknown arg -Wall
        compilers: Checking arg -Wno-unused-variable
        compilers: Unknown arg -Wno-unused-variable
        compilers: Checking arg -ffree-line-length-0
        compilers: Unknown arg -ffree-line-length-0
        compilers: Checking arg -Wno-unused-dummy-argument
        compilers: Unknown arg -Wno-unused-dummy-argument
        compilers: Checking arg -g
        compilers: Unknown arg -g
        compilers: Checking arg -O0
        compilers: Unknown arg -O0
        compilers: Checking arg -Wl,-rpath,/opt/mpich/lib
        compilers: Unknown arg -Wl,-rpath,/opt/mpich/lib
        compilers: Checking arg -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1
        compilers: Unknown arg -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1
        Library already in C list so skipping in Fortran
        compilers: Already in lflags: -ldl
        compilers: Checking arg -I/opt/mpich/include
        compilers: Found include directory: /opt/mpich/include
        compilers: Already in lflags so skipping: -L/opt/mpich/lib
        compilers: Checking arg -lmpifort
        compilers: Found library: -lmpifort
        compilers: Checking arg -Wl,/opt/mpich/lib
        compilers: Unknown arg -Wl,/opt/mpich/lib
        compilers: Checking arg -Wl,--enable-new-dtags
        compilers: Unknown arg -Wl,--enable-new-dtags
        compilers: Already in lflags: -lmpi
        compilers: Found canonical library: -lgfortran
        compilers: Found canonical library: -lm
        compilers: Checking arg -shared-libgcc
        compilers: Unknown arg -shared-libgcc
        compilers: Checking arg COLLECT_GCC=gfortran
        compilers: Unknown arg COLLECT_GCC=gfortran
        compilers: Checking arg Reading
        compilers: Unknown arg Reading
        compilers: Checking arg from
        compilers: Unknown arg from
        compilers: Checking arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/libgfortran.spec
        compilers: Unknown arg /usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/libgfortran.spec
        compilers: Checking arg rename
        compilers: Unknown arg rename
        compilers: Checking arg lib
        compilers: Unknown arg lib
        compilers: Checking arg to
        compilers: Unknown arg to
        compilers: Checking arg liborig
        compilers: Unknown arg liborig
        compilers: Skipping arg COMPILER_PATH=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/
        compilers: Skipping arg LIBRARY_PATH=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../../lib/:/lib/../lib/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/../../../:/lib/:/usr/lib/
        compilers: Checking arg -plugin-opt=-fresolution=/tmp/ccGxLTX1.res
        compilers: Unknown arg -plugin-opt=-fresolution=/tmp/ccGxLTX1.res
        compilers: Checking arg -plugin-opt=-pass-through=-lquadmath
        compilers: Unknown arg -plugin-opt=-pass-through=-lquadmath
        compilers: Checking arg -plugin-opt=-pass-through=-lm
        compilers: Unknown arg -plugin-opt=-pass-through=-lm
        compilers: Already in lflags so skipping: -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1
        compilers: Already in rpathflags so skipping: -rpath
        compilers: Already in lflags: -lgcc_s
        compilers: Already in lflags: -lmpifort
        compilers: Checking arg -lgfortran
        compilers: Found library: -lgfortran
        compilers: Found system library therefor skipping: -lgcc
        compilers: Checking arg -lquadmath
        compilers: Found library: -lquadmath
        compilers: Found system library therefor skipping: -lc
        compilers: Libraries needed to link Fortran code with the C linker: ['-Wl,-rpath,/opt/mpich/lib', '-L/opt/mpich/lib', '-Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1', '-L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1', '-lmpifort', '-lgfortran', '-lm', '-Wl,-rpath,/opt/mpich/lib', '-Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1', '-lgfortran', '-lm', '-lquadmath', '-lm']
        compilers: Libraries needed to link Fortran main with the C linker: []
        compilers: Check that Fortran libraries can be used from C
            Pushing language C
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lmpifort -lgfortran -lm -Wl,-rpath,/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lgfortran -lm -lquadmath -lm -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lmpifort -lgfortran -lm -Wl,-rpath,/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lgfortran -lm -lquadmath -lm -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
        compilers: Check that Fortran libraries can be used from C++
            Pushing language Cxx
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
Executing: /opt/mpich/bin/mpicxx  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lmpifort -lgfortran -lm -Wl,-rpath,/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lgfortran -lm -lquadmath -lm -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
Successful compile:
Source:
int main() {
  return 0;
Executing: /opt/mpich/bin/mpicxx  -o /tmp/petsc-lhuj9c/config.setCompilers/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  /tmp/petsc-lhuj9c/config.setCompilers/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lmpifort -lgfortran -lm -Wl,-rpath,/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lgfortran -lm -lquadmath -lm -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
            Popping language Cxx
        compilers: Fortran libraries can be used from C++
TEST checkFortranLinkingCxx from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:1061)
TESTING: checkFortranLinkingCxx from config.compilers(config/BuildSystem/config/compilers.py:1061)
  Check that Fortran can be linked against C++
Successful compile:
Source:
extern "C" void d1chk_(void);
void foo(void){d1chk_();}
Successful compile:
Source:
            Pushing language FC
Successful compile:
Source:
      program main
       call d1chk()
      end
                    Pushing language FC
                    Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.compilers/conftest    -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /tmp/petsc-lhuj9c/config.compilers/conftest.o /tmp/petsc-lhuj9c/config.compilers/cxxobj.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s /tmp/petsc-lhuj9c/config.compilers/confc.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
            Popping language FC
        compilers: Fortran can link C++ functions
TEST checkFortran90 from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:1096)
TESTING: checkFortran90 from config.compilers(config/BuildSystem/config/compilers.py:1096)
  Determine whether the Fortran compiler handles F90
          Pushing language FC
Successful compile:
Source:
      program main
      INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8)
      INTEGER (KIND=int) :: ierr
      ierr = 1
      end
                  Pushing language FC
                  Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.compilers/conftest    -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /tmp/petsc-lhuj9c/config.compilers/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
          Defined "USING_F90" to "1"
        Fortran compiler supports F90
          Popping language FC
TEST checkFortran2003 from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:1109)
TESTING: checkFortran2003 from config.compilers(config/BuildSystem/config/compilers.py:1109)
  Determine whether the Fortran compiler handles F2003
          Pushing language FC
Successful compile:
Source:
      program main
      use,intrinsic :: iso_c_binding
      Type(C_Ptr),Dimension(:),Pointer :: CArray
      character(kind=c_char),pointer   :: nullc => null()
      character(kind=c_char,len=5),dimension(:),pointer::list1
      allocate(list1(5))
      CArray = (/(c_loc(list1(i)),i=1,5),c_loc(nullc)/)
      end
                  Pushing language FC
                  Popping language FC
          Defined "USING_F2003" to "1"
        Fortran compiler supports F2003
          Popping language FC
TEST checkFortran90Array from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:1129)
TESTING: checkFortran90Array from config.compilers(config/BuildSystem/config/compilers.py:1129)
  Check for F90 array interfaces
Executing: uname -s
stdout: Linux
          Pushing language C
Successful compile:
Source:
#include<stdio.h>
#include <stdlib.h>
void f90arraytest_(void* a1, void* a2,void* a3, void* i)
  printf("arrays [%p %p %p]\n",a1,a2,a3);
  fflush(stdout);
  return;
void f90ptrtest_(void* a1, void* a2,void* a3, void* i, void* p1 ,void* p2, void* p3)
  if ((p1 == p3) && (p1 != p2)) {
    printf("pointers match! [%p %p] [%p]\n",p1,p3,p2);
    fflush(stdout);
  } else {
    printf("pointers do not match! [%p %p] [%p]\n",p1,p3,p2);
    fflush(stdout);
    abort();
  return;
          Popping language C
          Pushing language FC
Successful compile:
Source:
      program main
      Interface
         Subroutine f90ptrtest(p1,p2,p3,i)
         integer, pointer :: p1(:,:)
         integer, pointer :: p2(:,:)
         integer, pointer :: p3(:,:)
         integer i
         End Subroutine
      End Interface
      integer, pointer :: ptr1(:,:),ptr2(:,:)
      integer, target  :: array(6:8,9:21)
      integer  in
      in   = 25
      ptr1 => array
      ptr2 => array
      call f90arraytest(ptr1,ptr2,ptr1,in)
      call f90ptrtest(ptr1,ptr2,ptr1,in)
      end
                      Pushing language FC
                      Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.compilers/conftest    -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /tmp/petsc-lhuj9c/config.compilers/conftest.o /tmp/petsc-lhuj9c/config.compilers/fooobj.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
Testing executable /tmp/petsc-lhuj9c/config.compilers/conftest to see if it can be run
Executing: /tmp/petsc-lhuj9c/config.compilers/conftest
stdout:
arrays [0x7fffd5ec2680 0x7fffd5ec2680 0x7fffd5ec2680]
arrays [0x7fffd5ec2630 0x7fffd5ec25e0 0x7fffd5ec2630]
pointers do not match! [0x7fc325089a40 0x7fffd5ec2680] [0x7fc326598b40]
ERROR while running executable: Could not execute "/tmp/petsc-lhuj9c/config.compilers/conftest":
Program received signal SIGABRT: Process abort signal.
Backtrace for this error:
#0  0x7FC3255E84F7
#1  0x7FC3255E8B3E
#2  0x7FC324D1D9EF
#3  0x7FC324D1D967
#4  0x7FC324D1ED39
#5  0x400CE6 in f90ptrtest_ at conftest.c:20
#6  0x400B89 in MAIN__ at conftest.F:20
          Popping language FC
        compilers: F90 uses a single argument for array pointers
TEST checkFortranModuleInclude from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:1216)
TESTING: checkFortranModuleInclude from config.compilers(config/BuildSystem/config/compilers.py:1216)
  Figures out what flag is used to specify the include path for Fortran modules
          Pushing language FC
Successful compile:
Source:
      module configtest
      integer testint
      parameter (testint = 42)
      end module configtest
          Pushing language FC
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.compilers/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers/confdir  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /tmp/petsc-lhuj9c/config.compilers/conftest.F
Successful compile:
Source:
      program main
      use configtest
      write(*,*) testint
      end
                  Pushing language FC
                  Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.compilers/conftest   -I/tmp/petsc-lhuj9c/config.compilers/confdir  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /tmp/petsc-lhuj9c/config.compilers/conftest.o /tmp/petsc-lhuj9c/config.compilers/configtest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
        compilers: Fortran module include flag -I found
          Popping language FC
TEST checkFortranModuleOutput from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:1282)
TESTING: checkFortranModuleOutput from config.compilers(config/BuildSystem/config/compilers.py:1282)
          Pushing language FC
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.compilers/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers -module /tmp/petsc-lhuj9c/config.compilers/confdir  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /tmp/petsc-lhuj9c/config.compilers/conftest.F
stderr:
gfortran: error: unrecognized command line option ?-module?
Source:
      module configtest
      integer testint
        compilers: Fortran module output flag -module  compile failed
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.compilers/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers -module:/tmp/petsc-lhuj9c/config.compilers/confdir  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /tmp/petsc-lhuj9c/config.compilers/conftest.F
stderr:
gfortran: error: unrecognized command line option ?-module:/tmp/petsc-lhuj9c/config.compilers/confdir?
Source:
      module configtest
      integer testint
        compilers: Fortran module output flag -module: compile failed
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.compilers/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers -fmod=/tmp/petsc-lhuj9c/config.compilers/confdir  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /tmp/petsc-lhuj9c/config.compilers/conftest.F
stderr:
gfortran: error: unrecognized command line option ?-fmod=/tmp/petsc-lhuj9c/config.compilers/confdir?
Source:
      module configtest
      integer testint
        compilers: Fortran module output flag -fmod= compile failed
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.compilers/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers -J/tmp/petsc-lhuj9c/config.compilers/confdir  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /tmp/petsc-lhuj9c/config.compilers/conftest.F
Successful compile:
Source:
      module configtest
      integer testint
        compilers: Fortran module output flag -J found
          Popping language FC
TEST setupFrameworkCompilers from config.compilers(/home/jed/petsc/config/BuildSystem/config/compilers.py:1413)
TESTING: setupFrameworkCompilers from config.compilers(config/BuildSystem/config/compilers.py:1413)
TEST configureClosure from config.utilities.closure(/home/jed/petsc/config/BuildSystem/config/utilities/closure.py:18)
TESTING: configureClosure from config.utilities.closure(config/BuildSystem/config/utilities/closure.py:18)
  Determine if Apple ^close syntax is supported in C
          Pushing language C
                      All intermediate test results are stored in /tmp/petsc-lhuj9c/config.utilities.closure
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.utilities.closure/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.utilities.closure  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.utilities.closure/conftest.c
stderr:
/tmp/petsc-lhuj9c/config.utilities.closure/conftest.c: In function ?main?:
/tmp/petsc-lhuj9c/config.utilities.closure/conftest.c:6:6: error: expected identifier or ?(? before ?^? token
 int (^closure)(int);;
Source:
#include "confdefs.h"
#include "conffix.h"
#include <stdio.h>
int main() {
  return 0;
            Compile failed inside link
TEST configureFortranCPP from PETSc.options.fortranCPP(/home/jed/petsc/config/PETSc/options/fortranCPP.py:27)
TESTING: configureFortranCPP from PETSc.options.fortranCPP(config/PETSc/options/fortranCPP.py:27)
  Handle case where Fortran cannot preprocess properly
          Defined make rule ".f.o .f90.o .f95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FFLAGS} ${FC_FLAGS} -o $@ $<']
          Defined make rule ".f.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FFLAGS} ${FC_FLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
          Defined make rule ".F.o .F90.o .F95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FFLAGS} ${FC_FLAGS} ${FCPPFLAGS} -o $@ $<']
          Defined make rule ".F.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FFLAGS} ${FC_FLAGS} ${FCPPFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
TEST checkStdC from config.headers(/home/jed/petsc/config/BuildSystem/config/headers.py:105)
TESTING: checkStdC from config.headers(config/BuildSystem/config/headers.py:105)
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.headers/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.headers/conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdarg.h>
#include <string.h>
#include <float.h>
int main() {
  return 0;
Source:
#include <string.h>
Executing: /opt/mpich/bin/mpicc -E  -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.headers  /tmp/petsc-lhuj9c/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-lhuj9c/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/conffix.h" 1
# 3 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
# 1 "/usr/include/string.h" 1 3 4
# 25 "/usr/include/string.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 395 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 396 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 26 "/usr/include/string.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 33 "/usr/include/string.h" 2 3 4
# 44 "/usr/include/string.h" 3 4
extern void *memcpy (void *__restrict __dest, const void *__restrict __src,
       size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern void *memmove (void *__dest, const void *__src, size_t __n)
extern void *memccpy (void *__restrict __dest, const void *__restrict __src,
        int __c, size_t __n)
extern void *memset (void *__s, int __c, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int memcmp (const void *__s1, const void *__s2, size_t __n)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
# 96 "/usr/include/string.h" 3 4
extern void *memchr (const void *__s, int __c, size_t __n)
      __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
# 127 "/usr/include/string.h" 3 4
extern char *strcpy (char *__restrict __dest, const char *__restrict __src)
extern char *strncpy (char *__restrict __dest,
        const char *__restrict __src, size_t __n)
extern char *strcat (char *__restrict __dest, const char *__restrict __src)
extern char *strncat (char *__restrict __dest, const char *__restrict __src,
extern int strcmp (const char *__s1, const char *__s2)
extern int strncmp (const char *__s1, const char *__s2, size_t __n)
extern int strcoll (const char *__s1, const char *__s2)
extern size_t strxfrm (char *__restrict __dest,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 1 "/usr/include/xlocale.h" 1 3 4
# 27 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 164 "/usr/include/string.h" 2 3 4
extern int strcoll_l (const char *__s1, const char *__s2, __locale_t __l)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern size_t strxfrm_l (char *__dest, const char *__src, size_t __n,
    __locale_t __l) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern char *strdup (const char *__s)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) __attribute__ ((__nonnull__ (1)));
extern char *strndup (const char *__string, size_t __n)
# 210 "/usr/include/string.h" 3 4
# 235 "/usr/include/string.h" 3 4
extern char *strchr (const char *__s, int __c)
# 262 "/usr/include/string.h" 3 4
extern char *strrchr (const char *__s, int __c)
# 281 "/usr/include/string.h" 3 4
extern size_t strcspn (const char *__s, const char *__reject)
extern size_t strspn (const char *__s, const char *__accept)
# 314 "/usr/include/string.h" 3 4
extern char *strpbrk (const char *__s, const char *__accept)
# 341 "/usr/include/string.h" 3 4
extern char *strstr (const char *__haystack, const char *__needle)
extern char *strtok (char *__restrict __s, const char *__restrict __delim)
extern char *__strtok_r (char *__restrict __s,
    const char *__restrict __delim,
    char **__restrict __save_ptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3)));
extern char *strtok_r (char *__restrict __s, const char *__restrict __delim,
# 396 "/usr/include/string.h" 3 4
extern size_t strlen (const char *__s)
extern size_t strnlen (const char *__string, size_t __maxlen)
extern char *strerror (int __errnum) __attribute__ ((__nothrow__ , __leaf__));
# 426 "/usr/include/string.h" 3 4
extern int strerror_r (int __errnum, char *__buf, size_t __buflen) __asm__ ("" "__xpg_strerror_r") __attribute__ ((__nothrow__ , __leaf__))
# 444 "/usr/include/string.h" 3 4
extern char *strerror_l (int __errnum, __locale_t __l) __attribute__ ((__nothrow__ , __leaf__));
extern void __bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern void bcopy (const void *__src, void *__dest, size_t __n)
extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
# 488 "/usr/include/string.h" 3 4
extern char *index (const char *__s, int __c)
# 516 "/usr/include/string.h" 3 4
extern char *rindex (const char *__s, int __c)
extern int ffs (int __i) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 533 "/usr/include/string.h" 3 4
extern int strcasecmp (const char *__s1, const char *__s2)
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
# 556 "/usr/include/string.h" 3 4
extern char *strsep (char **__restrict __stringp,
extern char *strsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern char *__stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *__stpncpy (char *__restrict __dest,
extern char *stpncpy (char *__restrict __dest,
# 643 "/usr/include/string.h" 3 4
Source:
#include <stdlib.h>
stdout:
# 1 "<built-in>"
# 1 "/usr/include/stdlib.h" 1 3 4
# 24 "/usr/include/stdlib.h" 3 4
# 25 "/usr/include/stdlib.h" 2 3 4
# 324 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef int wchar_t;
# 33 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitflags.h" 1 3 4
# 42 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitstatus.h" 1 3 4
# 64 "/usr/include/bits/waitstatus.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 27 "/usr/include/bits/byteswap.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 28 "/usr/include/bits/byteswap.h" 2 3 4
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 65 "/usr/include/bits/waitstatus.h" 2 3 4
union wait
    int w_status;
    struct
 unsigned int __w_termsig:7;
 unsigned int __w_coredump:1;
 unsigned int __w_retcode:8;
 unsigned int:16;
      } __wait_terminated;
    struct
 unsigned int __w_stopval:8;
 unsigned int __w_stopsig:8;
 unsigned int:16;
      } __wait_stopped;
# 43 "/usr/include/stdlib.h" 2 3 4
# 67 "/usr/include/stdlib.h" 3 4
typedef union
    union wait *__uptr;
    int *__iptr;
  } __WAIT_STATUS __attribute__ ((__transparent_union__));
# 95 "/usr/include/stdlib.h" 3 4
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
# 139 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (const char *__nptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
__extension__ extern long long int atoll (const char *__nptr)
extern double strtod (const char *__restrict __nptr,
        char **__restrict __endptr)
extern float strtof (const char *__restrict __nptr,
       char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long double strtold (const char *__restrict __nptr,
extern long int strtol (const char *__restrict __nptr,
   char **__restrict __endptr, int __base)
extern unsigned long int strtoul (const char *__restrict __nptr,
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
# 305 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (const char *__s)
# 1 "/usr/include/sys/types.h" 1 3 4
# 27 "/usr/include/sys/types.h" 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 60 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 98 "/usr/include/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 132 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/time.h" 1 3 4
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 133 "/usr/include/sys/types.h" 2 3 4
# 146 "/usr/include/sys/types.h" 3 4
# 147 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 194 "/usr/include/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 219 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/sigset.h" 1 3 4
# 22 "/usr/include/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
# 44 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 46 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 64 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 96 "/usr/include/sys/select.h" 3 4
# 106 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 118 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 131 "/usr/include/sys/select.h" 3 4
# 220 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/sysmacros.h" 1 3 4
# 24 "/usr/include/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 58 "/usr/include/sys/sysmacros.h" 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 270 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 271 "/usr/include/sys/types.h" 2 3 4
# 315 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
   size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
       int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
   size_t __statelen,
   struct random_data *__restrict __buf)
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    __extension__ unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
        double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
        long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
       struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void cfree (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/alloca.h" 1 3 4
# 24 "/usr/include/alloca.h" 3 4
# 25 "/usr/include/alloca.h" 2 3 4
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
# 493 "/usr/include/stdlib.h" 2 3 4
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 513 "/usr/include/stdlib.h" 3 4
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 530 "/usr/include/stdlib.h" 3 4
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 578 "/usr/include/stdlib.h" 3 4
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 606 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 619 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 641 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 662 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 711 "/usr/include/stdlib.h" 3 4
extern int system (const char *__command) ;
# 733 "/usr/include/stdlib.h" 3 4
extern char *realpath (const char *__restrict __name,
         char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
typedef int (*__compar_fn_t) (const void *, const void *);
# 751 "/usr/include/stdlib.h" 3 4
extern void *bsearch (const void *__key, const void *__base,
        size_t __nmemb, size_t __size, __compar_fn_t __compar)
     __attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
     __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 774 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
        long long int __denom)
# 811 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign, char *__restrict __buf,
     size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign,
      char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int mbtowc (wchar_t *__restrict __pwc,
     const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__));
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
extern size_t wcstombs (char *__restrict __s,
   const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 898 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
        char *const *__restrict __tokens,
        char **__restrict __valuep)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 950 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 1 "/usr/include/bits/stdlib-float.h" 1 3 4
# 955 "/usr/include/stdlib.h" 2 3 4
# 967 "/usr/include/stdlib.h" 3 4
Successful compile:
Source:
#include <stdlib.h>
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
#define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
int main() {
        int i;
        for(i = 0; i < 256; i++) if (XOR(islower(i), ISLOWER(i)) || toupper(i) != TOUPPER(i)) exit(2);
        exit(0);
  return 0;
                      Pushing language C
                      Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.headers/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.headers/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
Testing executable /tmp/petsc-lhuj9c/config.headers/conftest to see if it can be run
Executing: /tmp/petsc-lhuj9c/config.headers/conftest
          Defined "STDC_HEADERS" to "1"
TEST checkStat from config.headers(/home/jed/petsc/config/BuildSystem/config/headers.py:138)
TESTING: checkStat from config.headers(config/BuildSystem/config/headers.py:138)
  Checks whether stat file-mode macros are broken, and defines STAT_MACROS_BROKEN if they are
Source:
#include <sys/types.h>
#include <sys/stat.h>
#if defined(S_ISBLK) && defined(S_IFDIR)
# if S_ISBLK (S_IFDIR)
  You lose.
# endif
#endif
#if defined(S_ISBLK) && defined(S_IFCHR)
# if S_ISBLK (S_IFCHR)
  You lose.
# endif
#endif
#if defined(S_ISLNK) && defined(S_IFREG)
# if S_ISLNK (S_IFREG)
  You lose.
# endif
#endif
#if defined(S_ISSOCK) && defined(S_IFREG)
# if S_ISSOCK (S_IFREG)
  You lose.
# endif
#endif
stdout:
# 1 "<built-in>"
# 25 "/usr/include/sys/types.h" 3 4
# 26 "/usr/include/sys/types.h" 2 3 4
# 30 "/usr/include/sys/types.h" 2 3 4
# 216 "/usr/include/sys/types.h" 3 4
# 28 "/usr/include/bits/byteswap.h" 3 4
# 217 "/usr/include/sys/types.h" 2 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 5 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
# 1 "/usr/include/sys/stat.h" 1 3 4
# 36 "/usr/include/sys/stat.h" 3 4
# 37 "/usr/include/sys/stat.h" 2 3 4
# 102 "/usr/include/sys/stat.h" 3 4
# 1 "/usr/include/bits/stat.h" 1 3 4
# 46 "/usr/include/bits/stat.h" 3 4
struct stat
    __dev_t st_dev;
    __ino_t st_ino;
    __nlink_t st_nlink;
    __mode_t st_mode;
    __uid_t st_uid;
    __gid_t st_gid;
    int __pad0;
    __dev_t st_rdev;
    __off_t st_size;
    __blksize_t st_blksize;
    __blkcnt_t st_blocks;
# 91 "/usr/include/bits/stat.h" 3 4
    struct timespec st_atim;
    struct timespec st_mtim;
    struct timespec st_ctim;
# 106 "/usr/include/bits/stat.h" 3 4
    __syscall_slong_t __glibc_reserved[3];
# 115 "/usr/include/bits/stat.h" 3 4
# 105 "/usr/include/sys/stat.h" 2 3 4
# 208 "/usr/include/sys/stat.h" 3 4
extern int stat (const char *__restrict __file,
   struct stat *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int fstat (int __fd, struct stat *__buf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 237 "/usr/include/sys/stat.h" 3 4
extern int fstatat (int __fd, const char *__restrict __file,
      struct stat *__restrict __buf, int __flag)
# 262 "/usr/include/sys/stat.h" 3 4
extern int lstat (const char *__restrict __file,
# 283 "/usr/include/sys/stat.h" 3 4
extern int chmod (const char *__file, __mode_t __mode)
extern int lchmod (const char *__file, __mode_t __mode)
extern int fchmod (int __fd, __mode_t __mode) __attribute__ ((__nothrow__ , __leaf__));
extern int fchmodat (int __fd, const char *__file, __mode_t __mode,
       int __flag)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2))) ;
extern __mode_t umask (__mode_t __mask) __attribute__ ((__nothrow__ , __leaf__));
# 320 "/usr/include/sys/stat.h" 3 4
extern int mkdir (const char *__path, __mode_t __mode)
extern int mkdirat (int __fd, const char *__path, __mode_t __mode)
extern int mknod (const char *__path, __mode_t __mode, __dev_t __dev)
extern int mknodat (int __fd, const char *__path, __mode_t __mode,
      __dev_t __dev) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern int mkfifo (const char *__path, __mode_t __mode)
extern int mkfifoat (int __fd, const char *__path, __mode_t __mode)
extern int utimensat (int __fd, const char *__path,
        const struct timespec __times[2],
        int __flags)
extern int futimens (int __fd, const struct timespec __times[2]) __attribute__ ((__nothrow__ , __leaf__));
# 398 "/usr/include/sys/stat.h" 3 4
extern int __fxstat (int __ver, int __fildes, struct stat *__stat_buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3)));
extern int __xstat (int __ver, const char *__filename,
      struct stat *__stat_buf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3)));
extern int __lxstat (int __ver, const char *__filename,
extern int __fxstatat (int __ver, int __fildes, const char *__filename,
         struct stat *__stat_buf, int __flag)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4)));
# 441 "/usr/include/sys/stat.h" 3 4
extern int __xmknod (int __ver, const char *__path, __mode_t __mode,
       __dev_t *__dev) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern int __xmknodat (int __ver, int __fd, const char *__path,
         __mode_t __mode, __dev_t *__dev)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 5)));
# 533 "/usr/include/sys/stat.h" 3 4
# 6 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
TEST checkSysWait from config.headers(/home/jed/petsc/config/BuildSystem/config/headers.py:173)
TESTING: checkSysWait from config.headers(config/BuildSystem/config/headers.py:173)
  Check for POSIX.1 compatible sys/wait.h, and defines HAVE_SYS_WAIT_H if found
Successful compile:
Source:
#include <sys/wait.h>
#ifndef WEXITSTATUS
#define WEXITSTATUS(stat_val) ((unsigned)(stat_val) >> 8)
#endif
#ifndef WIFEXITED
#define WIFEXITED(stat_val) (((stat_val) & 255) == 0)
#endif
int main() {
    int s;
    wait (&s);
    s = WIFEXITED (s) ? WEXITSTATUS (s) : 1;
  return 0;
          Defined "HAVE_SYS_WAIT_H" to "1"
TEST checkTime from config.headers(/home/jed/petsc/config/BuildSystem/config/headers.py:195)
TESTING: checkTime from config.headers(config/BuildSystem/config/headers.py:195)
  Checks if you can safely include both <sys/time.h> and <time.h>, and if so defines TIME_WITH_SYS_TIME
Checking for header: time.h
stdout:
# 1 "<built-in>"
# 27 "/usr/include/time.h" 3 4
# 28 "/usr/include/time.h" 2 3 4
# 38 "/usr/include/time.h" 2 3 4
# 42 "/usr/include/time.h" 2 3 4
# 55 "/usr/include/time.h" 3 4
# 56 "/usr/include/time.h" 2 3 4
struct timespec
    __time_t tv_sec;
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
  long int tm_gmtoff;
  const char *tm_zone;
struct itimerspec
    struct timespec it_interval;
    struct timespec it_value;
struct sigevent;
# 186 "/usr/include/time.h" 3 4
extern clock_t clock (void) __attribute__ ((__nothrow__ , __leaf__));
extern time_t time (time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern double difftime (time_t __time1, time_t __time0)
extern time_t mktime (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern size_t strftime (char *__restrict __s, size_t __maxsize,
   const char *__restrict __format,
   const struct tm *__restrict __tp) __attribute__ ((__nothrow__ , __leaf__));
# 221 "/usr/include/time.h" 3 4
} *__locale_t;
# 222 "/usr/include/time.h" 2 3 4
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
     const struct tm *__restrict __tp,
     __locale_t __loc) __attribute__ ((__nothrow__ , __leaf__));
# 236 "/usr/include/time.h" 3 4
extern struct tm *gmtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *localtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *gmtime_r (const time_t *__restrict __timer,
extern struct tm *localtime_r (const time_t *__restrict __timer,
extern char *asctime (const struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern char *asctime_r (const struct tm *__restrict __tp,
   char *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime_r (const time_t *__restrict __timer,
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daylight;
extern long int timezone;
extern int stime (const time_t *__when) __attribute__ ((__nothrow__ , __leaf__));
# 319 "/usr/include/time.h" 3 4
extern time_t timegm (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern time_t timelocal (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int dysize (int __year) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 334 "/usr/include/time.h" 3 4
extern int nanosleep (const struct timespec *__requested_time,
        struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
       const struct timespec *__req,
       struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_create (clockid_t __clock_id,
    struct sigevent *__restrict __evp,
    timer_t *__restrict __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_delete (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_settime (timer_t __timerid, int __flags,
     const struct itimerspec *__restrict __value,
     struct itimerspec *__restrict __ovalue) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
extern int timer_getoverrun (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
# 430 "/usr/include/time.h" 3 4
            Defined "HAVE_TIME_H" to "1"
Checking for header: sys/time.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/time.h" 1 3 4
# 21 "/usr/include/sys/time.h" 3 4
# 22 "/usr/include/sys/time.h" 2 3 4
# 24 "/usr/include/sys/time.h" 2 3 4
# 26 "/usr/include/sys/time.h" 2 3 4
struct timeval
    __time_t tv_sec;
# 28 "/usr/include/sys/time.h" 2 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
typedef struct
  } fd_set;
# 30 "/usr/include/sys/time.h" 2 3 4
# 55 "/usr/include/sys/time.h" 3 4
struct timezone
    int tz_minuteswest;
    int tz_dsttime;
typedef struct timezone *__restrict __timezone_ptr_t;
# 71 "/usr/include/sys/time.h" 3 4
extern int gettimeofday (struct timeval *__restrict __tv,
    __timezone_ptr_t __tz) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int settimeofday (const struct timeval *__tv,
    const struct timezone *__tz)
extern int adjtime (const struct timeval *__delta,
      struct timeval *__olddelta) __attribute__ ((__nothrow__ , __leaf__));
enum __itimer_which
    ITIMER_REAL = 0,
    ITIMER_VIRTUAL = 1,
    ITIMER_PROF = 2
struct itimerval
    struct timeval it_interval;
    struct timeval it_value;
typedef int __itimer_which_t;
extern int getitimer (__itimer_which_t __which,
        struct itimerval *__value) __attribute__ ((__nothrow__ , __leaf__));
extern int setitimer (__itimer_which_t __which,
        const struct itimerval *__restrict __new,
        struct itimerval *__restrict __old) __attribute__ ((__nothrow__ , __leaf__));
extern int utimes (const char *__file, const struct timeval __tvp[2])
extern int lutimes (const char *__file, const struct timeval __tvp[2])
extern int futimes (int __fd, const struct timeval __tvp[2]) __attribute__ ((__nothrow__ , __leaf__));
# 189 "/usr/include/sys/time.h" 3 4
            Defined "HAVE_SYS_TIME_H" to "1"
Successful compile:
Source:
#include <sys/time.h>
#include <time.h>
int main() {
struct tm *tp = 0;
if (tp);
  return 0;
          Defined "TIME_WITH_SYS_TIME" to "1"
TEST checkMath from config.headers(/home/jed/petsc/config/BuildSystem/config/headers.py:203)
TESTING: checkMath from config.headers(config/BuildSystem/config/headers.py:203)
  Checks for the math headers and defines
Checking for header: math.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/math.h" 1 3 4
# 26 "/usr/include/math.h" 3 4
# 27 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/bits/huge_val.h" 1 3 4
# 33 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/bits/huge_valf.h" 1 3 4
# 35 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/bits/huge_vall.h" 1 3 4
# 36 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/bits/inf.h" 1 3 4
# 39 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/bits/nan.h" 1 3 4
# 42 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/bits/mathdef.h" 1 3 4
# 28 "/usr/include/bits/mathdef.h" 3 4
typedef float float_t;
typedef double double_t;
# 46 "/usr/include/math.h" 2 3 4
# 69 "/usr/include/math.h" 3 4
# 1 "/usr/include/bits/mathcalls.h" 1 3 4
# 52 "/usr/include/bits/mathcalls.h" 3 4
extern double acos (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __acos (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double asin (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __asin (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double atan (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __atan (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double atan2 (double __y, double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __atan2 (double __y, double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double cos (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __cos (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double sin (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __sin (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double tan (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __tan (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double cosh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __cosh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double sinh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __sinh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double tanh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __tanh (double __x) __attribute__ ((__nothrow__ , __leaf__));
# 86 "/usr/include/bits/mathcalls.h" 3 4
extern double acosh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __acosh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double asinh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __asinh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double atanh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __atanh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double exp (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __exp (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double frexp (double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__)); extern double __frexp (double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__));
extern double ldexp (double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__)); extern double __ldexp (double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__));
extern double log (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double log10 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log10 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double modf (double __x, double *__iptr) __attribute__ ((__nothrow__ , __leaf__)); extern double __modf (double __x, double *__iptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 126 "/usr/include/bits/mathcalls.h" 3 4
extern double expm1 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __expm1 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double log1p (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log1p (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double logb (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __logb (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double exp2 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __exp2 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double log2 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log2 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double pow (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __pow (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double sqrt (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __sqrt (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double hypot (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __hypot (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double cbrt (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __cbrt (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double ceil (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __ceil (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double fabs (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __fabs (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double floor (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __floor (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double fmod (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __fmod (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __isinf (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __finite (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isinf (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int finite (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double drem (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __drem (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double significand (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __significand (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double copysign (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __copysign (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double nan (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __nan (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __isnan (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isnan (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double j0 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __j0 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double j1 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __j1 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double jn (int, double) __attribute__ ((__nothrow__ , __leaf__)); extern double __jn (int, double) __attribute__ ((__nothrow__ , __leaf__));
extern double y0 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __y0 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double y1 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __y1 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double yn (int, double) __attribute__ ((__nothrow__ , __leaf__)); extern double __yn (int, double) __attribute__ ((__nothrow__ , __leaf__));
extern double erf (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __erf (double) __attribute__ ((__nothrow__ , __leaf__));
extern double erfc (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __erfc (double) __attribute__ ((__nothrow__ , __leaf__));
extern double lgamma (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __lgamma (double) __attribute__ ((__nothrow__ , __leaf__));
extern double tgamma (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __tgamma (double) __attribute__ ((__nothrow__ , __leaf__));
extern double gamma (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __gamma (double) __attribute__ ((__nothrow__ , __leaf__));
extern double lgamma_r (double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__)); extern double __lgamma_r (double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__));
extern double rint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __rint (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double nextafter (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __nextafter (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double nexttoward (double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __nexttoward (double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double remainder (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __remainder (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double scalbn (double __x, int __n) __attribute__ ((__nothrow__ , __leaf__)); extern double __scalbn (double __x, int __n) __attribute__ ((__nothrow__ , __leaf__));
extern int ilogb (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern int __ilogb (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double scalbln (double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__)); extern double __scalbln (double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__));
extern double nearbyint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __nearbyint (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double round (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __round (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double trunc (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __trunc (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double remquo (double __x, double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__)); extern double __remquo (double __x, double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__));
extern long int lrint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lrint (double __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llrint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llrint (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long int lround (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lround (double __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llround (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llround (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double fdim (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __fdim (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double fmax (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __fmax (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double fmin (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __fmin (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __fpclassify (double __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __signbit (double __value) __attribute__ ((__nothrow__ , __leaf__))
extern double fma (double __x, double __y, double __z) __attribute__ ((__nothrow__ , __leaf__)); extern double __fma (double __x, double __y, double __z) __attribute__ ((__nothrow__ , __leaf__));
# 371 "/usr/include/bits/mathcalls.h" 3 4
extern double scalb (double __x, double __n) __attribute__ ((__nothrow__ , __leaf__)); extern double __scalb (double __x, double __n) __attribute__ ((__nothrow__ , __leaf__));
# 70 "/usr/include/math.h" 2 3 4
# 88 "/usr/include/math.h" 3 4
extern float acosf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __acosf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float asinf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __asinf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float atanf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __atanf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float atan2f (float __y, float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __atan2f (float __y, float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float cosf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __cosf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float sinf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __sinf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float tanf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __tanf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float coshf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __coshf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float sinhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __sinhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float tanhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __tanhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float acoshf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __acoshf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float asinhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __asinhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float atanhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __atanhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float expf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __expf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float frexpf (float __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__)); extern float __frexpf (float __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__));
extern float ldexpf (float __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__)); extern float __ldexpf (float __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__));
extern float logf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __logf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float log10f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __log10f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float modff (float __x, float *__iptr) __attribute__ ((__nothrow__ , __leaf__)); extern float __modff (float __x, float *__iptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern float expm1f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __expm1f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float log1pf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __log1pf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float logbf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __logbf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float exp2f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __exp2f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float log2f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __log2f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float powf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __powf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float sqrtf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __sqrtf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float hypotf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __hypotf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float cbrtf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __cbrtf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float ceilf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __ceilf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float fabsf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __fabsf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float floorf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __floorf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float fmodf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __fmodf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __isinff (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __finitef (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isinff (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int finitef (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float dremf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __dremf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float significandf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __significandf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float copysignf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __copysignf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float nanf (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __nanf (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __isnanf (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isnanf (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float j0f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __j0f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float j1f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __j1f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float jnf (int, float) __attribute__ ((__nothrow__ , __leaf__)); extern float __jnf (int, float) __attribute__ ((__nothrow__ , __leaf__));
extern float y0f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __y0f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float y1f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __y1f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float ynf (int, float) __attribute__ ((__nothrow__ , __leaf__)); extern float __ynf (int, float) __attribute__ ((__nothrow__ , __leaf__));
extern float erff (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __erff (float) __attribute__ ((__nothrow__ , __leaf__));
extern float erfcf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __erfcf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float lgammaf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __lgammaf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float tgammaf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __tgammaf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float gammaf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __gammaf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float lgammaf_r (float, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__)); extern float __lgammaf_r (float, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__));
extern float rintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __rintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float nextafterf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __nextafterf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float nexttowardf (float __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __nexttowardf (float __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float remainderf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __remainderf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float scalbnf (float __x, int __n) __attribute__ ((__nothrow__ , __leaf__)); extern float __scalbnf (float __x, int __n) __attribute__ ((__nothrow__ , __leaf__));
extern int ilogbf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern int __ilogbf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float scalblnf (float __x, long int __n) __attribute__ ((__nothrow__ , __leaf__)); extern float __scalblnf (float __x, long int __n) __attribute__ ((__nothrow__ , __leaf__));
extern float nearbyintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __nearbyintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float roundf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __roundf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float truncf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __truncf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float remquof (float __x, float __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__)); extern float __remquof (float __x, float __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__));
extern long int lrintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lrintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llrintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llrintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern long int lroundf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lroundf (float __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llroundf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llroundf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float fdimf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __fdimf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float fmaxf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __fmaxf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float fminf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __fminf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __fpclassifyf (float __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __signbitf (float __value) __attribute__ ((__nothrow__ , __leaf__))
extern float fmaf (float __x, float __y, float __z) __attribute__ ((__nothrow__ , __leaf__)); extern float __fmaf (float __x, float __y, float __z) __attribute__ ((__nothrow__ , __leaf__));
extern float scalbf (float __x, float __n) __attribute__ ((__nothrow__ , __leaf__)); extern float __scalbf (float __x, float __n) __attribute__ ((__nothrow__ , __leaf__));
# 89 "/usr/include/math.h" 2 3 4
# 132 "/usr/include/math.h" 3 4
extern long double acosl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __acosl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double asinl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __asinl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double atanl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __atanl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double atan2l (long double __y, long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __atan2l (long double __y, long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double cosl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __cosl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double sinl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __sinl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double tanl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __tanl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double coshl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __coshl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double sinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __sinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double tanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __tanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double acoshl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __acoshl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double asinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __asinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double atanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __atanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double expl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __expl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double frexpl (long double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__)); extern long double __frexpl (long double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__));
extern long double ldexpl (long double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__)); extern long double __ldexpl (long double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__));
extern long double logl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __logl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double log10l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __log10l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double modfl (long double __x, long double *__iptr) __attribute__ ((__nothrow__ , __leaf__)); extern long double __modfl (long double __x, long double *__iptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern long double expm1l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __expm1l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double log1pl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __log1pl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double logbl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __logbl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double exp2l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __exp2l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double log2l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __log2l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double powl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __powl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double sqrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __sqrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double hypotl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __hypotl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double cbrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __cbrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double ceill (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __ceill (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double fabsl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __fabsl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double floorl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __floorl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double fmodl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __fmodl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __isinfl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __finitel (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isinfl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int finitel (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double dreml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __dreml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double significandl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __significandl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double copysignl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __copysignl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double nanl (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __nanl (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __isnanl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isnanl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double j0l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __j0l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double j1l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __j1l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double jnl (int, long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __jnl (int, long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double y0l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __y0l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double y1l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __y1l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double ynl (int, long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __ynl (int, long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double erfl (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __erfl (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double erfcl (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __erfcl (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double lgammal (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __lgammal (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double tgammal (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __tgammal (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double gammal (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __gammal (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double lgammal_r (long double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__)); extern long double __lgammal_r (long double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__));
extern long double rintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __rintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double nextafterl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __nextafterl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double nexttowardl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __nexttowardl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double remainderl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __remainderl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double scalbnl (long double __x, int __n) __attribute__ ((__nothrow__ , __leaf__)); extern long double __scalbnl (long double __x, int __n) __attribute__ ((__nothrow__ , __leaf__));
extern int ilogbl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern int __ilogbl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double scalblnl (long double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__)); extern long double __scalblnl (long double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__));
extern long double nearbyintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __nearbyintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double roundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __roundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double truncl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __truncl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double remquol (long double __x, long double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__)); extern long double __remquol (long double __x, long double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__));
extern long int lrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long int lroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double fdiml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __fdiml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double fmaxl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __fmaxl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double fminl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __fminl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __fpclassifyl (long double __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __signbitl (long double __value) __attribute__ ((__nothrow__ , __leaf__))
extern long double fmal (long double __x, long double __y, long double __z) __attribute__ ((__nothrow__ , __leaf__)); extern long double __fmal (long double __x, long double __y, long double __z) __attribute__ ((__nothrow__ , __leaf__));
extern long double scalbl (long double __x, long double __n) __attribute__ ((__nothrow__ , __leaf__)); extern long double __scalbl (long double __x, long double __n) __attribute__ ((__nothrow__ , __leaf__));
# 133 "/usr/include/math.h" 2 3 4
# 148 "/usr/include/math.h" 3 4
extern int signgam;
# 189 "/usr/include/math.h" 3 4
enum
    FP_NAN =
      0,
    FP_INFINITE =
      1,
    FP_ZERO =
      2,
    FP_SUBNORMAL =
      3,
    FP_NORMAL =
      4
# 301 "/usr/include/math.h" 3 4
typedef enum
  _IEEE_ = -1,
  _SVID_,
  _XOPEN_,
  _POSIX_,
  _ISOC_
} _LIB_VERSION_TYPE;
extern _LIB_VERSION_TYPE _LIB_VERSION;
# 326 "/usr/include/math.h" 3 4
struct exception
    int type;
    char *name;
    double arg1;
    double arg2;
    double retval;
extern int matherr (struct exception *__exc);
# 488 "/usr/include/math.h" 3 4
# 3 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
            Defined "HAVE_MATH_H" to "1"
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.headers/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.headers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <math.h>
int main() {
double pi = M_PI;
if (pi);
  return 0;
        Found math #defines, like M_PI
TEST check from config.headers(/home/jed/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: sys/socket.h
Executing: /opt/mpich/bin/mpicc -E  -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.headers  /tmp/petsc-lhuj9c/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-lhuj9c/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/conffix.h" 1
# 1 "/usr/include/sys/socket.h" 1 3 4
# 22 "/usr/include/sys/socket.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 395 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 396 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 23 "/usr/include/sys/socket.h" 2 3 4
# 1 "/usr/include/sys/uio.h" 1 3 4
# 23 "/usr/include/sys/uio.h" 3 4
# 1 "/usr/include/sys/types.h" 1 3 4
# 27 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 60 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 98 "/usr/include/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 132 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/time.h" 1 3 4
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 133 "/usr/include/sys/types.h" 2 3 4
# 146 "/usr/include/sys/types.h" 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 147 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 194 "/usr/include/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/sigset.h" 1 3 4
# 22 "/usr/include/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
# 44 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 46 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 64 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 96 "/usr/include/sys/select.h" 3 4
# 106 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 118 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 131 "/usr/include/sys/select.h" 3 4
# 220 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/sysmacros.h" 1 3 4
# 24 "/usr/include/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 58 "/usr/include/sys/sysmacros.h" 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 270 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 271 "/usr/include/sys/types.h" 2 3 4
# 24 "/usr/include/sys/uio.h" 2 3 4
# 1 "/usr/include/bits/uio.h" 1 3 4
# 43 "/usr/include/bits/uio.h" 3 4
struct iovec
    void *iov_base;
    size_t iov_len;
# 29 "/usr/include/sys/uio.h" 2 3 4
# 39 "/usr/include/sys/uio.h" 3 4
extern ssize_t readv (int __fd, const struct iovec *__iovec, int __count)
# 50 "/usr/include/sys/uio.h" 3 4
extern ssize_t writev (int __fd, const struct iovec *__iovec, int __count)
# 65 "/usr/include/sys/uio.h" 3 4
extern ssize_t preadv (int __fd, const struct iovec *__iovec, int __count,
         __off_t __offset) ;
# 77 "/usr/include/sys/uio.h" 3 4
extern ssize_t pwritev (int __fd, const struct iovec *__iovec, int __count,
   __off_t __offset) ;
# 120 "/usr/include/sys/uio.h" 3 4
# 27 "/usr/include/sys/socket.h" 2 3 4
# 29 "/usr/include/sys/socket.h" 2 3 4
# 38 "/usr/include/sys/socket.h" 3 4
# 1 "/usr/include/bits/socket.h" 1 3 4
# 27 "/usr/include/bits/socket.h" 3 4
# 28 "/usr/include/bits/socket.h" 2 3 4
typedef __socklen_t socklen_t;
# 1 "/usr/include/bits/socket_type.h" 1 3 4
# 24 "/usr/include/bits/socket_type.h" 3 4
enum __socket_type
  SOCK_STREAM = 1,
  SOCK_DGRAM = 2,
  SOCK_RAW = 3,
  SOCK_RDM = 4,
  SOCK_SEQPACKET = 5,
  SOCK_DCCP = 6,
  SOCK_PACKET = 10,
  SOCK_CLOEXEC = 02000000,
  SOCK_NONBLOCK = 00004000
# 39 "/usr/include/bits/socket.h" 2 3 4
# 146 "/usr/include/bits/socket.h" 3 4
# 1 "/usr/include/bits/sockaddr.h" 1 3 4
# 28 "/usr/include/bits/sockaddr.h" 3 4
typedef unsigned short int sa_family_t;
# 147 "/usr/include/bits/socket.h" 2 3 4
struct sockaddr
    sa_family_t sa_family;
    char sa_data[14];
# 162 "/usr/include/bits/socket.h" 3 4
struct sockaddr_storage
    sa_family_t ss_family;
    unsigned long int __ss_align;
    char __ss_padding[(128 - (2 * sizeof (unsigned long int)))];
enum
    MSG_OOB = 0x01,
    MSG_PEEK = 0x02,
    MSG_DONTROUTE = 0x04,
    MSG_CTRUNC = 0x08,
    MSG_PROXY = 0x10,
    MSG_TRUNC = 0x20,
    MSG_DONTWAIT = 0x40,
    MSG_EOR = 0x80,
    MSG_WAITALL = 0x100,
    MSG_FIN = 0x200,
    MSG_SYN = 0x400,
    MSG_CONFIRM = 0x800,
    MSG_RST = 0x1000,
    MSG_ERRQUEUE = 0x2000,
    MSG_NOSIGNAL = 0x4000,
    MSG_MORE = 0x8000,
    MSG_WAITFORONE = 0x10000,
    MSG_FASTOPEN = 0x20000000,
    MSG_CMSG_CLOEXEC = 0x40000000
struct msghdr
    void *msg_name;
    socklen_t msg_namelen;
    struct iovec *msg_iov;
    size_t msg_iovlen;
    void *msg_control;
    size_t msg_controllen;
    int msg_flags;
struct cmsghdr
    size_t cmsg_len;
    int cmsg_level;
    int cmsg_type;
    __extension__ unsigned char __cmsg_data [];
# 272 "/usr/include/bits/socket.h" 3 4
extern struct cmsghdr *__cmsg_nxthdr (struct msghdr *__mhdr,
          struct cmsghdr *__cmsg) __attribute__ ((__nothrow__ , __leaf__));
# 299 "/usr/include/bits/socket.h" 3 4
enum
    SCM_RIGHTS = 0x01
# 345 "/usr/include/bits/socket.h" 3 4
# 1 "/usr/include/asm/socket.h" 1 3 4
# 1 "/usr/include/asm-generic/socket.h" 1 3 4
# 1 "/usr/include/asm/sockios.h" 1 3 4
# 1 "/usr/include/asm-generic/sockios.h" 1 3 4
# 1 "/usr/include/asm/sockios.h" 2 3 4
# 5 "/usr/include/asm-generic/socket.h" 2 3 4
# 1 "/usr/include/asm/socket.h" 2 3 4
# 346 "/usr/include/bits/socket.h" 2 3 4
# 379 "/usr/include/bits/socket.h" 3 4
struct linger
    int l_onoff;
    int l_linger;
# 39 "/usr/include/sys/socket.h" 2 3 4
struct osockaddr
    unsigned short int sa_family;
    unsigned char sa_data[14];
enum
  SHUT_RD = 0,
  SHUT_WR,
  SHUT_RDWR
# 113 "/usr/include/sys/socket.h" 3 4
extern int socket (int __domain, int __type, int __protocol) __attribute__ ((__nothrow__ , __leaf__));
extern int socketpair (int __domain, int __type, int __protocol,
         int __fds[2]) __attribute__ ((__nothrow__ , __leaf__));
extern int bind (int __fd, const struct sockaddr * __addr, socklen_t __len)
extern int getsockname (int __fd, struct sockaddr *__restrict __addr,
   socklen_t *__restrict __len) __attribute__ ((__nothrow__ , __leaf__));
# 137 "/usr/include/sys/socket.h" 3 4
extern int connect (int __fd, const struct sockaddr * __addr, socklen_t __len);
extern int getpeername (int __fd, struct sockaddr *__restrict __addr,
extern ssize_t send (int __fd, const void *__buf, size_t __n, int __flags);
extern ssize_t recv (int __fd, void *__buf, size_t __n, int __flags);
extern ssize_t sendto (int __fd, const void *__buf, size_t __n,
         int __flags, const struct sockaddr * __addr,
         socklen_t __addr_len);
# 174 "/usr/include/sys/socket.h" 3 4
extern ssize_t recvfrom (int __fd, void *__restrict __buf, size_t __n,
    int __flags, struct sockaddr *__restrict __addr,
    socklen_t *__restrict __addr_len);
extern ssize_t sendmsg (int __fd, const struct msghdr *__message,
   int __flags);
# 202 "/usr/include/sys/socket.h" 3 4
extern ssize_t recvmsg (int __fd, struct msghdr *__message, int __flags);
# 219 "/usr/include/sys/socket.h" 3 4
extern int getsockopt (int __fd, int __level, int __optname,
         void *__restrict __optval,
         socklen_t *__restrict __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int setsockopt (int __fd, int __level, int __optname,
         const void *__optval, socklen_t __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int listen (int __fd, int __n) __attribute__ ((__nothrow__ , __leaf__));
# 243 "/usr/include/sys/socket.h" 3 4
extern int accept (int __fd, struct sockaddr *__restrict __addr,
# 261 "/usr/include/sys/socket.h" 3 4
extern int shutdown (int __fd, int __how) __attribute__ ((__nothrow__ , __leaf__));
extern int sockatmark (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int isfdtype (int __fd, int __fdtype) __attribute__ ((__nothrow__ , __leaf__));
# 283 "/usr/include/sys/socket.h" 3 4
            Defined "HAVE_SYS_SOCKET_H" to "1"
Checking for header: sys/types.h
stdout:
# 1 "<built-in>"
# 25 "/usr/include/sys/types.h" 3 4
# 26 "/usr/include/sys/types.h" 2 3 4
# 30 "/usr/include/sys/types.h" 2 3 4
# 216 "/usr/include/sys/types.h" 3 4
# 28 "/usr/include/bits/byteswap.h" 3 4
# 217 "/usr/include/sys/types.h" 2 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
            Defined "HAVE_SYS_TYPES_H" to "1"
Checking for header: malloc.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/malloc.h" 1 3 4
# 22 "/usr/include/malloc.h" 3 4
# 23 "/usr/include/malloc.h" 2 3 4
# 147 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef long int ptrdiff_t;
# 324 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef int wchar_t;
# 24 "/usr/include/malloc.h" 2 3 4
# 1 "/usr/include/stdio.h" 1 3 4
# 29 "/usr/include/stdio.h" 3 4
# 34 "/usr/include/stdio.h" 2 3 4
# 36 "/usr/include/stdio.h" 2 3 4
# 44 "/usr/include/stdio.h" 3 4
struct _IO_FILE;
typedef struct _IO_FILE FILE;
# 64 "/usr/include/stdio.h" 3 4
typedef struct _IO_FILE __FILE;
# 74 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/libio.h" 1 3 4
# 31 "/usr/include/libio.h" 3 4
# 1 "/usr/include/_G_config.h" 1 3 4
# 15 "/usr/include/_G_config.h" 3 4
# 16 "/usr/include/_G_config.h" 2 3 4
# 1 "/usr/include/wchar.h" 1 3 4
# 82 "/usr/include/wchar.h" 3 4
typedef struct
  int __count;
  union
    unsigned int __wch;
    char __wchb[4];
  } __value;
} __mbstate_t;
# 21 "/usr/include/_G_config.h" 2 3 4
typedef struct
  __off_t __pos;
  __mbstate_t __state;
} _G_fpos_t;
typedef struct
  __off64_t __pos;
} _G_fpos64_t;
# 32 "/usr/include/libio.h" 2 3 4
# 49 "/usr/include/libio.h" 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdarg.h" 1 3 4
# 40 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdarg.h" 3 4
typedef __builtin_va_list __gnuc_va_list;
# 50 "/usr/include/libio.h" 2 3 4
# 144 "/usr/include/libio.h" 3 4
struct _IO_jump_t; struct _IO_FILE;
# 154 "/usr/include/libio.h" 3 4
typedef void _IO_lock_t;
struct _IO_marker {
  struct _IO_marker *_next;
  struct _IO_FILE *_sbuf;
  int _pos;
# 177 "/usr/include/libio.h" 3 4
enum __codecvt_result
  __codecvt_ok,
  __codecvt_partial,
  __codecvt_error,
  __codecvt_noconv
# 245 "/usr/include/libio.h" 3 4
struct _IO_FILE {
  int _flags;
  char* _IO_read_ptr;
  char* _IO_read_end;
  char* _IO_read_base;
  char* _IO_write_base;
  char* _IO_write_ptr;
  char* _IO_write_end;
  char* _IO_buf_base;
  char* _IO_buf_end;
  char *_IO_save_base;
  char *_IO_backup_base;
  char *_IO_save_end;
  struct _IO_marker *_markers;
  struct _IO_FILE *_chain;
  int _fileno;
  int _flags2;
  __off_t _old_offset;
  unsigned short _cur_column;
  signed char _vtable_offset;
  char _shortbuf[1];
  _IO_lock_t *_lock;
# 293 "/usr/include/libio.h" 3 4
  __off64_t _offset;
# 302 "/usr/include/libio.h" 3 4
  void *__pad1;
  void *__pad2;
  void *__pad3;
  void *__pad4;
  size_t __pad5;
  int _mode;
  char _unused2[15 * sizeof (int) - 4 * sizeof (void *) - sizeof (size_t)];
typedef struct _IO_FILE _IO_FILE;
struct _IO_FILE_plus;
extern struct _IO_FILE_plus _IO_2_1_stdin_;
extern struct _IO_FILE_plus _IO_2_1_stdout_;
extern struct _IO_FILE_plus _IO_2_1_stderr_;
# 338 "/usr/include/libio.h" 3 4
typedef __ssize_t __io_read_fn (void *__cookie, char *__buf, size_t __nbytes);
typedef __ssize_t __io_write_fn (void *__cookie, const char *__buf,
     size_t __n);
typedef int __io_seek_fn (void *__cookie, __off64_t *__pos, int __w);
typedef int __io_close_fn (void *__cookie);
# 390 "/usr/include/libio.h" 3 4
extern int __underflow (_IO_FILE *);
extern int __uflow (_IO_FILE *);
extern int __overflow (_IO_FILE *, int);
# 434 "/usr/include/libio.h" 3 4
extern int _IO_getc (_IO_FILE *__fp);
extern int _IO_putc (int __c, _IO_FILE *__fp);
extern int _IO_feof (_IO_FILE *__fp) __attribute__ ((__nothrow__ , __leaf__));
extern int _IO_ferror (_IO_FILE *__fp) __attribute__ ((__nothrow__ , __leaf__));
extern int _IO_peekc_locked (_IO_FILE *__fp);
extern void _IO_flockfile (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
extern void _IO_funlockfile (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
extern int _IO_ftrylockfile (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
# 464 "/usr/include/libio.h" 3 4
extern int _IO_vfscanf (_IO_FILE * __restrict, const char * __restrict,
   __gnuc_va_list, int *__restrict);
extern int _IO_vfprintf (_IO_FILE *__restrict, const char *__restrict,
    __gnuc_va_list);
extern __ssize_t _IO_padn (_IO_FILE *, int, __ssize_t);
extern size_t _IO_sgetn (_IO_FILE *, void *, size_t);
extern __off64_t _IO_seekoff (_IO_FILE *, __off64_t, int, int);
extern __off64_t _IO_seekpos (_IO_FILE *, __off64_t, int);
extern void _IO_free_backup_area (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
# 75 "/usr/include/stdio.h" 2 3 4
typedef __gnuc_va_list va_list;
# 90 "/usr/include/stdio.h" 3 4
# 102 "/usr/include/stdio.h" 3 4
typedef _G_fpos_t fpos_t;
# 164 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/bits/stdio_lim.h" 1 3 4
# 165 "/usr/include/stdio.h" 2 3 4
extern struct _IO_FILE *stdin;
extern struct _IO_FILE *stdout;
extern struct _IO_FILE *stderr;
extern int remove (const char *__filename) __attribute__ ((__nothrow__ , __leaf__));
extern int rename (const char *__old, const char *__new) __attribute__ ((__nothrow__ , __leaf__));
extern int renameat (int __oldfd, const char *__old, int __newfd,
extern FILE *tmpfile (void) ;
# 209 "/usr/include/stdio.h" 3 4
extern char *tmpnam (char *__s) __attribute__ ((__nothrow__ , __leaf__)) ;
extern char *tmpnam_r (char *__s) __attribute__ ((__nothrow__ , __leaf__)) ;
# 227 "/usr/include/stdio.h" 3 4
extern char *tempnam (const char *__dir, const char *__pfx)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int fclose (FILE *__stream);
extern int fflush (FILE *__stream);
# 252 "/usr/include/stdio.h" 3 4
extern int fflush_unlocked (FILE *__stream);
# 266 "/usr/include/stdio.h" 3 4
extern FILE *fopen (const char *__restrict __filename,
      const char *__restrict __modes) ;
extern FILE *freopen (const char *__restrict __filename,
        const char *__restrict __modes,
        FILE *__restrict __stream) ;
# 295 "/usr/include/stdio.h" 3 4
# 306 "/usr/include/stdio.h" 3 4
extern FILE *fdopen (int __fd, const char *__modes) __attribute__ ((__nothrow__ , __leaf__)) ;
# 319 "/usr/include/stdio.h" 3 4
extern FILE *fmemopen (void *__s, size_t __len, const char *__modes)
extern FILE *open_memstream (char **__bufloc, size_t *__sizeloc) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void setbuf (FILE *__restrict __stream, char *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__));
extern int setvbuf (FILE *__restrict __stream, char *__restrict __buf,
      int __modes, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern void setbuffer (FILE *__restrict __stream, char *__restrict __buf,
         size_t __size) __attribute__ ((__nothrow__ , __leaf__));
extern void setlinebuf (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int fprintf (FILE *__restrict __stream,
      const char *__restrict __format, ...);
extern int printf (const char *__restrict __format, ...);
extern int sprintf (char *__restrict __s,
      const char *__restrict __format, ...) __attribute__ ((__nothrow__));
extern int vfprintf (FILE *__restrict __s, const char *__restrict __format,
       __gnuc_va_list __arg);
extern int vprintf (const char *__restrict __format, __gnuc_va_list __arg);
extern int vsprintf (char *__restrict __s, const char *__restrict __format,
       __gnuc_va_list __arg) __attribute__ ((__nothrow__));
extern int snprintf (char *__restrict __s, size_t __maxlen,
     __attribute__ ((__nothrow__)) __attribute__ ((__format__ (__printf__, 3, 4)));
extern int vsnprintf (char *__restrict __s, size_t __maxlen,
     __attribute__ ((__nothrow__)) __attribute__ ((__format__ (__printf__, 3, 0)));
# 412 "/usr/include/stdio.h" 3 4
extern int vdprintf (int __fd, const char *__restrict __fmt,
     __attribute__ ((__format__ (__printf__, 2, 0)));
extern int dprintf (int __fd, const char *__restrict __fmt, ...)
     __attribute__ ((__format__ (__printf__, 2, 3)));
extern int fscanf (FILE *__restrict __stream,
     const char *__restrict __format, ...) ;
extern int scanf (const char *__restrict __format, ...) ;
extern int sscanf (const char *__restrict __s,
     const char *__restrict __format, ...) __attribute__ ((__nothrow__ , __leaf__));
# 443 "/usr/include/stdio.h" 3 4
extern int fscanf (FILE *__restrict __stream, const char *__restrict __format, ...) __asm__ ("" "__isoc99_fscanf")
extern int scanf (const char *__restrict __format, ...) __asm__ ("" "__isoc99_scanf")
extern int sscanf (const char *__restrict __s, const char *__restrict __format, ...) __asm__ ("" "__isoc99_sscanf") __attribute__ ((__nothrow__ , __leaf__))
# 463 "/usr/include/stdio.h" 3 4
extern int vfscanf (FILE *__restrict __s, const char *__restrict __format,
     __attribute__ ((__format__ (__scanf__, 2, 0))) ;
extern int vscanf (const char *__restrict __format, __gnuc_va_list __arg)
     __attribute__ ((__format__ (__scanf__, 1, 0))) ;
extern int vsscanf (const char *__restrict __s,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__format__ (__scanf__, 2, 0)));
# 494 "/usr/include/stdio.h" 3 4
extern int vfscanf (FILE *__restrict __s, const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vfscanf")
extern int vscanf (const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vscanf")
extern int vsscanf (const char *__restrict __s, const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vsscanf") __attribute__ ((__nothrow__ , __leaf__))
# 522 "/usr/include/stdio.h" 3 4
extern int fgetc (FILE *__stream);
extern int getc (FILE *__stream);
extern int getchar (void);
# 550 "/usr/include/stdio.h" 3 4
extern int getc_unlocked (FILE *__stream);
extern int getchar_unlocked (void);
# 561 "/usr/include/stdio.h" 3 4
extern int fgetc_unlocked (FILE *__stream);
extern int fputc (int __c, FILE *__stream);
extern int putc (int __c, FILE *__stream);
extern int putchar (int __c);
# 594 "/usr/include/stdio.h" 3 4
extern int fputc_unlocked (int __c, FILE *__stream);
extern int putc_unlocked (int __c, FILE *__stream);
extern int putchar_unlocked (int __c);
extern int getw (FILE *__stream);
extern int putw (int __w, FILE *__stream);
extern char *fgets (char *__restrict __s, int __n, FILE *__restrict __stream)
# 638 "/usr/include/stdio.h" 3 4
extern char *gets (char *__s) __attribute__ ((__deprecated__));
# 665 "/usr/include/stdio.h" 3 4
extern __ssize_t __getdelim (char **__restrict __lineptr,
          size_t *__restrict __n, int __delimiter,
extern __ssize_t getdelim (char **__restrict __lineptr,
extern __ssize_t getline (char **__restrict __lineptr,
extern int fputs (const char *__restrict __s, FILE *__restrict __stream);
extern int puts (const char *__s);
extern int ungetc (int __c, FILE *__stream);
extern size_t fread (void *__restrict __ptr, size_t __size,
       size_t __n, FILE *__restrict __stream) ;
extern size_t fwrite (const void *__restrict __ptr, size_t __size,
        size_t __n, FILE *__restrict __s);
# 737 "/usr/include/stdio.h" 3 4
extern size_t fread_unlocked (void *__restrict __ptr, size_t __size,
extern size_t fwrite_unlocked (const void *__restrict __ptr, size_t __size,
          size_t __n, FILE *__restrict __stream);
extern int fseek (FILE *__stream, long int __off, int __whence);
extern long int ftell (FILE *__stream) ;
extern void rewind (FILE *__stream);
# 773 "/usr/include/stdio.h" 3 4
extern int fseeko (FILE *__stream, __off_t __off, int __whence);
extern __off_t ftello (FILE *__stream) ;
# 792 "/usr/include/stdio.h" 3 4
extern int fgetpos (FILE *__restrict __stream, fpos_t *__restrict __pos);
extern int fsetpos (FILE *__stream, const fpos_t *__pos);
# 815 "/usr/include/stdio.h" 3 4
# 824 "/usr/include/stdio.h" 3 4
extern void clearerr (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int feof (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int ferror (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void clearerr_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int feof_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int ferror_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void perror (const char *__s);
# 1 "/usr/include/bits/sys_errlist.h" 1 3 4
# 26 "/usr/include/bits/sys_errlist.h" 3 4
extern int sys_nerr;
extern const char *const sys_errlist[];
# 854 "/usr/include/stdio.h" 2 3 4
extern int fileno (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int fileno_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
# 872 "/usr/include/stdio.h" 3 4
extern FILE *popen (const char *__command, const char *__modes) ;
extern int pclose (FILE *__stream);
extern char *ctermid (char *__s) __attribute__ ((__nothrow__ , __leaf__));
# 912 "/usr/include/stdio.h" 3 4
extern void flockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int ftrylockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void funlockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
# 942 "/usr/include/stdio.h" 3 4
# 25 "/usr/include/malloc.h" 2 3 4
# 35 "/usr/include/malloc.h" 3 4
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void cfree (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void *memalign (size_t __alignment, size_t __size)
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *pvalloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *(*__morecore) (ptrdiff_t __size);
extern void *__default_morecore (ptrdiff_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__));
struct mallinfo
  int arena;
  int ordblks;
  int smblks;
  int hblks;
  int hblkhd;
  int usmblks;
  int fsmblks;
  int uordblks;
  int fordblks;
  int keepcost;
extern struct mallinfo mallinfo (void) __attribute__ ((__nothrow__ , __leaf__));
# 121 "/usr/include/malloc.h" 3 4
extern int mallopt (int __param, int __val) __attribute__ ((__nothrow__ , __leaf__));
extern int malloc_trim (size_t __pad) __attribute__ ((__nothrow__ , __leaf__));
extern size_t malloc_usable_size (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void malloc_stats (void) __attribute__ ((__nothrow__ , __leaf__));
extern int malloc_info (int __options, FILE *__fp) __attribute__ ((__nothrow__ , __leaf__));
extern void *malloc_get_state (void) __attribute__ ((__nothrow__ , __leaf__));
extern int malloc_set_state (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void (*volatile __malloc_initialize_hook) (void)
extern void (*volatile __free_hook) (void *__ptr,
                                                   const void *)
extern void *(*volatile __malloc_hook)(size_t __size,
                                                     const void *)
extern void *(*volatile __realloc_hook)(void *__ptr,
                                                      size_t __size,
                                                      const void *)
extern void *(*volatile __memalign_hook)(size_t __alignment,
                                                       size_t __size,
                                                       const void *)
extern void (*volatile __after_morecore_hook) (void);
extern void __malloc_check_init (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
            Defined "HAVE_MALLOC_H" to "1"
Checking for header: time.h
stdout:
# 1 "<built-in>"
# 27 "/usr/include/time.h" 3 4
# 28 "/usr/include/time.h" 2 3 4
# 38 "/usr/include/time.h" 2 3 4
# 42 "/usr/include/time.h" 2 3 4
# 55 "/usr/include/time.h" 3 4
# 56 "/usr/include/time.h" 2 3 4
struct timespec
    __time_t tv_sec;
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
  long int tm_gmtoff;
  const char *tm_zone;
struct itimerspec
    struct timespec it_interval;
    struct timespec it_value;
struct sigevent;
# 186 "/usr/include/time.h" 3 4
extern clock_t clock (void) __attribute__ ((__nothrow__ , __leaf__));
extern time_t time (time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern double difftime (time_t __time1, time_t __time0)
extern time_t mktime (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern size_t strftime (char *__restrict __s, size_t __maxsize,
   const struct tm *__restrict __tp) __attribute__ ((__nothrow__ , __leaf__));
# 221 "/usr/include/time.h" 3 4
# 1 "/usr/include/xlocale.h" 1 3 4
# 27 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 222 "/usr/include/time.h" 2 3 4
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
     const struct tm *__restrict __tp,
     __locale_t __loc) __attribute__ ((__nothrow__ , __leaf__));
# 236 "/usr/include/time.h" 3 4
extern struct tm *gmtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *localtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *gmtime_r (const time_t *__restrict __timer,
extern struct tm *localtime_r (const time_t *__restrict __timer,
extern char *asctime (const struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern char *asctime_r (const struct tm *__restrict __tp,
extern char *ctime_r (const time_t *__restrict __timer,
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daylight;
extern long int timezone;
extern int stime (const time_t *__when) __attribute__ ((__nothrow__ , __leaf__));
# 319 "/usr/include/time.h" 3 4
extern time_t timegm (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern time_t timelocal (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int dysize (int __year) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 334 "/usr/include/time.h" 3 4
extern int nanosleep (const struct timespec *__requested_time,
        struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
       const struct timespec *__req,
       struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_create (clockid_t __clock_id,
    struct sigevent *__restrict __evp,
    timer_t *__restrict __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_delete (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_settime (timer_t __timerid, int __flags,
     const struct itimerspec *__restrict __value,
     struct itimerspec *__restrict __ovalue) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
extern int timer_getoverrun (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
# 430 "/usr/include/time.h" 3 4
            Defined "HAVE_TIME_H" to "1"
Checking for header: Direct.h
stdout:
# 1 "<built-in>"
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2stderr:
/tmp/petsc-lhuj9c/config.headers/conftest.c:3:20: fatal error: Direct.h: No such file or directory
 #include <Direct.h>
compilation terminated.
Source:
#include <Direct.h>
Checking for header: Ws2tcpip.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-lhuj9c/config.headers/conftest.c:3:22: fatal error: Ws2tcpip.h: No such file or directory
 #include <Ws2tcpip.h>
Source:
Checking for header: endian.h
stdout:
# 1 "<built-in>"
# 21 "/usr/include/endian.h" 3 4
# 22 "/usr/include/endian.h" 2 3 4
# 27 "/usr/include/bits/byteswap.h" 3 4
# 28 "/usr/include/bits/byteswap.h" 2 3 4
            Defined "HAVE_ENDIAN_H" to "1"
Checking for header: ieeefp.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-lhuj9c/config.headers/conftest.c:3:20: fatal error: ieeefp.h: No such file or directory
 #include <ieeefp.h>
Source:
#include <ieeefp.h>
Checking for header: strings.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/strings.h" 1 3 4
# 26 "/usr/include/strings.h" 3 4
# 27 "/usr/include/strings.h" 2 3 4
# 29 "/usr/include/strings.h" 2 3 4
# 39 "/usr/include/strings.h" 3 4
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__));
extern void bcopy (const void *__src, void *__dest, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
# 76 "/usr/include/strings.h" 3 4
extern char *index (const char *__s, int __c)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
# 104 "/usr/include/strings.h" 3 4
extern char *rindex (const char *__s, int __c)
extern int ffs (int __i) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((const));
extern int strcasecmp (const char *__s1, const char *__s2)
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
} *__locale_t;
# 128 "/usr/include/strings.h" 2 3 4
extern int strcasecmp_l (const char *__s1, const char *__s2, __locale_t __loc)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern int strncasecmp_l (const char *__s1, const char *__s2,
     size_t __n, __locale_t __loc)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 4)));
            Defined "HAVE_STRINGS_H" to "1"
Checking for header: sched.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sched.h" 1 3 4
# 22 "/usr/include/sched.h" 3 4
# 23 "/usr/include/sched.h" 2 3 4
# 26 "/usr/include/sched.h" 2 3 4
# 29 "/usr/include/sched.h" 2 3 4
struct timespec
    __time_t tv_sec;
# 35 "/usr/include/sched.h" 2 3 4
# 1 "/usr/include/bits/sched.h" 1 3 4
# 72 "/usr/include/bits/sched.h" 3 4
struct sched_param
    int __sched_priority;
# 95 "/usr/include/bits/sched.h" 3 4
struct __sched_param
# 118 "/usr/include/bits/sched.h" 3 4
typedef unsigned long int __cpu_mask;
typedef struct
  __cpu_mask __bits[1024 / (8 * sizeof (__cpu_mask))];
} cpu_set_t;
# 201 "/usr/include/bits/sched.h" 3 4
extern int __sched_cpucount (size_t __setsize, const cpu_set_t *__setp)
extern cpu_set_t *__sched_cpualloc (size_t __count) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void __sched_cpufree (cpu_set_t *__set) __attribute__ ((__nothrow__ , __leaf__));
# 44 "/usr/include/sched.h" 2 3 4
extern int sched_setparam (__pid_t __pid, const struct sched_param *__param)
extern int sched_getparam (__pid_t __pid, struct sched_param *__param) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_setscheduler (__pid_t __pid, int __policy,
          const struct sched_param *__param) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_getscheduler (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_yield (void) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_get_priority_max (int __algorithm) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_get_priority_min (int __algorithm) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_rr_get_interval (__pid_t __pid, struct timespec *__t) __attribute__ ((__nothrow__ , __leaf__));
# 126 "/usr/include/sched.h" 3 4
            Defined "HAVE_SCHED_H" to "1"
Checking for header: cxxabi.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-lhuj9c/config.headers/conftest.c:3:20: fatal error: cxxabi.h: No such file or directory
 #include <cxxabi.h>
Source:
#include <cxxabi.h>
Checking for header: sys/systeminfo.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-lhuj9c/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory
 #include <sys/systeminfo.h>
Source:
Checking for header: dos.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-lhuj9c/config.headers/conftest.c:3:17: fatal error: dos.h: No such file or directory
 #include <dos.h>
Source:
#include <dos.h>
Checking for header: WindowsX.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-lhuj9c/config.headers/conftest.c:3:22: fatal error: WindowsX.h: No such file or directory
 #include <WindowsX.h>
Source:
Checking for header: sys/sysinfo.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/sysinfo.h" 1 3 4
# 21 "/usr/include/sys/sysinfo.h" 3 4
# 22 "/usr/include/sys/sysinfo.h" 2 3 4
# 1 "/usr/include/linux/kernel.h" 1 3 4
# 1 "/usr/include/linux/sysinfo.h" 1 3 4
# 1 "/usr/include/linux/types.h" 1 3 4
# 1 "/usr/include/asm/types.h" 1 3 4
# 1 "/usr/include/asm-generic/types.h" 1 3 4
# 1 "/usr/include/asm-generic/int-ll64.h" 1 3 4
# 11 "/usr/include/asm-generic/int-ll64.h" 3 4
# 1 "/usr/include/asm/bitsperlong.h" 1 3 4
# 10 "/usr/include/asm/bitsperlong.h" 3 4
# 1 "/usr/include/asm-generic/bitsperlong.h" 1 3 4
# 11 "/usr/include/asm/bitsperlong.h" 2 3 4
# 12 "/usr/include/asm-generic/int-ll64.h" 2 3 4
typedef __signed__ char __s8;
typedef unsigned char __u8;
typedef __signed__ short __s16;
typedef unsigned short __u16;
typedef __signed__ int __s32;
typedef unsigned int __u32;
__extension__ typedef __signed__ long long __s64;
__extension__ typedef unsigned long long __u64;
# 7 "/usr/include/asm-generic/types.h" 2 3 4
# 5 "/usr/include/asm/types.h" 2 3 4
# 5 "/usr/include/linux/types.h" 2 3 4
# 1 "/usr/include/linux/posix_types.h" 1 3 4
# 1 "/usr/include/linux/stddef.h" 1 3 4
# 5 "/usr/include/linux/posix_types.h" 2 3 4
# 24 "/usr/include/linux/posix_types.h" 3 4
typedef struct {
 unsigned long fds_bits[1024 / (8 * sizeof(long))];
} __kernel_fd_set;
typedef void (*__kernel_sighandler_t)(int);
typedef int __kernel_key_t;
typedef int __kernel_mqd_t;
# 1 "/usr/include/asm/posix_types.h" 1 3 4
# 1 "/usr/include/asm/posix_types_64.h" 1 3 4
# 10 "/usr/include/asm/posix_types_64.h" 3 4
typedef unsigned short __kernel_old_uid_t;
typedef unsigned short __kernel_old_gid_t;
typedef unsigned long __kernel_old_dev_t;
# 1 "/usr/include/asm-generic/posix_types.h" 1 3 4
# 14 "/usr/include/asm-generic/posix_types.h" 3 4
typedef long __kernel_long_t;
typedef unsigned long __kernel_ulong_t;
typedef __kernel_ulong_t __kernel_ino_t;
typedef unsigned int __kernel_mode_t;
typedef int __kernel_pid_t;
typedef int __kernel_ipc_pid_t;
typedef unsigned int __kernel_uid_t;
typedef unsigned int __kernel_gid_t;
typedef __kernel_long_t __kernel_suseconds_t;
typedef int __kernel_daddr_t;
typedef unsigned int __kernel_uid32_t;
typedef unsigned int __kernel_gid32_t;
# 71 "/usr/include/asm-generic/posix_types.h" 3 4
typedef __kernel_ulong_t __kernel_size_t;
typedef __kernel_long_t __kernel_ssize_t;
typedef __kernel_long_t __kernel_ptrdiff_t;
typedef struct {
 int val[2];
} __kernel_fsid_t;
typedef __kernel_long_t __kernel_off_t;
typedef long long __kernel_loff_t;
typedef __kernel_long_t __kernel_time_t;
typedef __kernel_long_t __kernel_clock_t;
typedef int __kernel_timer_t;
typedef int __kernel_clockid_t;
typedef char * __kernel_caddr_t;
typedef unsigned short __kernel_uid16_t;
typedef unsigned short __kernel_gid16_t;
# 18 "/usr/include/asm/posix_types_64.h" 2 3 4
# 7 "/usr/include/asm/posix_types.h" 2 3 4
# 36 "/usr/include/linux/posix_types.h" 2 3 4
# 9 "/usr/include/linux/types.h" 2 3 4
# 27 "/usr/include/linux/types.h" 3 4
typedef __u16 __le16;
typedef __u16 __be16;
typedef __u32 __le32;
typedef __u32 __be32;
typedef __u64 __le64;
typedef __u64 __be64;
typedef __u16 __sum16;
typedef __u32 __wsum;
# 5 "/usr/include/linux/sysinfo.h" 2 3 4
struct sysinfo {
 __kernel_long_t uptime;
 __kernel_ulong_t loads[3];
 __kernel_ulong_t totalram;
 __kernel_ulong_t freeram;
 __kernel_ulong_t sharedram;
 __kernel_ulong_t bufferram;
 __kernel_ulong_t totalswap;
 __kernel_ulong_t freeswap;
 __u16 procs;
 __u16 pad;
 __kernel_ulong_t totalhigh;
 __kernel_ulong_t freehigh;
 __u32 mem_unit;
 char _f[20-2*sizeof(__kernel_ulong_t)-sizeof(__u32)];
# 5 "/usr/include/linux/kernel.h" 2 3 4
# 25 "/usr/include/sys/sysinfo.h" 2 3 4
extern int sysinfo (struct sysinfo *__info) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs_conf (void) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_phys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_avphys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
            Defined "HAVE_SYS_SYSINFO_H" to "1"
Checking for header: sys/wait.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/wait.h" 1 3 4
# 25 "/usr/include/sys/wait.h" 3 4
# 26 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/signal.h" 1 3 4
# 30 "/usr/include/signal.h" 3 4
typedef struct
  } __sigset_t;
# 102 "/usr/include/bits/sigset.h" 3 4
extern int __sigismember (const __sigset_t *, int);
extern int __sigaddset (__sigset_t *, int);
extern int __sigdelset (__sigset_t *, int);
# 33 "/usr/include/signal.h" 2 3 4
typedef __sig_atomic_t sig_atomic_t;
# 57 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/signum.h" 1 3 4
# 58 "/usr/include/signal.h" 2 3 4
struct timespec
    __time_t tv_sec;
# 76 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/siginfo.h" 1 3 4
# 24 "/usr/include/bits/siginfo.h" 3 4
# 25 "/usr/include/bits/siginfo.h" 2 3 4
typedef union sigval
    int sival_int;
    void *sival_ptr;
  } sigval_t;
# 58 "/usr/include/bits/siginfo.h" 3 4
typedef __clock_t __sigchld_clock_t;
typedef struct
    int si_signo;
    int si_errno;
    int si_code;
    union
 int _pad[((128 / sizeof (int)) - 4)];
 struct
     __pid_t si_pid;
     __uid_t si_uid;
   } _kill;
 struct
     int si_tid;
     int si_overrun;
     sigval_t si_sigval;
   } _timer;
 struct
     __pid_t si_pid;
     __uid_t si_uid;
     sigval_t si_sigval;
   } _rt;
 struct
     __pid_t si_pid;
     __uid_t si_uid;
     int si_status;
     __sigchld_clock_t si_utime;
     __sigchld_clock_t si_stime;
   } _sigchld;
 struct
     void *si_addr;
     short int si_addr_lsb;
   } _sigfault;
 struct
     long int si_band;
     int si_fd;
   } _sigpoll;
 struct
     void *_call_addr;
     int _syscall;
     unsigned int _arch;
   } _sigsys;
      } _sifields;
  } siginfo_t ;
# 153 "/usr/include/bits/siginfo.h" 3 4
enum
  SI_ASYNCNL = -60,
  SI_TKILL = -6,
  SI_SIGIO,
  SI_ASYNCIO,
  SI_MESGQ,
  SI_TIMER,
  SI_QUEUE,
  SI_USER,
  SI_KERNEL = 0x80
enum
  ILL_ILLOPC = 1,
  ILL_ILLOPN,
  ILL_ILLADR,
  ILL_ILLTRP,
  ILL_PRVOPC,
  ILL_PRVREG,
  ILL_COPROC,
  ILL_BADSTK
enum
  FPE_INTDIV = 1,
  FPE_INTOVF,
  FPE_FLTDIV,
  FPE_FLTOVF,
  FPE_FLTUND,
  FPE_FLTRES,
  FPE_FLTINV,
  FPE_FLTSUB
enum
  SEGV_MAPERR = 1,
  SEGV_ACCERR
enum
  BUS_ADRALN = 1,
  BUS_ADRERR,
  BUS_OBJERR,
  BUS_MCEERR_AR,
  BUS_MCEERR_AO
# 257 "/usr/include/bits/siginfo.h" 3 4
enum
  CLD_EXITED = 1,
  CLD_KILLED,
  CLD_DUMPED,
  CLD_TRAPPED,
  CLD_STOPPED,
  CLD_CONTINUED
enum
  POLL_IN = 1,
  POLL_OUT,
  POLL_MSG,
  POLL_ERR,
  POLL_PRI,
  POLL_HUP
# 309 "/usr/include/bits/siginfo.h" 3 4
typedef struct sigevent
    sigval_t sigev_value;
    int sigev_signo;
    int sigev_notify;
    union
 int _pad[((64 / sizeof (int)) - 4)];
 __pid_t _tid;
 struct
     void (*_function) (sigval_t);
     pthread_attr_t *_attribute;
   } _sigev_thread;
      } _sigev_un;
  } sigevent_t;
enum
  SIGEV_SIGNAL = 0,
  SIGEV_NONE,
  SIGEV_THREAD,
  SIGEV_THREAD_ID = 4
# 81 "/usr/include/signal.h" 2 3 4
typedef void (*__sighandler_t) (int);
extern __sighandler_t __sysv_signal (int __sig, __sighandler_t __handler)
# 100 "/usr/include/signal.h" 3 4
extern __sighandler_t signal (int __sig, __sighandler_t __handler)
# 114 "/usr/include/signal.h" 3 4
# 127 "/usr/include/signal.h" 3 4
extern int kill (__pid_t __pid, int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern int killpg (__pid_t __pgrp, int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern int raise (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern __sighandler_t ssignal (int __sig, __sighandler_t __handler)
extern int gsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern void psignal (int __sig, const char *__s);
extern void psiginfo (const siginfo_t *__pinfo, const char *__s);
# 167 "/usr/include/signal.h" 3 4
extern int __sigpause (int __sig_or_mask, int __is_sig);
# 189 "/usr/include/signal.h" 3 4
extern int sigblock (int __mask) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
extern int sigsetmask (int __mask) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
extern int siggetmask (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
# 209 "/usr/include/signal.h" 3 4
typedef __sighandler_t sig_t;
extern int sigemptyset (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigfillset (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigaddset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigdelset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigismember (const sigset_t *__set, int __signo)
# 245 "/usr/include/signal.h" 3 4
# 1 "/usr/include/bits/sigaction.h" 1 3 4
# 24 "/usr/include/bits/sigaction.h" 3 4
struct sigaction
    union
 __sighandler_t sa_handler;
 void (*sa_sigaction) (int, siginfo_t *, void *);
    __sigaction_handler;
    __sigset_t sa_mask;
    int sa_flags;
    void (*sa_restorer) (void);
# 246 "/usr/include/signal.h" 2 3 4
extern int sigprocmask (int __how, const sigset_t *__restrict __set,
   sigset_t *__restrict __oset) __attribute__ ((__nothrow__ , __leaf__));
extern int sigsuspend (const sigset_t *__set) __attribute__ ((__nonnull__ (1)));
extern int sigaction (int __sig, const struct sigaction *__restrict __act,
        struct sigaction *__restrict __oact) __attribute__ ((__nothrow__ , __leaf__));
extern int sigpending (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigwait (const sigset_t *__restrict __set, int *__restrict __sig)
     __attribute__ ((__nonnull__ (1, 2)));
extern int sigwaitinfo (const sigset_t *__restrict __set,
   siginfo_t *__restrict __info) __attribute__ ((__nonnull__ (1)));
extern int sigtimedwait (const sigset_t *__restrict __set,
    siginfo_t *__restrict __info,
    const struct timespec *__restrict __timeout)
extern int sigqueue (__pid_t __pid, int __sig, const union sigval __val)
# 303 "/usr/include/signal.h" 3 4
extern const char *const _sys_siglist[65];
extern const char *const sys_siglist[65];
struct sigvec
    __sighandler_t sv_handler;
    int sv_mask;
    int sv_flags;
# 327 "/usr/include/signal.h" 3 4
extern int sigvec (int __sig, const struct sigvec *__vec,
     struct sigvec *__ovec) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/bits/sigcontext.h" 1 3 4
# 29 "/usr/include/bits/sigcontext.h" 3 4
struct _fpx_sw_bytes
  __uint32_t magic1;
  __uint32_t extended_size;
  __uint64_t xstate_bv;
  __uint32_t xstate_size;
  __uint32_t padding[7];
struct _fpreg
  unsigned short significand[4];
  unsigned short exponent;
struct _fpxreg
  unsigned short padding[3];
struct _xmmreg
  __uint32_t element[4];
# 121 "/usr/include/bits/sigcontext.h" 3 4
struct _fpstate
  __uint16_t cwd;
  __uint16_t swd;
  __uint16_t ftw;
  __uint16_t fop;
  __uint64_t rip;
  __uint64_t rdp;
  __uint32_t mxcsr;
  __uint32_t mxcr_mask;
  struct _fpxreg _st[8];
  struct _xmmreg _xmm[16];
  __uint32_t padding[24];
struct sigcontext
  __uint64_t r8;
  __uint64_t r9;
  __uint64_t r10;
  __uint64_t r11;
  __uint64_t r12;
  __uint64_t r13;
  __uint64_t r14;
  __uint64_t r15;
  __uint64_t rdi;
  __uint64_t rsi;
  __uint64_t rbp;
  __uint64_t rbx;
  __uint64_t rdx;
  __uint64_t rax;
  __uint64_t rcx;
  __uint64_t rsp;
  __uint64_t rip;
  __uint64_t eflags;
  unsigned short cs;
  unsigned short gs;
  unsigned short fs;
  unsigned short __pad0;
  __uint64_t err;
  __uint64_t trapno;
  __uint64_t oldmask;
  __uint64_t cr2;
  __extension__ union
      struct _fpstate * fpstate;
      __uint64_t __fpstate_word;
  __uint64_t __reserved1 [8];
struct _xsave_hdr
  __uint64_t reserved1[2];
  __uint64_t reserved2[5];
struct _ymmh_state
  __uint32_t ymmh_space[64];
struct _xstate
  struct _fpstate fpstate;
  struct _xsave_hdr xstate_hdr;
  struct _ymmh_state ymmh;
# 333 "/usr/include/signal.h" 2 3 4
extern int sigreturn (struct sigcontext *__scp) __attribute__ ((__nothrow__ , __leaf__));
# 343 "/usr/include/signal.h" 2 3 4
extern int siginterrupt (int __sig, int __interrupt) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/bits/sigstack.h" 1 3 4
# 25 "/usr/include/bits/sigstack.h" 3 4
struct sigstack
    void *ss_sp;
    int ss_onstack;
enum
  SS_ONSTACK = 1,
  SS_DISABLE
# 49 "/usr/include/bits/sigstack.h" 3 4
typedef struct sigaltstack
    void *ss_sp;
    int ss_flags;
    size_t ss_size;
  } stack_t;
# 350 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/sys/ucontext.h" 1 3 4
# 22 "/usr/include/sys/ucontext.h" 3 4
# 23 "/usr/include/sys/ucontext.h" 2 3 4
# 31 "/usr/include/sys/ucontext.h" 3 4
__extension__ typedef long long int greg_t;
typedef greg_t gregset_t[23];
# 92 "/usr/include/sys/ucontext.h" 3 4
struct _libc_fpxreg
  unsigned short int significand[4];
  unsigned short int exponent;
  unsigned short int padding[3];
struct _libc_xmmreg
struct _libc_fpstate
  __uint16_t cwd;
  __uint16_t swd;
  __uint16_t ftw;
  __uint16_t fop;
  __uint64_t rip;
  __uint64_t rdp;
  __uint32_t mxcsr;
  struct _libc_fpxreg _st[8];
  struct _libc_xmmreg _xmm[16];
typedef struct _libc_fpstate *fpregset_t;
typedef struct
    gregset_t gregs;
    fpregset_t fpregs;
    __extension__ unsigned long long __reserved1 [8];
} mcontext_t;
typedef struct ucontext
    unsigned long int uc_flags;
    struct ucontext *uc_link;
    stack_t uc_stack;
    mcontext_t uc_mcontext;
    __sigset_t uc_sigmask;
    struct _libc_fpstate __fpregs_mem;
  } ucontext_t;
# 353 "/usr/include/signal.h" 2 3 4
extern int sigstack (struct sigstack *__ss, struct sigstack *__oss)
extern int sigaltstack (const struct sigaltstack *__restrict __ss,
   struct sigaltstack *__restrict __oss) __attribute__ ((__nothrow__ , __leaf__));
# 387 "/usr/include/signal.h" 3 4
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 388 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/sigthread.h" 1 3 4
# 30 "/usr/include/bits/sigthread.h" 3 4
extern int pthread_sigmask (int __how,
       const __sigset_t *__restrict __newmask,
       __sigset_t *__restrict __oldmask)__attribute__ ((__nothrow__ , __leaf__));
extern int pthread_kill (pthread_t __threadid, int __signo) __attribute__ ((__nothrow__ , __leaf__));
# 389 "/usr/include/signal.h" 2 3 4
extern int __libc_current_sigrtmin (void) __attribute__ ((__nothrow__ , __leaf__));
extern int __libc_current_sigrtmax (void) __attribute__ ((__nothrow__ , __leaf__));
# 30 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/bits/waitflags.h" 1 3 4
# 36 "/usr/include/sys/wait.h" 2 3 4
# 60 "/usr/include/sys/wait.h" 3 4
typedef union
    union wait *__uptr;
    int *__iptr;
  } __WAIT_STATUS __attribute__ ((__transparent_union__));
# 77 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/bits/waitstatus.h" 1 3 4
# 64 "/usr/include/bits/waitstatus.h" 3 4
# 65 "/usr/include/bits/waitstatus.h" 2 3 4
union wait
    int w_status;
    struct
 unsigned int __w_termsig:7;
 unsigned int __w_coredump:1;
 unsigned int __w_retcode:8;
 unsigned int:16;
      } __wait_terminated;
    struct
 unsigned int __w_stopval:8;
 unsigned int __w_stopsig:8;
 unsigned int:16;
      } __wait_stopped;
# 78 "/usr/include/sys/wait.h" 2 3 4
# 99 "/usr/include/sys/wait.h" 3 4
typedef enum
  P_ALL,
  P_PID,
  P_PGID
} idtype_t;
# 113 "/usr/include/sys/wait.h" 3 4
extern __pid_t wait (__WAIT_STATUS __stat_loc);
# 136 "/usr/include/sys/wait.h" 3 4
extern __pid_t waitpid (__pid_t __pid, int *__stat_loc, int __options);
# 147 "/usr/include/sys/wait.h" 2 3 4
# 159 "/usr/include/sys/wait.h" 3 4
extern int waitid (idtype_t __idtype, __id_t __id, siginfo_t *__infop,
     int __options);
struct rusage;
extern __pid_t wait3 (__WAIT_STATUS __stat_loc, int __options,
        struct rusage * __usage) __attribute__ ((__nothrow__));
extern __pid_t wait4 (__pid_t __pid, __WAIT_STATUS __stat_loc, int __options,
        struct rusage *__usage) __attribute__ ((__nothrow__));
            Defined "HAVE_SYS_WAIT_H" to "1"
Checking for header: stdlib.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/stdlib.h" 1 3 4
# 24 "/usr/include/stdlib.h" 3 4
# 25 "/usr/include/stdlib.h" 2 3 4
# 33 "/usr/include/stdlib.h" 2 3 4
# 42 "/usr/include/stdlib.h" 2 3 4
union wait
    int w_status;
    struct
 unsigned int:16;
    struct
 unsigned int:16;
      } __wait_stopped;
# 43 "/usr/include/stdlib.h" 2 3 4
# 67 "/usr/include/stdlib.h" 3 4
typedef union
    union wait *__uptr;
    int *__iptr;
# 95 "/usr/include/stdlib.h" 3 4
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
# 139 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (const char *__nptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
__extension__ extern long long int atoll (const char *__nptr)
extern double strtod (const char *__restrict __nptr,
        char **__restrict __endptr)
extern float strtof (const char *__restrict __nptr,
       char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long double strtold (const char *__restrict __nptr,
extern long int strtol (const char *__restrict __nptr,
   char **__restrict __endptr, int __base)
extern unsigned long int strtoul (const char *__restrict __nptr,
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
# 305 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (const char *__s)
# 219 "/usr/include/sys/types.h" 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 315 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
   size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
       int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
   size_t __statelen,
   struct random_data *__restrict __buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    __extension__ unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
        double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
        long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
       struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
# 1 "/usr/include/alloca.h" 1 3 4
# 24 "/usr/include/alloca.h" 3 4
# 25 "/usr/include/alloca.h" 2 3 4
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
# 493 "/usr/include/stdlib.h" 2 3 4
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 513 "/usr/include/stdlib.h" 3 4
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 530 "/usr/include/stdlib.h" 3 4
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 578 "/usr/include/stdlib.h" 3 4
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 606 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 619 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 641 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 662 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 711 "/usr/include/stdlib.h" 3 4
extern int system (const char *__command) ;
# 733 "/usr/include/stdlib.h" 3 4
extern char *realpath (const char *__restrict __name,
         char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
typedef int (*__compar_fn_t) (const void *, const void *);
# 751 "/usr/include/stdlib.h" 3 4
extern void *bsearch (const void *__key, const void *__base,
        size_t __nmemb, size_t __size, __compar_fn_t __compar)
     __attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
     __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 774 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
        long long int __denom)
# 811 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign, char *__restrict __buf,
     size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign,
      char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int mbtowc (wchar_t *__restrict __pwc,
     const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__));
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
extern size_t wcstombs (char *__restrict __s,
   const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 898 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
        char *const *__restrict __tokens,
        char **__restrict __valuep)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 950 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 1 "/usr/include/bits/stdlib-float.h" 1 3 4
# 955 "/usr/include/stdlib.h" 2 3 4
# 967 "/usr/include/stdlib.h" 3 4
            Defined "HAVE_STDLIB_H" to "1"
TEST check from config.headers(/home/jed/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: pthread.h
Executing: /opt/mpich/bin/mpicc -E  -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.headers  /tmp/petsc-lhuj9c/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-lhuj9c/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/conffix.h" 1
# 1 "/usr/include/pthread.h" 1 3 4
# 21 "/usr/include/pthread.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 395 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 396 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 22 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 23 "/usr/include/pthread.h" 2 3 4
# 28 "/usr/include/sched.h" 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 1 "/usr/include/time.h" 1 3 4
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
typedef __pid_t pid_t;
struct sched_param
typedef struct
} cpu_set_t;
# 24 "/usr/include/pthread.h" 2 3 4
# 29 "/usr/include/time.h" 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 131 "/usr/include/time.h" 3 4
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
  long int tm_gmtoff;
struct itimerspec
struct sigevent;
} *__locale_t;
# 25 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 27 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/bits/setjmp.h" 1 3 4
# 26 "/usr/include/bits/setjmp.h" 3 4
# 27 "/usr/include/bits/setjmp.h" 2 3 4
typedef long int __jmp_buf[8];
# 28 "/usr/include/pthread.h" 2 3 4
# 29 "/usr/include/pthread.h" 2 3 4
enum
  PTHREAD_CREATE_JOINABLE,
  PTHREAD_CREATE_DETACHED
enum
  PTHREAD_MUTEX_TIMED_NP,
  PTHREAD_MUTEX_RECURSIVE_NP,
  PTHREAD_MUTEX_ERRORCHECK_NP,
  PTHREAD_MUTEX_ADAPTIVE_NP
  PTHREAD_MUTEX_NORMAL = PTHREAD_MUTEX_TIMED_NP,
  PTHREAD_MUTEX_RECURSIVE = PTHREAD_MUTEX_RECURSIVE_NP,
  PTHREAD_MUTEX_ERRORCHECK = PTHREAD_MUTEX_ERRORCHECK_NP,
  PTHREAD_MUTEX_DEFAULT = PTHREAD_MUTEX_NORMAL
enum
  PTHREAD_MUTEX_STALLED,
  PTHREAD_MUTEX_STALLED_NP = PTHREAD_MUTEX_STALLED,
  PTHREAD_MUTEX_ROBUST,
  PTHREAD_MUTEX_ROBUST_NP = PTHREAD_MUTEX_ROBUST
enum
  PTHREAD_PRIO_NONE,
  PTHREAD_PRIO_INHERIT,
  PTHREAD_PRIO_PROTECT
# 116 "/usr/include/pthread.h" 3 4
enum
  PTHREAD_RWLOCK_PREFER_READER_NP,
  PTHREAD_RWLOCK_PREFER_WRITER_NP,
  PTHREAD_RWLOCK_PREFER_WRITER_NONRECURSIVE_NP,
  PTHREAD_RWLOCK_DEFAULT_NP = PTHREAD_RWLOCK_PREFER_READER_NP
# 157 "/usr/include/pthread.h" 3 4
enum
  PTHREAD_INHERIT_SCHED,
  PTHREAD_EXPLICIT_SCHED
enum
  PTHREAD_SCOPE_SYSTEM,
  PTHREAD_SCOPE_PROCESS
enum
  PTHREAD_PROCESS_PRIVATE,
  PTHREAD_PROCESS_SHARED
# 192 "/usr/include/pthread.h" 3 4
struct _pthread_cleanup_buffer
  void (*__routine) (void *);
  void *__arg;
  int __canceltype;
  struct _pthread_cleanup_buffer *__prev;
enum
  PTHREAD_CANCEL_ENABLE,
  PTHREAD_CANCEL_DISABLE
enum
  PTHREAD_CANCEL_DEFERRED,
  PTHREAD_CANCEL_ASYNCHRONOUS
# 230 "/usr/include/pthread.h" 3 4
extern int pthread_create (pthread_t *__restrict __newthread,
      const pthread_attr_t *__restrict __attr,
      void *(*__start_routine) (void *),
      void *__restrict __arg) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 3)));
extern void pthread_exit (void *__retval) __attribute__ ((__noreturn__));
extern int pthread_join (pthread_t __th, void **__thread_return);
# 273 "/usr/include/pthread.h" 3 4
extern int pthread_detach (pthread_t __th) __attribute__ ((__nothrow__ , __leaf__));
extern pthread_t pthread_self (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int pthread_equal (pthread_t __thread1, pthread_t __thread2)
extern int pthread_attr_init (pthread_attr_t *__attr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_attr_destroy (pthread_attr_t *__attr)
extern int pthread_attr_getdetachstate (const pthread_attr_t *__attr,
     int *__detachstate)
extern int pthread_attr_setdetachstate (pthread_attr_t *__attr,
     int __detachstate)
extern int pthread_attr_getguardsize (const pthread_attr_t *__attr,
          size_t *__guardsize)
extern int pthread_attr_setguardsize (pthread_attr_t *__attr,
          size_t __guardsize)
extern int pthread_attr_getschedparam (const pthread_attr_t *__restrict __attr,
           struct sched_param *__restrict __param)
extern int pthread_attr_setschedparam (pthread_attr_t *__restrict __attr,
           const struct sched_param *__restrict
           __param) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int pthread_attr_getschedpolicy (const pthread_attr_t *__restrict
     __attr, int *__restrict __policy)
extern int pthread_attr_setschedpolicy (pthread_attr_t *__attr, int __policy)
extern int pthread_attr_getinheritsched (const pthread_attr_t *__restrict
      __attr, int *__restrict __inherit)
extern int pthread_attr_setinheritsched (pthread_attr_t *__attr,
      int __inherit)
extern int pthread_attr_getscope (const pthread_attr_t *__restrict __attr,
      int *__restrict __scope)
extern int pthread_attr_setscope (pthread_attr_t *__attr, int __scope)
extern int pthread_attr_getstackaddr (const pthread_attr_t *__restrict
          __attr, void **__restrict __stackaddr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2))) __attribute__ ((__deprecated__));
extern int pthread_attr_setstackaddr (pthread_attr_t *__attr,
          void *__stackaddr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) __attribute__ ((__deprecated__));
extern int pthread_attr_getstacksize (const pthread_attr_t *__restrict
          __attr, size_t *__restrict __stacksize)
extern int pthread_attr_setstacksize (pthread_attr_t *__attr,
          size_t __stacksize)
extern int pthread_attr_getstack (const pthread_attr_t *__restrict __attr,
      void **__restrict __stackaddr,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern int pthread_attr_setstack (pthread_attr_t *__attr, void *__stackaddr,
      size_t __stacksize) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 431 "/usr/include/pthread.h" 3 4
extern int pthread_setschedparam (pthread_t __target_thread, int __policy,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3)));
extern int pthread_getschedparam (pthread_t __target_thread,
      int *__restrict __policy,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3)));
extern int pthread_setschedprio (pthread_t __target_thread, int __prio)
# 496 "/usr/include/pthread.h" 3 4
extern int pthread_once (pthread_once_t *__once_control,
    void (*__init_routine) (void)) __attribute__ ((__nonnull__ (1, 2)));
# 508 "/usr/include/pthread.h" 3 4
extern int pthread_setcancelstate (int __state, int *__oldstate);
extern int pthread_setcanceltype (int __type, int *__oldtype);
extern int pthread_cancel (pthread_t __th);
extern void pthread_testcancel (void);
typedef struct
  struct
    __jmp_buf __cancel_jmp_buf;
    int __mask_was_saved;
  } __cancel_jmp_buf[1];
  void *__pad[4];
} __pthread_unwind_buf_t __attribute__ ((__aligned__));
# 542 "/usr/include/pthread.h" 3 4
struct __pthread_cleanup_frame
  void (*__cancel_routine) (void *);
  void *__cancel_arg;
  int __do_it;
  int __cancel_type;
# 682 "/usr/include/pthread.h" 3 4
extern void __pthread_register_cancel (__pthread_unwind_buf_t *__buf)
# 694 "/usr/include/pthread.h" 3 4
extern void __pthread_unregister_cancel (__pthread_unwind_buf_t *__buf)
# 735 "/usr/include/pthread.h" 3 4
extern void __pthread_unwind_next (__pthread_unwind_buf_t *__buf)
     __attribute__ ((__weak__))
struct __jmp_buf_tag;
extern int __sigsetjmp (struct __jmp_buf_tag *__env, int __savemask) __attribute__ ((__nothrow__));
extern int pthread_mutex_init (pthread_mutex_t *__mutex,
          const pthread_mutexattr_t *__mutexattr)
extern int pthread_mutex_destroy (pthread_mutex_t *__mutex)
extern int pthread_mutex_trylock (pthread_mutex_t *__mutex)
     __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_mutex_lock (pthread_mutex_t *__mutex)
extern int pthread_mutex_timedlock (pthread_mutex_t *__restrict __mutex,
        __abstime) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
extern int pthread_mutex_unlock (pthread_mutex_t *__mutex)
extern int pthread_mutex_getprioceiling (const pthread_mutex_t *
      __restrict __mutex,
      int *__restrict __prioceiling)
extern int pthread_mutex_setprioceiling (pthread_mutex_t *__restrict __mutex,
      int __prioceiling,
      int *__restrict __old_ceiling)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 3)));
extern int pthread_mutex_consistent (pthread_mutex_t *__mutex)
# 808 "/usr/include/pthread.h" 3 4
extern int pthread_mutexattr_init (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_destroy (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_getpshared (const pthread_mutexattr_t *
      __restrict __attr,
      int *__restrict __pshared)
extern int pthread_mutexattr_setpshared (pthread_mutexattr_t *__attr,
      int __pshared)
extern int pthread_mutexattr_gettype (const pthread_mutexattr_t *__restrict
          __attr, int *__restrict __kind)
extern int pthread_mutexattr_settype (pthread_mutexattr_t *__attr, int __kind)
extern int pthread_mutexattr_getprotocol (const pthread_mutexattr_t *
       __restrict __attr,
       int *__restrict __protocol)
extern int pthread_mutexattr_setprotocol (pthread_mutexattr_t *__attr,
       int __protocol)
extern int pthread_mutexattr_getprioceiling (const pthread_mutexattr_t *
          __restrict __attr,
extern int pthread_mutexattr_setprioceiling (pthread_mutexattr_t *__attr,
          int __prioceiling)
extern int pthread_mutexattr_getrobust (const pthread_mutexattr_t *__attr,
     int *__robustness)
extern int pthread_mutexattr_setrobust (pthread_mutexattr_t *__attr,
     int __robustness)
# 890 "/usr/include/pthread.h" 3 4
extern int pthread_rwlock_init (pthread_rwlock_t *__restrict __rwlock,
    const pthread_rwlockattr_t *__restrict
extern int pthread_rwlock_destroy (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_rdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_tryrdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedrdlock (pthread_rwlock_t *__restrict __rwlock,
extern int pthread_rwlock_wrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_trywrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedwrlock (pthread_rwlock_t *__restrict __rwlock,
extern int pthread_rwlock_unlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlockattr_init (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_destroy (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_getpshared (const pthread_rwlockattr_t *
       __restrict __attr,
extern int pthread_rwlockattr_setpshared (pthread_rwlockattr_t *__attr,
       int __pshared)
extern int pthread_rwlockattr_getkind_np (const pthread_rwlockattr_t *
       __restrict __attr,
       int *__restrict __pref)
extern int pthread_rwlockattr_setkind_np (pthread_rwlockattr_t *__attr,
       int __pref) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_cond_init (pthread_cond_t *__restrict __cond,
         const pthread_condattr_t *__restrict __cond_attr)
extern int pthread_cond_destroy (pthread_cond_t *__cond)
extern int pthread_cond_signal (pthread_cond_t *__cond)
extern int pthread_cond_broadcast (pthread_cond_t *__cond)
extern int pthread_cond_wait (pthread_cond_t *__restrict __cond,
         pthread_mutex_t *__restrict __mutex)
# 1002 "/usr/include/pthread.h" 3 4
extern int pthread_cond_timedwait (pthread_cond_t *__restrict __cond,
       const struct timespec *__restrict __abstime)
extern int pthread_condattr_init (pthread_condattr_t *__attr)
extern int pthread_condattr_destroy (pthread_condattr_t *__attr)
extern int pthread_condattr_getpshared (const pthread_condattr_t *
     __restrict __attr,
extern int pthread_condattr_setpshared (pthread_condattr_t *__attr,
     int __pshared) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_condattr_getclock (const pthread_condattr_t *
          __restrict __attr,
          __clockid_t *__restrict __clock_id)
extern int pthread_condattr_setclock (pthread_condattr_t *__attr,
          __clockid_t __clock_id)
# 1046 "/usr/include/pthread.h" 3 4
extern int pthread_spin_init (pthread_spinlock_t *__lock, int __pshared)
extern int pthread_spin_destroy (pthread_spinlock_t *__lock)
extern int pthread_spin_lock (pthread_spinlock_t *__lock)
extern int pthread_spin_trylock (pthread_spinlock_t *__lock)
extern int pthread_spin_unlock (pthread_spinlock_t *__lock)
extern int pthread_barrier_init (pthread_barrier_t *__restrict __barrier,
     const pthread_barrierattr_t *__restrict
     __attr, unsigned int __count)
extern int pthread_barrier_destroy (pthread_barrier_t *__barrier)
extern int pthread_barrier_wait (pthread_barrier_t *__barrier)
extern int pthread_barrierattr_init (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_destroy (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_getpshared (const pthread_barrierattr_t *
        __restrict __attr,
extern int pthread_barrierattr_setpshared (pthread_barrierattr_t *__attr,
        int __pshared)
# 1113 "/usr/include/pthread.h" 3 4
extern int pthread_key_create (pthread_key_t *__key,
          void (*__destr_function) (void *))
extern int pthread_key_delete (pthread_key_t __key) __attribute__ ((__nothrow__ , __leaf__));
extern void *pthread_getspecific (pthread_key_t __key) __attribute__ ((__nothrow__ , __leaf__));
extern int pthread_setspecific (pthread_key_t __key,
    const void *__pointer) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int pthread_getcpuclockid (pthread_t __thread_id,
      __clockid_t *__clock_id)
# 1147 "/usr/include/pthread.h" 3 4
extern int pthread_atfork (void (*__prepare) (void),
      void (*__parent) (void),
      void (*__child) (void)) __attribute__ ((__nothrow__ , __leaf__));
# 1161 "/usr/include/pthread.h" 3 4
            Defined "HAVE_PTHREAD_H" to "1"
Checking for header: setjmp.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/setjmp.h" 1 3 4
# 25 "/usr/include/setjmp.h" 3 4
# 26 "/usr/include/setjmp.h" 2 3 4
# 30 "/usr/include/setjmp.h" 2 3 4
# 1 "/usr/include/bits/sigset.h" 1 3 4
# 22 "/usr/include/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 31 "/usr/include/setjmp.h" 2 3 4
    __jmp_buf __jmpbuf;
    __sigset_t __saved_mask;
typedef struct __jmp_buf_tag jmp_buf[1];
extern int setjmp (jmp_buf __env) __attribute__ ((__nothrow__));
extern int __sigsetjmp (struct __jmp_buf_tag __env[1], int __savemask) __attribute__ ((__nothrow__));
extern int _setjmp (struct __jmp_buf_tag __env[1]) __attribute__ ((__nothrow__));
extern void longjmp (struct __jmp_buf_tag __env[1], int __val)
     __attribute__ ((__nothrow__)) __attribute__ ((__noreturn__));
extern void _longjmp (struct __jmp_buf_tag __env[1], int __val)
typedef struct __jmp_buf_tag sigjmp_buf[1];
# 102 "/usr/include/setjmp.h" 3 4
extern void siglongjmp (sigjmp_buf __env, int __val)
# 112 "/usr/include/setjmp.h" 3 4
            Defined "HAVE_SETJMP_H" to "1"
Checking for header: sys/utsname.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/utsname.h" 1 3 4
# 25 "/usr/include/sys/utsname.h" 3 4
# 26 "/usr/include/sys/utsname.h" 2 3 4
# 1 "/usr/include/bits/utsname.h" 1 3 4
# 30 "/usr/include/sys/utsname.h" 2 3 4
# 48 "/usr/include/sys/utsname.h" 3 4
struct utsname
    char sysname[65];
    char nodename[65];
    char release[65];
    char version[65];
    char machine[65];
    char __domainname[65];
# 81 "/usr/include/sys/utsname.h" 3 4
extern int uname (struct utsname *__name) __attribute__ ((__nothrow__ , __leaf__));
            Defined "HAVE_SYS_UTSNAME_H" to "1"
Checking for header: machine/endian.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-lhuj9c/config.headers/conftest.c:3:28: fatal error: machine/endian.h: No such file or directory
 #include <machine/endian.h>
Source:
#include "confdefs.h"
#include "conffix.h"
Checking for header: limits.h
stdout:
# 1 "<built-in>"
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include-fixed/limits.h" 1 3 4
# 34 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include-fixed/limits.h" 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include-fixed/syslimits.h" 1 3 4
# 168 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include-fixed/limits.h" 3 4
# 1 "/usr/include/limits.h" 1 3 4
# 25 "/usr/include/limits.h" 3 4
# 26 "/usr/include/limits.h" 2 3 4
# 143 "/usr/include/limits.h" 3 4
# 1 "/usr/include/bits/posix1_lim.h" 1 3 4
# 160 "/usr/include/bits/posix1_lim.h" 3 4
# 1 "/usr/include/bits/local_lim.h" 1 3 4
# 38 "/usr/include/bits/local_lim.h" 3 4
# 1 "/usr/include/linux/limits.h" 1 3 4
# 39 "/usr/include/bits/local_lim.h" 2 3 4
# 161 "/usr/include/bits/posix1_lim.h" 2 3 4
# 144 "/usr/include/limits.h" 2 3 4
# 1 "/usr/include/bits/posix2_lim.h" 1 3 4
# 148 "/usr/include/limits.h" 2 3 4
# 169 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include-fixed/limits.h" 2 3 4
# 8 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include-fixed/syslimits.h" 2 3 4
# 35 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include-fixed/limits.h" 2 3 4
            Defined "HAVE_LIMITS_H" to "1"
Checking for header: fcntl.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/fcntl.h" 1 3 4
# 25 "/usr/include/fcntl.h" 3 4
# 26 "/usr/include/fcntl.h" 2 3 4
# 32 "/usr/include/fcntl.h" 2 3 4
# 1 "/usr/include/bits/fcntl.h" 1 3 4
# 35 "/usr/include/bits/fcntl.h" 3 4
struct flock
    short int l_type;
    short int l_whence;
    __off_t l_start;
    __off_t l_len;
    __pid_t l_pid;
# 61 "/usr/include/bits/fcntl.h" 3 4
# 1 "/usr/include/bits/fcntl-linux.h" 1 3 4
# 345 "/usr/include/bits/fcntl-linux.h" 3 4
# 419 "/usr/include/bits/fcntl-linux.h" 3 4
# 61 "/usr/include/bits/fcntl.h" 2 3 4
# 36 "/usr/include/fcntl.h" 2 3 4
typedef __mode_t mode_t;
typedef __off_t off_t;
# 60 "/usr/include/fcntl.h" 3 4
struct timespec
    __time_t tv_sec;
# 68 "/usr/include/fcntl.h" 2 3 4
# 1 "/usr/include/bits/stat.h" 1 3 4
# 46 "/usr/include/bits/stat.h" 3 4
struct stat
    __dev_t st_dev;
    __ino_t st_ino;
    __nlink_t st_nlink;
    __mode_t st_mode;
    __uid_t st_uid;
    __gid_t st_gid;
    int __pad0;
    __dev_t st_rdev;
    __off_t st_size;
    __blksize_t st_blksize;
    __blkcnt_t st_blocks;
# 91 "/usr/include/bits/stat.h" 3 4
    struct timespec st_atim;
    struct timespec st_mtim;
    struct timespec st_ctim;
# 106 "/usr/include/bits/stat.h" 3 4
    __syscall_slong_t __glibc_reserved[3];
# 115 "/usr/include/bits/stat.h" 3 4
# 69 "/usr/include/fcntl.h" 2 3 4
# 160 "/usr/include/fcntl.h" 3 4
extern int fcntl (int __fd, int __cmd, ...);
# 169 "/usr/include/fcntl.h" 3 4
extern int open (const char *__file, int __oflag, ...) __attribute__ ((__nonnull__ (1)));
# 193 "/usr/include/fcntl.h" 3 4
extern int openat (int __fd, const char *__file, int __oflag, ...)
# 215 "/usr/include/fcntl.h" 3 4
extern int creat (const char *__file, mode_t __mode) __attribute__ ((__nonnull__ (1)));
# 244 "/usr/include/fcntl.h" 3 4
extern int lockf (int __fd, int __cmd, off_t __len);
# 261 "/usr/include/fcntl.h" 3 4
extern int posix_fadvise (int __fd, off_t __offset, off_t __len,
     int __advise) __attribute__ ((__nothrow__ , __leaf__));
# 283 "/usr/include/fcntl.h" 3 4
extern int posix_fallocate (int __fd, off_t __offset, off_t __len);
# 305 "/usr/include/fcntl.h" 3 4
            Defined "HAVE_FCNTL_H" to "1"
Checking for header: string.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/string.h" 1 3 4
# 25 "/usr/include/string.h" 3 4
# 26 "/usr/include/string.h" 2 3 4
# 33 "/usr/include/string.h" 2 3 4
# 44 "/usr/include/string.h" 3 4
extern void *memcpy (void *__restrict __dest, const void *__restrict __src,
       size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern void *memmove (void *__dest, const void *__src, size_t __n)
extern void *memccpy (void *__restrict __dest, const void *__restrict __src,
        int __c, size_t __n)
extern void *memset (void *__s, int __c, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int memcmp (const void *__s1, const void *__s2, size_t __n)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
# 96 "/usr/include/string.h" 3 4
extern void *memchr (const void *__s, int __c, size_t __n)
# 127 "/usr/include/string.h" 3 4
extern char *strcpy (char *__restrict __dest, const char *__restrict __src)
extern char *strncpy (char *__restrict __dest,
        const char *__restrict __src, size_t __n)
extern char *strcat (char *__restrict __dest, const char *__restrict __src)
extern char *strncat (char *__restrict __dest, const char *__restrict __src,
extern int strcmp (const char *__s1, const char *__s2)
extern int strncmp (const char *__s1, const char *__s2, size_t __n)
extern int strcoll (const char *__s1, const char *__s2)
extern size_t strxfrm (char *__restrict __dest,
# 1 "/usr/include/xlocale.h" 1 3 4
# 27 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 164 "/usr/include/string.h" 2 3 4
extern int strcoll_l (const char *__s1, const char *__s2, __locale_t __l)
extern size_t strxfrm_l (char *__dest, const char *__src, size_t __n,
    __locale_t __l) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern char *strdup (const char *__s)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) __attribute__ ((__nonnull__ (1)));
extern char *strndup (const char *__string, size_t __n)
# 210 "/usr/include/string.h" 3 4
# 235 "/usr/include/string.h" 3 4
extern char *strchr (const char *__s, int __c)
# 262 "/usr/include/string.h" 3 4
extern char *strrchr (const char *__s, int __c)
# 281 "/usr/include/string.h" 3 4
extern size_t strcspn (const char *__s, const char *__reject)
extern size_t strspn (const char *__s, const char *__accept)
# 314 "/usr/include/string.h" 3 4
extern char *strpbrk (const char *__s, const char *__accept)
# 341 "/usr/include/string.h" 3 4
extern char *strstr (const char *__haystack, const char *__needle)
extern char *strtok (char *__restrict __s, const char *__restrict __delim)
extern char *__strtok_r (char *__restrict __s,
    const char *__restrict __delim,
    char **__restrict __save_ptr)
extern char *strtok_r (char *__restrict __s, const char *__restrict __delim,
# 396 "/usr/include/string.h" 3 4
extern size_t strlen (const char *__s)
extern size_t strnlen (const char *__string, size_t __maxlen)
extern char *strerror (int __errnum) __attribute__ ((__nothrow__ , __leaf__));
# 426 "/usr/include/string.h" 3 4
extern int strerror_r (int __errnum, char *__buf, size_t __buflen) __asm__ ("" "__xpg_strerror_r") __attribute__ ((__nothrow__ , __leaf__))
# 444 "/usr/include/string.h" 3 4
extern char *strerror_l (int __errnum, __locale_t __l) __attribute__ ((__nothrow__ , __leaf__));
extern void __bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 488 "/usr/include/string.h" 3 4
# 516 "/usr/include/string.h" 3 4
extern int ffs (int __i) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 533 "/usr/include/string.h" 3 4
# 556 "/usr/include/string.h" 3 4
extern char *strsep (char **__restrict __stringp,
extern char *strsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern char *__stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *__stpncpy (char *__restrict __dest,
extern char *stpncpy (char *__restrict __dest,
# 643 "/usr/include/string.h" 3 4
# 3 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
            Defined "HAVE_STRING_H" to "1"
Checking for header: sys/times.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/times.h" 1 3 4
# 25 "/usr/include/sys/times.h" 3 4
# 26 "/usr/include/sys/times.h" 2 3 4
# 55 "/usr/include/time.h" 3 4
# 56 "/usr/include/time.h" 2 3 4
# 29 "/usr/include/sys/times.h" 2 3 4
struct tms
    clock_t tms_utime;
    clock_t tms_stime;
    clock_t tms_cutime;
    clock_t tms_cstime;
extern clock_t times (struct tms *__buffer) __attribute__ ((__nothrow__ , __leaf__));
            Defined "HAVE_SYS_TIMES_H" to "1"
Checking for header: io.h
stdout:
# 1 "<built-in>"
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2stderr:
/tmp/petsc-lhuj9c/config.headers/conftest.c:3:16: fatal error: io.h: No such file or directory
 #include <io.h>
compilation terminated.
Source:
#include <io.h>
Checking for header: stdint.h
stdout:
# 1 "<built-in>"
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdint.h" 1 3 4
# 9 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 25 "/usr/include/stdint.h" 3 4
# 26 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/bits/wchar.h" 1 3 4
# 27 "/usr/include/stdint.h" 2 3 4
# 28 "/usr/include/stdint.h" 2 3 4
# 36 "/usr/include/stdint.h" 3 4
typedef signed char int8_t;
typedef short int int16_t;
typedef int int32_t;
typedef long int int64_t;
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned long int uint64_t;
# 65 "/usr/include/stdint.h" 3 4
typedef signed char int_least8_t;
typedef short int int_least16_t;
typedef int int_least32_t;
typedef long int int_least64_t;
typedef unsigned char uint_least8_t;
typedef unsigned short int uint_least16_t;
typedef unsigned int uint_least32_t;
typedef unsigned long int uint_least64_t;
# 90 "/usr/include/stdint.h" 3 4
typedef signed char int_fast8_t;
typedef long int int_fast16_t;
typedef long int int_fast32_t;
typedef long int int_fast64_t;
# 103 "/usr/include/stdint.h" 3 4
typedef unsigned char uint_fast8_t;
typedef unsigned long int uint_fast16_t;
typedef unsigned long int uint_fast32_t;
typedef unsigned long int uint_fast64_t;
# 119 "/usr/include/stdint.h" 3 4
typedef long int intptr_t;
typedef unsigned long int uintptr_t;
# 134 "/usr/include/stdint.h" 3 4
typedef long int intmax_t;
typedef unsigned long int uintmax_t;
# 10 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdint.h" 2 3 4
            Defined "HAVE_STDINT_H" to "1"
Checking for header: pwd.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/pwd.h" 1 3 4
# 25 "/usr/include/pwd.h" 3 4
# 26 "/usr/include/pwd.h" 2 3 4
# 30 "/usr/include/pwd.h" 2 3 4
# 33 "/usr/include/pwd.h" 2 3 4
typedef __gid_t gid_t;
typedef __uid_t uid_t;
struct passwd
  char *pw_name;
  char *pw_passwd;
  __uid_t pw_uid;
  __gid_t pw_gid;
  char *pw_gecos;
  char *pw_dir;
  char *pw_shell;
# 1 "/usr/include/stdio.h" 1 3 4
# 44 "/usr/include/stdio.h" 3 4
struct _IO_FILE;
typedef struct _IO_FILE FILE;
# 64 "/usr/include/pwd.h" 2 3 4
# 72 "/usr/include/pwd.h" 3 4
extern void setpwent (void);
extern void endpwent (void);
extern struct passwd *getpwent (void);
# 94 "/usr/include/pwd.h" 3 4
extern struct passwd *fgetpwent (FILE *__stream);
extern int putpwent (const struct passwd *__restrict __p,
       FILE *__restrict __f);
extern struct passwd *getpwuid (__uid_t __uid);
extern struct passwd *getpwnam (const char *__name);
# 139 "/usr/include/pwd.h" 3 4
extern int getpwent_r (struct passwd *__restrict __resultbuf,
         char *__restrict __buffer, size_t __buflen,
         struct passwd **__restrict __result);
extern int getpwuid_r (__uid_t __uid,
extern int getpwnam_r (const char *__restrict __name,
# 163 "/usr/include/pwd.h" 3 4
extern int fgetpwent_r (FILE *__restrict __stream,
# 183 "/usr/include/pwd.h" 3 4
            Defined "HAVE_PWD_H" to "1"
Checking for header: float.h
stdout:
# 1 "<built-in>"
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/float.h" 1 3 4
            Defined "HAVE_FLOAT_H" to "1"
Checking for header: sys/param.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/param.h" 1 3 4
# 23 "/usr/include/sys/param.h" 3 4
# 24 "/usr/include/sys/param.h" 2 3 4
# 1 "/usr/include/sys/types.h" 1 3 4
# 25 "/usr/include/sys/types.h" 3 4
# 26 "/usr/include/sys/types.h" 2 3 4
# 30 "/usr/include/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 60 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __nlink_t nlink_t;
# 98 "/usr/include/sys/types.h" 3 4
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 132 "/usr/include/sys/types.h" 3 4
# 133 "/usr/include/sys/types.h" 2 3 4
# 146 "/usr/include/sys/types.h" 3 4
# 147 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 194 "/usr/include/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 216 "/usr/include/sys/types.h" 3 4
# 28 "/usr/include/bits/byteswap.h" 3 4
# 217 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
typedef struct
  } __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
struct timespec
    __time_t tv_sec;
# 44 "/usr/include/sys/select.h" 2 3 4
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 46 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 64 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 96 "/usr/include/sys/select.h" 3 4
# 106 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 118 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 131 "/usr/include/sys/select.h" 3 4
# 220 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/sysmacros.h" 1 3 4
# 24 "/usr/include/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 58 "/usr/include/sys/sysmacros.h" 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 270 "/usr/include/sys/types.h" 3 4
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 271 "/usr/include/sys/types.h" 2 3 4
# 26 "/usr/include/sys/param.h" 2 3 4
# 27 "/usr/include/sys/param.h" 2 3 4
# 1 "/usr/include/signal.h" 1 3 4
# 30 "/usr/include/signal.h" 3 4
# 102 "/usr/include/bits/sigset.h" 3 4
extern int __sigismember (const __sigset_t *, int);
extern int __sigaddset (__sigset_t *, int);
extern int __sigdelset (__sigset_t *, int);
# 33 "/usr/include/signal.h" 2 3 4
typedef __sig_atomic_t sig_atomic_t;
# 57 "/usr/include/signal.h" 3 4
# 1 "/usr/include/bits/signum.h" 1 3 4
# 58 "/usr/include/signal.h" 2 3 4
# 75 "/usr/include/signal.h" 3 4
# 76 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/siginfo.h" 1 3 4
# 24 "/usr/include/bits/siginfo.h" 3 4
# 25 "/usr/include/bits/siginfo.h" 2 3 4
typedef union sigval
    int sival_int;
    void *sival_ptr;
  } sigval_t;
# 58 "/usr/include/bits/siginfo.h" 3 4
typedef __clock_t __sigchld_clock_t;
typedef struct
    int si_signo;
    int si_errno;
    int si_code;
    union
 int _pad[((128 / sizeof (int)) - 4)];
 struct
     __pid_t si_pid;
     __uid_t si_uid;
   } _kill;
 struct
     int si_tid;
     int si_overrun;
     sigval_t si_sigval;
   } _timer;
 struct
     __pid_t si_pid;
     __uid_t si_uid;
     sigval_t si_sigval;
   } _rt;
 struct
     __pid_t si_pid;
     __uid_t si_uid;
     int si_status;
     __sigchld_clock_t si_utime;
     __sigchld_clock_t si_stime;
   } _sigchld;
 struct
     void *si_addr;
     short int si_addr_lsb;
   } _sigfault;
 struct
     long int si_band;
     int si_fd;
   } _sigpoll;
 struct
     void *_call_addr;
     int _syscall;
     unsigned int _arch;
   } _sigsys;
      } _sifields;
  } siginfo_t ;
# 153 "/usr/include/bits/siginfo.h" 3 4
enum
  SI_ASYNCNL = -60,
  SI_TKILL = -6,
  SI_SIGIO,
  SI_ASYNCIO,
  SI_MESGQ,
  SI_TIMER,
  SI_QUEUE,
  SI_USER,
  SI_KERNEL = 0x80
enum
  ILL_ILLOPC = 1,
  ILL_ILLOPN,
  ILL_ILLADR,
  ILL_ILLTRP,
  ILL_PRVOPC,
  ILL_PRVREG,
  ILL_COPROC,
  ILL_BADSTK
enum
  FPE_INTDIV = 1,
  FPE_INTOVF,
  FPE_FLTDIV,
  FPE_FLTOVF,
  FPE_FLTUND,
  FPE_FLTRES,
  FPE_FLTINV,
  FPE_FLTSUB
enum
  SEGV_MAPERR = 1,
  SEGV_ACCERR
enum
  BUS_ADRALN = 1,
  BUS_ADRERR,
  BUS_OBJERR,
  BUS_MCEERR_AR,
  BUS_MCEERR_AO
# 257 "/usr/include/bits/siginfo.h" 3 4
enum
  CLD_EXITED = 1,
  CLD_KILLED,
  CLD_DUMPED,
  CLD_TRAPPED,
  CLD_STOPPED,
  CLD_CONTINUED
enum
  POLL_IN = 1,
  POLL_OUT,
  POLL_MSG,
  POLL_ERR,
  POLL_PRI,
  POLL_HUP
# 313 "/usr/include/bits/siginfo.h" 3 4
typedef struct sigevent
    sigval_t sigev_value;
    int sigev_signo;
    int sigev_notify;
    union
 int _pad[((64 / sizeof (int)) - 4)];
 __pid_t _tid;
 struct
     void (*_function) (sigval_t);
     pthread_attr_t *_attribute;
   } _sigev_thread;
      } _sigev_un;
  } sigevent_t;
enum
  SIGEV_SIGNAL = 0,
  SIGEV_NONE,
  SIGEV_THREAD,
  SIGEV_THREAD_ID = 4
# 81 "/usr/include/signal.h" 2 3 4
typedef void (*__sighandler_t) (int);
extern __sighandler_t __sysv_signal (int __sig, __sighandler_t __handler)
# 100 "/usr/include/signal.h" 3 4
extern __sighandler_t signal (int __sig, __sighandler_t __handler)
# 114 "/usr/include/signal.h" 3 4
# 127 "/usr/include/signal.h" 3 4
extern int kill (__pid_t __pid, int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern int killpg (__pid_t __pgrp, int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern int raise (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern __sighandler_t ssignal (int __sig, __sighandler_t __handler)
extern int gsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern void psignal (int __sig, const char *__s);
extern void psiginfo (const siginfo_t *__pinfo, const char *__s);
# 167 "/usr/include/signal.h" 3 4
extern int __sigpause (int __sig_or_mask, int __is_sig);
# 189 "/usr/include/signal.h" 3 4
extern int sigblock (int __mask) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
extern int sigsetmask (int __mask) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
extern int siggetmask (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
# 209 "/usr/include/signal.h" 3 4
typedef __sighandler_t sig_t;
extern int sigemptyset (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigfillset (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigaddset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigdelset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigismember (const sigset_t *__set, int __signo)
# 245 "/usr/include/signal.h" 3 4
# 1 "/usr/include/bits/sigaction.h" 1 3 4
# 24 "/usr/include/bits/sigaction.h" 3 4
struct sigaction
    union
 __sighandler_t sa_handler;
 void (*sa_sigaction) (int, siginfo_t *, void *);
    __sigaction_handler;
    __sigset_t sa_mask;
    int sa_flags;
    void (*sa_restorer) (void);
# 246 "/usr/include/signal.h" 2 3 4
extern int sigprocmask (int __how, const sigset_t *__restrict __set,
   sigset_t *__restrict __oset) __attribute__ ((__nothrow__ , __leaf__));
extern int sigsuspend (const sigset_t *__set) __attribute__ ((__nonnull__ (1)));
extern int sigaction (int __sig, const struct sigaction *__restrict __act,
        struct sigaction *__restrict __oact) __attribute__ ((__nothrow__ , __leaf__));
extern int sigpending (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigwait (const sigset_t *__restrict __set, int *__restrict __sig)
extern int sigwaitinfo (const sigset_t *__restrict __set,
   siginfo_t *__restrict __info) __attribute__ ((__nonnull__ (1)));
extern int sigtimedwait (const sigset_t *__restrict __set,
    siginfo_t *__restrict __info,
    const struct timespec *__restrict __timeout)
extern int sigqueue (__pid_t __pid, int __sig, const union sigval __val)
# 303 "/usr/include/signal.h" 3 4
extern const char *const _sys_siglist[65];
extern const char *const sys_siglist[65];
struct sigvec
    __sighandler_t sv_handler;
    int sv_mask;
    int sv_flags;
# 327 "/usr/include/signal.h" 3 4
extern int sigvec (int __sig, const struct sigvec *__vec,
     struct sigvec *__ovec) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/bits/sigcontext.h" 1 3 4
# 29 "/usr/include/bits/sigcontext.h" 3 4
struct _fpx_sw_bytes
  __uint32_t magic1;
  __uint32_t extended_size;
  __uint64_t xstate_bv;
  __uint32_t xstate_size;
  __uint32_t padding[7];
struct _fpreg
  unsigned short significand[4];
  unsigned short exponent;
struct _fpxreg
  unsigned short padding[3];
struct _xmmreg
  __uint32_t element[4];
# 121 "/usr/include/bits/sigcontext.h" 3 4
struct _fpstate
  __uint16_t cwd;
  __uint16_t swd;
  __uint16_t ftw;
  __uint16_t fop;
  __uint64_t rip;
  __uint64_t rdp;
  __uint32_t mxcsr;
  __uint32_t mxcr_mask;
  struct _fpxreg _st[8];
  struct _xmmreg _xmm[16];
  __uint32_t padding[24];
struct sigcontext
  __uint64_t r8;
  __uint64_t r9;
  __uint64_t r10;
  __uint64_t r11;
  __uint64_t r12;
  __uint64_t r13;
  __uint64_t r14;
  __uint64_t r15;
  __uint64_t rdi;
  __uint64_t rsi;
  __uint64_t rbp;
  __uint64_t rbx;
  __uint64_t rdx;
  __uint64_t rax;
  __uint64_t rcx;
  __uint64_t rsp;
  __uint64_t rip;
  __uint64_t eflags;
  unsigned short cs;
  unsigned short gs;
  unsigned short fs;
  unsigned short __pad0;
  __uint64_t err;
  __uint64_t trapno;
  __uint64_t oldmask;
  __uint64_t cr2;
  __extension__ union
      struct _fpstate * fpstate;
      __uint64_t __fpstate_word;
  __uint64_t __reserved1 [8];
struct _xsave_hdr
  __uint64_t reserved1[2];
  __uint64_t reserved2[5];
struct _ymmh_state
  __uint32_t ymmh_space[64];
struct _xstate
  struct _fpstate fpstate;
  struct _xsave_hdr xstate_hdr;
  struct _ymmh_state ymmh;
# 333 "/usr/include/signal.h" 2 3 4
extern int sigreturn (struct sigcontext *__scp) __attribute__ ((__nothrow__ , __leaf__));
# 343 "/usr/include/signal.h" 2 3 4
extern int siginterrupt (int __sig, int __interrupt) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/bits/sigstack.h" 1 3 4
# 25 "/usr/include/bits/sigstack.h" 3 4
struct sigstack
    void *ss_sp;
    int ss_onstack;
enum
  SS_ONSTACK = 1,
  SS_DISABLE
# 49 "/usr/include/bits/sigstack.h" 3 4
typedef struct sigaltstack
    void *ss_sp;
    int ss_flags;
    size_t ss_size;
  } stack_t;
# 350 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/sys/ucontext.h" 1 3 4
# 22 "/usr/include/sys/ucontext.h" 3 4
# 23 "/usr/include/sys/ucontext.h" 2 3 4
# 31 "/usr/include/sys/ucontext.h" 3 4
__extension__ typedef long long int greg_t;
typedef greg_t gregset_t[23];
# 92 "/usr/include/sys/ucontext.h" 3 4
struct _libc_fpxreg
  unsigned short int significand[4];
  unsigned short int exponent;
  unsigned short int padding[3];
struct _libc_xmmreg
  __uint16_t cwd;
  __uint16_t swd;
  __uint16_t ftw;
  __uint16_t fop;
  __uint64_t rip;
  __uint64_t rdp;
  __uint32_t mxcsr;
  struct _libc_fpxreg _st[8];
  struct _libc_xmmreg _xmm[16];
typedef struct _libc_fpstate *fpregset_t;
typedef struct
    gregset_t gregs;
    fpregset_t fpregs;
    __extension__ unsigned long long __reserved1 [8];
} mcontext_t;
typedef struct ucontext
    unsigned long int uc_flags;
    struct ucontext *uc_link;
    stack_t uc_stack;
    mcontext_t uc_mcontext;
    __sigset_t uc_sigmask;
    struct _libc_fpstate __fpregs_mem;
  } ucontext_t;
# 353 "/usr/include/signal.h" 2 3 4
extern int sigstack (struct sigstack *__ss, struct sigstack *__oss)
extern int sigaltstack (const struct sigaltstack *__restrict __ss,
   struct sigaltstack *__restrict __oss) __attribute__ ((__nothrow__ , __leaf__));
# 388 "/usr/include/signal.h" 3 4
# 29 "/usr/include/sys/param.h" 2 3 4
# 1 "/usr/include/bits/param.h" 1 3 4
# 28 "/usr/include/bits/param.h" 3 4
# 1 "/usr/include/linux/param.h" 1 3 4
# 1 "/usr/include/asm/param.h" 1 3 4
# 1 "/usr/include/asm-generic/param.h" 1 3 4
# 1 "/usr/include/asm/param.h" 2 3 4
# 5 "/usr/include/linux/param.h" 2 3 4
# 29 "/usr/include/bits/param.h" 2 3 4
# 32 "/usr/include/sys/param.h" 2 3 4
            Defined "HAVE_SYS_PARAM_H" to "1"
Checking for header: netdb.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/netdb.h" 1 3 4
# 25 "/usr/include/netdb.h" 3 4
# 26 "/usr/include/netdb.h" 2 3 4
# 1 "/usr/include/netinet/in.h" 1 3 4
# 22 "/usr/include/netinet/in.h" 3 4
# 26 "/usr/include/stdint.h" 3 4
# 23 "/usr/include/netinet/in.h" 2 3 4
# 1 "/usr/include/sys/socket.h" 1 3 4
# 24 "/usr/include/sys/socket.h" 3 4
# 1 "/usr/include/sys/uio.h" 1 3 4
# 23 "/usr/include/sys/uio.h" 3 4
# 27 "/usr/include/sys/types.h" 3 4
# 200 "/usr/include/sys/types.h" 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 24 "/usr/include/sys/uio.h" 2 3 4
# 1 "/usr/include/bits/uio.h" 1 3 4
# 43 "/usr/include/bits/uio.h" 3 4
struct iovec
    void *iov_base;
    size_t iov_len;
# 29 "/usr/include/sys/uio.h" 2 3 4
# 39 "/usr/include/sys/uio.h" 3 4
extern ssize_t readv (int __fd, const struct iovec *__iovec, int __count)
# 50 "/usr/include/sys/uio.h" 3 4
extern ssize_t writev (int __fd, const struct iovec *__iovec, int __count)
# 65 "/usr/include/sys/uio.h" 3 4
extern ssize_t preadv (int __fd, const struct iovec *__iovec, int __count,
         __off_t __offset) ;
# 77 "/usr/include/sys/uio.h" 3 4
extern ssize_t pwritev (int __fd, const struct iovec *__iovec, int __count,
   __off_t __offset) ;
# 120 "/usr/include/sys/uio.h" 3 4
# 27 "/usr/include/sys/socket.h" 2 3 4
# 29 "/usr/include/sys/socket.h" 2 3 4
# 38 "/usr/include/sys/socket.h" 3 4
# 1 "/usr/include/bits/socket.h" 1 3 4
# 27 "/usr/include/bits/socket.h" 3 4
# 28 "/usr/include/bits/socket.h" 2 3 4
typedef __socklen_t socklen_t;
# 1 "/usr/include/bits/socket_type.h" 1 3 4
# 24 "/usr/include/bits/socket_type.h" 3 4
enum __socket_type
  SOCK_STREAM = 1,
  SOCK_DGRAM = 2,
  SOCK_RAW = 3,
  SOCK_RDM = 4,
  SOCK_SEQPACKET = 5,
  SOCK_DCCP = 6,
  SOCK_PACKET = 10,
  SOCK_CLOEXEC = 02000000,
  SOCK_NONBLOCK = 00004000
# 39 "/usr/include/bits/socket.h" 2 3 4
# 146 "/usr/include/bits/socket.h" 3 4
# 1 "/usr/include/bits/sockaddr.h" 1 3 4
# 28 "/usr/include/bits/sockaddr.h" 3 4
typedef unsigned short int sa_family_t;
# 147 "/usr/include/bits/socket.h" 2 3 4
struct sockaddr
    sa_family_t sa_family;
    char sa_data[14];
# 162 "/usr/include/bits/socket.h" 3 4
struct sockaddr_storage
    sa_family_t ss_family;
    unsigned long int __ss_align;
    char __ss_padding[(128 - (2 * sizeof (unsigned long int)))];
enum
    MSG_OOB = 0x01,
    MSG_PEEK = 0x02,
    MSG_DONTROUTE = 0x04,
    MSG_CTRUNC = 0x08,
    MSG_PROXY = 0x10,
    MSG_TRUNC = 0x20,
    MSG_DONTWAIT = 0x40,
    MSG_EOR = 0x80,
    MSG_WAITALL = 0x100,
    MSG_FIN = 0x200,
    MSG_SYN = 0x400,
    MSG_CONFIRM = 0x800,
    MSG_RST = 0x1000,
    MSG_ERRQUEUE = 0x2000,
    MSG_NOSIGNAL = 0x4000,
    MSG_MORE = 0x8000,
    MSG_WAITFORONE = 0x10000,
    MSG_FASTOPEN = 0x20000000,
    MSG_CMSG_CLOEXEC = 0x40000000
struct msghdr
    void *msg_name;
    socklen_t msg_namelen;
    struct iovec *msg_iov;
    size_t msg_iovlen;
    void *msg_control;
    size_t msg_controllen;
    int msg_flags;
struct cmsghdr
    size_t cmsg_len;
    int cmsg_level;
    int cmsg_type;
    __extension__ unsigned char __cmsg_data [];
# 272 "/usr/include/bits/socket.h" 3 4
extern struct cmsghdr *__cmsg_nxthdr (struct msghdr *__mhdr,
          struct cmsghdr *__cmsg) __attribute__ ((__nothrow__ , __leaf__));
# 299 "/usr/include/bits/socket.h" 3 4
enum
    SCM_RIGHTS = 0x01
# 345 "/usr/include/bits/socket.h" 3 4
# 1 "/usr/include/asm/socket.h" 1 3 4
# 1 "/usr/include/asm-generic/socket.h" 1 3 4
# 1 "/usr/include/asm/sockios.h" 1 3 4
# 1 "/usr/include/asm-generic/sockios.h" 1 3 4
# 1 "/usr/include/asm/sockios.h" 2 3 4
# 5 "/usr/include/asm-generic/socket.h" 2 3 4
# 1 "/usr/include/asm/socket.h" 2 3 4
# 346 "/usr/include/bits/socket.h" 2 3 4
# 379 "/usr/include/bits/socket.h" 3 4
struct linger
    int l_onoff;
    int l_linger;
# 39 "/usr/include/sys/socket.h" 2 3 4
struct osockaddr
    unsigned short int sa_family;
    unsigned char sa_data[14];
enum
  SHUT_RD = 0,
  SHUT_WR,
  SHUT_RDWR
# 113 "/usr/include/sys/socket.h" 3 4
extern int socket (int __domain, int __type, int __protocol) __attribute__ ((__nothrow__ , __leaf__));
extern int socketpair (int __domain, int __type, int __protocol,
         int __fds[2]) __attribute__ ((__nothrow__ , __leaf__));
extern int bind (int __fd, const struct sockaddr * __addr, socklen_t __len)
extern int getsockname (int __fd, struct sockaddr *__restrict __addr,
   socklen_t *__restrict __len) __attribute__ ((__nothrow__ , __leaf__));
# 137 "/usr/include/sys/socket.h" 3 4
extern int connect (int __fd, const struct sockaddr * __addr, socklen_t __len);
extern int getpeername (int __fd, struct sockaddr *__restrict __addr,
extern ssize_t send (int __fd, const void *__buf, size_t __n, int __flags);
extern ssize_t recv (int __fd, void *__buf, size_t __n, int __flags);
extern ssize_t sendto (int __fd, const void *__buf, size_t __n,
         int __flags, const struct sockaddr * __addr,
         socklen_t __addr_len);
# 174 "/usr/include/sys/socket.h" 3 4
extern ssize_t recvfrom (int __fd, void *__restrict __buf, size_t __n,
    int __flags, struct sockaddr *__restrict __addr,
    socklen_t *__restrict __addr_len);
extern ssize_t sendmsg (int __fd, const struct msghdr *__message,
   int __flags);
# 202 "/usr/include/sys/socket.h" 3 4
extern ssize_t recvmsg (int __fd, struct msghdr *__message, int __flags);
# 219 "/usr/include/sys/socket.h" 3 4
extern int getsockopt (int __fd, int __level, int __optname,
         void *__restrict __optval,
         socklen_t *__restrict __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int setsockopt (int __fd, int __level, int __optname,
         const void *__optval, socklen_t __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int listen (int __fd, int __n) __attribute__ ((__nothrow__ , __leaf__));
# 243 "/usr/include/sys/socket.h" 3 4
extern int accept (int __fd, struct sockaddr *__restrict __addr,
# 261 "/usr/include/sys/socket.h" 3 4
extern int shutdown (int __fd, int __how) __attribute__ ((__nothrow__ , __leaf__));
extern int sockatmark (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int isfdtype (int __fd, int __fdtype) __attribute__ ((__nothrow__ , __leaf__));
# 283 "/usr/include/sys/socket.h" 3 4
# 24 "/usr/include/netinet/in.h" 2 3 4
typedef uint32_t in_addr_t;
struct in_addr
    in_addr_t s_addr;
# 1 "/usr/include/bits/in.h" 1 3 4
# 138 "/usr/include/bits/in.h" 3 4
struct ip_opts
    struct in_addr ip_dst;
    char ip_opts[40];
struct ip_mreqn
    struct in_addr imr_multiaddr;
    struct in_addr imr_address;
    int imr_ifindex;
struct in_pktinfo
    int ipi_ifindex;
    struct in_addr ipi_spec_dst;
    struct in_addr ipi_addr;
# 38 "/usr/include/netinet/in.h" 2 3 4
enum
    IPPROTO_IP = 0,
    IPPROTO_ICMP = 1,
    IPPROTO_IGMP = 2,
    IPPROTO_IPIP = 4,
    IPPROTO_TCP = 6,
    IPPROTO_EGP = 8,
    IPPROTO_PUP = 12,
    IPPROTO_UDP = 17,
    IPPROTO_IDP = 22,
    IPPROTO_TP = 29,
    IPPROTO_DCCP = 33,
    IPPROTO_IPV6 = 41,
    IPPROTO_RSVP = 46,
    IPPROTO_GRE = 47,
    IPPROTO_ESP = 50,
    IPPROTO_AH = 51,
    IPPROTO_MTP = 92,
    IPPROTO_BEETPH = 94,
    IPPROTO_ENCAP = 98,
    IPPROTO_PIM = 103,
    IPPROTO_COMP = 108,
    IPPROTO_SCTP = 132,
    IPPROTO_UDPLITE = 136,
    IPPROTO_RAW = 255,
    IPPROTO_MAX
enum
    IPPROTO_HOPOPTS = 0,
    IPPROTO_ROUTING = 43,
    IPPROTO_FRAGMENT = 44,
    IPPROTO_ICMPV6 = 58,
    IPPROTO_NONE = 59,
    IPPROTO_DSTOPTS = 60,
    IPPROTO_MH = 135
typedef uint16_t in_port_t;
enum
    IPPORT_ECHO = 7,
    IPPORT_DISCARD = 9,
    IPPORT_SYSTAT = 11,
    IPPORT_DAYTIME = 13,
    IPPORT_NETSTAT = 15,
    IPPORT_FTP = 21,
    IPPORT_TELNET = 23,
    IPPORT_SMTP = 25,
    IPPORT_TIMESERVER = 37,
    IPPORT_NAMESERVER = 42,
    IPPORT_WHOIS = 43,
    IPPORT_MTP = 57,
    IPPORT_TFTP = 69,
    IPPORT_RJE = 77,
    IPPORT_FINGER = 79,
    IPPORT_TTYLINK = 87,
    IPPORT_SUPDUP = 95,
    IPPORT_EXECSERVER = 512,
    IPPORT_LOGINSERVER = 513,
    IPPORT_CMDSERVER = 514,
    IPPORT_EFSSERVER = 520,
    IPPORT_BIFFUDP = 512,
    IPPORT_WHOSERVER = 513,
    IPPORT_ROUTESERVER = 520,
    IPPORT_RESERVED = 1024,
    IPPORT_USERRESERVED = 5000
# 209 "/usr/include/netinet/in.h" 3 4
struct in6_addr
    union
 uint8_t __u6_addr8[16];
 uint16_t __u6_addr16[8];
 uint32_t __u6_addr32[4];
      } __in6_u;
extern const struct in6_addr in6addr_any;
extern const struct in6_addr in6addr_loopback;
# 237 "/usr/include/netinet/in.h" 3 4
struct sockaddr_in
    sa_family_t sin_family;
    in_port_t sin_port;
    struct in_addr sin_addr;
    unsigned char sin_zero[sizeof (struct sockaddr) -
      (sizeof (unsigned short int)) -
      sizeof (in_port_t) -
      sizeof (struct in_addr)];
struct sockaddr_in6
    sa_family_t sin6_family;
    in_port_t sin6_port;
    uint32_t sin6_flowinfo;
    struct in6_addr sin6_addr;
    uint32_t sin6_scope_id;
struct ip_mreq
    struct in_addr imr_interface;
struct ip_mreq_source
    struct in_addr imr_sourceaddr;
struct ipv6_mreq
    struct in6_addr ipv6mr_multiaddr;
    unsigned int ipv6mr_interface;
struct group_req
    uint32_t gr_interface;
    struct sockaddr_storage gr_group;
struct group_source_req
    uint32_t gsr_interface;
    struct sockaddr_storage gsr_group;
    struct sockaddr_storage gsr_source;
struct ip_msfilter
    struct in_addr imsf_multiaddr;
    struct in_addr imsf_interface;
    uint32_t imsf_fmode;
    uint32_t imsf_numsrc;
    struct in_addr imsf_slist[1];
struct group_filter
    uint32_t gf_interface;
    struct sockaddr_storage gf_group;
    uint32_t gf_fmode;
    uint32_t gf_numsrc;
    struct sockaddr_storage gf_slist[1];
# 374 "/usr/include/netinet/in.h" 3 4
extern uint32_t ntohl (uint32_t __netlong) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern uint16_t ntohs (uint16_t __netshort)
extern uint32_t htonl (uint32_t __hostlong)
extern uint16_t htons (uint16_t __hostshort)
# 386 "/usr/include/netinet/in.h" 2 3 4
# 501 "/usr/include/netinet/in.h" 3 4
extern int bindresvport (int __sockfd, struct sockaddr_in *__sock_in) __attribute__ ((__nothrow__ , __leaf__));
extern int bindresvport6 (int __sockfd, struct sockaddr_in6 *__sock_in)
# 628 "/usr/include/netinet/in.h" 3 4
# 28 "/usr/include/netdb.h" 2 3 4
# 1 "/usr/include/rpc/netdb.h" 1 3 4
# 42 "/usr/include/rpc/netdb.h" 3 4
# 43 "/usr/include/rpc/netdb.h" 2 3 4
struct rpcent
  char *r_name;
  char **r_aliases;
  int r_number;
extern void setrpcent (int __stayopen) __attribute__ ((__nothrow__ , __leaf__));
extern void endrpcent (void) __attribute__ ((__nothrow__ , __leaf__));
extern struct rpcent *getrpcbyname (const char *__name) __attribute__ ((__nothrow__ , __leaf__));
extern struct rpcent *getrpcbynumber (int __number) __attribute__ ((__nothrow__ , __leaf__));
extern struct rpcent *getrpcent (void) __attribute__ ((__nothrow__ , __leaf__));
extern int getrpcbyname_r (const char *__name, struct rpcent *__result_buf,
      char *__buffer, size_t __buflen,
      struct rpcent **__result) __attribute__ ((__nothrow__ , __leaf__));
extern int getrpcbynumber_r (int __number, struct rpcent *__result_buf,
extern int getrpcent_r (struct rpcent *__result_buf, char *__buffer,
   size_t __buflen, struct rpcent **__result) __attribute__ ((__nothrow__ , __leaf__));
# 33 "/usr/include/netdb.h" 2 3 4
# 42 "/usr/include/netdb.h" 3 4
# 1 "/usr/include/bits/netdb.h" 1 3 4
# 26 "/usr/include/bits/netdb.h" 3 4
struct netent
  char *n_name;
  char **n_aliases;
  int n_addrtype;
  uint32_t n_net;
# 43 "/usr/include/netdb.h" 2 3 4
# 53 "/usr/include/netdb.h" 3 4
extern int *__h_errno_location (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 92 "/usr/include/netdb.h" 3 4
extern void herror (const char *__str) __attribute__ ((__nothrow__ , __leaf__));
extern const char *hstrerror (int __err_num) __attribute__ ((__nothrow__ , __leaf__));
struct hostent
  char *h_name;
  char **h_aliases;
  int h_addrtype;
  int h_length;
  char **h_addr_list;
extern void sethostent (int __stay_open);
extern void endhostent (void);
extern struct hostent *gethostent (void);
extern struct hostent *gethostbyaddr (const void *__addr, __socklen_t __len,
          int __type);
extern struct hostent *gethostbyname (const char *__name);
# 155 "/usr/include/netdb.h" 3 4
extern struct hostent *gethostbyname2 (const char *__name, int __af);
# 167 "/usr/include/netdb.h" 3 4
extern int gethostent_r (struct hostent *__restrict __result_buf,
    char *__restrict __buf, size_t __buflen,
    struct hostent **__restrict __result,
    int *__restrict __h_errnop);
extern int gethostbyaddr_r (const void *__restrict __addr, __socklen_t __len,
       int __type,
extern int gethostbyname_r (const char *__restrict __name,
extern int gethostbyname2_r (const char *__restrict __name, int __af,
# 198 "/usr/include/netdb.h" 3 4
extern void setnetent (int __stay_open);
extern void endnetent (void);
extern struct netent *getnetent (void);
extern struct netent *getnetbyaddr (uint32_t __net, int __type);
extern struct netent *getnetbyname (const char *__name);
# 237 "/usr/include/netdb.h" 3 4
extern int getnetent_r (struct netent *__restrict __result_buf,
   struct netent **__restrict __result,
extern int getnetbyaddr_r (uint32_t __net, int __type,
extern int getnetbyname_r (const char *__restrict __name,
struct servent
  char *s_name;
  char **s_aliases;
  int s_port;
  char *s_proto;
extern void setservent (int __stay_open);
extern void endservent (void);
extern struct servent *getservent (void);
extern struct servent *getservbyname (const char *__name, const char *__proto);
extern struct servent *getservbyport (int __port, const char *__proto);
# 308 "/usr/include/netdb.h" 3 4
extern int getservent_r (struct servent *__restrict __result_buf,
    struct servent **__restrict __result);
extern int getservbyname_r (const char *__restrict __name,
       const char *__restrict __proto,
extern int getservbyport_r (int __port, const char *__restrict __proto,
struct protoent
  char *p_name;
  char **p_aliases;
  int p_proto;
extern void setprotoent (int __stay_open);
extern void endprotoent (void);
extern struct protoent *getprotoent (void);
extern struct protoent *getprotobyname (const char *__name);
extern struct protoent *getprotobynumber (int __proto);
# 374 "/usr/include/netdb.h" 3 4
extern int getprotoent_r (struct protoent *__restrict __result_buf,
     struct protoent **__restrict __result);
extern int getprotobyname_r (const char *__restrict __name,
extern int getprotobynumber_r (int __proto,
# 395 "/usr/include/netdb.h" 3 4
extern int setnetgrent (const char *__netgroup);
extern void endnetgrent (void);
# 412 "/usr/include/netdb.h" 3 4
extern int getnetgrent (char **__restrict __hostp,
   char **__restrict __userp,
   char **__restrict __domainp);
# 423 "/usr/include/netdb.h" 3 4
extern int innetgr (const char *__netgroup, const char *__host,
      const char *__user, const char *__domain);
extern int getnetgrent_r (char **__restrict __hostp,
     char **__restrict __domainp,
     char *__restrict __buffer, size_t __buflen);
# 451 "/usr/include/netdb.h" 3 4
extern int rcmd (char **__restrict __ahost, unsigned short int __rport,
   const char *__restrict __locuser,
   const char *__restrict __remuser,
   const char *__restrict __cmd, int *__restrict __fd2p);
# 463 "/usr/include/netdb.h" 3 4
extern int rcmd_af (char **__restrict __ahost, unsigned short int __rport,
      const char *__restrict __cmd, int *__restrict __fd2p,
      sa_family_t __af);
# 479 "/usr/include/netdb.h" 3 4
extern int rexec (char **__restrict __ahost, int __rport,
    const char *__restrict __pass,
# 491 "/usr/include/netdb.h" 3 4
extern int rexec_af (char **__restrict __ahost, int __rport,
       sa_family_t __af);
# 505 "/usr/include/netdb.h" 3 4
extern int ruserok (const char *__rhost, int __suser,
      const char *__remuser, const char *__locuser);
# 515 "/usr/include/netdb.h" 3 4
extern int ruserok_af (const char *__rhost, int __suser,
         const char *__remuser, const char *__locuser,
         sa_family_t __af);
# 528 "/usr/include/netdb.h" 3 4
extern int iruserok (uint32_t __raddr, int __suser,
# 539 "/usr/include/netdb.h" 3 4
extern int iruserok_af (const void *__raddr, int __suser,
   sa_family_t __af);
# 551 "/usr/include/netdb.h" 3 4
extern int rresvport (int *__alport);
# 560 "/usr/include/netdb.h" 3 4
extern int rresvport_af (int *__alport, sa_family_t __af);
struct addrinfo
  int ai_flags;
  int ai_family;
  int ai_socktype;
  int ai_protocol;
  socklen_t ai_addrlen;
  struct sockaddr *ai_addr;
  char *ai_canonname;
  struct addrinfo *ai_next;
# 662 "/usr/include/netdb.h" 3 4
extern int getaddrinfo (const char *__restrict __name,
   const char *__restrict __service,
   const struct addrinfo *__restrict __req,
   struct addrinfo **__restrict __pai);
extern void freeaddrinfo (struct addrinfo *__ai) __attribute__ ((__nothrow__ , __leaf__));
extern const char *gai_strerror (int __ecode) __attribute__ ((__nothrow__ , __leaf__));
extern int getnameinfo (const struct sockaddr *__restrict __sa,
   socklen_t __salen, char *__restrict __host,
   socklen_t __hostlen, char *__restrict __serv,
   socklen_t __servlen, int __flags);
# 713 "/usr/include/netdb.h" 3 4
            Defined "HAVE_NETDB_H" to "1"
TEST check from config.headers(/home/jed/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: search.h
Executing: /opt/mpich/bin/mpicc -E  -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.headers  /tmp/petsc-lhuj9c/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-lhuj9c/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/conffix.h" 1
# 1 "/usr/include/search.h" 1 3 4
# 22 "/usr/include/search.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 395 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 396 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 23 "/usr/include/search.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 26 "/usr/include/search.h" 2 3 4
# 44 "/usr/include/search.h" 3 4
extern void insque (void *__elem, void *__prev) __attribute__ ((__nothrow__ , __leaf__));
extern void remque (void *__elem) __attribute__ ((__nothrow__ , __leaf__));
typedef int (*__compar_fn_t) (const void *, const void *);
typedef enum
    FIND,
    ENTER
ACTION;
typedef struct entry
    char *key;
    void *data;
ENTRY;
struct _ENTRY;
# 87 "/usr/include/search.h" 3 4
extern ENTRY *hsearch (ENTRY __item, ACTION __action) __attribute__ ((__nothrow__ , __leaf__));
extern int hcreate (size_t __nel) __attribute__ ((__nothrow__ , __leaf__));
extern void hdestroy (void) __attribute__ ((__nothrow__ , __leaf__));
# 118 "/usr/include/search.h" 3 4
typedef enum
  preorder,
  postorder,
  endorder,
  leaf
VISIT;
extern void *tsearch (const void *__key, void **__rootp,
        __compar_fn_t __compar);
extern void *tfind (const void *__key, void *const *__rootp,
extern void *tdelete (const void *__restrict __key,
        void **__restrict __rootp,
typedef void (*__action_fn_t) (const void *__nodep, VISIT __value,
          int __level);
extern void twalk (const void *__root, __action_fn_t __action);
# 164 "/usr/include/search.h" 3 4
extern void *lfind (const void *__key, const void *__base,
      size_t *__nmemb, size_t __size, __compar_fn_t __compar);
extern void *lsearch (const void *__key, void *__base,
            Defined "HAVE_SEARCH_H" to "1"
Checking for header: mathimf.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-lhuj9c/config.headers/conftest.c:3:21: fatal error: mathimf.h: No such file or directory
 #include <mathimf.h>
Source:
Checking for header: sys/procfs.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/procfs.h" 1 3 4
# 30 "/usr/include/sys/procfs.h" 3 4
# 31 "/usr/include/sys/procfs.h" 2 3 4
# 1 "/usr/include/sys/time.h" 1 3 4
# 23 "/usr/include/sys/time.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 24 "/usr/include/sys/time.h" 2 3 4
# 1 "/usr/include/time.h" 1 3 4
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 26 "/usr/include/sys/time.h" 2 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
struct timeval
    __time_t tv_sec;
# 28 "/usr/include/sys/time.h" 2 3 4
typedef struct
  } __sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
typedef struct
  } fd_set;
# 30 "/usr/include/sys/time.h" 2 3 4
# 55 "/usr/include/sys/time.h" 3 4
struct timezone
    int tz_minuteswest;
    int tz_dsttime;
typedef struct timezone *__restrict __timezone_ptr_t;
# 71 "/usr/include/sys/time.h" 3 4
extern int gettimeofday (struct timeval *__restrict __tv,
    __timezone_ptr_t __tz) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int settimeofday (const struct timeval *__tv,
    const struct timezone *__tz)
extern int adjtime (const struct timeval *__delta,
      struct timeval *__olddelta) __attribute__ ((__nothrow__ , __leaf__));
enum __itimer_which
    ITIMER_REAL = 0,
    ITIMER_VIRTUAL = 1,
    ITIMER_PROF = 2
struct itimerval
    struct timeval it_interval;
    struct timeval it_value;
typedef int __itimer_which_t;
extern int getitimer (__itimer_which_t __which,
        struct itimerval *__value) __attribute__ ((__nothrow__ , __leaf__));
extern int setitimer (__itimer_which_t __which,
        const struct itimerval *__restrict __new,
        struct itimerval *__restrict __old) __attribute__ ((__nothrow__ , __leaf__));
extern int utimes (const char *__file, const struct timeval __tvp[2])
extern int lutimes (const char *__file, const struct timeval __tvp[2])
extern int futimes (int __fd, const struct timeval __tvp[2]) __attribute__ ((__nothrow__ , __leaf__));
# 189 "/usr/include/sys/time.h" 3 4
# 32 "/usr/include/sys/procfs.h" 2 3 4
typedef __pid_t pid_t;
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
__extension__
__extension__
__extension__
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 33 "/usr/include/sys/procfs.h" 2 3 4
# 1 "/usr/include/sys/user.h" 1 3 4
# 27 "/usr/include/sys/user.h" 3 4
struct user_fpregs_struct
  unsigned short int cwd;
  unsigned short int swd;
  unsigned short int ftw;
  unsigned short int fop;
  __extension__ unsigned long long int rip;
  __extension__ unsigned long long int rdp;
  unsigned int mxcsr;
  unsigned int mxcr_mask;
  unsigned int st_space[32];
  unsigned int xmm_space[64];
  unsigned int padding[24];
struct user_regs_struct
  __extension__ unsigned long long int r15;
  __extension__ unsigned long long int r14;
  __extension__ unsigned long long int r13;
  __extension__ unsigned long long int r12;
  __extension__ unsigned long long int rbp;
  __extension__ unsigned long long int rbx;
  __extension__ unsigned long long int r11;
  __extension__ unsigned long long int r10;
  __extension__ unsigned long long int r9;
  __extension__ unsigned long long int r8;
  __extension__ unsigned long long int rax;
  __extension__ unsigned long long int rcx;
  __extension__ unsigned long long int rdx;
  __extension__ unsigned long long int rsi;
  __extension__ unsigned long long int rdi;
  __extension__ unsigned long long int orig_rax;
  __extension__ unsigned long long int cs;
  __extension__ unsigned long long int eflags;
  __extension__ unsigned long long int rsp;
  __extension__ unsigned long long int ss;
  __extension__ unsigned long long int fs_base;
  __extension__ unsigned long long int gs_base;
  __extension__ unsigned long long int ds;
  __extension__ unsigned long long int es;
  __extension__ unsigned long long int fs;
  __extension__ unsigned long long int gs;
struct user
  struct user_regs_struct regs;
  int u_fpvalid;
  struct user_fpregs_struct i387;
  __extension__ unsigned long long int u_tsize;
  __extension__ unsigned long long int u_dsize;
  __extension__ unsigned long long int u_ssize;
  __extension__ unsigned long long int start_code;
  __extension__ unsigned long long int start_stack;
  __extension__ long long int signal;
  int reserved;
  __extension__ union
      struct user_regs_struct* u_ar0;
      __extension__ unsigned long long int __u_ar0_word;
  __extension__ union
      struct user_fpregs_struct* u_fpstate;
      __extension__ unsigned long long int __u_fpstate_word;
  __extension__ unsigned long long int magic;
  char u_comm [32];
  __extension__ unsigned long long int u_debugreg [8];
# 34 "/usr/include/sys/procfs.h" 2 3 4
__extension__ typedef unsigned long long elf_greg_t;
# 49 "/usr/include/sys/procfs.h" 3 4
typedef elf_greg_t elf_gregset_t[(sizeof (struct user_regs_struct) / sizeof(elf_greg_t))];
# 63 "/usr/include/sys/procfs.h" 3 4
typedef struct user_fpregs_struct elf_fpregset_t;
struct elf_siginfo
    int si_signo;
    int si_code;
    int si_errno;
# 82 "/usr/include/sys/procfs.h" 3 4
struct elf_prstatus
    struct elf_siginfo pr_info;
    short int pr_cursig;
    unsigned long int pr_sigpend;
    unsigned long int pr_sighold;
    __pid_t pr_pid;
    __pid_t pr_ppid;
    __pid_t pr_pgrp;
    __pid_t pr_sid;
    struct timeval pr_utime;
    struct timeval pr_stime;
    struct timeval pr_cutime;
    struct timeval pr_cstime;
    elf_gregset_t pr_reg;
    int pr_fpvalid;
struct elf_prpsinfo
    char pr_state;
    char pr_sname;
    char pr_zomb;
    char pr_nice;
    unsigned long int pr_flag;
    unsigned int pr_uid;
    unsigned int pr_gid;
    int pr_pid, pr_ppid, pr_pgrp, pr_sid;
    char pr_fname[16];
    char pr_psargs[(80)];
typedef void *psaddr_t;
typedef elf_gregset_t prgregset_t;
typedef elf_fpregset_t prfpregset_t;
typedef __pid_t lwpid_t;
typedef struct elf_prstatus prstatus_t;
typedef struct elf_prpsinfo prpsinfo_t;
            Defined "HAVE_SYS_PROCFS_H" to "1"
Checking for header: sys/resource.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/resource.h" 1 3 4
# 21 "/usr/include/sys/resource.h" 3 4
# 22 "/usr/include/sys/resource.h" 2 3 4
# 1 "/usr/include/bits/resource.h" 1 3 4
# 23 "/usr/include/bits/resource.h" 3 4
# 24 "/usr/include/bits/resource.h" 2 3 4
enum __rlimit_resource
  RLIMIT_CPU = 0,
  RLIMIT_FSIZE = 1,
  RLIMIT_DATA = 2,
  RLIMIT_STACK = 3,
  RLIMIT_CORE = 4,
  __RLIMIT_RSS = 5,
  RLIMIT_NOFILE = 7,
  __RLIMIT_OFILE = RLIMIT_NOFILE,
  RLIMIT_AS = 9,
  __RLIMIT_NPROC = 6,
  __RLIMIT_MEMLOCK = 8,
  __RLIMIT_LOCKS = 10,
  __RLIMIT_SIGPENDING = 11,
  __RLIMIT_MSGQUEUE = 12,
  __RLIMIT_NICE = 13,
  __RLIMIT_RTPRIO = 14,
  __RLIMIT_RTTIME = 15,
  __RLIMIT_NLIMITS = 16,
  __RLIM_NLIMITS = __RLIMIT_NLIMITS
# 131 "/usr/include/bits/resource.h" 3 4
typedef __rlim_t rlim_t;
struct rlimit
    rlim_t rlim_cur;
    rlim_t rlim_max;
# 158 "/usr/include/bits/resource.h" 3 4
enum __rusage_who
  RUSAGE_SELF = 0,
  RUSAGE_CHILDREN = -1
# 176 "/usr/include/bits/resource.h" 3 4
struct timeval
    __time_t tv_sec;
# 180 "/usr/include/bits/resource.h" 2 3 4
struct rusage
    struct timeval ru_utime;
    struct timeval ru_stime;
    __extension__ union
 long int ru_maxrss;
 __syscall_slong_t __ru_maxrss_word;
    __extension__ union
 long int ru_ixrss;
 __syscall_slong_t __ru_ixrss_word;
    __extension__ union
 long int ru_idrss;
 __syscall_slong_t __ru_idrss_word;
    __extension__ union
 long int ru_isrss;
  __syscall_slong_t __ru_isrss_word;
    __extension__ union
 long int ru_minflt;
 __syscall_slong_t __ru_minflt_word;
    __extension__ union
 long int ru_majflt;
 __syscall_slong_t __ru_majflt_word;
    __extension__ union
 long int ru_nswap;
 __syscall_slong_t __ru_nswap_word;
    __extension__ union
 long int ru_inblock;
 __syscall_slong_t __ru_inblock_word;
    __extension__ union
 long int ru_oublock;
 __syscall_slong_t __ru_oublock_word;
    __extension__ union
 long int ru_msgsnd;
 __syscall_slong_t __ru_msgsnd_word;
    __extension__ union
 long int ru_msgrcv;
 __syscall_slong_t __ru_msgrcv_word;
    __extension__ union
 long int ru_nsignals;
 __syscall_slong_t __ru_nsignals_word;
    __extension__ union
 long int ru_nvcsw;
 __syscall_slong_t __ru_nvcsw_word;
    __extension__ union
 long int ru_nivcsw;
 __syscall_slong_t __ru_nivcsw_word;
enum __priority_which
  PRIO_PROCESS = 0,
  PRIO_PGRP = 1,
  PRIO_USER = 2
# 328 "/usr/include/bits/resource.h" 3 4
# 25 "/usr/include/sys/resource.h" 2 3 4
# 42 "/usr/include/sys/resource.h" 3 4
typedef int __rlimit_resource_t;
typedef int __rusage_who_t;
typedef int __priority_which_t;
extern int getrlimit (__rlimit_resource_t __resource,
        struct rlimit *__rlimits) __attribute__ ((__nothrow__ , __leaf__));
# 69 "/usr/include/sys/resource.h" 3 4
extern int setrlimit (__rlimit_resource_t __resource,
        const struct rlimit *__rlimits) __attribute__ ((__nothrow__ , __leaf__));
# 87 "/usr/include/sys/resource.h" 3 4
extern int getrusage (__rusage_who_t __who, struct rusage *__usage) __attribute__ ((__nothrow__ , __leaf__));
extern int getpriority (__priority_which_t __which, id_t __who) __attribute__ ((__nothrow__ , __leaf__));
extern int setpriority (__priority_which_t __which, id_t __who, int __prio)
            Defined "HAVE_SYS_RESOURCE_H" to "1"
Checking for header: unistd.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/unistd.h" 1 3 4
# 25 "/usr/include/unistd.h" 3 4
# 26 "/usr/include/unistd.h" 2 3 4
# 202 "/usr/include/unistd.h" 3 4
# 1 "/usr/include/bits/posix_opt.h" 1 3 4
# 203 "/usr/include/unistd.h" 2 3 4
# 1 "/usr/include/bits/environments.h" 1 3 4
# 22 "/usr/include/bits/environments.h" 3 4
# 23 "/usr/include/bits/environments.h" 2 3 4
# 207 "/usr/include/unistd.h" 2 3 4
# 217 "/usr/include/unistd.h" 3 4
# 218 "/usr/include/unistd.h" 2 3 4
# 227 "/usr/include/unistd.h" 2 3 4
# 255 "/usr/include/unistd.h" 3 4
typedef __useconds_t useconds_t;
typedef __intptr_t intptr_t;
# 287 "/usr/include/unistd.h" 3 4
extern int access (const char *__name, int __type) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 304 "/usr/include/unistd.h" 3 4
extern int faccessat (int __fd, const char *__file, int __type, int __flag)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2))) ;
# 334 "/usr/include/unistd.h" 3 4
extern __off_t lseek (int __fd, __off_t __offset, int __whence) __attribute__ ((__nothrow__ , __leaf__));
# 353 "/usr/include/unistd.h" 3 4
extern int close (int __fd);
extern ssize_t read (int __fd, void *__buf, size_t __nbytes) ;
extern ssize_t write (int __fd, const void *__buf, size_t __n) ;
# 376 "/usr/include/unistd.h" 3 4
extern ssize_t pread (int __fd, void *__buf, size_t __nbytes,
        __off_t __offset) ;
extern ssize_t pwrite (int __fd, const void *__buf, size_t __n,
         __off_t __offset) ;
# 417 "/usr/include/unistd.h" 3 4
extern int pipe (int __pipedes[2]) __attribute__ ((__nothrow__ , __leaf__)) ;
# 432 "/usr/include/unistd.h" 3 4
extern unsigned int alarm (unsigned int __seconds) __attribute__ ((__nothrow__ , __leaf__));
# 444 "/usr/include/unistd.h" 3 4
extern unsigned int sleep (unsigned int __seconds);
extern __useconds_t ualarm (__useconds_t __value, __useconds_t __interval)
extern int usleep (__useconds_t __useconds);
# 469 "/usr/include/unistd.h" 3 4
extern int pause (void);
extern int chown (const char *__file, __uid_t __owner, __gid_t __group)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern int fchown (int __fd, __uid_t __owner, __gid_t __group) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int lchown (const char *__file, __uid_t __owner, __gid_t __group)
extern int fchownat (int __fd, const char *__file, __uid_t __owner,
       __gid_t __group, int __flag)
extern int chdir (const char *__path) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern int fchdir (int __fd) __attribute__ ((__nothrow__ , __leaf__)) ;
# 511 "/usr/include/unistd.h" 3 4
extern char *getcwd (char *__buf, size_t __size) __attribute__ ((__nothrow__ , __leaf__)) ;
# 525 "/usr/include/unistd.h" 3 4
extern char *getwd (char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) __attribute__ ((__deprecated__)) ;
extern int dup (int __fd) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int dup2 (int __fd, int __fd2) __attribute__ ((__nothrow__ , __leaf__));
# 543 "/usr/include/unistd.h" 3 4
extern char **__environ;
extern int execve (const char *__path, char *const __argv[],
     char *const __envp[]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int fexecve (int __fd, char *const __argv[], char *const __envp[])
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern int execv (const char *__path, char *const __argv[])
extern int execle (const char *__path, const char *__arg, ...)
extern int execl (const char *__path, const char *__arg, ...)
extern int execvp (const char *__file, char *const __argv[])
extern int execlp (const char *__file, const char *__arg, ...)
# 598 "/usr/include/unistd.h" 3 4
extern int nice (int __inc) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void _exit (int __status) __attribute__ ((__noreturn__));
# 1 "/usr/include/bits/confname.h" 1 3 4
# 24 "/usr/include/bits/confname.h" 3 4
enum
    _PC_LINK_MAX,
    _PC_MAX_CANON,
    _PC_MAX_INPUT,
    _PC_NAME_MAX,
    _PC_PATH_MAX,
    _PC_PIPE_BUF,
    _PC_CHOWN_RESTRICTED,
    _PC_NO_TRUNC,
    _PC_VDISABLE,
    _PC_SYNC_IO,
    _PC_ASYNC_IO,
    _PC_PRIO_IO,
    _PC_SOCK_MAXBUF,
    _PC_FILESIZEBITS,
    _PC_REC_INCR_XFER_SIZE,
    _PC_REC_MAX_XFER_SIZE,
    _PC_REC_MIN_XFER_SIZE,
    _PC_REC_XFER_ALIGN,
    _PC_ALLOC_SIZE_MIN,
    _PC_SYMLINK_MAX,
    _PC_2_SYMLINKS
enum
    _SC_ARG_MAX,
    _SC_CHILD_MAX,
    _SC_CLK_TCK,
    _SC_NGROUPS_MAX,
    _SC_OPEN_MAX,
    _SC_STREAM_MAX,
    _SC_TZNAME_MAX,
    _SC_JOB_CONTROL,
    _SC_SAVED_IDS,
    _SC_REALTIME_SIGNALS,
    _SC_PRIORITY_SCHEDULING,
    _SC_TIMERS,
    _SC_ASYNCHRONOUS_IO,
    _SC_PRIORITIZED_IO,
    _SC_SYNCHRONIZED_IO,
    _SC_FSYNC,
    _SC_MAPPED_FILES,
    _SC_MEMLOCK,
    _SC_MEMLOCK_RANGE,
    _SC_MEMORY_PROTECTION,
    _SC_MESSAGE_PASSING,
    _SC_SEMAPHORES,
    _SC_SHARED_MEMORY_OBJECTS,
    _SC_AIO_LISTIO_MAX,
    _SC_AIO_MAX,
    _SC_AIO_PRIO_DELTA_MAX,
    _SC_DELAYTIMER_MAX,
    _SC_MQ_OPEN_MAX,
    _SC_MQ_PRIO_MAX,
    _SC_VERSION,
    _SC_PAGESIZE,
    _SC_RTSIG_MAX,
    _SC_SEM_NSEMS_MAX,
    _SC_SEM_VALUE_MAX,
    _SC_SIGQUEUE_MAX,
    _SC_TIMER_MAX,
    _SC_BC_BASE_MAX,
    _SC_BC_DIM_MAX,
    _SC_BC_SCALE_MAX,
    _SC_BC_STRING_MAX,
    _SC_COLL_WEIGHTS_MAX,
    _SC_EQUIV_CLASS_MAX,
    _SC_EXPR_NEST_MAX,
    _SC_LINE_MAX,
    _SC_RE_DUP_MAX,
    _SC_CHARCLASS_NAME_MAX,
    _SC_2_VERSION,
    _SC_2_C_BIND,
    _SC_2_C_DEV,
    _SC_2_FORT_DEV,
    _SC_2_FORT_RUN,
    _SC_2_SW_DEV,
    _SC_2_LOCALEDEF,
    _SC_PII,
    _SC_PII_XTI,
    _SC_PII_SOCKET,
    _SC_PII_INTERNET,
    _SC_PII_OSI,
    _SC_POLL,
    _SC_SELECT,
    _SC_UIO_MAXIOV,
    _SC_IOV_MAX = _SC_UIO_MAXIOV,
    _SC_PII_INTERNET_STREAM,
    _SC_PII_INTERNET_DGRAM,
    _SC_PII_OSI_COTS,
    _SC_PII_OSI_CLTS,
    _SC_PII_OSI_M,
    _SC_T_IOV_MAX,
    _SC_THREADS,
    _SC_THREAD_SAFE_FUNCTIONS,
    _SC_GETGR_R_SIZE_MAX,
    _SC_GETPW_R_SIZE_MAX,
    _SC_LOGIN_NAME_MAX,
    _SC_TTY_NAME_MAX,
    _SC_THREAD_DESTRUCTOR_ITERATIONS,
    _SC_THREAD_KEYS_MAX,
    _SC_THREAD_STACK_MIN,
    _SC_THREAD_THREADS_MAX,
    _SC_THREAD_ATTR_STACKADDR,
    _SC_THREAD_ATTR_STACKSIZE,
    _SC_THREAD_PRIORITY_SCHEDULING,
    _SC_THREAD_PRIO_INHERIT,
    _SC_THREAD_PRIO_PROTECT,
    _SC_THREAD_PROCESS_SHARED,
    _SC_NPROCESSORS_CONF,
    _SC_NPROCESSORS_ONLN,
    _SC_PHYS_PAGES,
    _SC_AVPHYS_PAGES,
    _SC_ATEXIT_MAX,
    _SC_PASS_MAX,
    _SC_XOPEN_VERSION,
    _SC_XOPEN_XCU_VERSION,
    _SC_XOPEN_UNIX,
    _SC_XOPEN_CRYPT,
    _SC_XOPEN_ENH_I18N,
    _SC_XOPEN_SHM,
    _SC_2_CHAR_TERM,
    _SC_2_C_VERSION,
    _SC_2_UPE,
    _SC_XOPEN_XPG2,
    _SC_XOPEN_XPG3,
    _SC_XOPEN_XPG4,
    _SC_CHAR_BIT,
    _SC_CHAR_MAX,
    _SC_CHAR_MIN,
    _SC_INT_MAX,
    _SC_INT_MIN,
    _SC_LONG_BIT,
    _SC_WORD_BIT,
    _SC_MB_LEN_MAX,
    _SC_NZERO,
    _SC_SSIZE_MAX,
    _SC_SCHAR_MAX,
    _SC_SCHAR_MIN,
    _SC_SHRT_MAX,
    _SC_SHRT_MIN,
    _SC_UCHAR_MAX,
    _SC_UINT_MAX,
    _SC_ULONG_MAX,
    _SC_USHRT_MAX,
    _SC_NL_ARGMAX,
    _SC_NL_LANGMAX,
    _SC_NL_MSGMAX,
    _SC_NL_NMAX,
    _SC_NL_SETMAX,
    _SC_NL_TEXTMAX,
    _SC_XBS5_ILP32_OFF32,
    _SC_XBS5_ILP32_OFFBIG,
    _SC_XBS5_LP64_OFF64,
    _SC_XBS5_LPBIG_OFFBIG,
    _SC_XOPEN_LEGACY,
    _SC_XOPEN_REALTIME,
    _SC_XOPEN_REALTIME_THREADS,
    _SC_ADVISORY_INFO,
    _SC_BARRIERS,
    _SC_BASE,
    _SC_C_LANG_SUPPORT,
    _SC_C_LANG_SUPPORT_R,
    _SC_CLOCK_SELECTION,
    _SC_CPUTIME,
    _SC_THREAD_CPUTIME,
    _SC_DEVICE_IO,
    _SC_DEVICE_SPECIFIC,
    _SC_DEVICE_SPECIFIC_R,
    _SC_FD_MGMT,
    _SC_FIFO,
    _SC_PIPE,
    _SC_FILE_ATTRIBUTES,
    _SC_FILE_LOCKING,
    _SC_FILE_SYSTEM,
    _SC_MONOTONIC_CLOCK,
    _SC_MULTI_PROCESS,
    _SC_SINGLE_PROCESS,
    _SC_NETWORKING,
    _SC_READER_WRITER_LOCKS,
    _SC_SPIN_LOCKS,
    _SC_REGEXP,
    _SC_REGEX_VERSION,
    _SC_SHELL,
    _SC_SIGNALS,
    _SC_SPAWN,
    _SC_SPORADIC_SERVER,
    _SC_THREAD_SPORADIC_SERVER,
    _SC_SYSTEM_DATABASE,
    _SC_SYSTEM_DATABASE_R,
    _SC_TIMEOUTS,
    _SC_TYPED_MEMORY_OBJECTS,
    _SC_USER_GROUPS,
    _SC_USER_GROUPS_R,
    _SC_2_PBS,
    _SC_2_PBS_ACCOUNTING,
    _SC_2_PBS_LOCATE,
    _SC_2_PBS_MESSAGE,
    _SC_2_PBS_TRACK,
    _SC_SYMLOOP_MAX,
    _SC_STREAMS,
    _SC_2_PBS_CHECKPOINT,
    _SC_V6_ILP32_OFF32,
    _SC_V6_ILP32_OFFBIG,
    _SC_V6_LP64_OFF64,
    _SC_V6_LPBIG_OFFBIG,
    _SC_HOST_NAME_MAX,
    _SC_TRACE,
    _SC_TRACE_EVENT_FILTER,
    _SC_TRACE_INHERIT,
    _SC_TRACE_LOG,
    _SC_LEVEL1_ICACHE_SIZE,
    _SC_LEVEL1_ICACHE_ASSOC,
    _SC_LEVEL1_ICACHE_LINESIZE,
    _SC_LEVEL1_DCACHE_SIZE,
    _SC_LEVEL1_DCACHE_ASSOC,
    _SC_LEVEL1_DCACHE_LINESIZE,
    _SC_LEVEL2_CACHE_SIZE,
    _SC_LEVEL2_CACHE_ASSOC,
    _SC_LEVEL2_CACHE_LINESIZE,
    _SC_LEVEL3_CACHE_SIZE,
    _SC_LEVEL3_CACHE_ASSOC,
    _SC_LEVEL3_CACHE_LINESIZE,
    _SC_LEVEL4_CACHE_SIZE,
    _SC_LEVEL4_CACHE_ASSOC,
    _SC_LEVEL4_CACHE_LINESIZE,
    _SC_IPV6 = _SC_LEVEL1_ICACHE_SIZE + 50,
    _SC_RAW_SOCKETS,
    _SC_V7_ILP32_OFF32,
    _SC_V7_ILP32_OFFBIG,
    _SC_V7_LP64_OFF64,
    _SC_V7_LPBIG_OFFBIG,
    _SC_SS_REPL_MAX,
    _SC_TRACE_EVENT_NAME_MAX,
    _SC_TRACE_NAME_MAX,
    _SC_TRACE_SYS_MAX,
    _SC_TRACE_USER_EVENT_MAX,
    _SC_XOPEN_STREAMS,
    _SC_THREAD_ROBUST_PRIO_INHERIT,
    _SC_THREAD_ROBUST_PRIO_PROTECT
enum
    _CS_PATH,
    _CS_V6_WIDTH_RESTRICTED_ENVS,
    _CS_GNU_LIBC_VERSION,
    _CS_GNU_LIBPTHREAD_VERSION,
    _CS_V5_WIDTH_RESTRICTED_ENVS,
    _CS_V7_WIDTH_RESTRICTED_ENVS,
    _CS_LFS_CFLAGS = 1000,
    _CS_LFS_LDFLAGS,
    _CS_LFS_LIBS,
    _CS_LFS_LINTFLAGS,
    _CS_LFS64_CFLAGS,
    _CS_LFS64_LDFLAGS,
    _CS_LFS64_LIBS,
    _CS_LFS64_LINTFLAGS,
    _CS_XBS5_ILP32_OFF32_CFLAGS = 1100,
    _CS_XBS5_ILP32_OFF32_LDFLAGS,
    _CS_XBS5_ILP32_OFF32_LIBS,
    _CS_XBS5_ILP32_OFF32_LINTFLAGS,
    _CS_XBS5_ILP32_OFFBIG_CFLAGS,
    _CS_XBS5_ILP32_OFFBIG_LDFLAGS,
    _CS_XBS5_ILP32_OFFBIG_LIBS,
    _CS_XBS5_ILP32_OFFBIG_LINTFLAGS,
    _CS_XBS5_LP64_OFF64_CFLAGS,
    _CS_XBS5_LP64_OFF64_LDFLAGS,
    _CS_XBS5_LP64_OFF64_LIBS,
    _CS_XBS5_LP64_OFF64_LINTFLAGS,
    _CS_XBS5_LPBIG_OFFBIG_CFLAGS,
    _CS_XBS5_LPBIG_OFFBIG_LDFLAGS,
    _CS_XBS5_LPBIG_OFFBIG_LIBS,
    _CS_XBS5_LPBIG_OFFBIG_LINTFLAGS,
    _CS_POSIX_V6_ILP32_OFF32_CFLAGS,
    _CS_POSIX_V6_ILP32_OFF32_LDFLAGS,
    _CS_POSIX_V6_ILP32_OFF32_LIBS,
    _CS_POSIX_V6_ILP32_OFF32_LINTFLAGS,
    _CS_POSIX_V6_ILP32_OFFBIG_CFLAGS,
    _CS_POSIX_V6_ILP32_OFFBIG_LDFLAGS,
    _CS_POSIX_V6_ILP32_OFFBIG_LIBS,
    _CS_POSIX_V6_ILP32_OFFBIG_LINTFLAGS,
    _CS_POSIX_V6_LP64_OFF64_CFLAGS,
    _CS_POSIX_V6_LP64_OFF64_LDFLAGS,
    _CS_POSIX_V6_LP64_OFF64_LIBS,
    _CS_POSIX_V6_LP64_OFF64_LINTFLAGS,
    _CS_POSIX_V6_LPBIG_OFFBIG_CFLAGS,
    _CS_POSIX_V6_LPBIG_OFFBIG_LDFLAGS,
    _CS_POSIX_V6_LPBIG_OFFBIG_LIBS,
    _CS_POSIX_V6_LPBIG_OFFBIG_LINTFLAGS,
    _CS_POSIX_V7_ILP32_OFF32_CFLAGS,
    _CS_POSIX_V7_ILP32_OFF32_LDFLAGS,
    _CS_POSIX_V7_ILP32_OFF32_LIBS,
    _CS_POSIX_V7_ILP32_OFF32_LINTFLAGS,
    _CS_POSIX_V7_ILP32_OFFBIG_CFLAGS,
    _CS_POSIX_V7_ILP32_OFFBIG_LDFLAGS,
    _CS_POSIX_V7_ILP32_OFFBIG_LIBS,
    _CS_POSIX_V7_ILP32_OFFBIG_LINTFLAGS,
    _CS_POSIX_V7_LP64_OFF64_CFLAGS,
    _CS_POSIX_V7_LP64_OFF64_LDFLAGS,
    _CS_POSIX_V7_LP64_OFF64_LIBS,
    _CS_POSIX_V7_LP64_OFF64_LINTFLAGS,
    _CS_POSIX_V7_LPBIG_OFFBIG_CFLAGS,
    _CS_POSIX_V7_LPBIG_OFFBIG_LDFLAGS,
    _CS_POSIX_V7_LPBIG_OFFBIG_LIBS,
    _CS_POSIX_V7_LPBIG_OFFBIG_LINTFLAGS,
    _CS_V6_ENV,
    _CS_V7_ENV
# 610 "/usr/include/unistd.h" 2 3 4
extern long int pathconf (const char *__path, int __name)
extern long int fpathconf (int __fd, int __name) __attribute__ ((__nothrow__ , __leaf__));
extern long int sysconf (int __name) __attribute__ ((__nothrow__ , __leaf__));
extern size_t confstr (int __name, char *__buf, size_t __len) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getpid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getppid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getpgrp (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t __getpgid (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getpgid (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern int setpgid (__pid_t __pid, __pid_t __pgid) __attribute__ ((__nothrow__ , __leaf__));
# 660 "/usr/include/unistd.h" 3 4
extern int setpgrp (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t setsid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getsid (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern __uid_t getuid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __uid_t geteuid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __gid_t getgid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __gid_t getegid (void) __attribute__ ((__nothrow__ , __leaf__));
extern int getgroups (int __size, __gid_t __list[]) __attribute__ ((__nothrow__ , __leaf__)) ;
# 700 "/usr/include/unistd.h" 3 4
extern int setuid (__uid_t __uid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setreuid (__uid_t __ruid, __uid_t __euid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int seteuid (__uid_t __uid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setgid (__gid_t __gid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setregid (__gid_t __rgid, __gid_t __egid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setegid (__gid_t __gid) __attribute__ ((__nothrow__ , __leaf__)) ;
# 756 "/usr/include/unistd.h" 3 4
extern __pid_t fork (void) __attribute__ ((__nothrow__));
extern __pid_t vfork (void) __attribute__ ((__nothrow__ , __leaf__));
extern char *ttyname (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int ttyname_r (int __fd, char *__buf, size_t __buflen)
extern int isatty (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int ttyslot (void) __attribute__ ((__nothrow__ , __leaf__));
extern int link (const char *__from, const char *__to)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2))) ;
extern int linkat (int __fromfd, const char *__from, int __tofd,
     const char *__to, int __flags)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4))) ;
extern int symlink (const char *__from, const char *__to)
extern ssize_t readlink (const char *__restrict __path,
    char *__restrict __buf, size_t __len)
extern int symlinkat (const char *__from, int __tofd,
        const char *__to) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 3))) ;
extern ssize_t readlinkat (int __fd, const char *__restrict __path,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3))) ;
extern int unlink (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int unlinkat (int __fd, const char *__name, int __flag)
extern int rmdir (const char *__path) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern __pid_t tcgetpgrp (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int tcsetpgrp (int __fd, __pid_t __pgrp_id) __attribute__ ((__nothrow__ , __leaf__));
extern char *getlogin (void);
extern int getlogin_r (char *__name, size_t __name_len) __attribute__ ((__nonnull__ (1)));
extern int setlogin (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 871 "/usr/include/unistd.h" 3 4
# 1 "/usr/include/getopt.h" 1 3 4
# 57 "/usr/include/getopt.h" 3 4
extern char *optarg;
# 71 "/usr/include/getopt.h" 3 4
extern int optind;
extern int opterr;
extern int optopt;
# 150 "/usr/include/getopt.h" 3 4
extern int getopt (int ___argc, char *const *___argv, const char *__shortopts)
# 872 "/usr/include/unistd.h" 2 3 4
extern int gethostname (char *__name, size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sethostname (const char *__name, size_t __len)
extern int sethostid (long int __id) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int getdomainname (char *__name, size_t __len)
extern int setdomainname (const char *__name, size_t __len)
extern int vhangup (void) __attribute__ ((__nothrow__ , __leaf__));
extern int revoke (const char *__file) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern int profil (unsigned short int *__sample_buffer, size_t __size,
     size_t __offset, unsigned int __scale)
extern int acct (const char *__name) __attribute__ ((__nothrow__ , __leaf__));
extern char *getusershell (void) __attribute__ ((__nothrow__ , __leaf__));
extern void endusershell (void) __attribute__ ((__nothrow__ , __leaf__));
extern void setusershell (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daemon (int __nochdir, int __noclose) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int chroot (const char *__path) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern char *getpass (const char *__prompt) __attribute__ ((__nonnull__ (1)));
extern int fsync (int __fd);
# 969 "/usr/include/unistd.h" 3 4
extern long int gethostid (void);
extern void sync (void) __attribute__ ((__nothrow__ , __leaf__));
extern int getpagesize (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int getdtablesize (void) __attribute__ ((__nothrow__ , __leaf__));
# 993 "/usr/include/unistd.h" 3 4
extern int truncate (const char *__file, __off_t __length)
# 1016 "/usr/include/unistd.h" 3 4
extern int ftruncate (int __fd, __off_t __length) __attribute__ ((__nothrow__ , __leaf__)) ;
# 1037 "/usr/include/unistd.h" 3 4
extern int brk (void *__addr) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void *sbrk (intptr_t __delta) __attribute__ ((__nothrow__ , __leaf__));
# 1058 "/usr/include/unistd.h" 3 4
extern long int syscall (long int __sysno, ...) __attribute__ ((__nothrow__ , __leaf__));
# 1081 "/usr/include/unistd.h" 3 4
extern int lockf (int __fd, int __cmd, __off_t __len) ;
# 1112 "/usr/include/unistd.h" 3 4
extern int fdatasync (int __fildes);
# 1151 "/usr/include/unistd.h" 3 4
# 3 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
            Defined "HAVE_UNISTD_H" to "1"
Checking for header: netinet/in.h
stdout:
# 1 "<built-in>"
# 21 "/usr/include/netinet/in.h" 3 4
# 22 "/usr/include/netinet/in.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdint.h" 1 3 4
# 9 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 1 "/usr/include/bits/wchar.h" 1 3 4
# 27 "/usr/include/stdint.h" 2 3 4
# 28 "/usr/include/stdint.h" 2 3 4
# 36 "/usr/include/stdint.h" 3 4
typedef signed char int8_t;
typedef short int int16_t;
typedef int int32_t;
typedef long int int64_t;
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned long int uint64_t;
# 65 "/usr/include/stdint.h" 3 4
typedef signed char int_least8_t;
typedef short int int_least16_t;
typedef int int_least32_t;
typedef long int int_least64_t;
typedef unsigned char uint_least8_t;
typedef unsigned short int uint_least16_t;
typedef unsigned int uint_least32_t;
typedef unsigned long int uint_least64_t;
# 90 "/usr/include/stdint.h" 3 4
typedef signed char int_fast8_t;
typedef long int int_fast16_t;
typedef long int int_fast32_t;
typedef long int int_fast64_t;
# 103 "/usr/include/stdint.h" 3 4
typedef unsigned char uint_fast8_t;
typedef unsigned long int uint_fast16_t;
typedef unsigned long int uint_fast32_t;
typedef unsigned long int uint_fast64_t;
# 119 "/usr/include/stdint.h" 3 4
typedef long int intptr_t;
typedef unsigned long int uintptr_t;
# 134 "/usr/include/stdint.h" 3 4
typedef long int intmax_t;
typedef unsigned long int uintmax_t;
# 10 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/types.h" 1 3 4
# 30 "/usr/include/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 60 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 98 "/usr/include/sys/types.h" 3 4
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 132 "/usr/include/sys/types.h" 3 4
# 133 "/usr/include/sys/types.h" 2 3 4
# 146 "/usr/include/sys/types.h" 3 4
# 147 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 216 "/usr/include/sys/types.h" 3 4
# 28 "/usr/include/bits/byteswap.h" 3 4
# 217 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/sigset.h" 1 3 4
# 22 "/usr/include/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
struct timespec
    __time_t tv_sec;
# 44 "/usr/include/sys/select.h" 2 3 4
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 46 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 64 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 96 "/usr/include/sys/select.h" 3 4
# 106 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 118 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 131 "/usr/include/sys/select.h" 3 4
# 220 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/sysmacros.h" 1 3 4
# 24 "/usr/include/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 58 "/usr/include/sys/sysmacros.h" 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 270 "/usr/include/sys/types.h" 3 4
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 271 "/usr/include/sys/types.h" 2 3 4
struct iovec
    void *iov_base;
    size_t iov_len;
         __off_t __offset) ;
   __off_t __offset) ;
enum __socket_type
  SOCK_STREAM = 1,
  SOCK_DGRAM = 2,
  SOCK_RAW = 3,
  SOCK_RDM = 4,
  SOCK_SEQPACKET = 5,
  SOCK_DCCP = 6,
  SOCK_PACKET = 10,
struct sockaddr
    char sa_data[14];
enum
    MSG_OOB = 0x01,
    MSG_PEEK = 0x02,
    MSG_CTRUNC = 0x08,
    MSG_PROXY = 0x10,
    MSG_TRUNC = 0x20,
    MSG_EOR = 0x80,
    MSG_FIN = 0x200,
    MSG_SYN = 0x400,
    MSG_RST = 0x1000,
    MSG_MORE = 0x8000,
struct msghdr
    void *msg_name;
    size_t msg_iovlen;
    void *msg_control;
    int msg_flags;
struct cmsghdr
    size_t cmsg_len;
    int cmsg_level;
    int cmsg_type;
enum
    SCM_RIGHTS = 0x01
struct linger
    int l_onoff;
    int l_linger;
struct osockaddr
enum
  SHUT_RD = 0,
  SHUT_WR,
  SHUT_RDWR
   int __flags);
struct in_addr
    in_addr_t s_addr;
struct ip_opts
    char ip_opts[40];
struct ip_mreqn
    int imr_ifindex;
struct in_pktinfo
    int ipi_ifindex;
enum
    IPPROTO_IP = 0,
    IPPROTO_ICMP = 1,
    IPPROTO_IGMP = 2,
    IPPROTO_IPIP = 4,
    IPPROTO_TCP = 6,
    IPPROTO_EGP = 8,
    IPPROTO_PUP = 12,
    IPPROTO_UDP = 17,
    IPPROTO_IDP = 22,
    IPPROTO_TP = 29,
    IPPROTO_DCCP = 33,
    IPPROTO_IPV6 = 41,
    IPPROTO_RSVP = 46,
    IPPROTO_GRE = 47,
    IPPROTO_ESP = 50,
    IPPROTO_AH = 51,
    IPPROTO_MTP = 92,
    IPPROTO_ENCAP = 98,
    IPPROTO_PIM = 103,
    IPPROTO_COMP = 108,
    IPPROTO_SCTP = 132,
    IPPROTO_RAW = 255,
    IPPROTO_MAX
enum
    IPPROTO_NONE = 59,
    IPPROTO_MH = 135
enum
    IPPORT_ECHO = 7,
    IPPORT_DISCARD = 9,
    IPPORT_SYSTAT = 11,
    IPPORT_FTP = 21,
    IPPORT_TELNET = 23,
    IPPORT_SMTP = 25,
    IPPORT_WHOIS = 43,
    IPPORT_MTP = 57,
    IPPORT_TFTP = 69,
    IPPORT_RJE = 77,
    IPPORT_FINGER = 79,
    IPPORT_SUPDUP = 95,
struct in6_addr
    union
      } __in6_u;
struct sockaddr_in
    in_port_t sin_port;
struct sockaddr_in6
struct ip_mreq
struct ipv6_mreq
struct group_req
struct ip_msfilter
struct group_filter
    uint32_t gf_fmode;
    uint32_t gf_numsrc;
            Defined "HAVE_NETINET_IN_H" to "1"
TEST checkRecursiveMacros from config.headers(/home/jed/petsc/config/BuildSystem/config/headers.py:218)
TESTING: checkRecursiveMacros from config.headers(config/BuildSystem/config/headers.py:218)
  Checks that the preprocessor allows recursive macros, and if not defines HAVE_BROKEN_RECURSIVE_MACRO
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.headers/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.headers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
void a(int i, int j) {}
#define a(b) a(b,__LINE__)
int main() {
a(0);
  return 0;
TEST configureCacheDetails from config.utilities.cacheDetails(/home/jed/petsc/config/BuildSystem/config/utilities/cacheDetails.py:78)
TESTING: configureCacheDetails from config.utilities.cacheDetails(config/BuildSystem/config/utilities/cacheDetails.py:78)
  Try to determine the size and associativity of the cache.
            Pushing language C
                      All intermediate test results are stored in /tmp/petsc-lhuj9c/config.utilities.cacheDetails
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.utilities.cacheDetails/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.utilities.cacheDetails/conftest.c
Successful compile:
Source:
#include <unistd.h>
long getconf_LEVEL1_DCACHE_SIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_SIZE); return (16 <= val && val <= 2147483647) ? val : 32768; }
int main() {
  return 0;
            Popping language C
          Pushing language C
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_SIZE()); fclose(output);;
  return 0;
                      Pushing language C
                      Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.utilities.cacheDetails/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.utilities.cacheDetails/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
Testing executable /tmp/petsc-lhuj9c/config.utilities.cacheDetails/conftest to see if it can be run
Executing: /tmp/petsc-lhuj9c/config.utilities.cacheDetails/conftest
          Popping language C
          Defined "LEVEL1_DCACHE_SIZE" to "32768"
          Pushing language C
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
long getconf_LEVEL1_DCACHE_LINESIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_LINESIZE); return (16 <= val && val <= 2147483647) ? val : 32; }
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_LINESIZE()); fclose(output);;
  return 0;
                      Pushing language C
                      Popping language C
          Popping language C
          Defined "LEVEL1_DCACHE_LINESIZE" to "64"
          Pushing language C
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
long getconf_LEVEL1_DCACHE_ASSOC() { long val = sysconf(_SC_LEVEL1_DCACHE_ASSOC); return (0 <= val && val <= 2147483647) ? val : 2; }
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_ASSOC()); fclose(output);;
  return 0;
                      Pushing language C
                      Popping language C
          Popping language C
          Defined "LEVEL1_DCACHE_ASSOC" to "8"
TEST checkMemcmp from config.functions(/home/jed/petsc/config/BuildSystem/config/functions.py:109)
TESTING: checkMemcmp from config.functions(config/BuildSystem/config/functions.py:109)
  Check for 8-bit clean memcmp
                          All intermediate test results are stored in /tmp/petsc-lhuj9c/config.functions
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.functions/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.functions/conftest.c
Successful compile:
Source:
#include <string.h>
void exit(int);
int main() {
char c0 = 0x40;
char c1 = (char) 0x80;
char c2 = (char) 0x81;
exit(memcmp(&c0, &c2, 1) < 0 && memcmp(&c1, &c2, 1) < 0 ? 0 : 1);
  return 0;
                      Pushing language C
                      Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.functions/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.functions/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
Testing executable /tmp/petsc-lhuj9c/config.functions/conftest to see if it can be run
Executing: /tmp/petsc-lhuj9c/config.functions/conftest
TEST checkSysinfo from config.functions(/home/jed/petsc/config/BuildSystem/config/functions.py:133)
TESTING: checkSysinfo from config.functions(config/BuildSystem/config/functions.py:133)
  Check whether sysinfo takes three arguments, and if it does define HAVE_SYSINFO_3ARG
Checking for functions [sysinfo]
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.functions/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.functions  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.functions/conftest.c
Successful compile:
Source:
/* System header to define __stub macros and hopefully no other prototypes since they would conflict with our 'char funcname()' declaration below. */
#include <assert.h>
/* Override any gcc2 internal prototype to avoid an error. */
#ifdef __cplusplus
extern "C" {
#endif
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char sysinfo();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_sysinfo) || defined (__stub___sysinfo)
sysinfo_will_always_fail_with_ENOSYS();
#else
sysinfo();
#endif
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_SYSINFO" to "1"
Checking for header: linux/kernel.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/linux/kernel.h" 1 3 4
# 1 "/usr/include/linux/sysinfo.h" 1 3 4
# 1 "/usr/include/linux/types.h" 1 3 4
# 1 "/usr/include/asm/types.h" 1 3 4
# 1 "/usr/include/asm-generic/types.h" 1 3 4
# 1 "/usr/include/asm-generic/int-ll64.h" 1 3 4
# 11 "/usr/include/asm-generic/int-ll64.h" 3 4
# 1 "/usr/include/asm/bitsperlong.h" 1 3 4
# 10 "/usr/include/asm/bitsperlong.h" 3 4
# 1 "/usr/include/asm-generic/bitsperlong.h" 1 3 4
# 11 "/usr/include/asm/bitsperlong.h" 2 3 4
# 12 "/usr/include/asm-generic/int-ll64.h" 2 3 4
typedef __signed__ char __s8;
typedef unsigned char __u8;
typedef __signed__ short __s16;
typedef unsigned short __u16;
typedef __signed__ int __s32;
typedef unsigned int __u32;
__extension__ typedef __signed__ long long __s64;
__extension__ typedef unsigned long long __u64;
# 7 "/usr/include/asm-generic/types.h" 2 3 4
# 5 "/usr/include/asm/types.h" 2 3 4
# 5 "/usr/include/linux/types.h" 2 3 4
# 1 "/usr/include/linux/posix_types.h" 1 3 4
# 1 "/usr/include/linux/stddef.h" 1 3 4
# 5 "/usr/include/linux/posix_types.h" 2 3 4
# 24 "/usr/include/linux/posix_types.h" 3 4
typedef struct {
 unsigned long fds_bits[1024 / (8 * sizeof(long))];
} __kernel_fd_set;
typedef void (*__kernel_sighandler_t)(int);
typedef int __kernel_key_t;
typedef int __kernel_mqd_t;
# 1 "/usr/include/asm/posix_types.h" 1 3 4
# 1 "/usr/include/asm/posix_types_64.h" 1 3 4
# 10 "/usr/include/asm/posix_types_64.h" 3 4
typedef unsigned short __kernel_old_uid_t;
typedef unsigned short __kernel_old_gid_t;
typedef unsigned long __kernel_old_dev_t;
# 1 "/usr/include/asm-generic/posix_types.h" 1 3 4
# 14 "/usr/include/asm-generic/posix_types.h" 3 4
typedef long __kernel_long_t;
typedef unsigned long __kernel_ulong_t;
typedef __kernel_ulong_t __kernel_ino_t;
typedef unsigned int __kernel_mode_t;
typedef int __kernel_pid_t;
typedef int __kernel_ipc_pid_t;
typedef unsigned int __kernel_uid_t;
typedef unsigned int __kernel_gid_t;
typedef __kernel_long_t __kernel_suseconds_t;
typedef int __kernel_daddr_t;
typedef unsigned int __kernel_uid32_t;
typedef unsigned int __kernel_gid32_t;
# 71 "/usr/include/asm-generic/posix_types.h" 3 4
typedef __kernel_ulong_t __kernel_size_t;
typedef __kernel_long_t __kernel_ssize_t;
typedef __kernel_long_t __kernel_ptrdiff_t;
typedef struct {
 int val[2];
} __kernel_fsid_t;
typedef __kernel_long_t __kernel_off_t;
typedef long long __kernel_loff_t;
typedef __kernel_long_t __kernel_time_t;
typedef __kernel_long_t __kernel_clock_t;
typedef int __kernel_timer_t;
typedef int __kernel_clockid_t;
typedef char * __kernel_caddr_t;
typedef unsigned short __kernel_uid16_t;
typedef unsigned short __kernel_gid16_t;
# 18 "/usr/include/asm/posix_types_64.h" 2 3 4
# 7 "/usr/include/asm/posix_types.h" 2 3 4
# 36 "/usr/include/linux/posix_types.h" 2 3 4
# 9 "/usr/include/linux/types.h" 2 3 4
# 27 "/usr/include/linux/types.h" 3 4
typedef __u16 __le16;
typedef __u16 __be16;
typedef __u32 __le32;
typedef __u32 __be32;
typedef __u64 __le64;
typedef __u64 __be64;
typedef __u16 __sum16;
typedef __u32 __wsum;
# 5 "/usr/include/linux/sysinfo.h" 2 3 4
struct sysinfo {
 __kernel_long_t uptime;
 __kernel_ulong_t loads[3];
 __kernel_ulong_t totalram;
 __kernel_ulong_t freeram;
 __kernel_ulong_t sharedram;
 __kernel_ulong_t bufferram;
 __kernel_ulong_t totalswap;
 __kernel_ulong_t freeswap;
 __u16 procs;
 __u16 pad;
 __kernel_ulong_t totalhigh;
 __kernel_ulong_t freehigh;
 __u32 mem_unit;
 char _f[20-2*sizeof(__kernel_ulong_t)-sizeof(__u32)];
# 5 "/usr/include/linux/kernel.h" 2 3 4
            Defined "HAVE_LINUX_KERNEL_H" to "1"
Checking for header: sys/sysinfo.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/sysinfo.h" 1 3 4
# 21 "/usr/include/sys/sysinfo.h" 3 4
# 22 "/usr/include/sys/sysinfo.h" 2 3 4
typedef struct {
} __kernel_fd_set;
typedef struct {
 int val[2];
} __kernel_fsid_t;
struct sysinfo {
 __u16 procs;
 __u16 pad;
 __u32 mem_unit;
# 25 "/usr/include/sys/sysinfo.h" 2 3 4
extern int sysinfo (struct sysinfo *__info) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs_conf (void) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_phys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_avphys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
            Defined "HAVE_SYS_SYSINFO_H" to "1"
Checking for header: sys/systeminfo.h
stdout:
# 1 "<built-in>"
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2stderr:
/tmp/petsc-lhuj9c/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory
 #include <sys/systeminfo.h>
compilation terminated.
Source:
Possible ERROR while running compiler: exit code 256
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:13:4: error: #error "Cannot check sysinfo without special headers"
 #  error "Cannot check sysinfo without special headers"
/tmp/petsc-lhuj9c/config.functions/conftest.c: In function ?main?:
/tmp/petsc-lhuj9c/config.functions/conftest.c:17:1: warning: implicit declaration of function ?sysinfo? [-Wimplicit-function-declaration]
 char buf[10]; long count=10; sysinfo(1, buf, count);
Source:
#ifdef HAVE_LINUX_KERNEL_H
#  include <linux/kernel.h>
#  include <linux/sys.h>
#  ifdef HAVE_SYS_SYSINFO_H
#    include <sys/sysinfo.h>
#  endif
#elif defined(HAVE_SYS_SYSTEMINFO_H)
#  include <sys/systeminfo.h>
#else
#endif
int main() {
  return 0;
            Compile failed inside link
TEST checkVPrintf from config.functions(/home/jed/petsc/config/BuildSystem/config/functions.py:156)
TESTING: checkVPrintf from config.functions(config/BuildSystem/config/functions.py:156)
  Checks whether vprintf requires a char * last argument, and if it does defines HAVE_VPRINTF_CHAR
Checking for functions [vprintf]
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ?vprintf?
 char vprintf();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vprintf) || defined (__stub___vprintf)
vprintf_will_always_fail_with_ENOSYS();
#else
vprintf();
#endif
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_VPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vprintf( "%d", Argp );
  return 0;
                  Pushing language C
                  Popping language C
TEST checkVFPrintf from config.functions(/home/jed/petsc/config/BuildSystem/config/functions.py:163)
TESTING: checkVFPrintf from config.functions(config/BuildSystem/config/functions.py:163)
  Checks whether vfprintf requires a char * last argument, and if it does defines HAVE_VFPRINTF_CHAR
Checking for functions [vfprintf]
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ?vfprintf?
 char vfprintf();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vfprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vfprintf) || defined (__stub___vfprintf)
vfprintf_will_always_fail_with_ENOSYS();
#else
vfprintf();
#endif
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_VFPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vfprintf(stdout, "%d", Argp );
  return 0;
                  Pushing language C
                  Popping language C
TEST checkVSNPrintf from config.functions(/home/jed/petsc/config/BuildSystem/config/functions.py:170)
TESTING: checkVSNPrintf from config.functions(config/BuildSystem/config/functions.py:170)
  Checks whether vsnprintf requires a char * last argument, and if it does defines HAVE_VSNPRINTF_CHAR
Checking for functions [_vsnprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _vsnprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub__vsnprintf) || defined (__stub____vsnprintf)
_vsnprintf_will_always_fail_with_ENOSYS();
#else
_vsnprintf();
#endif
  return 0;
                    Pushing language C
                    Popping language C
Possible ERROR while running linker: exit code 256
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.o: In function `main':
/tmp/petsc-lhuj9c/config.functions/conftest.c:24: undefined reference to `_vsnprintf'
collect2: error: ld returned 1 exit status
Checking for functions [vsnprintf]
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ?vsnprintf?
 char vsnprintf();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vsnprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vsnprintf) || defined (__stub___vsnprintf)
#else
vsnprintf();
#endif
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_VSNPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;char str[6];
vsnprintf(str,5, "%d", Argp );
  return 0;
                  Pushing language C
                  Popping language C
TEST checkNanosleep from config.functions(/home/jed/petsc/config/BuildSystem/config/functions.py:214)
TESTING: checkNanosleep from config.functions(config/BuildSystem/config/functions.py:214)
  Check for functional nanosleep() - as time.h behaves differently for different compiler flags - like -std=c89
Successful compile:
Source:
#include <time.h>
int main() {
struct timespec tp;
 tp.tv_sec = 0;
 tp.tv_nsec = (long)(1e9);
 nanosleep(&tp,0);
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_NANOSLEEP" to "1"
TEST checkSignalHandlerType from config.functions(/home/jed/petsc/config/BuildSystem/config/functions.py:190)
TESTING: checkSignalHandlerType from config.functions(config/BuildSystem/config/functions.py:190)
  Checks the type of C++ signals handlers, and defines SIGNAL_CAST to the correct value
          Pushing language Cxx
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.functions/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.functions  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0   -fPIC   /tmp/petsc-lhuj9c/config.functions/conftest.cc
Successful compile:
Source:
#include <signal.h>
static void myhandler(int sig) {}
int main() {
signal(SIGFPE,myhandler);
  return 0;
                  Pushing language CXX
                  Popping language CXX
Executing: /opt/mpich/bin/mpicxx  -o /tmp/petsc-lhuj9c/config.functions/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  /tmp/petsc-lhuj9c/config.functions/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
          Defined "SIGNAL_CAST" to " "
          Popping language Cxx
TEST checkFreeReturnType from config.functions(/home/jed/petsc/config/BuildSystem/config/functions.py:200)
TESTING: checkFreeReturnType from config.functions(config/BuildSystem/config/functions.py:200)
  Checks whether free returns void or int, and defines HAVE_FREE_RETURN_INT
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:6:25: error: void value not ignored as it ought to be
 int ierr; void *p; ierr = free(p); return 0;
/tmp/petsc-lhuj9c/config.functions/conftest.c:6:5: warning: variable ?ierr? set but not used [-Wunused-but-set-variable]
Source:
#include <stdlib.h>
int main() {
  return 0;
TEST checkVariableArgumentLists from config.functions(/home/jed/petsc/config/BuildSystem/config/functions.py:206)
TESTING: checkVariableArgumentLists from config.functions(config/BuildSystem/config/functions.py:206)
  Checks whether the variable argument list functionality is working
Successful compile:
Source:
#include <stdarg.h>
int main() {
  va_list l1, l2;
  va_copy(l1, l2);
  return 0;
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_VA_COPY" to "1"
TEST checkClassify from config.functions(/home/jed/petsc/config/BuildSystem/config/functions.py:88)
TESTING: checkClassify from config.functions(config/BuildSystem/config/functions.py:88)
  Recursive decompose to rapidly classify functions as found or missing
    To confirm that a function is missing, we require a compile/link
    failure with only that function in a compilation unit.  In contrast,
    we can confirm that many functions are present by compiling them all
    together in a large compilation unit.  We optimistically compile
    everything together, then trim all functions that were named in the
    error message and bisect the result.  The trimming is only an
    optimization to increase the likelihood of a big-batch compile
    succeeding; we do not rely on the compiler naming missing functions.
Checking for functions [rand getdomainname _sleep snprintf realpath dlsym bzero _getcwd getwd uname _lseek sleep _access lseek usleep dlclose gethostname clock get_nprocs access _snprintf dlerror mkstemp fork getpagesize sbreak memalign sigset getcwd gethostbyname gettimeofday readlink _set_output_format PXFGETARG sigaction strcasecmp dlopen drand48 socket memmove signal popen getrusage times time sysctlbyname stricmp]
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:16:6: warning: conflicting types for built-in function ?snprintf?
 char snprintf();
/tmp/petsc-lhuj9c/config.functions/conftest.c:19:6: warning: conflicting types for built-in function ?bzero?
 char bzero();
/tmp/petsc-lhuj9c/config.functions/conftest.c:36:6: warning: conflicting types for built-in function ?fork?
 char fork();
/tmp/petsc-lhuj9c/config.functions/conftest.c:48:6: warning: conflicting types for built-in function ?strcasecmp?
 char strcasecmp();
/tmp/petsc-lhuj9c/config.functions/conftest.c:52:6: warning: conflicting types for built-in function ?memmove?
 char memmove();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char getdomainname();
char _sleep();
char snprintf();
char realpath();
char dlsym();
char bzero();
char _getcwd();
char getwd();
char uname();
char _lseek();
char sleep();
char _access();
char lseek();
char usleep();
char dlclose();
char gethostname();
char clock();
char get_nprocs();
char access();
char _snprintf();
char dlerror();
char mkstemp();
char fork();
char getpagesize();
char sbreak();
char memalign();
char sigset();
char getcwd();
char gethostbyname();
char gettimeofday();
char readlink();
char _set_output_format();
char PXFGETARG();
char sigaction();
char strcasecmp();
char dlopen();
char drand48();
char socket();
char memmove();
char signal();
char popen();
char getrusage();
char times();
char time();
char sysctlbyname();
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_rand) || defined (__stub___rand)
rand_will_always_fail_with_ENOSYS();
#else
rand();
#endif
#if defined (__stub_getdomainname) || defined (__stub___getdomainname)
getdomainname_will_always_fail_with_ENOSYS();
#else
getdomainname();
#endif
#if defined (__stub__sleep) || defined (__stub____sleep)
_sleep_will_always_fail_with_ENOSYS();
#else
_sleep();
#endif
#if defined (__stub_snprintf) || defined (__stub___snprintf)
#else
snprintf();
#endif
#if defined (__stub_realpath) || defined (__stub___realpath)
realpath_will_always_fail_with_ENOSYS();
#else
realpath();
#endif
#if defined (__stub_dlsym) || defined (__stub___dlsym)
dlsym_will_always_fail_with_ENOSYS();
#else
dlsym();
#endif
#if defined (__stub_bzero) || defined (__stub___bzero)
bzero_will_always_fail_with_ENOSYS();
#else
bzero();
#endif
#if defined (__stub__getcwd) || defined (__stub____getcwd)
_getcwd_will_always_fail_with_ENOSYS();
#else
_getcwd();
#endif
#if defined (__stub_getwd) || defined (__stub___getwd)
getwd_will_always_fail_with_ENOSYS();
#else
getwd();
#endif
#if defined (__stub_uname) || defined (__stub___uname)
uname_will_always_fail_with_ENOSYS();
#else
uname();
#endif
#if defined (__stub__lseek) || defined (__stub____lseek)
_lseek_will_always_fail_with_ENOSYS();
#else
_lseek();
#endif
#if defined (__stub_sleep) || defined (__stub___sleep)
#else
sleep();
#endif
#if defined (__stub__access) || defined (__stub____access)
_access_will_always_fail_with_ENOSYS();
#else
_access();
#endif
#if defined (__stub_lseek) || defined (__stub___lseek)
#else
lseek();
#endif
#if defined (__stub_usleep) || defined (__stub___usleep)
usleep_will_always_fail_with_ENOSYS();
#else
usleep();
#endif
#if defined (__stub_dlclose) || defined (__stub___dlclose)
dlclose_will_always_fail_with_ENOSYS();
#else
dlclose();
#endif
#if defined (__stub_gethostname) || defined (__stub___gethostname)
gethostname_will_always_fail_with_ENOSYS();
#else
gethostname();
#endif
#if defined (__stub_clock) || defined (__stub___clock)
clock_will_always_fail_with_ENOSYS();
#else
clock();
#endif
#if defined (__stub_get_nprocs) || defined (__stub___get_nprocs)
get_nprocs_will_always_fail_with_ENOSYS();
#else
get_nprocs();
#endif
#if defined (__stub_access) || defined (__stub___access)
#else
access();
#endif
#if defined (__stub__snprintf) || defined (__stub____snprintf)
_snprintf_will_always_fail_with_ENOSYS();
#else
_snprintf();
#endif
#if defined (__stub_dlerror) || defined (__stub___dlerror)
dlerror_will_always_fail_with_ENOSYS();
#else
dlerror();
#endif
#if defined (__stub_mkstemp) || defined (__stub___mkstemp)
mkstemp_will_always_fail_with_ENOSYS();
#else
mkstemp();
#endif
#if defined (__stub_fork) || defined (__stub___fork)
fork_will_always_fail_with_ENOSYS();
#else
fork();
#endif
#if defined (__stub_getpagesize) || defined (__stub___getpagesize)
getpagesize_will_always_fail_with_ENOSYS();
#else
getpagesize();
#endif
#if defined (__stub_sbreak) || defined (__stub___sbreak)
sbreak_will_always_fail_with_ENOSYS();
#else
sbreak();
#endif
#if defined (__stub_memalign) || defined (__stub___memalign)
memalign_will_always_fail_with_ENOSYS();
#else
memalign();
#endif
#if defined (__stub_sigset) || defined (__stub___sigset)
sigset_will_always_fail_with_ENOSYS();
#else
sigset();
#endif
#if defined (__stub_getcwd) || defined (__stub___getcwd)
#else
getcwd();
#endif
#if defined (__stub_gethostbyname) || defined (__stub___gethostbyname)
gethostbyname_will_always_fail_with_ENOSYS();
#else
gethostbyname();
#endif
#if defined (__stub_gettimeofday) || defined (__stub___gettimeofday)
gettimeofday_will_always_fail_with_ENOSYS();
#else
gettimeofday();
#endif
#if defined (__stub_readlink) || defined (__stub___readlink)
readlink_will_always_fail_with_ENOSYS();
#else
readlink();
#endif
#if defined (__stub__set_output_format) || defined (__stub____set_output_format)
_set_output_format_will_always_fail_with_ENOSYS();
#else
#endif
#if defined (__stub_PXFGETARG) || defined (__stub___PXFGETARG)
PXFGETARG_will_always_fail_with_ENOSYS();
#else
PXFGETARG();
#endif
#if defined (__stub_sigaction) || defined (__stub___sigaction)
sigaction_will_always_fail_with_ENOSYS();
#else
sigaction();
#endif
#if defined (__stub_strcasecmp) || defined (__stub___strcasecmp)
strcasecmp_will_always_fail_with_ENOSYS();
#else
strcasecmp();
#endif
#if defined (__stub_dlopen) || defined (__stub___dlopen)
dlopen_will_always_fail_with_ENOSYS();
#else
dlopen();
#endif
#if defined (__stub_drand48) || defined (__stub___drand48)
drand48_will_always_fail_with_ENOSYS();
#else
drand48();
#endif
#if defined (__stub_socket) || defined (__stub___socket)
socket_will_always_fail_with_ENOSYS();
#else
socket();
#endif
#if defined (__stub_memmove) || defined (__stub___memmove)
memmove_will_always_fail_with_ENOSYS();
#else
memmove();
#endif
#if defined (__stub_signal) || defined (__stub___signal)
signal_will_always_fail_with_ENOSYS();
#else
signal();
#endif
#if defined (__stub_popen) || defined (__stub___popen)
popen_will_always_fail_with_ENOSYS();
#else
popen();
#endif
#if defined (__stub_getrusage) || defined (__stub___getrusage)
getrusage_will_always_fail_with_ENOSYS();
#else
getrusage();
#endif
#if defined (__stub_times) || defined (__stub___times)
times_will_always_fail_with_ENOSYS();
#else
times();
#endif
#if defined (__stub_time) || defined (__stub___time)
time_will_always_fail_with_ENOSYS();
#else
time();
#endif
#if defined (__stub_sysctlbyname) || defined (__stub___sysctlbyname)
sysctlbyname_will_always_fail_with_ENOSYS();
#else
sysctlbyname();
#endif
#if defined (__stub_stricmp) || defined (__stub___stricmp)
stricmp_will_always_fail_with_ENOSYS();
#else
stricmp();
#endif
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:118: warning: the `getwd' function is dangerous and should not be used.
conftest.c:(.text+0x1e): undefined reference to `_sleep'
conftest.c:(.text+0x50): undefined reference to `_getcwd'
conftest.c:(.text+0x6e): undefined reference to `_lseek'
conftest.c:(.text+0x82): undefined reference to `_access'
conftest.c:(.text+0xd2): undefined reference to `_snprintf'
conftest.c:(.text+0x104): undefined reference to `sbreak'
conftest.c:(.text+0x14a): undefined reference to `_set_output_format'
conftest.c:(.text+0x154): undefined reference to `PXFGETARG'
conftest.c:(.text+0x1cc): undefined reference to `sysctlbyname'
conftest.c:(.text+0x1d6): undefined reference to `stricmp'
Checking for functions [rand getdomainname realpath dlsym bzero uname usleep dlclose gethostname clock get_nprocs dlerror mkstemp fork getpagesize]
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:17:6: warning: conflicting types for built-in function ?bzero?
 char bzero();
/tmp/petsc-lhuj9c/config.functions/conftest.c:26:6: warning: conflicting types for built-in function ?fork?
 char fork();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char realpath();
char dlsym();
char bzero();
char uname();
char usleep();
char dlclose();
char gethostname();
char clock();
char get_nprocs();
char dlerror();
char mkstemp();
char fork();
char getpagesize();
#ifdef __cplusplus
#endif
int main() {
#else
rand();
#endif
#else
getdomainname();
#endif
#else
realpath();
#endif
#else
dlsym();
#endif
#else
bzero();
#endif
#else
uname();
#endif
#else
usleep();
#endif
#else
dlclose();
#endif
#else
gethostname();
#endif
#else
clock();
#endif
#else
get_nprocs();
#endif
#else
dlerror();
#endif
#else
mkstemp();
#endif
#else
fork();
#endif
#else
getpagesize();
#endif
  return 0;
                          Pushing language C
                          Popping language C
                  Defined "HAVE_RAND" to "1"
                  Defined "HAVE_GETDOMAINNAME" to "1"
                  Defined "HAVE_REALPATH" to "1"
                  Defined "HAVE_DLSYM" to "1"
                  Defined "HAVE_BZERO" to "1"
                  Defined "HAVE_UNAME" to "1"
                  Defined "HAVE_USLEEP" to "1"
                  Defined "HAVE_DLCLOSE" to "1"
                  Defined "HAVE_GETHOSTNAME" to "1"
                  Defined "HAVE_CLOCK" to "1"
                  Defined "HAVE_GET_NPROCS" to "1"
                  Defined "HAVE_DLERROR" to "1"
                  Defined "HAVE_MKSTEMP" to "1"
                  Defined "HAVE_FORK" to "1"
                  Defined "HAVE_GETPAGESIZE" to "1"
Checking for functions [memalign sigset gethostbyname gettimeofday readlink sigaction strcasecmp dlopen drand48 socket memmove signal popen getrusage times time]
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:19:6: warning: conflicting types for built-in function ?strcasecmp?
 char strcasecmp();
/tmp/petsc-lhuj9c/config.functions/conftest.c:23:6: warning: conflicting types for built-in function ?memmove?
 char memmove();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char memalign();
char sigset();
char readlink();
char sigaction();
char strcasecmp();
char dlopen();
char drand48();
char socket();
char memmove();
char signal();
char popen();
char getrusage();
char times();
char time();
#ifdef __cplusplus
#endif
int main() {
#else
memalign();
#endif
#else
sigset();
#endif
#else
gethostbyname();
#endif
#else
gettimeofday();
#endif
#else
readlink();
#endif
#else
sigaction();
#endif
#else
strcasecmp();
#endif
#else
dlopen();
#endif
#else
drand48();
#endif
#else
socket();
#endif
#else
memmove();
#endif
#else
signal();
#endif
#else
popen();
#endif
#else
getrusage();
#endif
#else
times();
#endif
#else
time();
#endif
  return 0;
                          Pushing language C
                          Popping language C
                  Defined "HAVE_MEMALIGN" to "1"
                  Defined "HAVE_SIGSET" to "1"
                  Defined "HAVE_GETHOSTBYNAME" to "1"
                  Defined "HAVE_GETTIMEOFDAY" to "1"
                  Defined "HAVE_READLINK" to "1"
                  Defined "HAVE_SIGACTION" to "1"
                  Defined "HAVE_STRCASECMP" to "1"
                  Defined "HAVE_DLOPEN" to "1"
                  Defined "HAVE_DRAND48" to "1"
                  Defined "HAVE_SOCKET" to "1"
                  Defined "HAVE_MEMMOVE" to "1"
                  Defined "HAVE_SIGNAL" to "1"
                  Defined "HAVE_POPEN" to "1"
                  Defined "HAVE_GETRUSAGE" to "1"
                  Defined "HAVE_TIMES" to "1"
                  Defined "HAVE_TIME" to "1"
Checking for functions [_sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _sleep();
#ifdef __cplusplus
#endif
int main() {
#else
_sleep();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:24: undefined reference to `_sleep'
Checking for functions [snprintf]
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ?snprintf?
 char snprintf();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
snprintf();
#endif
  return 0;
                          Pushing language C
                          Popping language C
                  Defined "HAVE_SNPRINTF" to "1"
Checking for functions [_getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
_getcwd();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:24: undefined reference to `_getcwd'
Checking for functions [getwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getwd();
#ifdef __cplusplus
#endif
int main() {
#else
getwd();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:24: warning: the `getwd' function is dangerous and should not be used.
                  Defined "HAVE_GETWD" to "1"
Checking for functions [_lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _lseek();
#ifdef __cplusplus
#endif
int main() {
#else
_lseek();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:24: undefined reference to `_lseek'
Checking for functions [sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sleep();
#ifdef __cplusplus
#endif
int main() {
#else
sleep();
#endif
  return 0;
                          Pushing language C
                          Popping language C
                  Defined "HAVE_SLEEP" to "1"
Checking for functions [_access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _access();
#ifdef __cplusplus
#endif
int main() {
#else
_access();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:24: undefined reference to `_access'
Checking for functions [lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char lseek();
#ifdef __cplusplus
#endif
int main() {
#else
lseek();
#endif
  return 0;
                          Pushing language C
                          Popping language C
                  Defined "HAVE_LSEEK" to "1"
Checking for functions [access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char access();
#ifdef __cplusplus
#endif
int main() {
#else
access();
#endif
  return 0;
                          Pushing language C
                          Popping language C
                  Defined "HAVE_ACCESS" to "1"
Checking for functions [_snprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
_snprintf();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:24: undefined reference to `_snprintf'
Checking for functions [sbreak]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sbreak();
#ifdef __cplusplus
#endif
int main() {
#else
sbreak();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:24: undefined reference to `sbreak'
Checking for functions [getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
getcwd();
#endif
  return 0;
                          Pushing language C
                          Popping language C
                  Defined "HAVE_GETCWD" to "1"
Checking for functions [_set_output_format]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:24: undefined reference to `_set_output_format'
Checking for functions [PXFGETARG]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:24: undefined reference to `PXFGETARG'
Checking for functions [sysctlbyname]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
sysctlbyname();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:24: undefined reference to `sysctlbyname'
Checking for functions [stricmp]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#else
stricmp();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:24: undefined reference to `stricmp'
TEST configureMemorySize from config.utilities.getResidentSetSize(/home/jed/petsc/config/BuildSystem/config/utilities/getResidentSetSize.py:31)
TESTING: configureMemorySize from config.utilities.getResidentSetSize(config/BuildSystem/config/utilities/getResidentSetSize.py:31)
  Try to determine how to measure the memory usage
          Defined "USE_PROC_FOR_SIZE" to "1"
        Using /proc for PetscMemoryGetCurrentUsage()
TEST configureFeatureTestMacros from config.utilities.featureTestMacros(/home/jed/petsc/config/BuildSystem/config/utilities/featureTestMacros.py:13)
TESTING: configureFeatureTestMacros from config.utilities.featureTestMacros(config/BuildSystem/config/utilities/featureTestMacros.py:13)
  Checks if certain feature test macros are support
                    All intermediate test results are stored in /tmp/petsc-lhuj9c/config.utilities.featureTestMacros
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.utilities.featureTestMacros/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.functions  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.utilities.featureTestMacros/conftest.c
stderr:
/tmp/petsc-lhuj9c/config.utilities.featureTestMacros/conftest.c:4:20: fatal error: sysctl.h: No such file or directory
 #include <sysctl.h>
Source:
#define _POSIX_C_SOURCE 200112L
#include <sysctl.h>
int main() {
  return 0;
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.utilities.featureTestMacros/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.utilities.featureTestMacros/conftest.c
stderr:
In file included from /usr/include/stdlib.h:24:0,
                 from /tmp/petsc-lhuj9c/config.utilities.featureTestMacros/conftest.c:4:
/usr/include/features.h:148:3: warning: #warning "_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE" [-Wcpp]
 # warning "_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE"
Source:
#define _BSD_SOURCE
#include<stdlib.h>
int main() {
  return 0;
          Defined "_BSD_SOURCE" to "1"
Successful compile:
Source:
#define _DEFAULT_SOURCE
#include<stdlib.h>
int main() {
  return 0;
          Defined "_DEFAULT_SOURCE" to "1"
Successful compile:
Source:
#define _GNU_SOURCE
#include <sched.h>
int main() {
cpu_set_t mset;
CPU_ZERO(&mset);;
  return 0;
          Defined "_GNU_SOURCE" to "1"
TEST configureFPTrap from config.utilities.FPTrap(/home/jed/petsc/config/BuildSystem/config/utilities/FPTrap.py:27)
TESTING: configureFPTrap from config.utilities.FPTrap(config/BuildSystem/config/utilities/FPTrap.py:27)
  Checking the handling of floating point traps
Checking for header: sigfpe.h
Executing: /opt/mpich/bin/mpicc -E  -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.headers  /tmp/petsc-lhuj9c/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-lhuj9c/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/conffix.h" 1
stdout:
# 1 "<built-in>"
/tmp/petsc-lhuj9c/config.headers/conftest.c:3:20: fatal error: sigfpe.h: No such file or directory
 #include <sigfpe.h>
Source:
#include <sigfpe.h>
Checking for header: fpxcp.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-lhuj9c/config.headers/conftest.c:3:19: fatal error: fpxcp.h: No such file or directory
 #include <fpxcp.h>
Source:
#include <fpxcp.h>
Checking for header: floatingpoint.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-lhuj9c/config.headers/conftest.c:3:27: fatal error: floatingpoint.h: No such file or directory
 #include <floatingpoint.h>
Source:
TEST check_siginfo_t from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:46)
TESTING: check_siginfo_t from config.types(config/BuildSystem/config/types.py:46)
  Checks if siginfo_t exists in signal.h. This check is for windows, and C89 check.
Checking for type: siginfo_t
                      All intermediate test results are stored in /tmp/petsc-lhuj9c/config.types
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.types/conftest.o -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.types  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.types/conftest.c
stderr:
/tmp/petsc-lhuj9c/config.types/conftest.c: In function ?main?:
/tmp/petsc-lhuj9c/config.types/conftest.c:13:11: warning: unused variable ?a? [-Wunused-variable]
 siginfo_t a;;
Source:
#include <sys/types.h>
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#include<signal.h>
#endif
int main() {
siginfo_t a;;
  return 0;
siginfo_t found
          Defined "HAVE_SIGINFO_T" to "1"
TEST check__int64 from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:52)
TESTING: check__int64 from config.types(config/BuildSystem/config/types.py:52)
  Checks if __int64 exists. This is primarily for windows.
Checking for type: __int64
stderr:
/tmp/petsc-lhuj9c/config.types/conftest.c:13:1: error: unknown type name ?__int64?
 __int64 a;;
/tmp/petsc-lhuj9c/config.types/conftest.c:13:9: warning: unused variable ?a? [-Wunused-variable]
 __int64 a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
__int64 a;;
  return 0;
__int64 found
TEST checkSizeTypes from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:58)
TESTING: checkSizeTypes from config.types(config/BuildSystem/config/types.py:58)
  Checks for types associated with sizes, such as size_t.
Checking for type: size_t
stderr:
/tmp/petsc-lhuj9c/config.types/conftest.c:13:8: warning: unused variable ?a? [-Wunused-variable]
 size_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
size_t a;;
  return 0;
size_t found
TEST checkFileTypes from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:68)
TESTING: checkFileTypes from config.types(config/BuildSystem/config/types.py:68)
  Checks for types associated with files, such as mode_t, off_t, etc.
Checking for type: mode_t
stderr:
 mode_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
mode_t a;;
  return 0;
mode_t found
Checking for type: off_t
stderr:
/tmp/petsc-lhuj9c/config.types/conftest.c:13:7: warning: unused variable ?a? [-Wunused-variable]
 off_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
off_t a;;
  return 0;
off_t found
TEST checkIntegerTypes from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:63)
TESTING: checkIntegerTypes from config.types(config/BuildSystem/config/types.py:63)
  Checks for types associated with integers, such as int32_t.
Checking for type: int32_t
stderr:
 int32_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
int32_t a;;
  return 0;
int32_t found
TEST checkPID from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:74)
TESTING: checkPID from config.types(config/BuildSystem/config/types.py:74)
  Checks for pid_t, and defines it if necessary
Checking for type: pid_t
stderr:
 pid_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
pid_t a;;
  return 0;
pid_t found
TEST checkUID from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:78)
TESTING: checkUID from config.types(config/BuildSystem/config/types.py:78)
  Checks for uid_t and gid_t, and defines them if necessary
Source:
Executing: /opt/mpich/bin/mpicc -E  -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.headers  /tmp/petsc-lhuj9c/config.types/conftest.c
stdout:
# 1 "/tmp/petsc-lhuj9c/config.types/conftest.c"
# 1 "<built-in>"
# 1 "/tmp/petsc-lhuj9c/config.types/confdefs.h" 1
# 2 "/tmp/petsc-lhuj9c/config.types/conftest.c" 2
# 1 "/tmp/petsc-lhuj9c/config.types/conffix.h" 1
# 3 "/tmp/petsc-lhuj9c/config.types/conftest.c" 2
# 25 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 395 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 396 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 26 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
typedef __pid_t pid_t;
# 1 "/usr/include/time.h" 1 3 4
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 194 "/usr/include/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
typedef struct
  } __sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
# 1 "/usr/include/bits/time.h" 1 3 4
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
TEST checkSignal from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:85)
TESTING: checkSignal from config.types(config/BuildSystem/config/types.py:85)
  Checks the return type of signal() and defines RETSIGTYPE to that type name
Successful compile:
Source:
#include <signal.h>
#ifdef signal
#undef signal
#endif
#ifdef __cplusplus
extern "C" void (*signal (int, void(*)(int)))(int);
#else
void (*signal())();
#endif
int main() {
  return 0;
          Defined "RETSIGTYPE" to "void"
TEST checkC99Complex from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:106)
TESTING: checkC99Complex from config.types(config/BuildSystem/config/types.py:106)
  Check for complex numbers in in C99 std
       Note that since PETSc source code uses _Complex we test specifically for that, not complex
stderr:
/tmp/petsc-lhuj9c/config.types/conftest.c:6:17: warning: variable ?x? set but not used [-Wunused-but-set-variable]
 double _Complex x;
Source:
#include <complex.h>
int main() {
double _Complex x;
 x = I;
  return 0;
stderr:
 double _Complex x;
Source:
int main() {
double _Complex x;
 x = I;
  return 0;
                  Pushing language C
                  Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.types/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.types/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
          Defined "HAVE_C99_COMPLEX" to "1"
TEST checkCxxComplex from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:117)
TESTING: checkCxxComplex from config.types(config/BuildSystem/config/types.py:117)
  Check for complex numbers in namespace std
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.types/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.types  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0   -fPIC   /tmp/petsc-lhuj9c/config.types/conftest.cc
Successful compile:
Source:
#include <complex>
int main() {
std::complex<double> x;
  return 0;
Executing: /opt/mpich/bin/mpicxx  -o /tmp/petsc-lhuj9c/config.types/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  /tmp/petsc-lhuj9c/config.types/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
          Defined "HAVE_CXX_COMPLEX" to "1"
TEST checkFortranKind from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:138)
TESTING: checkFortranKind from config.types(config/BuildSystem/config/types.py:138)
  Checks whether selected_int_kind etc work USE_FORTRANKIND
          Pushing language FC
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.types/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.types  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /tmp/petsc-lhuj9c/config.types/conftest.F
Successful compile:
Source:
      program main
        integer(kind=selected_int_kind(10)) i
        real(kind=selected_real_kind(10)) d
      end
          Defined "USE_FORTRANKIND" to "1"
          Popping language FC
TEST checkConst from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:150)
TESTING: checkConst from config.types(config/BuildSystem/config/types.py:150)
  Checks for working const, and if not found defines it to empty string
stderr:
/tmp/petsc-lhuj9c/config.types/conftest.c:30:9: warning: ?t? is used uninitialized in this function [-Wuninitialized]
       *t++ = 0;
/tmp/petsc-lhuj9c/config.types/conftest.c:46:25: warning: ?b? is used uninitialized in this function [-Wuninitialized]
       struct s *b; b->j = 5;
Source:
int main() {
    /* Ultrix mips cc rejects this.  */
    typedef int charset[2]; const charset x;
    /* SunOS 4.1.1 cc rejects this.  */
    char const *const *ccp;
    char **p;
    /* NEC SVR4.0.2 mips cc rejects this.  */
    struct point {int x, y;};
    static struct point const zero = {0,0};
    /* AIX XL C 1.02.0.0 rejects this.
    It does not let you subtract one const X* pointer from another in an arm
    of an if-expression whose if-part is not a constant expression */
    const char *g = "string";
    ccp = &g + (g ? g-g : 0);
    /* HPUX 7.0 cc rejects these. */
    ++ccp;
    p = (char**) ccp;
    ccp = (char const *const *) p;
    /* This section avoids unused variable warnings */
    if (zero.x);
    if (x[0]);
    { /* SCO 3.2v4 cc rejects this.  */
      char *t;
      char const *s = 0 ? (char *) 0 : (char const *) 0;
      *t++ = 0;
      if (*s);
    { /* Someone thinks the Sun supposedly-ANSI compiler will reject this.  */
      int x[] = {25, 17};
      const int *foo = &x[0];
      ++foo;
    { /* Sun SC1.0 ANSI compiler rejects this -- but not the above. */
      typedef const int *iptr;
      iptr p = 0;
      ++p;
    { /* AIX XL C 1.02.0.0 rejects this saying
      "k.c", line 2.27: 1506-025 (S) Operand must be a modifiable lvalue. */
      struct s { int j; const int *ap[3]; };
    { /* ULTRIX-32 V3.1 (Rev 9) vcc rejects this */
      const int foo = 10;
      /* Get rid of unused variable warning */
      if (foo);
  return 0;
TEST checkEndian from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:206)
TESTING: checkEndian from config.types(config/BuildSystem/config/types.py:206)
  If the machine is big endian, defines WORDS_BIGENDIAN
Successful compile:
Source:
#ifdef HAVE_SYS_PARAM_H
  #include <sys/param.h>
#endif
int main() {
#if !BYTE_ORDER || !BIG_ENDIAN || !LITTLE_ENDIAN
  bogus endian macros
#endif
  return 0;
stderr:
/tmp/petsc-lhuj9c/config.types/conftest.c:11:3: error: unknown type name ?not?
   not big endian
/tmp/petsc-lhuj9c/config.types/conftest.c:11:11: error: expected ?=?, ?,?, ?;?, ?asm? or ?__attribute__? before ?endian?
   not big endian
Source:
#endif
int main() {
#if BYTE_ORDER != BIG_ENDIAN
  not big endian
#endif
  return 0;
TEST checkSizeof from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:259)
TESTING: checkSizeof from config.types(config/BuildSystem/config/types.py:259)
  Determines the size of type "typeName", and defines SIZEOF_"typeName" to be the size
Checking for size of type: char
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
FILE *f = fopen("conftestval", "w");
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(char));
  return 0;
                        Pushing language C
                        Popping language C
Testing executable /tmp/petsc-lhuj9c/config.types/conftest to see if it can be run
Executing: /tmp/petsc-lhuj9c/config.types/conftest
            Popping language C
            Defined "SIZEOF_CHAR" to "1"
Checking for size of type: void *
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(void *));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_VOID_P" to "8"
Checking for size of type: short
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(short));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_SHORT" to "2"
Checking for size of type: int
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(int));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_INT" to "4"
Checking for size of type: long
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(long));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_LONG" to "8"
Checking for size of type: long long
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(long long));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_LONG_LONG" to "8"
Checking for size of type: float
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(float));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_FLOAT" to "4"
Checking for size of type: double
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(double));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_DOUBLE" to "8"
Checking for size of type: size_t
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(size_t));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_SIZE_T" to "8"
TEST checkBitsPerByte from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:310)
TESTING: checkBitsPerByte from config.types(config/BuildSystem/config/types.py:310)
  Determine the nubmer of bits per byte and define BITS_PER_BYTE
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#endif
int main() {
    char val[2];
    int i = 0;
    if (!f) exit(1);
    val[0]='\1';
    val[1]='\0';
    while(val[0]) {val[0] <<= 1; i++;}
    fprintf(f, "%d\n", i);
  return 0;
                      Pushing language C
                      Popping language C
          Defined "BITS_PER_BYTE" to "8"
TEST checkVisibility from config.types(/home/jed/petsc/config/BuildSystem/config/types.py:356)
TESTING: checkVisibility from config.types(config/BuildSystem/config/types.py:356)
TEST configureMemAlign from PETSc.options.memAlign(/home/jed/petsc/config/PETSc/options/memAlign.py:30)
TESTING: configureMemAlign from PETSc.options.memAlign(config/PETSc/options/memAlign.py:30)
  Choose alignment
          Defined "MEMALIGN" to "16"
        Memory alignment is 16
TEST check from config.libraries(/home/jed/petsc/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
          Checking for functions [socket] in library ['socket', 'nsl'] []
            Pushing language C
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.libraries/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.libraries/conftest.c
Successful compile:
Source:
char socket();
static void _check_socket() { socket(); }
int main() {
_check_socket();;
  return 0;
                    Pushing language C
                    Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.libraries/conftest.o  -lsocket -lnsl -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
stderr:
/usr/bin/ld: cannot find -lsocket
            Popping language C
          Checking for functions [handle_sigfpes] in library ['fpe'] []
            Pushing language C
Successful compile:
Source:
char handle_sigfpes();
static void _check_handle_sigfpes() { handle_sigfpes(); }
int main() {
_check_handle_sigfpes();;
  return 0;
                    Pushing language C
                    Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.libraries/conftest.o  -lfpe -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
stderr:
/usr/bin/ld: cannot find -lfpe
            Popping language C
            Pushing language C
Successful compile:
Source:
char socket();
int main() {
_check_socket();;
  return 0;
                    Pushing language C
                    Popping language C
stderr:
            Popping language C
            Pushing language C
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
stderr:
            Popping language C
TEST checkMath from config.libraries(/home/jed/petsc/config/BuildSystem/config/libraries.py:251)
TESTING: checkMath from config.libraries(config/BuildSystem/config/libraries.py:251)
  Check for sin() in libm, the math library
          Checking for functions [sin floor log10 pow] in library [''] []
            Pushing language C
stderr:
/tmp/petsc-lhuj9c/config.libraries/conftest.c: In function ?_check_sin?:
/tmp/petsc-lhuj9c/config.libraries/conftest.c:5:41: warning: variable ?y? set but not used [-Wunused-but-set-variable]
 static void _check_sin() { double x = 0,y; y = sin(x);
/tmp/petsc-lhuj9c/config.libraries/conftest.c: In function ?_check_floor?:
/tmp/petsc-lhuj9c/config.libraries/conftest.c:8:43: warning: variable ?y? set but not used [-Wunused-but-set-variable]
 static void _check_floor() { double x = 0,y; y = floor(x);
/tmp/petsc-lhuj9c/config.libraries/conftest.c: In function ?_check_log10?:
/tmp/petsc-lhuj9c/config.libraries/conftest.c:11:43: warning: variable ?y? set but not used [-Wunused-but-set-variable]
 static void _check_log10() { double x = 0,y; y = log10(x);
/tmp/petsc-lhuj9c/config.libraries/conftest.c: In function ?_check_pow?:
/tmp/petsc-lhuj9c/config.libraries/conftest.c:14:41: warning: variable ?y? set but not used [-Wunused-but-set-variable]
 static void _check_pow() { double x = 0,y ; y = pow(x, x);
Source:
double sin(double);
double floor(double);
double log10(double);
double pow(double, double);
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
  return 0;
                    Pushing language C
                    Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.libraries/conftest.o   -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
stderr:
/tmp/petsc-lhuj9c/config.libraries/conftest.o: In function `_check_sin':
/tmp/petsc-lhuj9c/config.libraries/conftest.c:5: undefined reference to `sin'
/tmp/petsc-lhuj9c/config.libraries/conftest.o: In function `_check_floor':
/tmp/petsc-lhuj9c/config.libraries/conftest.c:8: undefined reference to `floor'
/tmp/petsc-lhuj9c/config.libraries/conftest.o: In function `_check_log10':
/tmp/petsc-lhuj9c/config.libraries/conftest.c:11: undefined reference to `log10'
/tmp/petsc-lhuj9c/config.libraries/conftest.o: In function `_check_pow':
/tmp/petsc-lhuj9c/config.libraries/conftest.c:14: undefined reference to `pow'
            Popping language C
          Checking for functions [sin floor log10 pow] in library ['m'] []
            Pushing language C
stderr:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
double sin(double);
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
  return 0;
                    Pushing language C
                    Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.libraries/conftest.o  -lm -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
            Defined "HAVE_LIBM" to "1"
            Popping language C
        Using libm for the math library
TEST checkMathErf from config.libraries(/home/jed/petsc/config/BuildSystem/config/libraries.py:267)
TESTING: checkMathErf from config.libraries(config/BuildSystem/config/libraries.py:267)
  Check for erf() in libm, the math library
          Checking for functions [erf] in library ['libm.a'] []
            Pushing language C
stderr:
/tmp/petsc-lhuj9c/config.libraries/conftest.c: In function ?_check_erf?:
 static void _check_erf() { double x = 0,y; y = erf(x);
Source:
double erf(double);
int main() {
_check_erf();;
  return 0;
                    Pushing language C
                    Popping language C
            Popping language C
        erf() found
          Defined "HAVE_ERF" to "1"
TEST checkMathTgamma from config.libraries(/home/jed/petsc/config/BuildSystem/config/libraries.py:276)
TESTING: checkMathTgamma from config.libraries(config/BuildSystem/config/libraries.py:276)
  Check for tgama() in libm, the math library
          Checking for functions [tgamma] in library ['libm.a'] []
            Pushing language C
stderr:
/tmp/petsc-lhuj9c/config.libraries/conftest.c: In function ?_check_tgamma?:
/tmp/petsc-lhuj9c/config.libraries/conftest.c:5:44: warning: variable ?y? set but not used [-Wunused-but-set-variable]
 static void _check_tgamma() { double x = 0,y; y = tgamma(x);
Source:
double tgamma(double);
int main() {
_check_tgamma();;
  return 0;
                    Pushing language C
                    Popping language C
            Popping language C
        tgamma() found
          Defined "HAVE_TGAMMA" to "1"
TEST checkMathFenv from config.libraries(/home/jed/petsc/config/BuildSystem/config/libraries.py:285)
TESTING: checkMathFenv from config.libraries(config/BuildSystem/config/libraries.py:285)
  Checks if <fenv.h> can be used with FE_DFL_ENV
          Checking for functions [fesetenv] in library ['libm.a'] []
            Pushing language C
Successful compile:
Source:
#include <fenv.h>
static void _check_fesetenv() { fesetenv(FE_DFL_ENV);; }
int main() {
_check_fesetenv();;
  return 0;
                    Pushing language C
                    Popping language C
            Popping language C
          Defined "HAVE_FENV_H" to "1"
TEST checkCompression from config.libraries(/home/jed/petsc/config/BuildSystem/config/libraries.py:293)
TESTING: checkCompression from config.libraries(config/BuildSystem/config/libraries.py:293)
  Check for libz, the compression library
          Checking for functions [compress uncompress] in library [''] []
            Pushing language C
stderr:
/tmp/petsc-lhuj9c/config.libraries/conftest.c: In function ?_check_compress?:
/tmp/petsc-lhuj9c/config.libraries/conftest.c:5:119: warning: variable ?ret? set but not used [-Wunused-but-set-variable]
 static void _check_compress() { char *dest = 0; const char *source = 0; unsigned long destLen = 0, sourceLen = 0; int ret = 0; ret =   compress(dest, &destLen, source, sourceLen);
/tmp/petsc-lhuj9c/config.libraries/conftest.c: In function ?_check_uncompress?:
/tmp/petsc-lhuj9c/config.libraries/conftest.c:8:121: warning: variable ?ret? set but not used [-Wunused-but-set-variable]
 static void _check_uncompress() { char *dest = 0; const char *source = 0; unsigned long destLen = 0, sourceLen = 0; int ret = 0; ret = uncompress(dest, &destLen, source, sourceLen);
Source:
int   compress(char *dest, unsigned long *destLen, const char *source, unsigned long sourceLen);
int uncompress(char *dest, unsigned long *destLen, const char *source, unsigned long sourceLen);
int main() {
_check_compress();
_check_uncompress();;
  return 0;
                    Pushing language C
                    Popping language C
stderr:
/tmp/petsc-lhuj9c/config.libraries/conftest.o: In function `_check_compress':
/tmp/petsc-lhuj9c/config.libraries/conftest.c:5: undefined reference to `compress'
/tmp/petsc-lhuj9c/config.libraries/conftest.o: In function `_check_uncompress':
/tmp/petsc-lhuj9c/config.libraries/conftest.c:8: undefined reference to `uncompress'
            Popping language C
          Checking for functions [compress uncompress] in library ['z'] []
            Pushing language C
stderr:
Source:
int main() {
_check_compress();
  return 0;
                    Pushing language C
                    Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.libraries/conftest.o  -lz -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
            Defined "HAVE_LIBZ" to "1"
            Popping language C
        Using libz for the compression library
TEST checkRealtime from config.libraries(/home/jed/petsc/config/BuildSystem/config/libraries.py:314)
TESTING: checkRealtime from config.libraries(config/BuildSystem/config/libraries.py:314)
  Check for presence of clock_gettime() in realtime library (POSIX Realtime extensions)
          Checking for functions [clock_gettime] in library [''] []
            Pushing language C
Successful compile:
Source:
#include <time.h>
static void _check_clock_gettime() { struct timespec tp; clock_gettime(CLOCK_REALTIME,&tp);; }
int main() {
_check_clock_gettime();;
  return 0;
                    Pushing language C
                    Popping language C
            Popping language C
        realtime functions are linked in by default
TEST checkDynamic from config.libraries(/home/jed/petsc/config/BuildSystem/config/libraries.py:330)
TESTING: checkDynamic from config.libraries(config/BuildSystem/config/libraries.py:330)
  Check for the header and libraries necessary for dynamic library manipulation
          Checking for functions [dlopen] in library ['dl'] []
            Pushing language C
Successful compile:
Source:
char dlopen();
static void _check_dlopen() { dlopen(); }
int main() {
_check_dlopen();;
  return 0;
                    Pushing language C
                    Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.libraries/conftest.o  -ldl -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
            Defined "HAVE_LIBDL" to "1"
            Popping language C
Checking for header: dlfcn.h
Executing: /opt/mpich/bin/mpicc -E  -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.headers  /tmp/petsc-lhuj9c/config.headers/conftest.c
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
# 1 "/usr/include/dlfcn.h" 1 3 4
# 22 "/usr/include/dlfcn.h" 3 4
# 23 "/usr/include/dlfcn.h" 2 3 4
# 25 "/usr/include/dlfcn.h" 2 3 4
# 1 "/usr/include/bits/dlfcn.h" 1 3 4
# 28 "/usr/include/dlfcn.h" 2 3 4
# 52 "/usr/include/dlfcn.h" 3 4
extern void *dlopen (const char *__file, int __mode) __attribute__ ((__nothrow__));
extern int dlclose (void *__handle) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
extern void *dlsym (void *__restrict __handle,
      const char *__restrict __name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 82 "/usr/include/dlfcn.h" 3 4
extern char *dlerror (void) __attribute__ ((__nothrow__ , __leaf__));
# 188 "/usr/include/dlfcn.h" 3 4
            Defined "HAVE_DLFCN_H" to "1"
TEST configureMissingDefines from config.utilities.missing(/home/jed/petsc/config/BuildSystem/config/utilities/missing.py:41)
TESTING: configureMissingDefines from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:41)
  Checks for limits
                    All intermediate test results are stored in /tmp/petsc-lhuj9c/config.utilities.missing
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.utilities.missing/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.utilities.missing  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.utilities.missing/conftest.c
Successful compile:
Source:
#ifdef PETSC_HAVE_LIMITS_H
  #include <limits.h>
#endif
int main() {
int i=INT_MAX;
if (i);
  return 0;
Successful compile:
Source:
#ifdef PETSC_HAVE_FLOAT_H
  #include <float.h>
#endif
int main() {
double d=DBL_MAX;
if (d);
  return 0;
TEST configureMissingUtypeTypedefs from config.utilities.missing(/home/jed/petsc/config/BuildSystem/config/utilities/missing.py:51)
TESTING: configureMissingUtypeTypedefs from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:51)
   Checks if u_short is undefined
Possible ERROR while running compiler:
stderr:
/tmp/petsc-lhuj9c/config.utilities.missing/conftest.c: In function ?main?:
/tmp/petsc-lhuj9c/config.utilities.missing/conftest.c:6:9: warning: unused variable ?foo? [-Wunused-variable]
 u_short foo;
Source:
int main() {
u_short foo;
  return 0;
TEST configureMissingFunctions from config.utilities.missing(/home/jed/petsc/config/BuildSystem/config/utilities/missing.py:57)
TESTING: configureMissingFunctions from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:57)
  Checks for SOCKETS
TEST configureMissingSignals from config.utilities.missing(/home/jed/petsc/config/BuildSystem/config/utilities/missing.py:77)
TESTING: configureMissingSignals from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:77)
  Check for missing signals, and define MISSING_<signal name> if necessary
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGABRT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGALRM;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGBUS;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCHLD;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCONT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGFPE;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGHUP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGILL;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGINT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGKILL;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGPIPE;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGQUIT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSEGV;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSTOP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSYS;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTERM;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTRAP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTSTP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGURG;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR1;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR2;
if (i);
  return 0;
TEST configureMissingGetdomainnamePrototype from config.utilities.missing(/home/jed/petsc/config/BuildSystem/config/utilities/missing.py:94)
TESTING: configureMissingGetdomainnamePrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:94)
Successful compile:
Source:
#define _BSD_SOURCE
#define _GNU_SOURCE
#ifdef PETSC_HAVE_UNISTD_H
#include <unistd.h>
#endif
#ifdef PETSC_HAVE_NETDB_H
#include <netdb.h>
#endif
int main() {
int (*getdomainname_ptr)(char*,size_t) = getdomainname;
char test[10];
if (getdomainname_ptr(test,10)) return 1;
  return 0;
          Pushing language Cxx
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.utilities.missing/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.utilities.missing  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0   -fPIC   /tmp/petsc-lhuj9c/config.utilities.missing/conftest.cc
stderr:
/tmp/petsc-lhuj9c/config.utilities.missing/conftest.cc:5:0: warning: "_GNU_SOURCE" redefined
 #define _GNU_SOURCE
<command-line>:0:0: note: this is the location of the previous definition
Source:
#define _BSD_SOURCE
#define _GNU_SOURCE
#include <unistd.h>
#endif
#include <netdb.h>
#endif
int main() {
char test[10];
  return 0;
                  Pushing language CXX
                  Popping language CXX
Executing: /opt/mpich/bin/mpicxx  -o /tmp/petsc-lhuj9c/config.utilities.missing/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  /tmp/petsc-lhuj9c/config.utilities.missing/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
          Popping language Cxx
TEST configureMissingSrandPrototype from config.utilities.missing(/home/jed/petsc/config/BuildSystem/config/utilities/missing.py:119)
TESTING: configureMissingSrandPrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:119)
Successful compile:
Source:
#define _BSD_SOURCE
#define _GNU_SOURCE
#ifdef PETSC_HAVE_STDLIB_H
#include <stdlib.h>
#endif
int main() {
double (*drand48_ptr)(void) = drand48;
void (*srand48_ptr)(long int) = srand48;
long int seed=10;
srand48_ptr(seed);
if (drand48_ptr() > 0.5) return 1;
  return 0;
stderr:
 #define _GNU_SOURCE
Source:
#define _BSD_SOURCE
#define _GNU_SOURCE
#include <stdlib.h>
#endif
int main() {
long int seed=10;
srand48_ptr(seed);
  return 0;
TEST configureFortranCommandLine from config.utilities.fortranCommandLine(/home/jed/petsc/config/BuildSystem/config/utilities/fortranCommandLine.py:27)
TESTING: configureFortranCommandLine from config.utilities.fortranCommandLine(config/BuildSystem/config/utilities/fortranCommandLine.py:27)
  Check for the mechanism to retrieve command line arguments in Fortran
          Pushing language FC
          Checking for functions [] in library [''] []
            Pushing language FC
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.libraries/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /tmp/petsc-lhuj9c/config.libraries/conftest.F
Successful compile:
Source:
      program main
      integer i
      character*(80) arg
       call get_command_argument(i,arg)
      end
                    Pushing language FC
                    Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /tmp/petsc-lhuj9c/config.libraries/conftest.o   -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
            Popping language FC
          Defined "HAVE_FORTRAN_GET_COMMAND_ARGUMENT" to "1"
          Popping language FC
          Pushing language C
          Checking for functions [get_command_argument_] in library [''] ['-Wl,-rpath,/opt/mpich/lib', '-L/opt/mpich/lib', '-Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1', '-L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1', '-lmpifort', '-lgfortran', '-lm', '-Wl,-rpath,/opt/mpich/lib', '-Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1', '-lgfortran', '-lm', '-lquadmath', '-lm']
            Pushing language C
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.libraries/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.utilities.missing  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.libraries/conftest.c
Successful compile:
Source:
char get_command_argument_();
static void _check_get_command_argument_() { get_command_argument_(); }
int main() {
_check_get_command_argument_();;
  return 0;
                    Pushing language C
                    Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.libraries/conftest.o  -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lmpifort -lgfortran -lm -Wl,-rpath,/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lgfortran -lm -lquadmath -lm -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
Possible ERROR while running linker: exit code 256
stderr:
/tmp/petsc-lhuj9c/config.libraries/conftest.o: In function `_check_get_command_argument_':
/tmp/petsc-lhuj9c/config.libraries/conftest.c:5: undefined reference to `get_command_argument_'
collect2: error: ld returned 1 exit status
            Popping language C
          Checking for functions [getarg_] in library [''] ['-Wl,-rpath,/opt/mpich/lib', '-L/opt/mpich/lib', '-Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1', '-L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1', '-lmpifort', '-lgfortran', '-lm', '-Wl,-rpath,/opt/mpich/lib', '-Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1', '-lgfortran', '-lm', '-lquadmath', '-lm']
            Pushing language C
Successful compile:
Source:
char getarg_();
static void _check_getarg_() { getarg_(); }
int main() {
_check_getarg_();;
  return 0;
                    Pushing language C
                    Popping language C
stderr:
/tmp/petsc-lhuj9c/config.libraries/conftest.o: In function `_check_getarg_':
/tmp/petsc-lhuj9c/config.libraries/conftest.c:5: undefined reference to `getarg_'
            Popping language C
Checking for functions [ipxfargc_]
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.functions/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.functions/conftest.c
Successful compile:
Source:
/* System header to define __stub macros and hopefully no other prototypes since they would conflict with our 'char funcname()' declaration below. */
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char ipxfargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_ipxfargc_) || defined (__stub___ipxfargc_)
ipxfargc__will_always_fail_with_ENOSYS();
#else
ipxfargc_();
#endif
  return 0;
                    Pushing language C
                    Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.functions/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.functions/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl  -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lmpifort -lgfortran -lm -Wl,-rpath,/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -lgfortran -lm -lquadmath -lm
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.o: In function `main':
/tmp/petsc-lhuj9c/config.functions/conftest.c:24: undefined reference to `ipxfargc_'
Checking for functions [f90_unix_MP_iargc]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char f90_unix_MP_iargc();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_f90_unix_MP_iargc) || defined (__stub___f90_unix_MP_iargc)
f90_unix_MP_iargc_will_always_fail_with_ENOSYS();
#else
#endif
  return 0;
                    Pushing language C
                    Popping language C
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:24: undefined reference to `f90_unix_MP_iargc'
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_PXFGETARG) || defined (__stub___PXFGETARG)
PXFGETARG_will_always_fail_with_ENOSYS();
#else
PXFGETARG();
#endif
  return 0;
                    Pushing language C
                    Popping language C
stderr:
Checking for functions [iargc_]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char iargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_iargc_) || defined (__stub___iargc_)
iargc__will_always_fail_with_ENOSYS();
#else
iargc_();
#endif
  return 0;
                    Pushing language C
                    Popping language C
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:24: undefined reference to `iargc_'
Checking for functions [GETARG at 16]
Possible ERROR while running compiler: exit code 256
stderr:
/tmp/petsc-lhuj9c/config.functions/conftest.c:13:12: error: stray ?@? in program
 char GETARG at 16();
/tmp/petsc-lhuj9c/config.functions/conftest.c:13:13: error: expected ?=?, ?,?, ?;?, ?asm? or ?__attribute__? before numeric constant
/tmp/petsc-lhuj9c/config.functions/conftest.c: In function ?main?:
/tmp/petsc-lhuj9c/config.functions/conftest.c:21:27: error: missing ')' after "defined"
 #if defined (__stub_GETARG at 16) || defined (__stub___GETARG at 16)
/tmp/petsc-lhuj9c/config.functions/conftest.c:21:28: error: missing binary operator before token "16"
/tmp/petsc-lhuj9c/config.functions/conftest.c:24:7: error: stray ?@? in program
 GETARG at 16();
/tmp/petsc-lhuj9c/config.functions/conftest.c:24:1: error: ?GETARG? undeclared (first use in this function)
 GETARG at 16();
/tmp/petsc-lhuj9c/config.functions/conftest.c:24:1: note: each undeclared identifier is reported only once for each function it appears in
/tmp/petsc-lhuj9c/config.functions/conftest.c:24:8: error: expected ?;? before numeric constant
 GETARG at 16();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
GETARG at 16_will_always_fail_with_ENOSYS();
#else
GETARG at 16();
#endif
  return 0;
              Compile failed inside link
Checking for functions [_gfortran_iargc]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _gfortran_iargc();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub__gfortran_iargc) || defined (__stub____gfortran_iargc)
_gfortran_iargc_will_always_fail_with_ENOSYS();
#else
_gfortran_iargc();
#endif
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE__GFORTRAN_IARGC" to "1"
          Defined "HAVE_GFORTRAN_IARGC" to "1"
          Popping language C
TEST configureCPURelax from config.atomics(/home/jed/petsc/config/BuildSystem/config/atomics.py:17)
TESTING: configureCPURelax from config.atomics(config/BuildSystem/config/atomics.py:17)
   Definitions for cpu relax assembly instructions
                    All intermediate test results are stored in /tmp/petsc-lhuj9c/config.atomics
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.atomics/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.functions  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.atomics/conftest.c
Successful compile:
Source:
int main() {
asm volatile("rep; nop" ::: "memory");;
  return 0;
          Defined "CPU_RELAX()" to "asm volatile("rep; nop" ::: "memory")"
TEST configureMemoryBarriers from config.atomics(/home/jed/petsc/config/BuildSystem/config/atomics.py:36)
TESTING: configureMemoryBarriers from config.atomics(config/BuildSystem/config/atomics.py:36)
   Definitions for memory barrier instructions
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.atomics/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.atomics  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.atomics/conftest.c
Successful compile:
Source:
int main() {
asm volatile("mfence":::"memory");
  return 0;
          Defined "MEMORY_BARRIER()" to "asm volatile("mfence":::"memory")"
Successful compile:
Source:
int main() {
asm volatile("lfence":::"memory");
  return 0;
          Defined "READ_MEMORY_BARRIER()" to "asm volatile("lfence":::"memory")"
Successful compile:
Source:
int main() {
asm volatile("sfence":::"memory");
  return 0;
          Defined "WRITE_MEMORY_BARRIER()" to "asm volatile("sfence":::"memory")"
TEST configureMkdir from config.programs(/home/jed/petsc/config/BuildSystem/config/programs.py:22)
TESTING: configureMkdir from config.programs(config/BuildSystem/config/programs.py:22)
  Make sure we can have mkdir automatically make intermediate directories
Checking for program /home/jed/bin/mkdir...not found
Checking for program /usr/bin/mkdir...found
Executing: /usr/bin/mkdir -p .conftest/tmp
        Adding -p flag to /usr/bin/mkdir -p to automatically create directories
          Defined make macro "MKDIR" to "/usr/bin/mkdir -p"
TEST configureAutoreconf from config.programs(/home/jed/petsc/config/BuildSystem/config/programs.py:44)
TESTING: configureAutoreconf from config.programs(config/BuildSystem/config/programs.py:44)
  Check for autoreconf
Checking for program /home/jed/bin/autoreconf...not found
Checking for program /usr/bin/autoreconf...found
          All intermediate test results are stored in /tmp/petsc-lhuj9c/config.programs
Executing: cd /tmp/petsc-lhuj9c/config.programs/autoconfdir&&/usr/bin/autoreconf
        autoreconf test successful!
TEST configurePrograms from config.programs(/home/jed/petsc/config/BuildSystem/config/programs.py:66)
TESTING: configurePrograms from config.programs(config/BuildSystem/config/programs.py:66)
  Check for the programs needed to build and run PETSc
Checking for program /home/jed/bin/sh...not found
Checking for program /usr/bin/sh...found
            Defined make macro "SHELL" to "/usr/bin/sh"
Checking for program /home/jed/bin/sed...not found
Checking for program /usr/bin/sed...found
            Defined make macro "SED" to "/usr/bin/sed"
Executing: /usr/bin/sed -i s/sed/sd/g "/tmp/petsc-lhuj9c/config.programs/sed1"
        Adding SEDINPLACE cmd: /usr/bin/sed -i
          Defined make macro "SEDINPLACE" to "/usr/bin/sed -i"
Checking for program /home/jed/bin/mv...not found
Checking for program /usr/bin/mv...found
            Defined make macro "MV" to "/usr/bin/mv"
Checking for program /home/jed/bin/cp...not found
Checking for program /usr/bin/cp...found
            Defined make macro "CP" to "/usr/bin/cp"
Checking for program /home/jed/bin/grep...not found
Checking for program /usr/bin/grep...found
            Defined make macro "GREP" to "/usr/bin/grep"
Checking for program /home/jed/bin/rm...not found
Checking for program /usr/bin/rm...found
            Defined make macro "RM" to "/usr/bin/rm -f"
Checking for program /home/jed/bin/diff...not found
Checking for program /usr/bin/diff...found
Executing: "/usr/bin/diff" -w "/tmp/petsc-lhuj9c/config.programs/diff1" "/tmp/petsc-lhuj9c/config.programs/diff2"
          Defined make macro "DIFF" to "/usr/bin/diff -w"
Checking for program /usr/ucb/ps...not found
Checking for program /usr/usb/ps...not found
Checking for program /home/jed/ps...not found
Checking for program /home/jed/petsc/bin/win32fe/ps...not found
Checking for program /home/jed/bin/gzip...not found
Checking for program /usr/bin/gzip...found
            Defined make macro "GZIP" to "/usr/bin/gzip"
          Defined "HAVE_GZIP" to "1"
          Defined make macro "PYTHON" to "/usr/bin/python2"
TEST configureMake from config.packages.make(/home/jed/petsc/config/BuildSystem/config/packages/make.py:67)
TESTING: configureMake from config.packages.make(config/BuildSystem/config/packages/make.py:67)
  Check for user specified make - or gmake, make
Checking for program /home/jed/bin/gmake...not found
Checking for program /usr/bin/gmake...not found
Checking for program /usr/lib/mailman/bin/gmake...not found
Checking for program /opt/mpich/bin/gmake...not found
Checking for program /usr/bin/site_perl/gmake...not found
Checking for program /usr/bin/vendor_perl/gmake...not found
Checking for program /usr/bin/core_perl/gmake...not found
Checking for program /opt/visit/bin/gmake...not found
Checking for program /home/jed/gmake...not found
Checking for program /home/jed/petsc/bin/win32fe/gmake...not found
Checking for program /home/jed/bin/make...not found
Checking for program /usr/bin/make...found
            Defined make macro "MAKE" to "/usr/bin/make"
TEST configureCheckGNUMake from config.packages.make(/home/jed/petsc/config/BuildSystem/config/packages/make.py:85)
TESTING: configureCheckGNUMake from config.packages.make(config/BuildSystem/config/packages/make.py:85)
  Check for GNU make
Executing: /usr/bin/make --version
stdout:
GNU Make 4.1
Built for x86_64-unknown-linux-gnu
Copyright (C) 1988-2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
          Defined make macro "MAKE_IS_GNUMAKE" to "1"
          Defined make rule "libc" with dependencies "${LIBNAME}(${OBJSC})" and code []
          Defined make rule "libcxx" with dependencies "${LIBNAME}(${OBJSCXX})" and code []
          Defined make rule "libcu" with dependencies "${LIBNAME}(${OBJSCU})" and code []
          Defined make rule "libf" with dependencies "${OBJSF}" and code -${AR} ${AR_FLAGS} ${LIBNAME} ${OBJSF}
TEST configureMakeNP from config.packages.make(/home/jed/petsc/config/BuildSystem/config/packages/make.py:120)
TESTING: configureMakeNP from config.packages.make(config/BuildSystem/config/packages/make.py:120)
  check no of cores on the build machine [perhaps to do make '-j ncores']
        module multiprocessing found 4 cores: using make_np = 4
          Defined make macro "MAKE_NP" to "4"
      Defined make macro "OMAKE_PRINTDIR " to "/usr/bin/make  --print-directory"
      Defined make macro "OMAKE" to "/usr/bin/make  --no-print-directory"
TEST alternateConfigureLibrary from config.packages.MPICH(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.MPICH(config/BuildSystem/config/package.py:596)
  Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from config.packages.OpenMPI(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.OpenMPI(config/BuildSystem/config/package.py:596)
    PETSc clone, checking for Sowing
Checking for program /home/jed/bin/pdflatex...not found
Checking for program /usr/bin/pdflatex...found
        Defined make macro "PDFLATEX" to "/usr/bin/pdflatex"
Checking for program /home/jed/bin/bfort...not found
Checking for program /usr/bin/bfort...found
        Defined make macro "BFORT" to "/usr/bin/bfort"
Checking for program /home/jed/bin/doctext...not found
Checking for program /usr/bin/doctext...found
        Defined make macro "DOCTEXT" to "/usr/bin/doctext"
Checking for program /home/jed/bin/mapnames...not found
Checking for program /usr/bin/mapnames...found
        Defined make macro "MAPNAMES" to "/usr/bin/mapnames"
Checking for program /home/jed/bin/bib2html...not found
Checking for program /usr/bin/bib2html...found
        Defined make macro "BIB2HTML" to "/usr/bin/bib2html"
    Found bfort, not installing sowing
           Running /usr/bin/bfort to generate fortran stubs
TEST alternateConfigureLibrary from config.packages.yaml(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.yaml(config/BuildSystem/config/package.py:596)
      Pushing language C
TEST configureLibrary from config.packages.valgrind(/home/jed/petsc/config/BuildSystem/config/package.py:538)
TESTING: configureLibrary from config.packages.valgrind(config/BuildSystem/config/package.py:538)
  Find an installation and check if it can work with PETSc
        Checking for a functional valgrind
        Not checking for library in Package specific search directory VALGRIND: [] because no functions given to check for
            No functions to check for in library [] []
        Checking for headers Package specific search directory VALGRIND: ['/opt/mpich/include']
            Pushing language C
TEST checkInclude from config.headers(/home/jed/petsc/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
  Checks if a particular include file can be found along particular include paths
Checking for header files ['valgrind/valgrind.h'] in ['/opt/mpich/include']
              Checking include with compiler flags var CPPFLAGS ['/opt/mpich/include']
Executing: /opt/mpich/bin/mpicc -E  -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.headers  -I/opt/mpich/include /tmp/petsc-lhuj9c/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-lhuj9c/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/conffix.h" 1
# 1 "/usr/include/valgrind/valgrind.h" 1 3 4
# 95 "/usr/include/valgrind/valgrind.h" 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdarg.h" 1 3 4
# 40 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdarg.h" 3 4
typedef __builtin_va_list __gnuc_va_list;
# 98 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdarg.h" 3 4
typedef __gnuc_va_list va_list;
# 96 "/usr/include/valgrind/valgrind.h" 2 3 4
# 390 "/usr/include/valgrind/valgrind.h" 3 4
typedef
   struct {
      unsigned long long int nraddr;
   OrigFn;
# 6111 "/usr/include/valgrind/valgrind.h" 3 4
typedef
   enum { VG_USERREQ__RUNNING_ON_VALGRIND = 0x1001,
          VG_USERREQ__DISCARD_TRANSLATIONS = 0x1002,
          VG_USERREQ__CLIENT_CALL0 = 0x1101,
          VG_USERREQ__CLIENT_CALL1 = 0x1102,
          VG_USERREQ__CLIENT_CALL2 = 0x1103,
          VG_USERREQ__CLIENT_CALL3 = 0x1104,
          VG_USERREQ__COUNT_ERRORS = 0x1201,
          VG_USERREQ__GDB_MONITOR_COMMAND = 0x1202,
          VG_USERREQ__MALLOCLIKE_BLOCK = 0x1301,
          VG_USERREQ__RESIZEINPLACE_BLOCK = 0x130b,
          VG_USERREQ__FREELIKE_BLOCK = 0x1302,
          VG_USERREQ__CREATE_MEMPOOL = 0x1303,
          VG_USERREQ__DESTROY_MEMPOOL = 0x1304,
          VG_USERREQ__MEMPOOL_ALLOC = 0x1305,
          VG_USERREQ__MEMPOOL_FREE = 0x1306,
          VG_USERREQ__MEMPOOL_TRIM = 0x1307,
          VG_USERREQ__MOVE_MEMPOOL = 0x1308,
          VG_USERREQ__MEMPOOL_CHANGE = 0x1309,
          VG_USERREQ__MEMPOOL_EXISTS = 0x130a,
# 6156 "/usr/include/valgrind/valgrind.h" 3 4
          VG_USERREQ__PRINTF = 0x1401,
          VG_USERREQ__PRINTF_BACKTRACE = 0x1402,
          VG_USERREQ__PRINTF_VALIST_BY_REF = 0x1403,
          VG_USERREQ__PRINTF_BACKTRACE_VALIST_BY_REF = 0x1404,
          VG_USERREQ__STACK_REGISTER = 0x1501,
          VG_USERREQ__STACK_DEREGISTER = 0x1502,
          VG_USERREQ__STACK_CHANGE = 0x1503,
          VG_USERREQ__LOAD_PDB_DEBUGINFO = 0x1601,
          VG_USERREQ__MAP_IP_TO_SRCLOC = 0x1701,
          VG_USERREQ__CHANGE_ERR_DISABLEMENT = 0x1801,
          VG_USERREQ__VEX_INIT_FOR_IRI = 0x1901
   } Vg_ClientRequest;
# 6216 "/usr/include/valgrind/valgrind.h" 3 4
static int VALGRIND_PRINTF(const char *format, ...)
   __attribute__((format(__printf__, 1, 2), __unused__));
static int
   unsigned long _qzz_res;
   va_list vargs;
   __builtin_va_start(vargs,format);
   _qzz_res = __extension__ ({ volatile unsigned long long int _zzq_args[6]; volatile unsigned long long int _zzq_result; _zzq_args[0] = (unsigned long long int)(VG_USERREQ__PRINTF_VALIST_BY_REF); _zzq_args[1] = (unsigned long long int)((unsigned long)format); _zzq_args[2] = (unsigned long long int)((unsigned long)&vargs); _zzq_args[3] = (unsigned long long int)(0); _zzq_args[4] = (unsigned long long int)(0); _zzq_args[5] = (unsigned long long int)(0); __asm__ volatile("rolq $3,  %%rdi ; rolq $13, %%rdi\n\t" "rolq $61, %%rdi ; rolq $51, %%rdi\n\t" "xchgq %%rbx,%%rbx" : "=d" (_zzq_result) : "a" (&_zzq_args[0]), "0" (0) : "cc", "memory" ); _zzq_result; })
   __builtin_va_end(vargs);
   return (int)_qzz_res;
static int VALGRIND_PRINTF_BACKTRACE(const char *format, ...)
static int
   va_list vargs;
   _qzz_res = __extension__ ({ volatile unsigned long long int _zzq_args[6]; volatile unsigned long long int _zzq_result; _zzq_args[0] = (unsigned long long int)(VG_USERREQ__PRINTF_BACKTRACE_VALIST_BY_REF); _zzq_args[1] = (unsigned long long int)((unsigned long)format); _zzq_args[2] = (unsigned long long int)((unsigned long)&vargs); _zzq_args[3] = (unsigned long long int)(0); _zzq_args[4] = (unsigned long long int)(0); _zzq_args[5] = (unsigned long long int)(0); __asm__ volatile("rolq $3,  %%rdi ; rolq $13, %%rdi\n\t" "rolq $61, %%rdi ; rolq $51, %%rdi\n\t" "xchgq %%rbx,%%rbx" : "=d" (_zzq_result) : "a" (&_zzq_args[0]), "0" (0) : "cc", "memory" ); _zzq_result; })
Found header files ['valgrind/valgrind.h'] in ['/opt/mpich/include']
            Popping language C
                All intermediate test results are stored in /tmp/petsc-lhuj9c/config.packages.valgrind
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.packages.valgrind/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0   /tmp/petsc-lhuj9c/config.packages.valgrind/conftest.c
Successful compile:
Source:
#include <valgrind/valgrind.h>
int main() {
RUNNING_ON_VALGRIND;
  return 0;
      Popping language C
TEST alternateConfigureLibrary from config.packages.threadcomm(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.threadcomm(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.tetgen(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.tetgen(config/BuildSystem/config/package.py:596)
      Pushing language C
TEST configureLibrary from config.packages.ssl(/home/jed/petsc/config/BuildSystem/config/packages/ssl.py:26)
TESTING: configureLibrary from config.packages.ssl(config/BuildSystem/config/packages/ssl.py:26)
          Checking for a functional ssl
          Checking for library in Package specific search directory SSL: ['libssl.a', 'libcrypto.a']
              Checking for functions [SSLv23_method] in library ['libssl.a', 'libcrypto.a'] []
                Pushing language C
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.libraries/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.libraries  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.libraries/conftest.c
Successful compile:
Source:
char SSLv23_method();
static void _check_SSLv23_method() { SSLv23_method(); }
int main() {
_check_SSLv23_method();;
  return 0;
                        Pushing language C
                        Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.libraries/conftest.o  -lssl -lcrypto -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
                Defined "HAVE_LIBSSL" to "1"
                Defined "HAVE_LIBCRYPTO" to "1"
                Popping language C
          Checking for headers Package specific search directory SSL: ['/opt/mpich/include']
              Pushing language C
Checking for header files ['openssl/ssl.h'] in ['/opt/mpich/include']
stdout:
# 1 "<built-in>"
# 1 "/usr/include/openssl/ssl.h" 1 3 4
# 146 "/usr/include/openssl/ssl.h" 3 4
# 1 "/usr/include/openssl/e_os2.h" 1 3 4
# 56 "/usr/include/openssl/e_os2.h" 3 4
# 1 "/usr/include/openssl/opensslconf.h" 1 3 4
# 57 "/usr/include/openssl/e_os2.h" 2 3 4
# 147 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/comp.h" 1 3 4
# 1 "/usr/include/openssl/crypto.h" 1 3 4
# 120 "/usr/include/openssl/crypto.h" 3 4
# 1 "/usr/include/stdlib.h" 1 3 4
# 24 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 395 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 396 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 25 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 324 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef int wchar_t;
# 33 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitflags.h" 1 3 4
# 42 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitstatus.h" 1 3 4
# 64 "/usr/include/bits/waitstatus.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 27 "/usr/include/bits/byteswap.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 28 "/usr/include/bits/byteswap.h" 2 3 4
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 65 "/usr/include/bits/waitstatus.h" 2 3 4
union wait
    int w_status;
    struct
 unsigned int __w_termsig:7;
 unsigned int __w_coredump:1;
 unsigned int __w_retcode:8;
 unsigned int:16;
      } __wait_terminated;
    struct
 unsigned int __w_stopval:8;
 unsigned int __w_stopsig:8;
 unsigned int:16;
      } __wait_stopped;
# 43 "/usr/include/stdlib.h" 2 3 4
# 67 "/usr/include/stdlib.h" 3 4
typedef union
    union wait *__uptr;
    int *__iptr;
  } __WAIT_STATUS __attribute__ ((__transparent_union__));
# 95 "/usr/include/stdlib.h" 3 4
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
# 139 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (const char *__nptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
__extension__ extern long long int atoll (const char *__nptr)
extern double strtod (const char *__restrict __nptr,
        char **__restrict __endptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern float strtof (const char *__restrict __nptr,
       char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long double strtold (const char *__restrict __nptr,
extern long int strtol (const char *__restrict __nptr,
   char **__restrict __endptr, int __base)
extern unsigned long int strtoul (const char *__restrict __nptr,
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
# 305 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (const char *__s)
# 1 "/usr/include/sys/types.h" 1 3 4
# 27 "/usr/include/sys/types.h" 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 60 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 98 "/usr/include/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 132 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/time.h" 1 3 4
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 133 "/usr/include/sys/types.h" 2 3 4
# 146 "/usr/include/sys/types.h" 3 4
# 147 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 194 "/usr/include/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 219 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/sigset.h" 1 3 4
# 22 "/usr/include/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
# 44 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 46 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 64 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 96 "/usr/include/sys/select.h" 3 4
# 106 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 118 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 131 "/usr/include/sys/select.h" 3 4
# 220 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/sysmacros.h" 1 3 4
# 24 "/usr/include/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 58 "/usr/include/sys/sysmacros.h" 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 270 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 271 "/usr/include/sys/types.h" 2 3 4
# 315 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
   size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
       int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
   size_t __statelen,
   struct random_data *__restrict __buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    __extension__ unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
        double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
        long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
       struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void cfree (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/alloca.h" 1 3 4
# 24 "/usr/include/alloca.h" 3 4
# 25 "/usr/include/alloca.h" 2 3 4
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
# 493 "/usr/include/stdlib.h" 2 3 4
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 513 "/usr/include/stdlib.h" 3 4
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 530 "/usr/include/stdlib.h" 3 4
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 578 "/usr/include/stdlib.h" 3 4
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 606 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 619 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 641 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 662 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 711 "/usr/include/stdlib.h" 3 4
extern int system (const char *__command) ;
# 733 "/usr/include/stdlib.h" 3 4
extern char *realpath (const char *__restrict __name,
         char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
typedef int (*__compar_fn_t) (const void *, const void *);
# 751 "/usr/include/stdlib.h" 3 4
extern void *bsearch (const void *__key, const void *__base,
        size_t __nmemb, size_t __size, __compar_fn_t __compar)
     __attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
     __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 774 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
        long long int __denom)
# 811 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign, char *__restrict __buf,
     size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign,
      char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int mbtowc (wchar_t *__restrict __pwc,
     const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__));
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
extern size_t wcstombs (char *__restrict __s,
   const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 898 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
        char *const *__restrict __tokens,
        char **__restrict __valuep)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 950 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 1 "/usr/include/bits/stdlib-float.h" 1 3 4
# 955 "/usr/include/stdlib.h" 2 3 4
# 967 "/usr/include/stdlib.h" 3 4
# 121 "/usr/include/openssl/crypto.h" 2 3 4
# 123 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/stdio.h" 1 3 4
# 29 "/usr/include/stdio.h" 3 4
# 34 "/usr/include/stdio.h" 2 3 4
# 44 "/usr/include/stdio.h" 3 4
struct _IO_FILE;
typedef struct _IO_FILE FILE;
# 64 "/usr/include/stdio.h" 3 4
typedef struct _IO_FILE __FILE;
# 74 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/libio.h" 1 3 4
# 31 "/usr/include/libio.h" 3 4
# 1 "/usr/include/_G_config.h" 1 3 4
# 15 "/usr/include/_G_config.h" 3 4
# 16 "/usr/include/_G_config.h" 2 3 4
# 1 "/usr/include/wchar.h" 1 3 4
# 82 "/usr/include/wchar.h" 3 4
typedef struct
  int __count;
  union
    unsigned int __wch;
    char __wchb[4];
  } __value;
} __mbstate_t;
# 21 "/usr/include/_G_config.h" 2 3 4
typedef struct
  __off_t __pos;
  __mbstate_t __state;
} _G_fpos_t;
typedef struct
  __off64_t __pos;
} _G_fpos64_t;
# 32 "/usr/include/libio.h" 2 3 4
# 49 "/usr/include/libio.h" 3 4
# 50 "/usr/include/libio.h" 2 3 4
# 144 "/usr/include/libio.h" 3 4
struct _IO_jump_t; struct _IO_FILE;
# 154 "/usr/include/libio.h" 3 4
typedef void _IO_lock_t;
struct _IO_marker {
  struct _IO_marker *_next;
  struct _IO_FILE *_sbuf;
  int _pos;
# 177 "/usr/include/libio.h" 3 4
enum __codecvt_result
  __codecvt_ok,
  __codecvt_partial,
  __codecvt_error,
  __codecvt_noconv
# 245 "/usr/include/libio.h" 3 4
struct _IO_FILE {
  int _flags;
  char* _IO_read_ptr;
  char* _IO_read_end;
  char* _IO_read_base;
  char* _IO_write_base;
  char* _IO_write_ptr;
  char* _IO_write_end;
  char* _IO_buf_base;
  char* _IO_buf_end;
  char *_IO_save_base;
  char *_IO_backup_base;
  char *_IO_save_end;
  struct _IO_marker *_markers;
  struct _IO_FILE *_chain;
  int _fileno;
  int _flags2;
  __off_t _old_offset;
  unsigned short _cur_column;
  signed char _vtable_offset;
  char _shortbuf[1];
  _IO_lock_t *_lock;
# 293 "/usr/include/libio.h" 3 4
  __off64_t _offset;
# 302 "/usr/include/libio.h" 3 4
  void *__pad1;
  void *__pad2;
  void *__pad3;
  void *__pad4;
  size_t __pad5;
  int _mode;
  char _unused2[15 * sizeof (int) - 4 * sizeof (void *) - sizeof (size_t)];
typedef struct _IO_FILE _IO_FILE;
struct _IO_FILE_plus;
extern struct _IO_FILE_plus _IO_2_1_stdin_;
extern struct _IO_FILE_plus _IO_2_1_stdout_;
extern struct _IO_FILE_plus _IO_2_1_stderr_;
# 338 "/usr/include/libio.h" 3 4
typedef __ssize_t __io_read_fn (void *__cookie, char *__buf, size_t __nbytes);
typedef __ssize_t __io_write_fn (void *__cookie, const char *__buf,
     size_t __n);
typedef int __io_seek_fn (void *__cookie, __off64_t *__pos, int __w);
typedef int __io_close_fn (void *__cookie);
# 390 "/usr/include/libio.h" 3 4
extern int __underflow (_IO_FILE *);
extern int __uflow (_IO_FILE *);
extern int __overflow (_IO_FILE *, int);
# 434 "/usr/include/libio.h" 3 4
extern int _IO_getc (_IO_FILE *__fp);
extern int _IO_putc (int __c, _IO_FILE *__fp);
extern int _IO_feof (_IO_FILE *__fp) __attribute__ ((__nothrow__ , __leaf__));
extern int _IO_ferror (_IO_FILE *__fp) __attribute__ ((__nothrow__ , __leaf__));
extern int _IO_peekc_locked (_IO_FILE *__fp);
extern void _IO_flockfile (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
extern void _IO_funlockfile (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
extern int _IO_ftrylockfile (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
# 464 "/usr/include/libio.h" 3 4
extern int _IO_vfscanf (_IO_FILE * __restrict, const char * __restrict,
   __gnuc_va_list, int *__restrict);
extern int _IO_vfprintf (_IO_FILE *__restrict, const char *__restrict,
    __gnuc_va_list);
extern __ssize_t _IO_padn (_IO_FILE *, int, __ssize_t);
extern size_t _IO_sgetn (_IO_FILE *, void *, size_t);
extern __off64_t _IO_seekoff (_IO_FILE *, __off64_t, int, int);
extern __off64_t _IO_seekpos (_IO_FILE *, __off64_t, int);
extern void _IO_free_backup_area (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
# 75 "/usr/include/stdio.h" 2 3 4
# 108 "/usr/include/stdio.h" 3 4
typedef _G_fpos_t fpos_t;
# 164 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/bits/stdio_lim.h" 1 3 4
# 165 "/usr/include/stdio.h" 2 3 4
extern struct _IO_FILE *stdin;
extern struct _IO_FILE *stdout;
extern struct _IO_FILE *stderr;
extern int remove (const char *__filename) __attribute__ ((__nothrow__ , __leaf__));
extern int rename (const char *__old, const char *__new) __attribute__ ((__nothrow__ , __leaf__));
extern int renameat (int __oldfd, const char *__old, int __newfd,
extern FILE *tmpfile (void) ;
# 209 "/usr/include/stdio.h" 3 4
extern char *tmpnam (char *__s) __attribute__ ((__nothrow__ , __leaf__)) ;
extern char *tmpnam_r (char *__s) __attribute__ ((__nothrow__ , __leaf__)) ;
# 227 "/usr/include/stdio.h" 3 4
extern char *tempnam (const char *__dir, const char *__pfx)
extern int fclose (FILE *__stream);
extern int fflush (FILE *__stream);
# 252 "/usr/include/stdio.h" 3 4
extern int fflush_unlocked (FILE *__stream);
# 266 "/usr/include/stdio.h" 3 4
extern FILE *fopen (const char *__restrict __filename,
      const char *__restrict __modes) ;
extern FILE *freopen (const char *__restrict __filename,
        const char *__restrict __modes,
        FILE *__restrict __stream) ;
# 295 "/usr/include/stdio.h" 3 4
# 306 "/usr/include/stdio.h" 3 4
extern FILE *fdopen (int __fd, const char *__modes) __attribute__ ((__nothrow__ , __leaf__)) ;
# 319 "/usr/include/stdio.h" 3 4
extern FILE *fmemopen (void *__s, size_t __len, const char *__modes)
extern FILE *open_memstream (char **__bufloc, size_t *__sizeloc) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void setbuf (FILE *__restrict __stream, char *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__));
extern int setvbuf (FILE *__restrict __stream, char *__restrict __buf,
      int __modes, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern void setbuffer (FILE *__restrict __stream, char *__restrict __buf,
extern void setlinebuf (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int fprintf (FILE *__restrict __stream,
      const char *__restrict __format, ...);
extern int printf (const char *__restrict __format, ...);
extern int sprintf (char *__restrict __s,
      const char *__restrict __format, ...) __attribute__ ((__nothrow__));
extern int vfprintf (FILE *__restrict __s, const char *__restrict __format,
       __gnuc_va_list __arg);
extern int vprintf (const char *__restrict __format, __gnuc_va_list __arg);
extern int vsprintf (char *__restrict __s, const char *__restrict __format,
       __gnuc_va_list __arg) __attribute__ ((__nothrow__));
extern int snprintf (char *__restrict __s, size_t __maxlen,
     __attribute__ ((__nothrow__)) __attribute__ ((__format__ (__printf__, 3, 4)));
extern int vsnprintf (char *__restrict __s, size_t __maxlen,
     __attribute__ ((__nothrow__)) __attribute__ ((__format__ (__printf__, 3, 0)));
# 412 "/usr/include/stdio.h" 3 4
extern int vdprintf (int __fd, const char *__restrict __fmt,
     __attribute__ ((__format__ (__printf__, 2, 0)));
extern int dprintf (int __fd, const char *__restrict __fmt, ...)
     __attribute__ ((__format__ (__printf__, 2, 3)));
extern int fscanf (FILE *__restrict __stream,
     const char *__restrict __format, ...) ;
extern int scanf (const char *__restrict __format, ...) ;
extern int sscanf (const char *__restrict __s,
     const char *__restrict __format, ...) __attribute__ ((__nothrow__ , __leaf__));
# 443 "/usr/include/stdio.h" 3 4
extern int fscanf (FILE *__restrict __stream, const char *__restrict __format, ...) __asm__ ("" "__isoc99_fscanf")
extern int scanf (const char *__restrict __format, ...) __asm__ ("" "__isoc99_scanf")
extern int sscanf (const char *__restrict __s, const char *__restrict __format, ...) __asm__ ("" "__isoc99_sscanf") __attribute__ ((__nothrow__ , __leaf__))
# 463 "/usr/include/stdio.h" 3 4
extern int vfscanf (FILE *__restrict __s, const char *__restrict __format,
     __attribute__ ((__format__ (__scanf__, 2, 0))) ;
extern int vscanf (const char *__restrict __format, __gnuc_va_list __arg)
     __attribute__ ((__format__ (__scanf__, 1, 0))) ;
extern int vsscanf (const char *__restrict __s,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__format__ (__scanf__, 2, 0)));
# 494 "/usr/include/stdio.h" 3 4
extern int vfscanf (FILE *__restrict __s, const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vfscanf")
extern int vscanf (const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vscanf")
extern int vsscanf (const char *__restrict __s, const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vsscanf") __attribute__ ((__nothrow__ , __leaf__))
# 522 "/usr/include/stdio.h" 3 4
extern int fgetc (FILE *__stream);
extern int getc (FILE *__stream);
extern int getchar (void);
# 550 "/usr/include/stdio.h" 3 4
extern int getc_unlocked (FILE *__stream);
extern int getchar_unlocked (void);
# 561 "/usr/include/stdio.h" 3 4
extern int fgetc_unlocked (FILE *__stream);
extern int fputc (int __c, FILE *__stream);
extern int putc (int __c, FILE *__stream);
extern int putchar (int __c);
# 594 "/usr/include/stdio.h" 3 4
extern int fputc_unlocked (int __c, FILE *__stream);
extern int putc_unlocked (int __c, FILE *__stream);
extern int putchar_unlocked (int __c);
extern int getw (FILE *__stream);
extern int putw (int __w, FILE *__stream);
extern char *fgets (char *__restrict __s, int __n, FILE *__restrict __stream)
# 638 "/usr/include/stdio.h" 3 4
extern char *gets (char *__s) __attribute__ ((__deprecated__));
# 665 "/usr/include/stdio.h" 3 4
extern __ssize_t __getdelim (char **__restrict __lineptr,
          size_t *__restrict __n, int __delimiter,
extern __ssize_t getdelim (char **__restrict __lineptr,
extern __ssize_t getline (char **__restrict __lineptr,
extern int fputs (const char *__restrict __s, FILE *__restrict __stream);
extern int puts (const char *__s);
extern int ungetc (int __c, FILE *__stream);
extern size_t fread (void *__restrict __ptr, size_t __size,
       size_t __n, FILE *__restrict __stream) ;
extern size_t fwrite (const void *__restrict __ptr, size_t __size,
        size_t __n, FILE *__restrict __s);
# 737 "/usr/include/stdio.h" 3 4
extern size_t fread_unlocked (void *__restrict __ptr, size_t __size,
extern size_t fwrite_unlocked (const void *__restrict __ptr, size_t __size,
          size_t __n, FILE *__restrict __stream);
extern int fseek (FILE *__stream, long int __off, int __whence);
extern long int ftell (FILE *__stream) ;
extern void rewind (FILE *__stream);
# 773 "/usr/include/stdio.h" 3 4
extern int fseeko (FILE *__stream, __off_t __off, int __whence);
extern __off_t ftello (FILE *__stream) ;
# 792 "/usr/include/stdio.h" 3 4
extern int fgetpos (FILE *__restrict __stream, fpos_t *__restrict __pos);
extern int fsetpos (FILE *__stream, const fpos_t *__pos);
# 815 "/usr/include/stdio.h" 3 4
# 824 "/usr/include/stdio.h" 3 4
extern void clearerr (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int feof (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int ferror (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void clearerr_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int feof_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int ferror_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void perror (const char *__s);
# 1 "/usr/include/bits/sys_errlist.h" 1 3 4
# 26 "/usr/include/bits/sys_errlist.h" 3 4
extern int sys_nerr;
extern const char *const sys_errlist[];
# 854 "/usr/include/stdio.h" 2 3 4
extern int fileno (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int fileno_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
# 872 "/usr/include/stdio.h" 3 4
extern FILE *popen (const char *__command, const char *__modes) ;
extern int pclose (FILE *__stream);
extern char *ctermid (char *__s) __attribute__ ((__nothrow__ , __leaf__));
# 912 "/usr/include/stdio.h" 3 4
extern void flockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int ftrylockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void funlockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
# 942 "/usr/include/stdio.h" 3 4
# 126 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/openssl/stack.h" 1 3 4
# 66 "/usr/include/openssl/stack.h" 3 4
typedef struct stack_st
 int num;
 char **data;
 int sorted;
 int num_alloc;
 int (*comp)(const void *, const void *);
 } _STACK;
int sk_num(const _STACK *);
void *sk_value(const _STACK *, int);
void *sk_set(_STACK *, int, void *);
_STACK *sk_new(int (*cmp)(const void *, const void *));
_STACK *sk_new_null(void);
void sk_free(_STACK *);
void sk_pop_free(_STACK *st, void (*func)(void *));
int sk_insert(_STACK *sk, void *data, int where);
void *sk_delete(_STACK *st, int loc);
void *sk_delete_ptr(_STACK *st, void *p);
int sk_find(_STACK *st, void *data);
int sk_find_ex(_STACK *st, void *data);
int sk_push(_STACK *st, void *data);
int sk_unshift(_STACK *st, void *data);
void *sk_shift(_STACK *st);
void *sk_pop(_STACK *st);
void sk_zero(_STACK *st);
int (*sk_set_cmp_func(_STACK *sk, int (*c)(const void *, const void *)))
_STACK *sk_dup(_STACK *st);
void sk_sort(_STACK *st);
int sk_is_sorted(const _STACK *st);
# 129 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/openssl/safestack.h" 1 3 4
# 117 "/usr/include/openssl/safestack.h" 3 4
typedef char *OPENSSL_STRING;
typedef const char *OPENSSL_CSTRING;
# 129 "/usr/include/openssl/safestack.h" 3 4
struct stack_st_OPENSSL_STRING { _STACK stack; };
typedef void *OPENSSL_BLOCK;
struct stack_st_OPENSSL_BLOCK { _STACK stack; };
# 130 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/openssl/opensslv.h" 1 3 4
# 131 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/openssl/ossl_typ.h" 1 3 4
# 62 "/usr/include/openssl/ossl_typ.h" 3 4
# 63 "/usr/include/openssl/ossl_typ.h" 2 3 4
# 83 "/usr/include/openssl/ossl_typ.h" 3 4
typedef struct asn1_string_st ASN1_INTEGER;
typedef struct asn1_string_st ASN1_ENUMERATED;
typedef struct asn1_string_st ASN1_BIT_STRING;
typedef struct asn1_string_st ASN1_OCTET_STRING;
typedef struct asn1_string_st ASN1_PRINTABLESTRING;
typedef struct asn1_string_st ASN1_T61STRING;
typedef struct asn1_string_st ASN1_IA5STRING;
typedef struct asn1_string_st ASN1_GENERALSTRING;
typedef struct asn1_string_st ASN1_UNIVERSALSTRING;
typedef struct asn1_string_st ASN1_BMPSTRING;
typedef struct asn1_string_st ASN1_UTCTIME;
typedef struct asn1_string_st ASN1_TIME;
typedef struct asn1_string_st ASN1_GENERALIZEDTIME;
typedef struct asn1_string_st ASN1_VISIBLESTRING;
typedef struct asn1_string_st ASN1_UTF8STRING;
typedef struct asn1_string_st ASN1_STRING;
typedef int ASN1_BOOLEAN;
typedef int ASN1_NULL;
typedef struct ASN1_ITEM_st ASN1_ITEM;
typedef struct asn1_pctx_st ASN1_PCTX;
# 118 "/usr/include/openssl/ossl_typ.h" 3 4
typedef struct bignum_st BIGNUM;
typedef struct bignum_ctx BN_CTX;
typedef struct bn_blinding_st BN_BLINDING;
typedef struct bn_mont_ctx_st BN_MONT_CTX;
typedef struct bn_recp_ctx_st BN_RECP_CTX;
typedef struct bn_gencb_st BN_GENCB;
typedef struct buf_mem_st BUF_MEM;
typedef struct evp_cipher_st EVP_CIPHER;
typedef struct evp_cipher_ctx_st EVP_CIPHER_CTX;
typedef struct env_md_st EVP_MD;
typedef struct env_md_ctx_st EVP_MD_CTX;
typedef struct evp_pkey_st EVP_PKEY;
typedef struct evp_pkey_asn1_method_st EVP_PKEY_ASN1_METHOD;
typedef struct evp_pkey_method_st EVP_PKEY_METHOD;
typedef struct evp_pkey_ctx_st EVP_PKEY_CTX;
typedef struct dh_st DH;
typedef struct dh_method DH_METHOD;
typedef struct dsa_st DSA;
typedef struct dsa_method DSA_METHOD;
typedef struct rsa_st RSA;
typedef struct rsa_meth_st RSA_METHOD;
typedef struct rand_meth_st RAND_METHOD;
typedef struct ecdh_method ECDH_METHOD;
typedef struct ecdsa_method ECDSA_METHOD;
typedef struct x509_st X509;
typedef struct X509_algor_st X509_ALGOR;
typedef struct X509_crl_st X509_CRL;
typedef struct x509_crl_method_st X509_CRL_METHOD;
typedef struct x509_revoked_st X509_REVOKED;
typedef struct X509_name_st X509_NAME;
typedef struct X509_pubkey_st X509_PUBKEY;
typedef struct x509_store_st X509_STORE;
typedef struct x509_store_ctx_st X509_STORE_CTX;
typedef struct pkcs8_priv_key_info_st PKCS8_PRIV_KEY_INFO;
typedef struct v3_ext_ctx X509V3_CTX;
typedef struct conf_st CONF;
typedef struct store_st STORE;
typedef struct store_method_st STORE_METHOD;
typedef struct ui_st UI;
typedef struct ui_method_st UI_METHOD;
typedef struct st_ERR_FNS ERR_FNS;
typedef struct engine_st ENGINE;
typedef struct ssl_st SSL;
typedef struct ssl_ctx_st SSL_CTX;
typedef struct X509_POLICY_NODE_st X509_POLICY_NODE;
typedef struct X509_POLICY_LEVEL_st X509_POLICY_LEVEL;
typedef struct X509_POLICY_TREE_st X509_POLICY_TREE;
typedef struct X509_POLICY_CACHE_st X509_POLICY_CACHE;
typedef struct AUTHORITY_KEYID_st AUTHORITY_KEYID;
typedef struct DIST_POINT_st DIST_POINT;
typedef struct ISSUING_DIST_POINT_st ISSUING_DIST_POINT;
typedef struct NAME_CONSTRAINTS_st NAME_CONSTRAINTS;
typedef struct crypto_ex_data_st CRYPTO_EX_DATA;
typedef int CRYPTO_EX_new(void *parent, void *ptr, CRYPTO_EX_DATA *ad,
     int idx, long argl, void *argp);
typedef void CRYPTO_EX_free(void *parent, void *ptr, CRYPTO_EX_DATA *ad,
typedef int CRYPTO_EX_dup(CRYPTO_EX_DATA *to, CRYPTO_EX_DATA *from, void *from_d,
typedef struct ocsp_req_ctx_st OCSP_REQ_CTX;
typedef struct ocsp_response_st OCSP_RESPONSE;
typedef struct ocsp_responder_id_st OCSP_RESPID;
# 132 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/openssl/symhacks.h" 1 3 4
# 58 "/usr/include/openssl/symhacks.h" 3 4
# 59 "/usr/include/openssl/symhacks.h" 2 3 4
# 140 "/usr/include/openssl/crypto.h" 2 3 4
# 171 "/usr/include/openssl/crypto.h" 3 4
typedef struct openssl_item_st
 int code;
 void *value;
 size_t value_size;
 size_t *value_length;
 } OPENSSL_ITEM;
# 256 "/usr/include/openssl/crypto.h" 3 4
typedef struct
 int references;
 struct CRYPTO_dynlock_value *data;
 } CRYPTO_dynlock;
# 283 "/usr/include/openssl/crypto.h" 3 4
typedef struct bio_st BIO_dummy;
 struct stack_st_void *sk;
 int dummy;
struct stack_st_void { _STACK stack; };
typedef struct crypto_ex_data_func_st
 long argl;
 void *argp;
 CRYPTO_EX_new *new_func;
 CRYPTO_EX_free *free_func;
 CRYPTO_EX_dup *dup_func;
 } CRYPTO_EX_DATA_FUNCS;
struct stack_st_CRYPTO_EX_DATA_FUNCS { _STACK stack; };
# 356 "/usr/include/openssl/crypto.h" 3 4
int CRYPTO_mem_ctrl(int mode);
int CRYPTO_is_mem_check_on(void);
# 384 "/usr/include/openssl/crypto.h" 3 4
const char *SSLeay_version(int type);
unsigned long SSLeay(void);
int OPENSSL_issetugid(void);
typedef struct st_CRYPTO_EX_DATA_IMPL CRYPTO_EX_DATA_IMPL;
const CRYPTO_EX_DATA_IMPL *CRYPTO_get_ex_data_implementation(void);
int CRYPTO_set_ex_data_implementation(const CRYPTO_EX_DATA_IMPL *i);
int CRYPTO_ex_data_new_class(void);
int CRYPTO_get_ex_new_index(int class_index, long argl, void *argp,
  CRYPTO_EX_new *new_func, CRYPTO_EX_dup *dup_func,
  CRYPTO_EX_free *free_func);
int CRYPTO_new_ex_data(int class_index, void *obj, CRYPTO_EX_DATA *ad);
int CRYPTO_dup_ex_data(int class_index, CRYPTO_EX_DATA *to,
  CRYPTO_EX_DATA *from);
void CRYPTO_free_ex_data(int class_index, void *obj, CRYPTO_EX_DATA *ad);
int CRYPTO_set_ex_data(CRYPTO_EX_DATA *ad, int idx, void *val);
void *CRYPTO_get_ex_data(const CRYPTO_EX_DATA *ad,int idx);
void CRYPTO_cleanup_all_ex_data(void);
int CRYPTO_get_new_lockid(char *name);
int CRYPTO_num_locks(void);
void CRYPTO_lock(int mode, int type,const char *file,int line);
void CRYPTO_set_locking_callback(void (*func)(int mode,int type,
           const char *file,int line));
void (*CRYPTO_get_locking_callback(void))(int mode,int type,const char *file,
  int line);
void CRYPTO_set_add_lock_callback(int (*func)(int *num,int mount,int type,
           const char *file, int line));
int (*CRYPTO_get_add_lock_callback(void))(int *num,int mount,int type,
typedef struct crypto_threadid_st
 void *ptr;
 unsigned long val;
 } CRYPTO_THREADID;
void CRYPTO_THREADID_set_numeric(CRYPTO_THREADID *id, unsigned long val);
void CRYPTO_THREADID_set_pointer(CRYPTO_THREADID *id, void *ptr);
int CRYPTO_THREADID_set_callback(void (*threadid_func)(CRYPTO_THREADID *));
void (*CRYPTO_THREADID_get_callback(void))(CRYPTO_THREADID *);
void CRYPTO_THREADID_current(CRYPTO_THREADID *id);
int CRYPTO_THREADID_cmp(const CRYPTO_THREADID *a, const CRYPTO_THREADID *b);
void CRYPTO_THREADID_cpy(CRYPTO_THREADID *dest, const CRYPTO_THREADID *src);
unsigned long CRYPTO_THREADID_hash(const CRYPTO_THREADID *id);
void CRYPTO_set_id_callback(unsigned long (*func)(void));
unsigned long (*CRYPTO_get_id_callback(void))(void);
unsigned long CRYPTO_thread_id(void);
const char *CRYPTO_get_lock_name(int type);
int CRYPTO_add_lock(int *pointer,int amount,int type, const char *file,
      int line);
int CRYPTO_get_new_dynlockid(void);
void CRYPTO_destroy_dynlockid(int i);
struct CRYPTO_dynlock_value *CRYPTO_get_dynlock_value(int i);
void CRYPTO_set_dynlock_create_callback(struct CRYPTO_dynlock_value *(*dyn_create_function)(const char *file, int line));
void CRYPTO_set_dynlock_lock_callback(void (*dyn_lock_function)(int mode, struct CRYPTO_dynlock_value *l, const char *file, int line));
void CRYPTO_set_dynlock_destroy_callback(void (*dyn_destroy_function)(struct CRYPTO_dynlock_value *l, const char *file, int line));
struct CRYPTO_dynlock_value *(*CRYPTO_get_dynlock_create_callback(void))(const char *file,int line);
void (*CRYPTO_get_dynlock_lock_callback(void))(int mode, struct CRYPTO_dynlock_value *l, const char *file,int line);
void (*CRYPTO_get_dynlock_destroy_callback(void))(struct CRYPTO_dynlock_value *l, const char *file,int line);
int CRYPTO_set_mem_functions(void *(*m)(size_t),void *(*r)(void *,size_t), void (*f)(void *));
int CRYPTO_set_locked_mem_functions(void *(*m)(size_t), void (*free_func)(void *));
int CRYPTO_set_mem_ex_functions(void *(*m)(size_t,const char *,int),
                                void *(*r)(void *,size_t,const char *,int),
                                void (*f)(void *));
int CRYPTO_set_locked_mem_ex_functions(void *(*m)(size_t,const char *,int),
int CRYPTO_set_mem_debug_functions(void (*m)(void *,int,const char *,int,int),
       void (*r)(void *,void *,int,const char *,int,int),
       void (*f)(void *,int),
       void (*so)(long),
       long (*go)(void));
void CRYPTO_get_mem_functions(void *(**m)(size_t),void *(**r)(void *, size_t), void (**f)(void *));
void CRYPTO_get_locked_mem_functions(void *(**m)(size_t), void (**f)(void *));
void CRYPTO_get_mem_ex_functions(void *(**m)(size_t,const char *,int),
                                 void *(**r)(void *, size_t,const char *,int),
void CRYPTO_get_locked_mem_ex_functions(void *(**m)(size_t,const char *,int),
void CRYPTO_get_mem_debug_functions(void (**m)(void *,int,const char *,int,int),
        void (**r)(void *,void *,int,const char *,int,int),
        void (**f)(void *,int),
        void (**so)(long),
        long (**go)(void));
void *CRYPTO_malloc_locked(int num, const char *file, int line);
void CRYPTO_free_locked(void *ptr);
void *CRYPTO_malloc(int num, const char *file, int line);
char *CRYPTO_strdup(const char *str, const char *file, int line);
void CRYPTO_free(void *ptr);
void *CRYPTO_realloc(void *addr,int num, const char *file, int line);
void *CRYPTO_realloc_clean(void *addr,int old_num,int num,const char *file,
      int line);
void *CRYPTO_remalloc(void *addr,int num, const char *file, int line);
void OPENSSL_cleanse(void *ptr, size_t len);
void CRYPTO_set_mem_debug_options(long bits);
long CRYPTO_get_mem_debug_options(void);
int CRYPTO_push_info_(const char *info, const char *file, int line);
int CRYPTO_pop_info(void);
int CRYPTO_remove_all_info(void);
# 519 "/usr/include/openssl/crypto.h" 3 4
void CRYPTO_dbg_malloc(void *addr,int num,const char *file,int line,int before_p);
void CRYPTO_dbg_realloc(void *addr1,void *addr2,int num,const char *file,int line,int before_p);
void CRYPTO_dbg_free(void *addr,int before_p);
# 530 "/usr/include/openssl/crypto.h" 3 4
void CRYPTO_dbg_set_options(long bits);
long CRYPTO_dbg_get_options(void);
void CRYPTO_mem_leaks_fp(FILE *);
void CRYPTO_mem_leaks(struct bio_st *bio);
typedef void *CRYPTO_MEM_LEAK_CB(unsigned long, const char *, int, int, void *);
void CRYPTO_mem_leaks_cb(CRYPTO_MEM_LEAK_CB *cb);
void OpenSSLDie(const char *file,int line,const char *assertion);
unsigned long *OPENSSL_ia32cap_loc(void);
int OPENSSL_isservice(void);
int FIPS_mode(void);
int FIPS_mode_set(int r);
void OPENSSL_init(void);
# 582 "/usr/include/openssl/crypto.h" 3 4
int CRYPTO_memcmp(const void *a, const void *b, size_t len);
void ERR_load_CRYPTO_strings(void);
# 6 "/usr/include/openssl/comp.h" 2 3 4
typedef struct comp_ctx_st COMP_CTX;
typedef struct comp_method_st
 int type;
 const char *name;
 int (*init)(COMP_CTX *ctx);
 void (*finish)(COMP_CTX *ctx);
 int (*compress)(COMP_CTX *ctx,
   unsigned char *out, unsigned int olen,
   unsigned char *in, unsigned int ilen);
 int (*expand)(COMP_CTX *ctx,
 long (*ctrl)(void);
 long (*callback_ctrl)(void);
 } COMP_METHOD;
struct comp_ctx_st
 COMP_METHOD *meth;
 unsigned long compress_in;
 unsigned long compress_out;
 unsigned long expand_in;
 unsigned long expand_out;
 CRYPTO_EX_DATA ex_data;
COMP_CTX *COMP_CTX_new(COMP_METHOD *meth);
void COMP_CTX_free(COMP_CTX *ctx);
int COMP_compress_block(COMP_CTX *ctx, unsigned char *out, int olen,
 unsigned char *in, int ilen);
int COMP_expand_block(COMP_CTX *ctx, unsigned char *out, int olen,
COMP_METHOD *COMP_rle(void );
COMP_METHOD *COMP_zlib(void );
void COMP_zlib_cleanup(void);
# 62 "/usr/include/openssl/comp.h" 3 4
void ERR_load_COMP_strings(void);
# 150 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/bio.h" 1 3 4
# 62 "/usr/include/openssl/bio.h" 3 4
# 63 "/usr/include/openssl/bio.h" 2 3 4
# 68 "/usr/include/openssl/bio.h" 2 3 4
# 231 "/usr/include/openssl/bio.h" 3 4
typedef struct bio_st BIO;
void BIO_set_flags(BIO *b, int flags);
int BIO_test_flags(const BIO *b, int flags);
void BIO_clear_flags(BIO *b, int flags);
# 285 "/usr/include/openssl/bio.h" 3 4
long (*BIO_get_callback(const BIO *b)) (struct bio_st *,int,const char *,int, long,long);
void BIO_set_callback(BIO *b,
 long (*callback)(struct bio_st *,int,const char *,int, long,long));
char *BIO_get_callback_arg(const BIO *b);
void BIO_set_callback_arg(BIO *b, char *arg);
const char * BIO_method_name(const BIO *b);
int BIO_method_type(const BIO *b);
typedef void bio_info_cb(struct bio_st *, int, const char *, int, long, long);
typedef struct bio_method_st
 int type;
 const char *name;
 int (*bwrite)(BIO *, const char *, int);
 int (*bread)(BIO *, char *, int);
 int (*bputs)(BIO *, const char *);
 int (*bgets)(BIO *, char *, int);
 long (*ctrl)(BIO *, int, long, void *);
 int (*create)(BIO *);
 int (*destroy)(BIO *);
        long (*callback_ctrl)(BIO *, int, bio_info_cb *);
 } BIO_METHOD;
struct bio_st
 BIO_METHOD *method;
 long (*callback)(struct bio_st *,int,const char *,int, long,long);
 char *cb_arg;
 int init;
 int shutdown;
 int flags;
 int retry_reason;
 int num;
 void *ptr;
 struct bio_st *next_bio;
 struct bio_st *prev_bio;
 int references;
 unsigned long num_read;
 unsigned long num_write;
struct stack_st_BIO { _STACK stack; };
typedef struct bio_f_buffer_ctx_struct
# 346 "/usr/include/openssl/bio.h" 3 4
 int ibuf_size;
 int obuf_size;
 char *ibuf;
 int ibuf_len;
 int ibuf_off;
 char *obuf;
 int obuf_len;
 int obuf_off;
 } BIO_F_BUFFER_CTX;
typedef int asn1_ps_func(BIO *b, unsigned char **pbuf, int *plen, void *parg);
# 574 "/usr/include/openssl/bio.h" 3 4
size_t BIO_ctrl_pending(BIO *b);
size_t BIO_ctrl_wpending(BIO *b);
# 593 "/usr/include/openssl/bio.h" 3 4
size_t BIO_ctrl_get_write_guarantee(BIO *b);
size_t BIO_ctrl_get_read_request(BIO *b);
int BIO_ctrl_reset_read_request(BIO *b);
# 614 "/usr/include/openssl/bio.h" 3 4
int BIO_set_ex_data(BIO *bio,int idx,void *data);
void *BIO_get_ex_data(BIO *bio,int idx);
int BIO_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
 CRYPTO_EX_dup *dup_func, CRYPTO_EX_free *free_func);
unsigned long BIO_number_read(BIO *bio);
unsigned long BIO_number_written(BIO *bio);
int BIO_asn1_set_prefix(BIO *b, asn1_ps_func *prefix,
     asn1_ps_func *prefix_free);
int BIO_asn1_get_prefix(BIO *b, asn1_ps_func **pprefix,
     asn1_ps_func **pprefix_free);
int BIO_asn1_set_suffix(BIO *b, asn1_ps_func *suffix,
     asn1_ps_func *suffix_free);
int BIO_asn1_get_suffix(BIO *b, asn1_ps_func **psuffix,
     asn1_ps_func **psuffix_free);
BIO_METHOD *BIO_s_file(void );
BIO *BIO_new_file(const char *filename, const char *mode);
BIO *BIO_new_fp(FILE *stream, int close_flag);
BIO * BIO_new(BIO_METHOD *type);
int BIO_set(BIO *a,BIO_METHOD *type);
int BIO_free(BIO *a);
void BIO_vfree(BIO *a);
int BIO_read(BIO *b, void *data, int len);
int BIO_gets(BIO *bp,char *buf, int size);
int BIO_write(BIO *b, const void *data, int len);
int BIO_puts(BIO *bp,const char *buf);
int BIO_indent(BIO *b,int indent,int max);
long BIO_ctrl(BIO *bp,int cmd,long larg,void *parg);
long BIO_callback_ctrl(BIO *b, int cmd, void (*fp)(struct bio_st *, int, const char *, int, long, long));
char * BIO_ptr_ctrl(BIO *bp,int cmd,long larg);
long BIO_int_ctrl(BIO *bp,int cmd,long larg,int iarg);
BIO * BIO_push(BIO *b,BIO *append);
BIO * BIO_pop(BIO *b);
void BIO_free_all(BIO *a);
BIO * BIO_find_type(BIO *b,int bio_type);
BIO * BIO_next(BIO *b);
BIO * BIO_get_retry_BIO(BIO *bio, int *reason);
int BIO_get_retry_reason(BIO *bio);
BIO * BIO_dup_chain(BIO *in);
int BIO_nread0(BIO *bio, char **buf);
int BIO_nread(BIO *bio, char **buf, int num);
int BIO_nwrite0(BIO *bio, char **buf);
int BIO_nwrite(BIO *bio, char **buf, int num);
long BIO_debug_callback(BIO *bio,int cmd,const char *argp,int argi,
 long argl,long ret);
BIO_METHOD *BIO_s_mem(void);
BIO *BIO_new_mem_buf(void *buf, int len);
BIO_METHOD *BIO_s_socket(void);
BIO_METHOD *BIO_s_connect(void);
BIO_METHOD *BIO_s_accept(void);
BIO_METHOD *BIO_s_fd(void);
BIO_METHOD *BIO_s_log(void);
BIO_METHOD *BIO_s_bio(void);
BIO_METHOD *BIO_s_null(void);
BIO_METHOD *BIO_f_null(void);
BIO_METHOD *BIO_f_buffer(void);
BIO_METHOD *BIO_f_nbio_test(void);
BIO_METHOD *BIO_s_datagram(void);
int BIO_sock_should_retry(int i);
int BIO_sock_non_fatal_error(int error);
int BIO_dgram_non_fatal_error(int error);
int BIO_fd_should_retry(int i);
int BIO_fd_non_fatal_error(int error);
int BIO_dump_cb(int (*cb)(const void *data, size_t len, void *u),
  void *u, const char *s, int len);
int BIO_dump_indent_cb(int (*cb)(const void *data, size_t len, void *u),
         void *u, const char *s, int len, int indent);
int BIO_dump(BIO *b,const char *bytes,int len);
int BIO_dump_indent(BIO *b,const char *bytes,int len,int indent);
int BIO_dump_fp(FILE *fp, const char *s, int len);
int BIO_dump_indent_fp(FILE *fp, const char *s, int len, int indent);
struct hostent *BIO_gethostbyname(const char *name);
# 718 "/usr/include/openssl/bio.h" 3 4
int BIO_sock_error(int sock);
int BIO_socket_ioctl(int fd, long type, void *arg);
int BIO_socket_nbio(int fd,int mode);
int BIO_get_port(const char *str, unsigned short *port_ptr);
int BIO_get_host_ip(const char *str, unsigned char *ip);
int BIO_get_accept_socket(char *host_port,int mode);
int BIO_accept(int sock,char **ip_port);
int BIO_sock_init(void );
void BIO_sock_cleanup(void);
int BIO_set_tcp_ndelay(int sock,int turn_on);
BIO *BIO_new_socket(int sock, int close_flag);
BIO *BIO_new_dgram(int fd, int close_flag);
# 740 "/usr/include/openssl/bio.h" 3 4
BIO *BIO_new_fd(int fd, int close_flag);
BIO *BIO_new_connect(char *host_port);
BIO *BIO_new_accept(char *host_port);
int BIO_new_bio_pair(BIO **bio1, size_t writebuf1,
 BIO **bio2, size_t writebuf2);
void BIO_copy_next_retry(BIO *b);
# 760 "/usr/include/openssl/bio.h" 3 4
int BIO_printf(BIO *bio, const char *format, ...)
 __attribute__((__format__(__printf__,2,3)));
int BIO_vprintf(BIO *bio, const char *format, va_list args)
 __attribute__((__format__(__printf__,2,0)));
int BIO_snprintf(char *buf, size_t n, const char *format, ...)
 __attribute__((__format__(__printf__,3,4)));
int BIO_vsnprintf(char *buf, size_t n, const char *format, va_list args)
 __attribute__((__format__(__printf__,3,0)));
void ERR_load_BIO_strings(void);
# 153 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/x509.h" 1 3 4
# 67 "/usr/include/openssl/x509.h" 3 4
# 68 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/buffer.h" 1 3 4
# 68 "/usr/include/openssl/buffer.h" 3 4
# 147 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef long int ptrdiff_t;
# 69 "/usr/include/openssl/buffer.h" 2 3 4
# 77 "/usr/include/openssl/buffer.h" 3 4
struct buf_mem_st
 size_t length;
 char *data;
 size_t max;
BUF_MEM *BUF_MEM_new(void);
void BUF_MEM_free(BUF_MEM *a);
int BUF_MEM_grow(BUF_MEM *str, size_t len);
int BUF_MEM_grow_clean(BUF_MEM *str, size_t len);
char * BUF_strdup(const char *str);
char * BUF_strndup(const char *str, size_t siz);
void * BUF_memdup(const void *data, size_t siz);
void BUF_reverse(unsigned char *out, const unsigned char *in, size_t siz);
size_t BUF_strlcpy(char *dst,const char *src,size_t siz);
size_t BUF_strlcat(char *dst,const char *src,size_t siz);
void ERR_load_BUF_strings(void);
# 71 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/evp.h" 1 3 4
# 66 "/usr/include/openssl/evp.h" 3 4
# 67 "/usr/include/openssl/evp.h" 2 3 4
# 94 "/usr/include/openssl/evp.h" 3 4
# 1 "/usr/include/openssl/objects.h" 1 3 4
# 65 "/usr/include/openssl/objects.h" 3 4
# 1 "/usr/include/openssl/obj_mac.h" 1 3 4
# 66 "/usr/include/openssl/objects.h" 2 3 4
# 960 "/usr/include/openssl/objects.h" 3 4
# 1 "/usr/include/openssl/asn1.h" 1 3 4
# 62 "/usr/include/openssl/asn1.h" 3 4
# 29 "/usr/include/time.h" 3 4
# 38 "/usr/include/time.h" 2 3 4
# 42 "/usr/include/time.h" 2 3 4
# 131 "/usr/include/time.h" 3 4
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
  long int tm_gmtoff;
  const char *tm_zone;
struct itimerspec
    struct timespec it_interval;
    struct timespec it_value;
struct sigevent;
# 186 "/usr/include/time.h" 3 4
extern clock_t clock (void) __attribute__ ((__nothrow__ , __leaf__));
extern time_t time (time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern double difftime (time_t __time1, time_t __time0)
extern time_t mktime (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern size_t strftime (char *__restrict __s, size_t __maxsize,
   const struct tm *__restrict __tp) __attribute__ ((__nothrow__ , __leaf__));
# 221 "/usr/include/time.h" 3 4
# 1 "/usr/include/xlocale.h" 1 3 4
# 27 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 222 "/usr/include/time.h" 2 3 4
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
     const struct tm *__restrict __tp,
     __locale_t __loc) __attribute__ ((__nothrow__ , __leaf__));
# 236 "/usr/include/time.h" 3 4
extern struct tm *gmtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *localtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *gmtime_r (const time_t *__restrict __timer,
extern struct tm *localtime_r (const time_t *__restrict __timer,
extern char *asctime (const struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern char *asctime_r (const struct tm *__restrict __tp,
extern char *ctime_r (const time_t *__restrict __timer,
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daylight;
extern long int timezone;
extern int stime (const time_t *__when) __attribute__ ((__nothrow__ , __leaf__));
# 319 "/usr/include/time.h" 3 4
extern time_t timegm (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern time_t timelocal (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int dysize (int __year) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 334 "/usr/include/time.h" 3 4
extern int nanosleep (const struct timespec *__requested_time,
        struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
       const struct timespec *__req,
       struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_create (clockid_t __clock_id,
    struct sigevent *__restrict __evp,
    timer_t *__restrict __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_delete (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_settime (timer_t __timerid, int __flags,
     const struct itimerspec *__restrict __value,
     struct itimerspec *__restrict __ovalue) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
extern int timer_getoverrun (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
# 430 "/usr/include/time.h" 3 4
# 63 "/usr/include/openssl/asn1.h" 2 3 4
# 64 "/usr/include/openssl/asn1.h" 2 3 4
# 74 "/usr/include/openssl/asn1.h" 3 4
# 1 "/usr/include/openssl/bn.h" 1 3 4
# 128 "/usr/include/openssl/bn.h" 3 4
# 129 "/usr/include/openssl/bn.h" 2 3 4
# 318 "/usr/include/openssl/bn.h" 3 4
struct bignum_st
 unsigned long *d;
 int top;
 int dmax;
 int neg;
 int flags;
 int ri;
 BIGNUM RR;
 BIGNUM N;
 BIGNUM Ni;
 unsigned long n0[2];
 int flags;
 BIGNUM N;
 BIGNUM Nr;
 int num_bits;
 int shift;
 int flags;
struct bn_gencb_st
 unsigned int ver;
 void *arg;
 union
  void (*cb_1)(int, int, void *);
  int (*cb_2)(int, int, BN_GENCB *);
  } cb;
int BN_GENCB_call(BN_GENCB *cb, int a, int b);
# 425 "/usr/include/openssl/bn.h" 3 4
const BIGNUM *BN_value_one(void);
char * BN_options(void);
BN_CTX *BN_CTX_new(void);
void BN_CTX_init(BN_CTX *c);
void BN_CTX_free(BN_CTX *c);
void BN_CTX_start(BN_CTX *ctx);
BIGNUM *BN_CTX_get(BN_CTX *ctx);
void BN_CTX_end(BN_CTX *ctx);
int BN_rand(BIGNUM *rnd, int bits, int top,int bottom);
int BN_pseudo_rand(BIGNUM *rnd, int bits, int top,int bottom);
int BN_rand_range(BIGNUM *rnd, const BIGNUM *range);
int BN_pseudo_rand_range(BIGNUM *rnd, const BIGNUM *range);
int BN_num_bits(const BIGNUM *a);
int BN_num_bits_word(unsigned long);
BIGNUM *BN_new(void);
void BN_init(BIGNUM *);
void BN_clear_free(BIGNUM *a);
BIGNUM *BN_copy(BIGNUM *a, const BIGNUM *b);
void BN_swap(BIGNUM *a, BIGNUM *b);
BIGNUM *BN_bin2bn(const unsigned char *s,int len,BIGNUM *ret);
int BN_bn2bin(const BIGNUM *a, unsigned char *to);
BIGNUM *BN_mpi2bn(const unsigned char *s,int len,BIGNUM *ret);
int BN_bn2mpi(const BIGNUM *a, unsigned char *to);
int BN_sub(BIGNUM *r, const BIGNUM *a, const BIGNUM *b);
int BN_usub(BIGNUM *r, const BIGNUM *a, const BIGNUM *b);
int BN_uadd(BIGNUM *r, const BIGNUM *a, const BIGNUM *b);
int BN_add(BIGNUM *r, const BIGNUM *a, const BIGNUM *b);
int BN_mul(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, BN_CTX *ctx);
int BN_sqr(BIGNUM *r, const BIGNUM *a,BN_CTX *ctx);
void BN_set_negative(BIGNUM *b, int n);
int BN_div(BIGNUM *dv, BIGNUM *rem, const BIGNUM *m, const BIGNUM *d,
 BN_CTX *ctx);
int BN_nnmod(BIGNUM *r, const BIGNUM *m, const BIGNUM *d, BN_CTX *ctx);
int BN_mod_add(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m, BN_CTX *ctx);
int BN_mod_add_quick(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m);
int BN_mod_sub(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m, BN_CTX *ctx);
int BN_mod_sub_quick(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m);
int BN_mod_mul(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_mod_sqr(BIGNUM *r, const BIGNUM *a, const BIGNUM *m, BN_CTX *ctx);
int BN_mod_lshift1(BIGNUM *r, const BIGNUM *a, const BIGNUM *m, BN_CTX *ctx);
int BN_mod_lshift1_quick(BIGNUM *r, const BIGNUM *a, const BIGNUM *m);
int BN_mod_lshift(BIGNUM *r, const BIGNUM *a, int n, const BIGNUM *m, BN_CTX *ctx);
int BN_mod_lshift_quick(BIGNUM *r, const BIGNUM *a, int n, const BIGNUM *m);
unsigned long BN_mod_word(const BIGNUM *a, unsigned long w);
unsigned long BN_div_word(BIGNUM *a, unsigned long w);
int BN_mul_word(BIGNUM *a, unsigned long w);
int BN_add_word(BIGNUM *a, unsigned long w);
int BN_sub_word(BIGNUM *a, unsigned long w);
int BN_set_word(BIGNUM *a, unsigned long w);
unsigned long BN_get_word(const BIGNUM *a);
int BN_cmp(const BIGNUM *a, const BIGNUM *b);
void BN_free(BIGNUM *a);
int BN_is_bit_set(const BIGNUM *a, int n);
int BN_lshift(BIGNUM *r, const BIGNUM *a, int n);
int BN_lshift1(BIGNUM *r, const BIGNUM *a);
int BN_exp(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,BN_CTX *ctx);
int BN_mod_exp(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
 const BIGNUM *m,BN_CTX *ctx);
int BN_mod_exp_mont(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
 const BIGNUM *m, BN_CTX *ctx, BN_MONT_CTX *m_ctx);
int BN_mod_exp_mont_consttime(BIGNUM *rr, const BIGNUM *a, const BIGNUM *p,
 const BIGNUM *m, BN_CTX *ctx, BN_MONT_CTX *in_mont);
int BN_mod_exp_mont_word(BIGNUM *r, unsigned long a, const BIGNUM *p,
int BN_mod_exp2_mont(BIGNUM *r, const BIGNUM *a1, const BIGNUM *p1,
 const BIGNUM *a2, const BIGNUM *p2,const BIGNUM *m,
 BN_CTX *ctx,BN_MONT_CTX *m_ctx);
int BN_mod_exp_simple(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
int BN_mask_bits(BIGNUM *a,int n);
int BN_print_fp(FILE *fp, const BIGNUM *a);
int BN_print(BIO *fp, const BIGNUM *a);
int BN_reciprocal(BIGNUM *r, const BIGNUM *m, int len, BN_CTX *ctx);
int BN_rshift(BIGNUM *r, const BIGNUM *a, int n);
int BN_rshift1(BIGNUM *r, const BIGNUM *a);
void BN_clear(BIGNUM *a);
BIGNUM *BN_dup(const BIGNUM *a);
int BN_ucmp(const BIGNUM *a, const BIGNUM *b);
int BN_set_bit(BIGNUM *a, int n);
int BN_clear_bit(BIGNUM *a, int n);
char * BN_bn2hex(const BIGNUM *a);
char * BN_bn2dec(const BIGNUM *a);
int BN_hex2bn(BIGNUM **a, const char *str);
int BN_dec2bn(BIGNUM **a, const char *str);
int BN_asc2bn(BIGNUM **a, const char *str);
int BN_gcd(BIGNUM *r,const BIGNUM *a,const BIGNUM *b,BN_CTX *ctx);
int BN_kronecker(const BIGNUM *a,const BIGNUM *b,BN_CTX *ctx);
BIGNUM *BN_mod_inverse(BIGNUM *ret,
 const BIGNUM *a, const BIGNUM *n,BN_CTX *ctx);
BIGNUM *BN_mod_sqrt(BIGNUM *ret,
void BN_consttime_swap(unsigned long swap, BIGNUM *a, BIGNUM *b, int nwords);
BIGNUM *BN_generate_prime(BIGNUM *ret,int bits,int safe,
 const BIGNUM *add, const BIGNUM *rem,
 void (*callback)(int,int,void *),void *cb_arg);
int BN_is_prime(const BIGNUM *p,int nchecks,
 BN_CTX *ctx,void *cb_arg);
int BN_is_prime_fasttest(const BIGNUM *p,int nchecks,
 void (*callback)(int,int,void *),BN_CTX *ctx,void *cb_arg,
 int do_trial_division);
int BN_generate_prime_ex(BIGNUM *ret,int bits,int safe, const BIGNUM *add,
  const BIGNUM *rem, BN_GENCB *cb);
int BN_is_prime_ex(const BIGNUM *p,int nchecks, BN_CTX *ctx, BN_GENCB *cb);
int BN_is_prime_fasttest_ex(const BIGNUM *p,int nchecks, BN_CTX *ctx,
  int do_trial_division, BN_GENCB *cb);
int BN_X931_generate_Xpq(BIGNUM *Xp, BIGNUM *Xq, int nbits, BN_CTX *ctx);
int BN_X931_derive_prime_ex(BIGNUM *p, BIGNUM *p1, BIGNUM *p2,
   const BIGNUM *Xp, const BIGNUM *Xp1, const BIGNUM *Xp2,
   const BIGNUM *e, BN_CTX *ctx, BN_GENCB *cb);
int BN_X931_generate_prime_ex(BIGNUM *p, BIGNUM *p1, BIGNUM *p2,
   BIGNUM *Xp1, BIGNUM *Xp2,
   const BIGNUM *Xp,
   BN_GENCB *cb);
BN_MONT_CTX *BN_MONT_CTX_new(void );
void BN_MONT_CTX_init(BN_MONT_CTX *ctx);
int BN_mod_mul_montgomery(BIGNUM *r,const BIGNUM *a,const BIGNUM *b,
 BN_MONT_CTX *mont, BN_CTX *ctx);
int BN_from_montgomery(BIGNUM *r,const BIGNUM *a,
void BN_MONT_CTX_free(BN_MONT_CTX *mont);
int BN_MONT_CTX_set(BN_MONT_CTX *mont,const BIGNUM *mod,BN_CTX *ctx);
BN_MONT_CTX *BN_MONT_CTX_copy(BN_MONT_CTX *to,BN_MONT_CTX *from);
BN_MONT_CTX *BN_MONT_CTX_set_locked(BN_MONT_CTX **pmont, int lock,
     const BIGNUM *mod, BN_CTX *ctx);
BN_BLINDING *BN_BLINDING_new(const BIGNUM *A, const BIGNUM *Ai, BIGNUM *mod);
void BN_BLINDING_free(BN_BLINDING *b);
int BN_BLINDING_update(BN_BLINDING *b,BN_CTX *ctx);
int BN_BLINDING_convert(BIGNUM *n, BN_BLINDING *b, BN_CTX *ctx);
int BN_BLINDING_invert(BIGNUM *n, BN_BLINDING *b, BN_CTX *ctx);
int BN_BLINDING_convert_ex(BIGNUM *n, BIGNUM *r, BN_BLINDING *b, BN_CTX *);
int BN_BLINDING_invert_ex(BIGNUM *n, const BIGNUM *r, BN_BLINDING *b, BN_CTX *);
unsigned long BN_BLINDING_get_thread_id(const BN_BLINDING *);
void BN_BLINDING_set_thread_id(BN_BLINDING *, unsigned long);
CRYPTO_THREADID *BN_BLINDING_thread_id(BN_BLINDING *);
unsigned long BN_BLINDING_get_flags(const BN_BLINDING *);
void BN_BLINDING_set_flags(BN_BLINDING *, unsigned long);
BN_BLINDING *BN_BLINDING_create_param(BN_BLINDING *b,
 const BIGNUM *e, BIGNUM *m, BN_CTX *ctx,
 int (*bn_mod_exp)(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
     const BIGNUM *m, BN_CTX *ctx, BN_MONT_CTX *m_ctx),
void BN_set_params(int mul,int high,int low,int mont);
int BN_get_params(int which);
void BN_RECP_CTX_init(BN_RECP_CTX *recp);
BN_RECP_CTX *BN_RECP_CTX_new(void);
void BN_RECP_CTX_free(BN_RECP_CTX *recp);
int BN_RECP_CTX_set(BN_RECP_CTX *recp,const BIGNUM *rdiv,BN_CTX *ctx);
int BN_mod_mul_reciprocal(BIGNUM *r, const BIGNUM *x, const BIGNUM *y,
 BN_RECP_CTX *recp,BN_CTX *ctx);
int BN_mod_exp_recp(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
int BN_div_recp(BIGNUM *dv, BIGNUM *rem, const BIGNUM *m,
 BN_RECP_CTX *recp, BN_CTX *ctx);
# 639 "/usr/include/openssl/bn.h" 3 4
int BN_GF2m_add(BIGNUM *r, const BIGNUM *a, const BIGNUM *b);
int BN_GF2m_mod(BIGNUM *r, const BIGNUM *a, const BIGNUM *p);
int BN_GF2m_mod_mul(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
 const BIGNUM *p, BN_CTX *ctx);
int BN_GF2m_mod_sqr(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
 BN_CTX *ctx);
int BN_GF2m_mod_inv(BIGNUM *r, const BIGNUM *b, const BIGNUM *p,
 BN_CTX *ctx);
int BN_GF2m_mod_div(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_GF2m_mod_exp(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_GF2m_mod_sqrt(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
 BN_CTX *ctx);
int BN_GF2m_mod_solve_quad(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
 BN_CTX *ctx);
int BN_GF2m_mod_arr(BIGNUM *r, const BIGNUM *a, const int p[]);
int BN_GF2m_mod_mul_arr(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
 const int p[], BN_CTX *ctx);
int BN_GF2m_mod_sqr_arr(BIGNUM *r, const BIGNUM *a, const int p[],
 BN_CTX *ctx);
int BN_GF2m_mod_inv_arr(BIGNUM *r, const BIGNUM *b, const int p[],
 BN_CTX *ctx);
int BN_GF2m_mod_div_arr(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_GF2m_mod_exp_arr(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_GF2m_mod_sqrt_arr(BIGNUM *r, const BIGNUM *a,
int BN_GF2m_mod_solve_quad_arr(BIGNUM *r, const BIGNUM *a,
int BN_GF2m_poly2arr(const BIGNUM *a, int p[], int max);
int BN_GF2m_arr2poly(const int p[], BIGNUM *a);
int BN_nist_mod_192(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
int BN_nist_mod_224(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
int BN_nist_mod_256(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
int BN_nist_mod_384(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
int BN_nist_mod_521(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
const BIGNUM *BN_get0_nist_prime_192(void);
const BIGNUM *BN_get0_nist_prime_224(void);
const BIGNUM *BN_get0_nist_prime_256(void);
const BIGNUM *BN_get0_nist_prime_384(void);
const BIGNUM *BN_get0_nist_prime_521(void);
BIGNUM *bn_expand2(BIGNUM *a, int words);
BIGNUM *bn_dup_expand(const BIGNUM *a, int words);
# 809 "/usr/include/openssl/bn.h" 3 4
unsigned long bn_mul_add_words(unsigned long *rp, const unsigned long *ap, int num, unsigned long w);
unsigned long bn_mul_words(unsigned long *rp, const unsigned long *ap, int num, unsigned long w);
void bn_sqr_words(unsigned long *rp, const unsigned long *ap, int num);
unsigned long bn_div_words(unsigned long h, unsigned long l, unsigned long d);
unsigned long bn_add_words(unsigned long *rp, const unsigned long *ap, const unsigned long *bp,int num);
unsigned long bn_sub_words(unsigned long *rp, const unsigned long *ap, const unsigned long *bp,int num);
BIGNUM *get_rfc2409_prime_768(BIGNUM *bn);
BIGNUM *get_rfc2409_prime_1024(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_1536(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_2048(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_3072(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_4096(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_6144(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_8192(BIGNUM *bn);
int BN_bntest_rand(BIGNUM *rnd, int bits, int top,int bottom);
void ERR_load_BN_strings(void);
# 75 "/usr/include/openssl/asn1.h" 2 3 4
# 165 "/usr/include/openssl/asn1.h" 3 4
struct X509_algor_st;
struct stack_st_X509_ALGOR { _STACK stack; };
# 175 "/usr/include/openssl/asn1.h" 3 4
typedef struct asn1_ctx_st
 unsigned char *p;
 int eos;
 int error;
 int inf;
 int tag;
 int xclass;
 long slen;
 unsigned char *max;
 unsigned char *q;
 unsigned char **pp;
 int line;
 } ASN1_CTX;
typedef struct asn1_const_ctx_st
 const unsigned char *p;
 int eos;
 int error;
 int inf;
 int tag;
 int xclass;
 long slen;
 const unsigned char *max;
 const unsigned char *q;
 const unsigned char **pp;
 int line;
 } ASN1_const_CTX;
typedef struct asn1_object_st
 const char *sn,*ln;
 int nid;
 int length;
 const unsigned char *data;
 int flags;
 } ASN1_OBJECT;
# 238 "/usr/include/openssl/asn1.h" 3 4
 int length;
 int type;
 long flags;
typedef struct ASN1_ENCODING_st
 unsigned char *enc;
 long len;
 int modified;
 } ASN1_ENCODING;
# 271 "/usr/include/openssl/asn1.h" 3 4
typedef struct asn1_string_table_st {
 int nid;
 long minsize;
 long maxsize;
 unsigned long mask;
 unsigned long flags;
} ASN1_STRING_TABLE;
struct stack_st_ASN1_STRING_TABLE { _STACK stack; };
# 295 "/usr/include/openssl/asn1.h" 3 4
typedef struct ASN1_TEMPLATE_st ASN1_TEMPLATE;
typedef struct ASN1_TLC_st ASN1_TLC;
typedef struct ASN1_VALUE_st ASN1_VALUE;
# 362 "/usr/include/openssl/asn1.h" 3 4
typedef void *d2i_of_void(void **,const unsigned char **,long); typedef int i2d_of_void(void *,unsigned char **);
# 402 "/usr/include/openssl/asn1.h" 3 4
typedef const ASN1_ITEM ASN1_ITEM_EXP;
# 516 "/usr/include/openssl/asn1.h" 3 4
struct stack_st_ASN1_INTEGER { _STACK stack; };
struct stack_st_ASN1_GENERALSTRING { _STACK stack; };
typedef struct asn1_type_st
 int type;
 union {
  char *ptr;
  ASN1_BOOLEAN boolean;
  ASN1_STRING * asn1_string;
  ASN1_OBJECT * object;
  ASN1_INTEGER * integer;
  ASN1_ENUMERATED * enumerated;
  ASN1_BIT_STRING * bit_string;
  ASN1_OCTET_STRING * octet_string;
  ASN1_PRINTABLESTRING * printablestring;
  ASN1_T61STRING * t61string;
  ASN1_IA5STRING * ia5string;
  ASN1_GENERALSTRING * generalstring;
  ASN1_BMPSTRING * bmpstring;
  ASN1_UNIVERSALSTRING * universalstring;
  ASN1_UTCTIME * utctime;
  ASN1_GENERALIZEDTIME * generalizedtime;
  ASN1_VISIBLESTRING * visiblestring;
  ASN1_UTF8STRING * utf8string;
  ASN1_STRING * set;
  ASN1_STRING * sequence;
  ASN1_VALUE * asn1_value;
  } value;
 } ASN1_TYPE;
struct stack_st_ASN1_TYPE { _STACK stack; };
typedef struct stack_st_ASN1_TYPE ASN1_SEQUENCE_ANY;
ASN1_SEQUENCE_ANY *d2i_ASN1_SEQUENCE_ANY(ASN1_SEQUENCE_ANY **a, const unsigned char **in, long len); int i2d_ASN1_SEQUENCE_ANY(const ASN1_SEQUENCE_ANY *a, unsigned char **out); extern const ASN1_ITEM ASN1_SEQUENCE_ANY_it;
ASN1_SEQUENCE_ANY *d2i_ASN1_SET_ANY(ASN1_SEQUENCE_ANY **a, const unsigned char **in, long len); int i2d_ASN1_SET_ANY(const ASN1_SEQUENCE_ANY *a, unsigned char **out); extern const ASN1_ITEM ASN1_SET_ANY_it;
typedef struct NETSCAPE_X509_st
 ASN1_OCTET_STRING *header;
 X509 *cert;
 } NETSCAPE_X509;
typedef struct BIT_STRING_BITNAME_st {
 int bitnum;
 const char *lname;
 const char *sname;
} BIT_STRING_BITNAME;
# 774 "/usr/include/openssl/asn1.h" 3 4
ASN1_TYPE *ASN1_TYPE_new(void); void ASN1_TYPE_free(ASN1_TYPE *a); ASN1_TYPE *d2i_ASN1_TYPE(ASN1_TYPE **a, const unsigned char **in, long len); int i2d_ASN1_TYPE(ASN1_TYPE *a, unsigned char **out); extern const ASN1_ITEM ASN1_ANY_it;
int ASN1_TYPE_get(ASN1_TYPE *a);
void ASN1_TYPE_set(ASN1_TYPE *a, int type, void *value);
int ASN1_TYPE_set1(ASN1_TYPE *a, int type, const void *value);
int ASN1_TYPE_cmp(ASN1_TYPE *a, ASN1_TYPE *b);
ASN1_OBJECT * ASN1_OBJECT_new(void );
void ASN1_OBJECT_free(ASN1_OBJECT *a);
int i2d_ASN1_OBJECT(ASN1_OBJECT *a,unsigned char **pp);
ASN1_OBJECT * c2i_ASN1_OBJECT(ASN1_OBJECT **a,const unsigned char **pp,
   long length);
ASN1_OBJECT * d2i_ASN1_OBJECT(ASN1_OBJECT **a,const unsigned char **pp,
   long length);
extern const ASN1_ITEM ASN1_OBJECT_it;
struct stack_st_ASN1_OBJECT { _STACK stack; };
ASN1_STRING * ASN1_STRING_new(void);
void ASN1_STRING_free(ASN1_STRING *a);
int ASN1_STRING_copy(ASN1_STRING *dst, const ASN1_STRING *str);
ASN1_STRING * ASN1_STRING_dup(const ASN1_STRING *a);
ASN1_STRING * ASN1_STRING_type_new(int type );
int ASN1_STRING_cmp(const ASN1_STRING *a, const ASN1_STRING *b);
int ASN1_STRING_set(ASN1_STRING *str, const void *data, int len);
void ASN1_STRING_set0(ASN1_STRING *str, void *data, int len);
int ASN1_STRING_length(const ASN1_STRING *x);
void ASN1_STRING_length_set(ASN1_STRING *x, int n);
int ASN1_STRING_type(ASN1_STRING *x);
unsigned char * ASN1_STRING_data(ASN1_STRING *x);
ASN1_BIT_STRING *ASN1_BIT_STRING_new(void); void ASN1_BIT_STRING_free(ASN1_BIT_STRING *a); ASN1_BIT_STRING *d2i_ASN1_BIT_STRING(ASN1_BIT_STRING **a, const unsigned char **in, long len); int i2d_ASN1_BIT_STRING(ASN1_BIT_STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_BIT_STRING_it;
int i2c_ASN1_BIT_STRING(ASN1_BIT_STRING *a,unsigned char **pp);
ASN1_BIT_STRING *c2i_ASN1_BIT_STRING(ASN1_BIT_STRING **a,const unsigned char **pp,
   long length);
int ASN1_BIT_STRING_set(ASN1_BIT_STRING *a, unsigned char *d,
   int length );
int ASN1_BIT_STRING_set_bit(ASN1_BIT_STRING *a, int n, int value);
int ASN1_BIT_STRING_get_bit(ASN1_BIT_STRING *a, int n);
int ASN1_BIT_STRING_check(ASN1_BIT_STRING *a,
                                     unsigned char *flags, int flags_len);
int ASN1_BIT_STRING_name_print(BIO *out, ASN1_BIT_STRING *bs,
    BIT_STRING_BITNAME *tbl, int indent);
int ASN1_BIT_STRING_num_asc(char *name, BIT_STRING_BITNAME *tbl);
int ASN1_BIT_STRING_set_asc(ASN1_BIT_STRING *bs, char *name, int value,
int i2d_ASN1_BOOLEAN(int a,unsigned char **pp);
int d2i_ASN1_BOOLEAN(int *a,const unsigned char **pp,long length);
ASN1_INTEGER *ASN1_INTEGER_new(void); void ASN1_INTEGER_free(ASN1_INTEGER *a); ASN1_INTEGER *d2i_ASN1_INTEGER(ASN1_INTEGER **a, const unsigned char **in, long len); int i2d_ASN1_INTEGER(ASN1_INTEGER *a, unsigned char **out); extern const ASN1_ITEM ASN1_INTEGER_it;
int i2c_ASN1_INTEGER(ASN1_INTEGER *a,unsigned char **pp);
ASN1_INTEGER *c2i_ASN1_INTEGER(ASN1_INTEGER **a,const unsigned char **pp,
   long length);
ASN1_INTEGER *d2i_ASN1_UINTEGER(ASN1_INTEGER **a,const unsigned char **pp,
   long length);
ASN1_INTEGER * ASN1_INTEGER_dup(const ASN1_INTEGER *x);
int ASN1_INTEGER_cmp(const ASN1_INTEGER *x, const ASN1_INTEGER *y);
ASN1_ENUMERATED *ASN1_ENUMERATED_new(void); void ASN1_ENUMERATED_free(ASN1_ENUMERATED *a); ASN1_ENUMERATED *d2i_ASN1_ENUMERATED(ASN1_ENUMERATED **a, const unsigned char **in, long len); int i2d_ASN1_ENUMERATED(ASN1_ENUMERATED *a, unsigned char **out); extern const ASN1_ITEM ASN1_ENUMERATED_it;
int ASN1_UTCTIME_check(ASN1_UTCTIME *a);
ASN1_UTCTIME *ASN1_UTCTIME_set(ASN1_UTCTIME *s,time_t t);
ASN1_UTCTIME *ASN1_UTCTIME_adj(ASN1_UTCTIME *s, time_t t,
    int offset_day, long offset_sec);
int ASN1_UTCTIME_set_string(ASN1_UTCTIME *s, const char *str);
int ASN1_UTCTIME_cmp_time_t(const ASN1_UTCTIME *s, time_t t);
int ASN1_GENERALIZEDTIME_check(ASN1_GENERALIZEDTIME *a);
ASN1_GENERALIZEDTIME *ASN1_GENERALIZEDTIME_set(ASN1_GENERALIZEDTIME *s,time_t t);
ASN1_GENERALIZEDTIME *ASN1_GENERALIZEDTIME_adj(ASN1_GENERALIZEDTIME *s,
      time_t t, int offset_day, long offset_sec);
int ASN1_GENERALIZEDTIME_set_string(ASN1_GENERALIZEDTIME *s, const char *str);
ASN1_OCTET_STRING *ASN1_OCTET_STRING_new(void); void ASN1_OCTET_STRING_free(ASN1_OCTET_STRING *a); ASN1_OCTET_STRING *d2i_ASN1_OCTET_STRING(ASN1_OCTET_STRING **a, const unsigned char **in, long len); int i2d_ASN1_OCTET_STRING(ASN1_OCTET_STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_OCTET_STRING_it;
ASN1_OCTET_STRING * ASN1_OCTET_STRING_dup(const ASN1_OCTET_STRING *a);
int ASN1_OCTET_STRING_cmp(const ASN1_OCTET_STRING *a, const ASN1_OCTET_STRING *b);
int ASN1_OCTET_STRING_set(ASN1_OCTET_STRING *str, const unsigned char *data, int len);
ASN1_VISIBLESTRING *ASN1_VISIBLESTRING_new(void); void ASN1_VISIBLESTRING_free(ASN1_VISIBLESTRING *a); ASN1_VISIBLESTRING *d2i_ASN1_VISIBLESTRING(ASN1_VISIBLESTRING **a, const unsigned char **in, long len); int i2d_ASN1_VISIBLESTRING(ASN1_VISIBLESTRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_VISIBLESTRING_it;
ASN1_UNIVERSALSTRING *ASN1_UNIVERSALSTRING_new(void); void ASN1_UNIVERSALSTRING_free(ASN1_UNIVERSALSTRING *a); ASN1_UNIVERSALSTRING *d2i_ASN1_UNIVERSALSTRING(ASN1_UNIVERSALSTRING **a, const unsigned char **in, long len); int i2d_ASN1_UNIVERSALSTRING(ASN1_UNIVERSALSTRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_UNIVERSALSTRING_it;
ASN1_UTF8STRING *ASN1_UTF8STRING_new(void); void ASN1_UTF8STRING_free(ASN1_UTF8STRING *a); ASN1_UTF8STRING *d2i_ASN1_UTF8STRING(ASN1_UTF8STRING **a, const unsigned char **in, long len); int i2d_ASN1_UTF8STRING(ASN1_UTF8STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_UTF8STRING_it;
ASN1_NULL *ASN1_NULL_new(void); void ASN1_NULL_free(ASN1_NULL *a); ASN1_NULL *d2i_ASN1_NULL(ASN1_NULL **a, const unsigned char **in, long len); int i2d_ASN1_NULL(ASN1_NULL *a, unsigned char **out); extern const ASN1_ITEM ASN1_NULL_it;
ASN1_BMPSTRING *ASN1_BMPSTRING_new(void); void ASN1_BMPSTRING_free(ASN1_BMPSTRING *a); ASN1_BMPSTRING *d2i_ASN1_BMPSTRING(ASN1_BMPSTRING **a, const unsigned char **in, long len); int i2d_ASN1_BMPSTRING(ASN1_BMPSTRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_BMPSTRING_it;
int UTF8_getc(const unsigned char *str, int len, unsigned long *val);
int UTF8_putc(unsigned char *str, int len, unsigned long value);
ASN1_STRING *ASN1_PRINTABLE_new(void); void ASN1_PRINTABLE_free(ASN1_STRING *a); ASN1_STRING *d2i_ASN1_PRINTABLE(ASN1_STRING **a, const unsigned char **in, long len); int i2d_ASN1_PRINTABLE(ASN1_STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_PRINTABLE_it;
ASN1_STRING *DIRECTORYSTRING_new(void); void DIRECTORYSTRING_free(ASN1_STRING *a); ASN1_STRING *d2i_DIRECTORYSTRING(ASN1_STRING **a, const unsigned char **in, long len); int i2d_DIRECTORYSTRING(ASN1_STRING *a, unsigned char **out); extern const ASN1_ITEM DIRECTORYSTRING_it;
ASN1_STRING *DISPLAYTEXT_new(void); void DISPLAYTEXT_free(ASN1_STRING *a); ASN1_STRING *d2i_DISPLAYTEXT(ASN1_STRING **a, const unsigned char **in, long len); int i2d_DISPLAYTEXT(ASN1_STRING *a, unsigned char **out); extern const ASN1_ITEM DISPLAYTEXT_it;
ASN1_PRINTABLESTRING *ASN1_PRINTABLESTRING_new(void); void ASN1_PRINTABLESTRING_free(ASN1_PRINTABLESTRING *a); ASN1_PRINTABLESTRING *d2i_ASN1_PRINTABLESTRING(ASN1_PRINTABLESTRING **a, const unsigned char **in, long len); int i2d_ASN1_PRINTABLESTRING(ASN1_PRINTABLESTRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_PRINTABLESTRING_it;
ASN1_T61STRING *ASN1_T61STRING_new(void); void ASN1_T61STRING_free(ASN1_T61STRING *a); ASN1_T61STRING *d2i_ASN1_T61STRING(ASN1_T61STRING **a, const unsigned char **in, long len); int i2d_ASN1_T61STRING(ASN1_T61STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_T61STRING_it;
ASN1_IA5STRING *ASN1_IA5STRING_new(void); void ASN1_IA5STRING_free(ASN1_IA5STRING *a); ASN1_IA5STRING *d2i_ASN1_IA5STRING(ASN1_IA5STRING **a, const unsigned char **in, long len); int i2d_ASN1_IA5STRING(ASN1_IA5STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_IA5STRING_it;
ASN1_GENERALSTRING *ASN1_GENERALSTRING_new(void); void ASN1_GENERALSTRING_free(ASN1_GENERALSTRING *a); ASN1_GENERALSTRING *d2i_ASN1_GENERALSTRING(ASN1_GENERALSTRING **a, const unsigned char **in, long len); int i2d_ASN1_GENERALSTRING(ASN1_GENERALSTRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_GENERALSTRING_it;
ASN1_UTCTIME *ASN1_UTCTIME_new(void); void ASN1_UTCTIME_free(ASN1_UTCTIME *a); ASN1_UTCTIME *d2i_ASN1_UTCTIME(ASN1_UTCTIME **a, const unsigned char **in, long len); int i2d_ASN1_UTCTIME(ASN1_UTCTIME *a, unsigned char **out); extern const ASN1_ITEM ASN1_UTCTIME_it;
ASN1_GENERALIZEDTIME *ASN1_GENERALIZEDTIME_new(void); void ASN1_GENERALIZEDTIME_free(ASN1_GENERALIZEDTIME *a); ASN1_GENERALIZEDTIME *d2i_ASN1_GENERALIZEDTIME(ASN1_GENERALIZEDTIME **a, const unsigned char **in, long len); int i2d_ASN1_GENERALIZEDTIME(ASN1_GENERALIZEDTIME *a, unsigned char **out); extern const ASN1_ITEM ASN1_GENERALIZEDTIME_it;
ASN1_TIME *ASN1_TIME_new(void); void ASN1_TIME_free(ASN1_TIME *a); ASN1_TIME *d2i_ASN1_TIME(ASN1_TIME **a, const unsigned char **in, long len); int i2d_ASN1_TIME(ASN1_TIME *a, unsigned char **out); extern const ASN1_ITEM ASN1_TIME_it;
extern const ASN1_ITEM ASN1_OCTET_STRING_NDEF_it;
ASN1_TIME *ASN1_TIME_set(ASN1_TIME *s,time_t t);
ASN1_TIME *ASN1_TIME_adj(ASN1_TIME *s,time_t t,
int ASN1_TIME_check(ASN1_TIME *t);
ASN1_GENERALIZEDTIME *ASN1_TIME_to_generalizedtime(ASN1_TIME *t, ASN1_GENERALIZEDTIME **out);
int ASN1_TIME_set_string(ASN1_TIME *s, const char *str);
int i2d_ASN1_SET(struct stack_st_OPENSSL_BLOCK *a, unsigned char **pp,
   i2d_of_void *i2d, int ex_tag, int ex_class,
   int is_set);
struct stack_st_OPENSSL_BLOCK *d2i_ASN1_SET(struct stack_st_OPENSSL_BLOCK **a,
         long length, d2i_of_void *d2i,
         void (*free_func)(OPENSSL_BLOCK), int ex_tag,
         int ex_class);
int i2a_ASN1_INTEGER(BIO *bp, ASN1_INTEGER *a);
int a2i_ASN1_INTEGER(BIO *bp,ASN1_INTEGER *bs,char *buf,int size);
int i2a_ASN1_ENUMERATED(BIO *bp, ASN1_ENUMERATED *a);
int a2i_ASN1_ENUMERATED(BIO *bp,ASN1_ENUMERATED *bs,char *buf,int size);
int i2a_ASN1_OBJECT(BIO *bp,ASN1_OBJECT *a);
int a2i_ASN1_STRING(BIO *bp,ASN1_STRING *bs,char *buf,int size);
int i2a_ASN1_STRING(BIO *bp, ASN1_STRING *a, int type);
int i2t_ASN1_OBJECT(char *buf,int buf_len,ASN1_OBJECT *a);
int a2d_ASN1_OBJECT(unsigned char *out,int olen, const char *buf, int num);
ASN1_OBJECT *ASN1_OBJECT_create(int nid, unsigned char *data,int len,
 const char *sn, const char *ln);
int ASN1_INTEGER_set(ASN1_INTEGER *a, long v);
long ASN1_INTEGER_get(const ASN1_INTEGER *a);
ASN1_INTEGER *BN_to_ASN1_INTEGER(const BIGNUM *bn, ASN1_INTEGER *ai);
BIGNUM *ASN1_INTEGER_to_BN(const ASN1_INTEGER *ai,BIGNUM *bn);
int ASN1_ENUMERATED_set(ASN1_ENUMERATED *a, long v);
long ASN1_ENUMERATED_get(ASN1_ENUMERATED *a);
ASN1_ENUMERATED *BN_to_ASN1_ENUMERATED(BIGNUM *bn, ASN1_ENUMERATED *ai);
BIGNUM *ASN1_ENUMERATED_to_BN(ASN1_ENUMERATED *ai,BIGNUM *bn);
int ASN1_PRINTABLE_type(const unsigned char *s, int max);
int i2d_ASN1_bytes(ASN1_STRING *a, unsigned char **pp, int tag, int xclass);
ASN1_STRING *d2i_ASN1_bytes(ASN1_STRING **a, const unsigned char **pp,
 long length, int Ptag, int Pclass);
unsigned long ASN1_tag2bit(int tag);
ASN1_STRING *d2i_ASN1_type_bytes(ASN1_STRING **a,const unsigned char **pp,
  long length,int type);
int asn1_Finish(ASN1_CTX *c);
int asn1_const_Finish(ASN1_const_CTX *c);
int ASN1_get_object(const unsigned char **pp, long *plength, int *ptag,
 int *pclass, long omax);
int ASN1_check_infinite_end(unsigned char **p,long len);
int ASN1_const_check_infinite_end(const unsigned char **p,long len);
void ASN1_put_object(unsigned char **pp, int constructed, int length,
int ASN1_put_eoc(unsigned char **pp);
int ASN1_object_size(int constructed, int length, int tag);
void *ASN1_dup(i2d_of_void *i2d, d2i_of_void *d2i, void *x);
# 966 "/usr/include/openssl/asn1.h" 3 4
void *ASN1_item_dup(const ASN1_ITEM *it, void *x);
# 975 "/usr/include/openssl/asn1.h" 3 4
void *ASN1_d2i_fp(void *(*xnew)(void), d2i_of_void *d2i, FILE *in, void **x);
void *ASN1_item_d2i_fp(const ASN1_ITEM *it, FILE *in, void *x);
int ASN1_i2d_fp(i2d_of_void *i2d,FILE *out,void *x);
# 996 "/usr/include/openssl/asn1.h" 3 4
int ASN1_item_i2d_fp(const ASN1_ITEM *it, FILE *out, void *x);
int ASN1_STRING_print_ex_fp(FILE *fp, ASN1_STRING *str, unsigned long flags);
int ASN1_STRING_to_UTF8(unsigned char **out, ASN1_STRING *in);
void *ASN1_d2i_bio(void *(*xnew)(void), d2i_of_void *d2i, BIO *in, void **x);
void *ASN1_item_d2i_bio(const ASN1_ITEM *it, BIO *in, void *x);
int ASN1_i2d_bio(i2d_of_void *i2d,BIO *out, unsigned char *x);
# 1024 "/usr/include/openssl/asn1.h" 3 4
int ASN1_item_i2d_bio(const ASN1_ITEM *it, BIO *out, void *x);
int ASN1_UTCTIME_print(BIO *fp, const ASN1_UTCTIME *a);
int ASN1_GENERALIZEDTIME_print(BIO *fp, const ASN1_GENERALIZEDTIME *a);
int ASN1_TIME_print(BIO *fp, const ASN1_TIME *a);
int ASN1_STRING_print(BIO *bp, const ASN1_STRING *v);
int ASN1_STRING_print_ex(BIO *out, ASN1_STRING *str, unsigned long flags);
int ASN1_bn_print(BIO *bp, const char *number, const BIGNUM *num,
    unsigned char *buf, int off);
int ASN1_parse(BIO *bp,const unsigned char *pp,long len,int indent);
int ASN1_parse_dump(BIO *bp,const unsigned char *pp,long len,int indent,int dump);
const char *ASN1_tag2str(int tag);
NETSCAPE_X509 *NETSCAPE_X509_new(void); void NETSCAPE_X509_free(NETSCAPE_X509 *a); NETSCAPE_X509 *d2i_NETSCAPE_X509(NETSCAPE_X509 **a, const unsigned char **in, long len); int i2d_NETSCAPE_X509(NETSCAPE_X509 *a, unsigned char **out); extern const ASN1_ITEM NETSCAPE_X509_it;
int ASN1_UNIVERSALSTRING_to_string(ASN1_UNIVERSALSTRING *s);
int ASN1_TYPE_set_octetstring(ASN1_TYPE *a,
int ASN1_TYPE_get_octetstring(ASN1_TYPE *a,
 unsigned char *data, int max_len);
int ASN1_TYPE_set_int_octetstring(ASN1_TYPE *a, long num,
int ASN1_TYPE_get_int_octetstring(ASN1_TYPE *a,long *num,
struct stack_st_OPENSSL_BLOCK *ASN1_seq_unpack(const unsigned char *buf, int len,
     d2i_of_void *d2i, void (*free_func)(OPENSSL_BLOCK));
unsigned char *ASN1_seq_pack(struct stack_st_OPENSSL_BLOCK *safes, i2d_of_void *i2d,
        unsigned char **buf, int *len );
void *ASN1_unpack_string(ASN1_STRING *oct, d2i_of_void *d2i);
void *ASN1_item_unpack(ASN1_STRING *oct, const ASN1_ITEM *it);
ASN1_STRING *ASN1_pack_string(void *obj, i2d_of_void *i2d,
         ASN1_OCTET_STRING **oct);
ASN1_STRING *ASN1_item_pack(void *obj, const ASN1_ITEM *it, ASN1_OCTET_STRING **oct);
void ASN1_STRING_set_default_mask(unsigned long mask);
int ASN1_STRING_set_default_mask_asc(const char *p);
unsigned long ASN1_STRING_get_default_mask(void);
int ASN1_mbstring_copy(ASN1_STRING **out, const unsigned char *in, int len,
     int inform, unsigned long mask);
int ASN1_mbstring_ncopy(ASN1_STRING **out, const unsigned char *in, int len,
     int inform, unsigned long mask,
     long minsize, long maxsize);
ASN1_STRING *ASN1_STRING_set_by_NID(ASN1_STRING **out,
  const unsigned char *in, int inlen, int inform, int nid);
ASN1_STRING_TABLE *ASN1_STRING_TABLE_get(int nid);
int ASN1_STRING_TABLE_add(int, long, long, unsigned long, unsigned long);
void ASN1_STRING_TABLE_cleanup(void);
ASN1_VALUE *ASN1_item_new(const ASN1_ITEM *it);
void ASN1_item_free(ASN1_VALUE *val, const ASN1_ITEM *it);
ASN1_VALUE * ASN1_item_d2i(ASN1_VALUE **val, const unsigned char **in, long len, const ASN1_ITEM *it);
int ASN1_item_i2d(ASN1_VALUE *val, unsigned char **out, const ASN1_ITEM *it);
int ASN1_item_ndef_i2d(ASN1_VALUE *val, unsigned char **out, const ASN1_ITEM *it);
void ASN1_add_oid_module(void);
ASN1_TYPE *ASN1_generate_nconf(char *str, CONF *nconf);
ASN1_TYPE *ASN1_generate_v3(char *str, X509V3_CTX *cnf);
# 1118 "/usr/include/openssl/asn1.h" 3 4
int ASN1_item_print(BIO *out, ASN1_VALUE *ifld, int indent,
    const ASN1_ITEM *it, const ASN1_PCTX *pctx);
ASN1_PCTX *ASN1_PCTX_new(void);
void ASN1_PCTX_free(ASN1_PCTX *p);
unsigned long ASN1_PCTX_get_flags(ASN1_PCTX *p);
void ASN1_PCTX_set_flags(ASN1_PCTX *p, unsigned long flags);
unsigned long ASN1_PCTX_get_nm_flags(ASN1_PCTX *p);
void ASN1_PCTX_set_nm_flags(ASN1_PCTX *p, unsigned long flags);
unsigned long ASN1_PCTX_get_cert_flags(ASN1_PCTX *p);
void ASN1_PCTX_set_cert_flags(ASN1_PCTX *p, unsigned long flags);
unsigned long ASN1_PCTX_get_oid_flags(ASN1_PCTX *p);
void ASN1_PCTX_set_oid_flags(ASN1_PCTX *p, unsigned long flags);
unsigned long ASN1_PCTX_get_str_flags(ASN1_PCTX *p);
void ASN1_PCTX_set_str_flags(ASN1_PCTX *p, unsigned long flags);
BIO_METHOD *BIO_f_asn1(void);
BIO *BIO_new_NDEF(BIO *out, ASN1_VALUE *val, const ASN1_ITEM *it);
int i2d_ASN1_bio_stream(BIO *out, ASN1_VALUE *val, BIO *in, int flags,
int PEM_write_bio_ASN1_stream(BIO *out, ASN1_VALUE *val, BIO *in, int flags,
    const char *hdr,
int SMIME_write_ASN1(BIO *bio, ASN1_VALUE *val, BIO *data, int flags,
    int ctype_nid, int econt_nid,
    struct stack_st_X509_ALGOR *mdalgs,
ASN1_VALUE *SMIME_read_ASN1(BIO *bio, BIO **bcont, const ASN1_ITEM *it);
int SMIME_crlf_copy(BIO *in, BIO *out, int flags);
int SMIME_text(BIO *in, BIO *out);
void ERR_load_ASN1_strings(void);
# 961 "/usr/include/openssl/objects.h" 2 3 4
# 979 "/usr/include/openssl/objects.h" 3 4
typedef struct obj_name_st
 int type;
 int alias;
 const char *name;
 const char *data;
 } OBJ_NAME;
int OBJ_NAME_init(void);
int OBJ_NAME_new_index(unsigned long (*hash_func)(const char *),
         int (*cmp_func)(const char *, const char *),
         void (*free_func)(const char *, int, const char *));
const char *OBJ_NAME_get(const char *name,int type);
int OBJ_NAME_add(const char *name,int type,const char *data);
int OBJ_NAME_remove(const char *name,int type);
void OBJ_NAME_cleanup(int type);
void OBJ_NAME_do_all(int type,void (*fn)(const OBJ_NAME *,void *arg),
       void *arg);
void OBJ_NAME_do_all_sorted(int type,void (*fn)(const OBJ_NAME *,void *arg),
       void *arg);
ASN1_OBJECT * OBJ_dup(const ASN1_OBJECT *o);
ASN1_OBJECT * OBJ_nid2obj(int n);
const char * OBJ_nid2ln(int n);
const char * OBJ_nid2sn(int n);
int OBJ_obj2nid(const ASN1_OBJECT *o);
ASN1_OBJECT * OBJ_txt2obj(const char *s, int no_name);
int OBJ_obj2txt(char *buf, int buf_len, const ASN1_OBJECT *a, int no_name);
int OBJ_txt2nid(const char *s);
int OBJ_ln2nid(const char *s);
int OBJ_sn2nid(const char *s);
int OBJ_cmp(const ASN1_OBJECT *a,const ASN1_OBJECT *b);
const void * OBJ_bsearch_(const void *key,const void *base,int num,int size,
const void * OBJ_bsearch_ex_(const void *key,const void *base,int num,
    int size,
    int (*cmp)(const void *, const void *),
    int flags);
# 1100 "/usr/include/openssl/objects.h" 3 4
int OBJ_new_nid(int num);
int OBJ_add_object(const ASN1_OBJECT *obj);
int OBJ_create(const char *oid,const char *sn,const char *ln);
void OBJ_cleanup(void );
int OBJ_create_objects(BIO *in);
int OBJ_find_sigid_algs(int signid, int *pdig_nid, int *ppkey_nid);
int OBJ_find_sigid_by_algs(int *psignid, int dig_nid, int pkey_nid);
int OBJ_add_sigid(int signid, int dig_id, int pkey_id);
void OBJ_sigid_free(void);
extern int obj_cleanup_defer;
void check_defer(int nid);
void ERR_load_OBJ_strings(void);
# 95 "/usr/include/openssl/evp.h" 2 3 4
# 128 "/usr/include/openssl/evp.h" 3 4
struct evp_pkey_st
 int type;
 int save_type;
 int references;
 const EVP_PKEY_ASN1_METHOD *ameth;
 ENGINE *engine;
 union {
  char *ptr;
  struct rsa_st *rsa;
  struct dsa_st *dsa;
  struct dh_st *dh;
  struct ec_key_st *ec;
  } pkey;
 int save_parameters;
 struct stack_st_X509_ATTRIBUTE *attributes;
struct env_md_st
 int type;
 int pkey_type;
 int md_size;
 int (*init)(EVP_MD_CTX *ctx);
 int (*update)(EVP_MD_CTX *ctx,const void *data,size_t count);
 int (*final)(EVP_MD_CTX *ctx,unsigned char *md);
 int (*copy)(EVP_MD_CTX *to,const EVP_MD_CTX *from);
 int (*cleanup)(EVP_MD_CTX *ctx);
 int (*sign)(int type, const unsigned char *m, unsigned int m_length,
      unsigned char *sigret, unsigned int *siglen, void *key);
 int (*verify)(int type, const unsigned char *m, unsigned int m_length,
        const unsigned char *sigbuf, unsigned int siglen,
        void *key);
 int required_pkey_type[5];
 int block_size;
 int ctx_size;
 int (*md_ctrl)(EVP_MD_CTX *ctx, int cmd, int p1, void *p2);
typedef int evp_sign_method(int type,const unsigned char *m,
       unsigned int m_length,unsigned char *sigret,
typedef int evp_verify_method(int type,const unsigned char *m,
       unsigned int m_length,const unsigned char *sigbuf,
       unsigned int siglen, void *key);
# 265 "/usr/include/openssl/evp.h" 3 4
 const EVP_MD *digest;
 ENGINE *engine;
 void *md_data;
 EVP_PKEY_CTX *pctx;
# 303 "/usr/include/openssl/evp.h" 3 4
 int nid;
 int block_size;
 int key_len;
 int iv_len;
 int (*init)(EVP_CIPHER_CTX *ctx, const unsigned char *key,
      const unsigned char *iv, int enc);
 int (*do_cipher)(EVP_CIPHER_CTX *ctx, unsigned char *out,
    const unsigned char *in, size_t inl);
 int (*cleanup)(EVP_CIPHER_CTX *);
 int ctx_size;
 int (*set_asn1_parameters)(EVP_CIPHER_CTX *, ASN1_TYPE *);
 int (*get_asn1_parameters)(EVP_CIPHER_CTX *, ASN1_TYPE *);
 int (*ctrl)(EVP_CIPHER_CTX *, int type, int arg, void *ptr);
 void *app_data;
# 405 "/usr/include/openssl/evp.h" 3 4
typedef struct evp_cipher_info_st
 const EVP_CIPHER *cipher;
 unsigned char iv[16];
 } EVP_CIPHER_INFO;
 ENGINE *engine;
 int encrypt;
 int buf_len;
 unsigned char oiv[16];
 unsigned char buf[32];
 int num;
 void *app_data;
 int key_len;
 void *cipher_data;
 int final_used;
 int block_mask;
 unsigned char final[32];
typedef struct evp_Encode_Ctx_st
 int num;
 int length;
 unsigned char enc_data[80];
 int line_num;
 int expect_nl;
 } EVP_ENCODE_CTX;
typedef int (EVP_PBE_KEYGEN)(EVP_CIPHER_CTX *ctx, const char *pass, int passlen,
  ASN1_TYPE *param, const EVP_CIPHER *cipher,
                const EVP_MD *md, int en_de);
# 476 "/usr/include/openssl/evp.h" 3 4
int EVP_MD_type(const EVP_MD *md);
int EVP_MD_pkey_type(const EVP_MD *md);
int EVP_MD_size(const EVP_MD *md);
int EVP_MD_block_size(const EVP_MD *md);
unsigned long EVP_MD_flags(const EVP_MD *md);
const EVP_MD *EVP_MD_CTX_md(const EVP_MD_CTX *ctx);
int EVP_CIPHER_nid(const EVP_CIPHER *cipher);
int EVP_CIPHER_block_size(const EVP_CIPHER *cipher);
int EVP_CIPHER_key_length(const EVP_CIPHER *cipher);
int EVP_CIPHER_iv_length(const EVP_CIPHER *cipher);
unsigned long EVP_CIPHER_flags(const EVP_CIPHER *cipher);
const EVP_CIPHER * EVP_CIPHER_CTX_cipher(const EVP_CIPHER_CTX *ctx);
int EVP_CIPHER_CTX_nid(const EVP_CIPHER_CTX *ctx);
int EVP_CIPHER_CTX_block_size(const EVP_CIPHER_CTX *ctx);
int EVP_CIPHER_CTX_key_length(const EVP_CIPHER_CTX *ctx);
int EVP_CIPHER_CTX_iv_length(const EVP_CIPHER_CTX *ctx);
int EVP_CIPHER_CTX_copy(EVP_CIPHER_CTX *out, const EVP_CIPHER_CTX *in);
void * EVP_CIPHER_CTX_get_app_data(const EVP_CIPHER_CTX *ctx);
void EVP_CIPHER_CTX_set_app_data(EVP_CIPHER_CTX *ctx, void *data);
unsigned long EVP_CIPHER_CTX_flags(const EVP_CIPHER_CTX *ctx);
# 534 "/usr/include/openssl/evp.h" 3 4
int EVP_Cipher(EVP_CIPHER_CTX *c,
  unsigned char *out,
  unsigned int inl);
# 548 "/usr/include/openssl/evp.h" 3 4
void EVP_MD_CTX_init(EVP_MD_CTX *ctx);
int EVP_MD_CTX_cleanup(EVP_MD_CTX *ctx);
EVP_MD_CTX *EVP_MD_CTX_create(void);
void EVP_MD_CTX_destroy(EVP_MD_CTX *ctx);
int EVP_MD_CTX_copy_ex(EVP_MD_CTX *out,const EVP_MD_CTX *in);
void EVP_MD_CTX_set_flags(EVP_MD_CTX *ctx, int flags);
void EVP_MD_CTX_clear_flags(EVP_MD_CTX *ctx, int flags);
int EVP_MD_CTX_test_flags(const EVP_MD_CTX *ctx,int flags);
int EVP_DigestInit_ex(EVP_MD_CTX *ctx, const EVP_MD *type, ENGINE *impl);
int EVP_DigestUpdate(EVP_MD_CTX *ctx,const void *d,
    size_t cnt);
int EVP_DigestFinal_ex(EVP_MD_CTX *ctx,unsigned char *md,unsigned int *s);
int EVP_Digest(const void *data, size_t count,
  unsigned char *md, unsigned int *size, const EVP_MD *type, ENGINE *impl);
int EVP_MD_CTX_copy(EVP_MD_CTX *out,const EVP_MD_CTX *in);
int EVP_DigestInit(EVP_MD_CTX *ctx, const EVP_MD *type);
int EVP_DigestFinal(EVP_MD_CTX *ctx,unsigned char *md,unsigned int *s);
int EVP_read_pw_string(char *buf,int length,const char *prompt,int verify);
int EVP_read_pw_string_min(char *buf,int minlen,int maxlen,const char *prompt,int verify);
void EVP_set_pw_prompt(const char *prompt);
char * EVP_get_pw_prompt(void);
int EVP_BytesToKey(const EVP_CIPHER *type,const EVP_MD *md,
  const unsigned char *salt, const unsigned char *data,
  int datal, int count, unsigned char *key,unsigned char *iv);
void EVP_CIPHER_CTX_set_flags(EVP_CIPHER_CTX *ctx, int flags);
void EVP_CIPHER_CTX_clear_flags(EVP_CIPHER_CTX *ctx, int flags);
int EVP_CIPHER_CTX_test_flags(const EVP_CIPHER_CTX *ctx,int flags);
int EVP_EncryptInit(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher,
  const unsigned char *key, const unsigned char *iv);
int EVP_EncryptInit_ex(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher, ENGINE *impl,
int EVP_EncryptUpdate(EVP_CIPHER_CTX *ctx, unsigned char *out,
  int *outl, const unsigned char *in, int inl);
int EVP_EncryptFinal_ex(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl);
int EVP_EncryptFinal(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl);
int EVP_DecryptInit(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher,
int EVP_DecryptInit_ex(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher, ENGINE *impl,
int EVP_DecryptUpdate(EVP_CIPHER_CTX *ctx, unsigned char *out,
int EVP_DecryptFinal(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl);
int EVP_DecryptFinal_ex(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl);
int EVP_CipherInit(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher,
         const unsigned char *key,const unsigned char *iv,
         int enc);
int EVP_CipherInit_ex(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher, ENGINE *impl,
         int enc);
int EVP_CipherUpdate(EVP_CIPHER_CTX *ctx, unsigned char *out,
int EVP_CipherFinal(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl);
int EVP_CipherFinal_ex(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl);
int EVP_SignFinal(EVP_MD_CTX *ctx,unsigned char *md,unsigned int *s,
  EVP_PKEY *pkey);
int EVP_VerifyFinal(EVP_MD_CTX *ctx,const unsigned char *sigbuf,
  unsigned int siglen,EVP_PKEY *pkey);
int EVP_DigestSignInit(EVP_MD_CTX *ctx, EVP_PKEY_CTX **pctx,
   const EVP_MD *type, ENGINE *e, EVP_PKEY *pkey);
int EVP_DigestSignFinal(EVP_MD_CTX *ctx,
   unsigned char *sigret, size_t *siglen);
int EVP_DigestVerifyInit(EVP_MD_CTX *ctx, EVP_PKEY_CTX **pctx,
int EVP_DigestVerifyFinal(EVP_MD_CTX *ctx,
   unsigned char *sig, size_t siglen);
int EVP_OpenInit(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *type,
  const unsigned char *ek, int ekl, const unsigned char *iv,
  EVP_PKEY *priv);
int EVP_OpenFinal(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl);
int EVP_SealInit(EVP_CIPHER_CTX *ctx, const EVP_CIPHER *type,
   unsigned char **ek, int *ekl, unsigned char *iv,
  EVP_PKEY **pubk, int npubk);
int EVP_SealFinal(EVP_CIPHER_CTX *ctx,unsigned char *out,int *outl);
void EVP_EncodeInit(EVP_ENCODE_CTX *ctx);
void EVP_EncodeUpdate(EVP_ENCODE_CTX *ctx,unsigned char *out,int *outl,
  const unsigned char *in,int inl);
void EVP_EncodeFinal(EVP_ENCODE_CTX *ctx,unsigned char *out,int *outl);
int EVP_EncodeBlock(unsigned char *t, const unsigned char *f, int n);
void EVP_DecodeInit(EVP_ENCODE_CTX *ctx);
int EVP_DecodeUpdate(EVP_ENCODE_CTX *ctx,unsigned char *out,int *outl,
int EVP_DecodeFinal(EVP_ENCODE_CTX *ctx, unsigned
int EVP_DecodeBlock(unsigned char *t, const unsigned char *f, int n);
void EVP_CIPHER_CTX_init(EVP_CIPHER_CTX *a);
int EVP_CIPHER_CTX_cleanup(EVP_CIPHER_CTX *a);
EVP_CIPHER_CTX *EVP_CIPHER_CTX_new(void);
void EVP_CIPHER_CTX_free(EVP_CIPHER_CTX *a);
int EVP_CIPHER_CTX_set_key_length(EVP_CIPHER_CTX *x, int keylen);
int EVP_CIPHER_CTX_set_padding(EVP_CIPHER_CTX *c, int pad);
int EVP_CIPHER_CTX_ctrl(EVP_CIPHER_CTX *ctx, int type, int arg, void *ptr);
int EVP_CIPHER_CTX_rand_key(EVP_CIPHER_CTX *ctx, unsigned char *key);
BIO_METHOD *BIO_f_md(void);
BIO_METHOD *BIO_f_base64(void);
BIO_METHOD *BIO_f_cipher(void);
BIO_METHOD *BIO_f_reliable(void);
void BIO_set_cipher(BIO *b,const EVP_CIPHER *c,const unsigned char *k,
  const unsigned char *i, int enc);
const EVP_MD *EVP_md_null(void);
const EVP_MD *EVP_md4(void);
const EVP_MD *EVP_md5(void);
const EVP_MD *EVP_sha(void);
const EVP_MD *EVP_sha1(void);
const EVP_MD *EVP_dss(void);
const EVP_MD *EVP_dss1(void);
const EVP_MD *EVP_ecdsa(void);
const EVP_MD *EVP_sha224(void);
const EVP_MD *EVP_sha256(void);
const EVP_MD *EVP_sha384(void);
const EVP_MD *EVP_sha512(void);
const EVP_MD *EVP_mdc2(void);
const EVP_MD *EVP_ripemd160(void);
const EVP_MD *EVP_whirlpool(void);
const EVP_CIPHER *EVP_enc_null(void);
const EVP_CIPHER *EVP_des_ecb(void);
const EVP_CIPHER *EVP_des_ede(void);
const EVP_CIPHER *EVP_des_ede3(void);
const EVP_CIPHER *EVP_des_ede_ecb(void);
const EVP_CIPHER *EVP_des_ede3_ecb(void);
const EVP_CIPHER *EVP_des_cfb64(void);
const EVP_CIPHER *EVP_des_cfb1(void);
const EVP_CIPHER *EVP_des_cfb8(void);
const EVP_CIPHER *EVP_des_ede_cfb64(void);
const EVP_CIPHER *EVP_des_ede3_cfb64(void);
const EVP_CIPHER *EVP_des_ede3_cfb1(void);
const EVP_CIPHER *EVP_des_ede3_cfb8(void);
const EVP_CIPHER *EVP_des_ofb(void);
const EVP_CIPHER *EVP_des_ede_ofb(void);
const EVP_CIPHER *EVP_des_ede3_ofb(void);
const EVP_CIPHER *EVP_des_cbc(void);
const EVP_CIPHER *EVP_des_ede_cbc(void);
const EVP_CIPHER *EVP_des_ede3_cbc(void);
const EVP_CIPHER *EVP_desx_cbc(void);
# 739 "/usr/include/openssl/evp.h" 3 4
const EVP_CIPHER *EVP_rc4(void);
const EVP_CIPHER *EVP_rc4_40(void);
const EVP_CIPHER *EVP_rc4_hmac_md5(void);
const EVP_CIPHER *EVP_idea_ecb(void);
const EVP_CIPHER *EVP_idea_cfb64(void);
const EVP_CIPHER *EVP_idea_ofb(void);
const EVP_CIPHER *EVP_idea_cbc(void);
const EVP_CIPHER *EVP_rc2_ecb(void);
const EVP_CIPHER *EVP_rc2_cbc(void);
const EVP_CIPHER *EVP_rc2_40_cbc(void);
const EVP_CIPHER *EVP_rc2_64_cbc(void);
const EVP_CIPHER *EVP_rc2_cfb64(void);
const EVP_CIPHER *EVP_rc2_ofb(void);
const EVP_CIPHER *EVP_bf_ecb(void);
const EVP_CIPHER *EVP_bf_cbc(void);
const EVP_CIPHER *EVP_bf_cfb64(void);
const EVP_CIPHER *EVP_bf_ofb(void);
const EVP_CIPHER *EVP_cast5_ecb(void);
const EVP_CIPHER *EVP_cast5_cbc(void);
const EVP_CIPHER *EVP_cast5_cfb64(void);
const EVP_CIPHER *EVP_cast5_ofb(void);
# 783 "/usr/include/openssl/evp.h" 3 4
const EVP_CIPHER *EVP_aes_128_ecb(void);
const EVP_CIPHER *EVP_aes_128_cbc(void);
const EVP_CIPHER *EVP_aes_128_cfb1(void);
const EVP_CIPHER *EVP_aes_128_cfb8(void);
const EVP_CIPHER *EVP_aes_128_cfb128(void);
const EVP_CIPHER *EVP_aes_128_ofb(void);
const EVP_CIPHER *EVP_aes_128_ctr(void);
const EVP_CIPHER *EVP_aes_128_ccm(void);
const EVP_CIPHER *EVP_aes_128_gcm(void);
const EVP_CIPHER *EVP_aes_128_xts(void);
const EVP_CIPHER *EVP_aes_192_ecb(void);
const EVP_CIPHER *EVP_aes_192_cbc(void);
const EVP_CIPHER *EVP_aes_192_cfb1(void);
const EVP_CIPHER *EVP_aes_192_cfb8(void);
const EVP_CIPHER *EVP_aes_192_cfb128(void);
const EVP_CIPHER *EVP_aes_192_ofb(void);
const EVP_CIPHER *EVP_aes_192_ctr(void);
const EVP_CIPHER *EVP_aes_192_ccm(void);
const EVP_CIPHER *EVP_aes_192_gcm(void);
const EVP_CIPHER *EVP_aes_256_ecb(void);
const EVP_CIPHER *EVP_aes_256_cbc(void);
const EVP_CIPHER *EVP_aes_256_cfb1(void);
const EVP_CIPHER *EVP_aes_256_cfb8(void);
const EVP_CIPHER *EVP_aes_256_cfb128(void);
const EVP_CIPHER *EVP_aes_256_ofb(void);
const EVP_CIPHER *EVP_aes_256_ctr(void);
const EVP_CIPHER *EVP_aes_256_ccm(void);
const EVP_CIPHER *EVP_aes_256_gcm(void);
const EVP_CIPHER *EVP_aes_256_xts(void);
const EVP_CIPHER *EVP_aes_128_cbc_hmac_sha1(void);
const EVP_CIPHER *EVP_aes_256_cbc_hmac_sha1(void);
const EVP_CIPHER *EVP_camellia_128_ecb(void);
const EVP_CIPHER *EVP_camellia_128_cbc(void);
const EVP_CIPHER *EVP_camellia_128_cfb1(void);
const EVP_CIPHER *EVP_camellia_128_cfb8(void);
const EVP_CIPHER *EVP_camellia_128_cfb128(void);
const EVP_CIPHER *EVP_camellia_128_ofb(void);
const EVP_CIPHER *EVP_camellia_192_ecb(void);
const EVP_CIPHER *EVP_camellia_192_cbc(void);
const EVP_CIPHER *EVP_camellia_192_cfb1(void);
const EVP_CIPHER *EVP_camellia_192_cfb8(void);
const EVP_CIPHER *EVP_camellia_192_cfb128(void);
const EVP_CIPHER *EVP_camellia_192_ofb(void);
const EVP_CIPHER *EVP_camellia_256_ecb(void);
const EVP_CIPHER *EVP_camellia_256_cbc(void);
const EVP_CIPHER *EVP_camellia_256_cfb1(void);
const EVP_CIPHER *EVP_camellia_256_cfb8(void);
const EVP_CIPHER *EVP_camellia_256_cfb128(void);
const EVP_CIPHER *EVP_camellia_256_ofb(void);
const EVP_CIPHER *EVP_seed_ecb(void);
const EVP_CIPHER *EVP_seed_cbc(void);
const EVP_CIPHER *EVP_seed_cfb128(void);
const EVP_CIPHER *EVP_seed_ofb(void);
void OPENSSL_add_all_algorithms_noconf(void);
void OPENSSL_add_all_algorithms_conf(void);
# 863 "/usr/include/openssl/evp.h" 3 4
void OpenSSL_add_all_ciphers(void);
void OpenSSL_add_all_digests(void);
int EVP_add_cipher(const EVP_CIPHER *cipher);
int EVP_add_digest(const EVP_MD *digest);
const EVP_CIPHER *EVP_get_cipherbyname(const char *name);
const EVP_MD *EVP_get_digestbyname(const char *name);
void EVP_cleanup(void);
void EVP_CIPHER_do_all(void (*fn)(const EVP_CIPHER *ciph,
  const char *from, const char *to, void *x), void *arg);
void EVP_CIPHER_do_all_sorted(void (*fn)(const EVP_CIPHER *ciph,
void EVP_MD_do_all(void (*fn)(const EVP_MD *ciph,
void EVP_MD_do_all_sorted(void (*fn)(const EVP_MD *ciph,
int EVP_PKEY_decrypt_old(unsigned char *dec_key,
   const unsigned char *enc_key,int enc_key_len,
   EVP_PKEY *private_key);
int EVP_PKEY_encrypt_old(unsigned char *enc_key,
   const unsigned char *key,int key_len,
   EVP_PKEY *pub_key);
int EVP_PKEY_type(int type);
int EVP_PKEY_id(const EVP_PKEY *pkey);
int EVP_PKEY_base_id(const EVP_PKEY *pkey);
int EVP_PKEY_bits(EVP_PKEY *pkey);
int EVP_PKEY_size(EVP_PKEY *pkey);
int EVP_PKEY_set_type(EVP_PKEY *pkey,int type);
int EVP_PKEY_set_type_str(EVP_PKEY *pkey, const char *str, int len);
int EVP_PKEY_assign(EVP_PKEY *pkey,int type,void *key);
void * EVP_PKEY_get0(EVP_PKEY *pkey);
struct rsa_st;
int EVP_PKEY_set1_RSA(EVP_PKEY *pkey,struct rsa_st *key);
struct rsa_st *EVP_PKEY_get1_RSA(EVP_PKEY *pkey);
struct dsa_st;
int EVP_PKEY_set1_DSA(EVP_PKEY *pkey,struct dsa_st *key);
struct dsa_st *EVP_PKEY_get1_DSA(EVP_PKEY *pkey);
struct dh_st;
int EVP_PKEY_set1_DH(EVP_PKEY *pkey,struct dh_st *key);
struct dh_st *EVP_PKEY_get1_DH(EVP_PKEY *pkey);
struct ec_key_st;
int EVP_PKEY_set1_EC_KEY(EVP_PKEY *pkey,struct ec_key_st *key);
struct ec_key_st *EVP_PKEY_get1_EC_KEY(EVP_PKEY *pkey);
EVP_PKEY * EVP_PKEY_new(void);
void EVP_PKEY_free(EVP_PKEY *pkey);
EVP_PKEY * d2i_PublicKey(int type,EVP_PKEY **a, const unsigned char **pp,
   long length);
int i2d_PublicKey(EVP_PKEY *a, unsigned char **pp);
EVP_PKEY * d2i_PrivateKey(int type,EVP_PKEY **a, const unsigned char **pp,
   long length);
EVP_PKEY * d2i_AutoPrivateKey(EVP_PKEY **a, const unsigned char **pp,
   long length);
int i2d_PrivateKey(EVP_PKEY *a, unsigned char **pp);
int EVP_PKEY_copy_parameters(EVP_PKEY *to, const EVP_PKEY *from);
int EVP_PKEY_missing_parameters(const EVP_PKEY *pkey);
int EVP_PKEY_save_parameters(EVP_PKEY *pkey,int mode);
int EVP_PKEY_cmp_parameters(const EVP_PKEY *a, const EVP_PKEY *b);
int EVP_PKEY_cmp(const EVP_PKEY *a, const EVP_PKEY *b);
int EVP_PKEY_print_public(BIO *out, const EVP_PKEY *pkey,
    int indent, ASN1_PCTX *pctx);
int EVP_PKEY_print_private(BIO *out, const EVP_PKEY *pkey,
int EVP_PKEY_print_params(BIO *out, const EVP_PKEY *pkey,
int EVP_PKEY_get_default_digest_nid(EVP_PKEY *pkey, int *pnid);
int EVP_CIPHER_type(const EVP_CIPHER *ctx);
int EVP_CIPHER_param_to_asn1(EVP_CIPHER_CTX *c, ASN1_TYPE *type);
int EVP_CIPHER_asn1_to_param(EVP_CIPHER_CTX *c, ASN1_TYPE *type);
int EVP_CIPHER_set_asn1_iv(EVP_CIPHER_CTX *c,ASN1_TYPE *type);
int EVP_CIPHER_get_asn1_iv(EVP_CIPHER_CTX *c,ASN1_TYPE *type);
int PKCS5_PBE_keyivgen(EVP_CIPHER_CTX *ctx, const char *pass, int passlen,
    ASN1_TYPE *param, const EVP_CIPHER *cipher, const EVP_MD *md,
    int en_de);
int PKCS5_PBKDF2_HMAC_SHA1(const char *pass, int passlen,
      const unsigned char *salt, int saltlen, int iter,
      int keylen, unsigned char *out);
int PKCS5_PBKDF2_HMAC(const char *pass, int passlen,
      const EVP_MD *digest,
int PKCS5_v2_PBE_keyivgen(EVP_CIPHER_CTX *ctx, const char *pass, int passlen,
    int en_de);
void PKCS5_PBE_add(void);
int EVP_PBE_CipherInit (ASN1_OBJECT *pbe_obj, const char *pass, int passlen,
      ASN1_TYPE *param, EVP_CIPHER_CTX *ctx, int en_de);
# 989 "/usr/include/openssl/evp.h" 3 4
int EVP_PBE_alg_add_type(int pbe_type, int pbe_nid, int cipher_nid, int md_nid,
      EVP_PBE_KEYGEN *keygen);
int EVP_PBE_alg_add(int nid, const EVP_CIPHER *cipher, const EVP_MD *md,
int EVP_PBE_find(int type, int pbe_nid,
   int *pcnid, int *pmnid, EVP_PBE_KEYGEN **pkeygen);
void EVP_PBE_cleanup(void);
# 1007 "/usr/include/openssl/evp.h" 3 4
int EVP_PKEY_asn1_get_count(void);
const EVP_PKEY_ASN1_METHOD *EVP_PKEY_asn1_get0(int idx);
const EVP_PKEY_ASN1_METHOD *EVP_PKEY_asn1_find(ENGINE **pe, int type);
const EVP_PKEY_ASN1_METHOD *EVP_PKEY_asn1_find_str(ENGINE **pe,
int EVP_PKEY_asn1_add0(const EVP_PKEY_ASN1_METHOD *ameth);
int EVP_PKEY_asn1_add_alias(int to, int from);
int EVP_PKEY_asn1_get0_info(int *ppkey_id, int *pkey_base_id, int *ppkey_flags,
    const char **pinfo, const char **ppem_str,
const EVP_PKEY_ASN1_METHOD* EVP_PKEY_get0_asn1(EVP_PKEY *pkey);
EVP_PKEY_ASN1_METHOD* EVP_PKEY_asn1_new(int id, int flags,
     const char *pem_str, const char *info);
void EVP_PKEY_asn1_copy(EVP_PKEY_ASN1_METHOD *dst,
   const EVP_PKEY_ASN1_METHOD *src);
void EVP_PKEY_asn1_free(EVP_PKEY_ASN1_METHOD *ameth);
void EVP_PKEY_asn1_set_public(EVP_PKEY_ASN1_METHOD *ameth,
  int (*pub_decode)(EVP_PKEY *pk, X509_PUBKEY *pub),
  int (*pub_encode)(X509_PUBKEY *pub, const EVP_PKEY *pk),
  int (*pub_cmp)(const EVP_PKEY *a, const EVP_PKEY *b),
  int (*pub_print)(BIO *out, const EVP_PKEY *pkey, int indent,
       ASN1_PCTX *pctx),
  int (*pkey_size)(const EVP_PKEY *pk),
  int (*pkey_bits)(const EVP_PKEY *pk));
void EVP_PKEY_asn1_set_private(EVP_PKEY_ASN1_METHOD *ameth,
  int (*priv_decode)(EVP_PKEY *pk, PKCS8_PRIV_KEY_INFO *p8inf),
  int (*priv_encode)(PKCS8_PRIV_KEY_INFO *p8, const EVP_PKEY *pk),
  int (*priv_print)(BIO *out, const EVP_PKEY *pkey, int indent,
       ASN1_PCTX *pctx));
void EVP_PKEY_asn1_set_param(EVP_PKEY_ASN1_METHOD *ameth,
  int (*param_decode)(EVP_PKEY *pkey,
    const unsigned char **pder, int derlen),
  int (*param_encode)(const EVP_PKEY *pkey, unsigned char **pder),
  int (*param_missing)(const EVP_PKEY *pk),
  int (*param_copy)(EVP_PKEY *to, const EVP_PKEY *from),
  int (*param_cmp)(const EVP_PKEY *a, const EVP_PKEY *b),
  int (*param_print)(BIO *out, const EVP_PKEY *pkey, int indent,
       ASN1_PCTX *pctx));
void EVP_PKEY_asn1_set_free(EVP_PKEY_ASN1_METHOD *ameth,
  void (*pkey_free)(EVP_PKEY *pkey));
void EVP_PKEY_asn1_set_ctrl(EVP_PKEY_ASN1_METHOD *ameth,
  int (*pkey_ctrl)(EVP_PKEY *pkey, int op,
       long arg1, void *arg2));
# 1113 "/usr/include/openssl/evp.h" 3 4
const EVP_PKEY_METHOD *EVP_PKEY_meth_find(int type);
EVP_PKEY_METHOD* EVP_PKEY_meth_new(int id, int flags);
void EVP_PKEY_meth_get0_info(int *ppkey_id, int *pflags,
    const EVP_PKEY_METHOD *meth);
void EVP_PKEY_meth_copy(EVP_PKEY_METHOD *dst, const EVP_PKEY_METHOD *src);
void EVP_PKEY_meth_free(EVP_PKEY_METHOD *pmeth);
int EVP_PKEY_meth_add0(const EVP_PKEY_METHOD *pmeth);
EVP_PKEY_CTX *EVP_PKEY_CTX_new(EVP_PKEY *pkey, ENGINE *e);
EVP_PKEY_CTX *EVP_PKEY_CTX_new_id(int id, ENGINE *e);
EVP_PKEY_CTX *EVP_PKEY_CTX_dup(EVP_PKEY_CTX *ctx);
void EVP_PKEY_CTX_free(EVP_PKEY_CTX *ctx);
int EVP_PKEY_CTX_ctrl(EVP_PKEY_CTX *ctx, int keytype, int optype,
int EVP_PKEY_CTX_ctrl_str(EVP_PKEY_CTX *ctx, const char *type,
      const char *value);
int EVP_PKEY_CTX_get_operation(EVP_PKEY_CTX *ctx);
void EVP_PKEY_CTX_set0_keygen_info(EVP_PKEY_CTX *ctx, int *dat, int datlen);
EVP_PKEY *EVP_PKEY_new_mac_key(int type, ENGINE *e,
    const unsigned char *key, int keylen);
void EVP_PKEY_CTX_set_data(EVP_PKEY_CTX *ctx, void *data);
void *EVP_PKEY_CTX_get_data(EVP_PKEY_CTX *ctx);
EVP_PKEY *EVP_PKEY_CTX_get0_pkey(EVP_PKEY_CTX *ctx);
EVP_PKEY *EVP_PKEY_CTX_get0_peerkey(EVP_PKEY_CTX *ctx);
void EVP_PKEY_CTX_set_app_data(EVP_PKEY_CTX *ctx, void *data);
void *EVP_PKEY_CTX_get_app_data(EVP_PKEY_CTX *ctx);
int EVP_PKEY_sign_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_sign(EVP_PKEY_CTX *ctx,
   unsigned char *sig, size_t *siglen,
   const unsigned char *tbs, size_t tbslen);
int EVP_PKEY_verify_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_verify(EVP_PKEY_CTX *ctx,
   const unsigned char *sig, size_t siglen,
int EVP_PKEY_verify_recover_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_verify_recover(EVP_PKEY_CTX *ctx,
   unsigned char *rout, size_t *routlen,
   const unsigned char *sig, size_t siglen);
int EVP_PKEY_encrypt_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_encrypt(EVP_PKEY_CTX *ctx,
   unsigned char *out, size_t *outlen,
   const unsigned char *in, size_t inlen);
int EVP_PKEY_decrypt_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_decrypt(EVP_PKEY_CTX *ctx,
int EVP_PKEY_derive_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_derive_set_peer(EVP_PKEY_CTX *ctx, EVP_PKEY *peer);
int EVP_PKEY_derive(EVP_PKEY_CTX *ctx, unsigned char *key, size_t *keylen);
typedef int EVP_PKEY_gen_cb(EVP_PKEY_CTX *ctx);
int EVP_PKEY_paramgen_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_paramgen(EVP_PKEY_CTX *ctx, EVP_PKEY **ppkey);
int EVP_PKEY_keygen_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_keygen(EVP_PKEY_CTX *ctx, EVP_PKEY **ppkey);
void EVP_PKEY_CTX_set_cb(EVP_PKEY_CTX *ctx, EVP_PKEY_gen_cb *cb);
EVP_PKEY_gen_cb *EVP_PKEY_CTX_get_cb(EVP_PKEY_CTX *ctx);
int EVP_PKEY_CTX_get_keygen_info(EVP_PKEY_CTX *ctx, int idx);
void EVP_PKEY_meth_set_init(EVP_PKEY_METHOD *pmeth,
 int (*init)(EVP_PKEY_CTX *ctx));
void EVP_PKEY_meth_set_copy(EVP_PKEY_METHOD *pmeth,
 int (*copy)(EVP_PKEY_CTX *dst, EVP_PKEY_CTX *src));
void EVP_PKEY_meth_set_cleanup(EVP_PKEY_METHOD *pmeth,
 void (*cleanup)(EVP_PKEY_CTX *ctx));
void EVP_PKEY_meth_set_paramgen(EVP_PKEY_METHOD *pmeth,
 int (*paramgen_init)(EVP_PKEY_CTX *ctx),
 int (*paramgen)(EVP_PKEY_CTX *ctx, EVP_PKEY *pkey));
void EVP_PKEY_meth_set_keygen(EVP_PKEY_METHOD *pmeth,
 int (*keygen_init)(EVP_PKEY_CTX *ctx),
 int (*keygen)(EVP_PKEY_CTX *ctx, EVP_PKEY *pkey));
void EVP_PKEY_meth_set_sign(EVP_PKEY_METHOD *pmeth,
 int (*sign_init)(EVP_PKEY_CTX *ctx),
 int (*sign)(EVP_PKEY_CTX *ctx, unsigned char *sig, size_t *siglen,
     const unsigned char *tbs, size_t tbslen));
void EVP_PKEY_meth_set_verify(EVP_PKEY_METHOD *pmeth,
 int (*verify_init)(EVP_PKEY_CTX *ctx),
 int (*verify)(EVP_PKEY_CTX *ctx, const unsigned char *sig, size_t siglen,
void EVP_PKEY_meth_set_verify_recover(EVP_PKEY_METHOD *pmeth,
 int (*verify_recover_init)(EVP_PKEY_CTX *ctx),
 int (*verify_recover)(EVP_PKEY_CTX *ctx,
void EVP_PKEY_meth_set_signctx(EVP_PKEY_METHOD *pmeth,
 int (*signctx_init)(EVP_PKEY_CTX *ctx, EVP_MD_CTX *mctx),
 int (*signctx)(EVP_PKEY_CTX *ctx, unsigned char *sig, size_t *siglen,
     EVP_MD_CTX *mctx));
void EVP_PKEY_meth_set_verifyctx(EVP_PKEY_METHOD *pmeth,
 int (*verifyctx_init)(EVP_PKEY_CTX *ctx, EVP_MD_CTX *mctx),
 int (*verifyctx)(EVP_PKEY_CTX *ctx, const unsigned char *sig,int siglen,
     EVP_MD_CTX *mctx));
void EVP_PKEY_meth_set_encrypt(EVP_PKEY_METHOD *pmeth,
 int (*encrypt_init)(EVP_PKEY_CTX *ctx),
 int (*encryptfn)(EVP_PKEY_CTX *ctx, unsigned char *out, size_t *outlen,
     const unsigned char *in, size_t inlen));
void EVP_PKEY_meth_set_decrypt(EVP_PKEY_METHOD *pmeth,
 int (*decrypt_init)(EVP_PKEY_CTX *ctx),
 int (*decrypt)(EVP_PKEY_CTX *ctx, unsigned char *out, size_t *outlen,
void EVP_PKEY_meth_set_derive(EVP_PKEY_METHOD *pmeth,
 int (*derive_init)(EVP_PKEY_CTX *ctx),
 int (*derive)(EVP_PKEY_CTX *ctx, unsigned char *key, size_t *keylen));
void EVP_PKEY_meth_set_ctrl(EVP_PKEY_METHOD *pmeth,
 int (*ctrl)(EVP_PKEY_CTX *ctx, int type, int p1, void *p2),
 int (*ctrl_str)(EVP_PKEY_CTX *ctx,
     const char *type, const char *value));
void EVP_add_alg_module(void);
void ERR_load_EVP_strings(void);
# 74 "/usr/include/openssl/x509.h" 2 3 4
# 83 "/usr/include/openssl/x509.h" 3 4
# 1 "/usr/include/openssl/ec.h" 1 3 4
# 79 "/usr/include/openssl/ec.h" 3 4
# 1 "/usr/include/openssl/opensslconf.h" 1 3 4
# 80 "/usr/include/openssl/ec.h" 2 3 4
# 106 "/usr/include/openssl/ec.h" 3 4
typedef enum {
 POINT_CONVERSION_COMPRESSED = 2,
 POINT_CONVERSION_UNCOMPRESSED = 4,
 POINT_CONVERSION_HYBRID = 6
} point_conversion_form_t;
typedef struct ec_method_st EC_METHOD;
typedef struct ec_group_st
# 129 "/usr/include/openssl/ec.h" 3 4
 EC_GROUP;
typedef struct ec_point_st EC_POINT;
# 142 "/usr/include/openssl/ec.h" 3 4
const EC_METHOD *EC_GFp_simple_method(void);
const EC_METHOD *EC_GFp_mont_method(void);
const EC_METHOD *EC_GFp_nist_method(void);
const EC_METHOD *EC_GFp_nistp224_method(void);
const EC_METHOD *EC_GFp_nistp256_method(void);
const EC_METHOD *EC_GFp_nistp521_method(void);
# 179 "/usr/include/openssl/ec.h" 3 4
const EC_METHOD *EC_GF2m_simple_method(void);
# 192 "/usr/include/openssl/ec.h" 3 4
EC_GROUP *EC_GROUP_new(const EC_METHOD *meth);
void EC_GROUP_free(EC_GROUP *group);
void EC_GROUP_clear_free(EC_GROUP *group);
int EC_GROUP_copy(EC_GROUP *dst, const EC_GROUP *src);
EC_GROUP *EC_GROUP_dup(const EC_GROUP *src);
const EC_METHOD *EC_GROUP_method_of(const EC_GROUP *group);
int EC_METHOD_get_field_type(const EC_METHOD *meth);
# 238 "/usr/include/openssl/ec.h" 3 4
int EC_GROUP_set_generator(EC_GROUP *group, const EC_POINT *generator, const BIGNUM *order, const BIGNUM *cofactor);
const EC_POINT *EC_GROUP_get0_generator(const EC_GROUP *group);
int EC_GROUP_get_order(const EC_GROUP *group, BIGNUM *order, BN_CTX *ctx);
int EC_GROUP_get_cofactor(const EC_GROUP *group, BIGNUM *cofactor, BN_CTX *ctx);
void EC_GROUP_set_curve_name(EC_GROUP *group, int nid);
int EC_GROUP_get_curve_name(const EC_GROUP *group);
void EC_GROUP_set_asn1_flag(EC_GROUP *group, int flag);
int EC_GROUP_get_asn1_flag(const EC_GROUP *group);
void EC_GROUP_set_point_conversion_form(EC_GROUP *group, point_conversion_form_t form);
point_conversion_form_t EC_GROUP_get_point_conversion_form(const EC_GROUP *);
unsigned char *EC_GROUP_get0_seed(const EC_GROUP *x);
size_t EC_GROUP_get_seed_len(const EC_GROUP *);
size_t EC_GROUP_set_seed(EC_GROUP *, const unsigned char *, size_t len);
# 292 "/usr/include/openssl/ec.h" 3 4
int EC_GROUP_set_curve_GFp(EC_GROUP *group, const BIGNUM *p, const BIGNUM *a, const BIGNUM *b, BN_CTX *ctx);
# 302 "/usr/include/openssl/ec.h" 3 4
int EC_GROUP_get_curve_GFp(const EC_GROUP *group, BIGNUM *p, BIGNUM *a, BIGNUM *b, BN_CTX *ctx);
# 313 "/usr/include/openssl/ec.h" 3 4
int EC_GROUP_set_curve_GF2m(EC_GROUP *group, const BIGNUM *p, const BIGNUM *a, const BIGNUM *b, BN_CTX *ctx);
# 323 "/usr/include/openssl/ec.h" 3 4
int EC_GROUP_get_curve_GF2m(const EC_GROUP *group, BIGNUM *p, BIGNUM *a, BIGNUM *b, BN_CTX *ctx);
int EC_GROUP_get_degree(const EC_GROUP *group);
int EC_GROUP_check(const EC_GROUP *group, BN_CTX *ctx);
int EC_GROUP_check_discriminant(const EC_GROUP *group, BN_CTX *ctx);
int EC_GROUP_cmp(const EC_GROUP *a, const EC_GROUP *b, BN_CTX *ctx);
# 364 "/usr/include/openssl/ec.h" 3 4
EC_GROUP *EC_GROUP_new_curve_GFp(const BIGNUM *p, const BIGNUM *a, const BIGNUM *b, BN_CTX *ctx);
# 374 "/usr/include/openssl/ec.h" 3 4
EC_GROUP *EC_GROUP_new_curve_GF2m(const BIGNUM *p, const BIGNUM *a, const BIGNUM *b, BN_CTX *ctx);
EC_GROUP *EC_GROUP_new_by_curve_name(int nid);
typedef struct {
 int nid;
 const char *comment;
 } EC_builtin_curve;
size_t EC_get_builtin_curves(EC_builtin_curve *r, size_t nitems);
# 408 "/usr/include/openssl/ec.h" 3 4
EC_POINT *EC_POINT_new(const EC_GROUP *group);
void EC_POINT_free(EC_POINT *point);
void EC_POINT_clear_free(EC_POINT *point);
int EC_POINT_copy(EC_POINT *dst, const EC_POINT *src);
EC_POINT *EC_POINT_dup(const EC_POINT *src, const EC_GROUP *group);
const EC_METHOD *EC_POINT_method_of(const EC_POINT *point);
int EC_POINT_set_to_infinity(const EC_GROUP *group, EC_POINT *point);
# 457 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_set_Jprojective_coordinates_GFp(const EC_GROUP *group, EC_POINT *p,
 const BIGNUM *x, const BIGNUM *y, const BIGNUM *z, BN_CTX *ctx);
# 469 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_get_Jprojective_coordinates_GFp(const EC_GROUP *group,
 const EC_POINT *p, BIGNUM *x, BIGNUM *y, BIGNUM *z, BN_CTX *ctx);
# 480 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_set_affine_coordinates_GFp(const EC_GROUP *group, EC_POINT *p,
 const BIGNUM *x, const BIGNUM *y, BN_CTX *ctx);
# 491 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_get_affine_coordinates_GFp(const EC_GROUP *group,
 const EC_POINT *p, BIGNUM *x, BIGNUM *y, BN_CTX *ctx);
# 502 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_set_compressed_coordinates_GFp(const EC_GROUP *group, EC_POINT *p,
 const BIGNUM *x, int y_bit, BN_CTX *ctx);
# 513 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_set_affine_coordinates_GF2m(const EC_GROUP *group, EC_POINT *p,
# 524 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_get_affine_coordinates_GF2m(const EC_GROUP *group,
# 535 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_set_compressed_coordinates_GF2m(const EC_GROUP *group, EC_POINT *p,
# 548 "/usr/include/openssl/ec.h" 3 4
size_t EC_POINT_point2oct(const EC_GROUP *group, const EC_POINT *p,
 point_conversion_form_t form,
        unsigned char *buf, size_t len, BN_CTX *ctx);
# 560 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_oct2point(const EC_GROUP *group, EC_POINT *p,
        const unsigned char *buf, size_t len, BN_CTX *ctx);
BIGNUM *EC_POINT_point2bn(const EC_GROUP *, const EC_POINT *,
 point_conversion_form_t form, BIGNUM *, BN_CTX *);
EC_POINT *EC_POINT_bn2point(const EC_GROUP *, const BIGNUM *,
 EC_POINT *, BN_CTX *);
char *EC_POINT_point2hex(const EC_GROUP *, const EC_POINT *,
 point_conversion_form_t form, BN_CTX *);
EC_POINT *EC_POINT_hex2point(const EC_GROUP *, const char *,
# 586 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_add(const EC_GROUP *group, EC_POINT *r, const EC_POINT *a, const EC_POINT *b, BN_CTX *ctx);
# 595 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_dbl(const EC_GROUP *group, EC_POINT *r, const EC_POINT *a, BN_CTX *ctx);
int EC_POINT_invert(const EC_GROUP *group, EC_POINT *a, BN_CTX *ctx);
int EC_POINT_is_at_infinity(const EC_GROUP *group, const EC_POINT *p);
int EC_POINT_is_on_curve(const EC_GROUP *group, const EC_POINT *point, BN_CTX *ctx);
# 627 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_cmp(const EC_GROUP *group, const EC_POINT *a, const EC_POINT *b, BN_CTX *ctx);
int EC_POINT_make_affine(const EC_GROUP *group, EC_POINT *point, BN_CTX *ctx);
int EC_POINTs_make_affine(const EC_GROUP *group, size_t num, EC_POINT *points[], BN_CTX *ctx);
# 642 "/usr/include/openssl/ec.h" 3 4
int EC_POINTs_mul(const EC_GROUP *group, EC_POINT *r, const BIGNUM *n, size_t num, const EC_POINT *p[], const BIGNUM *m[], BN_CTX *ctx);
# 653 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_mul(const EC_GROUP *group, EC_POINT *r, const BIGNUM *n, const EC_POINT *q, const BIGNUM *m, BN_CTX *ctx);
int EC_GROUP_precompute_mult(EC_GROUP *group, BN_CTX *ctx);
int EC_GROUP_have_precompute_mult(const EC_GROUP *group);
# 675 "/usr/include/openssl/ec.h" 3 4
int EC_GROUP_get_basis_type(const EC_GROUP *);
int EC_GROUP_get_trinomial_basis(const EC_GROUP *, unsigned int *k);
int EC_GROUP_get_pentanomial_basis(const EC_GROUP *, unsigned int *k1,
 unsigned int *k2, unsigned int *k3);
typedef struct ecpk_parameters_st ECPKPARAMETERS;
EC_GROUP *d2i_ECPKParameters(EC_GROUP **, const unsigned char **in, long len);
int i2d_ECPKParameters(const EC_GROUP *, unsigned char **out);
# 697 "/usr/include/openssl/ec.h" 3 4
int ECPKParameters_print(BIO *bp, const EC_GROUP *x, int off);
int ECPKParameters_print_fp(FILE *fp, const EC_GROUP *x, int off);
typedef struct ec_key_st EC_KEY;
# 721 "/usr/include/openssl/ec.h" 3 4
EC_KEY *EC_KEY_new(void);
int EC_KEY_get_flags(const EC_KEY *key);
void EC_KEY_set_flags(EC_KEY *key, int flags);
void EC_KEY_clear_flags(EC_KEY *key, int flags);
EC_KEY *EC_KEY_new_by_curve_name(int nid);
void EC_KEY_free(EC_KEY *key);
EC_KEY *EC_KEY_copy(EC_KEY *dst, const EC_KEY *src);
EC_KEY *EC_KEY_dup(const EC_KEY *src);
int EC_KEY_up_ref(EC_KEY *key);
const EC_GROUP *EC_KEY_get0_group(const EC_KEY *key);
int EC_KEY_set_group(EC_KEY *key, const EC_GROUP *group);
const BIGNUM *EC_KEY_get0_private_key(const EC_KEY *key);
int EC_KEY_set_private_key(EC_KEY *key, const BIGNUM *prv);
const EC_POINT *EC_KEY_get0_public_key(const EC_KEY *key);
int EC_KEY_set_public_key(EC_KEY *key, const EC_POINT *pub);
unsigned EC_KEY_get_enc_flags(const EC_KEY *key);
void EC_KEY_set_enc_flags(EC_KEY *eckey, unsigned int flags);
point_conversion_form_t EC_KEY_get_conv_form(const EC_KEY *key);
void EC_KEY_set_conv_form(EC_KEY *eckey, point_conversion_form_t cform);
void *EC_KEY_get_key_method_data(EC_KEY *key,
 void *(*dup_func)(void *), void (*free_func)(void *), void (*clear_free_func)(void *));
# 817 "/usr/include/openssl/ec.h" 3 4
void *EC_KEY_insert_key_method_data(EC_KEY *key, void *data,
void EC_KEY_set_asn1_flag(EC_KEY *eckey, int asn1_flag);
int EC_KEY_precompute_mult(EC_KEY *key, BN_CTX *ctx);
int EC_KEY_generate_key(EC_KEY *key);
int EC_KEY_check_key(const EC_KEY *key);
# 849 "/usr/include/openssl/ec.h" 3 4
int EC_KEY_set_public_key_affine_coordinates(EC_KEY *key, BIGNUM *x, BIGNUM *y);
# 862 "/usr/include/openssl/ec.h" 3 4
EC_KEY *d2i_ECPrivateKey(EC_KEY **key, const unsigned char **in, long len);
int i2d_ECPrivateKey(EC_KEY *key, unsigned char **out);
# 884 "/usr/include/openssl/ec.h" 3 4
EC_KEY *d2i_ECParameters(EC_KEY **key, const unsigned char **in, long len);
int i2d_ECParameters(EC_KEY *key, unsigned char **out);
# 907 "/usr/include/openssl/ec.h" 3 4
EC_KEY *o2i_ECPublicKey(EC_KEY **key, const unsigned char **in, long len);
int i2o_ECPublicKey(EC_KEY *key, unsigned char **out);
int ECParameters_print(BIO *bp, const EC_KEY *key);
int EC_KEY_print(BIO *bp, const EC_KEY *key, int off);
# 940 "/usr/include/openssl/ec.h" 3 4
int ECParameters_print_fp(FILE *fp, const EC_KEY *key);
int EC_KEY_print_fp(FILE *fp, const EC_KEY *key, int off);
# 973 "/usr/include/openssl/ec.h" 3 4
void ERR_load_EC_strings(void);
# 84 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/ecdsa.h" 1 3 4
# 62 "/usr/include/openssl/ecdsa.h" 3 4
# 63 "/usr/include/openssl/ecdsa.h" 2 3 4
# 78 "/usr/include/openssl/ecdsa.h" 3 4
typedef struct ECDSA_SIG_st
 BIGNUM *r;
 BIGNUM *s;
 } ECDSA_SIG;
ECDSA_SIG *ECDSA_SIG_new(void);
void ECDSA_SIG_free(ECDSA_SIG *sig);
int i2d_ECDSA_SIG(const ECDSA_SIG *sig, unsigned char **pp);
# 109 "/usr/include/openssl/ecdsa.h" 3 4
ECDSA_SIG *d2i_ECDSA_SIG(ECDSA_SIG **sig, const unsigned char **pp, long len);
# 118 "/usr/include/openssl/ecdsa.h" 3 4
ECDSA_SIG *ECDSA_do_sign(const unsigned char *dgst,int dgst_len,EC_KEY *eckey);
# 130 "/usr/include/openssl/ecdsa.h" 3 4
ECDSA_SIG *ECDSA_do_sign_ex(const unsigned char *dgst, int dgstlen,
  const BIGNUM *kinv, const BIGNUM *rp, EC_KEY *eckey);
# 142 "/usr/include/openssl/ecdsa.h" 3 4
int ECDSA_do_verify(const unsigned char *dgst, int dgst_len,
  const ECDSA_SIG *sig, EC_KEY* eckey);
const ECDSA_METHOD *ECDSA_OpenSSL(void);
void ECDSA_set_default_method(const ECDSA_METHOD *meth);
const ECDSA_METHOD *ECDSA_get_default_method(void);
int ECDSA_set_method(EC_KEY *eckey, const ECDSA_METHOD *meth);
int ECDSA_size(const EC_KEY *eckey);
# 177 "/usr/include/openssl/ecdsa.h" 3 4
int ECDSA_sign_setup(EC_KEY *eckey, BN_CTX *ctx, BIGNUM **kinv,
  BIGNUM **rp);
# 190 "/usr/include/openssl/ecdsa.h" 3 4
int ECDSA_sign(int type, const unsigned char *dgst, int dgstlen,
  unsigned char *sig, unsigned int *siglen, EC_KEY *eckey);
# 207 "/usr/include/openssl/ecdsa.h" 3 4
int ECDSA_sign_ex(int type, const unsigned char *dgst, int dgstlen,
  unsigned char *sig, unsigned int *siglen, const BIGNUM *kinv,
# 222 "/usr/include/openssl/ecdsa.h" 3 4
int ECDSA_verify(int type, const unsigned char *dgst, int dgstlen,
  const unsigned char *sig, int siglen, EC_KEY *eckey);
int ECDSA_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new
  *new_func, CRYPTO_EX_dup *dup_func, CRYPTO_EX_free *free_func);
int ECDSA_set_ex_data(EC_KEY *d, int idx, void *arg);
void *ECDSA_get_ex_data(EC_KEY *d, int idx);
void ERR_load_ECDSA_strings(void);
# 88 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/ecdh.h" 1 3 4
# 72 "/usr/include/openssl/ecdh.h" 3 4
# 73 "/usr/include/openssl/ecdh.h" 2 3 4
# 88 "/usr/include/openssl/ecdh.h" 3 4
const ECDH_METHOD *ECDH_OpenSSL(void);
void ECDH_set_default_method(const ECDH_METHOD *);
const ECDH_METHOD *ECDH_get_default_method(void);
int ECDH_set_method(EC_KEY *, const ECDH_METHOD *);
int ECDH_compute_key(void *out, size_t outlen, const EC_POINT *pub_key, EC_KEY *ecdh,
                     void *(*KDF)(const void *in, size_t inlen, void *out, size_t *outlen));
int ECDH_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new
int ECDH_set_ex_data(EC_KEY *d, int idx, void *arg);
void *ECDH_get_ex_data(EC_KEY *d, int idx);
void ERR_load_ECDH_strings(void);
# 92 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/rsa.h" 1 3 4
# 85 "/usr/include/openssl/rsa.h" 3 4
struct rsa_meth_st
 const char *name;
 int (*rsa_pub_enc)(int flen,const unsigned char *from,
      unsigned char *to,
      RSA *rsa,int padding);
 int (*rsa_pub_dec)(int flen,const unsigned char *from,
      unsigned char *to,
 int (*rsa_priv_enc)(int flen,const unsigned char *from,
       unsigned char *to,
 int (*rsa_priv_dec)(int flen,const unsigned char *from,
       unsigned char *to,
 int (*rsa_mod_exp)(BIGNUM *r0,const BIGNUM *I,RSA *rsa,BN_CTX *ctx);
 int (*bn_mod_exp)(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
     const BIGNUM *m, BN_CTX *ctx,
     BN_MONT_CTX *m_ctx);
 int (*init)(RSA *rsa);
 int (*finish)(RSA *rsa);
 int flags;
 char *app_data;
 int (*rsa_sign)(int type,
  unsigned char *sigret, unsigned int *siglen, const RSA *rsa);
 int (*rsa_verify)(int dtype,
        const RSA *rsa);
 int (*rsa_keygen)(RSA *rsa, int bits, BIGNUM *e, BN_GENCB *cb);
struct rsa_st
 int pad;
 long version;
 const RSA_METHOD *meth;
 ENGINE *engine;
 BIGNUM *n;
 BIGNUM *e;
 BIGNUM *d;
 BIGNUM *p;
 BIGNUM *q;
 BIGNUM *dmp1;
 BIGNUM *dmq1;
 BIGNUM *iqmp;
 CRYPTO_EX_DATA ex_data;
 int references;
 int flags;
 BN_MONT_CTX *_method_mod_n;
 BN_MONT_CTX *_method_mod_p;
 BN_MONT_CTX *_method_mod_q;
 char *bignum_data;
 BN_BLINDING *blinding;
 BN_BLINDING *mt_blinding;
# 281 "/usr/include/openssl/rsa.h" 3 4
RSA * RSA_new(void);
RSA * RSA_new_method(ENGINE *engine);
int RSA_size(const RSA *rsa);
RSA * RSA_generate_key(int bits, unsigned long e,void
  (*callback)(int,int,void *),void *cb_arg);
int RSA_generate_key_ex(RSA *rsa, int bits, BIGNUM *e, BN_GENCB *cb);
int RSA_check_key(const RSA *);
int RSA_public_encrypt(int flen, const unsigned char *from,
  unsigned char *to, RSA *rsa,int padding);
int RSA_private_encrypt(int flen, const unsigned char *from,
int RSA_public_decrypt(int flen, const unsigned char *from,
int RSA_private_decrypt(int flen, const unsigned char *from,
void RSA_free (RSA *r);
int RSA_up_ref(RSA *r);
int RSA_flags(const RSA *r);
void RSA_set_default_method(const RSA_METHOD *meth);
const RSA_METHOD *RSA_get_default_method(void);
const RSA_METHOD *RSA_get_method(const RSA *rsa);
int RSA_set_method(RSA *rsa, const RSA_METHOD *meth);
int RSA_memory_lock(RSA *r);
const RSA_METHOD *RSA_PKCS1_SSLeay(void);
const RSA_METHOD *RSA_null_method(void);
RSA *d2i_RSAPublicKey(RSA **a, const unsigned char **in, long len); int i2d_RSAPublicKey(const RSA *a, unsigned char **out); extern const ASN1_ITEM RSAPublicKey_it;
RSA *d2i_RSAPrivateKey(RSA **a, const unsigned char **in, long len); int i2d_RSAPrivateKey(const RSA *a, unsigned char **out); extern const ASN1_ITEM RSAPrivateKey_it;
typedef struct rsa_pss_params_st
 X509_ALGOR *hashAlgorithm;
 X509_ALGOR *maskGenAlgorithm;
 ASN1_INTEGER *saltLength;
 ASN1_INTEGER *trailerField;
 } RSA_PSS_PARAMS;
RSA_PSS_PARAMS *RSA_PSS_PARAMS_new(void); void RSA_PSS_PARAMS_free(RSA_PSS_PARAMS *a); RSA_PSS_PARAMS *d2i_RSA_PSS_PARAMS(RSA_PSS_PARAMS **a, const unsigned char **in, long len); int i2d_RSA_PSS_PARAMS(RSA_PSS_PARAMS *a, unsigned char **out); extern const ASN1_ITEM RSA_PSS_PARAMS_it;
int RSA_print_fp(FILE *fp, const RSA *r,int offset);
int RSA_print(BIO *bp, const RSA *r,int offset);
int i2d_RSA_NET(const RSA *a, unsigned char **pp,
  int (*cb)(char *buf, int len, const char *prompt, int verify),
  int sgckey);
RSA *d2i_RSA_NET(RSA **a, const unsigned char **pp, long length,
   int sgckey);
int i2d_Netscape_RSA(const RSA *a, unsigned char **pp,
          int verify));
RSA *d2i_Netscape_RSA(RSA **a, const unsigned char **pp, long length,
    int verify));
int RSA_sign(int type, const unsigned char *m, unsigned int m_length,
 unsigned char *sigret, unsigned int *siglen, RSA *rsa);
int RSA_verify(int type, const unsigned char *m, unsigned int m_length,
 const unsigned char *sigbuf, unsigned int siglen, RSA *rsa);
int RSA_sign_ASN1_OCTET_STRING(int type,
int RSA_verify_ASN1_OCTET_STRING(int type,
int RSA_blinding_on(RSA *rsa, BN_CTX *ctx);
void RSA_blinding_off(RSA *rsa);
BN_BLINDING *RSA_setup_blinding(RSA *rsa, BN_CTX *ctx);
int RSA_padding_add_PKCS1_type_1(unsigned char *to,int tlen,
 const unsigned char *f,int fl);
int RSA_padding_check_PKCS1_type_1(unsigned char *to,int tlen,
 const unsigned char *f,int fl,int rsa_len);
int RSA_padding_add_PKCS1_type_2(unsigned char *to,int tlen,
int RSA_padding_check_PKCS1_type_2(unsigned char *to,int tlen,
int PKCS1_MGF1(unsigned char *mask, long len,
 const unsigned char *seed, long seedlen, const EVP_MD *dgst);
int RSA_padding_add_PKCS1_OAEP(unsigned char *to,int tlen,
 const unsigned char *p,int pl);
int RSA_padding_check_PKCS1_OAEP(unsigned char *to,int tlen,
 const unsigned char *f,int fl,int rsa_len,
int RSA_padding_add_SSLv23(unsigned char *to,int tlen,
int RSA_padding_check_SSLv23(unsigned char *to,int tlen,
int RSA_padding_add_none(unsigned char *to,int tlen,
int RSA_padding_check_none(unsigned char *to,int tlen,
int RSA_padding_add_X931(unsigned char *to,int tlen,
int RSA_padding_check_X931(unsigned char *to,int tlen,
int RSA_X931_hash_id(int nid);
int RSA_verify_PKCS1_PSS(RSA *rsa, const unsigned char *mHash,
   const EVP_MD *Hash, const unsigned char *EM, int sLen);
int RSA_padding_add_PKCS1_PSS(RSA *rsa, unsigned char *EM,
   const EVP_MD *Hash, int sLen);
int RSA_verify_PKCS1_PSS_mgf1(RSA *rsa, const unsigned char *mHash,
   const EVP_MD *Hash, const EVP_MD *mgf1Hash,
int RSA_padding_add_PKCS1_PSS_mgf1(RSA *rsa, unsigned char *EM,
   const EVP_MD *Hash, const EVP_MD *mgf1Hash, int sLen);
int RSA_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int RSA_set_ex_data(RSA *r,int idx,void *arg);
void *RSA_get_ex_data(const RSA *r, int idx);
RSA *RSAPublicKey_dup(RSA *rsa);
RSA *RSAPrivateKey_dup(RSA *rsa);
# 455 "/usr/include/openssl/rsa.h" 3 4
void ERR_load_RSA_strings(void);
# 97 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/dsa.h" 1 3 4
# 68 "/usr/include/openssl/dsa.h" 3 4
# 1 "/usr/include/openssl/e_os2.h" 1 3 4
# 56 "/usr/include/openssl/e_os2.h" 3 4
# 57 "/usr/include/openssl/e_os2.h" 2 3 4
# 69 "/usr/include/openssl/dsa.h" 2 3 4
# 83 "/usr/include/openssl/dsa.h" 3 4
# 1 "/usr/include/openssl/dh.h" 1 3 4
# 62 "/usr/include/openssl/dh.h" 3 4
# 63 "/usr/include/openssl/dh.h" 2 3 4
# 112 "/usr/include/openssl/dh.h" 3 4
struct dh_method
 const char *name;
 int (*generate_key)(DH *dh);
 int (*compute_key)(unsigned char *key,const BIGNUM *pub_key,DH *dh);
 int (*bn_mod_exp)(const DH *dh, BIGNUM *r, const BIGNUM *a,
    const BIGNUM *p, const BIGNUM *m, BN_CTX *ctx,
 int (*init)(DH *dh);
 int (*finish)(DH *dh);
 int flags;
 char *app_data;
 int (*generate_params)(DH *dh, int prime_len, int generator, BN_GENCB *cb);
struct dh_st
 int pad;
 int version;
 BIGNUM *p;
 BIGNUM *g;
 long length;
 BIGNUM *pub_key;
 BIGNUM *priv_key;
 int flags;
 BN_MONT_CTX *method_mont_p;
 BIGNUM *q;
 BIGNUM *j;
 unsigned char *seed;
 int seedlen;
 BIGNUM *counter;
 int references;
 const DH_METHOD *meth;
 ENGINE *engine;
# 182 "/usr/include/openssl/dh.h" 3 4
DH *DHparams_dup(DH *);
const DH_METHOD *DH_OpenSSL(void);
void DH_set_default_method(const DH_METHOD *meth);
const DH_METHOD *DH_get_default_method(void);
int DH_set_method(DH *dh, const DH_METHOD *meth);
DH *DH_new_method(ENGINE *engine);
DH * DH_new(void);
void DH_free(DH *dh);
int DH_up_ref(DH *dh);
int DH_size(const DH *dh);
int DH_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int DH_set_ex_data(DH *d, int idx, void *arg);
void *DH_get_ex_data(DH *d, int idx);
DH * DH_generate_parameters(int prime_len,int generator,
  void (*callback)(int,int,void *),void *cb_arg);
int DH_generate_parameters_ex(DH *dh, int prime_len,int generator, BN_GENCB *cb);
int DH_check(const DH *dh,int *codes);
int DH_check_pub_key(const DH *dh,const BIGNUM *pub_key, int *codes);
int DH_generate_key(DH *dh);
int DH_compute_key(unsigned char *key,const BIGNUM *pub_key,DH *dh);
DH * d2i_DHparams(DH **a,const unsigned char **pp, long length);
int i2d_DHparams(const DH *a,unsigned char **pp);
int DHparams_print_fp(FILE *fp, const DH *x);
int DHparams_print(BIO *bp, const DH *x);
# 240 "/usr/include/openssl/dh.h" 3 4
void ERR_load_DH_strings(void);
# 84 "/usr/include/openssl/dsa.h" 2 3 4
# 123 "/usr/include/openssl/dsa.h" 3 4
typedef struct DSA_SIG_st
 BIGNUM *r;
 BIGNUM *s;
 } DSA_SIG;
struct dsa_method
 const char *name;
 DSA_SIG * (*dsa_do_sign)(const unsigned char *dgst, int dlen, DSA *dsa);
 int (*dsa_sign_setup)(DSA *dsa, BN_CTX *ctx_in, BIGNUM **kinvp,
        BIGNUM **rp);
 int (*dsa_do_verify)(const unsigned char *dgst, int dgst_len,
        DSA_SIG *sig, DSA *dsa);
 int (*dsa_mod_exp)(DSA *dsa, BIGNUM *rr, BIGNUM *a1, BIGNUM *p1,
   BIGNUM *a2, BIGNUM *p2, BIGNUM *m, BN_CTX *ctx,
   BN_MONT_CTX *in_mont);
 int (*bn_mod_exp)(DSA *dsa, BIGNUM *r, BIGNUM *a, const BIGNUM *p,
 int (*init)(DSA *dsa);
 int (*finish)(DSA *dsa);
 int flags;
 char *app_data;
 int (*dsa_paramgen)(DSA *dsa, int bits,
   const unsigned char *seed, int seed_len,
   int *counter_ret, unsigned long *h_ret,
   BN_GENCB *cb);
 int (*dsa_keygen)(DSA *dsa);
struct dsa_st
 int pad;
 long version;
 int write_params;
 BIGNUM *p;
 BIGNUM *q;
 BIGNUM *g;
 BIGNUM *pub_key;
 BIGNUM *priv_key;
 BIGNUM *kinv;
 BIGNUM *r;
 int flags;
 int references;
 const DSA_METHOD *meth;
 ENGINE *engine;
# 191 "/usr/include/openssl/dsa.h" 3 4
DSA *DSAparams_dup(DSA *x);
DSA_SIG * DSA_SIG_new(void);
void DSA_SIG_free(DSA_SIG *a);
int i2d_DSA_SIG(const DSA_SIG *a, unsigned char **pp);
DSA_SIG * d2i_DSA_SIG(DSA_SIG **v, const unsigned char **pp, long length);
DSA_SIG * DSA_do_sign(const unsigned char *dgst,int dlen,DSA *dsa);
int DSA_do_verify(const unsigned char *dgst,int dgst_len,
        DSA_SIG *sig,DSA *dsa);
const DSA_METHOD *DSA_OpenSSL(void);
void DSA_set_default_method(const DSA_METHOD *);
const DSA_METHOD *DSA_get_default_method(void);
int DSA_set_method(DSA *dsa, const DSA_METHOD *);
DSA * DSA_new(void);
DSA * DSA_new_method(ENGINE *engine);
void DSA_free (DSA *r);
int DSA_up_ref(DSA *r);
int DSA_size(const DSA *);
int DSA_sign_setup( DSA *dsa,BN_CTX *ctx_in,BIGNUM **kinvp,BIGNUM **rp);
int DSA_sign(int type,const unsigned char *dgst,int dlen,
  unsigned char *sig, unsigned int *siglen, DSA *dsa);
int DSA_verify(int type,const unsigned char *dgst,int dgst_len,
  const unsigned char *sigbuf, int siglen, DSA *dsa);
int DSA_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int DSA_set_ex_data(DSA *d, int idx, void *arg);
void *DSA_get_ex_data(DSA *d, int idx);
DSA * d2i_DSAPublicKey(DSA **a, const unsigned char **pp, long length);
DSA * d2i_DSAPrivateKey(DSA **a, const unsigned char **pp, long length);
DSA * d2i_DSAparams(DSA **a, const unsigned char **pp, long length);
DSA * DSA_generate_parameters(int bits,
  unsigned char *seed,int seed_len,
  int *counter_ret, unsigned long *h_ret,void
  (*callback)(int, int, void *),void *cb_arg);
int DSA_generate_parameters_ex(DSA *dsa, int bits,
  const unsigned char *seed,int seed_len,
  int *counter_ret, unsigned long *h_ret, BN_GENCB *cb);
int DSA_generate_key(DSA *a);
int i2d_DSAPublicKey(const DSA *a, unsigned char **pp);
int i2d_DSAPrivateKey(const DSA *a, unsigned char **pp);
int i2d_DSAparams(const DSA *a,unsigned char **pp);
int DSAparams_print(BIO *bp, const DSA *x);
int DSA_print(BIO *bp, const DSA *x, int off);
int DSAparams_print_fp(FILE *fp, const DSA *x);
int DSA_print_fp(FILE *bp, const DSA *x, int off);
# 264 "/usr/include/openssl/dsa.h" 3 4
DH *DSA_dup_DH(const DSA *r);
# 279 "/usr/include/openssl/dsa.h" 3 4
void ERR_load_DSA_strings(void);
# 100 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/sha.h" 1 3 4
# 62 "/usr/include/openssl/sha.h" 3 4
# 63 "/usr/include/openssl/sha.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 1 3 4
# 64 "/usr/include/openssl/sha.h" 2 3 4
# 100 "/usr/include/openssl/sha.h" 3 4
typedef struct SHAstate_st
 unsigned int h0,h1,h2,h3,h4;
 unsigned int Nl,Nh;
 unsigned int data[16];
 unsigned int num;
 } SHA_CTX;
int SHA_Init(SHA_CTX *c);
int SHA_Update(SHA_CTX *c, const void *data, size_t len);
int SHA_Final(unsigned char *md, SHA_CTX *c);
unsigned char *SHA(const unsigned char *d, size_t n, unsigned char *md);
void SHA_Transform(SHA_CTX *c, const unsigned char *data);
int SHA1_Init(SHA_CTX *c);
int SHA1_Update(SHA_CTX *c, const void *data, size_t len);
int SHA1_Final(unsigned char *md, SHA_CTX *c);
unsigned char *SHA1(const unsigned char *d, size_t n, unsigned char *md);
void SHA1_Transform(SHA_CTX *c, const unsigned char *data);
# 135 "/usr/include/openssl/sha.h" 3 4
typedef struct SHA256state_st
 unsigned int h[8];
 unsigned int Nl,Nh;
 unsigned int num,md_len;
 } SHA256_CTX;
int SHA224_Init(SHA256_CTX *c);
int SHA224_Update(SHA256_CTX *c, const void *data, size_t len);
int SHA224_Final(unsigned char *md, SHA256_CTX *c);
unsigned char *SHA224(const unsigned char *d, size_t n,unsigned char *md);
int SHA256_Init(SHA256_CTX *c);
int SHA256_Update(SHA256_CTX *c, const void *data, size_t len);
int SHA256_Final(unsigned char *md, SHA256_CTX *c);
unsigned char *SHA256(const unsigned char *d, size_t n,unsigned char *md);
void SHA256_Transform(SHA256_CTX *c, const unsigned char *data);
# 182 "/usr/include/openssl/sha.h" 3 4
typedef struct SHA512state_st
 unsigned long long h[8];
 unsigned long long Nl,Nh;
 union {
  unsigned long long d[16];
  unsigned char p[(16*8)];
 } u;
 } SHA512_CTX;
int SHA384_Init(SHA512_CTX *c);
int SHA384_Update(SHA512_CTX *c, const void *data, size_t len);
int SHA384_Final(unsigned char *md, SHA512_CTX *c);
unsigned char *SHA384(const unsigned char *d, size_t n,unsigned char *md);
int SHA512_Init(SHA512_CTX *c);
int SHA512_Update(SHA512_CTX *c, const void *data, size_t len);
int SHA512_Final(unsigned char *md, SHA512_CTX *c);
unsigned char *SHA512(const unsigned char *d, size_t n,unsigned char *md);
void SHA512_Transform(SHA512_CTX *c, const unsigned char *data);
# 108 "/usr/include/openssl/x509.h" 2 3 4
# 137 "/usr/include/openssl/x509.h" 3 4
typedef struct X509_objects_st
 int nid;
 int (*a2i)(void);
 int (*i2a)(void);
 } X509_OBJECTS;
struct X509_algor_st
 ASN1_OBJECT *algorithm;
 ASN1_TYPE *parameter;
typedef struct stack_st_X509_ALGOR X509_ALGORS;
typedef struct X509_val_st
 ASN1_TIME *notBefore;
 ASN1_TIME *notAfter;
 } X509_VAL;
struct X509_pubkey_st
 X509_ALGOR *algor;
 ASN1_BIT_STRING *public_key;
 EVP_PKEY *pkey;
typedef struct X509_sig_st
 X509_ALGOR *algor;
 ASN1_OCTET_STRING *digest;
 } X509_SIG;
typedef struct X509_name_entry_st
 ASN1_OBJECT *object;
 ASN1_STRING *value;
 int set;
 int size;
 } X509_NAME_ENTRY;
struct stack_st_X509_NAME_ENTRY { _STACK stack; };
struct X509_name_st
 struct stack_st_X509_NAME_ENTRY *entries;
 int modified;
 BUF_MEM *bytes;
 unsigned char *canon_enc;
 int canon_enclen;
struct stack_st_X509_NAME { _STACK stack; };
typedef struct X509_extension_st
 ASN1_BOOLEAN critical;
 ASN1_OCTET_STRING *value;
 } X509_EXTENSION;
typedef struct stack_st_X509_EXTENSION X509_EXTENSIONS;
struct stack_st_X509_EXTENSION { _STACK stack; };
typedef struct x509_attributes_st
 int single;
 union {
  char *ptr;
         struct stack_st_ASN1_TYPE *set;
         ASN1_TYPE *single;
  } value;
 } X509_ATTRIBUTE;
struct stack_st_X509_ATTRIBUTE { _STACK stack; };
typedef struct X509_req_info_st
 ASN1_ENCODING enc;
 ASN1_INTEGER *version;
 X509_NAME *subject;
 X509_PUBKEY *pubkey;
 } X509_REQ_INFO;
typedef struct X509_req_st
 X509_REQ_INFO *req_info;
 X509_ALGOR *sig_alg;
 ASN1_BIT_STRING *signature;
 int references;
 } X509_REQ;
typedef struct x509_cinf_st
 ASN1_INTEGER *serialNumber;
 X509_ALGOR *signature;
 X509_NAME *issuer;
 X509_VAL *validity;
 X509_NAME *subject;
 X509_PUBKEY *key;
 ASN1_BIT_STRING *issuerUID;
 ASN1_BIT_STRING *subjectUID;
 struct stack_st_X509_EXTENSION *extensions;
 ASN1_ENCODING enc;
 } X509_CINF;
typedef struct x509_cert_aux_st
 struct stack_st_ASN1_OBJECT *trust;
 struct stack_st_ASN1_OBJECT *reject;
 ASN1_UTF8STRING *alias;
 ASN1_OCTET_STRING *keyid;
 struct stack_st_X509_ALGOR *other;
 } X509_CERT_AUX;
struct x509_st
 X509_CINF *cert_info;
 int valid;
 int references;
 char *name;
 long ex_pathlen;
 long ex_pcpathlen;
 unsigned long ex_flags;
 unsigned long ex_kusage;
 unsigned long ex_xkusage;
 unsigned long ex_nscert;
 ASN1_OCTET_STRING *skid;
 AUTHORITY_KEYID *akid;
 X509_POLICY_CACHE *policy_cache;
 struct stack_st_DIST_POINT *crldp;
 struct stack_st_GENERAL_NAME *altname;
 NAME_CONSTRAINTS *nc;
 unsigned char sha1_hash[20];
 X509_CERT_AUX *aux;
struct stack_st_X509 { _STACK stack; };
typedef struct x509_trust_st {
 int trust;
 int flags;
 int (*check_trust)(struct x509_trust_st *, X509 *, int);
 char *name;
 int arg1;
 void *arg2;
} X509_TRUST;
struct stack_st_X509_TRUST { _STACK stack; };
typedef struct x509_cert_pair_st {
 X509 *forward;
 X509 *reverse;
} X509_CERT_PAIR;
# 434 "/usr/include/openssl/x509.h" 3 4
struct x509_revoked_st
 ASN1_TIME *revocationDate;
 struct stack_st_GENERAL_NAME *issuer;
 int reason;
 int sequence;
struct stack_st_X509_REVOKED { _STACK stack; };
typedef struct X509_crl_info_st
 X509_NAME *issuer;
 ASN1_TIME *lastUpdate;
 ASN1_TIME *nextUpdate;
 struct stack_st_X509_REVOKED *revoked;
 ASN1_ENCODING enc;
 } X509_CRL_INFO;
struct X509_crl_st
 X509_CRL_INFO *crl;
 int references;
 int flags;
 ISSUING_DIST_POINT *idp;
 int idp_flags;
 int idp_reasons;
 ASN1_INTEGER *crl_number;
 ASN1_INTEGER *base_crl_number;
 struct stack_st_GENERAL_NAMES *issuers;
 const X509_CRL_METHOD *meth;
 void *meth_data;
struct stack_st_X509_CRL { _STACK stack; };
typedef struct private_key_st
 int version;
 X509_ALGOR *enc_algor;
 ASN1_OCTET_STRING *enc_pkey;
 EVP_PKEY *dec_pkey;
 int key_length;
 char *key_data;
 int key_free;
 EVP_CIPHER_INFO cipher;
 int references;
 } X509_PKEY;
typedef struct X509_info_st
 X509 *x509;
 X509_CRL *crl;
 X509_PKEY *x_pkey;
 EVP_CIPHER_INFO enc_cipher;
 int enc_len;
 char *enc_data;
 int references;
 } X509_INFO;
struct stack_st_X509_INFO { _STACK stack; };
typedef struct Netscape_spkac_st
 ASN1_IA5STRING *challenge;
 } NETSCAPE_SPKAC;
typedef struct Netscape_spki_st
 NETSCAPE_SPKAC *spkac;
 X509_ALGOR *sig_algor;
 } NETSCAPE_SPKI;
typedef struct Netscape_certificate_sequence
 ASN1_OBJECT *type;
 struct stack_st_X509 *certs;
 } NETSCAPE_CERT_SEQUENCE;
# 560 "/usr/include/openssl/x509.h" 3 4
typedef struct PBEPARAM_st {
ASN1_OCTET_STRING *salt;
ASN1_INTEGER *iter;
} PBEPARAM;
typedef struct PBE2PARAM_st {
X509_ALGOR *keyfunc;
X509_ALGOR *encryption;
} PBE2PARAM;
typedef struct PBKDF2PARAM_st {
ASN1_TYPE *salt;
ASN1_INTEGER *iter;
ASN1_INTEGER *keylength;
X509_ALGOR *prf;
} PBKDF2PARAM;
struct pkcs8_priv_key_info_st
        int broken;
        X509_ALGOR *pkeyalg;
        ASN1_TYPE *pkey;
# 1 "/usr/include/openssl/x509_vfy.h" 1 3 4
# 68 "/usr/include/openssl/x509_vfy.h" 3 4
# 69 "/usr/include/openssl/x509_vfy.h" 2 3 4
# 1 "/usr/include/openssl/lhash.h" 1 3 4
# 66 "/usr/include/openssl/lhash.h" 3 4
# 67 "/usr/include/openssl/lhash.h" 2 3 4
# 79 "/usr/include/openssl/lhash.h" 3 4
typedef struct lhash_node_st
 void *data;
 struct lhash_node_st *next;
 unsigned long hash;
 } LHASH_NODE;
typedef int (*LHASH_COMP_FN_TYPE)(const void *, const void *);
typedef unsigned long (*LHASH_HASH_FN_TYPE)(const void *);
typedef void (*LHASH_DOALL_FN_TYPE)(void *);
typedef void (*LHASH_DOALL_ARG_FN_TYPE)(void *, void *);
# 138 "/usr/include/openssl/lhash.h" 3 4
typedef struct lhash_st
 LHASH_NODE **b;
 LHASH_COMP_FN_TYPE comp;
 LHASH_HASH_FN_TYPE hash;
 unsigned int num_nodes;
 unsigned int num_alloc_nodes;
 unsigned int p;
 unsigned int pmax;
 unsigned long up_load;
 unsigned long down_load;
 unsigned long num_items;
 unsigned long num_expands;
 unsigned long num_expand_reallocs;
 unsigned long num_contracts;
 unsigned long num_contract_reallocs;
 unsigned long num_hash_calls;
 unsigned long num_comp_calls;
 unsigned long num_insert;
 unsigned long num_replace;
 unsigned long num_delete;
 unsigned long num_no_delete;
 unsigned long num_retrieve;
 unsigned long num_retrieve_miss;
 unsigned long num_hash_comps;
 int error;
 } _LHASH;
# 175 "/usr/include/openssl/lhash.h" 3 4
_LHASH *lh_new(LHASH_HASH_FN_TYPE h, LHASH_COMP_FN_TYPE c);
void lh_free(_LHASH *lh);
void *lh_insert(_LHASH *lh, void *data);
void *lh_delete(_LHASH *lh, const void *data);
void *lh_retrieve(_LHASH *lh, const void *data);
void lh_doall(_LHASH *lh, LHASH_DOALL_FN_TYPE func);
void lh_doall_arg(_LHASH *lh, LHASH_DOALL_ARG_FN_TYPE func, void *arg);
unsigned long lh_strhash(const char *c);
unsigned long lh_num_items(const _LHASH *lh);
void lh_stats(const _LHASH *lh, FILE *out);
void lh_node_stats(const _LHASH *lh, FILE *out);
void lh_node_usage_stats(const _LHASH *lh, FILE *out);
void lh_stats_bio(const _LHASH *lh, BIO *out);
void lh_node_stats_bio(const _LHASH *lh, BIO *out);
void lh_node_usage_stats_bio(const _LHASH *lh, BIO *out);
# 233 "/usr/include/openssl/lhash.h" 3 4
struct lhash_st_OPENSSL_STRING { int dummy; };
struct lhash_st_OPENSSL_CSTRING { int dummy; };
# 71 "/usr/include/openssl/x509_vfy.h" 2 3 4
# 91 "/usr/include/openssl/x509_vfy.h" 3 4
typedef struct x509_file_st
 int num_paths;
 int num_alloced;
 char **paths;
 int *path_type;
 } X509_CERT_FILE_CTX;
# 123 "/usr/include/openssl/x509_vfy.h" 3 4
typedef struct x509_object_st
 int type;
 union {
  char *ptr;
  X509 *x509;
  X509_CRL *crl;
  EVP_PKEY *pkey;
  } data;
 } X509_OBJECT;
typedef struct x509_lookup_st X509_LOOKUP;
struct stack_st_X509_LOOKUP { _STACK stack; };
struct stack_st_X509_OBJECT { _STACK stack; };
typedef struct x509_lookup_method_st
 const char *name;
 int (*new_item)(X509_LOOKUP *ctx);
 void (*free)(X509_LOOKUP *ctx);
 int (*init)(X509_LOOKUP *ctx);
 int (*shutdown)(X509_LOOKUP *ctx);
 int (*ctrl)(X509_LOOKUP *ctx,int cmd,const char *argc,long argl,
   char **ret);
 int (*get_by_subject)(X509_LOOKUP *ctx,int type,X509_NAME *name,
         X509_OBJECT *ret);
 int (*get_by_issuer_serial)(X509_LOOKUP *ctx,int type,X509_NAME *name,
        ASN1_INTEGER *serial,X509_OBJECT *ret);
 int (*get_by_fingerprint)(X509_LOOKUP *ctx,int type,
      unsigned char *bytes,int len,
      X509_OBJECT *ret);
 int (*get_by_alias)(X509_LOOKUP *ctx,int type,char *str,int len,
       X509_OBJECT *ret);
 } X509_LOOKUP_METHOD;
typedef struct X509_VERIFY_PARAM_st
 char *name;
 time_t check_time;
 unsigned long inh_flags;
 unsigned long flags;
 int purpose;
 int trust;
 int depth;
 struct stack_st_ASN1_OBJECT *policies;
 } X509_VERIFY_PARAM;
struct stack_st_X509_VERIFY_PARAM { _STACK stack; };
struct x509_store_st
 int cache;
 struct stack_st_X509_OBJECT *objs;
 struct stack_st_X509_LOOKUP *get_cert_methods;
 X509_VERIFY_PARAM *param;
 int (*verify)(X509_STORE_CTX *ctx);
 int (*verify_cb)(int ok,X509_STORE_CTX *ctx);
 int (*get_issuer)(X509 **issuer, X509_STORE_CTX *ctx, X509 *x);
 int (*check_issued)(X509_STORE_CTX *ctx, X509 *x, X509 *issuer);
 int (*check_revocation)(X509_STORE_CTX *ctx);
 int (*get_crl)(X509_STORE_CTX *ctx, X509_CRL **crl, X509 *x);
 int (*check_crl)(X509_STORE_CTX *ctx, X509_CRL *crl);
 int (*cert_crl)(X509_STORE_CTX *ctx, X509_CRL *crl, X509 *x);
 struct stack_st_X509 * (*lookup_certs)(X509_STORE_CTX *ctx, X509_NAME *nm);
 struct stack_st_X509_CRL * (*lookup_crls)(X509_STORE_CTX *ctx, X509_NAME *nm);
 int (*cleanup)(X509_STORE_CTX *ctx);
 int references;
int X509_STORE_set_depth(X509_STORE *store, int depth);
 int init;
 int skip;
 X509_LOOKUP_METHOD *method;
 char *method_data;
 X509_STORE *store_ctx;
struct x509_store_ctx_st
 X509_STORE *ctx;
 int current_method;
 X509 *cert;
 struct stack_st_X509 *untrusted;
 struct stack_st_X509_CRL *crls;
 void *other_ctx;
 int (*check_policy)(X509_STORE_CTX *ctx);
 int valid;
 int last_untrusted;
 struct stack_st_X509 *chain;
 X509_POLICY_TREE *tree;
 int explicit_policy;
 int error_depth;
 int error;
 X509 *current_cert;
 X509 *current_issuer;
 X509_CRL *current_crl;
 int current_crl_score;
 unsigned int current_reasons;
 X509_STORE_CTX *parent;
void X509_STORE_CTX_set_depth(X509_STORE_CTX *ctx, int depth);
# 406 "/usr/include/openssl/x509_vfy.h" 3 4
int X509_OBJECT_idx_by_subject(struct stack_st_X509_OBJECT *h, int type,
      X509_NAME *name);
X509_OBJECT *X509_OBJECT_retrieve_by_subject(struct stack_st_X509_OBJECT *h,int type,X509_NAME *name);
X509_OBJECT *X509_OBJECT_retrieve_match(struct stack_st_X509_OBJECT *h, X509_OBJECT *x);
void X509_OBJECT_up_ref_count(X509_OBJECT *a);
void X509_OBJECT_free_contents(X509_OBJECT *a);
X509_STORE *X509_STORE_new(void );
void X509_STORE_free(X509_STORE *v);
struct stack_st_X509* X509_STORE_get1_certs(X509_STORE_CTX *st, X509_NAME *nm);
struct stack_st_X509_CRL* X509_STORE_get1_crls(X509_STORE_CTX *st, X509_NAME *nm);
int X509_STORE_set_flags(X509_STORE *ctx, unsigned long flags);
int X509_STORE_set_purpose(X509_STORE *ctx, int purpose);
int X509_STORE_set_trust(X509_STORE *ctx, int trust);
int X509_STORE_set1_param(X509_STORE *ctx, X509_VERIFY_PARAM *pm);
void X509_STORE_set_verify_cb(X509_STORE *ctx,
      int (*verify_cb)(int, X509_STORE_CTX *));
X509_STORE_CTX *X509_STORE_CTX_new(void);
int X509_STORE_CTX_get1_issuer(X509 **issuer, X509_STORE_CTX *ctx, X509 *x);
void X509_STORE_CTX_free(X509_STORE_CTX *ctx);
int X509_STORE_CTX_init(X509_STORE_CTX *ctx, X509_STORE *store,
    X509 *x509, struct stack_st_X509 *chain);
void X509_STORE_CTX_trusted_stack(X509_STORE_CTX *ctx, struct stack_st_X509 *sk);
void X509_STORE_CTX_cleanup(X509_STORE_CTX *ctx);
X509_LOOKUP *X509_STORE_add_lookup(X509_STORE *v, X509_LOOKUP_METHOD *m);
X509_LOOKUP_METHOD *X509_LOOKUP_hash_dir(void);
X509_LOOKUP_METHOD *X509_LOOKUP_file(void);
int X509_STORE_add_cert(X509_STORE *ctx, X509 *x);
int X509_STORE_add_crl(X509_STORE *ctx, X509_CRL *x);
int X509_STORE_get_by_subject(X509_STORE_CTX *vs,int type,X509_NAME *name,
 X509_OBJECT *ret);
int X509_LOOKUP_ctrl(X509_LOOKUP *ctx, int cmd, const char *argc,
 long argl, char **ret);
int X509_load_cert_file(X509_LOOKUP *ctx, const char *file, int type);
int X509_load_crl_file(X509_LOOKUP *ctx, const char *file, int type);
int X509_load_cert_crl_file(X509_LOOKUP *ctx, const char *file, int type);
X509_LOOKUP *X509_LOOKUP_new(X509_LOOKUP_METHOD *method);
void X509_LOOKUP_free(X509_LOOKUP *ctx);
int X509_LOOKUP_init(X509_LOOKUP *ctx);
int X509_LOOKUP_by_subject(X509_LOOKUP *ctx, int type, X509_NAME *name,
 X509_OBJECT *ret);
int X509_LOOKUP_by_issuer_serial(X509_LOOKUP *ctx, int type, X509_NAME *name,
 ASN1_INTEGER *serial, X509_OBJECT *ret);
int X509_LOOKUP_by_fingerprint(X509_LOOKUP *ctx, int type,
 unsigned char *bytes, int len, X509_OBJECT *ret);
int X509_LOOKUP_by_alias(X509_LOOKUP *ctx, int type, char *str,
int X509_LOOKUP_shutdown(X509_LOOKUP *ctx);
int X509_STORE_load_locations (X509_STORE *ctx,
  const char *file, const char *dir);
int X509_STORE_set_default_paths(X509_STORE *ctx);
int X509_STORE_CTX_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int X509_STORE_CTX_set_ex_data(X509_STORE_CTX *ctx,int idx,void *data);
void * X509_STORE_CTX_get_ex_data(X509_STORE_CTX *ctx,int idx);
int X509_STORE_CTX_get_error(X509_STORE_CTX *ctx);
void X509_STORE_CTX_set_error(X509_STORE_CTX *ctx,int s);
int X509_STORE_CTX_get_error_depth(X509_STORE_CTX *ctx);
X509 * X509_STORE_CTX_get_current_cert(X509_STORE_CTX *ctx);
X509 *X509_STORE_CTX_get0_current_issuer(X509_STORE_CTX *ctx);
X509_CRL *X509_STORE_CTX_get0_current_crl(X509_STORE_CTX *ctx);
X509_STORE_CTX *X509_STORE_CTX_get0_parent_ctx(X509_STORE_CTX *ctx);
struct stack_st_X509 *X509_STORE_CTX_get_chain(X509_STORE_CTX *ctx);
struct stack_st_X509 *X509_STORE_CTX_get1_chain(X509_STORE_CTX *ctx);
void X509_STORE_CTX_set_cert(X509_STORE_CTX *c,X509 *x);
void X509_STORE_CTX_set_chain(X509_STORE_CTX *c,struct stack_st_X509 *sk);
void X509_STORE_CTX_set0_crls(X509_STORE_CTX *c,struct stack_st_X509_CRL *sk);
int X509_STORE_CTX_set_purpose(X509_STORE_CTX *ctx, int purpose);
int X509_STORE_CTX_set_trust(X509_STORE_CTX *ctx, int trust);
int X509_STORE_CTX_purpose_inherit(X509_STORE_CTX *ctx, int def_purpose,
    int purpose, int trust);
void X509_STORE_CTX_set_flags(X509_STORE_CTX *ctx, unsigned long flags);
void X509_STORE_CTX_set_time(X509_STORE_CTX *ctx, unsigned long flags,
        time_t t);
void X509_STORE_CTX_set_verify_cb(X509_STORE_CTX *ctx,
X509_POLICY_TREE *X509_STORE_CTX_get0_policy_tree(X509_STORE_CTX *ctx);
int X509_STORE_CTX_get_explicit_policy(X509_STORE_CTX *ctx);
X509_VERIFY_PARAM *X509_STORE_CTX_get0_param(X509_STORE_CTX *ctx);
void X509_STORE_CTX_set0_param(X509_STORE_CTX *ctx, X509_VERIFY_PARAM *param);
int X509_STORE_CTX_set_default(X509_STORE_CTX *ctx, const char *name);
X509_VERIFY_PARAM *X509_VERIFY_PARAM_new(void);
void X509_VERIFY_PARAM_free(X509_VERIFY_PARAM *param);
int X509_VERIFY_PARAM_inherit(X509_VERIFY_PARAM *to,
      const X509_VERIFY_PARAM *from);
int X509_VERIFY_PARAM_set1(X509_VERIFY_PARAM *to,
int X509_VERIFY_PARAM_set1_name(X509_VERIFY_PARAM *param, const char *name);
int X509_VERIFY_PARAM_set_flags(X509_VERIFY_PARAM *param, unsigned long flags);
int X509_VERIFY_PARAM_clear_flags(X509_VERIFY_PARAM *param,
unsigned long X509_VERIFY_PARAM_get_flags(X509_VERIFY_PARAM *param);
int X509_VERIFY_PARAM_set_purpose(X509_VERIFY_PARAM *param, int purpose);
int X509_VERIFY_PARAM_set_trust(X509_VERIFY_PARAM *param, int trust);
void X509_VERIFY_PARAM_set_depth(X509_VERIFY_PARAM *param, int depth);
void X509_VERIFY_PARAM_set_time(X509_VERIFY_PARAM *param, time_t t);
int X509_VERIFY_PARAM_add0_policy(X509_VERIFY_PARAM *param,
      ASN1_OBJECT *policy);
int X509_VERIFY_PARAM_set1_policies(X509_VERIFY_PARAM *param,
     struct stack_st_ASN1_OBJECT *policies);
int X509_VERIFY_PARAM_get_depth(const X509_VERIFY_PARAM *param);
int X509_VERIFY_PARAM_add0_table(X509_VERIFY_PARAM *param);
const X509_VERIFY_PARAM *X509_VERIFY_PARAM_lookup(const char *name);
void X509_VERIFY_PARAM_table_cleanup(void);
int X509_policy_check(X509_POLICY_TREE **ptree, int *pexplicit_policy,
   struct stack_st_X509 *certs,
   struct stack_st_ASN1_OBJECT *policy_oids,
void X509_policy_tree_free(X509_POLICY_TREE *tree);
int X509_policy_tree_level_count(const X509_POLICY_TREE *tree);
X509_POLICY_LEVEL *
 X509_policy_tree_get0_level(const X509_POLICY_TREE *tree, int i);
struct stack_st_X509_POLICY_NODE *
 X509_policy_tree_get0_policies(const X509_POLICY_TREE *tree);
 X509_policy_tree_get0_user_policies(const X509_POLICY_TREE *tree);
int X509_policy_level_node_count(X509_POLICY_LEVEL *level);
X509_POLICY_NODE *X509_policy_level_get0_node(X509_POLICY_LEVEL *level, int i);
const ASN1_OBJECT *X509_policy_node_get0_policy(const X509_POLICY_NODE *node);
struct stack_st_POLICYQUALINFO *
 X509_policy_node_get0_qualifiers(const X509_POLICY_NODE *node);
 X509_policy_node_get0_parent(const X509_POLICY_NODE *node);
# 601 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/pkcs7.h" 1 3 4
# 64 "/usr/include/openssl/pkcs7.h" 3 4
# 65 "/usr/include/openssl/pkcs7.h" 2 3 4
# 86 "/usr/include/openssl/pkcs7.h" 3 4
typedef struct pkcs7_issuer_and_serial_st
 X509_NAME *issuer;
 ASN1_INTEGER *serial;
 } PKCS7_ISSUER_AND_SERIAL;
typedef struct pkcs7_signer_info_st
 PKCS7_ISSUER_AND_SERIAL *issuer_and_serial;
 X509_ALGOR *digest_alg;
 struct stack_st_X509_ATTRIBUTE *auth_attr;
 X509_ALGOR *digest_enc_alg;
 ASN1_OCTET_STRING *enc_digest;
 struct stack_st_X509_ATTRIBUTE *unauth_attr;
 EVP_PKEY *pkey;
 } PKCS7_SIGNER_INFO;
struct stack_st_PKCS7_SIGNER_INFO { _STACK stack; };
typedef struct pkcs7_recip_info_st
 X509_ALGOR *key_enc_algor;
 ASN1_OCTET_STRING *enc_key;
 X509 *cert;
 } PKCS7_RECIP_INFO;
struct stack_st_PKCS7_RECIP_INFO { _STACK stack; };
typedef struct pkcs7_signed_st
 struct stack_st_X509_ALGOR *md_algs;
 struct stack_st_X509 *cert;
 struct stack_st_X509_CRL *crl;
 struct stack_st_PKCS7_SIGNER_INFO *signer_info;
 struct pkcs7_st *contents;
 } PKCS7_SIGNED;
typedef struct pkcs7_enc_content_st
 ASN1_OBJECT *content_type;
 X509_ALGOR *algorithm;
 ASN1_OCTET_STRING *enc_data;
 const EVP_CIPHER *cipher;
 } PKCS7_ENC_CONTENT;
typedef struct pkcs7_enveloped_st
 struct stack_st_PKCS7_RECIP_INFO *recipientinfo;
 PKCS7_ENC_CONTENT *enc_data;
 } PKCS7_ENVELOPE;
typedef struct pkcs7_signedandenveloped_st
 } PKCS7_SIGN_ENVELOPE;
typedef struct pkcs7_digest_st
 X509_ALGOR *md;
 } PKCS7_DIGEST;
typedef struct pkcs7_encrypted_st
 } PKCS7_ENCRYPT;
typedef struct pkcs7_st
 unsigned char *asn1;
 long length;
 int state;
 int detached;
 ASN1_OBJECT *type;
 union {
  char *ptr;
  ASN1_OCTET_STRING *data;
  PKCS7_SIGNED *sign;
  PKCS7_ENVELOPE *enveloped;
  PKCS7_SIGN_ENVELOPE *signed_and_enveloped;
  PKCS7_DIGEST *digest;
  PKCS7_ENCRYPT *encrypted;
  ASN1_TYPE *other;
  } d;
 } PKCS7;
struct stack_st_PKCS7 { _STACK stack; };
# 275 "/usr/include/openssl/pkcs7.h" 3 4
PKCS7_ISSUER_AND_SERIAL *PKCS7_ISSUER_AND_SERIAL_new(void); void PKCS7_ISSUER_AND_SERIAL_free(PKCS7_ISSUER_AND_SERIAL *a); PKCS7_ISSUER_AND_SERIAL *d2i_PKCS7_ISSUER_AND_SERIAL(PKCS7_ISSUER_AND_SERIAL **a, const unsigned char **in, long len); int i2d_PKCS7_ISSUER_AND_SERIAL(PKCS7_ISSUER_AND_SERIAL *a, unsigned char **out); extern const ASN1_ITEM PKCS7_ISSUER_AND_SERIAL_it;
int PKCS7_ISSUER_AND_SERIAL_digest(PKCS7_ISSUER_AND_SERIAL *data,const EVP_MD *type,
 unsigned char *md,unsigned int *len);
PKCS7 *d2i_PKCS7_fp(FILE *fp,PKCS7 **p7);
int i2d_PKCS7_fp(FILE *fp,PKCS7 *p7);
PKCS7 *PKCS7_dup(PKCS7 *p7);
PKCS7 *d2i_PKCS7_bio(BIO *bp,PKCS7 **p7);
int i2d_PKCS7_bio(BIO *bp,PKCS7 *p7);
int i2d_PKCS7_bio_stream(BIO *out, PKCS7 *p7, BIO *in, int flags);
int PEM_write_bio_PKCS7_stream(BIO *out, PKCS7 *p7, BIO *in, int flags);
PKCS7_SIGNER_INFO *PKCS7_SIGNER_INFO_new(void); void PKCS7_SIGNER_INFO_free(PKCS7_SIGNER_INFO *a); PKCS7_SIGNER_INFO *d2i_PKCS7_SIGNER_INFO(PKCS7_SIGNER_INFO **a, const unsigned char **in, long len); int i2d_PKCS7_SIGNER_INFO(PKCS7_SIGNER_INFO *a, unsigned char **out); extern const ASN1_ITEM PKCS7_SIGNER_INFO_it;
PKCS7_RECIP_INFO *PKCS7_RECIP_INFO_new(void); void PKCS7_RECIP_INFO_free(PKCS7_RECIP_INFO *a); PKCS7_RECIP_INFO *d2i_PKCS7_RECIP_INFO(PKCS7_RECIP_INFO **a, const unsigned char **in, long len); int i2d_PKCS7_RECIP_INFO(PKCS7_RECIP_INFO *a, unsigned char **out); extern const ASN1_ITEM PKCS7_RECIP_INFO_it;
PKCS7_SIGNED *PKCS7_SIGNED_new(void); void PKCS7_SIGNED_free(PKCS7_SIGNED *a); PKCS7_SIGNED *d2i_PKCS7_SIGNED(PKCS7_SIGNED **a, const unsigned char **in, long len); int i2d_PKCS7_SIGNED(PKCS7_SIGNED *a, unsigned char **out); extern const ASN1_ITEM PKCS7_SIGNED_it;
PKCS7_ENC_CONTENT *PKCS7_ENC_CONTENT_new(void); void PKCS7_ENC_CONTENT_free(PKCS7_ENC_CONTENT *a); PKCS7_ENC_CONTENT *d2i_PKCS7_ENC_CONTENT(PKCS7_ENC_CONTENT **a, const unsigned char **in, long len); int i2d_PKCS7_ENC_CONTENT(PKCS7_ENC_CONTENT *a, unsigned char **out); extern const ASN1_ITEM PKCS7_ENC_CONTENT_it;
PKCS7_ENVELOPE *PKCS7_ENVELOPE_new(void); void PKCS7_ENVELOPE_free(PKCS7_ENVELOPE *a); PKCS7_ENVELOPE *d2i_PKCS7_ENVELOPE(PKCS7_ENVELOPE **a, const unsigned char **in, long len); int i2d_PKCS7_ENVELOPE(PKCS7_ENVELOPE *a, unsigned char **out); extern const ASN1_ITEM PKCS7_ENVELOPE_it;
PKCS7_SIGN_ENVELOPE *PKCS7_SIGN_ENVELOPE_new(void); void PKCS7_SIGN_ENVELOPE_free(PKCS7_SIGN_ENVELOPE *a); PKCS7_SIGN_ENVELOPE *d2i_PKCS7_SIGN_ENVELOPE(PKCS7_SIGN_ENVELOPE **a, const unsigned char **in, long len); int i2d_PKCS7_SIGN_ENVELOPE(PKCS7_SIGN_ENVELOPE *a, unsigned char **out); extern const ASN1_ITEM PKCS7_SIGN_ENVELOPE_it;
PKCS7_DIGEST *PKCS7_DIGEST_new(void); void PKCS7_DIGEST_free(PKCS7_DIGEST *a); PKCS7_DIGEST *d2i_PKCS7_DIGEST(PKCS7_DIGEST **a, const unsigned char **in, long len); int i2d_PKCS7_DIGEST(PKCS7_DIGEST *a, unsigned char **out); extern const ASN1_ITEM PKCS7_DIGEST_it;
PKCS7_ENCRYPT *PKCS7_ENCRYPT_new(void); void PKCS7_ENCRYPT_free(PKCS7_ENCRYPT *a); PKCS7_ENCRYPT *d2i_PKCS7_ENCRYPT(PKCS7_ENCRYPT **a, const unsigned char **in, long len); int i2d_PKCS7_ENCRYPT(PKCS7_ENCRYPT *a, unsigned char **out); extern const ASN1_ITEM PKCS7_ENCRYPT_it;
PKCS7 *PKCS7_new(void); void PKCS7_free(PKCS7 *a); PKCS7 *d2i_PKCS7(PKCS7 **a, const unsigned char **in, long len); int i2d_PKCS7(PKCS7 *a, unsigned char **out); extern const ASN1_ITEM PKCS7_it;
extern const ASN1_ITEM PKCS7_ATTR_SIGN_it;
extern const ASN1_ITEM PKCS7_ATTR_VERIFY_it;
int i2d_PKCS7_NDEF(PKCS7 *a, unsigned char **out);
int PKCS7_print_ctx(BIO *out, PKCS7 *x, int indent, const ASN1_PCTX *pctx);
long PKCS7_ctrl(PKCS7 *p7, int cmd, long larg, char *parg);
int PKCS7_set_type(PKCS7 *p7, int type);
int PKCS7_set0_type_other(PKCS7 *p7, int type, ASN1_TYPE *other);
int PKCS7_set_content(PKCS7 *p7, PKCS7 *p7_data);
int PKCS7_SIGNER_INFO_set(PKCS7_SIGNER_INFO *p7i, X509 *x509, EVP_PKEY *pkey,
int PKCS7_SIGNER_INFO_sign(PKCS7_SIGNER_INFO *si);
int PKCS7_add_signer(PKCS7 *p7, PKCS7_SIGNER_INFO *p7i);
int PKCS7_add_certificate(PKCS7 *p7, X509 *x509);
int PKCS7_add_crl(PKCS7 *p7, X509_CRL *x509);
int PKCS7_content_new(PKCS7 *p7, int nid);
int PKCS7_dataVerify(X509_STORE *cert_store, X509_STORE_CTX *ctx,
 BIO *bio, PKCS7 *p7, PKCS7_SIGNER_INFO *si);
int PKCS7_signatureVerify(BIO *bio, PKCS7 *p7, PKCS7_SIGNER_INFO *si,
        X509 *x509);
BIO *PKCS7_dataInit(PKCS7 *p7, BIO *bio);
int PKCS7_dataFinal(PKCS7 *p7, BIO *bio);
BIO *PKCS7_dataDecode(PKCS7 *p7, EVP_PKEY *pkey, BIO *in_bio, X509 *pcert);
PKCS7_SIGNER_INFO *PKCS7_add_signature(PKCS7 *p7, X509 *x509,
 EVP_PKEY *pkey, const EVP_MD *dgst);
X509 *PKCS7_cert_from_signer_info(PKCS7 *p7, PKCS7_SIGNER_INFO *si);
int PKCS7_set_digest(PKCS7 *p7, const EVP_MD *md);
struct stack_st_PKCS7_SIGNER_INFO *PKCS7_get_signer_info(PKCS7 *p7);
PKCS7_RECIP_INFO *PKCS7_add_recipient(PKCS7 *p7, X509 *x509);
void PKCS7_SIGNER_INFO_get0_algs(PKCS7_SIGNER_INFO *si, EVP_PKEY **pk,
     X509_ALGOR **pdig, X509_ALGOR **psig);
void PKCS7_RECIP_INFO_get0_alg(PKCS7_RECIP_INFO *ri, X509_ALGOR **penc);
int PKCS7_add_recipient_info(PKCS7 *p7, PKCS7_RECIP_INFO *ri);
int PKCS7_RECIP_INFO_set(PKCS7_RECIP_INFO *p7i, X509 *x509);
int PKCS7_set_cipher(PKCS7 *p7, const EVP_CIPHER *cipher);
int PKCS7_stream(unsigned char ***boundary, PKCS7 *p7);
PKCS7_ISSUER_AND_SERIAL *PKCS7_get_issuer_and_serial(PKCS7 *p7, int idx);
ASN1_OCTET_STRING *PKCS7_digest_from_attributes(struct stack_st_X509_ATTRIBUTE *sk);
int PKCS7_add_signed_attribute(PKCS7_SIGNER_INFO *p7si,int nid,int type,
 void *data);
int PKCS7_add_attribute (PKCS7_SIGNER_INFO *p7si, int nid, int atrtype,
 void *value);
ASN1_TYPE *PKCS7_get_attribute(PKCS7_SIGNER_INFO *si, int nid);
ASN1_TYPE *PKCS7_get_signed_attribute(PKCS7_SIGNER_INFO *si, int nid);
int PKCS7_set_signed_attributes(PKCS7_SIGNER_INFO *p7si,
int PKCS7_set_attributes(PKCS7_SIGNER_INFO *p7si,struct stack_st_X509_ATTRIBUTE *sk);
PKCS7 *PKCS7_sign(X509 *signcert, EVP_PKEY *pkey, struct stack_st_X509 *certs,
       BIO *data, int flags);
PKCS7_SIGNER_INFO *PKCS7_sign_add_signer(PKCS7 *p7,
   X509 *signcert, EVP_PKEY *pkey, const EVP_MD *md,
   int flags);
int PKCS7_final(PKCS7 *p7, BIO *data, int flags);
int PKCS7_verify(PKCS7 *p7, struct stack_st_X509 *certs, X509_STORE *store,
     BIO *indata, BIO *out, int flags);
struct stack_st_X509 *PKCS7_get0_signers(PKCS7 *p7, struct stack_st_X509 *certs, int flags);
PKCS7 *PKCS7_encrypt(struct stack_st_X509 *certs, BIO *in, const EVP_CIPHER *cipher,
        int flags);
int PKCS7_decrypt(PKCS7 *p7, EVP_PKEY *pkey, X509 *cert, BIO *data, int flags);
int PKCS7_add_attrib_smimecap(PKCS7_SIGNER_INFO *si,
         struct stack_st_X509_ALGOR *cap);
struct stack_st_X509_ALGOR *PKCS7_get_smimecap(PKCS7_SIGNER_INFO *si);
int PKCS7_simple_smimecap(struct stack_st_X509_ALGOR *sk, int nid, int arg);
int PKCS7_add_attrib_content_type(PKCS7_SIGNER_INFO *si, ASN1_OBJECT *coid);
int PKCS7_add0_attrib_signing_time(PKCS7_SIGNER_INFO *si, ASN1_TIME *t);
int PKCS7_add1_attrib_digest(PKCS7_SIGNER_INFO *si,
    const unsigned char *md, int mdlen);
int SMIME_write_PKCS7(BIO *bio, PKCS7 *p7, BIO *data, int flags);
PKCS7 *SMIME_read_PKCS7(BIO *bio, BIO **bcont);
BIO *BIO_new_PKCS7(BIO *out, PKCS7 *p7);
void ERR_load_PKCS7_strings(void);
# 602 "/usr/include/openssl/x509.h" 2 3 4
# 627 "/usr/include/openssl/x509.h" 3 4
void X509_CRL_set_default_method(const X509_CRL_METHOD *meth);
X509_CRL_METHOD *X509_CRL_METHOD_new(
 int (*crl_init)(X509_CRL *crl),
 int (*crl_free)(X509_CRL *crl),
 int (*crl_lookup)(X509_CRL *crl, X509_REVOKED **ret,
    ASN1_INTEGER *ser, X509_NAME *issuer),
 int (*crl_verify)(X509_CRL *crl, EVP_PKEY *pk));
void X509_CRL_METHOD_free(X509_CRL_METHOD *m);
void X509_CRL_set_meth_data(X509_CRL *crl, void *dat);
void *X509_CRL_get_meth_data(X509_CRL *crl);
const char *X509_verify_cert_error_string(long n);
int X509_verify(X509 *a, EVP_PKEY *r);
int X509_REQ_verify(X509_REQ *a, EVP_PKEY *r);
int X509_CRL_verify(X509_CRL *a, EVP_PKEY *r);
int NETSCAPE_SPKI_verify(NETSCAPE_SPKI *a, EVP_PKEY *r);
NETSCAPE_SPKI * NETSCAPE_SPKI_b64_decode(const char *str, int len);
char * NETSCAPE_SPKI_b64_encode(NETSCAPE_SPKI *x);
EVP_PKEY *NETSCAPE_SPKI_get_pubkey(NETSCAPE_SPKI *x);
int NETSCAPE_SPKI_set_pubkey(NETSCAPE_SPKI *x, EVP_PKEY *pkey);
int NETSCAPE_SPKI_print(BIO *out, NETSCAPE_SPKI *spki);
int X509_signature_dump(BIO *bp,const ASN1_STRING *sig, int indent);
int X509_signature_print(BIO *bp,X509_ALGOR *alg, ASN1_STRING *sig);
int X509_sign(X509 *x, EVP_PKEY *pkey, const EVP_MD *md);
int X509_sign_ctx(X509 *x, EVP_MD_CTX *ctx);
int X509_REQ_sign(X509_REQ *x, EVP_PKEY *pkey, const EVP_MD *md);
int X509_REQ_sign_ctx(X509_REQ *x, EVP_MD_CTX *ctx);
int X509_CRL_sign(X509_CRL *x, EVP_PKEY *pkey, const EVP_MD *md);
int X509_CRL_sign_ctx(X509_CRL *x, EVP_MD_CTX *ctx);
int NETSCAPE_SPKI_sign(NETSCAPE_SPKI *x, EVP_PKEY *pkey, const EVP_MD *md);
int X509_pubkey_digest(const X509 *data,const EVP_MD *type,
  unsigned char *md, unsigned int *len);
int X509_digest(const X509 *data,const EVP_MD *type,
int X509_CRL_digest(const X509_CRL *data,const EVP_MD *type,
int X509_REQ_digest(const X509_REQ *data,const EVP_MD *type,
int X509_NAME_digest(const X509_NAME *data,const EVP_MD *type,
X509 *d2i_X509_fp(FILE *fp, X509 **x509);
int i2d_X509_fp(FILE *fp,X509 *x509);
X509_CRL *d2i_X509_CRL_fp(FILE *fp,X509_CRL **crl);
int i2d_X509_CRL_fp(FILE *fp,X509_CRL *crl);
X509_REQ *d2i_X509_REQ_fp(FILE *fp,X509_REQ **req);
int i2d_X509_REQ_fp(FILE *fp,X509_REQ *req);
RSA *d2i_RSAPrivateKey_fp(FILE *fp,RSA **rsa);
int i2d_RSAPrivateKey_fp(FILE *fp,RSA *rsa);
RSA *d2i_RSAPublicKey_fp(FILE *fp,RSA **rsa);
int i2d_RSAPublicKey_fp(FILE *fp,RSA *rsa);
RSA *d2i_RSA_PUBKEY_fp(FILE *fp,RSA **rsa);
int i2d_RSA_PUBKEY_fp(FILE *fp,RSA *rsa);
DSA *d2i_DSA_PUBKEY_fp(FILE *fp, DSA **dsa);
int i2d_DSA_PUBKEY_fp(FILE *fp, DSA *dsa);
DSA *d2i_DSAPrivateKey_fp(FILE *fp, DSA **dsa);
int i2d_DSAPrivateKey_fp(FILE *fp, DSA *dsa);
EC_KEY *d2i_EC_PUBKEY_fp(FILE *fp, EC_KEY **eckey);
int i2d_EC_PUBKEY_fp(FILE *fp, EC_KEY *eckey);
EC_KEY *d2i_ECPrivateKey_fp(FILE *fp, EC_KEY **eckey);
int i2d_ECPrivateKey_fp(FILE *fp, EC_KEY *eckey);
X509_SIG *d2i_PKCS8_fp(FILE *fp,X509_SIG **p8);
int i2d_PKCS8_fp(FILE *fp,X509_SIG *p8);
PKCS8_PRIV_KEY_INFO *d2i_PKCS8_PRIV_KEY_INFO_fp(FILE *fp,
      PKCS8_PRIV_KEY_INFO **p8inf);
int i2d_PKCS8_PRIV_KEY_INFO_fp(FILE *fp,PKCS8_PRIV_KEY_INFO *p8inf);
int i2d_PKCS8PrivateKeyInfo_fp(FILE *fp, EVP_PKEY *key);
int i2d_PrivateKey_fp(FILE *fp, EVP_PKEY *pkey);
EVP_PKEY *d2i_PrivateKey_fp(FILE *fp, EVP_PKEY **a);
int i2d_PUBKEY_fp(FILE *fp, EVP_PKEY *pkey);
EVP_PKEY *d2i_PUBKEY_fp(FILE *fp, EVP_PKEY **a);
X509 *d2i_X509_bio(BIO *bp,X509 **x509);
int i2d_X509_bio(BIO *bp,X509 *x509);
X509_CRL *d2i_X509_CRL_bio(BIO *bp,X509_CRL **crl);
int i2d_X509_CRL_bio(BIO *bp,X509_CRL *crl);
X509_REQ *d2i_X509_REQ_bio(BIO *bp,X509_REQ **req);
int i2d_X509_REQ_bio(BIO *bp,X509_REQ *req);
RSA *d2i_RSAPrivateKey_bio(BIO *bp,RSA **rsa);
int i2d_RSAPrivateKey_bio(BIO *bp,RSA *rsa);
RSA *d2i_RSAPublicKey_bio(BIO *bp,RSA **rsa);
int i2d_RSAPublicKey_bio(BIO *bp,RSA *rsa);
RSA *d2i_RSA_PUBKEY_bio(BIO *bp,RSA **rsa);
int i2d_RSA_PUBKEY_bio(BIO *bp,RSA *rsa);
DSA *d2i_DSA_PUBKEY_bio(BIO *bp, DSA **dsa);
int i2d_DSA_PUBKEY_bio(BIO *bp, DSA *dsa);
DSA *d2i_DSAPrivateKey_bio(BIO *bp, DSA **dsa);
int i2d_DSAPrivateKey_bio(BIO *bp, DSA *dsa);
EC_KEY *d2i_EC_PUBKEY_bio(BIO *bp, EC_KEY **eckey);
int i2d_EC_PUBKEY_bio(BIO *bp, EC_KEY *eckey);
EC_KEY *d2i_ECPrivateKey_bio(BIO *bp, EC_KEY **eckey);
int i2d_ECPrivateKey_bio(BIO *bp, EC_KEY *eckey);
X509_SIG *d2i_PKCS8_bio(BIO *bp,X509_SIG **p8);
int i2d_PKCS8_bio(BIO *bp,X509_SIG *p8);
PKCS8_PRIV_KEY_INFO *d2i_PKCS8_PRIV_KEY_INFO_bio(BIO *bp,
int i2d_PKCS8_PRIV_KEY_INFO_bio(BIO *bp,PKCS8_PRIV_KEY_INFO *p8inf);
int i2d_PKCS8PrivateKeyInfo_bio(BIO *bp, EVP_PKEY *key);
int i2d_PrivateKey_bio(BIO *bp, EVP_PKEY *pkey);
EVP_PKEY *d2i_PrivateKey_bio(BIO *bp, EVP_PKEY **a);
int i2d_PUBKEY_bio(BIO *bp, EVP_PKEY *pkey);
EVP_PKEY *d2i_PUBKEY_bio(BIO *bp, EVP_PKEY **a);
X509 *X509_dup(X509 *x509);
X509_ATTRIBUTE *X509_ATTRIBUTE_dup(X509_ATTRIBUTE *xa);
X509_EXTENSION *X509_EXTENSION_dup(X509_EXTENSION *ex);
X509_CRL *X509_CRL_dup(X509_CRL *crl);
X509_REQ *X509_REQ_dup(X509_REQ *req);
X509_ALGOR *X509_ALGOR_dup(X509_ALGOR *xn);
int X509_ALGOR_set0(X509_ALGOR *alg, ASN1_OBJECT *aobj, int ptype, void *pval);
void X509_ALGOR_get0(ASN1_OBJECT **paobj, int *pptype, void **ppval,
      X509_ALGOR *algor);
void X509_ALGOR_set_md(X509_ALGOR *alg, const EVP_MD *md);
X509_NAME *X509_NAME_dup(X509_NAME *xn);
X509_NAME_ENTRY *X509_NAME_ENTRY_dup(X509_NAME_ENTRY *ne);
int X509_cmp_time(const ASN1_TIME *s, time_t *t);
int X509_cmp_current_time(const ASN1_TIME *s);
ASN1_TIME * X509_time_adj(ASN1_TIME *s, long adj, time_t *t);
ASN1_TIME * X509_time_adj_ex(ASN1_TIME *s,
    int offset_day, long offset_sec, time_t *t);
ASN1_TIME * X509_gmtime_adj(ASN1_TIME *s, long adj);
const char * X509_get_default_cert_area(void );
const char * X509_get_default_cert_dir(void );
const char * X509_get_default_cert_file(void );
const char * X509_get_default_cert_dir_env(void );
const char * X509_get_default_cert_file_env(void );
const char * X509_get_default_private_dir(void );
X509_REQ * X509_to_X509_REQ(X509 *x, EVP_PKEY *pkey, const EVP_MD *md);
X509 * X509_REQ_to_X509(X509_REQ *r, int days,EVP_PKEY *pkey);
X509_ALGOR *X509_ALGOR_new(void); void X509_ALGOR_free(X509_ALGOR *a); X509_ALGOR *d2i_X509_ALGOR(X509_ALGOR **a, const unsigned char **in, long len); int i2d_X509_ALGOR(X509_ALGOR *a, unsigned char **out); extern const ASN1_ITEM X509_ALGOR_it;
X509_ALGORS *d2i_X509_ALGORS(X509_ALGORS **a, const unsigned char **in, long len); int i2d_X509_ALGORS(X509_ALGORS *a, unsigned char **out); extern const ASN1_ITEM X509_ALGORS_it;
X509_VAL *X509_VAL_new(void); void X509_VAL_free(X509_VAL *a); X509_VAL *d2i_X509_VAL(X509_VAL **a, const unsigned char **in, long len); int i2d_X509_VAL(X509_VAL *a, unsigned char **out); extern const ASN1_ITEM X509_VAL_it;
X509_PUBKEY *X509_PUBKEY_new(void); void X509_PUBKEY_free(X509_PUBKEY *a); X509_PUBKEY *d2i_X509_PUBKEY(X509_PUBKEY **a, const unsigned char **in, long len); int i2d_X509_PUBKEY(X509_PUBKEY *a, unsigned char **out); extern const ASN1_ITEM X509_PUBKEY_it;
int X509_PUBKEY_set(X509_PUBKEY **x, EVP_PKEY *pkey);
EVP_PKEY * X509_PUBKEY_get(X509_PUBKEY *key);
int X509_get_pubkey_parameters(EVP_PKEY *pkey,
int i2d_PUBKEY(EVP_PKEY *a,unsigned char **pp);
EVP_PKEY * d2i_PUBKEY(EVP_PKEY **a,const unsigned char **pp,
   long length);
int i2d_RSA_PUBKEY(RSA *a,unsigned char **pp);
RSA * d2i_RSA_PUBKEY(RSA **a,const unsigned char **pp,
   long length);
int i2d_DSA_PUBKEY(DSA *a,unsigned char **pp);
DSA * d2i_DSA_PUBKEY(DSA **a,const unsigned char **pp,
   long length);
int i2d_EC_PUBKEY(EC_KEY *a, unsigned char **pp);
EC_KEY *d2i_EC_PUBKEY(EC_KEY **a, const unsigned char **pp,
   long length);
X509_SIG *X509_SIG_new(void); void X509_SIG_free(X509_SIG *a); X509_SIG *d2i_X509_SIG(X509_SIG **a, const unsigned char **in, long len); int i2d_X509_SIG(X509_SIG *a, unsigned char **out); extern const ASN1_ITEM X509_SIG_it;
X509_REQ_INFO *X509_REQ_INFO_new(void); void X509_REQ_INFO_free(X509_REQ_INFO *a); X509_REQ_INFO *d2i_X509_REQ_INFO(X509_REQ_INFO **a, const unsigned char **in, long len); int i2d_X509_REQ_INFO(X509_REQ_INFO *a, unsigned char **out); extern const ASN1_ITEM X509_REQ_INFO_it;
X509_REQ *X509_REQ_new(void); void X509_REQ_free(X509_REQ *a); X509_REQ *d2i_X509_REQ(X509_REQ **a, const unsigned char **in, long len); int i2d_X509_REQ(X509_REQ *a, unsigned char **out); extern const ASN1_ITEM X509_REQ_it;
X509_ATTRIBUTE *X509_ATTRIBUTE_new(void); void X509_ATTRIBUTE_free(X509_ATTRIBUTE *a); X509_ATTRIBUTE *d2i_X509_ATTRIBUTE(X509_ATTRIBUTE **a, const unsigned char **in, long len); int i2d_X509_ATTRIBUTE(X509_ATTRIBUTE *a, unsigned char **out); extern const ASN1_ITEM X509_ATTRIBUTE_it;
X509_ATTRIBUTE *X509_ATTRIBUTE_create(int nid, int atrtype, void *value);
X509_EXTENSION *X509_EXTENSION_new(void); void X509_EXTENSION_free(X509_EXTENSION *a); X509_EXTENSION *d2i_X509_EXTENSION(X509_EXTENSION **a, const unsigned char **in, long len); int i2d_X509_EXTENSION(X509_EXTENSION *a, unsigned char **out); extern const ASN1_ITEM X509_EXTENSION_it;
X509_EXTENSIONS *d2i_X509_EXTENSIONS(X509_EXTENSIONS **a, const unsigned char **in, long len); int i2d_X509_EXTENSIONS(X509_EXTENSIONS *a, unsigned char **out); extern const ASN1_ITEM X509_EXTENSIONS_it;
X509_NAME_ENTRY *X509_NAME_ENTRY_new(void); void X509_NAME_ENTRY_free(X509_NAME_ENTRY *a); X509_NAME_ENTRY *d2i_X509_NAME_ENTRY(X509_NAME_ENTRY **a, const unsigned char **in, long len); int i2d_X509_NAME_ENTRY(X509_NAME_ENTRY *a, unsigned char **out); extern const ASN1_ITEM X509_NAME_ENTRY_it;
X509_NAME *X509_NAME_new(void); void X509_NAME_free(X509_NAME *a); X509_NAME *d2i_X509_NAME(X509_NAME **a, const unsigned char **in, long len); int i2d_X509_NAME(X509_NAME *a, unsigned char **out); extern const ASN1_ITEM X509_NAME_it;
int X509_NAME_set(X509_NAME **xn, X509_NAME *name);
X509_CINF *X509_CINF_new(void); void X509_CINF_free(X509_CINF *a); X509_CINF *d2i_X509_CINF(X509_CINF **a, const unsigned char **in, long len); int i2d_X509_CINF(X509_CINF *a, unsigned char **out); extern const ASN1_ITEM X509_CINF_it;
X509 *X509_new(void); void X509_free(X509 *a); X509 *d2i_X509(X509 **a, const unsigned char **in, long len); int i2d_X509(X509 *a, unsigned char **out); extern const ASN1_ITEM X509_it;
X509_CERT_AUX *X509_CERT_AUX_new(void); void X509_CERT_AUX_free(X509_CERT_AUX *a); X509_CERT_AUX *d2i_X509_CERT_AUX(X509_CERT_AUX **a, const unsigned char **in, long len); int i2d_X509_CERT_AUX(X509_CERT_AUX *a, unsigned char **out); extern const ASN1_ITEM X509_CERT_AUX_it;
X509_CERT_PAIR *X509_CERT_PAIR_new(void); void X509_CERT_PAIR_free(X509_CERT_PAIR *a); X509_CERT_PAIR *d2i_X509_CERT_PAIR(X509_CERT_PAIR **a, const unsigned char **in, long len); int i2d_X509_CERT_PAIR(X509_CERT_PAIR *a, unsigned char **out); extern const ASN1_ITEM X509_CERT_PAIR_it;
int X509_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int X509_set_ex_data(X509 *r, int idx, void *arg);
void *X509_get_ex_data(X509 *r, int idx);
int i2d_X509_AUX(X509 *a,unsigned char **pp);
X509 * d2i_X509_AUX(X509 **a,const unsigned char **pp,long length);
int X509_alias_set1(X509 *x, unsigned char *name, int len);
int X509_keyid_set1(X509 *x, unsigned char *id, int len);
unsigned char * X509_alias_get0(X509 *x, int *len);
unsigned char * X509_keyid_get0(X509 *x, int *len);
int (*X509_TRUST_set_default(int (*trust)(int , X509 *, int)))(int, X509 *, int);
int X509_TRUST_set(int *t, int trust);
int X509_add1_trust_object(X509 *x, ASN1_OBJECT *obj);
int X509_add1_reject_object(X509 *x, ASN1_OBJECT *obj);
void X509_trust_clear(X509 *x);
void X509_reject_clear(X509 *x);
X509_REVOKED *X509_REVOKED_new(void); void X509_REVOKED_free(X509_REVOKED *a); X509_REVOKED *d2i_X509_REVOKED(X509_REVOKED **a, const unsigned char **in, long len); int i2d_X509_REVOKED(X509_REVOKED *a, unsigned char **out); extern const ASN1_ITEM X509_REVOKED_it;
X509_CRL_INFO *X509_CRL_INFO_new(void); void X509_CRL_INFO_free(X509_CRL_INFO *a); X509_CRL_INFO *d2i_X509_CRL_INFO(X509_CRL_INFO **a, const unsigned char **in, long len); int i2d_X509_CRL_INFO(X509_CRL_INFO *a, unsigned char **out); extern const ASN1_ITEM X509_CRL_INFO_it;
X509_CRL *X509_CRL_new(void); void X509_CRL_free(X509_CRL *a); X509_CRL *d2i_X509_CRL(X509_CRL **a, const unsigned char **in, long len); int i2d_X509_CRL(X509_CRL *a, unsigned char **out); extern const ASN1_ITEM X509_CRL_it;
int X509_CRL_add0_revoked(X509_CRL *crl, X509_REVOKED *rev);
int X509_CRL_get0_by_serial(X509_CRL *crl,
  X509_REVOKED **ret, ASN1_INTEGER *serial);
int X509_CRL_get0_by_cert(X509_CRL *crl, X509_REVOKED **ret, X509 *x);
X509_PKEY * X509_PKEY_new(void );
void X509_PKEY_free(X509_PKEY *a);
int i2d_X509_PKEY(X509_PKEY *a,unsigned char **pp);
X509_PKEY * d2i_X509_PKEY(X509_PKEY **a,const unsigned char **pp,long length);
NETSCAPE_SPKI *NETSCAPE_SPKI_new(void); void NETSCAPE_SPKI_free(NETSCAPE_SPKI *a); NETSCAPE_SPKI *d2i_NETSCAPE_SPKI(NETSCAPE_SPKI **a, const unsigned char **in, long len); int i2d_NETSCAPE_SPKI(NETSCAPE_SPKI *a, unsigned char **out); extern const ASN1_ITEM NETSCAPE_SPKI_it;
NETSCAPE_SPKAC *NETSCAPE_SPKAC_new(void); void NETSCAPE_SPKAC_free(NETSCAPE_SPKAC *a); NETSCAPE_SPKAC *d2i_NETSCAPE_SPKAC(NETSCAPE_SPKAC **a, const unsigned char **in, long len); int i2d_NETSCAPE_SPKAC(NETSCAPE_SPKAC *a, unsigned char **out); extern const ASN1_ITEM NETSCAPE_SPKAC_it;
NETSCAPE_CERT_SEQUENCE *NETSCAPE_CERT_SEQUENCE_new(void); void NETSCAPE_CERT_SEQUENCE_free(NETSCAPE_CERT_SEQUENCE *a); NETSCAPE_CERT_SEQUENCE *d2i_NETSCAPE_CERT_SEQUENCE(NETSCAPE_CERT_SEQUENCE **a, const unsigned char **in, long len); int i2d_NETSCAPE_CERT_SEQUENCE(NETSCAPE_CERT_SEQUENCE *a, unsigned char **out); extern const ASN1_ITEM NETSCAPE_CERT_SEQUENCE_it;
X509_INFO * X509_INFO_new(void);
void X509_INFO_free(X509_INFO *a);
char * X509_NAME_oneline(X509_NAME *a,char *buf,int size);
int ASN1_verify(i2d_of_void *i2d, X509_ALGOR *algor1,
  ASN1_BIT_STRING *signature,char *data,EVP_PKEY *pkey);
int ASN1_digest(i2d_of_void *i2d,const EVP_MD *type,char *data,
int ASN1_sign(i2d_of_void *i2d, X509_ALGOR *algor1,
       X509_ALGOR *algor2, ASN1_BIT_STRING *signature,
       char *data,EVP_PKEY *pkey, const EVP_MD *type);
int ASN1_item_digest(const ASN1_ITEM *it,const EVP_MD *type,void *data,
int ASN1_item_verify(const ASN1_ITEM *it, X509_ALGOR *algor1,
 ASN1_BIT_STRING *signature,void *data,EVP_PKEY *pkey);
int ASN1_item_sign(const ASN1_ITEM *it, X509_ALGOR *algor1, X509_ALGOR *algor2,
 void *data, EVP_PKEY *pkey, const EVP_MD *type);
int ASN1_item_sign_ctx(const ASN1_ITEM *it,
       ASN1_BIT_STRING *signature, void *asn, EVP_MD_CTX *ctx);
int X509_set_version(X509 *x,long version);
int X509_set_serialNumber(X509 *x, ASN1_INTEGER *serial);
ASN1_INTEGER * X509_get_serialNumber(X509 *x);
int X509_set_issuer_name(X509 *x, X509_NAME *name);
X509_NAME * X509_get_issuer_name(X509 *a);
int X509_set_subject_name(X509 *x, X509_NAME *name);
X509_NAME * X509_get_subject_name(X509 *a);
int X509_set_notBefore(X509 *x, const ASN1_TIME *tm);
int X509_set_notAfter(X509 *x, const ASN1_TIME *tm);
int X509_set_pubkey(X509 *x, EVP_PKEY *pkey);
EVP_PKEY * X509_get_pubkey(X509 *x);
ASN1_BIT_STRING * X509_get0_pubkey_bitstr(const X509 *x);
int X509_certificate_type(X509 *x,EVP_PKEY *pubkey );
int X509_REQ_set_version(X509_REQ *x,long version);
int X509_REQ_set_subject_name(X509_REQ *req,X509_NAME *name);
int X509_REQ_set_pubkey(X509_REQ *x, EVP_PKEY *pkey);
EVP_PKEY * X509_REQ_get_pubkey(X509_REQ *req);
int X509_REQ_extension_nid(int nid);
int * X509_REQ_get_extension_nids(void);
void X509_REQ_set_extension_nids(int *nids);
struct stack_st_X509_EXTENSION *X509_REQ_get_extensions(X509_REQ *req);
int X509_REQ_add_extensions_nid(X509_REQ *req, struct stack_st_X509_EXTENSION *exts,
    int nid);
int X509_REQ_add_extensions(X509_REQ *req, struct stack_st_X509_EXTENSION *exts);
int X509_REQ_get_attr_count(const X509_REQ *req);
int X509_REQ_get_attr_by_NID(const X509_REQ *req, int nid,
     int lastpos);
int X509_REQ_get_attr_by_OBJ(const X509_REQ *req, ASN1_OBJECT *obj,
     int lastpos);
X509_ATTRIBUTE *X509_REQ_get_attr(const X509_REQ *req, int loc);
X509_ATTRIBUTE *X509_REQ_delete_attr(X509_REQ *req, int loc);
int X509_REQ_add1_attr(X509_REQ *req, X509_ATTRIBUTE *attr);
int X509_REQ_add1_attr_by_OBJ(X509_REQ *req,
   const ASN1_OBJECT *obj, int type,
   const unsigned char *bytes, int len);
int X509_REQ_add1_attr_by_NID(X509_REQ *req,
   int nid, int type,
int X509_REQ_add1_attr_by_txt(X509_REQ *req,
   const char *attrname, int type,
int X509_CRL_set_version(X509_CRL *x, long version);
int X509_CRL_set_issuer_name(X509_CRL *x, X509_NAME *name);
int X509_CRL_set_lastUpdate(X509_CRL *x, const ASN1_TIME *tm);
int X509_CRL_set_nextUpdate(X509_CRL *x, const ASN1_TIME *tm);
int X509_CRL_sort(X509_CRL *crl);
int X509_REVOKED_set_serialNumber(X509_REVOKED *x, ASN1_INTEGER *serial);
int X509_REVOKED_set_revocationDate(X509_REVOKED *r, ASN1_TIME *tm);
int X509_REQ_check_private_key(X509_REQ *x509,EVP_PKEY *pkey);
int X509_check_private_key(X509 *x509,EVP_PKEY *pkey);
int X509_issuer_and_serial_cmp(const X509 *a, const X509 *b);
unsigned long X509_issuer_and_serial_hash(X509 *a);
int X509_issuer_name_cmp(const X509 *a, const X509 *b);
unsigned long X509_issuer_name_hash(X509 *a);
int X509_subject_name_cmp(const X509 *a, const X509 *b);
unsigned long X509_subject_name_hash(X509 *x);
unsigned long X509_issuer_name_hash_old(X509 *a);
unsigned long X509_subject_name_hash_old(X509 *x);
int X509_cmp(const X509 *a, const X509 *b);
int X509_NAME_cmp(const X509_NAME *a, const X509_NAME *b);
unsigned long X509_NAME_hash(X509_NAME *x);
unsigned long X509_NAME_hash_old(X509_NAME *x);
int X509_CRL_cmp(const X509_CRL *a, const X509_CRL *b);
int X509_CRL_match(const X509_CRL *a, const X509_CRL *b);
int X509_print_ex_fp(FILE *bp,X509 *x, unsigned long nmflag, unsigned long cflag);
int X509_print_fp(FILE *bp,X509 *x);
int X509_CRL_print_fp(FILE *bp,X509_CRL *x);
int X509_REQ_print_fp(FILE *bp,X509_REQ *req);
int X509_NAME_print_ex_fp(FILE *fp, X509_NAME *nm, int indent, unsigned long flags);
int X509_NAME_print(BIO *bp, X509_NAME *name, int obase);
int X509_NAME_print_ex(BIO *out, X509_NAME *nm, int indent, unsigned long flags);
int X509_print_ex(BIO *bp,X509 *x, unsigned long nmflag, unsigned long cflag);
int X509_print(BIO *bp,X509 *x);
int X509_ocspid_print(BIO *bp,X509 *x);
int X509_CERT_AUX_print(BIO *bp,X509_CERT_AUX *x, int indent);
int X509_CRL_print(BIO *bp,X509_CRL *x);
int X509_REQ_print_ex(BIO *bp, X509_REQ *x, unsigned long nmflag, unsigned long cflag);
int X509_REQ_print(BIO *bp,X509_REQ *req);
int X509_NAME_entry_count(X509_NAME *name);
int X509_NAME_get_text_by_NID(X509_NAME *name, int nid,
   char *buf,int len);
int X509_NAME_get_text_by_OBJ(X509_NAME *name, ASN1_OBJECT *obj,
   char *buf,int len);
int X509_NAME_get_index_by_NID(X509_NAME *name,int nid,int lastpos);
int X509_NAME_get_index_by_OBJ(X509_NAME *name,ASN1_OBJECT *obj,
   int lastpos);
X509_NAME_ENTRY *X509_NAME_get_entry(X509_NAME *name, int loc);
X509_NAME_ENTRY *X509_NAME_delete_entry(X509_NAME *name, int loc);
int X509_NAME_add_entry(X509_NAME *name,X509_NAME_ENTRY *ne,
   int loc, int set);
int X509_NAME_add_entry_by_OBJ(X509_NAME *name, ASN1_OBJECT *obj, int type,
   unsigned char *bytes, int len, int loc, int set);
int X509_NAME_add_entry_by_NID(X509_NAME *name, int nid, int type,
X509_NAME_ENTRY *X509_NAME_ENTRY_create_by_txt(X509_NAME_ENTRY **ne,
  const char *field, int type, const unsigned char *bytes, int len);
X509_NAME_ENTRY *X509_NAME_ENTRY_create_by_NID(X509_NAME_ENTRY **ne, int nid,
   int type,unsigned char *bytes, int len);
int X509_NAME_add_entry_by_txt(X509_NAME *name, const char *field, int type,
   const unsigned char *bytes, int len, int loc, int set);
X509_NAME_ENTRY *X509_NAME_ENTRY_create_by_OBJ(X509_NAME_ENTRY **ne,
   ASN1_OBJECT *obj, int type,const unsigned char *bytes,
   int len);
int X509_NAME_ENTRY_set_object(X509_NAME_ENTRY *ne,
   ASN1_OBJECT *obj);
int X509_NAME_ENTRY_set_data(X509_NAME_ENTRY *ne, int type,
ASN1_OBJECT * X509_NAME_ENTRY_get_object(X509_NAME_ENTRY *ne);
ASN1_STRING * X509_NAME_ENTRY_get_data(X509_NAME_ENTRY *ne);
int X509v3_get_ext_count(const struct stack_st_X509_EXTENSION *x);
int X509v3_get_ext_by_NID(const struct stack_st_X509_EXTENSION *x,
          int nid, int lastpos);
int X509v3_get_ext_by_OBJ(const struct stack_st_X509_EXTENSION *x,
          ASN1_OBJECT *obj,int lastpos);
int X509v3_get_ext_by_critical(const struct stack_st_X509_EXTENSION *x,
        int crit, int lastpos);
X509_EXTENSION *X509v3_get_ext(const struct stack_st_X509_EXTENSION *x, int loc);
X509_EXTENSION *X509v3_delete_ext(struct stack_st_X509_EXTENSION *x, int loc);
struct stack_st_X509_EXTENSION *X509v3_add_ext(struct stack_st_X509_EXTENSION **x,
      X509_EXTENSION *ex, int loc);
int X509_get_ext_count(X509 *x);
int X509_get_ext_by_NID(X509 *x, int nid, int lastpos);
int X509_get_ext_by_OBJ(X509 *x,ASN1_OBJECT *obj,int lastpos);
int X509_get_ext_by_critical(X509 *x, int crit, int lastpos);
X509_EXTENSION *X509_get_ext(X509 *x, int loc);
X509_EXTENSION *X509_delete_ext(X509 *x, int loc);
int X509_add_ext(X509 *x, X509_EXTENSION *ex, int loc);
void * X509_get_ext_d2i(X509 *x, int nid, int *crit, int *idx);
int X509_add1_ext_i2d(X509 *x, int nid, void *value, int crit,
int X509_CRL_get_ext_count(X509_CRL *x);
int X509_CRL_get_ext_by_NID(X509_CRL *x, int nid, int lastpos);
int X509_CRL_get_ext_by_OBJ(X509_CRL *x,ASN1_OBJECT *obj,int lastpos);
int X509_CRL_get_ext_by_critical(X509_CRL *x, int crit, int lastpos);
X509_EXTENSION *X509_CRL_get_ext(X509_CRL *x, int loc);
X509_EXTENSION *X509_CRL_delete_ext(X509_CRL *x, int loc);
int X509_CRL_add_ext(X509_CRL *x, X509_EXTENSION *ex, int loc);
void * X509_CRL_get_ext_d2i(X509_CRL *x, int nid, int *crit, int *idx);
int X509_CRL_add1_ext_i2d(X509_CRL *x, int nid, void *value, int crit,
int X509_REVOKED_get_ext_count(X509_REVOKED *x);
int X509_REVOKED_get_ext_by_NID(X509_REVOKED *x, int nid, int lastpos);
int X509_REVOKED_get_ext_by_OBJ(X509_REVOKED *x,ASN1_OBJECT *obj,int lastpos);
int X509_REVOKED_get_ext_by_critical(X509_REVOKED *x, int crit, int lastpos);
X509_EXTENSION *X509_REVOKED_get_ext(X509_REVOKED *x, int loc);
X509_EXTENSION *X509_REVOKED_delete_ext(X509_REVOKED *x, int loc);
int X509_REVOKED_add_ext(X509_REVOKED *x, X509_EXTENSION *ex, int loc);
void * X509_REVOKED_get_ext_d2i(X509_REVOKED *x, int nid, int *crit, int *idx);
int X509_REVOKED_add1_ext_i2d(X509_REVOKED *x, int nid, void *value, int crit,
X509_EXTENSION *X509_EXTENSION_create_by_NID(X509_EXTENSION **ex,
   int nid, int crit, ASN1_OCTET_STRING *data);
X509_EXTENSION *X509_EXTENSION_create_by_OBJ(X509_EXTENSION **ex,
   ASN1_OBJECT *obj,int crit,ASN1_OCTET_STRING *data);
int X509_EXTENSION_set_object(X509_EXTENSION *ex,ASN1_OBJECT *obj);
int X509_EXTENSION_set_critical(X509_EXTENSION *ex, int crit);
int X509_EXTENSION_set_data(X509_EXTENSION *ex,
ASN1_OBJECT * X509_EXTENSION_get_object(X509_EXTENSION *ex);
ASN1_OCTET_STRING *X509_EXTENSION_get_data(X509_EXTENSION *ne);
int X509_EXTENSION_get_critical(X509_EXTENSION *ex);
int X509at_get_attr_count(const struct stack_st_X509_ATTRIBUTE *x);
int X509at_get_attr_by_NID(const struct stack_st_X509_ATTRIBUTE *x, int nid,
     int lastpos);
int X509at_get_attr_by_OBJ(const struct stack_st_X509_ATTRIBUTE *sk, ASN1_OBJECT *obj,
     int lastpos);
X509_ATTRIBUTE *X509at_get_attr(const struct stack_st_X509_ATTRIBUTE *x, int loc);
X509_ATTRIBUTE *X509at_delete_attr(struct stack_st_X509_ATTRIBUTE *x, int loc);
struct stack_st_X509_ATTRIBUTE *X509at_add1_attr(struct stack_st_X509_ATTRIBUTE **x,
struct stack_st_X509_ATTRIBUTE *X509at_add1_attr_by_OBJ(struct stack_st_X509_ATTRIBUTE **x,
struct stack_st_X509_ATTRIBUTE *X509at_add1_attr_by_NID(struct stack_st_X509_ATTRIBUTE **x,
   int nid, int type,
struct stack_st_X509_ATTRIBUTE *X509at_add1_attr_by_txt(struct stack_st_X509_ATTRIBUTE **x,
void *X509at_get0_data_by_OBJ(struct stack_st_X509_ATTRIBUTE *x,
    ASN1_OBJECT *obj, int lastpos, int type);
X509_ATTRIBUTE *X509_ATTRIBUTE_create_by_NID(X509_ATTRIBUTE **attr, int nid,
      int atrtype, const void *data, int len);
X509_ATTRIBUTE *X509_ATTRIBUTE_create_by_OBJ(X509_ATTRIBUTE **attr,
      const ASN1_OBJECT *obj, int atrtype, const void *data, int len);
X509_ATTRIBUTE *X509_ATTRIBUTE_create_by_txt(X509_ATTRIBUTE **attr,
  const char *atrname, int type, const unsigned char *bytes, int len);
int X509_ATTRIBUTE_set1_object(X509_ATTRIBUTE *attr, const ASN1_OBJECT *obj);
int X509_ATTRIBUTE_set1_data(X509_ATTRIBUTE *attr, int attrtype, const void *data, int len);
void *X509_ATTRIBUTE_get0_data(X509_ATTRIBUTE *attr, int idx,
     int atrtype, void *data);
int X509_ATTRIBUTE_count(X509_ATTRIBUTE *attr);
ASN1_OBJECT *X509_ATTRIBUTE_get0_object(X509_ATTRIBUTE *attr);
ASN1_TYPE *X509_ATTRIBUTE_get0_type(X509_ATTRIBUTE *attr, int idx);
int EVP_PKEY_get_attr_count(const EVP_PKEY *key);
int EVP_PKEY_get_attr_by_NID(const EVP_PKEY *key, int nid,
     int lastpos);
int EVP_PKEY_get_attr_by_OBJ(const EVP_PKEY *key, ASN1_OBJECT *obj,
     int lastpos);
X509_ATTRIBUTE *EVP_PKEY_get_attr(const EVP_PKEY *key, int loc);
X509_ATTRIBUTE *EVP_PKEY_delete_attr(EVP_PKEY *key, int loc);
int EVP_PKEY_add1_attr(EVP_PKEY *key, X509_ATTRIBUTE *attr);
int EVP_PKEY_add1_attr_by_OBJ(EVP_PKEY *key,
int EVP_PKEY_add1_attr_by_NID(EVP_PKEY *key,
   int nid, int type,
int EVP_PKEY_add1_attr_by_txt(EVP_PKEY *key,
int X509_verify_cert(X509_STORE_CTX *ctx);
X509 *X509_find_by_issuer_and_serial(struct stack_st_X509 *sk,X509_NAME *name,
X509 *X509_find_by_subject(struct stack_st_X509 *sk,X509_NAME *name);
PBEPARAM *PBEPARAM_new(void); void PBEPARAM_free(PBEPARAM *a); PBEPARAM *d2i_PBEPARAM(PBEPARAM **a, const unsigned char **in, long len); int i2d_PBEPARAM(PBEPARAM *a, unsigned char **out); extern const ASN1_ITEM PBEPARAM_it;
PBE2PARAM *PBE2PARAM_new(void); void PBE2PARAM_free(PBE2PARAM *a); PBE2PARAM *d2i_PBE2PARAM(PBE2PARAM **a, const unsigned char **in, long len); int i2d_PBE2PARAM(PBE2PARAM *a, unsigned char **out); extern const ASN1_ITEM PBE2PARAM_it;
PBKDF2PARAM *PBKDF2PARAM_new(void); void PBKDF2PARAM_free(PBKDF2PARAM *a); PBKDF2PARAM *d2i_PBKDF2PARAM(PBKDF2PARAM **a, const unsigned char **in, long len); int i2d_PBKDF2PARAM(PBKDF2PARAM *a, unsigned char **out); extern const ASN1_ITEM PBKDF2PARAM_it;
int PKCS5_pbe_set0_algor(X509_ALGOR *algor, int alg, int iter,
    const unsigned char *salt, int saltlen);
X509_ALGOR *PKCS5_pbe_set(int alg, int iter,
X509_ALGOR *PKCS5_pbe2_set(const EVP_CIPHER *cipher, int iter,
X509_ALGOR *PKCS5_pbe2_set_iv(const EVP_CIPHER *cipher, int iter,
     unsigned char *salt, int saltlen,
     unsigned char *aiv, int prf_nid);
X509_ALGOR *PKCS5_pbkdf2_set(int iter, unsigned char *salt, int saltlen,
    int prf_nid, int keylen);
PKCS8_PRIV_KEY_INFO *PKCS8_PRIV_KEY_INFO_new(void); void PKCS8_PRIV_KEY_INFO_free(PKCS8_PRIV_KEY_INFO *a); PKCS8_PRIV_KEY_INFO *d2i_PKCS8_PRIV_KEY_INFO(PKCS8_PRIV_KEY_INFO **a, const unsigned char **in, long len); int i2d_PKCS8_PRIV_KEY_INFO(PKCS8_PRIV_KEY_INFO *a, unsigned char **out); extern const ASN1_ITEM PKCS8_PRIV_KEY_INFO_it;
EVP_PKEY *EVP_PKCS82PKEY(PKCS8_PRIV_KEY_INFO *p8);
PKCS8_PRIV_KEY_INFO *EVP_PKEY2PKCS8(EVP_PKEY *pkey);
PKCS8_PRIV_KEY_INFO *EVP_PKEY2PKCS8_broken(EVP_PKEY *pkey, int broken);
PKCS8_PRIV_KEY_INFO *PKCS8_set_broken(PKCS8_PRIV_KEY_INFO *p8, int broken);
int PKCS8_pkey_set0(PKCS8_PRIV_KEY_INFO *priv, ASN1_OBJECT *aobj,
   int version, int ptype, void *pval,
    unsigned char *penc, int penclen);
int PKCS8_pkey_get0(ASN1_OBJECT **ppkalg,
  const unsigned char **pk, int *ppklen,
  X509_ALGOR **pa,
int X509_PUBKEY_set0_param(X509_PUBKEY *pub, ASN1_OBJECT *aobj,
int X509_PUBKEY_get0_param(ASN1_OBJECT **ppkalg,
  X509_ALGOR **pa,
  X509_PUBKEY *pub);
int X509_check_trust(X509 *x, int id, int flags);
int X509_TRUST_get_count(void);
X509_TRUST * X509_TRUST_get0(int idx);
int X509_TRUST_get_by_id(int id);
int X509_TRUST_add(int id, int flags, int (*ck)(X509_TRUST *, X509 *, int),
     char *name, int arg1, void *arg2);
void X509_TRUST_cleanup(void);
int X509_TRUST_get_flags(X509_TRUST *xp);
char *X509_TRUST_get0_name(X509_TRUST *xp);
int X509_TRUST_get_trust(X509_TRUST *xp);
void ERR_load_X509_strings(void);
# 157 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/pem.h" 1 3 4
# 62 "/usr/include/openssl/pem.h" 3 4
# 1 "/usr/include/openssl/e_os2.h" 1 3 4
# 56 "/usr/include/openssl/e_os2.h" 3 4
# 1 "/usr/include/openssl/opensslconf.h" 1 3 4
# 57 "/usr/include/openssl/e_os2.h" 2 3 4
# 63 "/usr/include/openssl/pem.h" 2 3 4
# 71 "/usr/include/openssl/pem.h" 3 4
# 1 "/usr/include/openssl/pem2.h" 1 3 4
# 72 "/usr/include/openssl/pem.h" 2 3 4
# 142 "/usr/include/openssl/pem.h" 3 4
typedef struct PEM_Encode_Seal_st
 EVP_ENCODE_CTX encode;
 EVP_MD_CTX md;
 EVP_CIPHER_CTX cipher;
 } PEM_ENCODE_SEAL_CTX;
typedef struct pem_recip_st
 char *name;
 X509_NAME *dn;
 int cipher;
 int key_enc;
 } PEM_USER;
typedef struct pem_ctx_st
 int type;
 struct {
  int version;
  int mode;
  } proc_type;
 char *domain;
 struct {
  int cipher;
  } DEK_info;
 PEM_USER *originator;
 int num_recipient;
 PEM_USER **recipient;
 EVP_MD *md;
 int md_enc;
 int md_len;
 char *md_data;
 EVP_CIPHER *dec;
 int key_len;
 unsigned char *key;
 int data_enc;
 int data_len;
 unsigned char *data;
 } PEM_CTX;
# 400 "/usr/include/openssl/pem.h" 3 4
typedef int pem_password_cb(char *buf, int size, int rwflag, void *userdata);
int PEM_get_EVP_CIPHER_INFO(char *header, EVP_CIPHER_INFO *cipher);
int PEM_do_header (EVP_CIPHER_INFO *cipher, unsigned char *data,long *len,
 pem_password_cb *callback,void *u);
int PEM_read_bio(BIO *bp, char **name, char **header,
  unsigned char **data,long *len);
int PEM_write_bio(BIO *bp,const char *name,char *hdr,unsigned char *data,
  long len);
int PEM_bytes_read_bio(unsigned char **pdata, long *plen, char **pnm, const char *name, BIO *bp,
      pem_password_cb *cb, void *u);
void * PEM_ASN1_read_bio(d2i_of_void *d2i, const char *name, BIO *bp,
     void **x, pem_password_cb *cb, void *u);
int PEM_ASN1_write_bio(i2d_of_void *i2d,const char *name,BIO *bp, void *x,
      const EVP_CIPHER *enc,unsigned char *kstr,int klen,
struct stack_st_X509_INFO * PEM_X509_INFO_read_bio(BIO *bp, struct stack_st_X509_INFO *sk, pem_password_cb *cb, void *u);
int PEM_X509_INFO_write_bio(BIO *bp,X509_INFO *xi, EVP_CIPHER *enc,
  unsigned char *kstr, int klen, pem_password_cb *cd, void *u);
int PEM_read(FILE *fp, char **name, char **header,
int PEM_write(FILE *fp,char *name,char *hdr,unsigned char *data,long len);
void * PEM_ASN1_read(d2i_of_void *d2i, const char *name, FILE *fp, void **x,
int PEM_ASN1_write(i2d_of_void *i2d,const char *name,FILE *fp,
         void *x,const EVP_CIPHER *enc,unsigned char *kstr,
         int klen,pem_password_cb *callback, void *u);
struct stack_st_X509_INFO * PEM_X509_INFO_read(FILE *fp, struct stack_st_X509_INFO *sk,
int PEM_SealInit(PEM_ENCODE_SEAL_CTX *ctx, EVP_CIPHER *type,
  EVP_MD *md_type, unsigned char **ek, int *ekl,
  unsigned char *iv, EVP_PKEY **pubk, int npubk);
void PEM_SealUpdate(PEM_ENCODE_SEAL_CTX *ctx, unsigned char *out, int *outl,
  unsigned char *in, int inl);
int PEM_SealFinal(PEM_ENCODE_SEAL_CTX *ctx, unsigned char *sig,int *sigl,
  unsigned char *out, int *outl, EVP_PKEY *priv);
void PEM_SignInit(EVP_MD_CTX *ctx, EVP_MD *type);
void PEM_SignUpdate(EVP_MD_CTX *ctx,unsigned char *d,unsigned int cnt);
int PEM_SignFinal(EVP_MD_CTX *ctx, unsigned char *sigret,
  unsigned int *siglen, EVP_PKEY *pkey);
int PEM_def_callback(char *buf, int num, int w, void *key);
void PEM_proc_type(char *buf, int type);
void PEM_dek_info(char *buf, const char *type, int len, char *str);
X509 *PEM_read_bio_X509(BIO *bp, X509 **x, pem_password_cb *cb, void *u); X509 *PEM_read_X509(FILE *fp, X509 **x, pem_password_cb *cb, void *u); int PEM_write_bio_X509(BIO *bp, X509 *x); int PEM_write_X509(FILE *fp, X509 *x);
X509 *PEM_read_bio_X509_AUX(BIO *bp, X509 **x, pem_password_cb *cb, void *u); X509 *PEM_read_X509_AUX(FILE *fp, X509 **x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_AUX(BIO *bp, X509 *x); int PEM_write_X509_AUX(FILE *fp, X509 *x);
X509_CERT_PAIR *PEM_read_bio_X509_CERT_PAIR(BIO *bp, X509_CERT_PAIR **x, pem_password_cb *cb, void *u); X509_CERT_PAIR *PEM_read_X509_CERT_PAIR(FILE *fp, X509_CERT_PAIR **x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_CERT_PAIR(BIO *bp, X509_CERT_PAIR *x); int PEM_write_X509_CERT_PAIR(FILE *fp, X509_CERT_PAIR *x);
X509_REQ *PEM_read_bio_X509_REQ(BIO *bp, X509_REQ **x, pem_password_cb *cb, void *u); X509_REQ *PEM_read_X509_REQ(FILE *fp, X509_REQ **x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_REQ(BIO *bp, X509_REQ *x); int PEM_write_X509_REQ(FILE *fp, X509_REQ *x);
int PEM_write_bio_X509_REQ_NEW(BIO *bp, X509_REQ *x); int PEM_write_X509_REQ_NEW(FILE *fp, X509_REQ *x);
X509_CRL *PEM_read_bio_X509_CRL(BIO *bp, X509_CRL **x, pem_password_cb *cb, void *u); X509_CRL *PEM_read_X509_CRL(FILE *fp, X509_CRL **x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_CRL(BIO *bp, X509_CRL *x); int PEM_write_X509_CRL(FILE *fp, X509_CRL *x);
PKCS7 *PEM_read_bio_PKCS7(BIO *bp, PKCS7 **x, pem_password_cb *cb, void *u); PKCS7 *PEM_read_PKCS7(FILE *fp, PKCS7 **x, pem_password_cb *cb, void *u); int PEM_write_bio_PKCS7(BIO *bp, PKCS7 *x); int PEM_write_PKCS7(FILE *fp, PKCS7 *x);
NETSCAPE_CERT_SEQUENCE *PEM_read_bio_NETSCAPE_CERT_SEQUENCE(BIO *bp, NETSCAPE_CERT_SEQUENCE **x, pem_password_cb *cb, void *u); NETSCAPE_CERT_SEQUENCE *PEM_read_NETSCAPE_CERT_SEQUENCE(FILE *fp, NETSCAPE_CERT_SEQUENCE **x, pem_password_cb *cb, void *u); int PEM_write_bio_NETSCAPE_CERT_SEQUENCE(BIO *bp, NETSCAPE_CERT_SEQUENCE *x); int PEM_write_NETSCAPE_CERT_SEQUENCE(FILE *fp, NETSCAPE_CERT_SEQUENCE *x);
X509_SIG *PEM_read_bio_PKCS8(BIO *bp, X509_SIG **x, pem_password_cb *cb, void *u); X509_SIG *PEM_read_PKCS8(FILE *fp, X509_SIG **x, pem_password_cb *cb, void *u); int PEM_write_bio_PKCS8(BIO *bp, X509_SIG *x); int PEM_write_PKCS8(FILE *fp, X509_SIG *x);
PKCS8_PRIV_KEY_INFO *PEM_read_bio_PKCS8_PRIV_KEY_INFO(BIO *bp, PKCS8_PRIV_KEY_INFO **x, pem_password_cb *cb, void *u); PKCS8_PRIV_KEY_INFO *PEM_read_PKCS8_PRIV_KEY_INFO(FILE *fp, PKCS8_PRIV_KEY_INFO **x, pem_password_cb *cb, void *u); int PEM_write_bio_PKCS8_PRIV_KEY_INFO(BIO *bp, PKCS8_PRIV_KEY_INFO *x); int PEM_write_PKCS8_PRIV_KEY_INFO(FILE *fp, PKCS8_PRIV_KEY_INFO *x);
RSA *PEM_read_bio_RSAPrivateKey(BIO *bp, RSA **x, pem_password_cb *cb, void *u); RSA *PEM_read_RSAPrivateKey(FILE *fp, RSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_RSAPrivateKey(BIO *bp, RSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u); int PEM_write_RSAPrivateKey(FILE *fp, RSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u);
RSA *PEM_read_bio_RSAPublicKey(BIO *bp, RSA **x, pem_password_cb *cb, void *u); RSA *PEM_read_RSAPublicKey(FILE *fp, RSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_RSAPublicKey(BIO *bp, const RSA *x); int PEM_write_RSAPublicKey(FILE *fp, const RSA *x);
RSA *PEM_read_bio_RSA_PUBKEY(BIO *bp, RSA **x, pem_password_cb *cb, void *u); RSA *PEM_read_RSA_PUBKEY(FILE *fp, RSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_RSA_PUBKEY(BIO *bp, RSA *x); int PEM_write_RSA_PUBKEY(FILE *fp, RSA *x);
DSA *PEM_read_bio_DSAPrivateKey(BIO *bp, DSA **x, pem_password_cb *cb, void *u); DSA *PEM_read_DSAPrivateKey(FILE *fp, DSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_DSAPrivateKey(BIO *bp, DSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u); int PEM_write_DSAPrivateKey(FILE *fp, DSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u);
DSA *PEM_read_bio_DSA_PUBKEY(BIO *bp, DSA **x, pem_password_cb *cb, void *u); DSA *PEM_read_DSA_PUBKEY(FILE *fp, DSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_DSA_PUBKEY(BIO *bp, DSA *x); int PEM_write_DSA_PUBKEY(FILE *fp, DSA *x);
DSA *PEM_read_bio_DSAparams(BIO *bp, DSA **x, pem_password_cb *cb, void *u); DSA *PEM_read_DSAparams(FILE *fp, DSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_DSAparams(BIO *bp, const DSA *x); int PEM_write_DSAparams(FILE *fp, const DSA *x);
EC_GROUP *PEM_read_bio_ECPKParameters(BIO *bp, EC_GROUP **x, pem_password_cb *cb, void *u); EC_GROUP *PEM_read_ECPKParameters(FILE *fp, EC_GROUP **x, pem_password_cb *cb, void *u); int PEM_write_bio_ECPKParameters(BIO *bp, const EC_GROUP *x); int PEM_write_ECPKParameters(FILE *fp, const EC_GROUP *x);
EC_KEY *PEM_read_bio_ECPrivateKey(BIO *bp, EC_KEY **x, pem_password_cb *cb, void *u); EC_KEY *PEM_read_ECPrivateKey(FILE *fp, EC_KEY **x, pem_password_cb *cb, void *u); int PEM_write_bio_ECPrivateKey(BIO *bp, EC_KEY *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u); int PEM_write_ECPrivateKey(FILE *fp, EC_KEY *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u);
EC_KEY *PEM_read_bio_EC_PUBKEY(BIO *bp, EC_KEY **x, pem_password_cb *cb, void *u); EC_KEY *PEM_read_EC_PUBKEY(FILE *fp, EC_KEY **x, pem_password_cb *cb, void *u); int PEM_write_bio_EC_PUBKEY(BIO *bp, EC_KEY *x); int PEM_write_EC_PUBKEY(FILE *fp, EC_KEY *x);
DH *PEM_read_bio_DHparams(BIO *bp, DH **x, pem_password_cb *cb, void *u); DH *PEM_read_DHparams(FILE *fp, DH **x, pem_password_cb *cb, void *u); int PEM_write_bio_DHparams(BIO *bp, const DH *x); int PEM_write_DHparams(FILE *fp, const DH *x);
EVP_PKEY *PEM_read_bio_PrivateKey(BIO *bp, EVP_PKEY **x, pem_password_cb *cb, void *u); EVP_PKEY *PEM_read_PrivateKey(FILE *fp, EVP_PKEY **x, pem_password_cb *cb, void *u); int PEM_write_bio_PrivateKey(BIO *bp, EVP_PKEY *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u); int PEM_write_PrivateKey(FILE *fp, EVP_PKEY *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u);
EVP_PKEY *PEM_read_bio_PUBKEY(BIO *bp, EVP_PKEY **x, pem_password_cb *cb, void *u); EVP_PKEY *PEM_read_PUBKEY(FILE *fp, EVP_PKEY **x, pem_password_cb *cb, void *u); int PEM_write_bio_PUBKEY(BIO *bp, EVP_PKEY *x); int PEM_write_PUBKEY(FILE *fp, EVP_PKEY *x);
int PEM_write_bio_PKCS8PrivateKey_nid(BIO *bp, EVP_PKEY *x, int nid,
int PEM_write_bio_PKCS8PrivateKey(BIO *, EVP_PKEY *, const EVP_CIPHER *,
                                  char *, int, pem_password_cb *, void *);
int i2d_PKCS8PrivateKey_bio(BIO *bp, EVP_PKEY *x, const EVP_CIPHER *enc,
int i2d_PKCS8PrivateKey_nid_bio(BIO *bp, EVP_PKEY *x, int nid,
EVP_PKEY *d2i_PKCS8PrivateKey_bio(BIO *bp, EVP_PKEY **x, pem_password_cb *cb, void *u);
int i2d_PKCS8PrivateKey_fp(FILE *fp, EVP_PKEY *x, const EVP_CIPHER *enc,
int i2d_PKCS8PrivateKey_nid_fp(FILE *fp, EVP_PKEY *x, int nid,
int PEM_write_PKCS8PrivateKey_nid(FILE *fp, EVP_PKEY *x, int nid,
EVP_PKEY *d2i_PKCS8PrivateKey_fp(FILE *fp, EVP_PKEY **x, pem_password_cb *cb, void *u);
int PEM_write_PKCS8PrivateKey(FILE *fp,EVP_PKEY *x,const EVP_CIPHER *enc,
         char *kstr,int klen, pem_password_cb *cd, void *u);
EVP_PKEY *PEM_read_bio_Parameters(BIO *bp, EVP_PKEY **x);
int PEM_write_bio_Parameters(BIO *bp, EVP_PKEY *x);
EVP_PKEY *b2i_PrivateKey(const unsigned char **in, long length);
EVP_PKEY *b2i_PublicKey(const unsigned char **in, long length);
EVP_PKEY *b2i_PrivateKey_bio(BIO *in);
EVP_PKEY *b2i_PublicKey_bio(BIO *in);
int i2b_PrivateKey_bio(BIO *out, EVP_PKEY *pk);
int i2b_PublicKey_bio(BIO *out, EVP_PKEY *pk);
EVP_PKEY *b2i_PVK_bio(BIO *in, pem_password_cb *cb, void *u);
int i2b_PVK_bio(BIO *out, EVP_PKEY *pk, int enclevel,
void ERR_load_PEM_strings(void);
# 163 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/hmac.h" 1 3 4
# 61 "/usr/include/openssl/hmac.h" 3 4
# 62 "/usr/include/openssl/hmac.h" 2 3 4
# 75 "/usr/include/openssl/hmac.h" 3 4
typedef struct hmac_ctx_st
 const EVP_MD *md;
 EVP_MD_CTX md_ctx;
 EVP_MD_CTX i_ctx;
 EVP_MD_CTX o_ctx;
 unsigned int key_length;
 unsigned char key[128];
 } HMAC_CTX;
void HMAC_CTX_init(HMAC_CTX *ctx);
void HMAC_CTX_cleanup(HMAC_CTX *ctx);
int HMAC_Init(HMAC_CTX *ctx, const void *key, int len,
        const EVP_MD *md);
int HMAC_Init_ex(HMAC_CTX *ctx, const void *key, int len,
    const EVP_MD *md, ENGINE *impl);
int HMAC_Update(HMAC_CTX *ctx, const unsigned char *data, size_t len);
int HMAC_Final(HMAC_CTX *ctx, unsigned char *md, unsigned int *len);
unsigned char *HMAC(const EVP_MD *evp_md, const void *key, int key_len,
      const unsigned char *d, size_t n, unsigned char *md,
      unsigned int *md_len);
int HMAC_CTX_copy(HMAC_CTX *dctx, HMAC_CTX *sctx);
void HMAC_CTX_set_flags(HMAC_CTX *ctx, unsigned long flags);
# 164 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/kssl.h" 1 3 4
# 66 "/usr/include/openssl/kssl.h" 3 4
# 67 "/usr/include/openssl/kssl.h" 2 3 4
# 166 "/usr/include/openssl/ssl.h" 2 3 4
# 365 "/usr/include/openssl/ssl.h" 3 4
typedef struct ssl_st *ssl_crock_st;
typedef struct tls_session_ticket_ext_st TLS_SESSION_TICKET_EXT;
typedef struct ssl_method_st SSL_METHOD;
typedef struct ssl_cipher_st SSL_CIPHER;
typedef struct ssl_session_st SSL_SESSION;
struct stack_st_SSL_CIPHER { _STACK stack; };
typedef struct srtp_protection_profile_st
       const char *name;
       unsigned long id;
       } SRTP_PROTECTION_PROFILE;
struct stack_st_SRTP_PROTECTION_PROFILE { _STACK stack; };
typedef int (*tls_session_ticket_ext_cb_fn)(SSL *s, const unsigned char *data, int len, void *arg);
typedef int (*tls_session_secret_cb_fn)(SSL *s, void *secret, int *secret_len, struct stack_st_SSL_CIPHER *peer_ciphers, SSL_CIPHER **cipher, void *arg);
 int valid;
 const char *name;
 unsigned long id;
 unsigned long algorithm_mkey;
 unsigned long algorithm_auth;
 unsigned long algorithm_enc;
 unsigned long algorithm_mac;
 unsigned long algorithm_ssl;
 unsigned long algo_strength;
 unsigned long algorithm2;
 int strength_bits;
 int alg_bits;
 int version;
 int (*ssl_new)(SSL *s);
 void (*ssl_clear)(SSL *s);
 void (*ssl_free)(SSL *s);
 int (*ssl_accept)(SSL *s);
 int (*ssl_connect)(SSL *s);
 int (*ssl_read)(SSL *s,void *buf,int len);
 int (*ssl_peek)(SSL *s,void *buf,int len);
 int (*ssl_write)(SSL *s,const void *buf,int len);
 int (*ssl_shutdown)(SSL *s);
 int (*ssl_renegotiate)(SSL *s);
 int (*ssl_renegotiate_check)(SSL *s);
 long (*ssl_get_message)(SSL *s, int st1, int stn, int mt, long
  max, int *ok);
 int (*ssl_read_bytes)(SSL *s, int type, unsigned char *buf, int len,
  int peek);
 int (*ssl_write_bytes)(SSL *s, int type, const void *buf_, int len);
 int (*ssl_dispatch_alert)(SSL *s);
 long (*ssl_ctrl)(SSL *s,int cmd,long larg,void *parg);
 long (*ssl_ctx_ctrl)(SSL_CTX *ctx,int cmd,long larg,void *parg);
 const SSL_CIPHER *(*get_cipher_by_char)(const unsigned char *ptr);
 int (*put_cipher_by_char)(const SSL_CIPHER *cipher,unsigned char *ptr);
 int (*ssl_pending)(const SSL *s);
 int (*num_ciphers)(void);
 const SSL_CIPHER *(*get_cipher)(unsigned ncipher);
 const struct ssl_method_st *(*get_ssl_method)(int version);
 long (*get_timeout)(void);
 struct ssl3_enc_method *ssl3_enc;
 int (*ssl_version)(void);
 long (*ssl_callback_ctrl)(SSL *s, int cb_id, void (*fp)(void));
 long (*ssl_ctx_callback_ctrl)(SSL_CTX *s, int cb_id, void (*fp)(void));
# 470 "/usr/include/openssl/ssl.h" 3 4
 int ssl_version;
 unsigned int key_arg_length;
 unsigned char key_arg[8];
 int master_key_length;
 unsigned char master_key[48];
 unsigned int session_id_length;
 unsigned char session_id[32];
 unsigned int sid_ctx_length;
 unsigned char sid_ctx[32];
 char *psk_identity_hint;
 char *psk_identity;
 int not_resumable;
 struct sess_cert_st *sess_cert;
 X509 *peer;
 long verify_result;
 int references;
 long timeout;
 long time;
 unsigned int compress_meth;
 const SSL_CIPHER *cipher;
 unsigned long cipher_id;
 struct stack_st_SSL_CIPHER *ciphers;
 CRYPTO_EX_DATA ex_data;
 struct ssl_session_st *prev,*next;
 char *tlsext_hostname;
 size_t tlsext_ecpointformatlist_length;
 unsigned char *tlsext_ecpointformatlist;
 size_t tlsext_ellipticcurvelist_length;
 unsigned char *tlsext_ellipticcurvelist;
 unsigned char *tlsext_tick;
 size_t tlsext_ticklen;
 long tlsext_tick_lifetime_hint;
 char *srp_username;
# 700 "/usr/include/openssl/ssl.h" 3 4
void SSL_CTX_set_msg_callback(SSL_CTX *ctx, void (*cb)(int write_p, int version, int content_type, const void *buf, size_t len, SSL *ssl, void *arg));
void SSL_set_msg_callback(SSL *ssl, void (*cb)(int write_p, int version, int content_type, const void *buf, size_t len, SSL *ssl, void *arg));
typedef struct srp_ctx_st
 void *SRP_cb_arg;
 int (*TLS_ext_srp_username_callback)(SSL *, int *, void *);
 int (*SRP_verify_param_callback)(SSL *, void *);
 char *(*SRP_give_srp_client_pwd_callback)(SSL *, void *);
 char *login;
 BIGNUM *N,*g,*s,*B,*A;
 BIGNUM *a,*b,*v;
 char *info;
 int strength;
 unsigned long srp_Mask;
 } SRP_CTX;
int SSL_SRP_CTX_init(SSL *s);
int SSL_CTX_SRP_CTX_init(SSL_CTX *ctx);
int SSL_SRP_CTX_free(SSL *ctx);
int SSL_CTX_SRP_CTX_free(SSL_CTX *ctx);
int SSL_srp_server_param_with_username(SSL *s, int *ad);
int SRP_generate_server_master_secret(SSL *s,unsigned char *master_key);
int SRP_Calc_A_param(SSL *s);
int SRP_generate_client_master_secret(SSL *s,unsigned char *master_key);
# 764 "/usr/include/openssl/ssl.h" 3 4
typedef int (*GEN_SESSION_CB)(const SSL *ssl, unsigned char *id,
    unsigned int *id_len);
typedef struct ssl_comp_st SSL_COMP;
struct ssl_comp_st
 int id;
 const char *name;
 COMP_METHOD *method;
struct stack_st_SSL_COMP { _STACK stack; };
struct lhash_st_SSL_SESSION { int dummy; };
struct ssl_ctx_st
 const SSL_METHOD *method;
 struct stack_st_SSL_CIPHER *cipher_list;
 struct stack_st_SSL_CIPHER *cipher_list_by_id;
 struct x509_store_st *cert_store;
 struct lhash_st_SSL_SESSION *sessions;
 unsigned long session_cache_size;
 struct ssl_session_st *session_cache_head;
 struct ssl_session_st *session_cache_tail;
 int session_cache_mode;
 long session_timeout;
# 821 "/usr/include/openssl/ssl.h" 3 4
 int (*new_session_cb)(struct ssl_st *ssl,SSL_SESSION *sess);
 void (*remove_session_cb)(struct ssl_ctx_st *ctx,SSL_SESSION *sess);
 SSL_SESSION *(*get_session_cb)(struct ssl_st *ssl,
  unsigned char *data,int len,int *copy);
 struct
  int sess_connect;
  int sess_connect_renegotiate;
  int sess_connect_good;
  int sess_accept;
  int sess_accept_renegotiate;
  int sess_accept_good;
  int sess_miss;
  int sess_timeout;
  int sess_cache_full;
  int sess_hit;
  int sess_cb_hit;
  } stats;
 int references;
 int (*app_verify_callback)(X509_STORE_CTX *, void *);
 void *app_verify_arg;
 pem_password_cb *default_passwd_callback;
 void *default_passwd_callback_userdata;
 int (*client_cert_cb)(SSL *ssl, X509 **x509, EVP_PKEY **pkey);
    int (*app_gen_cookie_cb)(SSL *ssl, unsigned char *cookie,
        unsigned int *cookie_len);
    int (*app_verify_cookie_cb)(SSL *ssl, unsigned char *cookie,
        unsigned int cookie_len);
 const EVP_MD *rsa_md5;
 const EVP_MD *md5;
 const EVP_MD *sha1;
 struct stack_st_X509 *extra_certs;
 struct stack_st_SSL_COMP *comp_methods;
 void (*info_callback)(const SSL *ssl,int type,int val);
 struct stack_st_X509_NAME *client_CA;
 unsigned long options;
 unsigned long mode;
 long max_cert_list;
 struct cert_st *cert;
 int read_ahead;
 void (*msg_callback)(int write_p, int version, int content_type, const void *buf, size_t len, SSL *ssl, void *arg);
 void *msg_callback_arg;
 int verify_mode;
 int (*default_verify_callback)(int ok,X509_STORE_CTX *ctx);
 GEN_SESSION_CB generate_session_id;
 X509_VERIFY_PARAM *param;
 int quiet_shutdown;
 unsigned int max_send_fragment;
 ENGINE *client_cert_engine;
 int (*tlsext_servername_callback)(SSL*, int *, void *);
 void *tlsext_servername_arg;
 unsigned char tlsext_tick_key_name[16];
 unsigned char tlsext_tick_hmac_key[16];
 unsigned char tlsext_tick_aes_key[16];
 int (*tlsext_ticket_key_cb)(SSL *ssl,
     unsigned char *name, unsigned char *iv,
     EVP_CIPHER_CTX *ectx,
      HMAC_CTX *hctx, int enc);
 int (*tlsext_status_cb)(SSL *ssl, void *arg);
 void *tlsext_status_arg;
 int (*tlsext_opaque_prf_input_callback)(SSL *, void *peerinput, size_t len, void *arg);
 void *tlsext_opaque_prf_input_callback_arg;
 unsigned int (*psk_client_callback)(SSL *ssl, const char *hint, char *identity,
  unsigned int max_identity_len, unsigned char *psk,
  unsigned int max_psk_len);
 unsigned int (*psk_server_callback)(SSL *ssl, const char *identity,
  unsigned char *psk, unsigned int max_psk_len);
 unsigned int freelist_max_len;
 struct ssl3_buf_freelist_st *wbuf_freelist;
 struct ssl3_buf_freelist_st *rbuf_freelist;
 SRP_CTX srp_ctx;
# 982 "/usr/include/openssl/ssl.h" 3 4
 int (*next_protos_advertised_cb)(SSL *s, const unsigned char **buf,
                    unsigned int *len, void *arg);
 void *next_protos_advertised_cb_arg;
 int (*next_proto_select_cb)(SSL *s, unsigned char **out,
        unsigned char *outlen,
        const unsigned char *in,
        unsigned int inlen,
        void *arg);
 void *next_proto_select_cb_arg;
        struct stack_st_SRTP_PROTECTION_PROFILE *srtp_profiles;
# 1012 "/usr/include/openssl/ssl.h" 3 4
struct lhash_st_SSL_SESSION *SSL_CTX_sessions(SSL_CTX *ctx);
# 1038 "/usr/include/openssl/ssl.h" 3 4
void SSL_CTX_sess_set_new_cb(SSL_CTX *ctx, int (*new_session_cb)(struct ssl_st *ssl,SSL_SESSION *sess));
int (*SSL_CTX_sess_get_new_cb(SSL_CTX *ctx))(struct ssl_st *ssl, SSL_SESSION *sess);
void SSL_CTX_sess_set_remove_cb(SSL_CTX *ctx, void (*remove_session_cb)(struct ssl_ctx_st *ctx,SSL_SESSION *sess));
void (*SSL_CTX_sess_get_remove_cb(SSL_CTX *ctx))(struct ssl_ctx_st *ctx, SSL_SESSION *sess);
void SSL_CTX_sess_set_get_cb(SSL_CTX *ctx, SSL_SESSION *(*get_session_cb)(struct ssl_st *ssl, unsigned char *data,int len,int *copy));
SSL_SESSION *(*SSL_CTX_sess_get_get_cb(SSL_CTX *ctx))(struct ssl_st *ssl, unsigned char *Data, int len, int *copy);
void SSL_CTX_set_info_callback(SSL_CTX *ctx, void (*cb)(const SSL *ssl,int type,int val));
void (*SSL_CTX_get_info_callback(SSL_CTX *ctx))(const SSL *ssl,int type,int val);
void SSL_CTX_set_client_cert_cb(SSL_CTX *ctx, int (*client_cert_cb)(SSL *ssl, X509 **x509, EVP_PKEY **pkey));
int (*SSL_CTX_get_client_cert_cb(SSL_CTX *ctx))(SSL *ssl, X509 **x509, EVP_PKEY **pkey);
int SSL_CTX_set_client_cert_engine(SSL_CTX *ctx, ENGINE *e);
void SSL_CTX_set_cookie_generate_cb(SSL_CTX *ctx, int (*app_gen_cookie_cb)(SSL *ssl, unsigned char *cookie, unsigned int *cookie_len));
void SSL_CTX_set_cookie_verify_cb(SSL_CTX *ctx, int (*app_verify_cookie_cb)(SSL *ssl, unsigned char *cookie, unsigned int cookie_len));
void SSL_CTX_set_next_protos_advertised_cb(SSL_CTX *s,
        int (*cb) (SSL *ssl,
            const unsigned char **out,
            unsigned int *outlen,
            void *arg),
        void *arg);
void SSL_CTX_set_next_proto_select_cb(SSL_CTX *s,
       unsigned int inlen,
       void *arg),
          void *arg);
int SSL_select_next_proto(unsigned char **out, unsigned char *outlen,
     const unsigned char *in, unsigned int inlen,
     const unsigned char *client, unsigned int client_len);
void SSL_get0_next_proto_negotiated(const SSL *s,
        const unsigned char **data, unsigned *len);
# 1085 "/usr/include/openssl/ssl.h" 3 4
void SSL_CTX_set_psk_client_callback(SSL_CTX *ctx,
  char *identity, unsigned int max_identity_len, unsigned char *psk,
  unsigned int max_psk_len));
void SSL_set_psk_client_callback(SSL *ssl,
void SSL_CTX_set_psk_server_callback(SSL_CTX *ctx,
  unsigned char *psk, unsigned int max_psk_len));
void SSL_set_psk_server_callback(SSL *ssl,
int SSL_CTX_use_psk_identity_hint(SSL_CTX *ctx, const char *identity_hint);
int SSL_use_psk_identity_hint(SSL *s, const char *identity_hint);
const char *SSL_get_psk_identity_hint(const SSL *s);
const char *SSL_get_psk_identity(const SSL *s);
# 1121 "/usr/include/openssl/ssl.h" 3 4
struct ssl_st
 int version;
 int type;
 BIO *rbio;
 BIO *wbio;
 BIO *bbio;
# 1149 "/usr/include/openssl/ssl.h" 3 4
 int rwstate;
 int in_handshake;
 int (*handshake_func)(SSL *);
# 1163 "/usr/include/openssl/ssl.h" 3 4
 int server;
 int new_session;
 int quiet_shutdown;
 int shutdown;
 int state;
 int rstate;
 BUF_MEM *init_buf;
 void *init_msg;
 int init_num;
 int init_off;
 unsigned char *packet;
 unsigned int packet_length;
 struct ssl2_state_st *s2;
 struct ssl3_state_st *s3;
 struct dtls1_state_st *d1;
 int read_ahead;
 int hit;
 int mac_flags;
 EVP_CIPHER_CTX *enc_read_ctx;
 EVP_MD_CTX *read_hash;
 COMP_CTX *expand;
 EVP_CIPHER_CTX *enc_write_ctx;
 EVP_MD_CTX *write_hash;
 COMP_CTX *compress;
# 1231 "/usr/include/openssl/ssl.h" 3 4
 SSL_SESSION *session;
 int verify_mode;
 int (*verify_callback)(int ok,X509_STORE_CTX *ctx);
 int error;
 int error_code;
 SSL_CTX *ctx;
 int debug;
 long verify_result;
 int references;
 unsigned long mode;
 long max_cert_list;
 int first_packet;
 int client_version;
 void (*tlsext_debug_cb)(SSL *s, int client_server, int type,
     void *arg);
 void *tlsext_debug_arg;
 int servername_done;
 int tlsext_status_type;
 int tlsext_status_expected;
 struct stack_st_OCSP_RESPID *tlsext_ocsp_ids;
 X509_EXTENSIONS *tlsext_ocsp_exts;
 unsigned char *tlsext_ocsp_resp;
 int tlsext_ocsp_resplen;
 int tlsext_ticket_expected;
 void *tlsext_opaque_prf_input;
 size_t tlsext_opaque_prf_input_len;
 TLS_SESSION_TICKET_EXT *tlsext_session_ticket;
 tls_session_ticket_ext_cb_fn tls_session_ticket_ext_cb;
 void *tls_session_ticket_ext_cb_arg;
 tls_session_secret_cb_fn tls_session_secret_cb;
 void *tls_session_secret_cb_arg;
 SSL_CTX * initial_ctx;
# 1344 "/usr/include/openssl/ssl.h" 3 4
 unsigned char *next_proto_negotiated;
 unsigned char next_proto_negotiated_len;
 SRTP_PROTECTION_PROFILE *srtp_profile;
 unsigned int tlsext_heartbeat;
 unsigned int tlsext_hb_pending;
 unsigned int tlsext_hb_seq;
 int renegotiate;
 SRP_CTX srp_ctx;
# 1 "/usr/include/openssl/ssl2.h" 1 3 4
# 160 "/usr/include/openssl/ssl2.h" 3 4
typedef struct ssl2_state_st
 int three_byte_header;
 int clear_text;
 int escape;
 int ssl2_rollback;
 unsigned int wnum;
 int wpend_tot;
 const unsigned char *wpend_buf;
 int wpend_off;
 int wpend_len;
 int wpend_ret;
 int rbuf_left;
 int rbuf_offs;
 unsigned char *rbuf;
 unsigned char *wbuf;
 unsigned char *write_ptr;
 unsigned int padding;
 unsigned int rlength;
 int ract_data_length;
 unsigned int wlength;
 int wact_data_length;
 unsigned char *ract_data;
 unsigned char *wact_data;
 unsigned char *mac_data;
 unsigned char *read_key;
 unsigned char *write_key;
 unsigned int challenge_length;
 unsigned char challenge[32];
 unsigned int conn_id_length;
 unsigned char conn_id[16];
 unsigned int key_material_length;
 unsigned char key_material[24*2];
 unsigned long read_sequence;
 unsigned long write_sequence;
 struct {
  unsigned int cert_type;
  unsigned int cert_length;
  unsigned int csl;
  unsigned int clear;
  unsigned int enc;
  unsigned char ccl[32];
  unsigned int cipher_spec_length;
  unsigned int clen;
  unsigned int rlen;
  } tmp;
 } SSL2_STATE;
# 1380 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/ssl3.h" 1 3 4
# 125 "/usr/include/openssl/ssl3.h" 3 4
# 1 "/usr/include/openssl/ssl.h" 1 3 4
# 126 "/usr/include/openssl/ssl3.h" 2 3 4
# 353 "/usr/include/openssl/ssl3.h" 3 4
typedef struct ssl3_record_st
       int type;
       unsigned int length;
       unsigned int off;
       unsigned char *input;
       unsigned char *comp;
        unsigned long epoch;
        unsigned char seq_num[8];
 } SSL3_RECORD;
typedef struct ssl3_buffer_st
 unsigned char *buf;
 size_t len;
 int offset;
 int left;
 } SSL3_BUFFER;
# 411 "/usr/include/openssl/ssl3.h" 3 4
typedef struct ssl3_state_st
 long flags;
 int delay_buf_pop_ret;
 unsigned char read_sequence[8];
 int read_mac_secret_size;
 unsigned char read_mac_secret[64];
 unsigned char write_sequence[8];
 int write_mac_secret_size;
 unsigned char write_mac_secret[64];
 unsigned char server_random[32];
 unsigned char client_random[32];
 int need_empty_fragments;
 int empty_fragment_done;
 int init_extra;
 SSL3_BUFFER rbuf;
 SSL3_BUFFER wbuf;
 SSL3_RECORD rrec;
 SSL3_RECORD wrec;
 unsigned char alert_fragment[2];
 unsigned int alert_fragment_len;
 unsigned char handshake_fragment[4];
 unsigned int handshake_fragment_len;
 unsigned int wnum;
 int wpend_tot;
 int wpend_type;
 int wpend_ret;
 BIO *handshake_buffer;
 EVP_MD_CTX **handshake_dgst;
 int change_cipher_spec;
 int warn_alert;
 int fatal_alert;
 int alert_dispatch;
 unsigned char send_alert[2];
 int renegotiate;
 int total_renegotiations;
 int num_renegotiations;
 int in_read_app_data;
 void *client_opaque_prf_input;
 size_t client_opaque_prf_input_len;
 void *server_opaque_prf_input;
 size_t server_opaque_prf_input_len;
 struct {
  unsigned char cert_verify_md[64*2];
  unsigned char finish_md[64*2];
  int finish_md_len;
  unsigned char peer_finish_md[64*2];
  int peer_finish_md_len;
  unsigned long message_size;
  int message_type;
  const SSL_CIPHER *new_cipher;
  DH *dh;
  EC_KEY *ecdh;
  int next_state;
  int reuse_message;
  int cert_req;
  int ctype_num;
  char ctype[9];
  struct stack_st_X509_NAME *ca_names;
  int use_rsa_tmp;
  int key_block_length;
  unsigned char *key_block;
  const EVP_CIPHER *new_sym_enc;
  const EVP_MD *new_hash;
  int new_mac_pkey_type;
  int new_mac_secret_size;
  const SSL_COMP *new_compression;
  int cert_request;
  } tmp;
        unsigned char previous_client_finished[64];
        unsigned char previous_client_finished_len;
        unsigned char previous_server_finished[64];
        unsigned char previous_server_finished_len;
        int send_connection_binding;
 int next_proto_neg_seen;
 char is_probably_safari;
 } SSL3_STATE;
# 1381 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/tls1.h" 1 3 4
# 291 "/usr/include/openssl/tls1.h" 3 4
const char *SSL_get_servername(const SSL *s, const int type);
int SSL_get_servername_type(const SSL *s);
int SSL_export_keying_material(SSL *s, unsigned char *out, size_t olen,
 const char *label, size_t llen, const unsigned char *p, size_t plen,
 int use_context);
# 735 "/usr/include/openssl/tls1.h" 3 4
 unsigned short length;
 void *data;
# 1382 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/dtls1.h" 1 3 4
# 64 "/usr/include/openssl/dtls1.h" 3 4
# 1 "/usr/include/openssl/pqueue.h" 1 3 4
# 65 "/usr/include/openssl/pqueue.h" 3 4
# 1 "/usr/include/string.h" 1 3 4
# 27 "/usr/include/string.h" 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 1 3 4
# 33 "/usr/include/string.h" 2 3 4
# 44 "/usr/include/string.h" 3 4
extern void *memcpy (void *__restrict __dest, const void *__restrict __src,
       size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern void *memmove (void *__dest, const void *__src, size_t __n)
extern void *memccpy (void *__restrict __dest, const void *__restrict __src,
        int __c, size_t __n)
extern void *memset (void *__s, int __c, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int memcmp (const void *__s1, const void *__s2, size_t __n)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
# 96 "/usr/include/string.h" 3 4
extern void *memchr (const void *__s, int __c, size_t __n)
      __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
# 127 "/usr/include/string.h" 3 4
extern char *strcpy (char *__restrict __dest, const char *__restrict __src)
extern char *strncpy (char *__restrict __dest,
        const char *__restrict __src, size_t __n)
extern char *strcat (char *__restrict __dest, const char *__restrict __src)
extern char *strncat (char *__restrict __dest, const char *__restrict __src,
extern int strcmp (const char *__s1, const char *__s2)
extern int strncmp (const char *__s1, const char *__s2, size_t __n)
extern int strcoll (const char *__s1, const char *__s2)
extern size_t strxfrm (char *__restrict __dest,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 166 "/usr/include/string.h" 3 4
extern int strcoll_l (const char *__s1, const char *__s2, __locale_t __l)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern size_t strxfrm_l (char *__dest, const char *__src, size_t __n,
    __locale_t __l) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern char *strdup (const char *__s)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) __attribute__ ((__nonnull__ (1)));
extern char *strndup (const char *__string, size_t __n)
# 210 "/usr/include/string.h" 3 4
# 235 "/usr/include/string.h" 3 4
extern char *strchr (const char *__s, int __c)
# 262 "/usr/include/string.h" 3 4
extern char *strrchr (const char *__s, int __c)
# 281 "/usr/include/string.h" 3 4
extern size_t strcspn (const char *__s, const char *__reject)
extern size_t strspn (const char *__s, const char *__accept)
# 314 "/usr/include/string.h" 3 4
extern char *strpbrk (const char *__s, const char *__accept)
# 341 "/usr/include/string.h" 3 4
extern char *strstr (const char *__haystack, const char *__needle)
extern char *strtok (char *__restrict __s, const char *__restrict __delim)
extern char *__strtok_r (char *__restrict __s,
    const char *__restrict __delim,
    char **__restrict __save_ptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3)));
extern char *strtok_r (char *__restrict __s, const char *__restrict __delim,
# 396 "/usr/include/string.h" 3 4
extern size_t strlen (const char *__s)
extern size_t strnlen (const char *__string, size_t __maxlen)
extern char *strerror (int __errnum) __attribute__ ((__nothrow__ , __leaf__));
# 426 "/usr/include/string.h" 3 4
extern int strerror_r (int __errnum, char *__buf, size_t __buflen) __asm__ ("" "__xpg_strerror_r") __attribute__ ((__nothrow__ , __leaf__))
# 444 "/usr/include/string.h" 3 4
extern char *strerror_l (int __errnum, __locale_t __l) __attribute__ ((__nothrow__ , __leaf__));
extern void __bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern void bcopy (const void *__src, void *__dest, size_t __n)
extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
# 488 "/usr/include/string.h" 3 4
extern char *index (const char *__s, int __c)
# 516 "/usr/include/string.h" 3 4
extern char *rindex (const char *__s, int __c)
extern int ffs (int __i) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 533 "/usr/include/string.h" 3 4
extern int strcasecmp (const char *__s1, const char *__s2)
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
# 556 "/usr/include/string.h" 3 4
extern char *strsep (char **__restrict __stringp,
extern char *strsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern char *__stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *__stpncpy (char *__restrict __dest,
extern char *stpncpy (char *__restrict __dest,
# 643 "/usr/include/string.h" 3 4
# 66 "/usr/include/openssl/pqueue.h" 2 3 4
typedef struct _pqueue *pqueue;
typedef struct _pitem
 unsigned char priority[8];
 void *data;
 struct _pitem *next;
 } pitem;
typedef struct _pitem *piterator;
pitem *pitem_new(unsigned char *prio64be, void *data);
void pitem_free(pitem *item);
pqueue pqueue_new(void);
void pqueue_free(pqueue pq);
pitem *pqueue_insert(pqueue pq, pitem *item);
pitem *pqueue_peek(pqueue pq);
pitem *pqueue_pop(pqueue pq);
pitem *pqueue_find(pqueue pq, unsigned char *prio64be);
pitem *pqueue_iterator(pqueue pq);
pitem *pqueue_next(piterator *iter);
void pqueue_print(pqueue pq);
int pqueue_size(pqueue pq);
# 65 "/usr/include/openssl/dtls1.h" 2 3 4
# 78 "/usr/include/openssl/dtls1.h" 3 4
# 1 "/usr/include/sys/time.h" 1 3 4
# 27 "/usr/include/sys/time.h" 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 28 "/usr/include/sys/time.h" 2 3 4
# 37 "/usr/include/sys/time.h" 3 4
# 55 "/usr/include/sys/time.h" 3 4
struct timezone
    int tz_minuteswest;
    int tz_dsttime;
typedef struct timezone *__restrict __timezone_ptr_t;
# 71 "/usr/include/sys/time.h" 3 4
extern int gettimeofday (struct timeval *__restrict __tv,
    __timezone_ptr_t __tz) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int settimeofday (const struct timeval *__tv,
    const struct timezone *__tz)
extern int adjtime (const struct timeval *__delta,
      struct timeval *__olddelta) __attribute__ ((__nothrow__ , __leaf__));
enum __itimer_which
    ITIMER_REAL = 0,
    ITIMER_VIRTUAL = 1,
    ITIMER_PROF = 2
struct itimerval
    struct timeval it_interval;
    struct timeval it_value;
typedef int __itimer_which_t;
extern int getitimer (__itimer_which_t __which,
        struct itimerval *__value) __attribute__ ((__nothrow__ , __leaf__));
extern int setitimer (__itimer_which_t __which,
        const struct itimerval *__restrict __new,
        struct itimerval *__restrict __old) __attribute__ ((__nothrow__ , __leaf__));
extern int utimes (const char *__file, const struct timeval __tvp[2])
extern int lutimes (const char *__file, const struct timeval __tvp[2])
extern int futimes (int __fd, const struct timeval __tvp[2]) __attribute__ ((__nothrow__ , __leaf__));
# 189 "/usr/include/sys/time.h" 3 4
# 79 "/usr/include/openssl/dtls1.h" 2 3 4
# 120 "/usr/include/openssl/dtls1.h" 3 4
typedef struct dtls1_bitmap_st
 unsigned long map;
 unsigned char max_seq_num[8];
 } DTLS1_BITMAP;
struct dtls1_retransmit_state
 COMP_CTX *compress;
 unsigned short epoch;
struct hm_header_st
 unsigned char type;
 unsigned long msg_len;
 unsigned short seq;
 unsigned long frag_off;
 unsigned long frag_len;
 unsigned int is_ccs;
 struct dtls1_retransmit_state saved_retransmit_state;
struct ccs_header_st
 unsigned char type;
 unsigned short seq;
struct dtls1_timeout_st
 unsigned int read_timeouts;
 unsigned int write_timeouts;
 unsigned int num_alerts;
typedef struct record_pqueue_st
 pqueue q;
 } record_pqueue;
typedef struct hm_fragment_st
 struct hm_header_st msg_header;
 unsigned char *fragment;
 unsigned char *reassembly;
 } hm_fragment;
typedef struct dtls1_state_st
 unsigned int send_cookie;
 unsigned char cookie[256];
 unsigned char rcvd_cookie[256];
 unsigned int cookie_len;
 unsigned short r_epoch;
 unsigned short w_epoch;
 DTLS1_BITMAP bitmap;
 DTLS1_BITMAP next_bitmap;
 unsigned short handshake_write_seq;
 unsigned short next_handshake_write_seq;
 unsigned short handshake_read_seq;
 unsigned char last_write_sequence[8];
 record_pqueue unprocessed_rcds;
 record_pqueue processed_rcds;
 pqueue buffered_messages;
 pqueue sent_messages;
 record_pqueue buffered_app_data;
 unsigned int listen;
 unsigned int mtu;
 struct hm_header_st w_msg_hdr;
 struct hm_header_st r_msg_hdr;
 struct dtls1_timeout_st timeout;
 struct timeval next_timeout;
 unsigned short timeout_duration;
 unsigned char handshake_fragment[12];
 unsigned int retransmitting;
 unsigned int change_cipher_spec_ok;
# 264 "/usr/include/openssl/dtls1.h" 3 4
 } DTLS1_STATE;
typedef struct dtls1_record_data_st
 SSL3_BUFFER rbuf;
 SSL3_RECORD rrec;
 } DTLS1_RECORD_DATA;
# 1383 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/ssl23.h" 1 3 4
# 1384 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/srtp.h" 1 3 4
# 135 "/usr/include/openssl/srtp.h" 3 4
int SSL_CTX_set_tlsext_use_srtp(SSL_CTX *ctx, const char *profiles);
int SSL_set_tlsext_use_srtp(SSL *ctx, const char *profiles);
SRTP_PROTECTION_PROFILE *SSL_get_selected_srtp_profile(SSL *s);
struct stack_st_SRTP_PROTECTION_PROFILE *SSL_get_srtp_profiles(SSL *ssl);
# 1385 "/usr/include/openssl/ssl.h" 2 3 4
# 1445 "/usr/include/openssl/ssl.h" 3 4
size_t SSL_get_finished(const SSL *s, void *buf, size_t count);
size_t SSL_get_peer_finished(const SSL *s, void *buf, size_t count);
# 1483 "/usr/include/openssl/ssl.h" 3 4
SSL_SESSION *PEM_read_bio_SSL_SESSION(BIO *bp, SSL_SESSION **x, pem_password_cb *cb, void *u); SSL_SESSION *PEM_read_SSL_SESSION(FILE *fp, SSL_SESSION **x, pem_password_cb *cb, void *u); int PEM_write_bio_SSL_SESSION(BIO *bp, SSL_SESSION *x); int PEM_write_SSL_SESSION(FILE *fp, SSL_SESSION *x);
# 1673 "/usr/include/openssl/ssl.h" 3 4
BIO_METHOD *BIO_f_ssl(void);
BIO *BIO_new_ssl(SSL_CTX *ctx,int client);
BIO *BIO_new_ssl_connect(SSL_CTX *ctx);
BIO *BIO_new_buffer_ssl_connect(SSL_CTX *ctx);
int BIO_ssl_copy_session_id(BIO *to,BIO *from);
void BIO_ssl_shutdown(BIO *ssl_bio);
int SSL_CTX_set_cipher_list(SSL_CTX *,const char *str);
SSL_CTX *SSL_CTX_new(const SSL_METHOD *meth);
void SSL_CTX_free(SSL_CTX *);
long SSL_CTX_set_timeout(SSL_CTX *ctx,long t);
long SSL_CTX_get_timeout(const SSL_CTX *ctx);
X509_STORE *SSL_CTX_get_cert_store(const SSL_CTX *);
void SSL_CTX_set_cert_store(SSL_CTX *,X509_STORE *);
int SSL_want(const SSL *s);
int SSL_clear(SSL *s);
void SSL_CTX_flush_sessions(SSL_CTX *ctx,long tm);
const SSL_CIPHER *SSL_get_current_cipher(const SSL *s);
int SSL_CIPHER_get_bits(const SSL_CIPHER *c,int *alg_bits);
char * SSL_CIPHER_get_version(const SSL_CIPHER *c);
const char * SSL_CIPHER_get_name(const SSL_CIPHER *c);
unsigned long SSL_CIPHER_get_id(const SSL_CIPHER *c);
int SSL_get_fd(const SSL *s);
int SSL_get_rfd(const SSL *s);
int SSL_get_wfd(const SSL *s);
const char * SSL_get_cipher_list(const SSL *s,int n);
char * SSL_get_shared_ciphers(const SSL *s, char *buf, int len);
int SSL_get_read_ahead(const SSL * s);
int SSL_pending(const SSL *s);
int SSL_set_fd(SSL *s, int fd);
int SSL_set_rfd(SSL *s, int fd);
int SSL_set_wfd(SSL *s, int fd);
void SSL_set_bio(SSL *s, BIO *rbio,BIO *wbio);
BIO * SSL_get_rbio(const SSL *s);
BIO * SSL_get_wbio(const SSL *s);
int SSL_set_cipher_list(SSL *s, const char *str);
void SSL_set_read_ahead(SSL *s, int yes);
int SSL_get_verify_mode(const SSL *s);
int SSL_get_verify_depth(const SSL *s);
int (*SSL_get_verify_callback(const SSL *s))(int,X509_STORE_CTX *);
void SSL_set_verify(SSL *s, int mode,
         int (*callback)(int ok,X509_STORE_CTX *ctx));
void SSL_set_verify_depth(SSL *s, int depth);
int SSL_use_RSAPrivateKey(SSL *ssl, RSA *rsa);
int SSL_use_RSAPrivateKey_ASN1(SSL *ssl, unsigned char *d, long len);
int SSL_use_PrivateKey(SSL *ssl, EVP_PKEY *pkey);
int SSL_use_PrivateKey_ASN1(int pk,SSL *ssl, const unsigned char *d, long len);
int SSL_use_certificate(SSL *ssl, X509 *x);
int SSL_use_certificate_ASN1(SSL *ssl, const unsigned char *d, int len);
int SSL_use_RSAPrivateKey_file(SSL *ssl, const char *file, int type);
int SSL_use_PrivateKey_file(SSL *ssl, const char *file, int type);
int SSL_use_certificate_file(SSL *ssl, const char *file, int type);
int SSL_CTX_use_RSAPrivateKey_file(SSL_CTX *ctx, const char *file, int type);
int SSL_CTX_use_PrivateKey_file(SSL_CTX *ctx, const char *file, int type);
int SSL_CTX_use_certificate_file(SSL_CTX *ctx, const char *file, int type);
int SSL_CTX_use_certificate_chain_file(SSL_CTX *ctx, const char *file);
struct stack_st_X509_NAME *SSL_load_client_CA_file(const char *file);
int SSL_add_file_cert_subjects_to_stack(struct stack_st_X509_NAME *stackCAs,
         const char *file);
int SSL_add_dir_cert_subjects_to_stack(struct stack_st_X509_NAME *stackCAs,
        const char *dir);
void SSL_load_error_strings(void );
const char *SSL_state_string(const SSL *s);
const char *SSL_rstate_string(const SSL *s);
const char *SSL_state_string_long(const SSL *s);
const char *SSL_rstate_string_long(const SSL *s);
long SSL_SESSION_get_time(const SSL_SESSION *s);
long SSL_SESSION_set_time(SSL_SESSION *s, long t);
long SSL_SESSION_get_timeout(const SSL_SESSION *s);
long SSL_SESSION_set_timeout(SSL_SESSION *s, long t);
void SSL_copy_session_id(SSL *to,const SSL *from);
X509 *SSL_SESSION_get0_peer(SSL_SESSION *s);
int SSL_SESSION_set1_id_context(SSL_SESSION *s,const unsigned char *sid_ctx,
          unsigned int sid_ctx_len);
SSL_SESSION *SSL_SESSION_new(void);
const unsigned char *SSL_SESSION_get_id(const SSL_SESSION *s,
     unsigned int *len);
unsigned int SSL_SESSION_get_compress_id(const SSL_SESSION *s);
int SSL_SESSION_print_fp(FILE *fp,const SSL_SESSION *ses);
int SSL_SESSION_print(BIO *fp,const SSL_SESSION *ses);
void SSL_SESSION_free(SSL_SESSION *ses);
int i2d_SSL_SESSION(SSL_SESSION *in,unsigned char **pp);
int SSL_set_session(SSL *to, SSL_SESSION *session);
int SSL_CTX_add_session(SSL_CTX *s, SSL_SESSION *c);
int SSL_CTX_remove_session(SSL_CTX *,SSL_SESSION *c);
int SSL_CTX_set_generate_session_id(SSL_CTX *, GEN_SESSION_CB);
int SSL_set_generate_session_id(SSL *, GEN_SESSION_CB);
int SSL_has_matching_session_id(const SSL *ssl, const unsigned char *id,
     unsigned int id_len);
SSL_SESSION *d2i_SSL_SESSION(SSL_SESSION **a,const unsigned char **pp,
        long length);
X509 * SSL_get_peer_certificate(const SSL *s);
struct stack_st_X509 *SSL_get_peer_cert_chain(const SSL *s);
int SSL_CTX_get_verify_mode(const SSL_CTX *ctx);
int SSL_CTX_get_verify_depth(const SSL_CTX *ctx);
int (*SSL_CTX_get_verify_callback(const SSL_CTX *ctx))(int,X509_STORE_CTX *);
void SSL_CTX_set_verify(SSL_CTX *ctx,int mode,
   int (*callback)(int, X509_STORE_CTX *));
void SSL_CTX_set_verify_depth(SSL_CTX *ctx,int depth);
void SSL_CTX_set_cert_verify_callback(SSL_CTX *ctx, int (*cb)(X509_STORE_CTX *,void *), void *arg);
int SSL_CTX_use_RSAPrivateKey(SSL_CTX *ctx, RSA *rsa);
int SSL_CTX_use_RSAPrivateKey_ASN1(SSL_CTX *ctx, const unsigned char *d, long len);
int SSL_CTX_use_PrivateKey(SSL_CTX *ctx, EVP_PKEY *pkey);
int SSL_CTX_use_PrivateKey_ASN1(int pk,SSL_CTX *ctx,
int SSL_CTX_use_certificate(SSL_CTX *ctx, X509 *x);
int SSL_CTX_use_certificate_ASN1(SSL_CTX *ctx, int len, const unsigned char *d);
void SSL_CTX_set_default_passwd_cb(SSL_CTX *ctx, pem_password_cb *cb);
void SSL_CTX_set_default_passwd_cb_userdata(SSL_CTX *ctx, void *u);
int SSL_CTX_check_private_key(const SSL_CTX *ctx);
int SSL_check_private_key(const SSL *ctx);
int SSL_CTX_set_session_id_context(SSL_CTX *ctx,const unsigned char *sid_ctx,
SSL * SSL_new(SSL_CTX *ctx);
int SSL_set_session_id_context(SSL *ssl,const unsigned char *sid_ctx,
int SSL_CTX_set_purpose(SSL_CTX *s, int purpose);
int SSL_set_purpose(SSL *s, int purpose);
int SSL_CTX_set_trust(SSL_CTX *s, int trust);
int SSL_set_trust(SSL *s, int trust);
int SSL_CTX_set1_param(SSL_CTX *ctx, X509_VERIFY_PARAM *vpm);
int SSL_set1_param(SSL *ssl, X509_VERIFY_PARAM *vpm);
int SSL_CTX_set_srp_username(SSL_CTX *ctx,char *name);
int SSL_CTX_set_srp_password(SSL_CTX *ctx,char *password);
int SSL_CTX_set_srp_strength(SSL_CTX *ctx, int strength);
int SSL_CTX_set_srp_client_pwd_callback(SSL_CTX *ctx,
     char *(*cb)(SSL *,void *));
int SSL_CTX_set_srp_verify_param_callback(SSL_CTX *ctx,
       int (*cb)(SSL *,void *));
int SSL_CTX_set_srp_username_callback(SSL_CTX *ctx,
          int (*cb)(SSL *,int *,void *));
int SSL_CTX_set_srp_cb_arg(SSL_CTX *ctx, void *arg);
int SSL_set_srp_server_param(SSL *s, const BIGNUM *N, const BIGNUM *g,
        BIGNUM *sa, BIGNUM *v, char *info);
int SSL_set_srp_server_param_pw(SSL *s, const char *user, const char *pass,
    const char *grp);
BIGNUM *SSL_get_srp_g(SSL *s);
BIGNUM *SSL_get_srp_N(SSL *s);
char *SSL_get_srp_username(SSL *s);
char *SSL_get_srp_userinfo(SSL *s);
void SSL_free(SSL *ssl);
int SSL_accept(SSL *ssl);
int SSL_connect(SSL *ssl);
int SSL_read(SSL *ssl,void *buf,int num);
int SSL_peek(SSL *ssl,void *buf,int num);
int SSL_write(SSL *ssl,const void *buf,int num);
long SSL_ctrl(SSL *ssl,int cmd, long larg, void *parg);
long SSL_callback_ctrl(SSL *, int, void (*)(void));
long SSL_CTX_ctrl(SSL_CTX *ctx,int cmd, long larg, void *parg);
long SSL_CTX_callback_ctrl(SSL_CTX *, int, void (*)(void));
int SSL_get_error(const SSL *s,int ret_code);
const char *SSL_get_version(const SSL *s);
int SSL_CTX_set_ssl_version(SSL_CTX *ctx, const SSL_METHOD *meth);
const SSL_METHOD *SSLv2_method(void);
const SSL_METHOD *SSLv2_server_method(void);
const SSL_METHOD *SSLv2_client_method(void);
const SSL_METHOD *SSLv3_method(void);
const SSL_METHOD *SSLv3_server_method(void);
const SSL_METHOD *SSLv3_client_method(void);
const SSL_METHOD *SSLv23_method(void);
const SSL_METHOD *SSLv23_server_method(void);
const SSL_METHOD *SSLv23_client_method(void);
const SSL_METHOD *TLSv1_method(void);
const SSL_METHOD *TLSv1_server_method(void);
const SSL_METHOD *TLSv1_client_method(void);
const SSL_METHOD *TLSv1_1_method(void);
const SSL_METHOD *TLSv1_1_server_method(void);
const SSL_METHOD *TLSv1_1_client_method(void);
const SSL_METHOD *TLSv1_2_method(void);
const SSL_METHOD *TLSv1_2_server_method(void);
const SSL_METHOD *TLSv1_2_client_method(void);
const SSL_METHOD *DTLSv1_method(void);
const SSL_METHOD *DTLSv1_server_method(void);
const SSL_METHOD *DTLSv1_client_method(void);
struct stack_st_SSL_CIPHER *SSL_get_ciphers(const SSL *s);
int SSL_do_handshake(SSL *s);
int SSL_renegotiate(SSL *s);
int SSL_renegotiate_abbreviated(SSL *s);
int SSL_renegotiate_pending(SSL *s);
int SSL_shutdown(SSL *s);
const SSL_METHOD *SSL_get_ssl_method(SSL *s);
int SSL_set_ssl_method(SSL *s, const SSL_METHOD *method);
const char *SSL_alert_type_string_long(int value);
const char *SSL_alert_type_string(int value);
const char *SSL_alert_desc_string_long(int value);
const char *SSL_alert_desc_string(int value);
void SSL_set_client_CA_list(SSL *s, struct stack_st_X509_NAME *name_list);
void SSL_CTX_set_client_CA_list(SSL_CTX *ctx, struct stack_st_X509_NAME *name_list);
struct stack_st_X509_NAME *SSL_get_client_CA_list(const SSL *s);
struct stack_st_X509_NAME *SSL_CTX_get_client_CA_list(const SSL_CTX *s);
int SSL_add_client_CA(SSL *ssl,X509 *x);
int SSL_CTX_add_client_CA(SSL_CTX *ctx,X509 *x);
void SSL_set_connect_state(SSL *s);
void SSL_set_accept_state(SSL *s);
long SSL_get_default_timeout(const SSL *s);
int SSL_library_init(void );
char *SSL_CIPHER_description(const SSL_CIPHER *,char *buf,int size);
struct stack_st_X509_NAME *SSL_dup_CA_list(struct stack_st_X509_NAME *sk);
SSL *SSL_dup(SSL *ssl);
X509 *SSL_get_certificate(const SSL *ssl);
               struct evp_pkey_st *SSL_get_privatekey(SSL *ssl);
void SSL_CTX_set_quiet_shutdown(SSL_CTX *ctx,int mode);
int SSL_CTX_get_quiet_shutdown(const SSL_CTX *ctx);
void SSL_set_quiet_shutdown(SSL *ssl,int mode);
int SSL_get_quiet_shutdown(const SSL *ssl);
void SSL_set_shutdown(SSL *ssl,int mode);
int SSL_get_shutdown(const SSL *ssl);
int SSL_version(const SSL *ssl);
int SSL_CTX_set_default_verify_paths(SSL_CTX *ctx);
int SSL_CTX_load_verify_locations(SSL_CTX *ctx, const char *CAfile,
 const char *CApath);
SSL_SESSION *SSL_get_session(const SSL *ssl);
SSL_SESSION *SSL_get1_session(SSL *ssl);
SSL_CTX *SSL_get_SSL_CTX(const SSL *ssl);
SSL_CTX *SSL_set_SSL_CTX(SSL *ssl, SSL_CTX* ctx);
void SSL_set_info_callback(SSL *ssl,
void (*SSL_get_info_callback(const SSL *ssl))(const SSL *ssl,int type,int val);
int SSL_state(const SSL *ssl);
void SSL_set_state(SSL *ssl, int state);
void SSL_set_verify_result(SSL *ssl,long v);
long SSL_get_verify_result(const SSL *ssl);
int SSL_set_ex_data(SSL *ssl,int idx,void *data);
void *SSL_get_ex_data(const SSL *ssl,int idx);
int SSL_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
 CRYPTO_EX_dup *dup_func, CRYPTO_EX_free *free_func);
int SSL_SESSION_set_ex_data(SSL_SESSION *ss,int idx,void *data);
void *SSL_SESSION_get_ex_data(const SSL_SESSION *ss,int idx);
int SSL_SESSION_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int SSL_CTX_set_ex_data(SSL_CTX *ssl,int idx,void *data);
void *SSL_CTX_get_ex_data(const SSL_CTX *ssl,int idx);
int SSL_CTX_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int SSL_get_ex_data_X509_STORE_CTX_idx(void );
# 2015 "/usr/include/openssl/ssl.h" 3 4
void SSL_CTX_set_tmp_rsa_callback(SSL_CTX *ctx,
      RSA *(*cb)(SSL *ssl,int is_export,
          int keylength));
void SSL_set_tmp_rsa_callback(SSL *ssl,
          int keylength));
void SSL_CTX_set_tmp_dh_callback(SSL_CTX *ctx,
     DH *(*dh)(SSL *ssl,int is_export,
        int keylength));
void SSL_set_tmp_dh_callback(SSL *ssl,
        int keylength));
void SSL_CTX_set_tmp_ecdh_callback(SSL_CTX *ctx,
     EC_KEY *(*ecdh)(SSL *ssl,int is_export,
        int keylength));
void SSL_set_tmp_ecdh_callback(SSL *ssl,
        int keylength));
const COMP_METHOD *SSL_get_current_compression(SSL *s);
const COMP_METHOD *SSL_get_current_expansion(SSL *s);
const char *SSL_COMP_get_name(const COMP_METHOD *comp);
struct stack_st_SSL_COMP *SSL_COMP_get_compression_methods(void);
int SSL_COMP_add_compression_method(int id,COMP_METHOD *cm);
# 2055 "/usr/include/openssl/ssl.h" 3 4
int SSL_set_session_ticket_ext(SSL *s, void *ext_data, int ext_len);
int SSL_set_session_ticket_ext_cb(SSL *s, tls_session_ticket_ext_cb_fn cb,
      void *arg);
int SSL_set_session_secret_cb(SSL *s, tls_session_secret_cb_fn tls_session_secret_cb, void *arg);
void SSL_set_debug(SSL *s, int debug);
int SSL_cache_hit(SSL *s);
# 2074 "/usr/include/openssl/ssl.h" 3 4
void ERR_load_SSL_strings(void);
# 3 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
Found header files ['openssl/ssl.h'] in ['/opt/mpich/include']
              Popping language C
TEST checkSharedLibrary from config.packages.ssl(/home/jed/petsc/config/BuildSystem/config/package.py:592)
TESTING: checkSharedLibrary from config.packages.ssl(config/BuildSystem/config/package.py:592)
  By default we don't care about checking if the library is shared
      Popping language C
TEST alternateConfigureLibrary from config.packages.saws(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.saws(config/BuildSystem/config/package.py:596)
  Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from config.packages.pcbddc(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.pcbddc(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.papi(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.papi(config/BuildSystem/config/package.py:596)
      Pushing language C
TEST configureLibrary from config.packages.pthread(/home/jed/petsc/config/BuildSystem/config/packages/pthread.py:24)
TESTING: configureLibrary from config.packages.pthread(config/BuildSystem/config/packages/pthread.py:24)
   Checks for pthread_barrier_t, cpu_set_t, and sys/sysctl.h
          Checking for a functional pthread
          Checking for library in Package specific search directory PTHREAD: ['libpthread.a']
TEST check from config.libraries(/home/jed/petsc/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
              Checking for functions [pthread_create] in library ['libpthread.a'] []
                Pushing language C
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.libraries/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.libraries  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.libraries/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
/* Override any gcc2 internal prototype to avoid an error. */
char pthread_create();
static void _check_pthread_create() { pthread_create(); }
int main() {
_check_pthread_create();;
  return 0;
                        Pushing language C
                        Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.libraries/conftest.o  -lpthread -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
                Defined "HAVE_LIBPTHREAD" to "1"
                Popping language C
          Checking for headers Package specific search directory PTHREAD: ['/opt/mpich/include']
              Pushing language C
TEST checkInclude from config.headers(/home/jed/petsc/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
  Checks if a particular include file can be found along particular include paths
Checking for header files ['pthread.h'] in ['/opt/mpich/include']
                Checking include with compiler flags var CPPFLAGS ['/opt/mpich/include']
Executing: /opt/mpich/bin/mpicc -E  -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.headers  -I/opt/mpich/include /tmp/petsc-lhuj9c/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-lhuj9c/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/conffix.h" 1
# 1 "/usr/include/pthread.h" 1 3 4
# 21 "/usr/include/pthread.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 395 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 396 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 22 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 27 "/usr/include/bits/byteswap.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 28 "/usr/include/bits/byteswap.h" 2 3 4
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 23 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/sched.h" 1 3 4
# 28 "/usr/include/sched.h" 3 4
# 212 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 29 "/usr/include/sched.h" 2 3 4
# 1 "/usr/include/time.h" 1 3 4
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
# 35 "/usr/include/sched.h" 2 3 4
typedef __pid_t pid_t;
# 1 "/usr/include/bits/sched.h" 1 3 4
# 72 "/usr/include/bits/sched.h" 3 4
struct sched_param
    int __sched_priority;
# 95 "/usr/include/bits/sched.h" 3 4
struct __sched_param
# 118 "/usr/include/bits/sched.h" 3 4
typedef unsigned long int __cpu_mask;
typedef struct
  __cpu_mask __bits[1024 / (8 * sizeof (__cpu_mask))];
} cpu_set_t;
# 201 "/usr/include/bits/sched.h" 3 4
extern int __sched_cpucount (size_t __setsize, const cpu_set_t *__setp)
extern cpu_set_t *__sched_cpualloc (size_t __count) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void __sched_cpufree (cpu_set_t *__set) __attribute__ ((__nothrow__ , __leaf__));
# 44 "/usr/include/sched.h" 2 3 4
extern int sched_setparam (__pid_t __pid, const struct sched_param *__param)
extern int sched_getparam (__pid_t __pid, struct sched_param *__param) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_setscheduler (__pid_t __pid, int __policy,
          const struct sched_param *__param) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_getscheduler (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_yield (void) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_get_priority_max (int __algorithm) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_get_priority_min (int __algorithm) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_rr_get_interval (__pid_t __pid, struct timespec *__t) __attribute__ ((__nothrow__ , __leaf__));
# 126 "/usr/include/sched.h" 3 4
# 24 "/usr/include/pthread.h" 2 3 4
# 29 "/usr/include/time.h" 3 4
# 38 "/usr/include/time.h" 2 3 4
# 42 "/usr/include/time.h" 2 3 4
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 131 "/usr/include/time.h" 3 4
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
  long int tm_gmtoff;
  const char *tm_zone;
struct itimerspec
    struct timespec it_interval;
    struct timespec it_value;
struct sigevent;
# 186 "/usr/include/time.h" 3 4
extern clock_t clock (void) __attribute__ ((__nothrow__ , __leaf__));
extern time_t time (time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern double difftime (time_t __time1, time_t __time0)
extern time_t mktime (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern size_t strftime (char *__restrict __s, size_t __maxsize,
   const char *__restrict __format,
   const struct tm *__restrict __tp) __attribute__ ((__nothrow__ , __leaf__));
# 221 "/usr/include/time.h" 3 4
# 1 "/usr/include/xlocale.h" 1 3 4
# 27 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 222 "/usr/include/time.h" 2 3 4
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
     const struct tm *__restrict __tp,
     __locale_t __loc) __attribute__ ((__nothrow__ , __leaf__));
# 236 "/usr/include/time.h" 3 4
extern struct tm *gmtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *localtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *gmtime_r (const time_t *__restrict __timer,
extern struct tm *localtime_r (const time_t *__restrict __timer,
extern char *asctime (const struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern char *asctime_r (const struct tm *__restrict __tp,
   char *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime_r (const time_t *__restrict __timer,
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daylight;
extern long int timezone;
extern int stime (const time_t *__when) __attribute__ ((__nothrow__ , __leaf__));
# 319 "/usr/include/time.h" 3 4
extern time_t timegm (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern time_t timelocal (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int dysize (int __year) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 334 "/usr/include/time.h" 3 4
extern int nanosleep (const struct timespec *__requested_time,
        struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
       const struct timespec *__req,
       struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_create (clockid_t __clock_id,
    struct sigevent *__restrict __evp,
    timer_t *__restrict __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_delete (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_settime (timer_t __timerid, int __flags,
     const struct itimerspec *__restrict __value,
     struct itimerspec *__restrict __ovalue) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
extern int timer_getoverrun (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
# 430 "/usr/include/time.h" 3 4
# 25 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 27 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/bits/setjmp.h" 1 3 4
# 26 "/usr/include/bits/setjmp.h" 3 4
# 27 "/usr/include/bits/setjmp.h" 2 3 4
typedef long int __jmp_buf[8];
# 28 "/usr/include/pthread.h" 2 3 4
# 29 "/usr/include/pthread.h" 2 3 4
enum
  PTHREAD_CREATE_JOINABLE,
  PTHREAD_CREATE_DETACHED
enum
  PTHREAD_MUTEX_TIMED_NP,
  PTHREAD_MUTEX_RECURSIVE_NP,
  PTHREAD_MUTEX_ERRORCHECK_NP,
  PTHREAD_MUTEX_ADAPTIVE_NP
  PTHREAD_MUTEX_NORMAL = PTHREAD_MUTEX_TIMED_NP,
  PTHREAD_MUTEX_RECURSIVE = PTHREAD_MUTEX_RECURSIVE_NP,
  PTHREAD_MUTEX_ERRORCHECK = PTHREAD_MUTEX_ERRORCHECK_NP,
  PTHREAD_MUTEX_DEFAULT = PTHREAD_MUTEX_NORMAL
enum
  PTHREAD_MUTEX_STALLED,
  PTHREAD_MUTEX_STALLED_NP = PTHREAD_MUTEX_STALLED,
  PTHREAD_MUTEX_ROBUST,
  PTHREAD_MUTEX_ROBUST_NP = PTHREAD_MUTEX_ROBUST
enum
  PTHREAD_PRIO_NONE,
  PTHREAD_PRIO_INHERIT,
  PTHREAD_PRIO_PROTECT
# 116 "/usr/include/pthread.h" 3 4
enum
  PTHREAD_RWLOCK_PREFER_READER_NP,
  PTHREAD_RWLOCK_PREFER_WRITER_NP,
  PTHREAD_RWLOCK_PREFER_WRITER_NONRECURSIVE_NP,
  PTHREAD_RWLOCK_DEFAULT_NP = PTHREAD_RWLOCK_PREFER_READER_NP
# 157 "/usr/include/pthread.h" 3 4
enum
  PTHREAD_INHERIT_SCHED,
  PTHREAD_EXPLICIT_SCHED
enum
  PTHREAD_SCOPE_SYSTEM,
  PTHREAD_SCOPE_PROCESS
enum
  PTHREAD_PROCESS_PRIVATE,
  PTHREAD_PROCESS_SHARED
# 192 "/usr/include/pthread.h" 3 4
struct _pthread_cleanup_buffer
  void (*__routine) (void *);
  void *__arg;
  int __canceltype;
  struct _pthread_cleanup_buffer *__prev;
enum
  PTHREAD_CANCEL_ENABLE,
  PTHREAD_CANCEL_DISABLE
enum
  PTHREAD_CANCEL_DEFERRED,
  PTHREAD_CANCEL_ASYNCHRONOUS
# 230 "/usr/include/pthread.h" 3 4
extern int pthread_create (pthread_t *__restrict __newthread,
      const pthread_attr_t *__restrict __attr,
      void *(*__start_routine) (void *),
      void *__restrict __arg) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 3)));
extern void pthread_exit (void *__retval) __attribute__ ((__noreturn__));
extern int pthread_join (pthread_t __th, void **__thread_return);
# 273 "/usr/include/pthread.h" 3 4
extern int pthread_detach (pthread_t __th) __attribute__ ((__nothrow__ , __leaf__));
extern pthread_t pthread_self (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int pthread_equal (pthread_t __thread1, pthread_t __thread2)
extern int pthread_attr_init (pthread_attr_t *__attr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_attr_destroy (pthread_attr_t *__attr)
extern int pthread_attr_getdetachstate (const pthread_attr_t *__attr,
     int *__detachstate)
extern int pthread_attr_setdetachstate (pthread_attr_t *__attr,
     int __detachstate)
extern int pthread_attr_getguardsize (const pthread_attr_t *__attr,
          size_t *__guardsize)
extern int pthread_attr_setguardsize (pthread_attr_t *__attr,
          size_t __guardsize)
extern int pthread_attr_getschedparam (const pthread_attr_t *__restrict __attr,
           struct sched_param *__restrict __param)
extern int pthread_attr_setschedparam (pthread_attr_t *__restrict __attr,
           const struct sched_param *__restrict
           __param) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int pthread_attr_getschedpolicy (const pthread_attr_t *__restrict
     __attr, int *__restrict __policy)
extern int pthread_attr_setschedpolicy (pthread_attr_t *__attr, int __policy)
extern int pthread_attr_getinheritsched (const pthread_attr_t *__restrict
      __attr, int *__restrict __inherit)
extern int pthread_attr_setinheritsched (pthread_attr_t *__attr,
      int __inherit)
extern int pthread_attr_getscope (const pthread_attr_t *__restrict __attr,
      int *__restrict __scope)
extern int pthread_attr_setscope (pthread_attr_t *__attr, int __scope)
extern int pthread_attr_getstackaddr (const pthread_attr_t *__restrict
          __attr, void **__restrict __stackaddr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2))) __attribute__ ((__deprecated__));
extern int pthread_attr_setstackaddr (pthread_attr_t *__attr,
          void *__stackaddr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) __attribute__ ((__deprecated__));
extern int pthread_attr_getstacksize (const pthread_attr_t *__restrict
          __attr, size_t *__restrict __stacksize)
extern int pthread_attr_setstacksize (pthread_attr_t *__attr,
          size_t __stacksize)
extern int pthread_attr_getstack (const pthread_attr_t *__restrict __attr,
      void **__restrict __stackaddr,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern int pthread_attr_setstack (pthread_attr_t *__attr, void *__stackaddr,
      size_t __stacksize) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 431 "/usr/include/pthread.h" 3 4
extern int pthread_setschedparam (pthread_t __target_thread, int __policy,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3)));
extern int pthread_getschedparam (pthread_t __target_thread,
      int *__restrict __policy,
extern int pthread_setschedprio (pthread_t __target_thread, int __prio)
# 496 "/usr/include/pthread.h" 3 4
extern int pthread_once (pthread_once_t *__once_control,
    void (*__init_routine) (void)) __attribute__ ((__nonnull__ (1, 2)));
# 508 "/usr/include/pthread.h" 3 4
extern int pthread_setcancelstate (int __state, int *__oldstate);
extern int pthread_setcanceltype (int __type, int *__oldtype);
extern int pthread_cancel (pthread_t __th);
extern void pthread_testcancel (void);
typedef struct
  struct
    __jmp_buf __cancel_jmp_buf;
    int __mask_was_saved;
  } __cancel_jmp_buf[1];
  void *__pad[4];
} __pthread_unwind_buf_t __attribute__ ((__aligned__));
# 542 "/usr/include/pthread.h" 3 4
struct __pthread_cleanup_frame
  void (*__cancel_routine) (void *);
  void *__cancel_arg;
  int __do_it;
  int __cancel_type;
# 682 "/usr/include/pthread.h" 3 4
extern void __pthread_register_cancel (__pthread_unwind_buf_t *__buf)
# 694 "/usr/include/pthread.h" 3 4
extern void __pthread_unregister_cancel (__pthread_unwind_buf_t *__buf)
# 735 "/usr/include/pthread.h" 3 4
extern void __pthread_unwind_next (__pthread_unwind_buf_t *__buf)
     __attribute__ ((__weak__))
struct __jmp_buf_tag;
extern int __sigsetjmp (struct __jmp_buf_tag *__env, int __savemask) __attribute__ ((__nothrow__));
extern int pthread_mutex_init (pthread_mutex_t *__mutex,
          const pthread_mutexattr_t *__mutexattr)
extern int pthread_mutex_destroy (pthread_mutex_t *__mutex)
extern int pthread_mutex_trylock (pthread_mutex_t *__mutex)
     __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_mutex_lock (pthread_mutex_t *__mutex)
extern int pthread_mutex_timedlock (pthread_mutex_t *__restrict __mutex,
        const struct timespec *__restrict
        __abstime) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
extern int pthread_mutex_unlock (pthread_mutex_t *__mutex)
extern int pthread_mutex_getprioceiling (const pthread_mutex_t *
      __restrict __mutex,
      int *__restrict __prioceiling)
extern int pthread_mutex_setprioceiling (pthread_mutex_t *__restrict __mutex,
      int __prioceiling,
      int *__restrict __old_ceiling)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 3)));
extern int pthread_mutex_consistent (pthread_mutex_t *__mutex)
# 808 "/usr/include/pthread.h" 3 4
extern int pthread_mutexattr_init (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_destroy (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_getpshared (const pthread_mutexattr_t *
      __restrict __attr,
      int *__restrict __pshared)
extern int pthread_mutexattr_setpshared (pthread_mutexattr_t *__attr,
      int __pshared)
extern int pthread_mutexattr_gettype (const pthread_mutexattr_t *__restrict
          __attr, int *__restrict __kind)
extern int pthread_mutexattr_settype (pthread_mutexattr_t *__attr, int __kind)
extern int pthread_mutexattr_getprotocol (const pthread_mutexattr_t *
       __restrict __attr,
       int *__restrict __protocol)
extern int pthread_mutexattr_setprotocol (pthread_mutexattr_t *__attr,
       int __protocol)
extern int pthread_mutexattr_getprioceiling (const pthread_mutexattr_t *
          __restrict __attr,
extern int pthread_mutexattr_setprioceiling (pthread_mutexattr_t *__attr,
          int __prioceiling)
extern int pthread_mutexattr_getrobust (const pthread_mutexattr_t *__attr,
     int *__robustness)
extern int pthread_mutexattr_setrobust (pthread_mutexattr_t *__attr,
     int __robustness)
# 890 "/usr/include/pthread.h" 3 4
extern int pthread_rwlock_init (pthread_rwlock_t *__restrict __rwlock,
    const pthread_rwlockattr_t *__restrict
extern int pthread_rwlock_destroy (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_rdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_tryrdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedrdlock (pthread_rwlock_t *__restrict __rwlock,
extern int pthread_rwlock_wrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_trywrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedwrlock (pthread_rwlock_t *__restrict __rwlock,
extern int pthread_rwlock_unlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlockattr_init (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_destroy (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_getpshared (const pthread_rwlockattr_t *
       __restrict __attr,
extern int pthread_rwlockattr_setpshared (pthread_rwlockattr_t *__attr,
       int __pshared)
extern int pthread_rwlockattr_getkind_np (const pthread_rwlockattr_t *
       __restrict __attr,
       int *__restrict __pref)
extern int pthread_rwlockattr_setkind_np (pthread_rwlockattr_t *__attr,
       int __pref) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_cond_init (pthread_cond_t *__restrict __cond,
         const pthread_condattr_t *__restrict __cond_attr)
extern int pthread_cond_destroy (pthread_cond_t *__cond)
extern int pthread_cond_signal (pthread_cond_t *__cond)
extern int pthread_cond_broadcast (pthread_cond_t *__cond)
extern int pthread_cond_wait (pthread_cond_t *__restrict __cond,
         pthread_mutex_t *__restrict __mutex)
# 1002 "/usr/include/pthread.h" 3 4
extern int pthread_cond_timedwait (pthread_cond_t *__restrict __cond,
       const struct timespec *__restrict __abstime)
extern int pthread_condattr_init (pthread_condattr_t *__attr)
extern int pthread_condattr_destroy (pthread_condattr_t *__attr)
extern int pthread_condattr_getpshared (const pthread_condattr_t *
     __restrict __attr,
extern int pthread_condattr_setpshared (pthread_condattr_t *__attr,
     int __pshared) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_condattr_getclock (const pthread_condattr_t *
          __restrict __attr,
          __clockid_t *__restrict __clock_id)
extern int pthread_condattr_setclock (pthread_condattr_t *__attr,
          __clockid_t __clock_id)
# 1046 "/usr/include/pthread.h" 3 4
extern int pthread_spin_init (pthread_spinlock_t *__lock, int __pshared)
extern int pthread_spin_destroy (pthread_spinlock_t *__lock)
extern int pthread_spin_lock (pthread_spinlock_t *__lock)
extern int pthread_spin_trylock (pthread_spinlock_t *__lock)
extern int pthread_spin_unlock (pthread_spinlock_t *__lock)
extern int pthread_barrier_init (pthread_barrier_t *__restrict __barrier,
     const pthread_barrierattr_t *__restrict
     __attr, unsigned int __count)
extern int pthread_barrier_destroy (pthread_barrier_t *__barrier)
extern int pthread_barrier_wait (pthread_barrier_t *__barrier)
extern int pthread_barrierattr_init (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_destroy (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_getpshared (const pthread_barrierattr_t *
        __restrict __attr,
extern int pthread_barrierattr_setpshared (pthread_barrierattr_t *__attr,
        int __pshared)
# 1113 "/usr/include/pthread.h" 3 4
extern int pthread_key_create (pthread_key_t *__key,
          void (*__destr_function) (void *))
extern int pthread_key_delete (pthread_key_t __key) __attribute__ ((__nothrow__ , __leaf__));
extern void *pthread_getspecific (pthread_key_t __key) __attribute__ ((__nothrow__ , __leaf__));
extern int pthread_setspecific (pthread_key_t __key,
    const void *__pointer) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int pthread_getcpuclockid (pthread_t __thread_id,
      __clockid_t *__clock_id)
# 1147 "/usr/include/pthread.h" 3 4
extern int pthread_atfork (void (*__prepare) (void),
      void (*__parent) (void),
      void (*__child) (void)) __attribute__ ((__nothrow__ , __leaf__));
# 1161 "/usr/include/pthread.h" 3 4
Found header files ['pthread.h'] in ['/opt/mpich/include']
              Popping language C
                    All intermediate test results are stored in /tmp/petsc-lhuj9c/config.packages.pthread
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.packages.pthread/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.libraries  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.packages.pthread/conftest.c
Possible ERROR while running compiler:
stderr:
/tmp/petsc-lhuj9c/config.packages.pthread/conftest.c: In function ?main?:
/tmp/petsc-lhuj9c/config.packages.pthread/conftest.c:6:20: warning: unused variable ?a? [-Wunused-variable]
 pthread_barrier_t *a;
Source:
#include <pthread.h>
int main() {
  return 0;
          Defined "HAVE_PTHREAD_BARRIER_T" to "1"
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.packages.pthread/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.packages.pthread  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.packages.pthread/conftest.c
stderr:
/tmp/petsc-lhuj9c/config.packages.pthread/conftest.c:6:12: warning: unused variable ?a? [-Wunused-variable]
 cpu_set_t *a;
Source:
#include <sched.h>
int main() {
cpu_set_t *a;
  return 0;
          Defined "HAVE_SCHED_CPU_SET_T" to "1"
Executing: /opt/mpich/bin/mpicc -E  -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.headers  /tmp/petsc-lhuj9c/config.packages.pthread/conftest.c
stdout:
# 1 "/tmp/petsc-lhuj9c/config.packages.pthread/conftest.c"
# 1 "<built-in>"
# 1 "/tmp/petsc-lhuj9c/config.packages.pthread/confdefs.h" 1
# 2 "/tmp/petsc-lhuj9c/config.packages.pthread/conftest.c" 2
# 1 "/tmp/petsc-lhuj9c/config.packages.pthread/conffix.h" 1
# 3 "/tmp/petsc-lhuj9c/config.packages.pthread/conftest.c" 2
# 1 "/usr/include/sys/sysctl.h" 1 3 4
# 21 "/usr/include/sys/sysctl.h" 3 4
# 22 "/usr/include/sys/sysctl.h" 2 3 4
# 24 "/usr/include/sys/sysctl.h" 2 3 4
# 43 "/usr/include/sys/sysctl.h" 3 4
# 1 "/usr/include/linux/sysctl.h" 1 3 4
# 25 "/usr/include/linux/sysctl.h" 3 4
# 1 "/usr/include/linux/kernel.h" 1 3 4
# 26 "/usr/include/linux/sysctl.h" 2 3 4
# 1 "/usr/include/linux/types.h" 1 3 4
# 27 "/usr/include/linux/sysctl.h" 2 3 4
struct completion;
struct __sysctl_args {
 int *name;
 int nlen;
 void *oldval;
 size_t *oldlenp;
 void *newval;
 size_t newlen;
 unsigned long __unused[4];
enum
 CTL_KERN=1,
 CTL_VM=2,
 CTL_NET=3,
 CTL_PROC=4,
 CTL_FS=5,
 CTL_DEBUG=6,
 CTL_DEV=7,
 CTL_BUS=8,
 CTL_ABI=9,
 CTL_CPU=10,
 CTL_ARLAN=254,
 CTL_S390DBF=5677,
 CTL_SUNRPC=7249,
 CTL_PM=9899,
 CTL_FRV=9898,
enum
 CTL_BUS_ISA=1
enum
 INOTIFY_MAX_USER_INSTANCES=1,
 INOTIFY_MAX_USER_WATCHES=2,
 INOTIFY_MAX_QUEUED_EVENTS=3
enum
 KERN_OSTYPE=1,
 KERN_OSRELEASE=2,
 KERN_OSREV=3,
 KERN_VERSION=4,
 KERN_SECUREMASK=5,
 KERN_PROF=6,
 KERN_NODENAME=7,
 KERN_DOMAINNAME=8,
 KERN_PANIC=15,
 KERN_REALROOTDEV=16,
 KERN_SPARC_REBOOT=21,
 KERN_CTLALTDEL=22,
 KERN_PRINTK=23,
 KERN_NAMETRANS=24,
 KERN_PPC_HTABRECLAIM=25,
 KERN_PPC_ZEROPAGED=26,
 KERN_PPC_POWERSAVE_NAP=27,
 KERN_MODPROBE=28,
 KERN_SG_BIG_BUFF=29,
 KERN_ACCT=30,
 KERN_PPC_L2CR=31,
 KERN_RTSIGNR=32,
 KERN_RTSIGMAX=33,
 KERN_SHMMAX=34,
 KERN_MSGMAX=35,
 KERN_MSGMNB=36,
 KERN_MSGPOOL=37,
 KERN_SYSRQ=38,
 KERN_MAX_THREADS=39,
  KERN_RANDOM=40,
  KERN_SHMALL=41,
  KERN_MSGMNI=42,
  KERN_SEM=43,
  KERN_SPARC_STOP_A=44,
  KERN_SHMMNI=45,
 KERN_OVERFLOWUID=46,
 KERN_OVERFLOWGID=47,
 KERN_SHMPATH=48,
 KERN_HOTPLUG=49,
 KERN_IEEE_EMULATION_WARNINGS=50,
 KERN_S390_USER_DEBUG_LOGGING=51,
 KERN_CORE_USES_PID=52,
 KERN_TAINTED=53,
 KERN_CADPID=54,
 KERN_PIDMAX=55,
   KERN_CORE_PATTERN=56,
 KERN_PANIC_ON_OOPS=57,
 KERN_HPPA_PWRSW=58,
 KERN_HPPA_UNALIGNED=59,
 KERN_PRINTK_RATELIMIT=60,
 KERN_PRINTK_RATELIMIT_BURST=61,
 KERN_PTY=62,
 KERN_NGROUPS_MAX=63,
 KERN_SPARC_SCONS_PWROFF=64,
 KERN_HZ_TIMER=65,
 KERN_UNKNOWN_NMI_PANIC=66,
 KERN_BOOTLOADER_TYPE=67,
 KERN_RANDOMIZE=68,
 KERN_SETUID_DUMPABLE=69,
 KERN_SPIN_RETRY=70,
 KERN_ACPI_VIDEO_FLAGS=71,
 KERN_IA64_UNALIGNED=72,
 KERN_COMPAT_LOG=73,
 KERN_MAX_LOCK_DEPTH=74,
 KERN_NMI_WATCHDOG=75,
 KERN_PANIC_ON_NMI=76,
enum
 VM_UNUSED1=1,
 VM_UNUSED2=2,
 VM_UNUSED3=3,
 VM_UNUSED4=4,
 VM_OVERCOMMIT_MEMORY=5,
 VM_UNUSED5=6,
 VM_UNUSED7=7,
 VM_UNUSED8=8,
 VM_UNUSED9=9,
 VM_PAGE_CLUSTER=10,
 VM_DIRTY_BACKGROUND=11,
 VM_DIRTY_RATIO=12,
 VM_DIRTY_WB_CS=13,
 VM_DIRTY_EXPIRE_CS=14,
 VM_NR_PDFLUSH_THREADS=15,
 VM_OVERCOMMIT_RATIO=16,
 VM_PAGEBUF=17,
 VM_HUGETLB_PAGES=18,
 VM_SWAPPINESS=19,
 VM_LOWMEM_RESERVE_RATIO=20,
 VM_MIN_FREE_KBYTES=21,
 VM_MAX_MAP_COUNT=22,
 VM_LAPTOP_MODE=23,
 VM_BLOCK_DUMP=24,
 VM_HUGETLB_GROUP=25,
 VM_VFS_CACHE_PRESSURE=26,
 VM_LEGACY_VA_LAYOUT=27,
 VM_SWAP_TOKEN_TIMEOUT=28,
 VM_DROP_PAGECACHE=29,
 VM_PERCPU_PAGELIST_FRACTION=30,
 VM_ZONE_RECLAIM_MODE=31,
 VM_MIN_UNMAPPED=32,
 VM_PANIC_ON_OOM=33,
 VM_VDSO_ENABLED=34,
 VM_MIN_SLAB=35,
enum
 NET_CORE=1,
 NET_ETHER=2,
 NET_802=3,
 NET_UNIX=4,
 NET_IPV4=5,
 NET_IPX=6,
 NET_ATALK=7,
 NET_NETROM=8,
 NET_AX25=9,
 NET_BRIDGE=10,
 NET_ROSE=11,
 NET_IPV6=12,
 NET_X25=13,
 NET_TR=14,
 NET_DECNET=15,
 NET_ECONET=16,
 NET_SCTP=17,
 NET_LLC=18,
 NET_NETFILTER=19,
 NET_DCCP=20,
 NET_IRDA=412,
enum
 RANDOM_POOLSIZE=1,
 RANDOM_ENTROPY_COUNT=2,
 RANDOM_READ_THRESH=3,
 RANDOM_WRITE_THRESH=4,
 RANDOM_BOOT_ID=5,
 RANDOM_UUID=6
enum
 PTY_MAX=1,
 PTY_NR=2
enum
 BUS_ISA_MEM_BASE=1,
 BUS_ISA_PORT_BASE=2,
 BUS_ISA_PORT_SHIFT=3
enum
 NET_CORE_WMEM_MAX=1,
 NET_CORE_RMEM_MAX=2,
 NET_CORE_WMEM_DEFAULT=3,
 NET_CORE_RMEM_DEFAULT=4,
 NET_CORE_MAX_BACKLOG=6,
 NET_CORE_FASTROUTE=7,
 NET_CORE_MSG_COST=8,
 NET_CORE_MSG_BURST=9,
 NET_CORE_OPTMEM_MAX=10,
 NET_CORE_HOT_LIST_LENGTH=11,
 NET_CORE_DIVERT_VERSION=12,
 NET_CORE_NO_CONG_THRESH=13,
 NET_CORE_NO_CONG=14,
 NET_CORE_LO_CONG=15,
 NET_CORE_MOD_CONG=16,
 NET_CORE_DEV_WEIGHT=17,
 NET_CORE_SOMAXCONN=18,
 NET_CORE_BUDGET=19,
 NET_CORE_AEVENT_ETIME=20,
 NET_CORE_AEVENT_RSEQTH=21,
 NET_CORE_WARNINGS=22,
enum
 NET_UNIX_DESTROY_DELAY=1,
 NET_UNIX_DELETE_DELAY=2,
 NET_UNIX_MAX_DGRAM_QLEN=3,
enum
 NET_NF_CONNTRACK_MAX=1,
 NET_NF_CONNTRACK_TCP_TIMEOUT_SYN_SENT=2,
 NET_NF_CONNTRACK_TCP_TIMEOUT_SYN_RECV=3,
 NET_NF_CONNTRACK_TCP_TIMEOUT_ESTABLISHED=4,
 NET_NF_CONNTRACK_TCP_TIMEOUT_FIN_WAIT=5,
 NET_NF_CONNTRACK_TCP_TIMEOUT_CLOSE_WAIT=6,
 NET_NF_CONNTRACK_TCP_TIMEOUT_LAST_ACK=7,
 NET_NF_CONNTRACK_TCP_TIMEOUT_TIME_WAIT=8,
 NET_NF_CONNTRACK_TCP_TIMEOUT_CLOSE=9,
 NET_NF_CONNTRACK_UDP_TIMEOUT=10,
 NET_NF_CONNTRACK_UDP_TIMEOUT_STREAM=11,
 NET_NF_CONNTRACK_ICMP_TIMEOUT=12,
 NET_NF_CONNTRACK_GENERIC_TIMEOUT=13,
 NET_NF_CONNTRACK_BUCKETS=14,
 NET_NF_CONNTRACK_LOG_INVALID=15,
 NET_NF_CONNTRACK_TCP_TIMEOUT_MAX_RETRANS=16,
 NET_NF_CONNTRACK_TCP_LOOSE=17,
 NET_NF_CONNTRACK_TCP_BE_LIBERAL=18,
 NET_NF_CONNTRACK_TCP_MAX_RETRANS=19,
 NET_NF_CONNTRACK_SCTP_TIMEOUT_CLOSED=20,
 NET_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_WAIT=21,
 NET_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_ECHOED=22,
 NET_NF_CONNTRACK_SCTP_TIMEOUT_ESTABLISHED=23,
 NET_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_SENT=24,
 NET_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_RECD=25,
 NET_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_ACK_SENT=26,
 NET_NF_CONNTRACK_COUNT=27,
 NET_NF_CONNTRACK_ICMPV6_TIMEOUT=28,
 NET_NF_CONNTRACK_FRAG6_TIMEOUT=29,
 NET_NF_CONNTRACK_FRAG6_LOW_THRESH=30,
 NET_NF_CONNTRACK_FRAG6_HIGH_THRESH=31,
 NET_NF_CONNTRACK_CHECKSUM=32,
enum
 NET_IPV4_FORWARD=8,
 NET_IPV4_DYNADDR=9,
 NET_IPV4_CONF=16,
 NET_IPV4_NEIGH=17,
 NET_IPV4_ROUTE=18,
 NET_IPV4_FIB_HASH=19,
 NET_IPV4_NETFILTER=20,
 NET_IPV4_TCP_TIMESTAMPS=33,
 NET_IPV4_TCP_WINDOW_SCALING=34,
 NET_IPV4_TCP_SACK=35,
 NET_IPV4_TCP_RETRANS_COLLAPSE=36,
 NET_IPV4_DEFAULT_TTL=37,
 NET_IPV4_AUTOCONFIG=38,
 NET_IPV4_NO_PMTU_DISC=39,
 NET_IPV4_TCP_SYN_RETRIES=40,
 NET_IPV4_IPFRAG_HIGH_THRESH=41,
 NET_IPV4_IPFRAG_LOW_THRESH=42,
 NET_IPV4_IPFRAG_TIME=43,
 NET_IPV4_TCP_MAX_KA_PROBES=44,
 NET_IPV4_TCP_KEEPALIVE_TIME=45,
 NET_IPV4_TCP_KEEPALIVE_PROBES=46,
 NET_IPV4_TCP_RETRIES1=47,
 NET_IPV4_TCP_RETRIES2=48,
 NET_IPV4_TCP_FIN_TIMEOUT=49,
 NET_IPV4_IP_MASQ_DEBUG=50,
 NET_TCP_SYNCOOKIES=51,
 NET_TCP_STDURG=52,
 NET_TCP_RFC1337=53,
 NET_TCP_SYN_TAILDROP=54,
 NET_TCP_MAX_SYN_BACKLOG=55,
 NET_IPV4_LOCAL_PORT_RANGE=56,
 NET_IPV4_ICMP_ECHO_IGNORE_ALL=57,
 NET_IPV4_ICMP_ECHO_IGNORE_BROADCASTS=58,
 NET_IPV4_ICMP_SOURCEQUENCH_RATE=59,
 NET_IPV4_ICMP_DESTUNREACH_RATE=60,
 NET_IPV4_ICMP_TIMEEXCEED_RATE=61,
 NET_IPV4_ICMP_PARAMPROB_RATE=62,
 NET_IPV4_ICMP_ECHOREPLY_RATE=63,
 NET_IPV4_ICMP_IGNORE_BOGUS_ERROR_RESPONSES=64,
 NET_IPV4_IGMP_MAX_MEMBERSHIPS=65,
 NET_TCP_TW_RECYCLE=66,
 NET_IPV4_ALWAYS_DEFRAG=67,
 NET_IPV4_TCP_KEEPALIVE_INTVL=68,
 NET_IPV4_INET_PEER_THRESHOLD=69,
 NET_IPV4_INET_PEER_MINTTL=70,
 NET_IPV4_INET_PEER_MAXTTL=71,
 NET_IPV4_INET_PEER_GC_MINTIME=72,
 NET_IPV4_INET_PEER_GC_MAXTIME=73,
 NET_TCP_ORPHAN_RETRIES=74,
 NET_TCP_ABORT_ON_OVERFLOW=75,
 NET_TCP_SYNACK_RETRIES=76,
 NET_TCP_MAX_ORPHANS=77,
 NET_TCP_MAX_TW_BUCKETS=78,
 NET_TCP_FACK=79,
 NET_TCP_REORDERING=80,
 NET_TCP_ECN=81,
 NET_TCP_DSACK=82,
 NET_TCP_MEM=83,
 NET_TCP_WMEM=84,
 NET_TCP_RMEM=85,
 NET_TCP_APP_WIN=86,
 NET_TCP_ADV_WIN_SCALE=87,
 NET_IPV4_NONLOCAL_BIND=88,
 NET_IPV4_ICMP_RATELIMIT=89,
 NET_IPV4_ICMP_RATEMASK=90,
 NET_TCP_TW_REUSE=91,
 NET_TCP_FRTO=92,
 NET_TCP_LOW_LATENCY=93,
 NET_IPV4_IPFRAG_SECRET_INTERVAL=94,
 NET_IPV4_IGMP_MAX_MSF=96,
 NET_TCP_NO_METRICS_SAVE=97,
 NET_TCP_DEFAULT_WIN_SCALE=105,
 NET_TCP_MODERATE_RCVBUF=106,
 NET_TCP_TSO_WIN_DIVISOR=107,
 NET_TCP_BIC_BETA=108,
 NET_IPV4_ICMP_ERRORS_USE_INBOUND_IFADDR=109,
 NET_TCP_CONG_CONTROL=110,
 NET_TCP_ABC=111,
 NET_IPV4_IPFRAG_MAX_DIST=112,
  NET_TCP_MTU_PROBING=113,
 NET_TCP_BASE_MSS=114,
 NET_IPV4_TCP_WORKAROUND_SIGNED_WINDOWS=115,
 NET_TCP_DMA_COPYBREAK=116,
 NET_TCP_SLOW_START_AFTER_IDLE=117,
 NET_CIPSOV4_CACHE_ENABLE=118,
 NET_CIPSOV4_CACHE_BUCKET_SIZE=119,
 NET_CIPSOV4_RBM_OPTFMT=120,
 NET_CIPSOV4_RBM_STRICTVALID=121,
 NET_TCP_AVAIL_CONG_CONTROL=122,
 NET_TCP_ALLOWED_CONG_CONTROL=123,
 NET_TCP_MAX_SSTHRESH=124,
 NET_TCP_FRTO_RESPONSE=125,
enum {
 NET_IPV4_ROUTE_FLUSH=1,
 NET_IPV4_ROUTE_MIN_DELAY=2,
 NET_IPV4_ROUTE_MAX_DELAY=3,
 NET_IPV4_ROUTE_GC_THRESH=4,
 NET_IPV4_ROUTE_MAX_SIZE=5,
 NET_IPV4_ROUTE_GC_MIN_INTERVAL=6,
 NET_IPV4_ROUTE_GC_TIMEOUT=7,
 NET_IPV4_ROUTE_GC_INTERVAL=8,
 NET_IPV4_ROUTE_REDIRECT_LOAD=9,
 NET_IPV4_ROUTE_REDIRECT_NUMBER=10,
 NET_IPV4_ROUTE_REDIRECT_SILENCE=11,
 NET_IPV4_ROUTE_ERROR_COST=12,
 NET_IPV4_ROUTE_ERROR_BURST=13,
 NET_IPV4_ROUTE_GC_ELASTICITY=14,
 NET_IPV4_ROUTE_MTU_EXPIRES=15,
 NET_IPV4_ROUTE_MIN_PMTU=16,
 NET_IPV4_ROUTE_MIN_ADVMSS=17,
 NET_IPV4_ROUTE_SECRET_INTERVAL=18,
 NET_IPV4_ROUTE_GC_MIN_INTERVAL_MS=19,
enum
 NET_PROTO_CONF_ALL=-2,
 NET_PROTO_CONF_DEFAULT=-3
enum
 NET_IPV4_CONF_FORWARDING=1,
 NET_IPV4_CONF_MC_FORWARDING=2,
 NET_IPV4_CONF_PROXY_ARP=3,
 NET_IPV4_CONF_ACCEPT_REDIRECTS=4,
 NET_IPV4_CONF_SECURE_REDIRECTS=5,
 NET_IPV4_CONF_SEND_REDIRECTS=6,
 NET_IPV4_CONF_SHARED_MEDIA=7,
 NET_IPV4_CONF_RP_FILTER=8,
 NET_IPV4_CONF_ACCEPT_SOURCE_ROUTE=9,
 NET_IPV4_CONF_BOOTP_RELAY=10,
 NET_IPV4_CONF_LOG_MARTIANS=11,
 NET_IPV4_CONF_TAG=12,
 NET_IPV4_CONF_ARPFILTER=13,
 NET_IPV4_CONF_MEDIUM_ID=14,
 NET_IPV4_CONF_NOXFRM=15,
 NET_IPV4_CONF_NOPOLICY=16,
 NET_IPV4_CONF_FORCE_IGMP_VERSION=17,
 NET_IPV4_CONF_ARP_ANNOUNCE=18,
 NET_IPV4_CONF_ARP_IGNORE=19,
 NET_IPV4_CONF_PROMOTE_SECONDARIES=20,
 NET_IPV4_CONF_ARP_ACCEPT=21,
 NET_IPV4_CONF_ARP_NOTIFY=22,
enum
 NET_IPV4_NF_CONNTRACK_MAX=1,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_SYN_SENT=2,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_SYN_RECV=3,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_ESTABLISHED=4,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_FIN_WAIT=5,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_CLOSE_WAIT=6,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_LAST_ACK=7,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_TIME_WAIT=8,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_CLOSE=9,
 NET_IPV4_NF_CONNTRACK_UDP_TIMEOUT=10,
 NET_IPV4_NF_CONNTRACK_UDP_TIMEOUT_STREAM=11,
 NET_IPV4_NF_CONNTRACK_ICMP_TIMEOUT=12,
 NET_IPV4_NF_CONNTRACK_GENERIC_TIMEOUT=13,
 NET_IPV4_NF_CONNTRACK_BUCKETS=14,
 NET_IPV4_NF_CONNTRACK_LOG_INVALID=15,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_MAX_RETRANS=16,
 NET_IPV4_NF_CONNTRACK_TCP_LOOSE=17,
 NET_IPV4_NF_CONNTRACK_TCP_BE_LIBERAL=18,
 NET_IPV4_NF_CONNTRACK_TCP_MAX_RETRANS=19,
  NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_CLOSED=20,
  NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_WAIT=21,
  NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_ECHOED=22,
  NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_ESTABLISHED=23,
  NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_SENT=24,
  NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_RECD=25,
  NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_ACK_SENT=26,
 NET_IPV4_NF_CONNTRACK_COUNT=27,
 NET_IPV4_NF_CONNTRACK_CHECKSUM=28,
enum {
 NET_IPV6_CONF=16,
 NET_IPV6_NEIGH=17,
 NET_IPV6_ROUTE=18,
 NET_IPV6_ICMP=19,
 NET_IPV6_BINDV6ONLY=20,
 NET_IPV6_IP6FRAG_HIGH_THRESH=21,
 NET_IPV6_IP6FRAG_LOW_THRESH=22,
 NET_IPV6_IP6FRAG_TIME=23,
 NET_IPV6_IP6FRAG_SECRET_INTERVAL=24,
 NET_IPV6_MLD_MAX_MSF=25,
enum {
 NET_IPV6_ROUTE_FLUSH=1,
 NET_IPV6_ROUTE_GC_THRESH=2,
 NET_IPV6_ROUTE_MAX_SIZE=3,
 NET_IPV6_ROUTE_GC_MIN_INTERVAL=4,
 NET_IPV6_ROUTE_GC_TIMEOUT=5,
 NET_IPV6_ROUTE_GC_INTERVAL=6,
 NET_IPV6_ROUTE_GC_ELASTICITY=7,
 NET_IPV6_ROUTE_MTU_EXPIRES=8,
 NET_IPV6_ROUTE_MIN_ADVMSS=9,
 NET_IPV6_ROUTE_GC_MIN_INTERVAL_MS=10
enum {
 NET_IPV6_FORWARDING=1,
 NET_IPV6_HOP_LIMIT=2,
 NET_IPV6_MTU=3,
 NET_IPV6_ACCEPT_RA=4,
 NET_IPV6_ACCEPT_REDIRECTS=5,
 NET_IPV6_AUTOCONF=6,
 NET_IPV6_DAD_TRANSMITS=7,
 NET_IPV6_RTR_SOLICITS=8,
 NET_IPV6_RTR_SOLICIT_INTERVAL=9,
 NET_IPV6_RTR_SOLICIT_DELAY=10,
 NET_IPV6_USE_TEMPADDR=11,
 NET_IPV6_TEMP_VALID_LFT=12,
 NET_IPV6_TEMP_PREFERED_LFT=13,
 NET_IPV6_REGEN_MAX_RETRY=14,
 NET_IPV6_MAX_DESYNC_FACTOR=15,
 NET_IPV6_MAX_ADDRESSES=16,
 NET_IPV6_FORCE_MLD_VERSION=17,
 NET_IPV6_ACCEPT_RA_DEFRTR=18,
 NET_IPV6_ACCEPT_RA_PINFO=19,
 NET_IPV6_ACCEPT_RA_RTR_PREF=20,
 NET_IPV6_RTR_PROBE_INTERVAL=21,
 NET_IPV6_ACCEPT_RA_RT_INFO_MAX_PLEN=22,
 NET_IPV6_PROXY_NDP=23,
 NET_IPV6_ACCEPT_SOURCE_ROUTE=25,
 __NET_IPV6_MAX
enum {
 NET_IPV6_ICMP_RATELIMIT=1
enum {
 NET_NEIGH_MCAST_SOLICIT=1,
 NET_NEIGH_UCAST_SOLICIT=2,
 NET_NEIGH_APP_SOLICIT=3,
 NET_NEIGH_RETRANS_TIME=4,
 NET_NEIGH_REACHABLE_TIME=5,
 NET_NEIGH_DELAY_PROBE_TIME=6,
 NET_NEIGH_GC_STALE_TIME=7,
 NET_NEIGH_UNRES_QLEN=8,
 NET_NEIGH_PROXY_QLEN=9,
 NET_NEIGH_ANYCAST_DELAY=10,
 NET_NEIGH_PROXY_DELAY=11,
 NET_NEIGH_LOCKTIME=12,
 NET_NEIGH_GC_INTERVAL=13,
 NET_NEIGH_GC_THRESH1=14,
 NET_NEIGH_GC_THRESH2=15,
 NET_NEIGH_GC_THRESH3=16,
 NET_NEIGH_RETRANS_TIME_MS=17,
 NET_NEIGH_REACHABLE_TIME_MS=18,
enum {
 NET_DCCP_DEFAULT=1,
enum {
 NET_IPX_PPROP_BROADCASTING=1,
 NET_IPX_FORWARDING=2
enum {
 NET_LLC2=1,
 NET_LLC_STATION=2,
enum {
 NET_LLC2_TIMEOUT=1,
enum {
 NET_LLC_STATION_ACK_TIMEOUT=1,
enum {
 NET_LLC2_ACK_TIMEOUT=1,
 NET_LLC2_P_TIMEOUT=2,
 NET_LLC2_REJ_TIMEOUT=3,
 NET_LLC2_BUSY_TIMEOUT=4,
enum {
 NET_ATALK_AARP_EXPIRY_TIME=1,
 NET_ATALK_AARP_TICK_TIME=2,
 NET_ATALK_AARP_RETRANSMIT_LIMIT=3,
 NET_ATALK_AARP_RESOLVE_TIME=4
enum {
 NET_NETROM_DEFAULT_PATH_QUALITY=1,
 NET_NETROM_OBSOLESCENCE_COUNT_INITIALISER=2,
 NET_NETROM_NETWORK_TTL_INITIALISER=3,
 NET_NETROM_TRANSPORT_TIMEOUT=4,
 NET_NETROM_TRANSPORT_MAXIMUM_TRIES=5,
 NET_NETROM_TRANSPORT_ACKNOWLEDGE_DELAY=6,
 NET_NETROM_TRANSPORT_BUSY_DELAY=7,
 NET_NETROM_TRANSPORT_REQUESTED_WINDOW_SIZE=8,
 NET_NETROM_TRANSPORT_NO_ACTIVITY_TIMEOUT=9,
 NET_NETROM_ROUTING_CONTROL=10,
 NET_NETROM_LINK_FAILS_COUNT=11,
 NET_NETROM_RESET=12
enum {
 NET_AX25_IP_DEFAULT_MODE=1,
 NET_AX25_DEFAULT_MODE=2,
 NET_AX25_BACKOFF_TYPE=3,
 NET_AX25_CONNECT_MODE=4,
 NET_AX25_STANDARD_WINDOW=5,
 NET_AX25_EXTENDED_WINDOW=6,
 NET_AX25_T1_TIMEOUT=7,
 NET_AX25_T2_TIMEOUT=8,
 NET_AX25_T3_TIMEOUT=9,
 NET_AX25_IDLE_TIMEOUT=10,
 NET_AX25_N2=11,
 NET_AX25_PACLEN=12,
 NET_AX25_PROTOCOL=13,
 NET_AX25_DAMA_SLAVE_TIMEOUT=14
enum {
 NET_ROSE_RESTART_REQUEST_TIMEOUT=1,
 NET_ROSE_CALL_REQUEST_TIMEOUT=2,
 NET_ROSE_RESET_REQUEST_TIMEOUT=3,
 NET_ROSE_CLEAR_REQUEST_TIMEOUT=4,
 NET_ROSE_ACK_HOLD_BACK_TIMEOUT=5,
 NET_ROSE_ROUTING_CONTROL=6,
 NET_ROSE_LINK_FAIL_TIMEOUT=7,
 NET_ROSE_MAX_VCS=8,
 NET_ROSE_WINDOW_SIZE=9,
 NET_ROSE_NO_ACTIVITY_TIMEOUT=10
enum {
 NET_X25_RESTART_REQUEST_TIMEOUT=1,
 NET_X25_CALL_REQUEST_TIMEOUT=2,
 NET_X25_RESET_REQUEST_TIMEOUT=3,
 NET_X25_CLEAR_REQUEST_TIMEOUT=4,
 NET_X25_ACK_HOLD_BACK_TIMEOUT=5,
 NET_X25_FORWARD=6
enum
 NET_TR_RIF_TIMEOUT=1
enum {
 NET_DECNET_NODE_TYPE = 1,
 NET_DECNET_NODE_ADDRESS = 2,
 NET_DECNET_NODE_NAME = 3,
 NET_DECNET_DEFAULT_DEVICE = 4,
 NET_DECNET_TIME_WAIT = 5,
 NET_DECNET_DN_COUNT = 6,
 NET_DECNET_DI_COUNT = 7,
 NET_DECNET_DR_COUNT = 8,
 NET_DECNET_DST_GC_INTERVAL = 9,
 NET_DECNET_CONF = 10,
 NET_DECNET_NO_FC_MAX_CWND = 11,
 NET_DECNET_MEM = 12,
 NET_DECNET_RMEM = 13,
 NET_DECNET_WMEM = 14,
 NET_DECNET_DEBUG_LEVEL = 255
enum {
 NET_DECNET_CONF_LOOPBACK = -2,
 NET_DECNET_CONF_DDCMP = -3,
 NET_DECNET_CONF_PPP = -4,
 NET_DECNET_CONF_X25 = -5,
 NET_DECNET_CONF_GRE = -6,
 NET_DECNET_CONF_ETHER = -7
enum {
 NET_DECNET_CONF_DEV_PRIORITY = 1,
 NET_DECNET_CONF_DEV_T1 = 2,
 NET_DECNET_CONF_DEV_T2 = 3,
 NET_DECNET_CONF_DEV_T3 = 4,
 NET_DECNET_CONF_DEV_FORWARDING = 5,
 NET_DECNET_CONF_DEV_BLKSIZE = 6,
 NET_DECNET_CONF_DEV_STATE = 7
enum {
 NET_SCTP_RTO_INITIAL = 1,
 NET_SCTP_RTO_MIN = 2,
 NET_SCTP_RTO_MAX = 3,
 NET_SCTP_RTO_ALPHA = 4,
 NET_SCTP_RTO_BETA = 5,
 NET_SCTP_VALID_COOKIE_LIFE = 6,
 NET_SCTP_ASSOCIATION_MAX_RETRANS = 7,
 NET_SCTP_PATH_MAX_RETRANS = 8,
 NET_SCTP_MAX_INIT_RETRANSMITS = 9,
 NET_SCTP_HB_INTERVAL = 10,
 NET_SCTP_PRESERVE_ENABLE = 11,
 NET_SCTP_MAX_BURST = 12,
 NET_SCTP_ADDIP_ENABLE = 13,
 NET_SCTP_PRSCTP_ENABLE = 14,
 NET_SCTP_SNDBUF_POLICY = 15,
 NET_SCTP_SACK_TIMEOUT = 16,
 NET_SCTP_RCVBUF_POLICY = 17,
enum {
 NET_BRIDGE_NF_CALL_ARPTABLES = 1,
 NET_BRIDGE_NF_CALL_IPTABLES = 2,
 NET_BRIDGE_NF_CALL_IP6TABLES = 3,
 NET_BRIDGE_NF_FILTER_VLAN_TAGGED = 4,
 NET_BRIDGE_NF_FILTER_PPPOE_TAGGED = 5,
enum {
 NET_IRDA_DISCOVERY=1,
 NET_IRDA_DEVNAME=2,
 NET_IRDA_DEBUG=3,
 NET_IRDA_FAST_POLL=4,
 NET_IRDA_DISCOVERY_SLOTS=5,
 NET_IRDA_DISCOVERY_TIMEOUT=6,
 NET_IRDA_SLOT_TIMEOUT=7,
 NET_IRDA_MAX_BAUD_RATE=8,
 NET_IRDA_MIN_TX_TURN_TIME=9,
 NET_IRDA_MAX_TX_DATA_SIZE=10,
 NET_IRDA_MAX_TX_WINDOW=11,
 NET_IRDA_MAX_NOREPLY_TIME=12,
 NET_IRDA_WARN_NOREPLY_TIME=13,
 NET_IRDA_LAP_KEEPALIVE_TIME=14,
enum
 FS_NRINODE=1,
 FS_STATINODE=2,
 FS_MAXINODE=3,
 FS_NRDQUOT=4,
 FS_MAXDQUOT=5,
 FS_NRFILE=6,
 FS_MAXFILE=7,
 FS_DENTRY=8,
 FS_NRSUPER=9,
 FS_MAXSUPER=10,
 FS_OVERFLOWUID=11,
 FS_OVERFLOWGID=12,
 FS_LEASES=13,
 FS_DIR_NOTIFY=14,
 FS_LEASE_TIME=15,
 FS_DQSTATS=16,
 FS_XFS=17,
 FS_AIO_NR=18,
 FS_AIO_MAX_NR=19,
 FS_INOTIFY=20,
 FS_OCFS2=988,
enum {
 FS_DQ_LOOKUPS = 1,
 FS_DQ_DROPS = 2,
 FS_DQ_READS = 3,
 FS_DQ_WRITES = 4,
 FS_DQ_CACHE_HITS = 5,
 FS_DQ_ALLOCATED = 6,
 FS_DQ_FREE = 7,
 FS_DQ_SYNCS = 8,
 FS_DQ_WARNINGS = 9,
enum {
 DEV_CDROM=1,
 DEV_HWMON=2,
 DEV_PARPORT=3,
 DEV_RAID=4,
 DEV_MAC_HID=5,
 DEV_SCSI=6,
 DEV_IPMI=7,
enum {
 DEV_CDROM_INFO=1,
 DEV_CDROM_AUTOCLOSE=2,
 DEV_CDROM_AUTOEJECT=3,
 DEV_CDROM_DEBUG=4,
 DEV_CDROM_LOCK=5,
 DEV_CDROM_CHECK_MEDIA=6
enum {
 DEV_PARPORT_DEFAULT=-3
enum {
 DEV_RAID_SPEED_LIMIT_MIN=1,
 DEV_RAID_SPEED_LIMIT_MAX=2
enum {
 DEV_PARPORT_DEFAULT_TIMESLICE=1,
 DEV_PARPORT_DEFAULT_SPINTIME=2
enum {
 DEV_PARPORT_SPINTIME=1,
 DEV_PARPORT_BASE_ADDR=2,
 DEV_PARPORT_IRQ=3,
 DEV_PARPORT_DMA=4,
 DEV_PARPORT_MODES=5,
 DEV_PARPORT_DEVICES=6,
 DEV_PARPORT_AUTOPROBE=16
enum {
 DEV_PARPORT_DEVICES_ACTIVE=-3,
enum {
 DEV_PARPORT_DEVICE_TIMESLICE=1,
enum {
 DEV_MAC_HID_KEYBOARD_SENDS_LINUX_KEYCODES=1,
 DEV_MAC_HID_KEYBOARD_LOCK_KEYCODES=2,
 DEV_MAC_HID_MOUSE_BUTTON_EMULATION=3,
 DEV_MAC_HID_MOUSE_BUTTON2_KEYCODE=4,
 DEV_MAC_HID_MOUSE_BUTTON3_KEYCODE=5,
 DEV_MAC_HID_ADB_MOUSE_SENDS_KEYCODES=6
enum {
 DEV_SCSI_LOGGING_LEVEL=1,
enum {
 DEV_IPMI_POWEROFF_POWERCYCLE=1,
enum
 ABI_DEFHANDLER_COFF=1,
 ABI_DEFHANDLER_ELF=2,
 ABI_DEFHANDLER_LCALL7=3,
 ABI_DEFHANDLER_LIBCSO=4,
 ABI_TRACE=5,
 ABI_FAKE_UTSNAME=6,
# 44 "/usr/include/sys/sysctl.h" 2 3 4
# 63 "/usr/include/sys/sysctl.h" 3 4
# 1 "/usr/include/bits/sysctl.h" 1 3 4
# 64 "/usr/include/sys/sysctl.h" 2 3 4
extern int sysctl (int *__name, int __nlen, void *__oldval,
     size_t *__oldlenp, void *__newval, size_t __newlen) __attribute__ ((__nothrow__ , __leaf__));
          Defined "HAVE_SYS_SYSCTL_H" to "1"
TEST checkSharedLibrary from config.packages.pthread(/home/jed/petsc/config/BuildSystem/config/package.py:592)
TESTING: checkSharedLibrary from config.packages.pthread(config/BuildSystem/config/package.py:592)
      Popping language C
TEST alternateConfigureLibrary from config.packages.pthreadclasses(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.pthreadclasses(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.openmp(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.openmp(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.opengles(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.opengles(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.opencl(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.opencl(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.viennacl(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.viennacl(config/BuildSystem/config/package.py:596)
Checking for program /home/jed/bin/lgrind...not found
Checking for program /usr/bin/lgrind...not found
Checking for program /usr/lib/mailman/bin/lgrind...not found
Checking for program /opt/mpich/bin/lgrind...not found
Checking for program /usr/bin/site_perl/lgrind...not found
Checking for program /usr/bin/vendor_perl/lgrind...not found
Checking for program /usr/bin/core_perl/lgrind...not found
Checking for program /opt/visit/bin/lgrind...not found
Checking for program /home/jed/lgrind...not found
Checking for program /home/jed/petsc/bin/win32fe/lgrind...not found
        Pushing language C
TEST configureLibrary from config.packages.hwloc(/home/jed/petsc/config/BuildSystem/config/package.py:538)
TESTING: configureLibrary from config.packages.hwloc(config/BuildSystem/config/package.py:538)
  Find an installation and check if it can work with PETSc
          Checking for a functional hwloc
          Checking for library in Package specific search directory HWLOC: ['libhwloc.a']
              Checking for functions [hwloc_topology_init] in library ['libhwloc.a'] []
                Pushing language C
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.libraries/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.libraries  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.libraries/conftest.c
Successful compile:
Source:
char hwloc_topology_init();
static void _check_hwloc_topology_init() { hwloc_topology_init(); }
int main() {
_check_hwloc_topology_init();;
  return 0;
                        Pushing language C
                        Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.libraries/conftest.o  -lhwloc -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
                Defined "HAVE_LIBHWLOC" to "1"
                Popping language C
          Checking for headers Package specific search directory HWLOC: ['/opt/mpich/include']
              Pushing language C
Checking for header files ['hwloc.h'] in ['/opt/mpich/include']
Executing: /opt/mpich/bin/mpicc -E  -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.headers  -I/opt/mpich/include /tmp/petsc-lhuj9c/config.headers/conftest.c
stdout:
# 1 "<built-in>"
# 1 "/usr/include/hwloc.h" 1 3 4
# 50 "/usr/include/hwloc.h" 3 4
# 1 "/usr/include/hwloc/autogen/config.h" 1 3 4
# 166 "/usr/include/hwloc/autogen/config.h" 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 1 3 4
struct timespec
    __time_t tv_sec;
struct sched_param
typedef struct
} cpu_set_t;
# 1 "/usr/include/bits/time.h" 1 3 4
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
  long int tm_gmtoff;
struct itimerspec
struct sigevent;
} *__locale_t;
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
enum
enum
enum
enum
  PTHREAD_PRIO_NONE,
enum
enum
enum
enum
  void *__arg;
  int __canceltype;
enum
enum
     int *__detachstate)
     int __detachstate)
          size_t __guardsize)
      int __inherit)
          void *__stackaddr)
          size_t __stacksize)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3)));
typedef struct
  struct
  void *__pad[4];
  void *__cancel_arg;
  int __do_it;
  int __cancel_type;
      __restrict __mutex,
      int __prioceiling,
      __restrict __attr,
      int __pshared)
       __restrict __attr,
       int __protocol)
          __restrict __attr,
          int __prioceiling)
     int *__robustness)
     int __robustness)
       __restrict __attr,
       int __pshared)
       __restrict __attr,
     __restrict __attr,
          __restrict __attr,
        __restrict __attr,
        int __pshared)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 167 "/usr/include/hwloc/autogen/config.h" 2 3 4
# 1 "/usr/include/unistd.h" 1 3 4
# 27 "/usr/include/unistd.h" 3 4
# 202 "/usr/include/unistd.h" 3 4
# 1 "/usr/include/bits/posix_opt.h" 1 3 4
# 203 "/usr/include/unistd.h" 2 3 4
# 1 "/usr/include/bits/environments.h" 1 3 4
# 22 "/usr/include/bits/environments.h" 3 4
# 23 "/usr/include/bits/environments.h" 2 3 4
# 207 "/usr/include/unistd.h" 2 3 4
# 220 "/usr/include/unistd.h" 3 4
typedef __ssize_t ssize_t;
# 227 "/usr/include/unistd.h" 2 3 4
typedef __gid_t gid_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 255 "/usr/include/unistd.h" 3 4
typedef __useconds_t useconds_t;
# 267 "/usr/include/unistd.h" 3 4
typedef __intptr_t intptr_t;
typedef __socklen_t socklen_t;
# 287 "/usr/include/unistd.h" 3 4
extern int access (const char *__name, int __type) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 304 "/usr/include/unistd.h" 3 4
extern int faccessat (int __fd, const char *__file, int __type, int __flag)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2))) ;
# 334 "/usr/include/unistd.h" 3 4
extern __off_t lseek (int __fd, __off_t __offset, int __whence) __attribute__ ((__nothrow__ , __leaf__));
# 353 "/usr/include/unistd.h" 3 4
extern int close (int __fd);
extern ssize_t read (int __fd, void *__buf, size_t __nbytes) ;
extern ssize_t write (int __fd, const void *__buf, size_t __n) ;
# 376 "/usr/include/unistd.h" 3 4
extern ssize_t pread (int __fd, void *__buf, size_t __nbytes,
        __off_t __offset) ;
extern ssize_t pwrite (int __fd, const void *__buf, size_t __n,
         __off_t __offset) ;
# 417 "/usr/include/unistd.h" 3 4
extern int pipe (int __pipedes[2]) __attribute__ ((__nothrow__ , __leaf__)) ;
# 432 "/usr/include/unistd.h" 3 4
extern unsigned int alarm (unsigned int __seconds) __attribute__ ((__nothrow__ , __leaf__));
# 444 "/usr/include/unistd.h" 3 4
extern unsigned int sleep (unsigned int __seconds);
extern __useconds_t ualarm (__useconds_t __value, __useconds_t __interval)
extern int usleep (__useconds_t __useconds);
# 469 "/usr/include/unistd.h" 3 4
extern int pause (void);
extern int chown (const char *__file, __uid_t __owner, __gid_t __group)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern int fchown (int __fd, __uid_t __owner, __gid_t __group) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int lchown (const char *__file, __uid_t __owner, __gid_t __group)
extern int fchownat (int __fd, const char *__file, __uid_t __owner,
       __gid_t __group, int __flag)
extern int chdir (const char *__path) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern int fchdir (int __fd) __attribute__ ((__nothrow__ , __leaf__)) ;
# 511 "/usr/include/unistd.h" 3 4
extern char *getcwd (char *__buf, size_t __size) __attribute__ ((__nothrow__ , __leaf__)) ;
# 525 "/usr/include/unistd.h" 3 4
extern char *getwd (char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) __attribute__ ((__deprecated__)) ;
extern int dup (int __fd) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int dup2 (int __fd, int __fd2) __attribute__ ((__nothrow__ , __leaf__));
# 543 "/usr/include/unistd.h" 3 4
extern char **__environ;
extern int execve (const char *__path, char *const __argv[],
     char *const __envp[]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int fexecve (int __fd, char *const __argv[], char *const __envp[])
extern int execv (const char *__path, char *const __argv[])
extern int execle (const char *__path, const char *__arg, ...)
extern int execl (const char *__path, const char *__arg, ...)
extern int execvp (const char *__file, char *const __argv[])
extern int execlp (const char *__file, const char *__arg, ...)
# 598 "/usr/include/unistd.h" 3 4
extern int nice (int __inc) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void _exit (int __status) __attribute__ ((__noreturn__));
# 1 "/usr/include/bits/confname.h" 1 3 4
# 24 "/usr/include/bits/confname.h" 3 4
enum
    _PC_LINK_MAX,
    _PC_MAX_CANON,
    _PC_MAX_INPUT,
    _PC_NAME_MAX,
    _PC_PATH_MAX,
    _PC_PIPE_BUF,
    _PC_CHOWN_RESTRICTED,
    _PC_NO_TRUNC,
    _PC_VDISABLE,
    _PC_SYNC_IO,
    _PC_ASYNC_IO,
    _PC_PRIO_IO,
    _PC_SOCK_MAXBUF,
    _PC_FILESIZEBITS,
    _PC_REC_INCR_XFER_SIZE,
    _PC_REC_MAX_XFER_SIZE,
    _PC_REC_MIN_XFER_SIZE,
    _PC_REC_XFER_ALIGN,
    _PC_ALLOC_SIZE_MIN,
    _PC_SYMLINK_MAX,
    _PC_2_SYMLINKS
enum
    _SC_ARG_MAX,
    _SC_CHILD_MAX,
    _SC_CLK_TCK,
    _SC_NGROUPS_MAX,
    _SC_OPEN_MAX,
    _SC_STREAM_MAX,
    _SC_TZNAME_MAX,
    _SC_JOB_CONTROL,
    _SC_SAVED_IDS,
    _SC_REALTIME_SIGNALS,
    _SC_PRIORITY_SCHEDULING,
    _SC_TIMERS,
    _SC_ASYNCHRONOUS_IO,
    _SC_PRIORITIZED_IO,
    _SC_SYNCHRONIZED_IO,
    _SC_FSYNC,
    _SC_MAPPED_FILES,
    _SC_MEMLOCK,
    _SC_MEMLOCK_RANGE,
    _SC_MEMORY_PROTECTION,
    _SC_MESSAGE_PASSING,
    _SC_SEMAPHORES,
    _SC_SHARED_MEMORY_OBJECTS,
    _SC_AIO_LISTIO_MAX,
    _SC_AIO_MAX,
    _SC_AIO_PRIO_DELTA_MAX,
    _SC_DELAYTIMER_MAX,
    _SC_MQ_OPEN_MAX,
    _SC_MQ_PRIO_MAX,
    _SC_VERSION,
    _SC_PAGESIZE,
    _SC_RTSIG_MAX,
    _SC_SEM_NSEMS_MAX,
    _SC_SEM_VALUE_MAX,
    _SC_SIGQUEUE_MAX,
    _SC_TIMER_MAX,
    _SC_BC_BASE_MAX,
    _SC_BC_DIM_MAX,
    _SC_BC_SCALE_MAX,
    _SC_BC_STRING_MAX,
    _SC_COLL_WEIGHTS_MAX,
    _SC_EQUIV_CLASS_MAX,
    _SC_EXPR_NEST_MAX,
    _SC_LINE_MAX,
    _SC_RE_DUP_MAX,
    _SC_CHARCLASS_NAME_MAX,
    _SC_2_VERSION,
    _SC_2_C_BIND,
    _SC_2_C_DEV,
    _SC_2_FORT_DEV,
    _SC_2_FORT_RUN,
    _SC_2_SW_DEV,
    _SC_2_LOCALEDEF,
    _SC_PII,
    _SC_PII_XTI,
    _SC_PII_SOCKET,
    _SC_PII_INTERNET,
    _SC_PII_OSI,
    _SC_POLL,
    _SC_SELECT,
    _SC_UIO_MAXIOV,
    _SC_IOV_MAX = _SC_UIO_MAXIOV,
    _SC_PII_INTERNET_STREAM,
    _SC_PII_INTERNET_DGRAM,
    _SC_PII_OSI_COTS,
    _SC_PII_OSI_CLTS,
    _SC_PII_OSI_M,
    _SC_T_IOV_MAX,
    _SC_THREADS,
    _SC_THREAD_SAFE_FUNCTIONS,
    _SC_GETGR_R_SIZE_MAX,
    _SC_GETPW_R_SIZE_MAX,
    _SC_LOGIN_NAME_MAX,
    _SC_TTY_NAME_MAX,
    _SC_THREAD_DESTRUCTOR_ITERATIONS,
    _SC_THREAD_KEYS_MAX,
    _SC_THREAD_STACK_MIN,
    _SC_THREAD_THREADS_MAX,
    _SC_THREAD_ATTR_STACKADDR,
    _SC_THREAD_ATTR_STACKSIZE,
    _SC_THREAD_PRIORITY_SCHEDULING,
    _SC_THREAD_PRIO_INHERIT,
    _SC_THREAD_PRIO_PROTECT,
    _SC_THREAD_PROCESS_SHARED,
    _SC_NPROCESSORS_CONF,
    _SC_NPROCESSORS_ONLN,
    _SC_PHYS_PAGES,
    _SC_AVPHYS_PAGES,
    _SC_ATEXIT_MAX,
    _SC_PASS_MAX,
    _SC_XOPEN_VERSION,
    _SC_XOPEN_XCU_VERSION,
    _SC_XOPEN_UNIX,
    _SC_XOPEN_CRYPT,
    _SC_XOPEN_ENH_I18N,
    _SC_XOPEN_SHM,
    _SC_2_CHAR_TERM,
    _SC_2_C_VERSION,
    _SC_2_UPE,
    _SC_XOPEN_XPG2,
    _SC_XOPEN_XPG3,
    _SC_XOPEN_XPG4,
    _SC_CHAR_BIT,
    _SC_CHAR_MAX,
    _SC_CHAR_MIN,
    _SC_INT_MAX,
    _SC_INT_MIN,
    _SC_LONG_BIT,
    _SC_WORD_BIT,
    _SC_MB_LEN_MAX,
    _SC_NZERO,
    _SC_SSIZE_MAX,
    _SC_SCHAR_MAX,
    _SC_SCHAR_MIN,
    _SC_SHRT_MAX,
    _SC_SHRT_MIN,
    _SC_UCHAR_MAX,
    _SC_UINT_MAX,
    _SC_ULONG_MAX,
    _SC_USHRT_MAX,
    _SC_NL_ARGMAX,
    _SC_NL_LANGMAX,
    _SC_NL_MSGMAX,
    _SC_NL_NMAX,
    _SC_NL_SETMAX,
    _SC_NL_TEXTMAX,
    _SC_XBS5_ILP32_OFF32,
    _SC_XBS5_ILP32_OFFBIG,
    _SC_XBS5_LP64_OFF64,
    _SC_XBS5_LPBIG_OFFBIG,
    _SC_XOPEN_LEGACY,
    _SC_XOPEN_REALTIME,
    _SC_XOPEN_REALTIME_THREADS,
    _SC_ADVISORY_INFO,
    _SC_BARRIERS,
    _SC_BASE,
    _SC_C_LANG_SUPPORT,
    _SC_C_LANG_SUPPORT_R,
    _SC_CLOCK_SELECTION,
    _SC_CPUTIME,
    _SC_THREAD_CPUTIME,
    _SC_DEVICE_IO,
    _SC_DEVICE_SPECIFIC,
    _SC_DEVICE_SPECIFIC_R,
    _SC_FD_MGMT,
    _SC_FIFO,
    _SC_PIPE,
    _SC_FILE_ATTRIBUTES,
    _SC_FILE_LOCKING,
    _SC_FILE_SYSTEM,
    _SC_MONOTONIC_CLOCK,
    _SC_MULTI_PROCESS,
    _SC_SINGLE_PROCESS,
    _SC_NETWORKING,
    _SC_READER_WRITER_LOCKS,
    _SC_SPIN_LOCKS,
    _SC_REGEXP,
    _SC_REGEX_VERSION,
    _SC_SHELL,
    _SC_SIGNALS,
    _SC_SPAWN,
    _SC_SPORADIC_SERVER,
    _SC_THREAD_SPORADIC_SERVER,
    _SC_SYSTEM_DATABASE,
    _SC_SYSTEM_DATABASE_R,
    _SC_TIMEOUTS,
    _SC_TYPED_MEMORY_OBJECTS,
    _SC_USER_GROUPS,
    _SC_USER_GROUPS_R,
    _SC_2_PBS,
    _SC_2_PBS_ACCOUNTING,
    _SC_2_PBS_LOCATE,
    _SC_2_PBS_MESSAGE,
    _SC_2_PBS_TRACK,
    _SC_SYMLOOP_MAX,
    _SC_STREAMS,
    _SC_2_PBS_CHECKPOINT,
    _SC_V6_ILP32_OFF32,
    _SC_V6_ILP32_OFFBIG,
    _SC_V6_LP64_OFF64,
    _SC_V6_LPBIG_OFFBIG,
    _SC_HOST_NAME_MAX,
    _SC_TRACE,
    _SC_TRACE_EVENT_FILTER,
    _SC_TRACE_INHERIT,
    _SC_TRACE_LOG,
    _SC_LEVEL1_ICACHE_SIZE,
    _SC_LEVEL1_ICACHE_ASSOC,
    _SC_LEVEL1_ICACHE_LINESIZE,
    _SC_LEVEL1_DCACHE_SIZE,
    _SC_LEVEL1_DCACHE_ASSOC,
    _SC_LEVEL1_DCACHE_LINESIZE,
    _SC_LEVEL2_CACHE_SIZE,
    _SC_LEVEL2_CACHE_ASSOC,
    _SC_LEVEL2_CACHE_LINESIZE,
    _SC_LEVEL3_CACHE_SIZE,
    _SC_LEVEL3_CACHE_ASSOC,
    _SC_LEVEL3_CACHE_LINESIZE,
    _SC_LEVEL4_CACHE_SIZE,
    _SC_LEVEL4_CACHE_ASSOC,
    _SC_LEVEL4_CACHE_LINESIZE,
    _SC_IPV6 = _SC_LEVEL1_ICACHE_SIZE + 50,
    _SC_RAW_SOCKETS,
    _SC_V7_ILP32_OFF32,
    _SC_V7_ILP32_OFFBIG,
    _SC_V7_LP64_OFF64,
    _SC_V7_LPBIG_OFFBIG,
    _SC_SS_REPL_MAX,
    _SC_TRACE_EVENT_NAME_MAX,
    _SC_TRACE_NAME_MAX,
    _SC_TRACE_SYS_MAX,
    _SC_TRACE_USER_EVENT_MAX,
    _SC_XOPEN_STREAMS,
    _SC_THREAD_ROBUST_PRIO_INHERIT,
    _SC_THREAD_ROBUST_PRIO_PROTECT
enum
    _CS_PATH,
    _CS_V6_WIDTH_RESTRICTED_ENVS,
    _CS_GNU_LIBC_VERSION,
    _CS_GNU_LIBPTHREAD_VERSION,
    _CS_V5_WIDTH_RESTRICTED_ENVS,
    _CS_V7_WIDTH_RESTRICTED_ENVS,
    _CS_LFS_CFLAGS = 1000,
    _CS_LFS_LDFLAGS,
    _CS_LFS_LIBS,
    _CS_LFS_LINTFLAGS,
    _CS_LFS64_CFLAGS,
    _CS_LFS64_LDFLAGS,
    _CS_LFS64_LIBS,
    _CS_LFS64_LINTFLAGS,
    _CS_XBS5_ILP32_OFF32_CFLAGS = 1100,
    _CS_XBS5_ILP32_OFF32_LDFLAGS,
    _CS_XBS5_ILP32_OFF32_LIBS,
    _CS_XBS5_ILP32_OFF32_LINTFLAGS,
    _CS_XBS5_ILP32_OFFBIG_CFLAGS,
    _CS_XBS5_ILP32_OFFBIG_LDFLAGS,
    _CS_XBS5_ILP32_OFFBIG_LIBS,
    _CS_XBS5_ILP32_OFFBIG_LINTFLAGS,
    _CS_XBS5_LP64_OFF64_CFLAGS,
    _CS_XBS5_LP64_OFF64_LDFLAGS,
    _CS_XBS5_LP64_OFF64_LIBS,
    _CS_XBS5_LP64_OFF64_LINTFLAGS,
    _CS_XBS5_LPBIG_OFFBIG_CFLAGS,
    _CS_XBS5_LPBIG_OFFBIG_LDFLAGS,
    _CS_XBS5_LPBIG_OFFBIG_LIBS,
    _CS_XBS5_LPBIG_OFFBIG_LINTFLAGS,
    _CS_POSIX_V6_ILP32_OFF32_CFLAGS,
    _CS_POSIX_V6_ILP32_OFF32_LDFLAGS,
    _CS_POSIX_V6_ILP32_OFF32_LIBS,
    _CS_POSIX_V6_ILP32_OFF32_LINTFLAGS,
    _CS_POSIX_V6_ILP32_OFFBIG_CFLAGS,
    _CS_POSIX_V6_ILP32_OFFBIG_LDFLAGS,
    _CS_POSIX_V6_ILP32_OFFBIG_LIBS,
    _CS_POSIX_V6_ILP32_OFFBIG_LINTFLAGS,
    _CS_POSIX_V6_LP64_OFF64_CFLAGS,
    _CS_POSIX_V6_LP64_OFF64_LDFLAGS,
    _CS_POSIX_V6_LP64_OFF64_LIBS,
    _CS_POSIX_V6_LP64_OFF64_LINTFLAGS,
    _CS_POSIX_V6_LPBIG_OFFBIG_CFLAGS,
    _CS_POSIX_V6_LPBIG_OFFBIG_LDFLAGS,
    _CS_POSIX_V6_LPBIG_OFFBIG_LIBS,
    _CS_POSIX_V6_LPBIG_OFFBIG_LINTFLAGS,
    _CS_POSIX_V7_ILP32_OFF32_CFLAGS,
    _CS_POSIX_V7_ILP32_OFF32_LDFLAGS,
    _CS_POSIX_V7_ILP32_OFF32_LIBS,
    _CS_POSIX_V7_ILP32_OFF32_LINTFLAGS,
    _CS_POSIX_V7_ILP32_OFFBIG_CFLAGS,
    _CS_POSIX_V7_ILP32_OFFBIG_LDFLAGS,
    _CS_POSIX_V7_ILP32_OFFBIG_LIBS,
    _CS_POSIX_V7_ILP32_OFFBIG_LINTFLAGS,
    _CS_POSIX_V7_LP64_OFF64_CFLAGS,
    _CS_POSIX_V7_LP64_OFF64_LDFLAGS,
    _CS_POSIX_V7_LP64_OFF64_LIBS,
    _CS_POSIX_V7_LP64_OFF64_LINTFLAGS,
    _CS_POSIX_V7_LPBIG_OFFBIG_CFLAGS,
    _CS_POSIX_V7_LPBIG_OFFBIG_LDFLAGS,
    _CS_POSIX_V7_LPBIG_OFFBIG_LIBS,
    _CS_POSIX_V7_LPBIG_OFFBIG_LINTFLAGS,
    _CS_V6_ENV,
    _CS_V7_ENV
# 610 "/usr/include/unistd.h" 2 3 4
extern long int pathconf (const char *__path, int __name)
extern long int fpathconf (int __fd, int __name) __attribute__ ((__nothrow__ , __leaf__));
extern long int sysconf (int __name) __attribute__ ((__nothrow__ , __leaf__));
extern size_t confstr (int __name, char *__buf, size_t __len) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getpid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getppid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getpgrp (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t __getpgid (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getpgid (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern int setpgid (__pid_t __pid, __pid_t __pgid) __attribute__ ((__nothrow__ , __leaf__));
# 660 "/usr/include/unistd.h" 3 4
extern int setpgrp (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t setsid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getsid (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern __uid_t getuid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __uid_t geteuid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __gid_t getgid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __gid_t getegid (void) __attribute__ ((__nothrow__ , __leaf__));
extern int getgroups (int __size, __gid_t __list[]) __attribute__ ((__nothrow__ , __leaf__)) ;
# 700 "/usr/include/unistd.h" 3 4
extern int setuid (__uid_t __uid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setreuid (__uid_t __ruid, __uid_t __euid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int seteuid (__uid_t __uid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setgid (__gid_t __gid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setregid (__gid_t __rgid, __gid_t __egid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setegid (__gid_t __gid) __attribute__ ((__nothrow__ , __leaf__)) ;
# 756 "/usr/include/unistd.h" 3 4
extern __pid_t fork (void) __attribute__ ((__nothrow__));
extern __pid_t vfork (void) __attribute__ ((__nothrow__ , __leaf__));
extern char *ttyname (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int ttyname_r (int __fd, char *__buf, size_t __buflen)
extern int isatty (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int ttyslot (void) __attribute__ ((__nothrow__ , __leaf__));
extern int link (const char *__from, const char *__to)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2))) ;
extern int linkat (int __fromfd, const char *__from, int __tofd,
     const char *__to, int __flags)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4))) ;
extern int symlink (const char *__from, const char *__to)
extern ssize_t readlink (const char *__restrict __path,
    char *__restrict __buf, size_t __len)
extern int symlinkat (const char *__from, int __tofd,
        const char *__to) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 3))) ;
extern ssize_t readlinkat (int __fd, const char *__restrict __path,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3))) ;
extern int unlink (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int unlinkat (int __fd, const char *__name, int __flag)
extern int rmdir (const char *__path) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern __pid_t tcgetpgrp (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int tcsetpgrp (int __fd, __pid_t __pgrp_id) __attribute__ ((__nothrow__ , __leaf__));
extern char *getlogin (void);
extern int getlogin_r (char *__name, size_t __name_len) __attribute__ ((__nonnull__ (1)));
extern int setlogin (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 871 "/usr/include/unistd.h" 3 4
# 1 "/usr/include/getopt.h" 1 3 4
# 57 "/usr/include/getopt.h" 3 4
extern char *optarg;
# 71 "/usr/include/getopt.h" 3 4
extern int optind;
extern int opterr;
extern int optopt;
# 150 "/usr/include/getopt.h" 3 4
extern int getopt (int ___argc, char *const *___argv, const char *__shortopts)
# 872 "/usr/include/unistd.h" 2 3 4
extern int gethostname (char *__name, size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sethostname (const char *__name, size_t __len)
extern int sethostid (long int __id) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int getdomainname (char *__name, size_t __len)
extern int setdomainname (const char *__name, size_t __len)
extern int vhangup (void) __attribute__ ((__nothrow__ , __leaf__));
extern int revoke (const char *__file) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern int profil (unsigned short int *__sample_buffer, size_t __size,
     size_t __offset, unsigned int __scale)
extern int acct (const char *__name) __attribute__ ((__nothrow__ , __leaf__));
extern char *getusershell (void) __attribute__ ((__nothrow__ , __leaf__));
extern void endusershell (void) __attribute__ ((__nothrow__ , __leaf__));
extern void setusershell (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daemon (int __nochdir, int __noclose) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int chroot (const char *__path) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern char *getpass (const char *__prompt) __attribute__ ((__nonnull__ (1)));
extern int fsync (int __fd);
# 969 "/usr/include/unistd.h" 3 4
extern long int gethostid (void);
extern void sync (void) __attribute__ ((__nothrow__ , __leaf__));
extern int getpagesize (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int getdtablesize (void) __attribute__ ((__nothrow__ , __leaf__));
# 993 "/usr/include/unistd.h" 3 4
extern int truncate (const char *__file, __off_t __length)
# 1016 "/usr/include/unistd.h" 3 4
extern int ftruncate (int __fd, __off_t __length) __attribute__ ((__nothrow__ , __leaf__)) ;
# 1037 "/usr/include/unistd.h" 3 4
extern int brk (void *__addr) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void *sbrk (intptr_t __delta) __attribute__ ((__nothrow__ , __leaf__));
# 1058 "/usr/include/unistd.h" 3 4
extern long int syscall (long int __sysno, ...) __attribute__ ((__nothrow__ , __leaf__));
# 1081 "/usr/include/unistd.h" 3 4
extern int lockf (int __fd, int __cmd, __off_t __len) ;
# 1112 "/usr/include/unistd.h" 3 4
extern int fdatasync (int __fildes);
# 1151 "/usr/include/unistd.h" 3 4
# 173 "/usr/include/hwloc/autogen/config.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdint.h" 1 3 4
# 9 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 26 "/usr/include/stdint.h" 3 4
# 1 "/usr/include/bits/wchar.h" 1 3 4
# 27 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 28 "/usr/include/stdint.h" 2 3 4
# 36 "/usr/include/stdint.h" 3 4
typedef signed char int8_t;
typedef short int int16_t;
typedef int int32_t;
typedef long int int64_t;
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned long int uint64_t;
# 65 "/usr/include/stdint.h" 3 4
typedef signed char int_least8_t;
typedef short int int_least16_t;
typedef int int_least32_t;
typedef long int int_least64_t;
typedef unsigned char uint_least8_t;
typedef unsigned short int uint_least16_t;
typedef unsigned int uint_least32_t;
typedef unsigned long int uint_least64_t;
# 90 "/usr/include/stdint.h" 3 4
typedef signed char int_fast8_t;
typedef long int int_fast16_t;
typedef long int int_fast32_t;
typedef long int int_fast64_t;
# 103 "/usr/include/stdint.h" 3 4
typedef unsigned char uint_fast8_t;
typedef unsigned long int uint_fast16_t;
typedef unsigned long int uint_fast32_t;
typedef unsigned long int uint_fast64_t;
# 122 "/usr/include/stdint.h" 3 4
typedef unsigned long int uintptr_t;
# 134 "/usr/include/stdint.h" 3 4
typedef long int intmax_t;
typedef unsigned long int uintmax_t;
# 10 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdint.h" 2 3 4
# 175 "/usr/include/hwloc/autogen/config.h" 2 3 4
typedef uint64_t hwloc_uint64_t;
# 51 "/usr/include/hwloc.h" 2 3 4
# 1 "/usr/include/sys/types.h" 1 3 4
# 27 "/usr/include/sys/types.h" 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 60 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
# 70 "/usr/include/sys/types.h" 3 4
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
# 104 "/usr/include/sys/types.h" 3 4
typedef __id_t id_t;
# 115 "/usr/include/sys/types.h" 3 4
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 146 "/usr/include/sys/types.h" 3 4
# 147 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 200 "/usr/include/sys/types.h" 3 4
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 219 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/sigset.h" 1 3 4
# 22 "/usr/include/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 46 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 64 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 96 "/usr/include/sys/select.h" 3 4
# 106 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 118 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 131 "/usr/include/sys/select.h" 3 4
# 220 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/sysmacros.h" 1 3 4
# 24 "/usr/include/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 58 "/usr/include/sys/sysmacros.h" 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 273 "/usr/include/sys/types.h" 3 4
# 52 "/usr/include/hwloc.h" 2 3 4
# 1 "/usr/include/stdio.h" 1 3 4
# 29 "/usr/include/stdio.h" 3 4
# 34 "/usr/include/stdio.h" 2 3 4
# 44 "/usr/include/stdio.h" 3 4
struct _IO_FILE;
typedef struct _IO_FILE FILE;
# 64 "/usr/include/stdio.h" 3 4
typedef struct _IO_FILE __FILE;
# 74 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/libio.h" 1 3 4
# 31 "/usr/include/libio.h" 3 4
# 1 "/usr/include/_G_config.h" 1 3 4
# 15 "/usr/include/_G_config.h" 3 4
# 16 "/usr/include/_G_config.h" 2 3 4
# 1 "/usr/include/wchar.h" 1 3 4
# 82 "/usr/include/wchar.h" 3 4
typedef struct
  int __count;
  union
    unsigned int __wch;
    char __wchb[4];
  } __value;
} __mbstate_t;
# 21 "/usr/include/_G_config.h" 2 3 4
typedef struct
  __off_t __pos;
  __mbstate_t __state;
} _G_fpos_t;
typedef struct
  __off64_t __pos;
} _G_fpos64_t;
# 32 "/usr/include/libio.h" 2 3 4
# 49 "/usr/include/libio.h" 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdarg.h" 1 3 4
# 40 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stdarg.h" 3 4
typedef __builtin_va_list __gnuc_va_list;
# 50 "/usr/include/libio.h" 2 3 4
# 144 "/usr/include/libio.h" 3 4
struct _IO_jump_t; struct _IO_FILE;
# 154 "/usr/include/libio.h" 3 4
typedef void _IO_lock_t;
struct _IO_marker {
  struct _IO_marker *_next;
  struct _IO_FILE *_sbuf;
  int _pos;
# 177 "/usr/include/libio.h" 3 4
enum __codecvt_result
  __codecvt_ok,
  __codecvt_partial,
  __codecvt_error,
  __codecvt_noconv
# 245 "/usr/include/libio.h" 3 4
struct _IO_FILE {
  int _flags;
  char* _IO_read_ptr;
  char* _IO_read_end;
  char* _IO_read_base;
  char* _IO_write_base;
  char* _IO_write_ptr;
  char* _IO_write_end;
  char* _IO_buf_base;
  char* _IO_buf_end;
  char *_IO_save_base;
  char *_IO_backup_base;
  char *_IO_save_end;
  struct _IO_marker *_markers;
  struct _IO_FILE *_chain;
  int _fileno;
  int _flags2;
  __off_t _old_offset;
  unsigned short _cur_column;
  signed char _vtable_offset;
  char _shortbuf[1];
  _IO_lock_t *_lock;
# 293 "/usr/include/libio.h" 3 4
  __off64_t _offset;
# 302 "/usr/include/libio.h" 3 4
  void *__pad1;
  void *__pad2;
  void *__pad3;
  void *__pad4;
  size_t __pad5;
  int _mode;
  char _unused2[15 * sizeof (int) - 4 * sizeof (void *) - sizeof (size_t)];
typedef struct _IO_FILE _IO_FILE;
struct _IO_FILE_plus;
extern struct _IO_FILE_plus _IO_2_1_stdin_;
extern struct _IO_FILE_plus _IO_2_1_stdout_;
extern struct _IO_FILE_plus _IO_2_1_stderr_;
# 338 "/usr/include/libio.h" 3 4
typedef __ssize_t __io_read_fn (void *__cookie, char *__buf, size_t __nbytes);
typedef __ssize_t __io_write_fn (void *__cookie, const char *__buf,
     size_t __n);
typedef int __io_seek_fn (void *__cookie, __off64_t *__pos, int __w);
typedef int __io_close_fn (void *__cookie);
# 390 "/usr/include/libio.h" 3 4
extern int __underflow (_IO_FILE *);
extern int __uflow (_IO_FILE *);
extern int __overflow (_IO_FILE *, int);
# 434 "/usr/include/libio.h" 3 4
extern int _IO_getc (_IO_FILE *__fp);
extern int _IO_putc (int __c, _IO_FILE *__fp);
extern int _IO_feof (_IO_FILE *__fp) __attribute__ ((__nothrow__ , __leaf__));
extern int _IO_ferror (_IO_FILE *__fp) __attribute__ ((__nothrow__ , __leaf__));
extern int _IO_peekc_locked (_IO_FILE *__fp);
extern void _IO_flockfile (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
extern void _IO_funlockfile (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
extern int _IO_ftrylockfile (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
# 464 "/usr/include/libio.h" 3 4
extern int _IO_vfscanf (_IO_FILE * __restrict, const char * __restrict,
   __gnuc_va_list, int *__restrict);
extern int _IO_vfprintf (_IO_FILE *__restrict, const char *__restrict,
    __gnuc_va_list);
extern __ssize_t _IO_padn (_IO_FILE *, int, __ssize_t);
extern size_t _IO_sgetn (_IO_FILE *, void *, size_t);
extern __off64_t _IO_seekoff (_IO_FILE *, __off64_t, int, int);
extern __off64_t _IO_seekpos (_IO_FILE *, __off64_t, int);
extern void _IO_free_backup_area (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
# 75 "/usr/include/stdio.h" 2 3 4
typedef __gnuc_va_list va_list;
# 108 "/usr/include/stdio.h" 3 4
typedef _G_fpos_t fpos_t;
# 164 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/bits/stdio_lim.h" 1 3 4
# 165 "/usr/include/stdio.h" 2 3 4
extern struct _IO_FILE *stdin;
extern struct _IO_FILE *stdout;
extern struct _IO_FILE *stderr;
extern int remove (const char *__filename) __attribute__ ((__nothrow__ , __leaf__));
extern int rename (const char *__old, const char *__new) __attribute__ ((__nothrow__ , __leaf__));
extern int renameat (int __oldfd, const char *__old, int __newfd,
extern FILE *tmpfile (void) ;
# 209 "/usr/include/stdio.h" 3 4
extern char *tmpnam (char *__s) __attribute__ ((__nothrow__ , __leaf__)) ;
extern char *tmpnam_r (char *__s) __attribute__ ((__nothrow__ , __leaf__)) ;
# 227 "/usr/include/stdio.h" 3 4
extern char *tempnam (const char *__dir, const char *__pfx)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int fclose (FILE *__stream);
extern int fflush (FILE *__stream);
# 252 "/usr/include/stdio.h" 3 4
extern int fflush_unlocked (FILE *__stream);
# 266 "/usr/include/stdio.h" 3 4
extern FILE *fopen (const char *__restrict __filename,
      const char *__restrict __modes) ;
extern FILE *freopen (const char *__restrict __filename,
        const char *__restrict __modes,
        FILE *__restrict __stream) ;
# 295 "/usr/include/stdio.h" 3 4
# 306 "/usr/include/stdio.h" 3 4
extern FILE *fdopen (int __fd, const char *__modes) __attribute__ ((__nothrow__ , __leaf__)) ;
# 319 "/usr/include/stdio.h" 3 4
extern FILE *fmemopen (void *__s, size_t __len, const char *__modes)
extern FILE *open_memstream (char **__bufloc, size_t *__sizeloc) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void setbuf (FILE *__restrict __stream, char *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__));
extern int setvbuf (FILE *__restrict __stream, char *__restrict __buf,
      int __modes, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern void setbuffer (FILE *__restrict __stream, char *__restrict __buf,
         size_t __size) __attribute__ ((__nothrow__ , __leaf__));
extern void setlinebuf (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int fprintf (FILE *__restrict __stream,
      const char *__restrict __format, ...);
extern int printf (const char *__restrict __format, ...);
extern int sprintf (char *__restrict __s,
      const char *__restrict __format, ...) __attribute__ ((__nothrow__));
extern int vfprintf (FILE *__restrict __s, const char *__restrict __format,
       __gnuc_va_list __arg);
extern int vprintf (const char *__restrict __format, __gnuc_va_list __arg);
extern int vsprintf (char *__restrict __s, const char *__restrict __format,
       __gnuc_va_list __arg) __attribute__ ((__nothrow__));
extern int snprintf (char *__restrict __s, size_t __maxlen,
     __attribute__ ((__nothrow__)) __attribute__ ((__format__ (__printf__, 3, 4)));
extern int vsnprintf (char *__restrict __s, size_t __maxlen,
     __attribute__ ((__nothrow__)) __attribute__ ((__format__ (__printf__, 3, 0)));
# 412 "/usr/include/stdio.h" 3 4
extern int vdprintf (int __fd, const char *__restrict __fmt,
     __attribute__ ((__format__ (__printf__, 2, 0)));
extern int dprintf (int __fd, const char *__restrict __fmt, ...)
     __attribute__ ((__format__ (__printf__, 2, 3)));
extern int fscanf (FILE *__restrict __stream,
     const char *__restrict __format, ...) ;
extern int scanf (const char *__restrict __format, ...) ;
extern int sscanf (const char *__restrict __s,
     const char *__restrict __format, ...) __attribute__ ((__nothrow__ , __leaf__));
# 443 "/usr/include/stdio.h" 3 4
extern int fscanf (FILE *__restrict __stream, const char *__restrict __format, ...) __asm__ ("" "__isoc99_fscanf")
extern int scanf (const char *__restrict __format, ...) __asm__ ("" "__isoc99_scanf")
extern int sscanf (const char *__restrict __s, const char *__restrict __format, ...) __asm__ ("" "__isoc99_sscanf") __attribute__ ((__nothrow__ , __leaf__))
# 463 "/usr/include/stdio.h" 3 4
extern int vfscanf (FILE *__restrict __s, const char *__restrict __format,
     __attribute__ ((__format__ (__scanf__, 2, 0))) ;
extern int vscanf (const char *__restrict __format, __gnuc_va_list __arg)
     __attribute__ ((__format__ (__scanf__, 1, 0))) ;
extern int vsscanf (const char *__restrict __s,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__format__ (__scanf__, 2, 0)));
# 494 "/usr/include/stdio.h" 3 4
extern int vfscanf (FILE *__restrict __s, const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vfscanf")
extern int vscanf (const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vscanf")
extern int vsscanf (const char *__restrict __s, const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vsscanf") __attribute__ ((__nothrow__ , __leaf__))
# 522 "/usr/include/stdio.h" 3 4
extern int fgetc (FILE *__stream);
extern int getc (FILE *__stream);
extern int getchar (void);
# 550 "/usr/include/stdio.h" 3 4
extern int getc_unlocked (FILE *__stream);
extern int getchar_unlocked (void);
# 561 "/usr/include/stdio.h" 3 4
extern int fgetc_unlocked (FILE *__stream);
extern int fputc (int __c, FILE *__stream);
extern int putc (int __c, FILE *__stream);
extern int putchar (int __c);
# 594 "/usr/include/stdio.h" 3 4
extern int fputc_unlocked (int __c, FILE *__stream);
extern int putc_unlocked (int __c, FILE *__stream);
extern int putchar_unlocked (int __c);
extern int getw (FILE *__stream);
extern int putw (int __w, FILE *__stream);
extern char *fgets (char *__restrict __s, int __n, FILE *__restrict __stream)
# 638 "/usr/include/stdio.h" 3 4
extern char *gets (char *__s) __attribute__ ((__deprecated__));
# 665 "/usr/include/stdio.h" 3 4
extern __ssize_t __getdelim (char **__restrict __lineptr,
          size_t *__restrict __n, int __delimiter,
extern __ssize_t getdelim (char **__restrict __lineptr,
extern __ssize_t getline (char **__restrict __lineptr,
extern int fputs (const char *__restrict __s, FILE *__restrict __stream);
extern int puts (const char *__s);
extern int ungetc (int __c, FILE *__stream);
extern size_t fread (void *__restrict __ptr, size_t __size,
       size_t __n, FILE *__restrict __stream) ;
extern size_t fwrite (const void *__restrict __ptr, size_t __size,
        size_t __n, FILE *__restrict __s);
# 737 "/usr/include/stdio.h" 3 4
extern size_t fread_unlocked (void *__restrict __ptr, size_t __size,
extern size_t fwrite_unlocked (const void *__restrict __ptr, size_t __size,
          size_t __n, FILE *__restrict __stream);
extern int fseek (FILE *__stream, long int __off, int __whence);
extern long int ftell (FILE *__stream) ;
extern void rewind (FILE *__stream);
# 773 "/usr/include/stdio.h" 3 4
extern int fseeko (FILE *__stream, __off_t __off, int __whence);
extern __off_t ftello (FILE *__stream) ;
# 792 "/usr/include/stdio.h" 3 4
extern int fgetpos (FILE *__restrict __stream, fpos_t *__restrict __pos);
extern int fsetpos (FILE *__stream, const fpos_t *__pos);
# 815 "/usr/include/stdio.h" 3 4
# 824 "/usr/include/stdio.h" 3 4
extern void clearerr (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int feof (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int ferror (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void clearerr_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int feof_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int ferror_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void perror (const char *__s);
# 1 "/usr/include/bits/sys_errlist.h" 1 3 4
# 26 "/usr/include/bits/sys_errlist.h" 3 4
extern int sys_nerr;
extern const char *const sys_errlist[];
# 854 "/usr/include/stdio.h" 2 3 4
extern int fileno (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int fileno_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
# 872 "/usr/include/stdio.h" 3 4
extern FILE *popen (const char *__command, const char *__modes) ;
extern int pclose (FILE *__stream);
extern char *ctermid (char *__s) __attribute__ ((__nothrow__ , __leaf__));
# 912 "/usr/include/stdio.h" 3 4
extern void flockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int ftrylockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void funlockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
# 942 "/usr/include/stdio.h" 3 4
# 53 "/usr/include/hwloc.h" 2 3 4
# 1 "/usr/include/string.h" 1 3 4
# 27 "/usr/include/string.h" 3 4
# 33 "/usr/include/string.h" 2 3 4
# 44 "/usr/include/string.h" 3 4
extern void *memcpy (void *__restrict __dest, const void *__restrict __src,
       size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern void *memmove (void *__dest, const void *__src, size_t __n)
extern void *memccpy (void *__restrict __dest, const void *__restrict __src,
        int __c, size_t __n)
extern void *memset (void *__s, int __c, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int memcmp (const void *__s1, const void *__s2, size_t __n)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
# 96 "/usr/include/string.h" 3 4
extern void *memchr (const void *__s, int __c, size_t __n)
      __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
# 127 "/usr/include/string.h" 3 4
extern char *strcpy (char *__restrict __dest, const char *__restrict __src)
extern char *strncpy (char *__restrict __dest,
        const char *__restrict __src, size_t __n)
extern char *strcat (char *__restrict __dest, const char *__restrict __src)
extern char *strncat (char *__restrict __dest, const char *__restrict __src,
extern int strcmp (const char *__s1, const char *__s2)
extern int strncmp (const char *__s1, const char *__s2, size_t __n)
extern int strcoll (const char *__s1, const char *__s2)
extern size_t strxfrm (char *__restrict __dest,
# 166 "/usr/include/string.h" 3 4
extern int strcoll_l (const char *__s1, const char *__s2, __locale_t __l)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern size_t strxfrm_l (char *__dest, const char *__src, size_t __n,
    __locale_t __l) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern char *strdup (const char *__s)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) __attribute__ ((__nonnull__ (1)));
extern char *strndup (const char *__string, size_t __n)
# 210 "/usr/include/string.h" 3 4
# 235 "/usr/include/string.h" 3 4
extern char *strchr (const char *__s, int __c)
# 262 "/usr/include/string.h" 3 4
extern char *strrchr (const char *__s, int __c)
# 281 "/usr/include/string.h" 3 4
extern size_t strcspn (const char *__s, const char *__reject)
extern size_t strspn (const char *__s, const char *__accept)
# 314 "/usr/include/string.h" 3 4
extern char *strpbrk (const char *__s, const char *__accept)
# 341 "/usr/include/string.h" 3 4
extern char *strstr (const char *__haystack, const char *__needle)
extern char *strtok (char *__restrict __s, const char *__restrict __delim)
extern char *__strtok_r (char *__restrict __s,
    const char *__restrict __delim,
    char **__restrict __save_ptr)
extern char *strtok_r (char *__restrict __s, const char *__restrict __delim,
# 396 "/usr/include/string.h" 3 4
extern size_t strlen (const char *__s)
extern size_t strnlen (const char *__string, size_t __maxlen)
extern char *strerror (int __errnum) __attribute__ ((__nothrow__ , __leaf__));
# 426 "/usr/include/string.h" 3 4
extern int strerror_r (int __errnum, char *__buf, size_t __buflen) __asm__ ("" "__xpg_strerror_r") __attribute__ ((__nothrow__ , __leaf__))
# 444 "/usr/include/string.h" 3 4
extern char *strerror_l (int __errnum, __locale_t __l) __attribute__ ((__nothrow__ , __leaf__));
extern void __bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern void bcopy (const void *__src, void *__dest, size_t __n)
extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
# 488 "/usr/include/string.h" 3 4
extern char *index (const char *__s, int __c)
# 516 "/usr/include/string.h" 3 4
extern char *rindex (const char *__s, int __c)
extern int ffs (int __i) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 533 "/usr/include/string.h" 3 4
extern int strcasecmp (const char *__s1, const char *__s2)
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
# 556 "/usr/include/string.h" 3 4
extern char *strsep (char **__restrict __stringp,
extern char *strsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern char *__stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *__stpncpy (char *__restrict __dest,
extern char *stpncpy (char *__restrict __dest,
# 643 "/usr/include/string.h" 3 4
# 54 "/usr/include/hwloc.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include-fixed/limits.h" 1 3 4
# 34 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include-fixed/limits.h" 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include-fixed/syslimits.h" 1 3 4
# 168 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include-fixed/limits.h" 3 4
# 1 "/usr/include/limits.h" 1 3 4
# 143 "/usr/include/limits.h" 3 4
# 1 "/usr/include/bits/posix1_lim.h" 1 3 4
# 160 "/usr/include/bits/posix1_lim.h" 3 4
# 1 "/usr/include/bits/local_lim.h" 1 3 4
# 38 "/usr/include/bits/local_lim.h" 3 4
# 1 "/usr/include/linux/limits.h" 1 3 4
# 39 "/usr/include/bits/local_lim.h" 2 3 4
# 161 "/usr/include/bits/posix1_lim.h" 2 3 4
# 144 "/usr/include/limits.h" 2 3 4
# 1 "/usr/include/bits/posix2_lim.h" 1 3 4
# 148 "/usr/include/limits.h" 2 3 4
# 169 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include-fixed/limits.h" 2 3 4
# 8 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include-fixed/syslimits.h" 2 3 4
# 35 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include-fixed/limits.h" 2 3 4
# 55 "/usr/include/hwloc.h" 2 3 4
# 1 "/usr/include/hwloc/rename.h" 1 3 4
# 60 "/usr/include/hwloc.h" 2 3 4
# 1 "/usr/include/hwloc/bitmap.h" 1 3 4
# 17 "/usr/include/hwloc/bitmap.h" 3 4
# 1 "/usr/include/assert.h" 1 3 4
# 64 "/usr/include/assert.h" 3 4
extern void __assert_fail (const char *__assertion, const char *__file,
      unsigned int __line, const char *__function)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void __assert_perror_fail (int __errnum, const char *__file,
extern void __assert (const char *__assertion, const char *__file, int __line)
# 18 "/usr/include/hwloc/bitmap.h" 2 3 4
# 45 "/usr/include/hwloc/bitmap.h" 3 4
typedef struct hwloc_bitmap_s * hwloc_bitmap_t;
typedef const struct hwloc_bitmap_s * hwloc_const_bitmap_t;
# 61 "/usr/include/hwloc/bitmap.h" 3 4
 hwloc_bitmap_t hwloc_bitmap_alloc(void) __attribute__((__malloc__));
 hwloc_bitmap_t hwloc_bitmap_alloc_full(void) __attribute__((__malloc__));
 void hwloc_bitmap_free(hwloc_bitmap_t bitmap);
 hwloc_bitmap_t hwloc_bitmap_dup(hwloc_const_bitmap_t bitmap) __attribute__((__malloc__));
 void hwloc_bitmap_copy(hwloc_bitmap_t dst, hwloc_const_bitmap_t src);
# 95 "/usr/include/hwloc/bitmap.h" 3 4
 int hwloc_bitmap_snprintf(char * __restrict buf, size_t buflen, hwloc_const_bitmap_t bitmap);
 int hwloc_bitmap_asprintf(char ** strp, hwloc_const_bitmap_t bitmap);
 int hwloc_bitmap_sscanf(hwloc_bitmap_t bitmap, const char * __restrict string);
# 118 "/usr/include/hwloc/bitmap.h" 3 4
 int hwloc_bitmap_list_snprintf(char * __restrict buf, size_t buflen, hwloc_const_bitmap_t bitmap);
 int hwloc_bitmap_list_asprintf(char ** strp, hwloc_const_bitmap_t bitmap);
 int hwloc_bitmap_list_sscanf(hwloc_bitmap_t bitmap, const char * __restrict string);
# 140 "/usr/include/hwloc/bitmap.h" 3 4
 int hwloc_bitmap_taskset_snprintf(char * __restrict buf, size_t buflen, hwloc_const_bitmap_t bitmap);
 int hwloc_bitmap_taskset_asprintf(char ** strp, hwloc_const_bitmap_t bitmap);
 int hwloc_bitmap_taskset_sscanf(hwloc_bitmap_t bitmap, const char * __restrict string);
 void hwloc_bitmap_zero(hwloc_bitmap_t bitmap);
 void hwloc_bitmap_fill(hwloc_bitmap_t bitmap);
 void hwloc_bitmap_only(hwloc_bitmap_t bitmap, unsigned id);
 void hwloc_bitmap_allbut(hwloc_bitmap_t bitmap, unsigned id);
 void hwloc_bitmap_from_ulong(hwloc_bitmap_t bitmap, unsigned long mask);
 void hwloc_bitmap_from_ith_ulong(hwloc_bitmap_t bitmap, unsigned i, unsigned long mask);
 void hwloc_bitmap_set(hwloc_bitmap_t bitmap, unsigned id);
 void hwloc_bitmap_set_range(hwloc_bitmap_t bitmap, unsigned begin, int end);
 void hwloc_bitmap_set_ith_ulong(hwloc_bitmap_t bitmap, unsigned i, unsigned long mask);
 void hwloc_bitmap_clr(hwloc_bitmap_t bitmap, unsigned id);
 void hwloc_bitmap_clr_range(hwloc_bitmap_t bitmap, unsigned begin, int end);
 void hwloc_bitmap_singlify(hwloc_bitmap_t bitmap);
 unsigned long hwloc_bitmap_to_ulong(hwloc_const_bitmap_t bitmap) __attribute__((__pure__));
 unsigned long hwloc_bitmap_to_ith_ulong(hwloc_const_bitmap_t bitmap, unsigned i) __attribute__((__pure__));
 int hwloc_bitmap_isset(hwloc_const_bitmap_t bitmap, unsigned id) __attribute__((__pure__));
 int hwloc_bitmap_iszero(hwloc_const_bitmap_t bitmap) __attribute__((__pure__));
 int hwloc_bitmap_isfull(hwloc_const_bitmap_t bitmap) __attribute__((__pure__));
 int hwloc_bitmap_first(hwloc_const_bitmap_t bitmap) __attribute__((__pure__));
 int hwloc_bitmap_next(hwloc_const_bitmap_t bitmap, int prev) __attribute__((__pure__));
 int hwloc_bitmap_last(hwloc_const_bitmap_t bitmap) __attribute__((__pure__));
 int hwloc_bitmap_weight(hwloc_const_bitmap_t bitmap) __attribute__((__pure__));
# 288 "/usr/include/hwloc/bitmap.h" 3 4
 void hwloc_bitmap_or (hwloc_bitmap_t res, hwloc_const_bitmap_t bitmap1, hwloc_const_bitmap_t bitmap2);
 void hwloc_bitmap_and (hwloc_bitmap_t res, hwloc_const_bitmap_t bitmap1, hwloc_const_bitmap_t bitmap2);
 void hwloc_bitmap_andnot (hwloc_bitmap_t res, hwloc_const_bitmap_t bitmap1, hwloc_const_bitmap_t bitmap2);
 void hwloc_bitmap_xor (hwloc_bitmap_t res, hwloc_const_bitmap_t bitmap1, hwloc_const_bitmap_t bitmap2);
 void hwloc_bitmap_not (hwloc_bitmap_t res, hwloc_const_bitmap_t bitmap);
 int hwloc_bitmap_intersects (hwloc_const_bitmap_t bitmap1, hwloc_const_bitmap_t bitmap2) __attribute__((__pure__));
 int hwloc_bitmap_isincluded (hwloc_const_bitmap_t sub_bitmap, hwloc_const_bitmap_t super_bitmap) __attribute__((__pure__));
 int hwloc_bitmap_isequal (hwloc_const_bitmap_t bitmap1, hwloc_const_bitmap_t bitmap2) __attribute__((__pure__));
 int hwloc_bitmap_compare_first(hwloc_const_bitmap_t bitmap1, hwloc_const_bitmap_t bitmap2) __attribute__((__pure__));
 int hwloc_bitmap_compare(hwloc_const_bitmap_t bitmap1, hwloc_const_bitmap_t bitmap2) __attribute__((__pure__));
# 66 "/usr/include/hwloc.h" 2 3 4
# 81 "/usr/include/hwloc.h" 3 4
 unsigned hwloc_get_api_version(void);
# 116 "/usr/include/hwloc.h" 3 4
typedef hwloc_bitmap_t hwloc_cpuset_t;
typedef hwloc_const_bitmap_t hwloc_const_cpuset_t;
# 133 "/usr/include/hwloc.h" 3 4
typedef hwloc_bitmap_t hwloc_nodeset_t;
typedef hwloc_const_bitmap_t hwloc_const_nodeset_t;
# 152 "/usr/include/hwloc.h" 3 4
typedef enum {
# 162 "/usr/include/hwloc.h" 3 4
  HWLOC_OBJ_SYSTEM,
  HWLOC_OBJ_MACHINE,
  HWLOC_OBJ_NODE,
  HWLOC_OBJ_SOCKET,
  HWLOC_OBJ_CACHE,
  HWLOC_OBJ_CORE,
  HWLOC_OBJ_PU,
# 196 "/usr/include/hwloc.h" 3 4
  HWLOC_OBJ_GROUP,
# 208 "/usr/include/hwloc.h" 3 4
  HWLOC_OBJ_MISC,
  HWLOC_OBJ_BRIDGE,
  HWLOC_OBJ_PCI_DEVICE,
  HWLOC_OBJ_OS_DEVICE,
  HWLOC_OBJ_TYPE_MAX
# 241 "/usr/include/hwloc.h" 3 4
} hwloc_obj_type_t;
typedef enum hwloc_obj_cache_type_e {
  HWLOC_OBJ_CACHE_UNIFIED,
  HWLOC_OBJ_CACHE_DATA,
  HWLOC_OBJ_CACHE_INSTRUCTION
} hwloc_obj_cache_type_t;
typedef enum hwloc_obj_bridge_type_e {
  HWLOC_OBJ_BRIDGE_HOST,
  HWLOC_OBJ_BRIDGE_PCI
} hwloc_obj_bridge_type_t;
typedef enum hwloc_obj_osdev_type_e {
  HWLOC_OBJ_OSDEV_BLOCK,
  HWLOC_OBJ_OSDEV_GPU,
  HWLOC_OBJ_OSDEV_NETWORK,
  HWLOC_OBJ_OSDEV_OPENFABRICS,
  HWLOC_OBJ_OSDEV_DMA,
  HWLOC_OBJ_OSDEV_COPROC
} hwloc_obj_osdev_type_t;
# 293 "/usr/include/hwloc.h" 3 4
 int hwloc_compare_types (hwloc_obj_type_t type1, hwloc_obj_type_t type2) __attribute__((__const__));
enum hwloc_compare_types_e {
    HWLOC_TYPE_UNORDERED = 2147483647
# 307 "/usr/include/hwloc.h" 3 4
union hwloc_obj_attr_u;
struct hwloc_obj_memory_s {
  hwloc_uint64_t total_memory;
  hwloc_uint64_t local_memory;
  unsigned page_types_len;
  struct hwloc_obj_memory_page_type_s {
    hwloc_uint64_t size;
    hwloc_uint64_t count;
  } * page_types;
struct hwloc_obj {
  hwloc_obj_type_t type;
  unsigned os_index;
  char *name;
  struct hwloc_obj_memory_s memory;
  union hwloc_obj_attr_u *attr;
  unsigned depth;
  unsigned logical_index;
  signed os_level;
  struct hwloc_obj *next_cousin;
  struct hwloc_obj *prev_cousin;
  struct hwloc_obj *parent;
  unsigned sibling_rank;
  struct hwloc_obj *next_sibling;
  struct hwloc_obj *prev_sibling;
  unsigned arity;
  struct hwloc_obj **children;
  struct hwloc_obj *first_child;
  struct hwloc_obj *last_child;
  void *userdata;
  hwloc_cpuset_t cpuset;
# 388 "/usr/include/hwloc.h" 3 4
  hwloc_cpuset_t complete_cpuset;
# 399 "/usr/include/hwloc.h" 3 4
  hwloc_cpuset_t online_cpuset;
  hwloc_cpuset_t allowed_cpuset;
# 418 "/usr/include/hwloc.h" 3 4
  hwloc_nodeset_t nodeset;
# 435 "/usr/include/hwloc.h" 3 4
  hwloc_nodeset_t complete_nodeset;
# 449 "/usr/include/hwloc.h" 3 4
  hwloc_nodeset_t allowed_nodeset;
# 462 "/usr/include/hwloc.h" 3 4
  struct hwloc_distances_s **distances;
  unsigned distances_count;
  struct hwloc_obj_info_s *infos;
  unsigned infos_count;
  int symmetric_subtree;
typedef struct hwloc_obj * hwloc_obj_t;
union hwloc_obj_attr_u {
  struct hwloc_cache_attr_s {
    unsigned depth;
    unsigned linesize;
    int associativity;
    hwloc_obj_cache_type_t type;
  } cache;
  struct hwloc_group_attr_s {
    unsigned depth;
  } group;
  struct hwloc_pcidev_attr_s {
    unsigned short domain;
    unsigned char bus, dev, func;
    unsigned short class_id;
    unsigned short vendor_id, device_id, subvendor_id, subdevice_id;
    unsigned char revision;
    float linkspeed;
  } pcidev;
  struct hwloc_bridge_attr_s {
    union {
      struct hwloc_pcidev_attr_s pci;
    } upstream;
    hwloc_obj_bridge_type_t upstream_type;
    union {
      struct {
 unsigned char secondary_bus, subordinate_bus;
      } pci;
    } downstream;
    hwloc_obj_bridge_type_t downstream_type;
    unsigned depth;
  } bridge;
  struct hwloc_osdev_attr_s {
    hwloc_obj_osdev_type_t type;
  } osdev;
# 538 "/usr/include/hwloc.h" 3 4
struct hwloc_distances_s {
  unsigned relative_depth;
  unsigned nbobjs;
  float *latency;
  float latency_max;
  float latency_base;
struct hwloc_obj_info_s {
  char *name;
  char *value;
# 572 "/usr/include/hwloc.h" 3 4
struct hwloc_topology;
typedef struct hwloc_topology * hwloc_topology_t;
 int hwloc_topology_init (hwloc_topology_t *topologyp);
# 604 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_load(hwloc_topology_t topology);
 void hwloc_topology_destroy (hwloc_topology_t topology);
# 623 "/usr/include/hwloc.h" 3 4
 void hwloc_topology_check(hwloc_topology_t topology);
# 659 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_ignore_type(hwloc_topology_t topology, hwloc_obj_type_t type);
# 669 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_ignore_type_keep_structure(hwloc_topology_t topology, hwloc_obj_type_t type);
# 678 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_ignore_all_keep_structure(hwloc_topology_t topology);
enum hwloc_topology_flags_e {
  HWLOC_TOPOLOGY_FLAG_WHOLE_SYSTEM = (1UL<<0),
# 713 "/usr/include/hwloc.h" 3 4
  HWLOC_TOPOLOGY_FLAG_IS_THISSYSTEM = (1UL<<1),
# 725 "/usr/include/hwloc.h" 3 4
  HWLOC_TOPOLOGY_FLAG_IO_DEVICES = (1UL<<2),
# 734 "/usr/include/hwloc.h" 3 4
  HWLOC_TOPOLOGY_FLAG_IO_BRIDGES = (1UL<<3),
# 743 "/usr/include/hwloc.h" 3 4
  HWLOC_TOPOLOGY_FLAG_WHOLE_IO = (1UL<<4),
  HWLOC_TOPOLOGY_FLAG_ICACHES = (1UL<<5)
# 763 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_set_flags (hwloc_topology_t topology, unsigned long flags);
 unsigned long hwloc_topology_get_flags (hwloc_topology_t topology);
# 787 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_set_pid(hwloc_topology_t __restrict topology, pid_t pid);
# 815 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_set_fsroot(hwloc_topology_t __restrict topology, const char * __restrict fsroot_path);
# 844 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_set_synthetic(hwloc_topology_t __restrict topology, const char * __restrict description);
# 872 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_set_xml(hwloc_topology_t __restrict topology, const char * __restrict xmlpath);
# 900 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_set_xmlbuffer(hwloc_topology_t __restrict topology, const char * __restrict buffer, int size);
# 921 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_set_custom(hwloc_topology_t topology);
# 940 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_set_distance_matrix(hwloc_topology_t __restrict topology,
            hwloc_obj_type_t type, unsigned nbobjs,
            unsigned *os_index, float *distances);
# 951 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_is_thissystem(hwloc_topology_t __restrict topology) __attribute__((__pure__));
struct hwloc_topology_discovery_support {
  unsigned char pu;
struct hwloc_topology_cpubind_support {
  unsigned char set_thisproc_cpubind;
  unsigned char get_thisproc_cpubind;
  unsigned char set_proc_cpubind;
  unsigned char get_proc_cpubind;
  unsigned char set_thisthread_cpubind;
  unsigned char get_thisthread_cpubind;
  unsigned char set_thread_cpubind;
  unsigned char get_thread_cpubind;
  unsigned char get_thisproc_last_cpu_location;
  unsigned char get_proc_last_cpu_location;
  unsigned char get_thisthread_last_cpu_location;
struct hwloc_topology_membind_support {
  unsigned char set_thisproc_membind;
  unsigned char get_thisproc_membind;
  unsigned char set_proc_membind;
  unsigned char get_proc_membind;
  unsigned char set_thisthread_membind;
  unsigned char get_thisthread_membind;
  unsigned char set_area_membind;
  unsigned char get_area_membind;
  unsigned char alloc_membind;
  unsigned char firsttouch_membind;
  unsigned char bind_membind;
  unsigned char interleave_membind;
  unsigned char replicate_membind;
  unsigned char nexttouch_membind;
  unsigned char migrate_membind;
struct hwloc_topology_support {
  struct hwloc_topology_discovery_support *discovery;
  struct hwloc_topology_cpubind_support *cpubind;
  struct hwloc_topology_membind_support *membind;
 const struct hwloc_topology_support *hwloc_topology_get_support(hwloc_topology_t __restrict topology);
# 1052 "/usr/include/hwloc.h" 3 4
 unsigned hwloc_topology_get_depth(hwloc_topology_t __restrict topology) __attribute__((__pure__));
# 1076 "/usr/include/hwloc.h" 3 4
 int hwloc_get_type_depth (hwloc_topology_t topology, hwloc_obj_type_t type);
enum hwloc_get_type_depth_e {
    HWLOC_TYPE_DEPTH_UNKNOWN = -1,
    HWLOC_TYPE_DEPTH_MULTIPLE = -2,
    HWLOC_TYPE_DEPTH_BRIDGE = -3,
    HWLOC_TYPE_DEPTH_PCI_DEVICE = -4,
    HWLOC_TYPE_DEPTH_OS_DEVICE = -5
# 1095 "/usr/include/hwloc.h" 3 4
static __inline__ int
hwloc_get_type_or_below_depth (hwloc_topology_t topology, hwloc_obj_type_t type) __attribute__((__pure__));
# 1107 "/usr/include/hwloc.h" 3 4
hwloc_get_type_or_above_depth (hwloc_topology_t topology, hwloc_obj_type_t type) __attribute__((__pure__));
 hwloc_obj_type_t hwloc_get_depth_type (hwloc_topology_t topology, unsigned depth) __attribute__((__pure__));
 unsigned hwloc_get_nbobjs_by_depth (hwloc_topology_t topology, unsigned depth) __attribute__((__pure__));
hwloc_get_nbobjs_by_type (hwloc_topology_t topology, hwloc_obj_type_t type) __attribute__((__pure__));
static __inline__ hwloc_obj_t
hwloc_get_root_obj (hwloc_topology_t topology) __attribute__((__pure__));
 hwloc_obj_t hwloc_get_obj_by_depth (hwloc_topology_t topology, unsigned depth, unsigned idx) __attribute__((__pure__));
hwloc_get_obj_by_type (hwloc_topology_t topology, hwloc_obj_type_t type, unsigned idx) __attribute__((__pure__));
hwloc_get_next_obj_by_depth (hwloc_topology_t topology, unsigned depth, hwloc_obj_t prev);
hwloc_get_next_obj_by_type (hwloc_topology_t topology, hwloc_obj_type_t type,
       hwloc_obj_t prev);
# 1174 "/usr/include/hwloc.h" 3 4
 const char * hwloc_obj_type_string (hwloc_obj_type_t type) __attribute__((__const__));
# 1202 "/usr/include/hwloc.h" 3 4
 int hwloc_obj_type_sscanf(const char *string,
      hwloc_obj_type_t *typep,
      int *depthattrp,
      void *typeattrp, size_t typeattrsize);
# 1217 "/usr/include/hwloc.h" 3 4
 int hwloc_obj_type_snprintf(char * __restrict string, size_t size, hwloc_obj_t obj,
       int verbose);
# 1231 "/usr/include/hwloc.h" 3 4
 int hwloc_obj_attr_snprintf(char * __restrict string, size_t size, hwloc_obj_t obj, const char * __restrict separator,
       int verbose);
# 1241 "/usr/include/hwloc.h" 3 4
 int hwloc_obj_cpuset_snprintf(char * __restrict str, size_t size, size_t nobj, const hwloc_obj_t * __restrict objs);
static __inline__ const char *
hwloc_obj_get_info_by_name(hwloc_obj_t obj, const char *name) __attribute__((__pure__));
# 1266 "/usr/include/hwloc.h" 3 4
 void hwloc_obj_add_info(hwloc_obj_t obj, const char *name, const char *value);
# 1325 "/usr/include/hwloc.h" 3 4
typedef enum {
  HWLOC_CPUBIND_PROCESS = (1<<0),
  HWLOC_CPUBIND_THREAD = (1<<1),
# 1357 "/usr/include/hwloc.h" 3 4
  HWLOC_CPUBIND_STRICT = (1<<2),
# 1374 "/usr/include/hwloc.h" 3 4
  HWLOC_CPUBIND_NOMEMBIND = (1<<3)
} hwloc_cpubind_flags_t;
 int hwloc_set_cpubind(hwloc_topology_t topology, hwloc_const_cpuset_t set, int flags);
 int hwloc_get_cpubind(hwloc_topology_t topology, hwloc_cpuset_t set, int flags);
# 1402 "/usr/include/hwloc.h" 3 4
 int hwloc_set_proc_cpubind(hwloc_topology_t topology, pid_t pid, hwloc_const_cpuset_t set, int flags);
# 1415 "/usr/include/hwloc.h" 3 4
 int hwloc_get_proc_cpubind(hwloc_topology_t topology, pid_t pid, hwloc_cpuset_t set, int flags);
# 1425 "/usr/include/hwloc.h" 3 4
 int hwloc_set_thread_cpubind(hwloc_topology_t topology, pthread_t thread, hwloc_const_cpuset_t set, int flags);
# 1436 "/usr/include/hwloc.h" 3 4
 int hwloc_get_thread_cpubind(hwloc_topology_t topology, pthread_t thread, hwloc_cpuset_t set, int flags);
# 1452 "/usr/include/hwloc.h" 3 4
 int hwloc_get_last_cpu_location(hwloc_topology_t topology, hwloc_cpuset_t set, int flags);
# 1470 "/usr/include/hwloc.h" 3 4
 int hwloc_get_proc_last_cpu_location(hwloc_topology_t topology, pid_t pid, hwloc_cpuset_t set, int flags);
# 1539 "/usr/include/hwloc.h" 3 4
typedef enum {
  HWLOC_MEMBIND_DEFAULT = 0,
# 1552 "/usr/include/hwloc.h" 3 4
  HWLOC_MEMBIND_FIRSTTOUCH = 1,
  HWLOC_MEMBIND_BIND = 2,
# 1565 "/usr/include/hwloc.h" 3 4
  HWLOC_MEMBIND_INTERLEAVE = 3,
# 1578 "/usr/include/hwloc.h" 3 4
  HWLOC_MEMBIND_REPLICATE = 4,
  HWLOC_MEMBIND_NEXTTOUCH = 5,
  HWLOC_MEMBIND_MIXED = -1
} hwloc_membind_policy_t;
# 1605 "/usr/include/hwloc.h" 3 4
typedef enum {
  HWLOC_MEMBIND_PROCESS = (1<<0),
  HWLOC_MEMBIND_THREAD = (1<<1),
  HWLOC_MEMBIND_STRICT = (1<<2),
  HWLOC_MEMBIND_MIGRATE = (1<<3),
# 1642 "/usr/include/hwloc.h" 3 4
  HWLOC_MEMBIND_NOCPUBIND = (1<<4)
} hwloc_membind_flags_t;
# 1657 "/usr/include/hwloc.h" 3 4
 int hwloc_set_membind_nodeset(hwloc_topology_t topology, hwloc_const_nodeset_t nodeset, hwloc_membind_policy_t policy, int flags);
# 1672 "/usr/include/hwloc.h" 3 4
 int hwloc_set_membind(hwloc_topology_t topology, hwloc_const_cpuset_t cpuset, hwloc_membind_policy_t policy, int flags);
# 1714 "/usr/include/hwloc.h" 3 4
 int hwloc_get_membind_nodeset(hwloc_topology_t topology, hwloc_nodeset_t nodeset, hwloc_membind_policy_t * policy, int flags);
# 1761 "/usr/include/hwloc.h" 3 4
 int hwloc_get_membind(hwloc_topology_t topology, hwloc_cpuset_t cpuset, hwloc_membind_policy_t * policy, int flags);
# 1772 "/usr/include/hwloc.h" 3 4
 int hwloc_set_proc_membind_nodeset(hwloc_topology_t topology, pid_t pid, hwloc_const_nodeset_t nodeset, hwloc_membind_policy_t policy, int flags);
# 1783 "/usr/include/hwloc.h" 3 4
 int hwloc_set_proc_membind(hwloc_topology_t topology, pid_t pid, hwloc_const_cpuset_t cpuset, hwloc_membind_policy_t policy, int flags);
# 1821 "/usr/include/hwloc.h" 3 4
 int hwloc_get_proc_membind_nodeset(hwloc_topology_t topology, pid_t pid, hwloc_nodeset_t nodeset, hwloc_membind_policy_t * policy, int flags);
# 1862 "/usr/include/hwloc.h" 3 4
 int hwloc_get_proc_membind(hwloc_topology_t topology, pid_t pid, hwloc_cpuset_t cpuset, hwloc_membind_policy_t * policy, int flags);
 int hwloc_set_area_membind_nodeset(hwloc_topology_t topology, const void *addr, size_t len, hwloc_const_nodeset_t nodeset, hwloc_membind_policy_t policy, int flags);
 int hwloc_set_area_membind(hwloc_topology_t topology, const void *addr, size_t len, hwloc_const_cpuset_t cpuset, hwloc_membind_policy_t policy, int flags);
# 1902 "/usr/include/hwloc.h" 3 4
 int hwloc_get_area_membind_nodeset(hwloc_topology_t topology, const void *addr, size_t len, hwloc_nodeset_t nodeset, hwloc_membind_policy_t * policy, int flags);
# 1928 "/usr/include/hwloc.h" 3 4
 int hwloc_get_area_membind(hwloc_topology_t topology, const void *addr, size_t len, hwloc_cpuset_t cpuset, hwloc_membind_policy_t * policy, int flags);
# 1937 "/usr/include/hwloc.h" 3 4
 void *hwloc_alloc(hwloc_topology_t topology, size_t len);
# 1948 "/usr/include/hwloc.h" 3 4
 void *hwloc_alloc_membind_nodeset(hwloc_topology_t topology, size_t len, hwloc_const_nodeset_t nodeset, hwloc_membind_policy_t policy, int flags) __attribute__((__malloc__));
# 1959 "/usr/include/hwloc.h" 3 4
 void *hwloc_alloc_membind(hwloc_topology_t topology, size_t len, hwloc_const_cpuset_t cpuset, hwloc_membind_policy_t policy, int flags) __attribute__((__malloc__));
static __inline__ void *
hwloc_alloc_membind_policy_nodeset(hwloc_topology_t topology, size_t len, hwloc_const_nodeset_t nodeset, hwloc_membind_policy_t policy, int flags) __attribute__((__malloc__));
hwloc_alloc_membind_policy(hwloc_topology_t topology, size_t len, hwloc_const_cpuset_t set, hwloc_membind_policy_t policy, int flags) __attribute__((__malloc__));
 int hwloc_free(hwloc_topology_t topology, void *addr, size_t len);
# 2004 "/usr/include/hwloc.h" 3 4
 hwloc_obj_t hwloc_topology_insert_misc_object_by_cpuset(hwloc_topology_t topology, hwloc_const_cpuset_t cpuset, const char *name);
# 2021 "/usr/include/hwloc.h" 3 4
 hwloc_obj_t hwloc_topology_insert_misc_object_by_parent(hwloc_topology_t topology, hwloc_obj_t parent, const char *name);
enum hwloc_restrict_flags_e {
  HWLOC_RESTRICT_FLAG_ADAPT_DISTANCES = (1<<0),
  HWLOC_RESTRICT_FLAG_ADAPT_MISC = (1<<1),
  HWLOC_RESTRICT_FLAG_ADAPT_IO = (1<<2)
# 2065 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_restrict(hwloc_topology_t __restrict topology, hwloc_const_cpuset_t cpuset, unsigned long flags);
# 2074 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_dup(hwloc_topology_t *newtopology, hwloc_topology_t oldtopology);
# 2109 "/usr/include/hwloc.h" 3 4
 int hwloc_custom_insert_topology(hwloc_topology_t newtopology, hwloc_obj_t newparent, hwloc_topology_t oldtopology, hwloc_obj_t oldroot);
# 2132 "/usr/include/hwloc.h" 3 4
 hwloc_obj_t hwloc_custom_insert_group_object_by_parent(hwloc_topology_t topology, hwloc_obj_t parent, int groupdepth);
# 2157 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_export_xml(hwloc_topology_t topology, const char *xmlpath);
# 2175 "/usr/include/hwloc.h" 3 4
 int hwloc_topology_export_xmlbuffer(hwloc_topology_t topology, char **xmlbuffer, int *buflen);
 void hwloc_free_xmlbuffer(hwloc_topology_t topology, char *xmlbuffer);
# 2196 "/usr/include/hwloc.h" 3 4
 void hwloc_topology_set_userdata_export_callback(hwloc_topology_t topology,
        void (*export_cb)(void *reserved, hwloc_topology_t topology, hwloc_obj_t obj));
# 2224 "/usr/include/hwloc.h" 3 4
 int hwloc_export_obj_userdata(void *reserved, hwloc_topology_t topology, hwloc_obj_t obj, const char *name, const void *buffer, size_t length);
# 2239 "/usr/include/hwloc.h" 3 4
 int hwloc_export_obj_userdata_base64(void *reserved, hwloc_topology_t topology, hwloc_obj_t obj, const char *name, const void *buffer, size_t length);
# 2261 "/usr/include/hwloc.h" 3 4
 void hwloc_topology_set_userdata_import_callback(hwloc_topology_t topology,
        void (*import_cb)(hwloc_topology_t topology, hwloc_obj_t obj, const char *name, const void *buffer, size_t length));
# 2274 "/usr/include/hwloc.h" 3 4
# 1 "/usr/include/hwloc/helper.h" 1 3 4
# 20 "/usr/include/hwloc/helper.h" 3 4
# 1 "/usr/include/stdlib.h" 1 3 4
# 32 "/usr/include/stdlib.h" 3 4
# 1 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 1 3 4
# 324 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef int wchar_t;
# 33 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitflags.h" 1 3 4
# 42 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitstatus.h" 1 3 4
# 66 "/usr/include/bits/waitstatus.h" 3 4
union wait
    int w_status;
    struct
 unsigned int __w_termsig:7;
 unsigned int __w_coredump:1;
 unsigned int __w_retcode:8;
 unsigned int:16;
      } __wait_terminated;
    struct
 unsigned int __w_stopval:8;
 unsigned int __w_stopsig:8;
 unsigned int:16;
      } __wait_stopped;
# 43 "/usr/include/stdlib.h" 2 3 4
# 67 "/usr/include/stdlib.h" 3 4
typedef union
    union wait *__uptr;
    int *__iptr;
  } __WAIT_STATUS __attribute__ ((__transparent_union__));
# 95 "/usr/include/stdlib.h" 3 4
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
# 139 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (const char *__nptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
__extension__ extern long long int atoll (const char *__nptr)
extern double strtod (const char *__restrict __nptr,
        char **__restrict __endptr)
extern float strtof (const char *__restrict __nptr,
       char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long double strtold (const char *__restrict __nptr,
extern long int strtol (const char *__restrict __nptr,
   char **__restrict __endptr, int __base)
extern unsigned long int strtoul (const char *__restrict __nptr,
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
# 305 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (const char *__s)
# 321 "/usr/include/stdlib.h" 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
   size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
       int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
   size_t __statelen,
   struct random_data *__restrict __buf)
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    __extension__ unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
        double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
        long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
       struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void cfree (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/alloca.h" 1 3 4
# 24 "/usr/include/alloca.h" 3 4
# 25 "/usr/include/alloca.h" 2 3 4
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
# 493 "/usr/include/stdlib.h" 2 3 4
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
# 513 "/usr/include/stdlib.h" 3 4
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 530 "/usr/include/stdlib.h" 3 4
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 578 "/usr/include/stdlib.h" 3 4
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 606 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 619 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 641 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 662 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 711 "/usr/include/stdlib.h" 3 4
extern int system (const char *__command) ;
# 733 "/usr/include/stdlib.h" 3 4
extern char *realpath (const char *__restrict __name,
         char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
typedef int (*__compar_fn_t) (const void *, const void *);
# 751 "/usr/include/stdlib.h" 3 4
extern void *bsearch (const void *__key, const void *__base,
        size_t __nmemb, size_t __size, __compar_fn_t __compar)
     __attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
     __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 774 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
        long long int __denom)
# 811 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign, char *__restrict __buf,
     size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign,
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int mbtowc (wchar_t *__restrict __pwc,
     const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__));
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
extern size_t wcstombs (char *__restrict __s,
   const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 898 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
        char *const *__restrict __tokens,
        char **__restrict __valuep)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 950 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 1 "/usr/include/bits/stdlib-float.h" 1 3 4
# 955 "/usr/include/stdlib.h" 2 3 4
# 967 "/usr/include/stdlib.h" 3 4
# 21 "/usr/include/hwloc/helper.h" 2 3 4
# 1 "/usr/include/errno.h" 1 3 4
# 31 "/usr/include/errno.h" 3 4
# 1 "/usr/include/bits/errno.h" 1 3 4
# 24 "/usr/include/bits/errno.h" 3 4
# 1 "/usr/include/linux/errno.h" 1 3 4
# 1 "/usr/include/asm/errno.h" 1 3 4
# 1 "/usr/include/asm-generic/errno.h" 1 3 4
# 1 "/usr/include/asm-generic/errno-base.h" 1 3 4
# 5 "/usr/include/asm-generic/errno.h" 2 3 4
# 1 "/usr/include/asm/errno.h" 2 3 4
# 1 "/usr/include/linux/errno.h" 2 3 4
# 25 "/usr/include/bits/errno.h" 2 3 4
# 50 "/usr/include/bits/errno.h" 3 4
extern int *__errno_location (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 36 "/usr/include/errno.h" 2 3 4
# 58 "/usr/include/errno.h" 3 4
# 22 "/usr/include/hwloc/helper.h" 2 3 4
# 44 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_first_largest_obj_inside_cpuset(hwloc_topology_t topology, hwloc_const_cpuset_t set)
  hwloc_obj_t obj = hwloc_get_root_obj(topology);
  if (!obj->cpuset || !hwloc_bitmap_intersects(obj->cpuset, set))
    return ((void *)0);
  while (!hwloc_bitmap_isincluded(obj->cpuset, set)) {
    hwloc_obj_t child = obj->first_child;
    while (child) {
      if (child->cpuset && hwloc_bitmap_intersects(child->cpuset, set))
 break;
      child = child->next_sibling;
    if (!child)
      return obj;
    obj = child;
  return obj;
# 75 "/usr/include/hwloc/helper.h" 3 4
 int hwloc_get_largest_objs_inside_cpuset (hwloc_topology_t topology, hwloc_const_cpuset_t set,
       hwloc_obj_t * __restrict objs, int max);
# 87 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_next_obj_inside_cpuset_by_depth (hwloc_topology_t topology, hwloc_const_cpuset_t set,
  hwloc_obj_t next = hwloc_get_next_obj_by_depth(topology, depth, prev);
  if (!next || !next->cpuset)
    return ((void *)0);
  while (next && !hwloc_bitmap_isincluded(next->cpuset, set))
    next = next->next_cousin;
  return next;
# 108 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_next_obj_inside_cpuset_by_type (hwloc_topology_t topology, hwloc_const_cpuset_t set,
       hwloc_obj_type_t type, hwloc_obj_t prev)
  int depth = hwloc_get_type_depth(topology, type);
  if (depth == HWLOC_TYPE_DEPTH_UNKNOWN || depth == HWLOC_TYPE_DEPTH_MULTIPLE)
    return ((void *)0);
  return hwloc_get_next_obj_inside_cpuset_by_depth(topology, set, depth, prev);
hwloc_get_obj_inside_cpuset_by_depth (hwloc_topology_t topology, hwloc_const_cpuset_t set,
  hwloc_obj_t obj = hwloc_get_obj_by_depth (topology, depth, 0);
  unsigned count = 0;
  if (!obj || !obj->cpuset)
    return ((void *)0);
  while (obj) {
    if (hwloc_bitmap_isincluded(obj->cpuset, set)) {
      if (count == idx)
 return obj;
      count++;
    obj = obj->next_cousin;
  return ((void *)0);
# 154 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_obj_inside_cpuset_by_type (hwloc_topology_t topology, hwloc_const_cpuset_t set,
    return ((void *)0);
  return hwloc_get_obj_inside_cpuset_by_depth(topology, set, depth, idx);
static __inline__ unsigned
hwloc_get_nbobjs_inside_cpuset_by_depth (hwloc_topology_t topology, hwloc_const_cpuset_t set,
      unsigned depth)
  unsigned count = 0;
    return 0;
  while (obj) {
      count++;
  return count;
# 200 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_nbobjs_inside_cpuset_by_type (hwloc_topology_t topology, hwloc_const_cpuset_t set,
  if (depth == HWLOC_TYPE_DEPTH_UNKNOWN)
    return 0;
  if (depth == HWLOC_TYPE_DEPTH_MULTIPLE)
    return -1;
  return hwloc_get_nbobjs_inside_cpuset_by_depth(topology, set, depth);
# 223 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_obj_index_inside_cpuset (hwloc_topology_t topology __attribute__((__unused__)), hwloc_const_cpuset_t set,
       hwloc_obj_t obj) __attribute__((__pure__));
       hwloc_obj_t obj)
  int idx = 0;
  if (!hwloc_bitmap_isincluded(obj->cpuset, set))
    return -1;
  while ((obj = obj->prev_cousin) != ((void *)0))
      idx++;
  return idx;
# 254 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_child_covering_cpuset (hwloc_topology_t topology __attribute__((__unused__)), hwloc_const_cpuset_t set,
    hwloc_obj_t parent) __attribute__((__pure__));
    hwloc_obj_t parent)
  hwloc_obj_t child;
  if (!parent->cpuset || hwloc_bitmap_iszero(set))
    return ((void *)0);
  child = parent->first_child;
  while (child) {
    if (child->cpuset && hwloc_bitmap_isincluded(set, child->cpuset))
      return child;
  return ((void *)0);
# 280 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_obj_covering_cpuset (hwloc_topology_t topology, hwloc_const_cpuset_t set) __attribute__((__pure__));
  struct hwloc_obj *current = hwloc_get_root_obj(topology);
  if (hwloc_bitmap_iszero(set) || !current->cpuset || !hwloc_bitmap_isincluded(set, current->cpuset))
    return ((void *)0);
  while (1) {
    hwloc_obj_t child = hwloc_get_child_covering_cpuset(topology, set, current);
    if (!child)
      return current;
    current = child;
# 306 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_next_obj_covering_cpuset_by_depth(hwloc_topology_t topology, hwloc_const_cpuset_t set,
    return ((void *)0);
  while (next && !hwloc_bitmap_intersects(set, next->cpuset))
  return next;
# 333 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_next_obj_covering_cpuset_by_type(hwloc_topology_t topology, hwloc_const_cpuset_t set,
    return ((void *)0);
  return hwloc_get_next_obj_covering_cpuset_by_depth(topology, set, depth, prev);
# 357 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_ancestor_obj_by_depth (hwloc_topology_t topology __attribute__((__unused__)), unsigned depth, hwloc_obj_t obj) __attribute__((__pure__));
  hwloc_obj_t ancestor = obj;
  if (obj->depth < depth)
    return ((void *)0);
  while (ancestor && ancestor->depth > depth)
    ancestor = ancestor->parent;
  return ancestor;
hwloc_get_ancestor_obj_by_type (hwloc_topology_t topology __attribute__((__unused__)), hwloc_obj_type_t type, hwloc_obj_t obj) __attribute__((__pure__));
  hwloc_obj_t ancestor = obj->parent;
  while (ancestor && ancestor->type != type)
  return ancestor;
hwloc_get_common_ancestor_obj (hwloc_topology_t topology __attribute__((__unused__)), hwloc_obj_t obj1, hwloc_obj_t obj2) __attribute__((__pure__));
  while (obj1 != obj2) {
    while (obj1->depth > obj2->depth)
      obj1 = obj1->parent;
    while (obj2->depth > obj1->depth)
      obj2 = obj2->parent;
    if (obj1 != obj2 && obj1->depth == obj2->depth) {
  return obj1;
hwloc_obj_is_in_subtree (hwloc_topology_t topology __attribute__((__unused__)), hwloc_obj_t obj, hwloc_obj_t subtree_root) __attribute__((__pure__));
  return hwloc_bitmap_isincluded(obj->cpuset, subtree_root->cpuset);
hwloc_get_next_child (hwloc_topology_t topology __attribute__((__unused__)), hwloc_obj_t parent, hwloc_obj_t prev)
  if (!prev)
    return parent->first_child;
  if (prev->parent != parent)
    return ((void *)0);
  return prev->next_sibling;
# 459 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_cache_type_depth (hwloc_topology_t topology,
       unsigned cachelevel, hwloc_obj_cache_type_t cachetype)
  int depth;
  int found = HWLOC_TYPE_DEPTH_UNKNOWN;
  for (depth=0; ; depth++) {
    hwloc_obj_t obj = hwloc_get_obj_by_depth(topology, depth, 0);
    if (!obj)
      break;
    if (obj->type != HWLOC_OBJ_CACHE || obj->attr->cache.depth != cachelevel)
      continue;
    if (cachetype == (hwloc_obj_cache_type_t) -1) {
      if (found != HWLOC_TYPE_DEPTH_UNKNOWN) {
        return HWLOC_TYPE_DEPTH_MULTIPLE;
      found = depth;
      continue;
    if (obj->attr->cache.type == cachetype || obj->attr->cache.type == HWLOC_OBJ_CACHE_UNIFIED)
      return depth;
  return found;
# 496 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_cache_covering_cpuset (hwloc_topology_t topology, hwloc_const_cpuset_t set) __attribute__((__pure__));
  hwloc_obj_t current = hwloc_get_obj_covering_cpuset(topology, set);
  while (current) {
    if (current->type == HWLOC_OBJ_CACHE)
      return current;
    current = current->parent;
  return ((void *)0);
hwloc_get_shared_cache_covering_obj (hwloc_topology_t topology __attribute__((__unused__)), hwloc_obj_t obj) __attribute__((__pure__));
  hwloc_obj_t current = obj->parent;
  if (!obj->cpuset)
    return ((void *)0);
  while (current && current->cpuset) {
    if (!hwloc_bitmap_isequal(current->cpuset, obj->cpuset)
        && current->type == HWLOC_OBJ_CACHE)
      return current;
  return ((void *)0);
# 552 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_pu_obj_by_os_index(hwloc_topology_t topology, unsigned os_index) __attribute__((__pure__));
  hwloc_obj_t obj = ((void *)0);
  while ((obj = hwloc_get_next_obj_by_type(topology, HWLOC_OBJ_PU, obj)) != ((void *)0))
    if (obj->os_index == os_index)
      return obj;
  return ((void *)0);
# 576 "/usr/include/hwloc/helper.h" 3 4
 unsigned hwloc_get_closest_objs (hwloc_topology_t topology, hwloc_obj_t src, hwloc_obj_t * __restrict objs, unsigned max);
# 590 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_obj_below_by_type (hwloc_topology_t topology,
        hwloc_obj_type_t type1, unsigned idx1,
        hwloc_obj_type_t type2, unsigned idx2) __attribute__((__pure__));
  hwloc_obj_t obj;
  obj = hwloc_get_obj_by_type (topology, type1, idx1);
    return ((void *)0);
  return hwloc_get_obj_inside_cpuset_by_type(topology, obj->cpuset, type2, idx2);
# 624 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_obj_below_array_by_type (hwloc_topology_t topology, int nr, hwloc_obj_type_t *typev, unsigned *idxv) __attribute__((__pure__));
  int i;
  for(i=0; i<nr; i++) {
      return ((void *)0);
    obj = hwloc_get_obj_inside_cpuset_by_type(topology, obj->cpuset, typev[i], idxv[i]);
  return obj;
# 649 "/usr/include/hwloc/helper.h" 3 4
enum hwloc_distrib_flags_e {
  HWLOC_DISTRIB_FLAG_REVERSE = (1UL<<0)
# 679 "/usr/include/hwloc/helper.h" 3 4
hwloc_distrib(hwloc_topology_t topology,
       hwloc_obj_t *roots, unsigned n_roots,
       hwloc_cpuset_t *set,
       unsigned n,
       unsigned until, unsigned long flags)
  unsigned i;
  unsigned tot_weight;
  hwloc_cpuset_t *cpusetp = set;
  if (flags & ~HWLOC_DISTRIB_FLAG_REVERSE) {
    (*__errno_location ()) = 22;
    return -1;
  tot_weight = 0;
  for (i = 0; i < n_roots; i++)
    if (roots[i]->cpuset)
      tot_weight += hwloc_bitmap_weight(roots[i]->cpuset);
  for (i = 0; i < n_roots && tot_weight; i++) {
    hwloc_obj_t root = roots[flags & HWLOC_DISTRIB_FLAG_REVERSE ? n_roots-1-i : i];
    unsigned weight = root->cpuset ? hwloc_bitmap_weight(root->cpuset) : 0;
    unsigned chunk = (n * weight + tot_weight-1) / tot_weight;
    if (!root->arity || chunk == 1 || root->depth >= until) {
      unsigned j;
      for (j=0; j<n; j++)
 cpusetp[j] = hwloc_bitmap_dup(root->cpuset);
    } else {
      hwloc_distrib(topology, root->children, root->arity, cpusetp, chunk, until, flags);
    cpusetp += chunk;
    tot_weight -= weight;
    n -= chunk;
  return 0;
# 738 "/usr/include/hwloc/helper.h" 3 4
static __inline__ hwloc_const_cpuset_t
hwloc_topology_get_complete_cpuset(hwloc_topology_t topology) __attribute__((__pure__));
  return hwloc_get_root_obj(topology)->complete_cpuset;
# 756 "/usr/include/hwloc/helper.h" 3 4
hwloc_topology_get_topology_cpuset(hwloc_topology_t topology) __attribute__((__pure__));
  return hwloc_get_root_obj(topology)->cpuset;
# 773 "/usr/include/hwloc/helper.h" 3 4
hwloc_topology_get_online_cpuset(hwloc_topology_t topology) __attribute__((__pure__));
  return hwloc_get_root_obj(topology)->online_cpuset;
# 790 "/usr/include/hwloc/helper.h" 3 4
hwloc_topology_get_allowed_cpuset(hwloc_topology_t topology) __attribute__((__pure__));
  return hwloc_get_root_obj(topology)->allowed_cpuset;
# 807 "/usr/include/hwloc/helper.h" 3 4
static __inline__ hwloc_const_nodeset_t
hwloc_topology_get_complete_nodeset(hwloc_topology_t topology) __attribute__((__pure__));
  return hwloc_get_root_obj(topology)->complete_nodeset;
# 825 "/usr/include/hwloc/helper.h" 3 4
hwloc_topology_get_topology_nodeset(hwloc_topology_t topology) __attribute__((__pure__));
  return hwloc_get_root_obj(topology)->nodeset;
# 842 "/usr/include/hwloc/helper.h" 3 4
hwloc_topology_get_allowed_nodeset(hwloc_topology_t topology) __attribute__((__pure__));
  return hwloc_get_root_obj(topology)->allowed_nodeset;
# 880 "/usr/include/hwloc/helper.h" 3 4
hwloc_cpuset_to_nodeset(hwloc_topology_t topology, hwloc_const_cpuset_t _cpuset, hwloc_nodeset_t nodeset)
 int depth = hwloc_get_type_depth(topology, HWLOC_OBJ_NODE);
 hwloc_obj_t obj;
 if (depth == HWLOC_TYPE_DEPTH_UNKNOWN) {
   if (hwloc_bitmap_iszero(_cpuset))
   hwloc_bitmap_zero(nodeset);
  else
   hwloc_bitmap_fill(nodeset);
  return;
 obj = ((void *)0);
 while ((obj = hwloc_get_next_obj_covering_cpuset_by_depth(topology, _cpuset, depth, obj)) != ((void *)0))
  hwloc_bitmap_set(nodeset, obj->os_index);
# 908 "/usr/include/hwloc/helper.h" 3 4
hwloc_cpuset_to_nodeset_strict(struct hwloc_topology *topology, hwloc_const_cpuset_t _cpuset, hwloc_nodeset_t nodeset)
 hwloc_obj_t obj;
 if (depth == HWLOC_TYPE_DEPTH_UNKNOWN )
  return;
 obj = ((void *)0);
# 929 "/usr/include/hwloc/helper.h" 3 4
hwloc_cpuset_from_nodeset(hwloc_topology_t topology, hwloc_cpuset_t _cpuset, hwloc_const_nodeset_t nodeset)
 hwloc_obj_t obj;
 if (depth == HWLOC_TYPE_DEPTH_UNKNOWN ) {
  if (hwloc_bitmap_iszero(nodeset))
   hwloc_bitmap_zero(_cpuset);
  else
   hwloc_bitmap_fill(_cpuset);
  return;
 obj = ((void *)0);
 while ((obj = hwloc_get_next_obj_by_depth(topology, depth, obj)) != ((void *)0)) {
  if (hwloc_bitmap_isset(nodeset, obj->os_index))
   hwloc_bitmap_or(_cpuset, _cpuset, obj->cpuset);
# 960 "/usr/include/hwloc/helper.h" 3 4
hwloc_cpuset_from_nodeset_strict(struct hwloc_topology *topology, hwloc_cpuset_t _cpuset, hwloc_const_nodeset_t nodeset)
 hwloc_obj_t obj;
  return;
 obj = ((void *)0);
# 1002 "/usr/include/hwloc/helper.h" 3 4
static __inline__ const struct hwloc_distances_s *
hwloc_get_whole_distance_matrix_by_depth(hwloc_topology_t topology, unsigned depth)
  hwloc_obj_t root = hwloc_get_root_obj(topology);
  unsigned i;
  for(i=0; i<root->distances_count; i++)
    if (root->distances[i]->relative_depth == depth)
      return root->distances[i];
  return ((void *)0);
# 1032 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_whole_distance_matrix_by_type(hwloc_topology_t topology, hwloc_obj_type_t type)
  if (depth < 0)
    return ((void *)0);
  return hwloc_get_whole_distance_matrix_by_depth(topology, depth);
# 1054 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_distance_matrix_covering_obj_by_depth(hwloc_topology_t topology,
      hwloc_obj_t obj, unsigned depth,
      unsigned *firstp)
  while (obj && obj->cpuset) {
    unsigned i;
    for(i=0; i<obj->distances_count; i++)
      if (obj->distances[i]->relative_depth == depth - obj->depth) {
 if (!obj->distances[i]->nbobjs)
   continue;
 *firstp = hwloc_get_next_obj_inside_cpuset_by_depth(topology, obj->cpuset, depth, ((void *)0))->logical_index;
 return obj->distances[i];
    obj = obj->parent;
  return ((void *)0);
# 1084 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_latency(hwloc_topology_t topology,
     hwloc_obj_t obj1, hwloc_obj_t obj2,
     float *latency, float *reverse_latency)
  hwloc_obj_t ancestor;
  const struct hwloc_distances_s * distances;
  unsigned first_logical ;
  if (obj1->depth != obj2->depth) {
    return -1;
  ancestor = hwloc_get_common_ancestor_obj(topology, obj1, obj2);
  distances = hwloc_get_distance_matrix_covering_obj_by_depth(topology, ancestor, obj1->depth, &first_logical);
  if (distances && distances->latency) {
    const float * latency_matrix = distances->latency;
    unsigned nbobjs = distances->nbobjs;
    unsigned l1 = obj1->logical_index - first_logical;
    unsigned l2 = obj2->logical_index - first_logical;
    *latency = latency_matrix[l1*nbobjs+l2];
    *reverse_latency = latency_matrix[l2*nbobjs+l1];
    return 0;
  (*__errno_location ()) = 38;
  return -1;
# 1128 "/usr/include/hwloc/helper.h" 3 4
hwloc_get_non_io_ancestor_obj(hwloc_topology_t topology __attribute__((__unused__)),
         hwloc_obj_t ioobj)
  hwloc_obj_t obj = ioobj;
  while (obj && !obj->cpuset) {
    obj = obj->parent;
  return obj;
hwloc_get_next_pcidev(hwloc_topology_t topology, hwloc_obj_t prev)
  return hwloc_get_next_obj_by_type(topology, HWLOC_OBJ_PCI_DEVICE, prev);
hwloc_get_pcidev_by_busid(hwloc_topology_t topology,
     unsigned domain, unsigned bus, unsigned dev, unsigned func)
  while ((obj = hwloc_get_next_pcidev(topology, obj)) != ((void *)0)) {
    if (obj->attr->pcidev.domain == domain
 && obj->attr->pcidev.bus == bus
 && obj->attr->pcidev.dev == dev
 && obj->attr->pcidev.func == func)
      return obj;
  return ((void *)0);
hwloc_get_pcidev_by_busidstring(hwloc_topology_t topology, const char *busid)
  unsigned domain = 0;
  unsigned bus, dev, func;
  if (sscanf(busid, "%x:%x.%x", &bus, &dev, &func) != 3
      && sscanf(busid, "%x:%x:%x.%x", &domain, &bus, &dev, &func) != 4) {
    return ((void *)0);
  return hwloc_get_pcidev_by_busid(topology, domain, bus, dev, func);
hwloc_get_next_osdev(hwloc_topology_t topology, hwloc_obj_t prev)
  return hwloc_get_next_obj_by_type(topology, HWLOC_OBJ_OS_DEVICE, prev);
hwloc_get_next_bridge(hwloc_topology_t topology, hwloc_obj_t prev)
  return hwloc_get_next_obj_by_type(topology, HWLOC_OBJ_BRIDGE, prev);
hwloc_bridge_covers_pcibus(hwloc_obj_t bridge,
      unsigned domain, unsigned bus)
  return bridge->type == HWLOC_OBJ_BRIDGE
    && bridge->attr->bridge.downstream_type == HWLOC_OBJ_BRIDGE_PCI
    && bridge->attr->bridge.downstream.pci.domain == domain
    && bridge->attr->bridge.downstream.pci.secondary_bus <= bus
    && bridge->attr->bridge.downstream.pci.subordinate_bus >= bus;
hwloc_get_hostbridge_by_pcibus(hwloc_topology_t topology,
  while ((obj = hwloc_get_next_bridge(topology, obj)) != ((void *)0)) {
    if (hwloc_bridge_covers_pcibus(obj, domain, bus)) {
      ((obj->attr->bridge.upstream_type == HWLOC_OBJ_BRIDGE_HOST) ? (void) (0) : __assert_fail ("obj->attr->bridge.upstream_type == HWLOC_OBJ_BRIDGE_HOST", "/usr/include/hwloc/helper.h", 1231, __PRETTY_FUNCTION__));
      ((obj->parent->type != HWLOC_OBJ_BRIDGE) ? (void) (0) : __assert_fail ("obj->parent->type != HWLOC_OBJ_BRIDGE", "/usr/include/hwloc/helper.h", 1232, __PRETTY_FUNCTION__));
      ((obj->parent->cpuset) ? (void) (0) : __assert_fail ("obj->parent->cpuset", "/usr/include/hwloc/helper.h", 1233, __PRETTY_FUNCTION__));
      return obj;
  return ((void *)0);
# 2275 "/usr/include/hwloc.h" 2 3 4
# 1 "/usr/include/hwloc/inlines.h" 1 3 4
# 21 "/usr/include/hwloc/inlines.h" 3 4
# 22 "/usr/include/hwloc/inlines.h" 2 3 4
  if (depth != HWLOC_TYPE_DEPTH_UNKNOWN)
    return depth;
  for(depth = hwloc_get_type_depth(topology, HWLOC_OBJ_PU); ; depth--)
    if (hwloc_compare_types(hwloc_get_depth_type(topology, depth), type) < 0)
      return depth+1;
    return depth;
  for(depth = 0; ; depth++)
    if (hwloc_compare_types(hwloc_get_depth_type(topology, depth), type) > 0)
      return depth-1;
    return 0;
    return -1;
  return hwloc_get_nbobjs_by_depth(topology, depth);
    return ((void *)0);
    return ((void *)0);
  return hwloc_get_obj_by_depth(topology, depth, idx);
  if (!prev)
    return hwloc_get_obj_by_depth (topology, depth, 0);
  if (prev->depth != depth)
    return ((void *)0);
  return prev->next_cousin;
       hwloc_obj_t prev)
    return ((void *)0);
  return hwloc_get_next_obj_by_depth (topology, depth, prev);
  return hwloc_get_obj_by_depth (topology, 0, 0);
  unsigned i;
  for(i=0; i<obj->infos_count; i++)
    if (!strcmp(obj->infos[i].name, name))
      return obj->infos[i].value;
  return ((void *)0);
  void *p = hwloc_alloc_membind_nodeset(topology, len, nodeset, policy, flags);
  if (p)
    return p;
  hwloc_set_membind_nodeset(topology, nodeset, policy, flags);
  p = hwloc_alloc(topology, len);
  if (p && policy != HWLOC_MEMBIND_FIRSTTOUCH)
    memset(p, 0, len);
  return p;
  void *p = hwloc_alloc_membind(topology, len, set, policy, flags);
  if (p)
    return p;
  hwloc_set_membind(topology, set, policy, flags);
    memset(p, 0, len);
  return p;
# 2278 "/usr/include/hwloc.h" 2 3 4
# 1 "/usr/include/hwloc/diff.h" 1 3 4
# 60 "/usr/include/hwloc/diff.h" 3 4
typedef enum hwloc_topology_diff_obj_attr_type_e {
  HWLOC_TOPOLOGY_DIFF_OBJ_ATTR_SIZE,
  HWLOC_TOPOLOGY_DIFF_OBJ_ATTR_NAME,
  HWLOC_TOPOLOGY_DIFF_OBJ_ATTR_INFO
} hwloc_topology_diff_obj_attr_type_t;
union hwloc_topology_diff_obj_attr_u {
  struct hwloc_topology_diff_obj_attr_generic_s {
    hwloc_topology_diff_obj_attr_type_t type;
  } generic;
  struct hwloc_topology_diff_obj_attr_uint64_s {
    hwloc_uint64_t index;
    hwloc_uint64_t oldvalue;
    hwloc_uint64_t newvalue;
  } uint64;
  struct hwloc_topology_diff_obj_attr_string_s {
    char *name;
    char *oldvalue;
    char *newvalue;
  } string;
typedef enum hwloc_topology_diff_type_e {
  HWLOC_TOPOLOGY_DIFF_OBJ_ATTR,
# 122 "/usr/include/hwloc/diff.h" 3 4
  HWLOC_TOPOLOGY_DIFF_TOO_COMPLEX
} hwloc_topology_diff_type_t;
typedef union hwloc_topology_diff_u {
  struct hwloc_topology_diff_generic_s {
    hwloc_topology_diff_type_t type;
    union hwloc_topology_diff_u * next;
  } generic;
  struct hwloc_topology_diff_obj_attr_s {
    unsigned obj_depth;
    unsigned obj_index;
    union hwloc_topology_diff_obj_attr_u diff;
  } obj_attr;
  struct hwloc_topology_diff_too_complex_s {
    unsigned obj_depth;
    unsigned obj_index;
  } too_complex;
} * hwloc_topology_diff_t;
# 192 "/usr/include/hwloc/diff.h" 3 4
 int hwloc_topology_diff_build(hwloc_topology_t topology, hwloc_topology_t newtopology, unsigned long flags, hwloc_topology_diff_t *diff);
enum hwloc_topology_diff_apply_flags_e {
  HWLOC_TOPOLOGY_DIFF_APPLY_REVERSE = (1UL<<0)
# 220 "/usr/include/hwloc/diff.h" 3 4
 int hwloc_topology_diff_apply(hwloc_topology_t topology, hwloc_topology_diff_t diff, unsigned long flags);
 int hwloc_topology_diff_destroy(hwloc_topology_t topology, hwloc_topology_diff_t diff);
# 243 "/usr/include/hwloc/diff.h" 3 4
 int hwloc_topology_diff_load_xml(hwloc_topology_t topology, const char *xmlpath, hwloc_topology_diff_t *diff, char **refname);
# 257 "/usr/include/hwloc/diff.h" 3 4
 int hwloc_topology_diff_export_xml(hwloc_topology_t topology, hwloc_topology_diff_t diff, const char *refname, const char *xmlpath);
# 273 "/usr/include/hwloc/diff.h" 3 4
 int hwloc_topology_diff_load_xmlbuffer(hwloc_topology_t topology, const char *xmlbuffer, int buflen, hwloc_topology_diff_t *diff, char **refname);
# 289 "/usr/include/hwloc/diff.h" 3 4
 int hwloc_topology_diff_export_xmlbuffer(hwloc_topology_t topology, hwloc_topology_diff_t diff, const char *refname, char **xmlbuffer, int *buflen);
# 2281 "/usr/include/hwloc.h" 2 3 4
# 1 "/usr/include/hwloc/deprecated.h" 1 3 4
# 28 "/usr/include/hwloc/deprecated.h" 3 4
 hwloc_obj_type_t hwloc_obj_type_of_string (const char * string) __attribute__((__pure__));
# 50 "/usr/include/hwloc/deprecated.h" 3 4
 int hwloc_obj_snprintf(char * __restrict string, size_t size,
          const char * __restrict indexprefix, int verbose);
# 69 "/usr/include/hwloc/deprecated.h" 3 4
hwloc_distribute(hwloc_topology_t topology, hwloc_obj_t root, hwloc_cpuset_t *set, unsigned n, unsigned until)
  hwloc_distrib(topology, &root, 1, set, n, until, 0);
# 82 "/usr/include/hwloc/deprecated.h" 3 4
hwloc_distributev(hwloc_topology_t topology, hwloc_obj_t *roots, unsigned n_roots, hwloc_cpuset_t *set, unsigned n, unsigned until)
  hwloc_distrib(topology, roots, n_roots, set, n, until, 0);
# 2284 "/usr/include/hwloc.h" 2 3 4
# 3 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
Found header files ['hwloc.h'] in ['/opt/mpich/include']
              Popping language C
TEST checkSharedLibrary from config.packages.hwloc(/home/jed/petsc/config/BuildSystem/config/package.py:592)
TESTING: checkSharedLibrary from config.packages.hwloc(config/BuildSystem/config/package.py:592)
  By default we don't care about checking if the library is shared
        Popping language C
TEST alternateConfigureLibrary from config.packages.opengl(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.opengl(config/BuildSystem/config/package.py:596)
  Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from config.packages.glut(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.glut(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.scientificpython(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.scientificpython(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.fiat(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.fiat(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.ctetgen(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.ctetgen(config/BuildSystem/config/package.py:596)
TEST locateC2html from config.packages.c2html(/home/jed/petsc/config/BuildSystem/config/packages/c2html.py:34)
TESTING: locateC2html from config.packages.c2html(config/BuildSystem/config/packages/c2html.py:34)
Looking for default C2html executable
Checking for program /home/jed/bin/c2html...not found
Checking for program /usr/bin/c2html...found
            Defined make macro "C2HTML" to "/usr/bin/c2html"
TEST alternateConfigureLibrary from config.packages.boost(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.boost(config/BuildSystem/config/package.py:596)
      Pushing language C
TEST configureLibrary from config.packages.X(/home/jed/petsc/config/BuildSystem/config/package.py:538)
TESTING: configureLibrary from config.packages.X(config/BuildSystem/config/package.py:538)
  Find an installation and check if it can work with PETSc
        Checking for a functional X
        Checking for library in Package specific search directory X: ['libX11.a']
TEST check from config.libraries(/home/jed/petsc/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
            Checking for functions [XSetWMName] in library ['libX11.a'] []
              Pushing language C
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.libraries/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.libraries  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.libraries/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
/* Override any gcc2 internal prototype to avoid an error. */
char XSetWMName();
static void _check_XSetWMName() { XSetWMName(); }
int main() {
_check_XSetWMName();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.libraries/conftest.o  -lX11 -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
              Defined "HAVE_LIBX11" to "1"
              Popping language C
        Checking for headers Package specific search directory X: ['/opt/mpich/include']
            Pushing language C
TEST checkInclude from config.headers(/home/jed/petsc/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
  Checks if a particular include file can be found along particular include paths
Checking for header files ['X11/Xlib.h'] in ['/opt/mpich/include']
              Checking include with compiler flags var CPPFLAGS ['/opt/mpich/include']
Executing: /opt/mpich/bin/mpicc -E  -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.headers  -I/opt/mpich/include /tmp/petsc-lhuj9c/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-lhuj9c/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
# 1 "/tmp/petsc-lhuj9c/config.headers/conffix.h" 1
# 1 "/usr/include/X11/Xlib.h" 1 3 4
# 38 "/usr/include/X11/Xlib.h" 3 4
# 1 "/usr/include/sys/types.h" 1 3 4
# 25 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 395 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 396 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 26 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 30 "/usr/include/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 60 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 98 "/usr/include/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 132 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/time.h" 1 3 4
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 133 "/usr/include/sys/types.h" 2 3 4
# 146 "/usr/include/sys/types.h" 3 4
# 212 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 147 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 194 "/usr/include/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 216 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 28 "/usr/include/bits/byteswap.h" 3 4
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 217 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/sigset.h" 1 3 4
# 22 "/usr/include/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
# 44 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 46 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 64 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 96 "/usr/include/sys/select.h" 3 4
# 106 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 118 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 131 "/usr/include/sys/select.h" 3 4
# 220 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/sysmacros.h" 1 3 4
# 24 "/usr/include/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 58 "/usr/include/sys/sysmacros.h" 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 270 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 271 "/usr/include/sys/types.h" 2 3 4
# 39 "/usr/include/X11/Xlib.h" 2 3 4
# 1 "/usr/include/X11/X.h" 1 3 4
# 66 "/usr/include/X11/X.h" 3 4
typedef unsigned long XID;
typedef unsigned long Mask;
typedef unsigned long Atom;
typedef unsigned long VisualID;
typedef unsigned long Time;
# 96 "/usr/include/X11/X.h" 3 4
typedef XID Window;
typedef XID Drawable;
typedef XID Font;
typedef XID Pixmap;
typedef XID Cursor;
typedef XID Colormap;
typedef XID GContext;
typedef XID KeySym;
typedef unsigned char KeyCode;
# 45 "/usr/include/X11/Xlib.h" 2 3 4
# 1 "/usr/include/X11/Xfuncproto.h" 1 3 4
# 48 "/usr/include/X11/Xlib.h" 2 3 4
# 1 "/usr/include/X11/Xosdefs.h" 1 3 4
# 49 "/usr/include/X11/Xlib.h" 2 3 4
# 147 "/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1/include/stddef.h" 3 4
typedef long int ptrdiff_t;
# 52 "/usr/include/X11/Xlib.h" 2 3 4
# 69 "/usr/include/X11/Xlib.h" 3 4
extern int
_Xmblen(
    char *str,
    int len
# 92 "/usr/include/X11/Xlib.h" 3 4
typedef char *XPointer;
# 160 "/usr/include/X11/Xlib.h" 3 4
typedef struct _XExtData {
 int number;
 struct _XExtData *next;
 int (*free_private)(
 struct _XExtData *extension
 XPointer private_data;
} XExtData;
typedef struct {
 int extension;
 int major_opcode;
 int first_event;
 int first_error;
} XExtCodes;
typedef struct {
    int depth;
    int bits_per_pixel;
    int scanline_pad;
} XPixmapFormatValues;
typedef struct {
 int function;
 unsigned long plane_mask;
 unsigned long foreground;
 unsigned long background;
 int line_width;
 int line_style;
 int cap_style;
 int join_style;
 int fill_style;
 int fill_rule;
 int arc_mode;
 Pixmap tile;
 Pixmap stipple;
 int ts_x_origin;
 int ts_y_origin;
        Font font;
 int subwindow_mode;
 int graphics_exposures;
 int clip_x_origin;
 int clip_y_origin;
 Pixmap clip_mask;
 int dash_offset;
 char dashes;
} XGCValues;
typedef struct _XGC
*GC;
typedef struct {
 XExtData *ext_data;
 VisualID visualid;
 int class;
 unsigned long red_mask, green_mask, blue_mask;
 int bits_per_rgb;
 int map_entries;
} Visual;
typedef struct {
 int depth;
 int nvisuals;
 Visual *visuals;
} Depth;
struct _XDisplay;
typedef struct {
 XExtData *ext_data;
 struct _XDisplay *display;
 Window root;
 int width, height;
 int mwidth, mheight;
 int ndepths;
 Depth *depths;
 int root_depth;
 Visual *root_visual;
 GC default_gc;
 Colormap cmap;
 unsigned long white_pixel;
 unsigned long black_pixel;
 int max_maps, min_maps;
 int backing_store;
 int save_unders;
 long root_input_mask;
} Screen;
typedef struct {
 XExtData *ext_data;
 int depth;
 int bits_per_pixel;
 int scanline_pad;
} ScreenFormat;
typedef struct {
    Pixmap background_pixmap;
    unsigned long background_pixel;
    Pixmap border_pixmap;
    unsigned long border_pixel;
    int bit_gravity;
    int win_gravity;
    int backing_store;
    unsigned long backing_planes;
    unsigned long backing_pixel;
    int save_under;
    long event_mask;
    long do_not_propagate_mask;
    int override_redirect;
    Colormap colormap;
    Cursor cursor;
} XSetWindowAttributes;
typedef struct {
    int x, y;
    int width, height;
    int border_width;
    int depth;
    Visual *visual;
    Window root;
    int class;
    int bit_gravity;
    int win_gravity;
    int backing_store;
    int save_under;
    Colormap colormap;
    int map_installed;
    int map_state;
    long all_event_masks;
    long your_event_mask;
    Screen *screen;
} XWindowAttributes;
typedef struct {
 int family;
 int length;
 char *address;
} XHostAddress;
typedef struct {
 int typelength;
 int valuelength;
 char *type;
 char *value;
} XServerInterpretedAddress;
typedef struct _XImage {
    int width, height;
    int xoffset;
    int format;
    char *data;
    int byte_order;
    int bitmap_unit;
    int bitmap_bit_order;
    int bitmap_pad;
    int depth;
    int bytes_per_line;
    int bits_per_pixel;
    unsigned long red_mask;
    unsigned long green_mask;
    unsigned long blue_mask;
    XPointer obdata;
    struct funcs {
 struct _XImage *(*create_image)(
  struct _XDisplay* ,
  Visual* ,
  unsigned int ,
  int ,
  int ,
  char* ,
  unsigned int ,
  unsigned int ,
  int ,
  int );
 int (*destroy_image) (struct _XImage *);
 unsigned long (*get_pixel) (struct _XImage *, int, int);
 int (*put_pixel) (struct _XImage *, int, int, unsigned long);
 struct _XImage *(*sub_image)(struct _XImage *, int, int, unsigned int, unsigned int);
 int (*add_pixel) (struct _XImage *, long);
 } f;
} XImage;
typedef struct {
    int x, y;
    int width, height;
    int border_width;
    Window sibling;
    int stack_mode;
} XWindowChanges;
typedef struct {
 unsigned long pixel;
 unsigned short red, green, blue;
 char flags;
 char pad;
} XColor;
typedef struct {
    short x1, y1, x2, y2;
} XSegment;
typedef struct {
    short x, y;
} XPoint;
typedef struct {
    short x, y;
    unsigned short width, height;
} XRectangle;
typedef struct {
    short x, y;
    short angle1, angle2;
} XArc;
typedef struct {
        int key_click_percent;
        int bell_percent;
        int bell_pitch;
        int bell_duration;
        int led;
        int led_mode;
        int key;
        int auto_repeat_mode;
} XKeyboardControl;
typedef struct {
 int bell_percent;
 unsigned int bell_pitch, bell_duration;
 unsigned long led_mask;
 int global_auto_repeat;
 char auto_repeats[32];
} XKeyboardState;
typedef struct {
        Time time;
 short x, y;
} XTimeCoord;
typedef struct {
  int max_keypermod;
  KeyCode *modifiermap;
} XModifierKeymap;
# 499 "/usr/include/X11/Xlib.h" 3 4
typedef struct _XDisplay Display;
struct _XPrivate;
struct _XrmHashBucketRec;
typedef struct
 XExtData *ext_data;
 struct _XPrivate *private1;
 int fd;
 int private2;
 int proto_major_version;
 int proto_minor_version;
 char *vendor;
        XID private3;
 XID private4;
 XID private5;
 int private6;
 XID (*resource_alloc)(
  struct _XDisplay*
 int byte_order;
 int bitmap_unit;
 int bitmap_pad;
 int nformats;
 ScreenFormat *pixmap_format;
 int private8;
 int release;
 struct _XPrivate *private9, *private10;
 int qlen;
 unsigned long last_request_read;
 unsigned long request;
 XPointer private11;
 XPointer private12;
 XPointer private13;
 XPointer private14;
 unsigned max_request_size;
 struct _XrmHashBucketRec *db;
 int (*private15)(
  struct _XDisplay*
 char *display_name;
 int default_screen;
 int nscreens;
 Screen *screens;
 unsigned long motion_buffer;
 unsigned long private16;
 int min_keycode;
 int max_keycode;
 XPointer private17;
 XPointer private18;
 int private19;
 char *xdefaults;
*_XPrivDisplay;
typedef struct {
 int type;
 unsigned long serial;
 int send_event;
 Display *display;
 Window window;
 Window root;
 Window subwindow;
 Time time;
 int x, y;
 int x_root, y_root;
 unsigned int state;
 unsigned int keycode;
 int same_screen;
} XKeyEvent;
typedef XKeyEvent XKeyPressedEvent;
typedef XKeyEvent XKeyReleasedEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window window;
 Window root;
 Window subwindow;
 Time time;
 int x, y;
 int x_root, y_root;
 unsigned int state;
 unsigned int button;
 int same_screen;
} XButtonEvent;
typedef XButtonEvent XButtonPressedEvent;
typedef XButtonEvent XButtonReleasedEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window window;
 Window root;
 Window subwindow;
 Time time;
 int x, y;
 int x_root, y_root;
 unsigned int state;
 char is_hint;
 int same_screen;
} XMotionEvent;
typedef XMotionEvent XPointerMovedEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window window;
 Window root;
 Window subwindow;
 Time time;
 int x, y;
 int x_root, y_root;
 int mode;
 int detail;
 int same_screen;
 int focus;
 unsigned int state;
} XCrossingEvent;
typedef XCrossingEvent XEnterWindowEvent;
typedef XCrossingEvent XLeaveWindowEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window window;
 int mode;
 int detail;
} XFocusChangeEvent;
typedef XFocusChangeEvent XFocusInEvent;
typedef XFocusChangeEvent XFocusOutEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window window;
 char key_vector[32];
} XKeymapEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window window;
 int x, y;
 int width, height;
 int count;
} XExposeEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Drawable drawable;
 int x, y;
 int width, height;
 int count;
 int major_code;
 int minor_code;
} XGraphicsExposeEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Drawable drawable;
 int major_code;
 int minor_code;
} XNoExposeEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window window;
 int state;
} XVisibilityEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window parent;
 Window window;
 int x, y;
 int width, height;
 int border_width;
} XCreateWindowEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window event;
 Window window;
} XDestroyWindowEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window event;
 Window window;
 int from_configure;
} XUnmapEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window event;
 Window window;
} XMapEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window parent;
 Window window;
} XMapRequestEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window event;
 Window window;
 Window parent;
 int x, y;
} XReparentEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window event;
 Window window;
 int x, y;
 int width, height;
 int border_width;
 Window above;
} XConfigureEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window event;
 Window window;
 int x, y;
} XGravityEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window window;
 int width, height;
} XResizeRequestEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window parent;
 Window window;
 int x, y;
 int width, height;
 int border_width;
 Window above;
 int detail;
 unsigned long value_mask;
} XConfigureRequestEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window event;
 Window window;
 int place;
} XCirculateEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window parent;
 Window window;
 int place;
} XCirculateRequestEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window window;
 Atom atom;
 Time time;
 int state;
} XPropertyEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window window;
 Atom selection;
 Time time;
} XSelectionClearEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window owner;
 Window requestor;
 Atom selection;
 Atom target;
 Atom property;
 Time time;
} XSelectionRequestEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window requestor;
 Atom selection;
 Atom target;
 Atom property;
 Time time;
} XSelectionEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window window;
 Colormap colormap;
 int new;
 int state;
} XColormapEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window window;
 Atom message_type;
 int format;
 union {
  char b[20];
  short s[10];
  long l[5];
  } data;
} XClientMessageEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window window;
 int request;
 int first_keycode;
 int count;
} XMappingEvent;
typedef struct {
 int type;
 Display *display;
 XID resourceid;
 unsigned char error_code;
 unsigned char request_code;
 unsigned char minor_code;
} XErrorEvent;
typedef struct {
 int type;
 int send_event;
 Display *display;
 Window window;
} XAnyEvent;
typedef struct
    int type;
    int send_event;
    Display *display;
    int extension;
    int evtype;
    } XGenericEvent;
typedef struct {
    int type;
    int send_event;
    Display *display;
    int extension;
    int evtype;
    unsigned int cookie;
    void *data;
} XGenericEventCookie;
typedef union _XEvent {
        int type;
 XAnyEvent xany;
 XKeyEvent xkey;
 XButtonEvent xbutton;
 XMotionEvent xmotion;
 XCrossingEvent xcrossing;
 XFocusChangeEvent xfocus;
 XExposeEvent xexpose;
 XGraphicsExposeEvent xgraphicsexpose;
 XNoExposeEvent xnoexpose;
 XVisibilityEvent xvisibility;
 XCreateWindowEvent xcreatewindow;
 XDestroyWindowEvent xdestroywindow;
 XUnmapEvent xunmap;
 XMapEvent xmap;
 XMapRequestEvent xmaprequest;
 XReparentEvent xreparent;
 XConfigureEvent xconfigure;
 XGravityEvent xgravity;
 XResizeRequestEvent xresizerequest;
 XConfigureRequestEvent xconfigurerequest;
 XCirculateEvent xcirculate;
 XCirculateRequestEvent xcirculaterequest;
 XPropertyEvent xproperty;
 XSelectionClearEvent xselectionclear;
 XSelectionRequestEvent xselectionrequest;
 XSelectionEvent xselection;
 XColormapEvent xcolormap;
 XClientMessageEvent xclient;
 XMappingEvent xmapping;
 XErrorEvent xerror;
 XKeymapEvent xkeymap;
 XGenericEvent xgeneric;
 XGenericEventCookie xcookie;
 long pad[24];
} XEvent;
typedef struct {
    short lbearing;
    short rbearing;
    short width;
    short ascent;
    short descent;
    unsigned short attributes;
} XCharStruct;
typedef struct {
    Atom name;
    unsigned long card32;
} XFontProp;
typedef struct {
    XExtData *ext_data;
    Font fid;
    unsigned direction;
    unsigned min_char_or_byte2;
    unsigned max_char_or_byte2;
    unsigned min_byte1;
    unsigned max_byte1;
    int all_chars_exist;
    unsigned default_char;
    int n_properties;
    XFontProp *properties;
    XCharStruct min_bounds;
    XCharStruct max_bounds;
    XCharStruct *per_char;
    int ascent;
    int descent;
} XFontStruct;
typedef struct {
    char *chars;
    int nchars;
    int delta;
    Font font;
} XTextItem;
typedef struct {
    unsigned char byte1;
    unsigned char byte2;
} XChar2b;
typedef struct {
    XChar2b *chars;
    int nchars;
    int delta;
    Font font;
} XTextItem16;
typedef union { Display *display;
  GC gc;
  Visual *visual;
  Screen *screen;
  XFontStruct *font; } XEDataObject;
typedef struct {
    XRectangle max_ink_extent;
    XRectangle max_logical_extent;
} XFontSetExtents;
typedef struct _XOM *XOM;
typedef struct _XOC *XOC, *XFontSet;
typedef struct {
    char *chars;
    int nchars;
    int delta;
    XFontSet font_set;
} XmbTextItem;
typedef struct {
    wchar_t *chars;
    int nchars;
    int delta;
    XFontSet font_set;
} XwcTextItem;
# 1133 "/usr/include/X11/Xlib.h" 3 4
typedef struct {
    int charset_count;
    char **charset_list;
} XOMCharSetList;
typedef enum {
    XOMOrientation_LTR_TTB,
    XOMOrientation_RTL_TTB,
    XOMOrientation_TTB_LTR,
    XOMOrientation_TTB_RTL,
    XOMOrientation_Context
} XOrientation;
typedef struct {
    int num_orientation;
    XOrientation *orientation;
} XOMOrientation;
typedef struct {
    int num_font;
    XFontStruct **font_struct_list;
    char **font_name_list;
} XOMFontInfo;
typedef struct _XIM *XIM;
typedef struct _XIC *XIC;
typedef void (*XIMProc)(
    XIM,
    XPointer,
    XPointer
typedef int (*XICProc)(
    XIC,
    XPointer,
    XPointer
typedef void (*XIDProc)(
    Display*,
    XPointer,
    XPointer
typedef unsigned long XIMStyle;
typedef struct {
    unsigned short count_styles;
    XIMStyle *supported_styles;
} XIMStyles;
# 1245 "/usr/include/X11/Xlib.h" 3 4
typedef void *XVaNestedList;
typedef struct {
    XPointer client_data;
    XIMProc callback;
} XIMCallback;
typedef struct {
    XICProc callback;
} XICCallback;
typedef unsigned long XIMFeedback;
# 1269 "/usr/include/X11/Xlib.h" 3 4
typedef struct _XIMText {
    unsigned short length;
    XIMFeedback *feedback;
    int encoding_is_wchar;
    union {
 char *multi_byte;
 wchar_t *wide_char;
    } string;
} XIMText;
typedef unsigned long XIMPreeditState;
typedef struct _XIMPreeditStateNotifyCallbackStruct {
    XIMPreeditState state;
} XIMPreeditStateNotifyCallbackStruct;
typedef unsigned long XIMResetState;
typedef unsigned long XIMStringConversionFeedback;
# 1303 "/usr/include/X11/Xlib.h" 3 4
typedef struct _XIMStringConversionText {
    XIMStringConversionFeedback *feedback;
    union {
 char *mbs;
 wchar_t *wcs;
    } string;
} XIMStringConversionText;
typedef unsigned short XIMStringConversionPosition;
typedef unsigned short XIMStringConversionType;
typedef unsigned short XIMStringConversionOperation;
typedef enum {
    XIMForwardChar, XIMBackwardChar,
    XIMForwardWord, XIMBackwardWord,
    XIMCaretUp, XIMCaretDown,
    XIMNextLine, XIMPreviousLine,
    XIMLineStart, XIMLineEnd,
    XIMAbsolutePosition,
    XIMDontChange
} XIMCaretDirection;
typedef struct _XIMStringConversionCallbackStruct {
    XIMStringConversionPosition position;
    XIMCaretDirection direction;
    XIMStringConversionOperation operation;
    unsigned short factor;
    XIMStringConversionText *text;
} XIMStringConversionCallbackStruct;
typedef struct _XIMPreeditDrawCallbackStruct {
    int caret;
    int chg_first;
    int chg_length;
    XIMText *text;
} XIMPreeditDrawCallbackStruct;
typedef enum {
    XIMIsInvisible,
    XIMIsPrimary,
    XIMIsSecondary
} XIMCaretStyle;
typedef struct _XIMPreeditCaretCallbackStruct {
    int position;
    XIMCaretStyle style;
} XIMPreeditCaretCallbackStruct;
typedef enum {
    XIMTextType,
    XIMBitmapType
} XIMStatusDataType;
typedef struct _XIMStatusDrawCallbackStruct {
    XIMStatusDataType type;
    union {
 XIMText *text;
 Pixmap bitmap;
    } data;
} XIMStatusDrawCallbackStruct;
typedef struct _XIMHotKeyTrigger {
    KeySym keysym;
    int modifier;
    int modifier_mask;
} XIMHotKeyTrigger;
typedef struct _XIMHotKeyTriggers {
    int num_hot_key;
    XIMHotKeyTrigger *key;
} XIMHotKeyTriggers;
typedef unsigned long XIMHotKeyState;
typedef struct {
    unsigned short count_values;
    char **supported_values;
} XIMValuesList;
extern int _Xdebug;
extern XFontStruct *XLoadQueryFont(
    Display* ,
    const char*
extern XFontStruct *XQueryFont(
    Display* ,
    XID
extern XTimeCoord *XGetMotionEvents(
    Display* ,
    Window ,
    Time ,
    Time ,
    int*
extern XModifierKeymap *XDeleteModifiermapEntry(
    XModifierKeymap* ,
    KeyCode ,
    int
extern XModifierKeymap *XGetModifierMapping(
    Display*
extern XModifierKeymap *XInsertModifiermapEntry(
    XModifierKeymap* ,
    KeyCode ,
    int
extern XModifierKeymap *XNewModifiermap(
    int
extern XImage *XCreateImage(
    Display* ,
    Visual* ,
    unsigned int ,
    int ,
    int ,
    char* ,
    unsigned int ,
    unsigned int ,
    int ,
    int
extern int XInitImage(
    XImage*
extern XImage *XGetImage(
    Display* ,
    Drawable ,
    int ,
    int ,
    unsigned int ,
    unsigned int ,
    unsigned long ,
    int
extern XImage *XGetSubImage(
    Display* ,
    Drawable ,
    int ,
    int ,
    unsigned int ,
    unsigned int ,
    unsigned long ,
    int ,
    XImage* ,
    int ,
    int
extern Display *XOpenDisplay(
    const char*
extern void XrmInitialize(
    void
extern char *XFetchBytes(
    Display* ,
    int*
extern char *XFetchBuffer(
    Display* ,
    int* ,
    int
extern char *XGetAtomName(
    Display* ,
    Atom
extern int XGetAtomNames(
    Display* ,
    Atom* ,
    int ,
    char**
extern char *XGetDefault(
    Display* ,
    const char* ,
    const char*
extern char *XDisplayName(
    const char*
extern char *XKeysymToString(
    KeySym
extern int (*XSynchronize(
    Display* ,
    int
    Display*
extern int (*XSetAfterFunction(
    Display* ,
    int (*) (
      Display*
    Display*
extern Atom XInternAtom(
    Display* ,
    const char* ,
    int
extern int XInternAtoms(
    Display* ,
    char** ,
    int ,
    int ,
    Atom*
extern Colormap XCopyColormapAndFree(
    Display* ,
    Colormap
extern Colormap XCreateColormap(
    Display* ,
    Window ,
    Visual* ,
    int
extern Cursor XCreatePixmapCursor(
    Display* ,
    Pixmap ,
    Pixmap ,
    XColor* ,
    XColor* ,
    unsigned int ,
    unsigned int
extern Cursor XCreateGlyphCursor(
    Display* ,
    Font ,
    Font ,
    unsigned int ,
    unsigned int ,
    XColor const * ,
    XColor const *
extern Cursor XCreateFontCursor(
    Display* ,
    unsigned int
extern Font XLoadFont(
    Display* ,
    const char*
extern GC XCreateGC(
    Display* ,
    Drawable ,
    unsigned long ,
    XGCValues*
extern GContext XGContextFromGC(
    GC
extern void XFlushGC(
    Display* ,
    GC
extern Pixmap XCreatePixmap(
    Display* ,
    Drawable ,
    unsigned int ,
    unsigned int ,
    unsigned int
extern Pixmap XCreateBitmapFromData(
    Display* ,
    Drawable ,
    const char* ,
    unsigned int ,
    unsigned int
extern Pixmap XCreatePixmapFromBitmapData(
    Display* ,
    Drawable ,
    char* ,
    unsigned int ,
    unsigned int ,
    unsigned long ,
    unsigned long ,
    unsigned int
extern Window XCreateSimpleWindow(
    Display* ,
    Window ,
    int ,
    int ,
    unsigned int ,
    unsigned int ,
    unsigned int ,
    unsigned long ,
    unsigned long
extern Window XGetSelectionOwner(
    Display* ,
    Atom
extern Window XCreateWindow(
    Display* ,
    Window ,
    int ,
    int ,
    unsigned int ,
    unsigned int ,
    unsigned int ,
    int ,
    unsigned int ,
    Visual* ,
    unsigned long ,
    XSetWindowAttributes*
extern Colormap *XListInstalledColormaps(
    Display* ,
    Window ,
    int*
extern char **XListFonts(
    Display* ,
    const char* ,
    int ,
    int*
extern char **XListFontsWithInfo(
    Display* ,
    const char* ,
    int ,
    int* ,
    XFontStruct**
extern char **XGetFontPath(
    Display* ,
    int*
extern char **XListExtensions(
    Display* ,
    int*
extern Atom *XListProperties(
    Display* ,
    Window ,
    int*
extern XHostAddress *XListHosts(
    Display* ,
    int* ,
    int*
__attribute__((deprecated))
extern KeySym XKeycodeToKeysym(
    Display* ,
    KeyCode ,
    int
extern KeySym XLookupKeysym(
    XKeyEvent* ,
    int
extern KeySym *XGetKeyboardMapping(
    Display* ,
    KeyCode ,
    int ,
    int*
extern KeySym XStringToKeysym(
    const char*
extern long XMaxRequestSize(
    Display*
extern long XExtendedMaxRequestSize(
    Display*
extern char *XResourceManagerString(
    Display*
extern char *XScreenResourceString(
 Screen*
extern unsigned long XDisplayMotionBufferSize(
    Display*
extern VisualID XVisualIDFromVisual(
    Visual*
extern int XInitThreads(
    void
extern void XLockDisplay(
    Display*
extern void XUnlockDisplay(
    Display*
extern XExtCodes *XInitExtension(
    Display* ,
    const char*
extern XExtCodes *XAddExtension(
    Display*
extern XExtData *XFindOnExtensionList(
    XExtData** ,
    int
extern XExtData **XEHeadOfExtensionList(
    XEDataObject
extern Window XRootWindow(
    Display* ,
    int
extern Window XDefaultRootWindow(
    Display*
extern Window XRootWindowOfScreen(
    Screen*
extern Visual *XDefaultVisual(
    Display* ,
    int
extern Visual *XDefaultVisualOfScreen(
    Screen*
extern GC XDefaultGC(
    Display* ,
    int
extern GC XDefaultGCOfScreen(
    Screen*
extern unsigned long XBlackPixel(
    Display* ,
    int
extern unsigned long XWhitePixel(
    Display* ,
    int
extern unsigned long XAllPlanes(
    void
extern unsigned long XBlackPixelOfScreen(
    Screen*
extern unsigned long XWhitePixelOfScreen(
    Screen*
extern unsigned long XNextRequest(
    Display*
extern unsigned long XLastKnownRequestProcessed(
    Display*
extern char *XServerVendor(
    Display*
extern char *XDisplayString(
    Display*
extern Colormap XDefaultColormap(
    Display* ,
    int
extern Colormap XDefaultColormapOfScreen(
    Screen*
extern Display *XDisplayOfScreen(
    Screen*
extern Screen *XScreenOfDisplay(
    Display* ,
    int
extern Screen *XDefaultScreenOfDisplay(
    Display*
extern long XEventMaskOfScreen(
    Screen*
extern int XScreenNumberOfScreen(
    Screen*
typedef int (*XErrorHandler) (
    Display* ,
    XErrorEvent*
extern XErrorHandler XSetErrorHandler (
    XErrorHandler
typedef int (*XIOErrorHandler) (
    Display*
extern XIOErrorHandler XSetIOErrorHandler (
    XIOErrorHandler
extern XPixmapFormatValues *XListPixmapFormats(
    Display* ,
    int*
extern int *XListDepths(
    Display* ,
    int ,
    int*
extern int XReconfigureWMWindow(
    Display* ,
    Window ,
    int ,
    unsigned int ,
    XWindowChanges*
extern int XGetWMProtocols(
    Display* ,
    Window ,
    Atom** ,
    int*
extern int XSetWMProtocols(
    Display* ,
    Window ,
    Atom* ,
    int
extern int XIconifyWindow(
    Display* ,
    Window ,
    int
extern int XWithdrawWindow(
    Display* ,
    Window ,
    int
extern int XGetCommand(
    Display* ,
    Window ,
    char*** ,
    int*
extern int XGetWMColormapWindows(
    Display* ,
    Window ,
    Window** ,
    int*
extern int XSetWMColormapWindows(
    Display* ,
    Window ,
    Window* ,
    int
extern void XFreeStringList(
    char**
extern int XSetTransientForHint(
    Display* ,
    Window ,
    Window
extern int XActivateScreenSaver(
    Display*
extern int XAddHost(
    Display* ,
    XHostAddress*
extern int XAddHosts(
    Display* ,
    XHostAddress* ,
    int
extern int XAddToExtensionList(
    struct _XExtData** ,
    XExtData*
extern int XAddToSaveSet(
    Display* ,
    Window
extern int XAllocColor(
    Display* ,
    Colormap ,
    XColor*
extern int XAllocColorCells(
    Display* ,
    Colormap ,
    int ,
    unsigned long* ,
    unsigned int ,
    unsigned long* ,
    unsigned int
extern int XAllocColorPlanes(
    Display* ,
    Colormap ,
    int ,
    unsigned long* ,
    int ,
    int ,
    int ,
    int ,
    unsigned long* ,
    unsigned long* ,
    unsigned long*
extern int XAllocNamedColor(
    Display* ,
    Colormap ,
    const char* ,
    XColor* ,
    XColor*
extern int XAllowEvents(
    Display* ,
    int ,
    Time
extern int XAutoRepeatOff(
    Display*
extern int XAutoRepeatOn(
    Display*
extern int XBell(
    Display* ,
    int
extern int XBitmapBitOrder(
    Display*
extern int XBitmapPad(
    Display*
extern int XBitmapUnit(
    Display*
extern int XCellsOfScreen(
    Screen*
extern int XChangeActivePointerGrab(
    Display* ,
    unsigned int ,
    Cursor ,
    Time
extern int XChangeGC(
    Display* ,
    GC ,
    unsigned long ,
    XGCValues*
extern int XChangeKeyboardControl(
    Display* ,
    unsigned long ,
    XKeyboardControl*
extern int XChangeKeyboardMapping(
    Display* ,
    int ,
    int ,
    KeySym* ,
    int
extern int XChangePointerControl(
    Display* ,
    int ,
    int ,
    int ,
    int ,
    int
extern int XChangeProperty(
    Display* ,
    Window ,
    Atom ,
    Atom ,
    int ,
    int ,
    const unsigned char* ,
    int
extern int XChangeSaveSet(
    Display* ,
    Window ,
    int
extern int XChangeWindowAttributes(
    Display* ,
    Window ,
    unsigned long ,
extern int XCheckIfEvent(
    Display* ,
    XEvent* ,
    int (*) (
        Display* ,
               XEvent* ,
               XPointer
    XPointer
extern int XCheckMaskEvent(
    Display* ,
    long ,
    XEvent*
extern int XCheckTypedEvent(
    Display* ,
    int ,
    XEvent*
extern int XCheckTypedWindowEvent(
    Display* ,
    Window ,
    int ,
    XEvent*
extern int XCheckWindowEvent(
    Display* ,
    Window ,
    long ,
    XEvent*
extern int XCirculateSubwindows(
    Display* ,
    Window ,
    int
extern int XCirculateSubwindowsDown(
    Display* ,
    Window
extern int XCirculateSubwindowsUp(
    Display* ,
    Window
extern int XClearArea(
    Display* ,
    Window ,
    int ,
    int ,
    unsigned int ,
    unsigned int ,
    int
extern int XClearWindow(
    Display* ,
    Window
extern int XCloseDisplay(
    Display*
extern int XConfigureWindow(
    Display* ,
    Window ,
    unsigned int ,
    XWindowChanges*
extern int XConnectionNumber(
    Display*
extern int XConvertSelection(
    Display* ,
    Atom ,
    Atom ,
    Atom ,
    Window ,
    Time
extern int XCopyArea(
    Display* ,
    Drawable ,
    Drawable ,
    GC ,
    int ,
    int ,
    unsigned int ,
    unsigned int ,
    int ,
    int
extern int XCopyGC(
    Display* ,
    GC ,
    unsigned long ,
    GC
extern int XCopyPlane(
    Display* ,
    Drawable ,
    Drawable ,
    GC ,
    int ,
    int ,
    unsigned int ,
    unsigned int ,
    int ,
    int ,
    unsigned long
extern int XDefaultDepth(
    Display* ,
    int
extern int XDefaultDepthOfScreen(
    Screen*
extern int XDefaultScreen(
    Display*
extern int XDefineCursor(
    Display* ,
    Window ,
    Cursor
extern int XDeleteProperty(
    Display* ,
    Window ,
    Atom
extern int XDestroyWindow(
    Display* ,
    Window
extern int XDestroySubwindows(
    Display* ,
    Window
extern int XDoesBackingStore(
    Screen*
extern int XDoesSaveUnders(
    Screen*
extern int XDisableAccessControl(
    Display*
extern int XDisplayCells(
    Display* ,
    int
extern int XDisplayHeight(
    Display* ,
    int
extern int XDisplayHeightMM(
    Display* ,
    int
extern int XDisplayKeycodes(
    Display* ,
    int* ,
    int*
extern int XDisplayPlanes(
    Display* ,
    int
extern int XDisplayWidth(
    Display* ,
    int
extern int XDisplayWidthMM(
    Display* ,
    int
extern int XDrawArc(
    Display* ,
    Drawable ,
    GC ,
    int ,
    int ,
    unsigned int ,
    unsigned int ,
    int ,
    int
extern int XDrawArcs(
    Display* ,
    Drawable ,
    GC ,
    XArc* ,
    int
extern int XDrawImageString(
    Display* ,
    Drawable ,
    GC ,
    int ,
    int ,
    const char* ,
    int
extern int XDrawImageString16(
    Display* ,
    Drawable ,
    GC ,
    int ,
    int ,
    const XChar2b* ,
    int
extern int XDrawLine(
    Display* ,
    Drawable ,
    GC ,
    int ,
    int ,
    int ,
    int
extern int XDrawLines(
    Display* ,
    Drawable ,
    GC ,
    XPoint* ,
    int ,
    int
extern int XDrawPoint(
    Display* ,
    Drawable ,
    GC ,
    int ,
    int
extern int XDrawPoints(
    Display* ,
    Drawable ,
    GC ,
    XPoint* ,
    int ,
    int
extern int XDrawRectangle(
    Display* ,
    Drawable ,
    GC ,
    int ,
    int ,
    unsigned int ,
    unsigned int
extern int XDrawRectangles(
    Display* ,
    Drawable ,
    GC ,
    XRectangle* ,
    int
extern int XDrawSegments(
    Display* ,
    Drawable ,
    GC ,
    XSegment* ,
    int
extern int XDrawString(
    Display* ,
    Drawable ,
    GC ,
    int ,
    int ,
    const char* ,
    int
extern int XDrawString16(
    Display* ,
    Drawable ,
    GC ,
    int ,
    int ,
    const XChar2b* ,
    int
extern int XDrawText(
    Display* ,
    Drawable ,
    GC ,
    int ,
    int ,
    XTextItem* ,
    int
extern int XDrawText16(
    Display* ,
    Drawable ,
    GC ,
    int ,
    int ,
    XTextItem16* ,
    int
extern int XEnableAccessControl(
    Display*
extern int XEventsQueued(
    Display* ,
    int
extern int XFetchName(
    Display* ,
    Window ,
    char**
extern int XFillArc(
    Display* ,
    Drawable ,
    GC ,
    int ,
    int ,
    unsigned int ,
    unsigned int ,
    int ,
    int
extern int XFillArcs(
    Display* ,
    Drawable ,
    GC ,
    XArc* ,
    int
extern int XFillPolygon(
    Display* ,
    Drawable ,
    GC ,
    XPoint* ,
    int ,
    int ,
    int
extern int XFillRectangle(
    Display* ,
    Drawable ,
    GC ,
    int ,
    int ,
    unsigned int ,
    unsigned int
extern int XFillRectangles(
    Display* ,
    Drawable ,
    GC ,
    XRectangle* ,
    int
extern int XFlush(
    Display*
extern int XForceScreenSaver(
    Display* ,
    int
extern int XFree(
    void*
extern int XFreeColormap(
    Display* ,
    Colormap
extern int XFreeColors(
    Display* ,
    Colormap ,
    unsigned long* ,
    int ,
    unsigned long
extern int XFreeCursor(
    Display* ,
    Cursor
extern int XFreeExtensionList(
    char**
extern int XFreeFont(
    Display* ,
    XFontStruct*
extern int XFreeFontInfo(
    char** ,
    XFontStruct* ,
    int
extern int XFreeFontNames(
    char**
extern int XFreeFontPath(
    char**
extern int XFreeGC(
    Display* ,
    GC
extern int XFreeModifiermap(
    XModifierKeymap*
extern int XFreePixmap(
    Display* ,
    Pixmap
extern int XGeometry(
    Display* ,
    int ,
    const char* ,
    const char* ,
    unsigned int ,
    unsigned int ,
    unsigned int ,
    int ,
    int ,
    int* ,
    int* ,
    int* ,
    int*
extern int XGetErrorDatabaseText(
    Display* ,
    const char* ,
    const char* ,
    const char* ,
    char* ,
    int
extern int XGetErrorText(
    Display* ,
    int ,
    char* ,
    int
extern int XGetFontProperty(
    XFontStruct* ,
    Atom ,
    unsigned long*
extern int XGetGCValues(
    Display* ,
    GC ,
    unsigned long ,
    XGCValues*
extern int XGetGeometry(
    Display* ,
    Drawable ,
    Window* ,
    int* ,
    int* ,
    unsigned int* ,
    unsigned int* ,
    unsigned int* ,
    unsigned int*
extern int XGetIconName(
    Display* ,
    Window ,
    char**
extern int XGetInputFocus(
    Display* ,
    Window* ,
    int*
extern int XGetKeyboardControl(
    Display* ,
    XKeyboardState*
extern int XGetPointerControl(
    Display* ,
    int* ,
    int* ,
    int*
extern int XGetPointerMapping(
    Display* ,
    unsigned char* ,
    int
extern int XGetScreenSaver(
    Display* ,
    int* ,
    int* ,
    int* ,
    int*
extern int XGetTransientForHint(
    Display* ,
    Window ,
    Window*
extern int XGetWindowProperty(
    Display* ,
    Window ,
    Atom ,
    long ,
    long ,
    int ,
    Atom ,
    Atom* ,
    int* ,
    unsigned long* ,
    unsigned long* ,
    unsigned char**
extern int XGetWindowAttributes(
    Display* ,
    Window ,
    XWindowAttributes*
extern int XGrabButton(
    Display* ,
    unsigned int ,
    unsigned int ,
    Window ,
    int ,
    unsigned int ,
    int ,
    int ,
    Window ,
    Cursor
extern int XGrabKey(
    Display* ,
    int ,
    unsigned int ,
    Window ,
    int ,
    int ,
    int
extern int XGrabKeyboard(
    Display* ,
    Window ,
    int ,
    int ,
    int ,
    Time
extern int XGrabPointer(
    Display* ,
    Window ,
    int ,
    unsigned int ,
    int ,
    int ,
    Window ,
    Cursor ,
    Time
extern int XGrabServer(
    Display*
extern int XHeightMMOfScreen(
    Screen*
extern int XHeightOfScreen(
    Screen*
extern int XIfEvent(
    Display* ,
    XEvent* ,
    int (*) (
        Display* ,
               XEvent* ,
               XPointer
    XPointer
extern int XImageByteOrder(
    Display*
extern int XInstallColormap(
    Display* ,
    Colormap
extern KeyCode XKeysymToKeycode(
    Display* ,
    KeySym
extern int XKillClient(
    Display* ,
    XID
extern int XLookupColor(
    Display* ,
    Colormap ,
    const char* ,
    XColor* ,
    XColor*
extern int XLowerWindow(
    Display* ,
    Window
extern int XMapRaised(
    Display* ,
    Window
extern int XMapSubwindows(
    Display* ,
    Window
extern int XMapWindow(
    Display* ,
    Window
extern int XMaskEvent(
    Display* ,
    long ,
    XEvent*
extern int XMaxCmapsOfScreen(
    Screen*
extern int XMinCmapsOfScreen(
    Screen*
extern int XMoveResizeWindow(
    Display* ,
    Window ,
    int ,
    int ,
    unsigned int ,
    unsigned int
extern int XMoveWindow(
    Display* ,
    Window ,
    int ,
    int
extern int XNextEvent(
    Display* ,
    XEvent*
extern int XNoOp(
    Display*
extern int XParseColor(
    Display* ,
    Colormap ,
    const char* ,
    XColor*
extern int XParseGeometry(
    const char* ,
    int* ,
    int* ,
    unsigned int* ,
    unsigned int*
extern int XPeekEvent(
    Display* ,
    XEvent*
extern int XPeekIfEvent(
    Display* ,
    XEvent* ,
    int (*) (
        Display* ,
               XEvent* ,
               XPointer
    XPointer
extern int XPending(
    Display*
extern int XPlanesOfScreen(
    Screen*
extern int XProtocolRevision(
    Display*
extern int XProtocolVersion(
    Display*
extern int XPutBackEvent(
    Display* ,
    XEvent*
extern int XPutImage(
    Display* ,
    Drawable ,
    GC ,
    XImage* ,
    int ,
    int ,
    int ,
    int ,
    unsigned int ,
    unsigned int
extern int XQLength(
    Display*
extern int XQueryBestCursor(
    Display* ,
    Drawable ,
    unsigned int ,
    unsigned int ,
    unsigned int* ,
    unsigned int*
extern int XQueryBestSize(
    Display* ,
    int ,
    Drawable ,
    unsigned int ,
    unsigned int ,
    unsigned int* ,
    unsigned int*
extern int XQueryBestStipple(
    Display* ,
    Drawable ,
    unsigned int ,
    unsigned int ,
    unsigned int* ,
    unsigned int*
extern int XQueryBestTile(
    Display* ,
    Drawable ,
    unsigned int ,
    unsigned int ,
    unsigned int* ,
    unsigned int*
extern int XQueryColor(
    Display* ,
    Colormap ,
    XColor*
extern int XQueryColors(
    Display* ,
    Colormap ,
    XColor* ,
    int
extern int XQueryExtension(
    Display* ,
    const char* ,
    int* ,
    int* ,
    int*
extern int XQueryKeymap(
    Display* ,
    char [32]
extern int XQueryPointer(
    Display* ,
    Window ,
    Window* ,
    Window* ,
    int* ,
    int* ,
    int* ,
    int* ,
    unsigned int*
extern int XQueryTextExtents(
    Display* ,
    XID ,
    const char* ,
    int ,
    int* ,
    int* ,
    int* ,
    XCharStruct*
extern int XQueryTextExtents16(
    Display* ,
    XID ,
    const XChar2b* ,
    int ,
    int* ,
    int* ,
    int* ,
    XCharStruct*
extern int XQueryTree(
    Display* ,
    Window ,
    Window* ,
    Window* ,
    Window** ,
    unsigned int*
extern int XRaiseWindow(
    Display* ,
    Window
extern int XReadBitmapFile(
    Display* ,
    Drawable ,
    const char* ,
    unsigned int* ,
    unsigned int* ,
    Pixmap* ,
    int* ,
    int*
extern int XReadBitmapFileData(
    const char* ,
    unsigned int* ,
    unsigned int* ,
    unsigned char** ,
    int* ,
    int*
extern int XRebindKeysym(
    Display* ,
    KeySym ,
    KeySym* ,
    int ,
    int
extern int XRecolorCursor(
    Display* ,
    Cursor ,
    XColor* ,
    XColor*
extern int XRefreshKeyboardMapping(
    XMappingEvent*
extern int XRemoveFromSaveSet(
    Display* ,
    Window
extern int XRemoveHost(
    Display* ,
    XHostAddress*
extern int XRemoveHosts(
    Display* ,
    XHostAddress* ,
    int
extern int XReparentWindow(
    Display* ,
    Window ,
    Window ,
    int ,
    int
extern int XResetScreenSaver(
    Display*
extern int XResizeWindow(
    Display* ,
    Window ,
    unsigned int ,
    unsigned int
extern int XRestackWindows(
    Display* ,
    Window* ,
    int
extern int XRotateBuffers(
    Display* ,
    int
extern int XRotateWindowProperties(
    Display* ,
    Window ,
    Atom* ,
    int ,
    int
extern int XScreenCount(
    Display*
extern int XSelectInput(
    Display* ,
    Window ,
    long
extern int XSendEvent(
    Display* ,
    Window ,
    int ,
    long ,
    XEvent*
extern int XSetAccessControl(
    Display* ,
    int
extern int XSetArcMode(
    Display* ,
    GC ,
    int
extern int XSetBackground(
    Display* ,
    GC ,
    unsigned long
extern int XSetClipMask(
    Display* ,
    GC ,
    Pixmap
extern int XSetClipOrigin(
    Display* ,
    GC ,
    int ,
    int
extern int XSetClipRectangles(
    Display* ,
    GC ,
    int ,
    int ,
    XRectangle* ,
    int ,
    int
extern int XSetCloseDownMode(
    Display* ,
    int
extern int XSetCommand(
    Display* ,
    Window ,
    char** ,
    int
extern int XSetDashes(
    Display* ,
    GC ,
    int ,
    const char* ,
    int
extern int XSetFillRule(
    Display* ,
    GC ,
    int
extern int XSetFillStyle(
    Display* ,
    GC ,
    int
extern int XSetFont(
    Display* ,
    GC ,
    Font
extern int XSetFontPath(
    Display* ,
    char** ,
    int
extern int XSetForeground(
    Display* ,
    GC ,
    unsigned long
extern int XSetFunction(
    Display* ,
    GC ,
    int
extern int XSetGraphicsExposures(
    Display* ,
    GC ,
    int
extern int XSetIconName(
    Display* ,
    Window ,
    const char*
extern int XSetInputFocus(
    Display* ,
    Window ,
    int ,
    Time
extern int XSetLineAttributes(
    Display* ,
    GC ,
    unsigned int ,
    int ,
    int ,
    int
extern int XSetModifierMapping(
    Display* ,
    XModifierKeymap*
extern int XSetPlaneMask(
    Display* ,
    GC ,
    unsigned long
extern int XSetPointerMapping(
    Display* ,
    int
extern int XSetScreenSaver(
    Display* ,
    int ,
    int ,
    int ,
    int
extern int XSetSelectionOwner(
    Display* ,
    Atom ,
    Window ,
    Time
extern int XSetState(
    Display* ,
    GC ,
    unsigned long ,
    unsigned long ,
    int ,
    unsigned long
extern int XSetStipple(
    Display* ,
    GC ,
    Pixmap
extern int XSetSubwindowMode(
    Display* ,
    GC ,
    int
extern int XSetTSOrigin(
    Display* ,
    GC ,
    int ,
    int
extern int XSetTile(
    Display* ,
    GC ,
    Pixmap
extern int XSetWindowBackground(
    Display* ,
    Window ,
    unsigned long
extern int XSetWindowBackgroundPixmap(
    Display* ,
    Window ,
    Pixmap
extern int XSetWindowBorder(
    Display* ,
    Window ,
    unsigned long
extern int XSetWindowBorderPixmap(
    Display* ,
    Window ,
    Pixmap
extern int XSetWindowBorderWidth(
    Display* ,
    Window ,
    unsigned int
extern int XSetWindowColormap(
    Display* ,
    Window ,
    Colormap
extern int XStoreBuffer(
    Display* ,
    const char* ,
    int ,
    int
extern int XStoreBytes(
    Display* ,
    const char* ,
    int
extern int XStoreColor(
    Display* ,
    Colormap ,
    XColor*
extern int XStoreColors(
    Display* ,
    Colormap ,
    XColor* ,
    int
extern int XStoreName(
    Display* ,
    Window ,
    const char*
extern int XStoreNamedColor(
    Display* ,
    Colormap ,
    const char* ,
    unsigned long ,
    int
extern int XSync(
    Display* ,
    int
extern int XTextExtents(
    XFontStruct* ,
    const char* ,
    int ,
    int* ,
    int* ,
    int* ,
    XCharStruct*
extern int XTextExtents16(
    XFontStruct* ,
    const XChar2b* ,
    int ,
    int* ,
    int* ,
    int* ,
    XCharStruct*
extern int XTextWidth(
    XFontStruct* ,
    const char* ,
    int
extern int XTextWidth16(
    XFontStruct* ,
    const XChar2b* ,
    int
extern int XTranslateCoordinates(
    Display* ,
    Window ,
    Window ,
    int ,
    int ,
    int* ,
    int* ,
    Window*
extern int XUndefineCursor(
    Display* ,
    Window
extern int XUngrabButton(
    Display* ,
    unsigned int ,
    unsigned int ,
    Window
extern int XUngrabKey(
    Display* ,
    int ,
    unsigned int ,
    Window
extern int XUngrabKeyboard(
    Display* ,
    Time
extern int XUngrabPointer(
    Display* ,
    Time
extern int XUngrabServer(
    Display*
extern int XUninstallColormap(
    Display* ,
    Colormap
extern int XUnloadFont(
    Display* ,
    Font
extern int XUnmapSubwindows(
    Display* ,
    Window
extern int XUnmapWindow(
    Display* ,
    Window
extern int XVendorRelease(
    Display*
extern int XWarpPointer(
    Display* ,
    Window ,
    Window ,
    int ,
    int ,
    unsigned int ,
    unsigned int ,
    int ,
    int
extern int XWidthMMOfScreen(
    Screen*
extern int XWidthOfScreen(
    Screen*
extern int XWindowEvent(
    Display* ,
    Window ,
    long ,
    XEvent*
extern int XWriteBitmapFile(
    Display* ,
    const char* ,
    Pixmap ,
    unsigned int ,
    unsigned int ,
    int ,
    int
extern int XSupportsLocale (void);
extern char *XSetLocaleModifiers(
    const char*
extern XOM XOpenOM(
    Display* ,
    struct _XrmHashBucketRec* ,
    const char* ,
    const char*
extern int XCloseOM(
    XOM
extern char *XSetOMValues(
    XOM ,
) __attribute__ ((__sentinel__(0)));
extern char *XGetOMValues(
    XOM ,
extern Display *XDisplayOfOM(
    XOM
extern char *XLocaleOfOM(
    XOM
extern XOC XCreateOC(
    XOM ,
extern void XDestroyOC(
    XOC
extern XOM XOMOfOC(
    XOC
extern char *XSetOCValues(
    XOC ,
extern char *XGetOCValues(
    XOC ,
extern XFontSet XCreateFontSet(
    Display* ,
    const char* ,
    char*** ,
    int* ,
    char**
extern void XFreeFontSet(
    Display* ,
    XFontSet
extern int XFontsOfFontSet(
    XFontSet ,
    XFontStruct*** ,
    char***
extern char *XBaseFontNameListOfFontSet(
    XFontSet
extern char *XLocaleOfFontSet(
    XFontSet
extern int XContextDependentDrawing(
    XFontSet
extern int XDirectionalDependentDrawing(
    XFontSet
extern int XContextualDrawing(
    XFontSet
extern XFontSetExtents *XExtentsOfFontSet(
    XFontSet
extern int XmbTextEscapement(
    XFontSet ,
    const char* ,
    int
extern int XwcTextEscapement(
    XFontSet ,
    const wchar_t* ,
    int
extern int Xutf8TextEscapement(
    XFontSet ,
    const char* ,
    int
extern int XmbTextExtents(
    XFontSet ,
    const char* ,
    int ,
    XRectangle* ,
    XRectangle*
extern int XwcTextExtents(
    XFontSet ,
    const wchar_t* ,
    int ,
    XRectangle* ,
    XRectangle*
extern int Xutf8TextExtents(
    XFontSet ,
    const char* ,
    int ,
    XRectangle* ,
    XRectangle*
extern int XmbTextPerCharExtents(
    XFontSet ,
    const char* ,
    int ,
    XRectangle* ,
    XRectangle* ,
    int ,
    int* ,
    XRectangle* ,
    XRectangle*
extern int XwcTextPerCharExtents(
    XFontSet ,
    const wchar_t* ,
    int ,
    XRectangle* ,
    XRectangle* ,
    int ,
    int* ,
    XRectangle* ,
    XRectangle*
extern int Xutf8TextPerCharExtents(
    XFontSet ,
    const char* ,
    int ,
    XRectangle* ,
    XRectangle* ,
    int ,
    int* ,
    XRectangle* ,
    XRectangle*
extern void XmbDrawText(
    Display* ,
    Drawable ,
    GC ,
    int ,
    int ,
    XmbTextItem* ,
    int
extern void XwcDrawText(
    Display* ,
    Drawable ,
    GC ,
    int ,
    int ,
    XwcTextItem* ,
    int
extern void Xutf8DrawText(
    Display* ,
    Drawable ,
    GC ,
    int ,
    int ,
    XmbTextItem* ,
    int
extern void XmbDrawString(
    Display* ,
    Drawable ,
    XFontSet ,
    GC ,
    int ,
    int ,
    const char* ,
    int
extern void XwcDrawString(
    Display* ,
    Drawable ,
    XFontSet ,
    GC ,
    int ,
    int ,
    const wchar_t* ,
    int
extern void Xutf8DrawString(
    Display* ,
    Drawable ,
    XFontSet ,
    GC ,
    int ,
    int ,
    const char* ,
    int
extern void XmbDrawImageString(
    Display* ,
    Drawable ,
    XFontSet ,
    GC ,
    int ,
    int ,
    const char* ,
    int
extern void XwcDrawImageString(
    Display* ,
    Drawable ,
    XFontSet ,
    GC ,
    int ,
    int ,
    const wchar_t* ,
    int
extern void Xutf8DrawImageString(
    Display* ,
    Drawable ,
    XFontSet ,
    GC ,
    int ,
    int ,
    const char* ,
    int
extern XIM XOpenIM(
    Display* ,
    char* ,
    char*
extern int XCloseIM(
    XIM
extern char *XGetIMValues(
    XIM , ...
extern char *XSetIMValues(
    XIM , ...
extern Display *XDisplayOfIM(
    XIM
extern char *XLocaleOfIM(
    XIM
extern XIC XCreateIC(
    XIM , ...
extern void XDestroyIC(
    XIC
extern void XSetICFocus(
    XIC
extern void XUnsetICFocus(
    XIC
extern wchar_t *XwcResetIC(
    XIC
extern char *XmbResetIC(
    XIC
extern char *Xutf8ResetIC(
    XIC
extern char *XSetICValues(
    XIC , ...
extern char *XGetICValues(
    XIC , ...
extern XIM XIMOfIC(
    XIC
extern int XFilterEvent(
    XEvent* ,
    Window
extern int XmbLookupString(
    XIC ,
    XKeyPressedEvent* ,
    char* ,
    int ,
    KeySym* ,
    int*
extern int XwcLookupString(
    XIC ,
    XKeyPressedEvent* ,
    wchar_t* ,
    int ,
    KeySym* ,
    int*
extern int Xutf8LookupString(
    XIC ,
    XKeyPressedEvent* ,
    char* ,
    int ,
    KeySym* ,
    int*
extern XVaNestedList XVaCreateNestedList(
    int , ...
extern int XRegisterIMInstantiateCallback(
    Display* ,
    char* ,
    char* ,
    XIDProc ,
    XPointer
extern int XUnregisterIMInstantiateCallback(
    Display* ,
    char* ,
    char* ,
    XIDProc ,
    XPointer
typedef void (*XConnectionWatchProc)(
    Display* ,
    XPointer ,
    int ,
    int ,
    XPointer*
extern int XInternalConnectionNumbers(
    Display* ,
    int** ,
    int*
extern void XProcessInternalConnection(
    Display* ,
    int
extern int XAddConnectionWatch(
    Display* ,
    XConnectionWatchProc ,
    XPointer
extern void XRemoveConnectionWatch(
    Display* ,
    XPointer
extern void XSetAuthorization(
    char * ,
    int ,
    char * ,
    int
extern int _Xmbtowc(
    wchar_t * ,
    char * ,
    int
extern int _Xwctomb(
    char * ,
    wchar_t
extern int XGetEventData(
    Display* ,
    XGenericEventCookie*
extern void XFreeEventData(
    Display* ,
Found header files ['X11/Xlib.h'] in ['/opt/mpich/include']
            Popping language C
TEST checkSharedLibrary from config.packages.X(/home/jed/petsc/config/BuildSystem/config/package.py:592)
TESTING: checkSharedLibrary from config.packages.X(config/BuildSystem/config/package.py:592)
      Popping language C
TEST alternateConfigureLibrary from config.packages.afterimage(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.afterimage(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.Triangle(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.Triangle(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.PARTY(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.PARTY(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.Numpy(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.Numpy(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.Matlab(/home/jed/petsc/config/BuildSystem/config/packages/Matlab.py:35)
TESTING: alternateConfigureLibrary from config.packages.Matlab(config/BuildSystem/config/packages/Matlab.py:35)
TEST alternateConfigureLibrary from config.packages.MatlabEngine(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.MatlabEngine(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.Mathematica(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.Mathematica(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.Chaco(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.Chaco(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.cgns(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.cgns(config/BuildSystem/config/package.py:596)
      Pushing language C
TEST configureLibrary from config.packages.MPI(/home/jed/petsc/config/BuildSystem/config/packages/MPI.py:495)
TESTING: configureLibrary from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:495)
  Calls the regular package configureLibrary and then does an additional test needed by MPI
          Checking for a functional MPI
          Checking for library in User specified root directory MPI: []
          Contents: ['lib', 'include', 'bin', 'share']
              Checking for functions [MPI_Init MPI_Comm_create] in library [] []
                Pushing language C
Successful compile:
Source:
char MPI_Init();
static void _check_MPI_Init() { MPI_Init(); }
char MPI_Comm_create();
static void _check_MPI_Comm_create() { MPI_Comm_create(); }
int main() {
_check_MPI_Init();
_check_MPI_Comm_create();;
  return 0;
                        Pushing language C
                        Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.libraries/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
                Popping language C
          Checking for headers User specified root directory MPI: ['/opt/mpich/include']
              Pushing language C
Checking for header files ['mpi.h'] in ['/opt/mpich/include']
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
# 1 "/opt/mpich/include/mpi.h" 1
# 96 "/opt/mpich/include/mpi.h"
typedef int MPI_Datatype;
# 279 "/opt/mpich/include/mpi.h"
typedef int MPI_Comm;
typedef int MPI_Group;
typedef int MPI_Win;
typedef struct ADIOI_FileD *MPI_File;
typedef int MPI_Op;
# 362 "/opt/mpich/include/mpi.h"
typedef enum MPIR_Win_flavor {
    MPI_WIN_FLAVOR_CREATE = 1,
    MPI_WIN_FLAVOR_ALLOCATE = 2,
    MPI_WIN_FLAVOR_DYNAMIC = 3,
    MPI_WIN_FLAVOR_SHARED = 4
} MPIR_Win_flavor_t;
typedef enum MPIR_Win_model {
    MPI_WIN_SEPARATE = 1,
    MPI_WIN_UNIFIED = 2
} MPIR_Win_model_t;
typedef enum MPIR_Topo_type { MPI_GRAPH=1, MPI_CART=2, MPI_DIST_GRAPH=3 } MPIR_Topo_type;
extern int * const MPI_UNWEIGHTED;
extern int * const MPI_WEIGHTS_EMPTY;
# 394 "/opt/mpich/include/mpi.h"
typedef void (MPI_Handler_function) ( MPI_Comm *, int *, ... );
typedef int (MPI_Comm_copy_attr_function)(MPI_Comm, int, void *, void *,
       void *, int *);
typedef int (MPI_Comm_delete_attr_function)(MPI_Comm, int, void *, void *);
typedef int (MPI_Type_copy_attr_function)(MPI_Datatype, int, void *, void *,
       void *, int *);
typedef int (MPI_Type_delete_attr_function)(MPI_Datatype, int, void *, void *);
typedef int (MPI_Win_copy_attr_function)(MPI_Win, int, void *, void *, void *,
      int *);
typedef int (MPI_Win_delete_attr_function)(MPI_Win, int, void *, void *);
typedef void (MPI_Comm_errhandler_function)(MPI_Comm *, int *, ...);
typedef void (MPI_File_errhandler_function)(MPI_File *, int *, ...);
typedef void (MPI_Win_errhandler_function)(MPI_Win *, int *, ...);
typedef MPI_Comm_errhandler_function MPI_Comm_errhandler_fn;
typedef MPI_File_errhandler_function MPI_File_errhandler_fn;
typedef MPI_Win_errhandler_function MPI_Win_errhandler_fn;
# 422 "/opt/mpich/include/mpi.h"
typedef int MPI_Errhandler;
# 443 "/opt/mpich/include/mpi.h"
typedef int MPI_Request;
typedef int MPI_Message;
typedef void (MPI_User_function) ( void *, void *, int *, MPI_Datatype * );
typedef int (MPI_Copy_function) ( MPI_Comm, int, void *, void *, void *, int * );
typedef int (MPI_Delete_function) ( MPI_Comm, int, void *, void * );
# 497 "/opt/mpich/include/mpi.h"
enum MPIR_Combiner_enum {
    MPI_COMBINER_NAMED = 1,
    MPI_COMBINER_DUP = 2,
    MPI_COMBINER_CONTIGUOUS = 3,
    MPI_COMBINER_VECTOR = 4,
    MPI_COMBINER_HVECTOR_INTEGER = 5,
    MPI_COMBINER_HVECTOR = 6,
    MPI_COMBINER_INDEXED = 7,
    MPI_COMBINER_HINDEXED_INTEGER = 8,
    MPI_COMBINER_HINDEXED = 9,
    MPI_COMBINER_INDEXED_BLOCK = 10,
    MPI_COMBINER_STRUCT_INTEGER = 11,
    MPI_COMBINER_STRUCT = 12,
    MPI_COMBINER_SUBARRAY = 13,
    MPI_COMBINER_DARRAY = 14,
    MPI_COMBINER_F90_REAL = 15,
    MPI_COMBINER_F90_COMPLEX = 16,
    MPI_COMBINER_F90_INTEGER = 17,
    MPI_COMBINER_RESIZED = 18,
    MPI_COMBINER_HINDEXED_BLOCK = 19
typedef int MPI_Info;
# 547 "/opt/mpich/include/mpi.h"
typedef long MPI_Aint;
typedef int MPI_Fint;
typedef long long MPI_Count;
# 566 "/opt/mpich/include/mpi.h"
typedef long long MPI_Offset;
typedef struct MPI_Status {
    int count_lo;
    int count_hi_and_cancelled;
    int MPI_SOURCE;
    int MPI_TAG;
    int MPI_ERROR;
} MPI_Status;
struct MPIR_T_enum_s;
struct MPIR_T_cvar_handle_s;
struct MPIR_T_pvar_handle_s;
struct MPIR_T_pvar_session_s;
typedef struct MPIR_T_enum_s * MPI_T_enum;
typedef struct MPIR_T_cvar_handle_s * MPI_T_cvar_handle;
typedef struct MPIR_T_pvar_handle_s * MPI_T_pvar_handle;
typedef struct MPIR_T_pvar_session_s * MPI_T_pvar_session;
extern struct MPIR_T_pvar_handle_s * const MPI_T_PVAR_ALL_HANDLES;
# 603 "/opt/mpich/include/mpi.h"
typedef enum MPIR_T_verbosity_t {
    MPIX_T_VERBOSITY_INVALID = 0,
    MPI_T_VERBOSITY_USER_BASIC = 221,
    MPI_T_VERBOSITY_USER_DETAIL,
    MPI_T_VERBOSITY_USER_ALL,
    MPI_T_VERBOSITY_TUNER_BASIC,
    MPI_T_VERBOSITY_TUNER_DETAIL,
    MPI_T_VERBOSITY_TUNER_ALL,
    MPI_T_VERBOSITY_MPIDEV_BASIC,
    MPI_T_VERBOSITY_MPIDEV_DETAIL,
    MPI_T_VERBOSITY_MPIDEV_ALL
} MPIR_T_verbosity_t;
typedef enum MPIR_T_bind_t {
    MPIX_T_BIND_INVALID = 0,
    MPI_T_BIND_NO_OBJECT = 9700,
    MPI_T_BIND_MPI_COMM,
    MPI_T_BIND_MPI_DATATYPE,
    MPI_T_BIND_MPI_ERRHANDLER,
    MPI_T_BIND_MPI_FILE,
    MPI_T_BIND_MPI_GROUP,
    MPI_T_BIND_MPI_OP,
    MPI_T_BIND_MPI_REQUEST,
    MPI_T_BIND_MPI_WIN,
    MPI_T_BIND_MPI_MESSAGE,
    MPI_T_BIND_MPI_INFO
} MPIR_T_bind_t;
typedef enum MPIR_T_scope_t {
    MPIX_T_SCOPE_INVALID = 0,
    MPI_T_SCOPE_CONSTANT = 60438,
    MPI_T_SCOPE_READONLY,
    MPI_T_SCOPE_LOCAL,
    MPI_T_SCOPE_GROUP,
    MPI_T_SCOPE_GROUP_EQ,
    MPI_T_SCOPE_ALL,
    MPI_T_SCOPE_ALL_EQ
} MPIR_T_scope_t;
typedef enum MPIR_T_pvar_class_t {
    MPIX_T_PVAR_CLASS_INVALID = 0,
    MPIR_T_PVAR_CLASS_FIRST = 240,
    MPI_T_PVAR_CLASS_STATE = MPIR_T_PVAR_CLASS_FIRST,
    MPI_T_PVAR_CLASS_LEVEL,
    MPI_T_PVAR_CLASS_SIZE,
    MPI_T_PVAR_CLASS_PERCENTAGE,
    MPI_T_PVAR_CLASS_HIGHWATERMARK,
    MPI_T_PVAR_CLASS_LOWWATERMARK,
    MPI_T_PVAR_CLASS_COUNTER,
    MPI_T_PVAR_CLASS_AGGREGATE,
    MPI_T_PVAR_CLASS_TIMER,
    MPI_T_PVAR_CLASS_GENERIC,
    MPIR_T_PVAR_CLASS_LAST,
    MPIR_T_PVAR_CLASS_NUMBER = MPIR_T_PVAR_CLASS_LAST - MPIR_T_PVAR_CLASS_FIRST
} MPIR_T_pvar_class_t;
# 725 "/opt/mpich/include/mpi.h"
extern MPI_Fint * MPI_F_STATUS_IGNORE;
extern MPI_Fint * MPI_F_STATUSES_IGNORE;
# 740 "/opt/mpich/include/mpi.h"
typedef struct {
    MPI_Fint count_lo;
    MPI_Fint count_hi_and_cancelled;
    MPI_Fint MPI_SOURCE;
    MPI_Fint MPI_TAG;
    MPI_Fint MPI_ERROR;
} MPI_F08_Status;
extern MPI_F08_Status MPIR_F08_MPI_STATUS_IGNORE_OBJ;
extern MPI_F08_Status MPIR_F08_MPI_STATUSES_IGNORE_OBJ[1];
extern int MPIR_F08_MPI_IN_PLACE;
extern int MPIR_F08_MPI_BOTTOM;
extern MPI_F08_Status *MPI_F08_STATUS_IGNORE;
extern MPI_F08_Status *MPI_F08_STATUSES_IGNORE;
# 764 "/opt/mpich/include/mpi.h"
typedef int (MPI_Grequest_cancel_function)(void *, int);
typedef int (MPI_Grequest_free_function)(void *);
typedef int (MPI_Grequest_query_function)(void *, MPI_Status *);
typedef int (MPIX_Grequest_poll_function)(void *, MPI_Status *);
typedef int (MPIX_Grequest_wait_function)(int, void **, double, MPI_Status *);
# 892 "/opt/mpich/include/mpi.h"
typedef int (MPI_Datarep_conversion_function)(void *, MPI_Datatype, int,
             void *, MPI_Offset, void *);
typedef int (MPI_Datarep_extent_function)(MPI_Datatype datatype, MPI_Aint *,
                      void *);
# 912 "/opt/mpich/include/mpi.h"
int MPI_Send(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
             MPI_Comm comm) ;
int MPI_Recv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
             MPI_Comm comm, MPI_Status *status) ;
int MPI_Get_count(const MPI_Status *status, MPI_Datatype datatype, int *count);
int MPI_Bsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int MPI_Ssend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int MPI_Rsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int MPI_Buffer_attach(void *buffer, int size);
int MPI_Buffer_detach(void *buffer_addr, int *size);
int MPI_Isend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm, MPI_Request *request) ;
int MPI_Ibsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Issend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Irsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int MPI_Wait(MPI_Request *request, MPI_Status *status);
int MPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
int MPI_Request_free(MPI_Request *request);
int MPI_Waitany(int count, MPI_Request array_of_requests[], int *indx, MPI_Status *status);
int MPI_Testany(int count, MPI_Request array_of_requests[], int *indx, int *flag,
int MPI_Waitall(int count, MPI_Request array_of_requests[], MPI_Status array_of_statuses[]);
int MPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
int MPI_Waitsome(int incount, MPI_Request array_of_requests[], int *outcount,
                 int array_of_indices[], MPI_Status array_of_statuses[]);
int MPI_Testsome(int incount, MPI_Request array_of_requests[], int *outcount,
int MPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag, MPI_Status *status);
int MPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
int MPI_Cancel(MPI_Request *request);
int MPI_Test_cancelled(const MPI_Status *status, int *flag);
int MPI_Send_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Bsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Ssend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Rsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int MPI_Start(MPI_Request *request);
int MPI_Startall(int count, MPI_Request array_of_requests[]);
int MPI_Sendrecv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, int dest,
                 int sendtag, void *recvbuf, int recvcount, MPI_Datatype recvtype,
                 int source, int recvtag, MPI_Comm comm, MPI_Status *status)
int MPI_Sendrecv_replace(void *buf, int count, MPI_Datatype datatype, int dest,
                         int sendtag, int source, int recvtag, MPI_Comm comm,
int MPI_Type_contiguous(int count, MPI_Datatype oldtype, MPI_Datatype *newtype);
int MPI_Type_vector(int count, int blocklength, int stride, MPI_Datatype oldtype,
int MPI_Type_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int MPI_Type_indexed(int count, const int *array_of_blocklengths,
                     const int *array_of_displacements, MPI_Datatype oldtype,
int MPI_Type_hindexed(int count, const int *array_of_blocklengths,
                      const MPI_Aint *array_of_displacements, MPI_Datatype oldtype,
int MPI_Type_struct(int count, const int *array_of_blocklengths,
                    const MPI_Datatype *array_of_types, MPI_Datatype *newtype);
int MPI_Address(const void *location, MPI_Aint *address);
int MPI_Type_extent(MPI_Datatype datatype, MPI_Aint *extent);
int MPI_Type_size(MPI_Datatype datatype, int *size);
int MPI_Type_lb(MPI_Datatype datatype, MPI_Aint *displacement);
int MPI_Type_ub(MPI_Datatype datatype, MPI_Aint *displacement);
int MPI_Type_commit(MPI_Datatype *datatype);
int MPI_Type_free(MPI_Datatype *datatype);
int MPI_Get_elements(const MPI_Status *status, MPI_Datatype datatype, int *count);
int MPI_Pack(const void *inbuf, int incount, MPI_Datatype datatype, void *outbuf,
             int outsize, int *position, MPI_Comm comm) ;
int MPI_Unpack(const void *inbuf, int insize, int *position, void *outbuf, int outcount,
               MPI_Datatype datatype, MPI_Comm comm) ;
int MPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm, int *size);
int MPI_Barrier(MPI_Comm comm);
int MPI_Bcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm)
int MPI_Gather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
               int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm)
int MPI_Gatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                const int *recvcounts, const int *displs, MPI_Datatype recvtype, int root,
                MPI_Comm comm)
int MPI_Scatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Scatterv(const void *sendbuf, const int *sendcounts, const int *displs,
                 MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype,
int MPI_Allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                  int recvcount, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                   const int *recvcounts, const int *displs, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Alltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls,
                  MPI_Datatype sendtype, void *recvbuf, const int *recvcounts,
                  const int *rdispls, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Alltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
                  const MPI_Datatype sendtypes[], void *recvbuf, const int recvcounts[],
                  const int rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm);
int MPI_Exscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
               MPI_Op op, MPI_Comm comm)
int MPI_Reduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
               MPI_Op op, int root, MPI_Comm comm)
int MPI_Op_create(MPI_User_function *user_fn, int commute, MPI_Op *op);
int MPI_Op_free(MPI_Op *op);
int MPI_Allreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int MPI_Reduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
                       MPI_Datatype datatype, MPI_Op op, MPI_Comm comm)
int MPI_Scan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
             MPI_Comm comm)
int MPI_Group_size(MPI_Group group, int *size);
int MPI_Group_rank(MPI_Group group, int *rank);
int MPI_Group_translate_ranks(MPI_Group group1, int n, const int ranks1[], MPI_Group group2,
                              int ranks2[]);
int MPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
int MPI_Comm_group(MPI_Comm comm, MPI_Group *group);
int MPI_Group_union(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int MPI_Group_intersection(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int MPI_Group_difference(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int MPI_Group_incl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int MPI_Group_excl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int MPI_Group_range_incl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int MPI_Group_range_excl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int MPI_Group_free(MPI_Group *group);
int MPI_Comm_size(MPI_Comm comm, int *size);
int MPI_Comm_rank(MPI_Comm comm, int *rank);
int MPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
int MPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
int MPI_Comm_dup_with_info(MPI_Comm comm, MPI_Info info, MPI_Comm *newcomm);
int MPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
int MPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
int MPI_Comm_free(MPI_Comm *comm);
int MPI_Comm_test_inter(MPI_Comm comm, int *flag);
int MPI_Comm_remote_size(MPI_Comm comm, int *size);
int MPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
int MPI_Intercomm_create(MPI_Comm local_comm, int local_leader, MPI_Comm peer_comm,
                         int remote_leader, int tag, MPI_Comm *newintercomm);
int MPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm);
int MPI_Keyval_create(MPI_Copy_function *copy_fn, MPI_Delete_function *delete_fn,
                      int *keyval, void *extra_state);
int MPI_Keyval_free(int *keyval);
int MPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val);
int MPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag);
int MPI_Attr_delete(MPI_Comm comm, int keyval);
int MPI_Topo_test(MPI_Comm comm, int *status);
int MPI_Cart_create(MPI_Comm comm_old, int ndims, const int dims[], const int periods[],
                    int reorder, MPI_Comm *comm_cart);
int MPI_Dims_create(int nnodes, int ndims, int dims[]);
int MPI_Graph_create(MPI_Comm comm_old, int nnodes, const int indx[], const int edges[],
                     int reorder, MPI_Comm *comm_graph);
int MPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
int MPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges, int indx[], int edges[]);
int MPI_Cartdim_get(MPI_Comm comm, int *ndims);
int MPI_Cart_get(MPI_Comm comm, int maxdims, int dims[], int periods[], int coords[]);
int MPI_Cart_rank(MPI_Comm comm, const int coords[], int *rank);
int MPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int coords[]);
int MPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
int MPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors, int neighbors[]);
int MPI_Cart_shift(MPI_Comm comm, int direction, int disp, int *rank_source, int *rank_dest);
int MPI_Cart_sub(MPI_Comm comm, const int remain_dims[], MPI_Comm *newcomm);
int MPI_Cart_map(MPI_Comm comm, int ndims, const int dims[], const int periods[], int *newrank);
int MPI_Graph_map(MPI_Comm comm, int nnodes, const int indx[], const int edges[], int *newrank);
int MPI_Get_processor_name(char *name, int *resultlen);
int MPI_Get_version(int *version, int *subversion);
int MPI_Get_library_version(char *version, int *resultlen);
int MPI_Errhandler_create(MPI_Handler_function *function, MPI_Errhandler *errhandler);
int MPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler);
int MPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler);
int MPI_Errhandler_free(MPI_Errhandler *errhandler);
int MPI_Error_string(int errorcode, char *string, int *resultlen);
int MPI_Error_class(int errorcode, int *errorclass);
double MPI_Wtime(void);
double MPI_Wtick(void);
int MPI_Init(int *argc, char ***argv);
int MPI_Finalize(void);
int MPI_Initialized(int *flag);
int MPI_Abort(MPI_Comm comm, int errorcode);
int MPI_Pcontrol(const int level, ...);
int MPIR_Dup_fn(MPI_Comm oldcomm, int keyval, void *extra_state, void *attribute_val_in,
               void *attribute_val_out, int *flag);
int MPI_Close_port(const char *port_name);
int MPI_Comm_accept(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                    MPI_Comm *newcomm);
int MPI_Comm_connect(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                     MPI_Comm *newcomm);
int MPI_Comm_disconnect(MPI_Comm *comm);
int MPI_Comm_get_parent(MPI_Comm *parent);
int MPI_Comm_join(int fd, MPI_Comm *intercomm);
int MPI_Comm_spawn(const char *command, char *argv[], int maxprocs, MPI_Info info, int root,
                   MPI_Comm comm, MPI_Comm *intercomm, int array_of_errcodes[]);
int MPI_Comm_spawn_multiple(int count, char *array_of_commands[], char **array_of_argv[],
                            const int array_of_maxprocs[], const MPI_Info array_of_info[],
                            int root, MPI_Comm comm, MPI_Comm *intercomm, int array_of_errcodes[]);
int MPI_Lookup_name(const char *service_name, MPI_Info info, char *port_name);
int MPI_Open_port(MPI_Info info, char *port_name);
int MPI_Publish_name(const char *service_name, MPI_Info info, const char *port_name);
int MPI_Unpublish_name(const char *service_name, MPI_Info info, const char *port_name);
int MPI_Comm_set_info(MPI_Comm comm, MPI_Info info);
int MPI_Comm_get_info(MPI_Comm comm, MPI_Info *info);
int MPI_Accumulate(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
                   int target_rank, MPI_Aint target_disp, int target_count,
                   MPI_Datatype target_datatype, MPI_Op op, MPI_Win win)
int MPI_Get(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
            MPI_Datatype target_datatype, MPI_Win win) ;
int MPI_Put(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int MPI_Win_complete(MPI_Win win);
int MPI_Win_create(void *base, MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
                   MPI_Win *win);
int MPI_Win_fence(int assert, MPI_Win win);
int MPI_Win_free(MPI_Win *win);
int MPI_Win_get_group(MPI_Win win, MPI_Group *group);
int MPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
int MPI_Win_post(MPI_Group group, int assert, MPI_Win win);
int MPI_Win_start(MPI_Group group, int assert, MPI_Win win);
int MPI_Win_test(MPI_Win win, int *flag);
int MPI_Win_unlock(int rank, MPI_Win win);
int MPI_Win_wait(MPI_Win win);
int MPI_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm, void *baseptr,
                     MPI_Win *win);
int MPI_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
                            void *baseptr, MPI_Win *win);
int MPI_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
int MPI_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
int MPI_Win_attach(MPI_Win win, void *base, MPI_Aint size);
int MPI_Win_detach(MPI_Win win, const void *base);
int MPI_Win_get_info(MPI_Win win, MPI_Info *info_used);
int MPI_Win_set_info(MPI_Win win, MPI_Info info);
int MPI_Get_accumulate(const void *origin_addr, int origin_count,
                        MPI_Datatype origin_datatype, void *result_addr, int result_count,
                        MPI_Datatype result_datatype, int target_rank, MPI_Aint target_disp,
                        int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win)
int MPI_Fetch_and_op(const void *origin_addr, void *result_addr,
                      MPI_Datatype datatype, int target_rank, MPI_Aint target_disp,
int MPI_Compare_and_swap(const void *origin_addr, const void *compare_addr,
                          void *result_addr, MPI_Datatype datatype, int target_rank,
                          MPI_Aint target_disp, MPI_Win win)
int MPI_Rput(const void *origin_addr, int origin_count,
              MPI_Datatype origin_datatype, int target_rank, MPI_Aint target_disp,
              int target_count, MPI_Datatype target_datatype, MPI_Win win,
int MPI_Rget(void *origin_addr, int origin_count,
int MPI_Raccumulate(const void *origin_addr, int origin_count,
                     int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win,
int MPI_Rget_accumulate(const void *origin_addr, int origin_count,
int MPI_Win_lock_all(int assert, MPI_Win win);
int MPI_Win_unlock_all(MPI_Win win);
int MPI_Win_flush(int rank, MPI_Win win);
int MPI_Win_flush_all(MPI_Win win);
int MPI_Win_flush_local(int rank, MPI_Win win);
int MPI_Win_flush_local_all(MPI_Win win);
int MPI_Win_sync(MPI_Win win);
int MPI_Add_error_class(int *errorclass);
int MPI_Add_error_code(int errorclass, int *errorcode);
int MPI_Add_error_string(int errorcode, const char *string);
int MPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
int MPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
                           MPI_Comm_delete_attr_function *comm_delete_attr_fn, int *comm_keyval,
                           void *extra_state);
int MPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
int MPI_Comm_free_keyval(int *comm_keyval);
int MPI_Comm_get_attr(MPI_Comm comm, int comm_keyval, void *attribute_val, int *flag);
int MPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
int MPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
int MPI_Comm_set_name(MPI_Comm comm, const char *comm_name);
int MPI_File_call_errhandler(MPI_File fh, int errorcode);
int MPI_Grequest_complete(MPI_Request request);
int MPI_Grequest_start(MPI_Grequest_query_function *query_fn, MPI_Grequest_free_function *free_fn,
                       MPI_Grequest_cancel_function *cancel_fn, void *extra_state,
int MPI_Init_thread(int *argc, char ***argv, int required, int *provided);
int MPI_Is_thread_main(int *flag);
int MPI_Query_thread(int *provided);
int MPI_Status_set_cancelled(MPI_Status *status, int flag);
int MPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype, int count);
int MPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
                           MPI_Type_delete_attr_function *type_delete_attr_fn,
                           int *type_keyval, void *extra_state);
int MPI_Type_delete_attr(MPI_Datatype datatype, int type_keyval);
int MPI_Type_dup(MPI_Datatype oldtype, MPI_Datatype *newtype);
int MPI_Type_free_keyval(int *type_keyval);
int MPI_Type_get_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val, int *flag);
int MPI_Type_get_contents(MPI_Datatype datatype, int max_integers, int max_addresses,
                          int max_datatypes, int array_of_integers[],
                          MPI_Aint array_of_addresses[], MPI_Datatype array_of_datatypes[]);
int MPI_Type_get_envelope(MPI_Datatype datatype, int *num_integers, int *num_addresses,
                          int *num_datatypes, int *combiner);
int MPI_Type_get_name(MPI_Datatype datatype, char *type_name, int *resultlen);
int MPI_Type_set_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val);
int MPI_Type_set_name(MPI_Datatype datatype, const char *type_name);
int MPI_Type_match_size(int typeclass, int size, MPI_Datatype *datatype);
int MPI_Win_call_errhandler(MPI_Win win, int errorcode);
int MPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
                          MPI_Win_delete_attr_function *win_delete_attr_fn, int *win_keyval,
                          void *extra_state);
int MPI_Win_delete_attr(MPI_Win win, int win_keyval);
int MPI_Win_free_keyval(int *win_keyval);
int MPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val, int *flag);
int MPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
int MPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
int MPI_Win_set_name(MPI_Win win, const char *win_name);
int MPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr);
int MPI_Comm_create_errhandler(MPI_Comm_errhandler_function *comm_errhandler_fn,
int MPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *errhandler);
int MPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
int MPI_File_create_errhandler(MPI_File_errhandler_function *file_errhandler_fn,
int MPI_File_get_errhandler(MPI_File file, MPI_Errhandler *errhandler);
int MPI_File_set_errhandler(MPI_File file, MPI_Errhandler errhandler);
int MPI_Finalized(int *flag);
int MPI_Free_mem(void *base);
int MPI_Get_address(const void *location, MPI_Aint *address);
int MPI_Info_create(MPI_Info *info);
int MPI_Info_delete(MPI_Info info, const char *key);
int MPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
int MPI_Info_free(MPI_Info *info);
int MPI_Info_get(MPI_Info info, const char *key, int valuelen, char *value, int *flag);
int MPI_Info_get_nkeys(MPI_Info info, int *nkeys);
int MPI_Info_get_nthkey(MPI_Info info, int n, char *key);
int MPI_Info_get_valuelen(MPI_Info info, const char *key, int *valuelen, int *flag);
int MPI_Info_set(MPI_Info info, const char *key, const char *value);
int MPI_Pack_external(const char datarep[], const void *inbuf, int incount,
                      MPI_Datatype datatype, void *outbuf, MPI_Aint outsize, MPI_Aint *position)
int MPI_Pack_external_size(const char datarep[], int incount, MPI_Datatype datatype,
                           MPI_Aint *size);
int MPI_Request_get_status(MPI_Request request, int *flag, MPI_Status *status);
int MPI_Status_c2f(const MPI_Status *c_status, MPI_Fint *f_status);
int MPI_Status_f2c(const MPI_Fint *f_status, MPI_Status *c_status);
int MPI_Type_create_darray(int size, int rank, int ndims, const int array_of_gsizes[],
                           const int array_of_distribs[], const int array_of_dargs[],
                           const int array_of_psizes[], int order, MPI_Datatype oldtype,
int MPI_Type_create_hindexed(int count, const int array_of_blocklengths[],
                             const MPI_Aint array_of_displacements[], MPI_Datatype oldtype,
int MPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int MPI_Type_create_indexed_block(int count, int blocklength, const int array_of_displacements[],
int MPI_Type_create_hindexed_block(int count, int blocklength,
int MPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb, MPI_Aint extent,
int MPI_Type_create_struct(int count, const int array_of_blocklengths[],
                           const MPI_Datatype array_of_types[], MPI_Datatype *newtype);
int MPI_Type_create_subarray(int ndims, const int array_of_sizes[],
                             const int array_of_subsizes[], const int array_of_starts[],
                             int order, MPI_Datatype oldtype, MPI_Datatype *newtype);
int MPI_Type_get_extent(MPI_Datatype datatype, MPI_Aint *lb, MPI_Aint *extent);
int MPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb, MPI_Aint *true_extent);
int MPI_Unpack_external(const char datarep[], const void *inbuf, MPI_Aint insize,
                        MPI_Aint *position, void *outbuf, int outcount, MPI_Datatype datatype)
int MPI_Win_create_errhandler(MPI_Win_errhandler_function *win_errhandler_fn,
int MPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
int MPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
int MPI_Type_create_f90_integer(int range, MPI_Datatype *newtype);
int MPI_Type_create_f90_real(int precision, int range, MPI_Datatype *newtype);
int MPI_Type_create_f90_complex(int precision, int range, MPI_Datatype *newtype);
int MPI_Reduce_local(const void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype,
                     MPI_Op op)
int MPI_Op_commutative(MPI_Op op, int *commute);
int MPI_Reduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int MPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree, const int sources[],
                                   const int sourceweights[], int outdegree,
                                   const int destinations[], const int destweights[],
                                   MPI_Info info, int reorder, MPI_Comm *comm_dist_graph);
int MPI_Dist_graph_create(MPI_Comm comm_old, int n, const int sources[], const int degrees[],
                          const int destinations[], const int weights[], MPI_Info info,
int MPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
int MPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int sources[], int sourceweights[],
                             int maxoutdegree, int destinations[], int destweights[]);
int MPI_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPI_Message *message,
int MPI_Imrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int MPI_Mprobe(int source, int tag, MPI_Comm comm, MPI_Message *message, MPI_Status *status);
int MPI_Mrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int MPI_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
int MPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
int MPI_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm,
int MPI_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm,
int MPI_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                 const int recvcounts[], const int displs[], MPI_Datatype recvtype, int root,
int MPI_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Iscatterv(const void *sendbuf, const int sendcounts[], const int displs[],
                  int root, MPI_Comm comm, MPI_Request *request)
int MPI_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                   int recvcount, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)
int MPI_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Ialltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
                   MPI_Datatype sendtype, void *recvbuf, const int recvcounts[],
                   const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm,
int MPI_Ialltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
                   const int rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm,
int MPI_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
                MPI_Op op, int root, MPI_Comm comm, MPI_Request *request)
int MPI_Iallreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
                   MPI_Op op, MPI_Comm comm, MPI_Request *request)
int MPI_Ireduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
                        MPI_Datatype datatype, MPI_Op op, MPI_Comm comm, MPI_Request *request)
int MPI_Ireduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int MPI_Iscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
int MPI_Iexscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int MPI_Ineighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Ineighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
                             void *recvbuf, const int recvcounts[], const int displs[],
int MPI_Ineighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
                           void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm,
int MPI_Ineighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int MPI_Ineighbor_alltoallw(const void *sendbuf, const int sendcounts[],
                            const MPI_Aint sdispls[], const MPI_Datatype sendtypes[],
                            void *recvbuf, const int recvcounts[], const MPI_Aint rdispls[],
                            const MPI_Datatype recvtypes[], MPI_Comm comm, MPI_Request *request);
int MPI_Neighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
                           void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Neighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Neighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Neighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
                           const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Neighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[],
                           const MPI_Aint rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm);
int MPI_Comm_split_type(MPI_Comm comm, int split_type, int key, MPI_Info info, MPI_Comm *newcomm);
int MPI_Get_elements_x(const MPI_Status *status, MPI_Datatype datatype, MPI_Count *count);
int MPI_Status_set_elements_x(MPI_Status *status, MPI_Datatype datatype, MPI_Count count);
int MPI_Type_get_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int MPI_Type_get_true_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int MPI_Type_size_x(MPI_Datatype datatype, MPI_Count *size);
int MPI_Comm_create_group(MPI_Comm comm, MPI_Group group, int tag, MPI_Comm *newcomm);
int MPI_T_init_thread(int required, int *provided);
int MPI_T_finalize(void);
int MPI_T_enum_get_info(MPI_T_enum enumtype, int *num, char *name, int *name_len);
int MPI_T_enum_get_item(MPI_T_enum enumtype, int indx, int *value, char *name, int *name_len);
int MPI_T_cvar_get_num(int *num_cvar);
int MPI_T_cvar_get_info(int cvar_index, char *name, int *name_len, int *verbosity,
                        MPI_Datatype *datatype, MPI_T_enum *enumtype, char *desc, int *desc_len,
                        int *binding, int *scope);
int MPI_T_cvar_handle_alloc(int cvar_index, void *obj_handle, MPI_T_cvar_handle *handle,
                            int *count);
int MPI_T_cvar_handle_free(MPI_T_cvar_handle *handle);
int MPI_T_cvar_read(MPI_T_cvar_handle handle, void *buf);
int MPI_T_cvar_write(MPI_T_cvar_handle handle, const void *buf);
int MPI_T_pvar_get_num(int *num_pvar);
int MPI_T_pvar_get_info(int pvar_index, char *name, int *name_len, int *verbosity, int *var_class,
                        int *binding, int *readonly, int *continuous, int *atomic);
int MPI_T_pvar_session_create(MPI_T_pvar_session *session);
int MPI_T_pvar_session_free(MPI_T_pvar_session *session);
int MPI_T_pvar_handle_alloc(MPI_T_pvar_session session, int pvar_index, void *obj_handle,
                            MPI_T_pvar_handle *handle, int *count);
int MPI_T_pvar_handle_free(MPI_T_pvar_session session, MPI_T_pvar_handle *handle);
int MPI_T_pvar_start(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int MPI_T_pvar_stop(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int MPI_T_pvar_read(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int MPI_T_pvar_write(MPI_T_pvar_session session, MPI_T_pvar_handle handle, const void *buf);
int MPI_T_pvar_reset(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int MPI_T_pvar_readreset(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int MPI_T_category_get_num(int *num_cat);
int MPI_T_category_get_info(int cat_index, char *name, int *name_len, char *desc, int *desc_len,
                            int *num_cvars, int *num_pvars, int *num_categories);
int MPI_T_category_get_cvars(int cat_index, int len, int indices[]);
int MPI_T_category_get_pvars(int cat_index, int len, int indices[]);
int MPI_T_category_get_categories(int cat_index, int len, int indices[]);
int MPI_T_category_changed(int *stamp);
int MPIX_Comm_failure_ack(MPI_Comm comm);
int MPIX_Comm_failure_get_acked(MPI_Comm comm, MPI_Group *failedgrp);
int MPIX_Comm_revoke(MPI_Comm comm);
int MPIX_Comm_shrink(MPI_Comm comm, MPI_Comm *newcomm);
int MPIX_Comm_agree(MPI_Comm comm, int *flag);
# 1551 "/opt/mpich/include/mpi.h"
int PMPI_Send(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int PMPI_Recv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int PMPI_Get_count(const MPI_Status *status, MPI_Datatype datatype, int *count);
int PMPI_Bsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
               MPI_Comm comm) ;
int PMPI_Ssend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
               MPI_Comm comm) ;
int PMPI_Rsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
               MPI_Comm comm) ;
int PMPI_Buffer_attach(void *buffer, int size);
int PMPI_Buffer_detach(void *buffer_addr, int *size);
int PMPI_Isend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Ibsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Issend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Irsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int PMPI_Wait(MPI_Request *request, MPI_Status *status);
int PMPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
int PMPI_Request_free(MPI_Request *request);
int PMPI_Waitany(int count, MPI_Request array_of_requests[], int *indx, MPI_Status *status);
int PMPI_Testany(int count, MPI_Request array_of_requests[], int *indx, int *flag,
int PMPI_Waitall(int count, MPI_Request array_of_requests[], MPI_Status array_of_statuses[]);
int PMPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
int PMPI_Waitsome(int incount, MPI_Request array_of_requests[], int *outcount,
int PMPI_Testsome(int incount, MPI_Request array_of_requests[], int *outcount,
int PMPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag, MPI_Status *status);
int PMPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
int PMPI_Cancel(MPI_Request *request);
int PMPI_Test_cancelled(const MPI_Status *status, int *flag);
int PMPI_Send_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Bsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Ssend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Rsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int PMPI_Start(MPI_Request *request);
int PMPI_Startall(int count, MPI_Request array_of_requests[]);
int PMPI_Sendrecv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, int dest,
int PMPI_Sendrecv_replace(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Type_contiguous(int count, MPI_Datatype oldtype, MPI_Datatype *newtype);
int PMPI_Type_vector(int count, int blocklength, int stride, MPI_Datatype oldtype,
int PMPI_Type_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int PMPI_Type_indexed(int count, const int *array_of_blocklengths,
int PMPI_Type_hindexed(int count, const int *array_of_blocklengths,
int PMPI_Type_struct(int count, const int *array_of_blocklengths,
int PMPI_Address(const void *location, MPI_Aint *address);
int PMPI_Type_extent(MPI_Datatype datatype, MPI_Aint *extent);
int PMPI_Type_size(MPI_Datatype datatype, int *size);
int PMPI_Type_lb(MPI_Datatype datatype, MPI_Aint *displacement);
int PMPI_Type_ub(MPI_Datatype datatype, MPI_Aint *displacement);
int PMPI_Type_commit(MPI_Datatype *datatype);
int PMPI_Type_free(MPI_Datatype *datatype);
int PMPI_Get_elements(const MPI_Status *status, MPI_Datatype datatype, int *count);
int PMPI_Pack(const void *inbuf, int incount, MPI_Datatype datatype, void *outbuf,
int PMPI_Unpack(const void *inbuf, int insize, int *position, void *outbuf, int outcount,
int PMPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm, int *size);
int PMPI_Barrier(MPI_Comm comm);
int PMPI_Bcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm)
int PMPI_Gather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Gatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                 MPI_Comm comm)
int PMPI_Scatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Scatterv(const void *sendbuf, const int *sendcounts, const int *displs,
int PMPI_Allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Alltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls,
int PMPI_Alltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Exscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Reduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Op_create(MPI_User_function *user_fn, int commute, MPI_Op *op);
int PMPI_Op_free(MPI_Op *op);
int PMPI_Allreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Reduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
int PMPI_Scan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
              MPI_Comm comm)
int PMPI_Group_size(MPI_Group group, int *size);
int PMPI_Group_rank(MPI_Group group, int *rank);
int PMPI_Group_translate_ranks(MPI_Group group1, int n, const int ranks1[], MPI_Group group2,
                               int ranks2[]);
int PMPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
int PMPI_Comm_group(MPI_Comm comm, MPI_Group *group);
int PMPI_Group_union(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int PMPI_Group_intersection(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int PMPI_Group_difference(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int PMPI_Group_incl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int PMPI_Group_excl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int PMPI_Group_range_incl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int PMPI_Group_range_excl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int PMPI_Group_free(MPI_Group *group);
int PMPI_Comm_size(MPI_Comm comm, int *size);
int PMPI_Comm_rank(MPI_Comm comm, int *rank);
int PMPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
int PMPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
int PMPI_Comm_dup_with_info(MPI_Comm comm, MPI_Info info, MPI_Comm *newcomm);
int PMPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
int PMPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
int PMPI_Comm_free(MPI_Comm *comm);
int PMPI_Comm_test_inter(MPI_Comm comm, int *flag);
int PMPI_Comm_remote_size(MPI_Comm comm, int *size);
int PMPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
int PMPI_Intercomm_create(MPI_Comm local_comm, int local_leader, MPI_Comm peer_comm,
int PMPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm);
int PMPI_Keyval_create(MPI_Copy_function *copy_fn, MPI_Delete_function *delete_fn,
int PMPI_Keyval_free(int *keyval);
int PMPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val);
int PMPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag);
int PMPI_Attr_delete(MPI_Comm comm, int keyval);
int PMPI_Topo_test(MPI_Comm comm, int *status);
int PMPI_Cart_create(MPI_Comm comm_old, int ndims, const int dims[], const int periods[],
int PMPI_Dims_create(int nnodes, int ndims, int dims[]);
int PMPI_Graph_create(MPI_Comm comm_old, int nnodes, const int indx[], const int edges[],
int PMPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
int PMPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges, int indx[], int edges[]);
int PMPI_Cartdim_get(MPI_Comm comm, int *ndims);
int PMPI_Cart_get(MPI_Comm comm, int maxdims, int dims[], int periods[], int coords[]);
int PMPI_Cart_rank(MPI_Comm comm, const int coords[], int *rank);
int PMPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int coords[]);
int PMPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
int PMPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors, int neighbors[]);
int PMPI_Cart_shift(MPI_Comm comm, int direction, int disp, int *rank_source, int *rank_dest);
int PMPI_Cart_sub(MPI_Comm comm, const int remain_dims[], MPI_Comm *newcomm);
int PMPI_Cart_map(MPI_Comm comm, int ndims, const int dims[], const int periods[], int *newrank);
int PMPI_Graph_map(MPI_Comm comm, int nnodes, const int indx[], const int edges[], int *newrank);
int PMPI_Get_processor_name(char *name, int *resultlen);
int PMPI_Get_version(int *version, int *subversion);
int PMPI_Get_library_version(char *version, int *resultlen);
int PMPI_Errhandler_create(MPI_Handler_function *function, MPI_Errhandler *errhandler);
int PMPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler);
int PMPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler);
int PMPI_Errhandler_free(MPI_Errhandler *errhandler);
int PMPI_Error_string(int errorcode, char *string, int *resultlen);
int PMPI_Error_class(int errorcode, int *errorclass);
double PMPI_Wtime(void);
double PMPI_Wtick(void);
int PMPI_Init(int *argc, char ***argv);
int PMPI_Finalize(void);
int PMPI_Initialized(int *flag);
int PMPI_Abort(MPI_Comm comm, int errorcode);
int PMPI_Pcontrol(const int level, ...);
int PMPI_Close_port(const char *port_name);
int PMPI_Comm_accept(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                     MPI_Comm *newcomm);
int PMPI_Comm_connect(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                      MPI_Comm *newcomm);
int PMPI_Comm_disconnect(MPI_Comm *comm);
int PMPI_Comm_get_parent(MPI_Comm *parent);
int PMPI_Comm_join(int fd, MPI_Comm *intercomm);
int PMPI_Comm_spawn(const char *command, char *argv[], int maxprocs, MPI_Info info, int root,
int PMPI_Comm_spawn_multiple(int count, char *array_of_commands[], char **array_of_argv[],
int PMPI_Lookup_name(const char *service_name, MPI_Info info, char *port_name);
int PMPI_Open_port(MPI_Info info, char *port_name);
int PMPI_Publish_name(const char *service_name, MPI_Info info, const char *port_name);
int PMPI_Unpublish_name(const char *service_name, MPI_Info info, const char *port_name);
int PMPI_Comm_set_info(MPI_Comm comm, MPI_Info info);
int PMPI_Comm_get_info(MPI_Comm comm, MPI_Info *info);
int PMPI_Accumulate(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Get(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Put(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Win_complete(MPI_Win win);
int PMPI_Win_create(void *base, MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
                    MPI_Win *win);
int PMPI_Win_fence(int assert, MPI_Win win);
int PMPI_Win_free(MPI_Win *win);
int PMPI_Win_get_group(MPI_Win win, MPI_Group *group);
int PMPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
int PMPI_Win_post(MPI_Group group, int assert, MPI_Win win);
int PMPI_Win_start(MPI_Group group, int assert, MPI_Win win);
int PMPI_Win_test(MPI_Win win, int *flag);
int PMPI_Win_unlock(int rank, MPI_Win win);
int PMPI_Win_wait(MPI_Win win);
int PMPI_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm, void *baseptr,
                      MPI_Win *win);
int PMPI_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
int PMPI_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
int PMPI_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
int PMPI_Win_attach(MPI_Win win, void *base, MPI_Aint size);
int PMPI_Win_detach(MPI_Win win, const void *base);
int PMPI_Win_get_info(MPI_Win win, MPI_Info *info_used);
int PMPI_Win_set_info(MPI_Win win, MPI_Info info);
int PMPI_Get_accumulate(const void *origin_addr, int origin_count,
int PMPI_Fetch_and_op(const void *origin_addr, void *result_addr,
int PMPI_Compare_and_swap(const void *origin_addr, const void *compare_addr,
int PMPI_Rput(const void *origin_addr, int origin_count,
int PMPI_Rget(void *origin_addr, int origin_count,
int PMPI_Raccumulate(const void *origin_addr, int origin_count,
int PMPI_Rget_accumulate(const void *origin_addr, int origin_count,
int PMPI_Win_lock_all(int assert, MPI_Win win);
int PMPI_Win_unlock_all(MPI_Win win);
int PMPI_Win_flush(int rank, MPI_Win win);
int PMPI_Win_flush_all(MPI_Win win);
int PMPI_Win_flush_local(int rank, MPI_Win win);
int PMPI_Win_flush_local_all(MPI_Win win);
int PMPI_Win_sync(MPI_Win win);
int PMPI_Add_error_class(int *errorclass);
int PMPI_Add_error_code(int errorclass, int *errorcode);
int PMPI_Add_error_string(int errorcode, const char *string);
int PMPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
int PMPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
                            void *extra_state);
int PMPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
int PMPI_Comm_free_keyval(int *comm_keyval);
int PMPI_Comm_get_attr(MPI_Comm comm, int comm_keyval, void *attribute_val, int *flag);
int PMPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
int PMPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
int PMPI_Comm_set_name(MPI_Comm comm, const char *comm_name);
int PMPI_File_call_errhandler(MPI_File fh, int errorcode);
int PMPI_Grequest_complete(MPI_Request request);
int PMPI_Grequest_start(MPI_Grequest_query_function *query_fn, MPI_Grequest_free_function *free_fn,
int PMPI_Init_thread(int *argc, char ***argv, int required, int *provided);
int PMPI_Is_thread_main(int *flag);
int PMPI_Query_thread(int *provided);
int PMPI_Status_set_cancelled(MPI_Status *status, int flag);
int PMPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype, int count);
int PMPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
int PMPI_Type_delete_attr(MPI_Datatype datatype, int type_keyval);
int PMPI_Type_dup(MPI_Datatype oldtype, MPI_Datatype *newtype);
int PMPI_Type_free_keyval(int *type_keyval);
int PMPI_Type_get_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val, int *flag);
int PMPI_Type_get_contents(MPI_Datatype datatype, int max_integers, int max_addresses,
int PMPI_Type_get_envelope(MPI_Datatype datatype, int *num_integers, int *num_addresses,
int PMPI_Type_get_name(MPI_Datatype datatype, char *type_name, int *resultlen);
int PMPI_Type_set_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val);
int PMPI_Type_set_name(MPI_Datatype datatype, const char *type_name);
int PMPI_Type_match_size(int typeclass, int size, MPI_Datatype *datatype);
int PMPI_Win_call_errhandler(MPI_Win win, int errorcode);
int PMPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
                           void *extra_state);
int PMPI_Win_delete_attr(MPI_Win win, int win_keyval);
int PMPI_Win_free_keyval(int *win_keyval);
int PMPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val, int *flag);
int PMPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
int PMPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
int PMPI_Win_set_name(MPI_Win win, const char *win_name);
int PMPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr);
int PMPI_Comm_create_errhandler(MPI_Comm_errhandler_function *comm_errhandler_fn,
int PMPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *errhandler);
int PMPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
int PMPI_File_create_errhandler(MPI_File_errhandler_function *file_errhandler_fn,
int PMPI_File_get_errhandler(MPI_File file, MPI_Errhandler *errhandler);
int PMPI_File_set_errhandler(MPI_File file, MPI_Errhandler errhandler);
int PMPI_Finalized(int *flag);
int PMPI_Free_mem(void *base);
int PMPI_Get_address(const void *location, MPI_Aint *address);
int PMPI_Info_create(MPI_Info *info);
int PMPI_Info_delete(MPI_Info info, const char *key);
int PMPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
int PMPI_Info_free(MPI_Info *info);
int PMPI_Info_get(MPI_Info info, const char *key, int valuelen, char *value, int *flag);
int PMPI_Info_get_nkeys(MPI_Info info, int *nkeys);
int PMPI_Info_get_nthkey(MPI_Info info, int n, char *key);
int PMPI_Info_get_valuelen(MPI_Info info, const char *key, int *valuelen, int *flag);
int PMPI_Info_set(MPI_Info info, const char *key, const char *value);
int PMPI_Pack_external(const char datarep[], const void *inbuf, int incount,
int PMPI_Pack_external_size(const char datarep[], int incount, MPI_Datatype datatype,
                            MPI_Aint *size);
int PMPI_Request_get_status(MPI_Request request, int *flag, MPI_Status *status);
int PMPI_Status_c2f(const MPI_Status *c_status, MPI_Fint *f_status);
int PMPI_Status_f2c(const MPI_Fint *f_status, MPI_Status *c_status);
int PMPI_Type_create_darray(int size, int rank, int ndims, const int array_of_gsizes[],
int PMPI_Type_create_hindexed(int count, const int array_of_blocklengths[],
int PMPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int PMPI_Type_create_indexed_block(int count, int blocklength, const int array_of_displacements[],
int PMPI_Type_create_hindexed_block(int count, int blocklength,
int PMPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb, MPI_Aint extent,
int PMPI_Type_create_struct(int count, const int array_of_blocklengths[],
int PMPI_Type_create_subarray(int ndims, const int array_of_sizes[],
int PMPI_Type_get_extent(MPI_Datatype datatype, MPI_Aint *lb, MPI_Aint *extent);
int PMPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb, MPI_Aint *true_extent);
int PMPI_Unpack_external(const char datarep[], const void *inbuf, MPI_Aint insize,
int PMPI_Win_create_errhandler(MPI_Win_errhandler_function *win_errhandler_fn,
int PMPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
int PMPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
int PMPI_Type_create_f90_integer(int r, MPI_Datatype *newtype);
int PMPI_Type_create_f90_real(int p, int r, MPI_Datatype *newtype);
int PMPI_Type_create_f90_complex(int p, int r, MPI_Datatype *newtype);
int PMPI_Reduce_local(const void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype,
                      MPI_Op op)
int PMPI_Op_commutative(MPI_Op op, int *commute);
int PMPI_Reduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int PMPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree, const int sources[],
int PMPI_Dist_graph_create(MPI_Comm comm_old, int n, const int sources[], const int degrees[],
int PMPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
int PMPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int sources[], int sourceweights[],
int PMPI_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPI_Message *message,
int PMPI_Imrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int PMPI_Mprobe(int source, int tag, MPI_Comm comm, MPI_Message *message, MPI_Status *status);
int PMPI_Mrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int PMPI_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
int PMPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
int PMPI_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm,
int PMPI_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Iscatterv(const void *sendbuf, const int sendcounts[], const int displs[],
int PMPI_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Ialltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Ialltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Iallreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Ireduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
int PMPI_Ireduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int PMPI_Iscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
int PMPI_Iexscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Ineighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Ineighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Ineighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Ineighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Ineighbor_alltoallw(const void *sendbuf, const int sendcounts[],
int PMPI_Neighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Neighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Neighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Neighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Neighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[],
                            MPI_Comm comm);
int PMPI_Comm_split_type(MPI_Comm comm, int split_type, int key, MPI_Info info, MPI_Comm *newcomm);
int PMPI_Comm_create_group(MPI_Comm comm, MPI_Group group, int tag, MPI_Comm *newcomm);
int PMPI_Get_elements_x(const MPI_Status *status, MPI_Datatype datatype, MPI_Count *count);
int PMPI_Status_set_elements_x(MPI_Status *status, MPI_Datatype datatype, MPI_Count count);
int PMPI_Type_get_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int PMPI_Type_get_true_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int PMPI_Type_size_x(MPI_Datatype datatype, MPI_Count *size);
int PMPI_T_init_thread(int required, int *provided);
int PMPI_T_finalize(void);
int PMPI_T_enum_get_info(MPI_T_enum enumtype, int *num, char *name, int *name_len);
int PMPI_T_enum_get_item(MPI_T_enum enumtype, int indx, int *value, char *name, int *name_len);
int PMPI_T_cvar_get_num(int *num_cvar);
int PMPI_T_cvar_get_info(int cvar_index, char *name, int *name_len, int *verbosity,
int PMPI_T_cvar_handle_alloc(int cvar_index, void *obj_handle, MPI_T_cvar_handle *handle,
                             int *count);
int PMPI_T_cvar_handle_free(MPI_T_cvar_handle *handle);
int PMPI_T_cvar_read(MPI_T_cvar_handle handle, void *buf);
int PMPI_T_cvar_write(MPI_T_cvar_handle handle, const void *buf);
int PMPI_T_pvar_get_num(int *num_pvar);
int PMPI_T_pvar_get_info(int pvar_index, char *name, int *name_len, int *verbosity, int *var_class,
int PMPI_T_pvar_session_create(MPI_T_pvar_session *session);
int PMPI_T_pvar_session_free(MPI_T_pvar_session *session);
int PMPI_T_pvar_handle_alloc(MPI_T_pvar_session session, int pvar_index, void *obj_handle,
int PMPI_T_pvar_handle_free(MPI_T_pvar_session session, MPI_T_pvar_handle *handle);
int PMPI_T_pvar_start(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int PMPI_T_pvar_stop(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int PMPI_T_pvar_read(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int PMPI_T_pvar_write(MPI_T_pvar_session session, MPI_T_pvar_handle handle, const void *buf);
int PMPI_T_pvar_reset(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int PMPI_T_pvar_readreset(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int PMPI_T_category_get_num(int *num_cat);
int PMPI_T_category_get_info(int cat_index, char *name, int *name_len, char *desc, int *desc_len,
int PMPI_T_category_get_cvars(int cat_index, int len, int indices[]);
int PMPI_T_category_get_pvars(int cat_index, int len, int indices[]);
int PMPI_T_category_get_categories(int cat_index, int len, int indices[]);
int PMPI_T_category_changed(int *stamp);
int PMPIX_Comm_failure_ack(MPI_Comm comm);
int PMPIX_Comm_failure_get_acked(MPI_Comm comm, MPI_Group *failedgrp);
int PMPIX_Comm_revoke(MPI_Comm comm);
int PMPIX_Comm_shrink(MPI_Comm comm, MPI_Comm *newcomm);
int PMPIX_Comm_agree(MPI_Comm comm, int *flag);
# 2200 "/opt/mpich/include/mpi.h"
# 1 "/opt/mpich/include/mpio.h" 1
# 13 "/opt/mpich/include/mpio.h"
# 14 "/opt/mpich/include/mpio.h" 2
# 123 "/opt/mpich/include/mpio.h"
int MPI_File_open(MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh);
int MPI_File_close(MPI_File *fh);
int MPI_File_delete(const char *filename, MPI_Info info);
int MPI_File_set_size(MPI_File fh, MPI_Offset size);
int MPI_File_preallocate(MPI_File fh, MPI_Offset size);
int MPI_File_get_size(MPI_File fh, MPI_Offset *size);
int MPI_File_get_group(MPI_File fh, MPI_Group *group);
int MPI_File_get_amode(MPI_File fh, int *amode);
int MPI_File_set_info(MPI_File fh, MPI_Info info);
int MPI_File_get_info(MPI_File fh, MPI_Info *info_used);
int MPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype,
                      const char *datarep, MPI_Info info);
int MPI_File_get_view(MPI_File fh, MPI_Offset *disp, MPI_Datatype *etype, MPI_Datatype *filetype,
                      char *datarep);
int MPI_File_read_at(MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype,
int MPI_File_read_at_all(MPI_File fh, MPI_Offset offset, void * buf, int count,
                         MPI_Datatype datatype, MPI_Status *status)
int MPI_File_write_at(MPI_File fh, MPI_Offset offset, const void * buf, int count,
int MPI_File_write_at_all(MPI_File fh, MPI_Offset offset, const void *buf, int count,
int MPI_File_iread_at(MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype,
int MPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, const void *buf, int count,
                       MPI_Datatype datatype, MPI_Request *request)
int MPI_File_read(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status)
int MPI_File_read_all(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status)
int MPI_File_write(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_write_all(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_iread(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Request *request)
int MPI_File_iwrite(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_seek(MPI_File fh, MPI_Offset offset, int whence);
int MPI_File_get_position(MPI_File fh, MPI_Offset *offset);
int MPI_File_get_byte_offset(MPI_File fh, MPI_Offset offset, MPI_Offset *disp);
int MPI_File_read_shared(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int MPI_File_write_shared(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_iread_shared(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int MPI_File_iwrite_shared(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_read_ordered(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int MPI_File_write_ordered(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_seek_shared(MPI_File fh, MPI_Offset offset, int whence);
int MPI_File_get_position_shared(MPI_File fh, MPI_Offset *offset);
int MPI_File_read_at_all_begin(MPI_File fh, MPI_Offset offset, void *buf, int count,
                               MPI_Datatype datatype) ;
int MPI_File_read_at_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, const void *buf, int count,
int MPI_File_write_at_all_end(MPI_File fh, const void *buf, MPI_Status *status);
int MPI_File_read_all_begin(MPI_File fh, void *buf, int count, MPI_Datatype datatype)
int MPI_File_read_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_all_begin(MPI_File fh, const void *buf, int count, MPI_Datatype datatype)
int MPI_File_write_all_end(MPI_File fh, const void *buf, MPI_Status *status);
int MPI_File_read_ordered_begin(MPI_File fh, void *buf, int count, MPI_Datatype datatype)
int MPI_File_read_ordered_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_ordered_begin(MPI_File fh, const void *buf, int count, MPI_Datatype datatype)
int MPI_File_write_ordered_end(MPI_File fh, const void *buf, MPI_Status *status);
int MPI_File_get_type_extent(MPI_File fh, MPI_Datatype datatype, MPI_Aint *extent);
int MPI_Register_datarep(const char *datarep, MPI_Datarep_conversion_function *read_conversion_fn,
    MPI_Datarep_conversion_function *write_conversion_fn,
    MPI_Datarep_extent_function *dtype_file_extent_fn, void *extra_state);
int MPI_File_set_atomicity(MPI_File fh, int flag);
int MPI_File_get_atomicity(MPI_File fh, int *flag);
int MPI_File_sync(MPI_File fh);
# 268 "/opt/mpich/include/mpio.h"
MPI_File MPI_File_f2c(MPI_Fint file);
MPI_Fint MPI_File_c2f(MPI_File file);
# 329 "/opt/mpich/include/mpio.h"
int PMPI_File_open(MPI_Comm, const char *, int, MPI_Info, MPI_File *);
int PMPI_File_close(MPI_File *);
int PMPI_File_delete(const char *, MPI_Info);
int PMPI_File_set_size(MPI_File, MPI_Offset);
int PMPI_File_preallocate(MPI_File, MPI_Offset);
int PMPI_File_get_size(MPI_File, MPI_Offset *);
int PMPI_File_get_group(MPI_File, MPI_Group *);
int PMPI_File_get_amode(MPI_File, int *);
int PMPI_File_set_info(MPI_File, MPI_Info);
int PMPI_File_get_info(MPI_File, MPI_Info *);
int PMPI_File_set_view(MPI_File, MPI_Offset,
    MPI_Datatype, MPI_Datatype, const char *, MPI_Info);
int PMPI_File_get_view(MPI_File, MPI_Offset *,
      MPI_Datatype *, MPI_Datatype *, char *);
int PMPI_File_read_at(MPI_File, MPI_Offset, void *,
       int, MPI_Datatype, MPI_Status *)
int PMPI_File_read_at_all(MPI_File, MPI_Offset, void *,
int PMPI_File_write_at(MPI_File, MPI_Offset, const void *,
int PMPI_File_write_at_all(MPI_File, MPI_Offset, const void *,
int PMPI_File_iread_at(MPI_File, MPI_Offset, void *,
       int, MPI_Datatype, MPI_Request *)
int PMPI_File_iwrite_at(MPI_File, MPI_Offset, const void *,
int PMPI_File_read(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_read_all(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write_all(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_iread(MPI_File, void *, int, MPI_Datatype, MPI_Request *)
int PMPI_File_iwrite(MPI_File, const void *, int, MPI_Datatype, MPI_Request *)
int PMPI_File_seek(MPI_File, MPI_Offset, int);
int PMPI_File_get_position(MPI_File, MPI_Offset *);
int PMPI_File_get_byte_offset(MPI_File, MPI_Offset, MPI_Offset *);
int PMPI_File_read_shared(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write_shared(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_iread_shared(MPI_File, void *, int,
int PMPI_File_iwrite_shared(MPI_File, const void *, int,
int PMPI_File_read_ordered(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write_ordered(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_seek_shared(MPI_File, MPI_Offset, int);
int PMPI_File_get_position_shared(MPI_File, MPI_Offset *);
int PMPI_File_read_at_all_begin(MPI_File, MPI_Offset, void *,
                               int, MPI_Datatype)
int PMPI_File_read_at_all_end(MPI_File, void *, MPI_Status *);
int PMPI_File_write_at_all_begin(MPI_File, MPI_Offset, const void *,
                                 int, MPI_Datatype)
int PMPI_File_write_at_all_end(MPI_File, const void *, MPI_Status *);
int PMPI_File_read_all_begin(MPI_File, void *, int, MPI_Datatype)
int PMPI_File_read_all_end(MPI_File, void *, MPI_Status *);
int PMPI_File_write_all_begin(MPI_File, const void *, int, MPI_Datatype)
int PMPI_File_write_all_end(MPI_File, const void *, MPI_Status *);
int PMPI_File_read_ordered_begin(MPI_File, void *, int, MPI_Datatype)
int PMPI_File_read_ordered_end(MPI_File, void *, MPI_Status *);
int PMPI_File_write_ordered_begin(MPI_File, const void *, int, MPI_Datatype)
int PMPI_File_write_ordered_end(MPI_File, const void *, MPI_Status *);
int PMPI_File_get_type_extent(MPI_File, MPI_Datatype, MPI_Aint *);
int PMPI_Register_datarep(const char *,
    MPI_Datarep_conversion_function *,
    MPI_Datarep_extent_function *,
    void *);
int PMPI_File_set_atomicity(MPI_File, int);
int PMPI_File_get_atomicity(MPI_File, int *);
int PMPI_File_sync(MPI_File);
# 467 "/opt/mpich/include/mpio.h"
MPI_File PMPI_File_f2c(MPI_Fint);
MPI_Fint PMPI_File_c2f(MPI_File);
# 2201 "/opt/mpich/include/mpi.h" 2
# 2222 "/opt/mpich/include/mpi.h"
typedef int MPIX_Grequest_class;
int MPIX_Grequest_class_create(MPI_Grequest_query_function *query_fn,
                               MPIX_Grequest_poll_function *poll_fn,
                               MPIX_Grequest_wait_function *wait_fn,
                               MPIX_Grequest_class *greq_class);
int MPIX_Grequest_class_allocate(MPIX_Grequest_class greq_class, void *extra_state,
int MPIX_Grequest_start(MPI_Grequest_query_function *query_fn,
                        MPIX_Grequest_wait_function *wait_fn, void *extra_state,
struct mpixi_mutex_s;
typedef struct mpixi_mutex_s * MPIX_Mutex;
int MPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
int MPIX_Mutex_free(MPIX_Mutex *hdl);
int MPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
int MPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
int PMPIX_Grequest_class_create(MPI_Grequest_query_function *query_fn,
int PMPIX_Grequest_class_allocate(MPIX_Grequest_class greq_class, void *extra_state,
int PMPIX_Grequest_start(MPI_Grequest_query_function *query_fn,
int PMPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
int PMPIX_Mutex_free(MPIX_Mutex *hdl);
int PMPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
int PMPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
# 3 "/tmp/petsc-lhuj9c/config.headers/conftest.c" 2
Found header files ['mpi.h'] in ['/opt/mpich/include']
              Popping language C
TEST configureConversion from config.packages.MPI(/home/jed/petsc/config/BuildSystem/config/packages/MPI.py:206)
TESTING: configureConversion from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:206)
  Check for the functions which convert communicators between C and Fortran
       - Define HAVE_MPI_COMM_F2C and HAVE_MPI_COMM_C2F if they are present
       - Some older MPI 1 implementations are missing these
                          All intermediate test results are stored in /tmp/petsc-lhuj9c/config.packages.MPI
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.packages.MPI/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.packages.MPI  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  -I/opt/mpich/include /tmp/petsc-lhuj9c/config.packages.MPI/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <mpi.h>
int main() {
if (MPI_Comm_f2c((MPI_Fint)0));
  return 0;
                      Pushing language C
                      Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.packages.MPI/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.packages.MPI/conftest.o  -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
              Defined "HAVE_MPI_COMM_F2C" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Comm_c2f(MPI_COMM_WORLD));
  return 0;
                      Pushing language C
                      Popping language C
              Defined "HAVE_MPI_COMM_C2F" to "1"
Possible ERROR while running compiler:
stderr:
/tmp/petsc-lhuj9c/config.packages.MPI/conftest.c: In function ?main?:
/tmp/petsc-lhuj9c/config.packages.MPI/conftest.c:6:10: warning: unused variable ?a? [-Wunused-variable]
 MPI_Fint a;
Source:
#include <mpi.h>
int main() {
MPI_Fint a;
  return 0;
                      Pushing language C
                      Popping language C
              Defined "HAVE_MPI_FINT" to "1"
TEST configureMPI2 from config.packages.MPI(/home/jed/petsc/config/BuildSystem/config/packages/MPI.py:174)
TESTING: configureMPI2 from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:174)
  Check for functions added to the interface in MPI-2
Successful compile:
Source:
#include <mpi.h>
int main() {
int flag;if (MPI_Finalized(&flag));
  return 0;
                      Pushing language C
                      Popping language C
              Defined "HAVE_MPI_FINALIZED" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Allreduce(MPI_IN_PLACE,0, 1, MPI_INT, MPI_SUM, MPI_COMM_SELF));
  return 0;
                      Pushing language C
                      Popping language C
              Defined "HAVE_MPI_IN_PLACE" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
int count=2; int blocklens[2]={0,1}; MPI_Aint indices[2]={0,1}; MPI_Datatype old_types[2]={0,1}; MPI_Datatype *newtype = 0;
                                              if (MPI_Type_create_struct(count, blocklens, indices, old_types, newtype));
  return 0;
                      Pushing language C
                      Popping language C
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Comm_errhandler_fn * p_err_fun = 0; MPI_Errhandler * p_errhandler = 0; if (MPI_Comm_create_errhandler(p_err_fun,p_errhandler));
  return 0;
                      Pushing language C
                      Popping language C
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Comm_set_errhandler(MPI_COMM_WORLD,MPI_ERRORS_RETURN));
  return 0;
                      Pushing language C
                      Popping language C
TEST configureTypes from config.packages.MPI(/home/jed/petsc/config/BuildSystem/config/packages/MPI.py:226)
TESTING: configureTypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:226)
  Checking for MPI types
Checking for size of type: MPI_Comm
                Pushing language C
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.types/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.packages.MPI  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  -I/opt/mpich/include /tmp/petsc-lhuj9c/config.types/conftest.c
Successful compile:
Source:
#include <sys/types.h>
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
#define MPICH_IGNORE_CXX_SEEK
#define MPICH_SKIP_MPICXX 1
#define OMPI_SKIP_MPICXX 1
#include <mpi.h>
int main() {
FILE *f = fopen("conftestval", "w");
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(MPI_Comm));
  return 0;
                            Pushing language C
                            Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.types/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.types/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
Testing executable /tmp/petsc-lhuj9c/config.types/conftest to see if it can be run
Executing: /tmp/petsc-lhuj9c/config.types/conftest
                Popping language C
                Defined "SIZEOF_MPI_COMM" to "4"
Checking for size of type: MPI_Fint
                Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
#include <mpi.h>
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(MPI_Fint));
  return 0;
                            Pushing language C
                            Popping language C
                Popping language C
                Defined "SIZEOF_MPI_FINT" to "4"
TEST configureMPITypes from config.packages.MPI(/home/jed/petsc/config/BuildSystem/config/packages/MPI.py:238)
TESTING: configureMPITypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:238)
  Checking for MPI Datatype handles
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.packages.MPI/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.packages.MPI  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  -I/opt/mpich/include /tmp/petsc-lhuj9c/config.packages.MPI/conftest.c
Successful compile:
Source:
#ifdef PETSC_HAVE_STDLIB_H
  #include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_extent(MPI_LONG_DOUBLE, &size);
if(ierr || (size == 0)) exit(1);
MPI_Finalize();
  return 0;
              Pushing language C
Successful compile:
Source:
  #include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
MPI_Finalize();
  return 0;
                          Pushing language C
                          Popping language C
Testing executable /tmp/petsc-lhuj9c/config.packages.MPI/conftest to see if it can be run
Executing: /tmp/petsc-lhuj9c/config.packages.MPI/conftest
              Defined "HAVE_MPI_LONG_DOUBLE" to "1"
              Popping language C
Successful compile:
Source:
  #include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_extent(MPI_INT64_T, &size);
MPI_Finalize();
  return 0;
              Pushing language C
Successful compile:
Source:
  #include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
MPI_Finalize();
  return 0;
                          Pushing language C
                          Popping language C
              Defined "HAVE_MPI_INT64_T" to "1"
              Popping language C
Successful compile:
Source:
  #include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_extent(MPI_C_DOUBLE_COMPLEX, &size);
MPI_Finalize();
  return 0;
              Pushing language C
Successful compile:
Source:
  #include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
MPI_Finalize();
  return 0;
                          Pushing language C
                          Popping language C
              Defined "HAVE_MPI_C_DOUBLE_COMPLEX" to "1"
              Popping language C
TEST configureMissingPrototypes from config.packages.MPI(/home/jed/petsc/config/BuildSystem/config/packages/MPI.py:312)
TESTING: configureMissingPrototypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:312)
  Checks for missing prototypes, which it adds to petscfix.h
TEST SGIMPICheck from config.packages.MPI(/home/jed/petsc/config/BuildSystem/config/packages/MPI.py:363)
TESTING: SGIMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:363)
  Returns true if SGI MPI is used
              Checking for functions [MPI_SGI_barrier] in library [] []
                Pushing language C
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.libraries/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.packages.MPI  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char MPI_SGI_barrier();
static void _check_MPI_SGI_barrier() { MPI_SGI_barrier(); }
int main() {
_check_MPI_SGI_barrier();;
  return 0;
                        Pushing language C
                        Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.libraries/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
Possible ERROR while running linker: exit code 256
stderr:
/tmp/petsc-lhuj9c/config.libraries/conftest.o: In function `_check_MPI_SGI_barrier':
/tmp/petsc-lhuj9c/config.libraries/conftest.c:5: undefined reference to `MPI_SGI_barrier'
collect2: error: ld returned 1 exit status
                Popping language C
            SGI MPI test failure
TEST CxxMPICheck from config.packages.MPI(/home/jed/petsc/config/BuildSystem/config/packages/MPI.py:373)
TESTING: CxxMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:373)
  Make sure C++ can compile and link
              Pushing language Cxx
Checking for header mpi.h
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.libraries/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.utilities.missing  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0   -fPIC   -I/opt/mpich/include /tmp/petsc-lhuj9c/config.libraries/conftest.cc
Successful compile:
Source:
#include <mpi.h>
int main() {
  return 0;
Checking for C++ MPI_Finalize()
              Checking for functions [MPI_Finalize] in library [] []
Executing: /opt/mpich/bin/mpicxx -c -o /tmp/petsc-lhuj9c/config.libraries/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.libraries  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0   -fPIC   -I/opt/mpich/include /tmp/petsc-lhuj9c/config.libraries/conftest.cc
stderr:
/tmp/petsc-lhuj9c/config.libraries/conftest.cc: In function ?void _check_MPI_Finalize()?:
/tmp/petsc-lhuj9c/config.libraries/conftest.cc:5:41: warning: variable ?ierr? set but not used [-Wunused-but-set-variable]
 static void _check_MPI_Finalize() { int ierr;
Source:
#include <mpi.h>
ierr = MPI_Finalize();; }
int main() {
_check_MPI_Finalize();;
  return 0;
                        Pushing language CXX
                        Popping language CXX
Executing: /opt/mpich/bin/mpicxx  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  /tmp/petsc-lhuj9c/config.libraries/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
                Popping language Cxx
TEST FortranMPICheck from config.packages.MPI(/home/jed/petsc/config/BuildSystem/config/packages/MPI.py:391)
TESTING: FortranMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:391)
  Make sure fortran include [mpif.h] and library symbols are found
              Pushing language FC
Checking for header mpif.h
Executing: /opt/mpich/bin/mpif90 -c -o /tmp/petsc-lhuj9c/config.libraries/conftest.o -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   -I/opt/mpich/include /tmp/petsc-lhuj9c/config.libraries/conftest.F
Successful compile:
Source:
      program main
       include 'mpif.h'
      end
Checking for fortran mpi_init()
              Checking for functions [] in library [] []
                Pushing language FC
Successful compile:
Source:
      program main
       include 'mpif.h'
       integer ierr
       call mpi_init(ierr)
      end
                        Pushing language FC
                        Popping language FC
Executing: /opt/mpich/bin/mpif90  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /tmp/petsc-lhuj9c/config.libraries/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
                Popping language FC
Checking for mpi.mod
                Pushing language FC
Successful compile:
Source:
      program main
       use mpi
       integer ierr,rank
       call mpi_init(ierr)
       call mpi_comm_rank(MPI_COMM_WORLD,rank,ierr)
      end
                        Pushing language FC
                        Popping language FC
                Popping language FC
              Defined "HAVE_MPI_F90MODULE" to "1"
              Popping language FC
TEST configureIO from config.packages.MPI(/home/jed/petsc/config/BuildSystem/config/packages/MPI.py:416)
TESTING: configureIO from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:416)
  Check for the functions in MPI/IO
       - Define HAVE_MPIIO if they are present
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.packages.MPI/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.packages.MPI  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  -I/opt/mpich/include /tmp/petsc-lhuj9c/config.packages.MPI/conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Aint lb, extent;
if (MPI_Type_get_extent(MPI_INT, &lb, &extent));
  return 0;
                      Pushing language C
                      Popping language C
stderr:
/tmp/petsc-lhuj9c/config.packages.MPI/conftest.c:9:5: warning: ?fh? is used uninitialized in this function [-Wuninitialized]
 if (MPI_File_write_all(fh, buf, 1, MPI_INT, &status));
/tmp/petsc-lhuj9c/config.packages.MPI/conftest.c:9:5: warning: ?buf? is used uninitialized in this function [-Wuninitialized]
Source:
#include <mpi.h>
int main() {
MPI_File fh;
void *buf;
MPI_Status status;
  return 0;
                      Pushing language C
                      Popping language C
stderr:
 if (MPI_File_read_all(fh, buf, 1, MPI_INT, &status));
Source:
#include <mpi.h>
int main() {
MPI_File fh;
void *buf;
MPI_Status status;
  return 0;
                      Pushing language C
                      Popping language C
stderr:
 if (MPI_File_set_view(fh, disp, MPI_INT, MPI_INT, "", info));
/tmp/petsc-lhuj9c/config.packages.MPI/conftest.c:9:5: warning: ?disp? is used uninitialized in this function [-Wuninitialized]
/tmp/petsc-lhuj9c/config.packages.MPI/conftest.c:9:5: warning: ?info? is used uninitialized in this function [-Wuninitialized]
Source:
#include <mpi.h>
int main() {
MPI_File fh;
MPI_Offset disp;
MPI_Info info;
  return 0;
                      Pushing language C
                      Popping language C
stderr:
/tmp/petsc-lhuj9c/config.packages.MPI/conftest.c:8:5: warning: ?info? is used uninitialized in this function [-Wuninitialized]
 if (MPI_File_open(MPI_COMM_SELF, "", 0, info, &fh));
Source:
#include <mpi.h>
int main() {
MPI_File fh;
MPI_Info info;
  return 0;
                      Pushing language C
                      Popping language C
stderr:
/tmp/petsc-lhuj9c/config.packages.MPI/conftest.c:7:10: warning: unused variable ?info? [-Wunused-variable]
 MPI_Info info;
Source:
#include <mpi.h>
int main() {
MPI_File fh;
MPI_Info info;
if (MPI_File_close(&fh));
  return 0;
                      Pushing language C
                      Popping language C
              Defined "HAVE_MPIIO" to "1"
TEST findMPIInc from config.packages.MPI(/home/jed/petsc/config/BuildSystem/config/packages/MPI.py:471)
TESTING: findMPIInc from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:471)
  Find MPI include paths from "mpicc -show"
Executing: /opt/mpich/bin/mpicc -show
stdout: gcc -I/opt/mpich/include -L/opt/mpich/lib -Wl,-rpath -Wl,/opt/mpich/lib -Wl,--enable-new-dtags -lmpi
            compilers: Checking arg gcc
            compilers: Checking arg -I/opt/mpich/include
            compilers: Found include directory: /opt/mpich/include
            compilers: Checking arg -L/opt/mpich/lib
            compilers: Checking arg -Wl,-rpath
            compilers: Checking arg -Wl,/opt/mpich/lib
            compilers: Checking arg -Wl,--enable-new-dtags
            compilers: Checking arg -lmpi
TEST checkMPICHorOpenMPI from config.packages.MPI(/home/jed/petsc/config/BuildSystem/config/packages/MPI.py:453)
TESTING: checkMPICHorOpenMPI from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:453)
  Determine if MPICH_NUMVERSION or OMPI_MAJOR_VERSION exist in mpi.h
       Used for consistency checking of MPI installation at compile time
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.packages.MPI/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.packages.MPI  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.packages.MPI/conftest.c
Successful compile:
Source:
#include <mpi.h>
int mpich_ver = MPICH_NUMVERSION;
int main() {
  return 0;
Source:
#include <mpi.h>
Executing: /opt/mpich/bin/mpicc -E  -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.packages.MPI -I/tmp/petsc-lhuj9c/config.headers  /tmp/petsc-lhuj9c/config.packages.MPI/conftest.c
stdout:
# 1 "/tmp/petsc-lhuj9c/config.packages.MPI/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-lhuj9c/config.packages.MPI/confdefs.h" 1
# 2 "/tmp/petsc-lhuj9c/config.packages.MPI/conftest.c" 2
# 1 "/tmp/petsc-lhuj9c/config.packages.MPI/conffix.h" 1
# 3 "/tmp/petsc-lhuj9c/config.packages.MPI/conftest.c" 2
# 1 "/opt/mpich/include/mpi.h" 1
# 96 "/opt/mpich/include/mpi.h"
typedef int MPI_Datatype;
# 279 "/opt/mpich/include/mpi.h"
typedef int MPI_Comm;
typedef int MPI_Group;
typedef int MPI_Win;
typedef struct ADIOI_FileD *MPI_File;
typedef int MPI_Op;
# 362 "/opt/mpich/include/mpi.h"
typedef enum MPIR_Win_flavor {
    MPI_WIN_FLAVOR_CREATE = 1,
    MPI_WIN_FLAVOR_ALLOCATE = 2,
    MPI_WIN_FLAVOR_DYNAMIC = 3,
    MPI_WIN_FLAVOR_SHARED = 4
} MPIR_Win_flavor_t;
typedef enum MPIR_Win_model {
    MPI_WIN_SEPARATE = 1,
    MPI_WIN_UNIFIED = 2
} MPIR_Win_model_t;
typedef enum MPIR_Topo_type { MPI_GRAPH=1, MPI_CART=2, MPI_DIST_GRAPH=3 } MPIR_Topo_type;
extern int * const MPI_UNWEIGHTED;
extern int * const MPI_WEIGHTS_EMPTY;
# 394 "/opt/mpich/include/mpi.h"
typedef void (MPI_Handler_function) ( MPI_Comm *, int *, ... );
typedef int (MPI_Comm_copy_attr_function)(MPI_Comm, int, void *, void *,
       void *, int *);
typedef int (MPI_Comm_delete_attr_function)(MPI_Comm, int, void *, void *);
typedef int (MPI_Type_copy_attr_function)(MPI_Datatype, int, void *, void *,
       void *, int *);
typedef int (MPI_Type_delete_attr_function)(MPI_Datatype, int, void *, void *);
typedef int (MPI_Win_copy_attr_function)(MPI_Win, int, void *, void *, void *,
      int *);
typedef int (MPI_Win_delete_attr_function)(MPI_Win, int, void *, void *);
typedef void (MPI_Comm_errhandler_function)(MPI_Comm *, int *, ...);
typedef void (MPI_File_errhandler_function)(MPI_File *, int *, ...);
typedef void (MPI_Win_errhandler_function)(MPI_Win *, int *, ...);
typedef MPI_Comm_errhandler_function MPI_Comm_errhandler_fn;
typedef MPI_File_errhandler_function MPI_File_errhandler_fn;
typedef MPI_Win_errhandler_function MPI_Win_errhandler_fn;
# 422 "/opt/mpich/include/mpi.h"
typedef int MPI_Errhandler;
# 443 "/opt/mpich/include/mpi.h"
typedef int MPI_Request;
typedef int MPI_Message;
typedef void (MPI_User_function) ( void *, void *, int *, MPI_Datatype * );
typedef int (MPI_Copy_function) ( MPI_Comm, int, void *, void *, void *, int * );
typedef int (MPI_Delete_function) ( MPI_Comm, int, void *, void * );
# 497 "/opt/mpich/include/mpi.h"
enum MPIR_Combiner_enum {
    MPI_COMBINER_NAMED = 1,
    MPI_COMBINER_DUP = 2,
    MPI_COMBINER_CONTIGUOUS = 3,
    MPI_COMBINER_VECTOR = 4,
    MPI_COMBINER_HVECTOR_INTEGER = 5,
    MPI_COMBINER_HVECTOR = 6,
    MPI_COMBINER_INDEXED = 7,
    MPI_COMBINER_HINDEXED_INTEGER = 8,
    MPI_COMBINER_HINDEXED = 9,
    MPI_COMBINER_INDEXED_BLOCK = 10,
    MPI_COMBINER_STRUCT_INTEGER = 11,
    MPI_COMBINER_STRUCT = 12,
    MPI_COMBINER_SUBARRAY = 13,
    MPI_COMBINER_DARRAY = 14,
    MPI_COMBINER_F90_REAL = 15,
    MPI_COMBINER_F90_COMPLEX = 16,
    MPI_COMBINER_F90_INTEGER = 17,
    MPI_COMBINER_RESIZED = 18,
    MPI_COMBINER_HINDEXED_BLOCK = 19
typedef int MPI_Info;
# 547 "/opt/mpich/include/mpi.h"
typedef long MPI_Aint;
typedef int MPI_Fint;
typedef long long MPI_Count;
# 566 "/opt/mpich/include/mpi.h"
typedef long long MPI_Offset;
typedef struct MPI_Status {
    int count_lo;
    int count_hi_and_cancelled;
    int MPI_SOURCE;
    int MPI_TAG;
    int MPI_ERROR;
} MPI_Status;
struct MPIR_T_enum_s;
struct MPIR_T_cvar_handle_s;
struct MPIR_T_pvar_handle_s;
struct MPIR_T_pvar_session_s;
typedef struct MPIR_T_enum_s * MPI_T_enum;
typedef struct MPIR_T_cvar_handle_s * MPI_T_cvar_handle;
typedef struct MPIR_T_pvar_handle_s * MPI_T_pvar_handle;
typedef struct MPIR_T_pvar_session_s * MPI_T_pvar_session;
extern struct MPIR_T_pvar_handle_s * const MPI_T_PVAR_ALL_HANDLES;
# 603 "/opt/mpich/include/mpi.h"
typedef enum MPIR_T_verbosity_t {
    MPIX_T_VERBOSITY_INVALID = 0,
    MPI_T_VERBOSITY_USER_BASIC = 221,
    MPI_T_VERBOSITY_USER_DETAIL,
    MPI_T_VERBOSITY_USER_ALL,
    MPI_T_VERBOSITY_TUNER_BASIC,
    MPI_T_VERBOSITY_TUNER_DETAIL,
    MPI_T_VERBOSITY_TUNER_ALL,
    MPI_T_VERBOSITY_MPIDEV_BASIC,
    MPI_T_VERBOSITY_MPIDEV_DETAIL,
    MPI_T_VERBOSITY_MPIDEV_ALL
} MPIR_T_verbosity_t;
typedef enum MPIR_T_bind_t {
    MPIX_T_BIND_INVALID = 0,
    MPI_T_BIND_NO_OBJECT = 9700,
    MPI_T_BIND_MPI_COMM,
    MPI_T_BIND_MPI_DATATYPE,
    MPI_T_BIND_MPI_ERRHANDLER,
    MPI_T_BIND_MPI_FILE,
    MPI_T_BIND_MPI_GROUP,
    MPI_T_BIND_MPI_OP,
    MPI_T_BIND_MPI_REQUEST,
    MPI_T_BIND_MPI_WIN,
    MPI_T_BIND_MPI_MESSAGE,
    MPI_T_BIND_MPI_INFO
} MPIR_T_bind_t;
typedef enum MPIR_T_scope_t {
    MPIX_T_SCOPE_INVALID = 0,
    MPI_T_SCOPE_CONSTANT = 60438,
    MPI_T_SCOPE_READONLY,
    MPI_T_SCOPE_LOCAL,
    MPI_T_SCOPE_GROUP,
    MPI_T_SCOPE_GROUP_EQ,
    MPI_T_SCOPE_ALL,
    MPI_T_SCOPE_ALL_EQ
} MPIR_T_scope_t;
typedef enum MPIR_T_pvar_class_t {
    MPIX_T_PVAR_CLASS_INVALID = 0,
    MPIR_T_PVAR_CLASS_FIRST = 240,
    MPI_T_PVAR_CLASS_STATE = MPIR_T_PVAR_CLASS_FIRST,
    MPI_T_PVAR_CLASS_LEVEL,
    MPI_T_PVAR_CLASS_SIZE,
    MPI_T_PVAR_CLASS_PERCENTAGE,
    MPI_T_PVAR_CLASS_HIGHWATERMARK,
    MPI_T_PVAR_CLASS_LOWWATERMARK,
    MPI_T_PVAR_CLASS_COUNTER,
    MPI_T_PVAR_CLASS_AGGREGATE,
    MPI_T_PVAR_CLASS_TIMER,
    MPI_T_PVAR_CLASS_GENERIC,
    MPIR_T_PVAR_CLASS_LAST,
    MPIR_T_PVAR_CLASS_NUMBER = MPIR_T_PVAR_CLASS_LAST - MPIR_T_PVAR_CLASS_FIRST
} MPIR_T_pvar_class_t;
# 725 "/opt/mpich/include/mpi.h"
extern MPI_Fint * MPI_F_STATUS_IGNORE;
extern MPI_Fint * MPI_F_STATUSES_IGNORE;
# 740 "/opt/mpich/include/mpi.h"
typedef struct {
    MPI_Fint count_lo;
    MPI_Fint count_hi_and_cancelled;
    MPI_Fint MPI_SOURCE;
    MPI_Fint MPI_TAG;
    MPI_Fint MPI_ERROR;
} MPI_F08_Status;
extern MPI_F08_Status MPIR_F08_MPI_STATUS_IGNORE_OBJ;
extern MPI_F08_Status MPIR_F08_MPI_STATUSES_IGNORE_OBJ[1];
extern int MPIR_F08_MPI_IN_PLACE;
extern int MPIR_F08_MPI_BOTTOM;
extern MPI_F08_Status *MPI_F08_STATUS_IGNORE;
extern MPI_F08_Status *MPI_F08_STATUSES_IGNORE;
# 764 "/opt/mpich/include/mpi.h"
typedef int (MPI_Grequest_cancel_function)(void *, int);
typedef int (MPI_Grequest_free_function)(void *);
typedef int (MPI_Grequest_query_function)(void *, MPI_Status *);
typedef int (MPIX_Grequest_poll_function)(void *, MPI_Status *);
typedef int (MPIX_Grequest_wait_function)(int, void **, double, MPI_Status *);
# 892 "/opt/mpich/include/mpi.h"
typedef int (MPI_Datarep_conversion_function)(void *, MPI_Datatype, int,
             void *, MPI_Offset, void *);
typedef int (MPI_Datarep_extent_function)(MPI_Datatype datatype, MPI_Aint *,
                      void *);
# 912 "/opt/mpich/include/mpi.h"
int MPI_Send(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
             MPI_Comm comm) ;
int MPI_Recv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
             MPI_Comm comm, MPI_Status *status) ;
int MPI_Get_count(const MPI_Status *status, MPI_Datatype datatype, int *count);
int MPI_Bsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int MPI_Ssend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int MPI_Rsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int MPI_Buffer_attach(void *buffer, int size);
int MPI_Buffer_detach(void *buffer_addr, int *size);
int MPI_Isend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm, MPI_Request *request) ;
int MPI_Ibsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Issend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Irsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int MPI_Wait(MPI_Request *request, MPI_Status *status);
int MPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
int MPI_Request_free(MPI_Request *request);
int MPI_Waitany(int count, MPI_Request array_of_requests[], int *indx, MPI_Status *status);
int MPI_Testany(int count, MPI_Request array_of_requests[], int *indx, int *flag,
int MPI_Waitall(int count, MPI_Request array_of_requests[], MPI_Status array_of_statuses[]);
int MPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
int MPI_Waitsome(int incount, MPI_Request array_of_requests[], int *outcount,
                 int array_of_indices[], MPI_Status array_of_statuses[]);
int MPI_Testsome(int incount, MPI_Request array_of_requests[], int *outcount,
int MPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag, MPI_Status *status);
int MPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
int MPI_Cancel(MPI_Request *request);
int MPI_Test_cancelled(const MPI_Status *status, int *flag);
int MPI_Send_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Bsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Ssend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Rsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int MPI_Start(MPI_Request *request);
int MPI_Startall(int count, MPI_Request array_of_requests[]);
int MPI_Sendrecv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, int dest,
                 int sendtag, void *recvbuf, int recvcount, MPI_Datatype recvtype,
                 int source, int recvtag, MPI_Comm comm, MPI_Status *status)
int MPI_Sendrecv_replace(void *buf, int count, MPI_Datatype datatype, int dest,
                         int sendtag, int source, int recvtag, MPI_Comm comm,
int MPI_Type_contiguous(int count, MPI_Datatype oldtype, MPI_Datatype *newtype);
int MPI_Type_vector(int count, int blocklength, int stride, MPI_Datatype oldtype,
int MPI_Type_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int MPI_Type_indexed(int count, const int *array_of_blocklengths,
                     const int *array_of_displacements, MPI_Datatype oldtype,
int MPI_Type_hindexed(int count, const int *array_of_blocklengths,
                      const MPI_Aint *array_of_displacements, MPI_Datatype oldtype,
int MPI_Type_struct(int count, const int *array_of_blocklengths,
                    const MPI_Datatype *array_of_types, MPI_Datatype *newtype);
int MPI_Address(const void *location, MPI_Aint *address);
int MPI_Type_extent(MPI_Datatype datatype, MPI_Aint *extent);
int MPI_Type_size(MPI_Datatype datatype, int *size);
int MPI_Type_lb(MPI_Datatype datatype, MPI_Aint *displacement);
int MPI_Type_ub(MPI_Datatype datatype, MPI_Aint *displacement);
int MPI_Type_commit(MPI_Datatype *datatype);
int MPI_Type_free(MPI_Datatype *datatype);
int MPI_Get_elements(const MPI_Status *status, MPI_Datatype datatype, int *count);
int MPI_Pack(const void *inbuf, int incount, MPI_Datatype datatype, void *outbuf,
             int outsize, int *position, MPI_Comm comm) ;
int MPI_Unpack(const void *inbuf, int insize, int *position, void *outbuf, int outcount,
               MPI_Datatype datatype, MPI_Comm comm) ;
int MPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm, int *size);
int MPI_Barrier(MPI_Comm comm);
int MPI_Bcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm)
int MPI_Gather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
               int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm)
int MPI_Gatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                const int *recvcounts, const int *displs, MPI_Datatype recvtype, int root,
                MPI_Comm comm)
int MPI_Scatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Scatterv(const void *sendbuf, const int *sendcounts, const int *displs,
                 MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype,
int MPI_Allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                  int recvcount, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                   const int *recvcounts, const int *displs, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Alltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls,
                  MPI_Datatype sendtype, void *recvbuf, const int *recvcounts,
                  const int *rdispls, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Alltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
                  const MPI_Datatype sendtypes[], void *recvbuf, const int recvcounts[],
                  const int rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm);
int MPI_Exscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
               MPI_Op op, MPI_Comm comm)
int MPI_Reduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
               MPI_Op op, int root, MPI_Comm comm)
int MPI_Op_create(MPI_User_function *user_fn, int commute, MPI_Op *op);
int MPI_Op_free(MPI_Op *op);
int MPI_Allreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int MPI_Reduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
                       MPI_Datatype datatype, MPI_Op op, MPI_Comm comm)
int MPI_Scan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
             MPI_Comm comm)
int MPI_Group_size(MPI_Group group, int *size);
int MPI_Group_rank(MPI_Group group, int *rank);
int MPI_Group_translate_ranks(MPI_Group group1, int n, const int ranks1[], MPI_Group group2,
                              int ranks2[]);
int MPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
int MPI_Comm_group(MPI_Comm comm, MPI_Group *group);
int MPI_Group_union(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int MPI_Group_intersection(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int MPI_Group_difference(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int MPI_Group_incl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int MPI_Group_excl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int MPI_Group_range_incl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int MPI_Group_range_excl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int MPI_Group_free(MPI_Group *group);
int MPI_Comm_size(MPI_Comm comm, int *size);
int MPI_Comm_rank(MPI_Comm comm, int *rank);
int MPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
int MPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
int MPI_Comm_dup_with_info(MPI_Comm comm, MPI_Info info, MPI_Comm *newcomm);
int MPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
int MPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
int MPI_Comm_free(MPI_Comm *comm);
int MPI_Comm_test_inter(MPI_Comm comm, int *flag);
int MPI_Comm_remote_size(MPI_Comm comm, int *size);
int MPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
int MPI_Intercomm_create(MPI_Comm local_comm, int local_leader, MPI_Comm peer_comm,
                         int remote_leader, int tag, MPI_Comm *newintercomm);
int MPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm);
int MPI_Keyval_create(MPI_Copy_function *copy_fn, MPI_Delete_function *delete_fn,
                      int *keyval, void *extra_state);
int MPI_Keyval_free(int *keyval);
int MPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val);
int MPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag);
int MPI_Attr_delete(MPI_Comm comm, int keyval);
int MPI_Topo_test(MPI_Comm comm, int *status);
int MPI_Cart_create(MPI_Comm comm_old, int ndims, const int dims[], const int periods[],
                    int reorder, MPI_Comm *comm_cart);
int MPI_Dims_create(int nnodes, int ndims, int dims[]);
int MPI_Graph_create(MPI_Comm comm_old, int nnodes, const int indx[], const int edges[],
                     int reorder, MPI_Comm *comm_graph);
int MPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
int MPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges, int indx[], int edges[]);
int MPI_Cartdim_get(MPI_Comm comm, int *ndims);
int MPI_Cart_get(MPI_Comm comm, int maxdims, int dims[], int periods[], int coords[]);
int MPI_Cart_rank(MPI_Comm comm, const int coords[], int *rank);
int MPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int coords[]);
int MPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
int MPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors, int neighbors[]);
int MPI_Cart_shift(MPI_Comm comm, int direction, int disp, int *rank_source, int *rank_dest);
int MPI_Cart_sub(MPI_Comm comm, const int remain_dims[], MPI_Comm *newcomm);
int MPI_Cart_map(MPI_Comm comm, int ndims, const int dims[], const int periods[], int *newrank);
int MPI_Graph_map(MPI_Comm comm, int nnodes, const int indx[], const int edges[], int *newrank);
int MPI_Get_processor_name(char *name, int *resultlen);
int MPI_Get_version(int *version, int *subversion);
int MPI_Get_library_version(char *version, int *resultlen);
int MPI_Errhandler_create(MPI_Handler_function *function, MPI_Errhandler *errhandler);
int MPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler);
int MPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler);
int MPI_Errhandler_free(MPI_Errhandler *errhandler);
int MPI_Error_string(int errorcode, char *string, int *resultlen);
int MPI_Error_class(int errorcode, int *errorclass);
double MPI_Wtime(void);
double MPI_Wtick(void);
int MPI_Init(int *argc, char ***argv);
int MPI_Finalize(void);
int MPI_Initialized(int *flag);
int MPI_Abort(MPI_Comm comm, int errorcode);
int MPI_Pcontrol(const int level, ...);
int MPIR_Dup_fn(MPI_Comm oldcomm, int keyval, void *extra_state, void *attribute_val_in,
               void *attribute_val_out, int *flag);
int MPI_Close_port(const char *port_name);
int MPI_Comm_accept(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                    MPI_Comm *newcomm);
int MPI_Comm_connect(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                     MPI_Comm *newcomm);
int MPI_Comm_disconnect(MPI_Comm *comm);
int MPI_Comm_get_parent(MPI_Comm *parent);
int MPI_Comm_join(int fd, MPI_Comm *intercomm);
int MPI_Comm_spawn(const char *command, char *argv[], int maxprocs, MPI_Info info, int root,
                   MPI_Comm comm, MPI_Comm *intercomm, int array_of_errcodes[]);
int MPI_Comm_spawn_multiple(int count, char *array_of_commands[], char **array_of_argv[],
                            const int array_of_maxprocs[], const MPI_Info array_of_info[],
                            int root, MPI_Comm comm, MPI_Comm *intercomm, int array_of_errcodes[]);
int MPI_Lookup_name(const char *service_name, MPI_Info info, char *port_name);
int MPI_Open_port(MPI_Info info, char *port_name);
int MPI_Publish_name(const char *service_name, MPI_Info info, const char *port_name);
int MPI_Unpublish_name(const char *service_name, MPI_Info info, const char *port_name);
int MPI_Comm_set_info(MPI_Comm comm, MPI_Info info);
int MPI_Comm_get_info(MPI_Comm comm, MPI_Info *info);
int MPI_Accumulate(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
                   int target_rank, MPI_Aint target_disp, int target_count,
                   MPI_Datatype target_datatype, MPI_Op op, MPI_Win win)
int MPI_Get(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
            MPI_Datatype target_datatype, MPI_Win win) ;
int MPI_Put(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int MPI_Win_complete(MPI_Win win);
int MPI_Win_create(void *base, MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
                   MPI_Win *win);
int MPI_Win_fence(int assert, MPI_Win win);
int MPI_Win_free(MPI_Win *win);
int MPI_Win_get_group(MPI_Win win, MPI_Group *group);
int MPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
int MPI_Win_post(MPI_Group group, int assert, MPI_Win win);
int MPI_Win_start(MPI_Group group, int assert, MPI_Win win);
int MPI_Win_test(MPI_Win win, int *flag);
int MPI_Win_unlock(int rank, MPI_Win win);
int MPI_Win_wait(MPI_Win win);
int MPI_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm, void *baseptr,
                     MPI_Win *win);
int MPI_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
                            void *baseptr, MPI_Win *win);
int MPI_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
int MPI_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
int MPI_Win_attach(MPI_Win win, void *base, MPI_Aint size);
int MPI_Win_detach(MPI_Win win, const void *base);
int MPI_Win_get_info(MPI_Win win, MPI_Info *info_used);
int MPI_Win_set_info(MPI_Win win, MPI_Info info);
int MPI_Get_accumulate(const void *origin_addr, int origin_count,
                        MPI_Datatype origin_datatype, void *result_addr, int result_count,
                        MPI_Datatype result_datatype, int target_rank, MPI_Aint target_disp,
                        int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win)
int MPI_Fetch_and_op(const void *origin_addr, void *result_addr,
                      MPI_Datatype datatype, int target_rank, MPI_Aint target_disp,
int MPI_Compare_and_swap(const void *origin_addr, const void *compare_addr,
                          void *result_addr, MPI_Datatype datatype, int target_rank,
                          MPI_Aint target_disp, MPI_Win win)
int MPI_Rput(const void *origin_addr, int origin_count,
              MPI_Datatype origin_datatype, int target_rank, MPI_Aint target_disp,
              int target_count, MPI_Datatype target_datatype, MPI_Win win,
int MPI_Rget(void *origin_addr, int origin_count,
int MPI_Raccumulate(const void *origin_addr, int origin_count,
                     int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win,
int MPI_Rget_accumulate(const void *origin_addr, int origin_count,
int MPI_Win_lock_all(int assert, MPI_Win win);
int MPI_Win_unlock_all(MPI_Win win);
int MPI_Win_flush(int rank, MPI_Win win);
int MPI_Win_flush_all(MPI_Win win);
int MPI_Win_flush_local(int rank, MPI_Win win);
int MPI_Win_flush_local_all(MPI_Win win);
int MPI_Win_sync(MPI_Win win);
int MPI_Add_error_class(int *errorclass);
int MPI_Add_error_code(int errorclass, int *errorcode);
int MPI_Add_error_string(int errorcode, const char *string);
int MPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
int MPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
                           MPI_Comm_delete_attr_function *comm_delete_attr_fn, int *comm_keyval,
                           void *extra_state);
int MPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
int MPI_Comm_free_keyval(int *comm_keyval);
int MPI_Comm_get_attr(MPI_Comm comm, int comm_keyval, void *attribute_val, int *flag);
int MPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
int MPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
int MPI_Comm_set_name(MPI_Comm comm, const char *comm_name);
int MPI_File_call_errhandler(MPI_File fh, int errorcode);
int MPI_Grequest_complete(MPI_Request request);
int MPI_Grequest_start(MPI_Grequest_query_function *query_fn, MPI_Grequest_free_function *free_fn,
                       MPI_Grequest_cancel_function *cancel_fn, void *extra_state,
int MPI_Init_thread(int *argc, char ***argv, int required, int *provided);
int MPI_Is_thread_main(int *flag);
int MPI_Query_thread(int *provided);
int MPI_Status_set_cancelled(MPI_Status *status, int flag);
int MPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype, int count);
int MPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
                           MPI_Type_delete_attr_function *type_delete_attr_fn,
                           int *type_keyval, void *extra_state);
int MPI_Type_delete_attr(MPI_Datatype datatype, int type_keyval);
int MPI_Type_dup(MPI_Datatype oldtype, MPI_Datatype *newtype);
int MPI_Type_free_keyval(int *type_keyval);
int MPI_Type_get_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val, int *flag);
int MPI_Type_get_contents(MPI_Datatype datatype, int max_integers, int max_addresses,
                          int max_datatypes, int array_of_integers[],
                          MPI_Aint array_of_addresses[], MPI_Datatype array_of_datatypes[]);
int MPI_Type_get_envelope(MPI_Datatype datatype, int *num_integers, int *num_addresses,
                          int *num_datatypes, int *combiner);
int MPI_Type_get_name(MPI_Datatype datatype, char *type_name, int *resultlen);
int MPI_Type_set_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val);
int MPI_Type_set_name(MPI_Datatype datatype, const char *type_name);
int MPI_Type_match_size(int typeclass, int size, MPI_Datatype *datatype);
int MPI_Win_call_errhandler(MPI_Win win, int errorcode);
int MPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
                          MPI_Win_delete_attr_function *win_delete_attr_fn, int *win_keyval,
                          void *extra_state);
int MPI_Win_delete_attr(MPI_Win win, int win_keyval);
int MPI_Win_free_keyval(int *win_keyval);
int MPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val, int *flag);
int MPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
int MPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
int MPI_Win_set_name(MPI_Win win, const char *win_name);
int MPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr);
int MPI_Comm_create_errhandler(MPI_Comm_errhandler_function *comm_errhandler_fn,
int MPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *errhandler);
int MPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
int MPI_File_create_errhandler(MPI_File_errhandler_function *file_errhandler_fn,
int MPI_File_get_errhandler(MPI_File file, MPI_Errhandler *errhandler);
int MPI_File_set_errhandler(MPI_File file, MPI_Errhandler errhandler);
int MPI_Finalized(int *flag);
int MPI_Free_mem(void *base);
int MPI_Get_address(const void *location, MPI_Aint *address);
int MPI_Info_create(MPI_Info *info);
int MPI_Info_delete(MPI_Info info, const char *key);
int MPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
int MPI_Info_free(MPI_Info *info);
int MPI_Info_get(MPI_Info info, const char *key, int valuelen, char *value, int *flag);
int MPI_Info_get_nkeys(MPI_Info info, int *nkeys);
int MPI_Info_get_nthkey(MPI_Info info, int n, char *key);
int MPI_Info_get_valuelen(MPI_Info info, const char *key, int *valuelen, int *flag);
int MPI_Info_set(MPI_Info info, const char *key, const char *value);
int MPI_Pack_external(const char datarep[], const void *inbuf, int incount,
                      MPI_Datatype datatype, void *outbuf, MPI_Aint outsize, MPI_Aint *position)
int MPI_Pack_external_size(const char datarep[], int incount, MPI_Datatype datatype,
                           MPI_Aint *size);
int MPI_Request_get_status(MPI_Request request, int *flag, MPI_Status *status);
int MPI_Status_c2f(const MPI_Status *c_status, MPI_Fint *f_status);
int MPI_Status_f2c(const MPI_Fint *f_status, MPI_Status *c_status);
int MPI_Type_create_darray(int size, int rank, int ndims, const int array_of_gsizes[],
                           const int array_of_distribs[], const int array_of_dargs[],
                           const int array_of_psizes[], int order, MPI_Datatype oldtype,
int MPI_Type_create_hindexed(int count, const int array_of_blocklengths[],
                             const MPI_Aint array_of_displacements[], MPI_Datatype oldtype,
int MPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int MPI_Type_create_indexed_block(int count, int blocklength, const int array_of_displacements[],
int MPI_Type_create_hindexed_block(int count, int blocklength,
int MPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb, MPI_Aint extent,
int MPI_Type_create_struct(int count, const int array_of_blocklengths[],
                           const MPI_Datatype array_of_types[], MPI_Datatype *newtype);
int MPI_Type_create_subarray(int ndims, const int array_of_sizes[],
                             const int array_of_subsizes[], const int array_of_starts[],
                             int order, MPI_Datatype oldtype, MPI_Datatype *newtype);
int MPI_Type_get_extent(MPI_Datatype datatype, MPI_Aint *lb, MPI_Aint *extent);
int MPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb, MPI_Aint *true_extent);
int MPI_Unpack_external(const char datarep[], const void *inbuf, MPI_Aint insize,
                        MPI_Aint *position, void *outbuf, int outcount, MPI_Datatype datatype)
int MPI_Win_create_errhandler(MPI_Win_errhandler_function *win_errhandler_fn,
int MPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
int MPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
int MPI_Type_create_f90_integer(int range, MPI_Datatype *newtype);
int MPI_Type_create_f90_real(int precision, int range, MPI_Datatype *newtype);
int MPI_Type_create_f90_complex(int precision, int range, MPI_Datatype *newtype);
int MPI_Reduce_local(const void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype,
                     MPI_Op op)
int MPI_Op_commutative(MPI_Op op, int *commute);
int MPI_Reduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int MPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree, const int sources[],
                                   const int sourceweights[], int outdegree,
                                   const int destinations[], const int destweights[],
                                   MPI_Info info, int reorder, MPI_Comm *comm_dist_graph);
int MPI_Dist_graph_create(MPI_Comm comm_old, int n, const int sources[], const int degrees[],
                          const int destinations[], const int weights[], MPI_Info info,
int MPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
int MPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int sources[], int sourceweights[],
                             int maxoutdegree, int destinations[], int destweights[]);
int MPI_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPI_Message *message,
int MPI_Imrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int MPI_Mprobe(int source, int tag, MPI_Comm comm, MPI_Message *message, MPI_Status *status);
int MPI_Mrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int MPI_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
int MPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
int MPI_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm,
int MPI_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm,
int MPI_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                 const int recvcounts[], const int displs[], MPI_Datatype recvtype, int root,
int MPI_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Iscatterv(const void *sendbuf, const int sendcounts[], const int displs[],
                  int root, MPI_Comm comm, MPI_Request *request)
int MPI_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                   int recvcount, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)
int MPI_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Ialltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
                   MPI_Datatype sendtype, void *recvbuf, const int recvcounts[],
                   const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm,
int MPI_Ialltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
                   const int rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm,
int MPI_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
                MPI_Op op, int root, MPI_Comm comm, MPI_Request *request)
int MPI_Iallreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
                   MPI_Op op, MPI_Comm comm, MPI_Request *request)
int MPI_Ireduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
                        MPI_Datatype datatype, MPI_Op op, MPI_Comm comm, MPI_Request *request)
int MPI_Ireduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int MPI_Iscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
int MPI_Iexscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int MPI_Ineighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Ineighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
                             void *recvbuf, const int recvcounts[], const int displs[],
int MPI_Ineighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
                           void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm,
int MPI_Ineighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int MPI_Ineighbor_alltoallw(const void *sendbuf, const int sendcounts[],
                            const MPI_Aint sdispls[], const MPI_Datatype sendtypes[],
                            void *recvbuf, const int recvcounts[], const MPI_Aint rdispls[],
                            const MPI_Datatype recvtypes[], MPI_Comm comm, MPI_Request *request);
int MPI_Neighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
                           void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Neighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Neighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Neighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
                           const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Neighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[],
                           const MPI_Aint rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm);
int MPI_Comm_split_type(MPI_Comm comm, int split_type, int key, MPI_Info info, MPI_Comm *newcomm);
int MPI_Get_elements_x(const MPI_Status *status, MPI_Datatype datatype, MPI_Count *count);
int MPI_Status_set_elements_x(MPI_Status *status, MPI_Datatype datatype, MPI_Count count);
int MPI_Type_get_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int MPI_Type_get_true_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int MPI_Type_size_x(MPI_Datatype datatype, MPI_Count *size);
int MPI_Comm_create_group(MPI_Comm comm, MPI_Group group, int tag, MPI_Comm *newcomm);
int MPI_T_init_thread(int required, int *provided);
int MPI_T_finalize(void);
int MPI_T_enum_get_info(MPI_T_enum enumtype, int *num, char *name, int *name_len);
int MPI_T_enum_get_item(MPI_T_enum enumtype, int indx, int *value, char *name, int *name_len);
int MPI_T_cvar_get_num(int *num_cvar);
int MPI_T_cvar_get_info(int cvar_index, char *name, int *name_len, int *verbosity,
                        MPI_Datatype *datatype, MPI_T_enum *enumtype, char *desc, int *desc_len,
                        int *binding, int *scope);
int MPI_T_cvar_handle_alloc(int cvar_index, void *obj_handle, MPI_T_cvar_handle *handle,
                            int *count);
int MPI_T_cvar_handle_free(MPI_T_cvar_handle *handle);
int MPI_T_cvar_read(MPI_T_cvar_handle handle, void *buf);
int MPI_T_cvar_write(MPI_T_cvar_handle handle, const void *buf);
int MPI_T_pvar_get_num(int *num_pvar);
int MPI_T_pvar_get_info(int pvar_index, char *name, int *name_len, int *verbosity, int *var_class,
                        int *binding, int *readonly, int *continuous, int *atomic);
int MPI_T_pvar_session_create(MPI_T_pvar_session *session);
int MPI_T_pvar_session_free(MPI_T_pvar_session *session);
int MPI_T_pvar_handle_alloc(MPI_T_pvar_session session, int pvar_index, void *obj_handle,
                            MPI_T_pvar_handle *handle, int *count);
int MPI_T_pvar_handle_free(MPI_T_pvar_session session, MPI_T_pvar_handle *handle);
int MPI_T_pvar_start(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int MPI_T_pvar_stop(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int MPI_T_pvar_read(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int MPI_T_pvar_write(MPI_T_pvar_session session, MPI_T_pvar_handle handle, const void *buf);
int MPI_T_pvar_reset(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int MPI_T_pvar_readreset(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int MPI_T_category_get_num(int *num_cat);
int MPI_T_category_get_info(int cat_index, char *name, int *name_len, char *desc, int *desc_len,
                            int *num_cvars, int *num_pvars, int *num_categories);
int MPI_T_category_get_cvars(int cat_index, int len, int indices[]);
int MPI_T_category_get_pvars(int cat_index, int len, int indices[]);
int MPI_T_category_get_categories(int cat_index, int len, int indices[]);
int MPI_T_category_changed(int *stamp);
int MPIX_Comm_failure_ack(MPI_Comm comm);
int MPIX_Comm_failure_get_acked(MPI_Comm comm, MPI_Group *failedgrp);
int MPIX_Comm_revoke(MPI_Comm comm);
int MPIX_Comm_shrink(MPI_Comm comm, MPI_Comm *newcomm);
int MPIX_Comm_agree(MPI_Comm comm, int *flag);
# 1551 "/opt/mpich/include/mpi.h"
int PMPI_Send(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int PMPI_Recv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int PMPI_Get_count(const MPI_Status *status, MPI_Datatype datatype, int *count);
int PMPI_Bsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
               MPI_Comm comm) ;
int PMPI_Ssend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
               MPI_Comm comm) ;
int PMPI_Rsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
               MPI_Comm comm) ;
int PMPI_Buffer_attach(void *buffer, int size);
int PMPI_Buffer_detach(void *buffer_addr, int *size);
int PMPI_Isend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Ibsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Issend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Irsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int PMPI_Wait(MPI_Request *request, MPI_Status *status);
int PMPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
int PMPI_Request_free(MPI_Request *request);
int PMPI_Waitany(int count, MPI_Request array_of_requests[], int *indx, MPI_Status *status);
int PMPI_Testany(int count, MPI_Request array_of_requests[], int *indx, int *flag,
int PMPI_Waitall(int count, MPI_Request array_of_requests[], MPI_Status array_of_statuses[]);
int PMPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
int PMPI_Waitsome(int incount, MPI_Request array_of_requests[], int *outcount,
int PMPI_Testsome(int incount, MPI_Request array_of_requests[], int *outcount,
int PMPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag, MPI_Status *status);
int PMPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
int PMPI_Cancel(MPI_Request *request);
int PMPI_Test_cancelled(const MPI_Status *status, int *flag);
int PMPI_Send_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Bsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Ssend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Rsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int PMPI_Start(MPI_Request *request);
int PMPI_Startall(int count, MPI_Request array_of_requests[]);
int PMPI_Sendrecv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, int dest,
int PMPI_Sendrecv_replace(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Type_contiguous(int count, MPI_Datatype oldtype, MPI_Datatype *newtype);
int PMPI_Type_vector(int count, int blocklength, int stride, MPI_Datatype oldtype,
int PMPI_Type_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int PMPI_Type_indexed(int count, const int *array_of_blocklengths,
int PMPI_Type_hindexed(int count, const int *array_of_blocklengths,
int PMPI_Type_struct(int count, const int *array_of_blocklengths,
int PMPI_Address(const void *location, MPI_Aint *address);
int PMPI_Type_extent(MPI_Datatype datatype, MPI_Aint *extent);
int PMPI_Type_size(MPI_Datatype datatype, int *size);
int PMPI_Type_lb(MPI_Datatype datatype, MPI_Aint *displacement);
int PMPI_Type_ub(MPI_Datatype datatype, MPI_Aint *displacement);
int PMPI_Type_commit(MPI_Datatype *datatype);
int PMPI_Type_free(MPI_Datatype *datatype);
int PMPI_Get_elements(const MPI_Status *status, MPI_Datatype datatype, int *count);
int PMPI_Pack(const void *inbuf, int incount, MPI_Datatype datatype, void *outbuf,
int PMPI_Unpack(const void *inbuf, int insize, int *position, void *outbuf, int outcount,
int PMPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm, int *size);
int PMPI_Barrier(MPI_Comm comm);
int PMPI_Bcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm)
int PMPI_Gather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Gatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                 MPI_Comm comm)
int PMPI_Scatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Scatterv(const void *sendbuf, const int *sendcounts, const int *displs,
int PMPI_Allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Alltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls,
int PMPI_Alltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Exscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Reduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Op_create(MPI_User_function *user_fn, int commute, MPI_Op *op);
int PMPI_Op_free(MPI_Op *op);
int PMPI_Allreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Reduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
int PMPI_Scan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
              MPI_Comm comm)
int PMPI_Group_size(MPI_Group group, int *size);
int PMPI_Group_rank(MPI_Group group, int *rank);
int PMPI_Group_translate_ranks(MPI_Group group1, int n, const int ranks1[], MPI_Group group2,
                               int ranks2[]);
int PMPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
int PMPI_Comm_group(MPI_Comm comm, MPI_Group *group);
int PMPI_Group_union(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int PMPI_Group_intersection(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int PMPI_Group_difference(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int PMPI_Group_incl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int PMPI_Group_excl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int PMPI_Group_range_incl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int PMPI_Group_range_excl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int PMPI_Group_free(MPI_Group *group);
int PMPI_Comm_size(MPI_Comm comm, int *size);
int PMPI_Comm_rank(MPI_Comm comm, int *rank);
int PMPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
int PMPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
int PMPI_Comm_dup_with_info(MPI_Comm comm, MPI_Info info, MPI_Comm *newcomm);
int PMPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
int PMPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
int PMPI_Comm_free(MPI_Comm *comm);
int PMPI_Comm_test_inter(MPI_Comm comm, int *flag);
int PMPI_Comm_remote_size(MPI_Comm comm, int *size);
int PMPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
int PMPI_Intercomm_create(MPI_Comm local_comm, int local_leader, MPI_Comm peer_comm,
int PMPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm);
int PMPI_Keyval_create(MPI_Copy_function *copy_fn, MPI_Delete_function *delete_fn,
int PMPI_Keyval_free(int *keyval);
int PMPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val);
int PMPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag);
int PMPI_Attr_delete(MPI_Comm comm, int keyval);
int PMPI_Topo_test(MPI_Comm comm, int *status);
int PMPI_Cart_create(MPI_Comm comm_old, int ndims, const int dims[], const int periods[],
int PMPI_Dims_create(int nnodes, int ndims, int dims[]);
int PMPI_Graph_create(MPI_Comm comm_old, int nnodes, const int indx[], const int edges[],
int PMPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
int PMPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges, int indx[], int edges[]);
int PMPI_Cartdim_get(MPI_Comm comm, int *ndims);
int PMPI_Cart_get(MPI_Comm comm, int maxdims, int dims[], int periods[], int coords[]);
int PMPI_Cart_rank(MPI_Comm comm, const int coords[], int *rank);
int PMPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int coords[]);
int PMPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
int PMPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors, int neighbors[]);
int PMPI_Cart_shift(MPI_Comm comm, int direction, int disp, int *rank_source, int *rank_dest);
int PMPI_Cart_sub(MPI_Comm comm, const int remain_dims[], MPI_Comm *newcomm);
int PMPI_Cart_map(MPI_Comm comm, int ndims, const int dims[], const int periods[], int *newrank);
int PMPI_Graph_map(MPI_Comm comm, int nnodes, const int indx[], const int edges[], int *newrank);
int PMPI_Get_processor_name(char *name, int *resultlen);
int PMPI_Get_version(int *version, int *subversion);
int PMPI_Get_library_version(char *version, int *resultlen);
int PMPI_Errhandler_create(MPI_Handler_function *function, MPI_Errhandler *errhandler);
int PMPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler);
int PMPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler);
int PMPI_Errhandler_free(MPI_Errhandler *errhandler);
int PMPI_Error_string(int errorcode, char *string, int *resultlen);
int PMPI_Error_class(int errorcode, int *errorclass);
double PMPI_Wtime(void);
double PMPI_Wtick(void);
int PMPI_Init(int *argc, char ***argv);
int PMPI_Finalize(void);
int PMPI_Initialized(int *flag);
int PMPI_Abort(MPI_Comm comm, int errorcode);
int PMPI_Pcontrol(const int level, ...);
int PMPI_Close_port(const char *port_name);
int PMPI_Comm_accept(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                     MPI_Comm *newcomm);
int PMPI_Comm_connect(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                      MPI_Comm *newcomm);
int PMPI_Comm_disconnect(MPI_Comm *comm);
int PMPI_Comm_get_parent(MPI_Comm *parent);
int PMPI_Comm_join(int fd, MPI_Comm *intercomm);
int PMPI_Comm_spawn(const char *command, char *argv[], int maxprocs, MPI_Info info, int root,
int PMPI_Comm_spawn_multiple(int count, char *array_of_commands[], char **array_of_argv[],
int PMPI_Lookup_name(const char *service_name, MPI_Info info, char *port_name);
int PMPI_Open_port(MPI_Info info, char *port_name);
int PMPI_Publish_name(const char *service_name, MPI_Info info, const char *port_name);
int PMPI_Unpublish_name(const char *service_name, MPI_Info info, const char *port_name);
int PMPI_Comm_set_info(MPI_Comm comm, MPI_Info info);
int PMPI_Comm_get_info(MPI_Comm comm, MPI_Info *info);
int PMPI_Accumulate(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Get(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Put(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Win_complete(MPI_Win win);
int PMPI_Win_create(void *base, MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
                    MPI_Win *win);
int PMPI_Win_fence(int assert, MPI_Win win);
int PMPI_Win_free(MPI_Win *win);
int PMPI_Win_get_group(MPI_Win win, MPI_Group *group);
int PMPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
int PMPI_Win_post(MPI_Group group, int assert, MPI_Win win);
int PMPI_Win_start(MPI_Group group, int assert, MPI_Win win);
int PMPI_Win_test(MPI_Win win, int *flag);
int PMPI_Win_unlock(int rank, MPI_Win win);
int PMPI_Win_wait(MPI_Win win);
int PMPI_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm, void *baseptr,
                      MPI_Win *win);
int PMPI_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
int PMPI_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
int PMPI_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
int PMPI_Win_attach(MPI_Win win, void *base, MPI_Aint size);
int PMPI_Win_detach(MPI_Win win, const void *base);
int PMPI_Win_get_info(MPI_Win win, MPI_Info *info_used);
int PMPI_Win_set_info(MPI_Win win, MPI_Info info);
int PMPI_Get_accumulate(const void *origin_addr, int origin_count,
int PMPI_Fetch_and_op(const void *origin_addr, void *result_addr,
int PMPI_Compare_and_swap(const void *origin_addr, const void *compare_addr,
int PMPI_Rput(const void *origin_addr, int origin_count,
int PMPI_Rget(void *origin_addr, int origin_count,
int PMPI_Raccumulate(const void *origin_addr, int origin_count,
int PMPI_Rget_accumulate(const void *origin_addr, int origin_count,
int PMPI_Win_lock_all(int assert, MPI_Win win);
int PMPI_Win_unlock_all(MPI_Win win);
int PMPI_Win_flush(int rank, MPI_Win win);
int PMPI_Win_flush_all(MPI_Win win);
int PMPI_Win_flush_local(int rank, MPI_Win win);
int PMPI_Win_flush_local_all(MPI_Win win);
int PMPI_Win_sync(MPI_Win win);
int PMPI_Add_error_class(int *errorclass);
int PMPI_Add_error_code(int errorclass, int *errorcode);
int PMPI_Add_error_string(int errorcode, const char *string);
int PMPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
int PMPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
                            void *extra_state);
int PMPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
int PMPI_Comm_free_keyval(int *comm_keyval);
int PMPI_Comm_get_attr(MPI_Comm comm, int comm_keyval, void *attribute_val, int *flag);
int PMPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
int PMPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
int PMPI_Comm_set_name(MPI_Comm comm, const char *comm_name);
int PMPI_File_call_errhandler(MPI_File fh, int errorcode);
int PMPI_Grequest_complete(MPI_Request request);
int PMPI_Grequest_start(MPI_Grequest_query_function *query_fn, MPI_Grequest_free_function *free_fn,
int PMPI_Init_thread(int *argc, char ***argv, int required, int *provided);
int PMPI_Is_thread_main(int *flag);
int PMPI_Query_thread(int *provided);
int PMPI_Status_set_cancelled(MPI_Status *status, int flag);
int PMPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype, int count);
int PMPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
int PMPI_Type_delete_attr(MPI_Datatype datatype, int type_keyval);
int PMPI_Type_dup(MPI_Datatype oldtype, MPI_Datatype *newtype);
int PMPI_Type_free_keyval(int *type_keyval);
int PMPI_Type_get_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val, int *flag);
int PMPI_Type_get_contents(MPI_Datatype datatype, int max_integers, int max_addresses,
int PMPI_Type_get_envelope(MPI_Datatype datatype, int *num_integers, int *num_addresses,
int PMPI_Type_get_name(MPI_Datatype datatype, char *type_name, int *resultlen);
int PMPI_Type_set_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val);
int PMPI_Type_set_name(MPI_Datatype datatype, const char *type_name);
int PMPI_Type_match_size(int typeclass, int size, MPI_Datatype *datatype);
int PMPI_Win_call_errhandler(MPI_Win win, int errorcode);
int PMPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
                           void *extra_state);
int PMPI_Win_delete_attr(MPI_Win win, int win_keyval);
int PMPI_Win_free_keyval(int *win_keyval);
int PMPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val, int *flag);
int PMPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
int PMPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
int PMPI_Win_set_name(MPI_Win win, const char *win_name);
int PMPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr);
int PMPI_Comm_create_errhandler(MPI_Comm_errhandler_function *comm_errhandler_fn,
int PMPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *errhandler);
int PMPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
int PMPI_File_create_errhandler(MPI_File_errhandler_function *file_errhandler_fn,
int PMPI_File_get_errhandler(MPI_File file, MPI_Errhandler *errhandler);
int PMPI_File_set_errhandler(MPI_File file, MPI_Errhandler errhandler);
int PMPI_Finalized(int *flag);
int PMPI_Free_mem(void *base);
int PMPI_Get_address(const void *location, MPI_Aint *address);
int PMPI_Info_create(MPI_Info *info);
int PMPI_Info_delete(MPI_Info info, const char *key);
int PMPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
int PMPI_Info_free(MPI_Info *info);
int PMPI_Info_get(MPI_Info info, const char *key, int valuelen, char *value, int *flag);
int PMPI_Info_get_nkeys(MPI_Info info, int *nkeys);
int PMPI_Info_get_nthkey(MPI_Info info, int n, char *key);
int PMPI_Info_get_valuelen(MPI_Info info, const char *key, int *valuelen, int *flag);
int PMPI_Info_set(MPI_Info info, const char *key, const char *value);
int PMPI_Pack_external(const char datarep[], const void *inbuf, int incount,
int PMPI_Pack_external_size(const char datarep[], int incount, MPI_Datatype datatype,
                            MPI_Aint *size);
int PMPI_Request_get_status(MPI_Request request, int *flag, MPI_Status *status);
int PMPI_Status_c2f(const MPI_Status *c_status, MPI_Fint *f_status);
int PMPI_Status_f2c(const MPI_Fint *f_status, MPI_Status *c_status);
int PMPI_Type_create_darray(int size, int rank, int ndims, const int array_of_gsizes[],
int PMPI_Type_create_hindexed(int count, const int array_of_blocklengths[],
int PMPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int PMPI_Type_create_indexed_block(int count, int blocklength, const int array_of_displacements[],
int PMPI_Type_create_hindexed_block(int count, int blocklength,
int PMPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb, MPI_Aint extent,
int PMPI_Type_create_struct(int count, const int array_of_blocklengths[],
int PMPI_Type_create_subarray(int ndims, const int array_of_sizes[],
int PMPI_Type_get_extent(MPI_Datatype datatype, MPI_Aint *lb, MPI_Aint *extent);
int PMPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb, MPI_Aint *true_extent);
int PMPI_Unpack_external(const char datarep[], const void *inbuf, MPI_Aint insize,
int PMPI_Win_create_errhandler(MPI_Win_errhandler_function *win_errhandler_fn,
int PMPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
int PMPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
int PMPI_Type_create_f90_integer(int r, MPI_Datatype *newtype);
int PMPI_Type_create_f90_real(int p, int r, MPI_Datatype *newtype);
int PMPI_Type_create_f90_complex(int p, int r, MPI_Datatype *newtype);
int PMPI_Reduce_local(const void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype,
                      MPI_Op op)
int PMPI_Op_commutative(MPI_Op op, int *commute);
int PMPI_Reduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int PMPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree, const int sources[],
int PMPI_Dist_graph_create(MPI_Comm comm_old, int n, const int sources[], const int degrees[],
int PMPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
int PMPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int sources[], int sourceweights[],
int PMPI_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPI_Message *message,
int PMPI_Imrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int PMPI_Mprobe(int source, int tag, MPI_Comm comm, MPI_Message *message, MPI_Status *status);
int PMPI_Mrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int PMPI_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
int PMPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
int PMPI_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm,
int PMPI_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Iscatterv(const void *sendbuf, const int sendcounts[], const int displs[],
int PMPI_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Ialltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Ialltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Iallreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Ireduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
int PMPI_Ireduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int PMPI_Iscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
int PMPI_Iexscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Ineighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Ineighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Ineighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Ineighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Ineighbor_alltoallw(const void *sendbuf, const int sendcounts[],
int PMPI_Neighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Neighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Neighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Neighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Neighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[],
                            MPI_Comm comm);
int PMPI_Comm_split_type(MPI_Comm comm, int split_type, int key, MPI_Info info, MPI_Comm *newcomm);
int PMPI_Comm_create_group(MPI_Comm comm, MPI_Group group, int tag, MPI_Comm *newcomm);
int PMPI_Get_elements_x(const MPI_Status *status, MPI_Datatype datatype, MPI_Count *count);
int PMPI_Status_set_elements_x(MPI_Status *status, MPI_Datatype datatype, MPI_Count count);
int PMPI_Type_get_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int PMPI_Type_get_true_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int PMPI_Type_size_x(MPI_Datatype datatype, MPI_Count *size);
int PMPI_T_init_thread(int required, int *provided);
int PMPI_T_finalize(void);
int PMPI_T_enum_get_info(MPI_T_enum enumtype, int *num, char *name, int *name_len);
int PMPI_T_enum_get_item(MPI_T_enum enumtype, int indx, int *value, char *name, int *name_len);
int PMPI_T_cvar_get_num(int *num_cvar);
int PMPI_T_cvar_get_info(int cvar_index, char *name, int *name_len, int *verbosity,
int PMPI_T_cvar_handle_alloc(int cvar_index, void *obj_handle, MPI_T_cvar_handle *handle,
                             int *count);
int PMPI_T_cvar_handle_free(MPI_T_cvar_handle *handle);
int PMPI_T_cvar_read(MPI_T_cvar_handle handle, void *buf);
int PMPI_T_cvar_write(MPI_T_cvar_handle handle, const void *buf);
int PMPI_T_pvar_get_num(int *num_pvar);
int PMPI_T_pvar_get_info(int pvar_index, char *name, int *name_len, int *verbosity, int *var_class,
int PMPI_T_pvar_session_create(MPI_T_pvar_session *session);
int PMPI_T_pvar_session_free(MPI_T_pvar_session *session);
int PMPI_T_pvar_handle_alloc(MPI_T_pvar_session session, int pvar_index, void *obj_handle,
int PMPI_T_pvar_handle_free(MPI_T_pvar_session session, MPI_T_pvar_handle *handle);
int PMPI_T_pvar_start(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int PMPI_T_pvar_stop(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int PMPI_T_pvar_read(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int PMPI_T_pvar_write(MPI_T_pvar_session session, MPI_T_pvar_handle handle, const void *buf);
int PMPI_T_pvar_reset(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int PMPI_T_pvar_readreset(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int PMPI_T_category_get_num(int *num_cat);
int PMPI_T_category_get_info(int cat_index, char *name, int *name_len, char *desc, int *desc_len,
int PMPI_T_category_get_cvars(int cat_index, int len, int indices[]);
int PMPI_T_category_get_pvars(int cat_index, int len, int indices[]);
int PMPI_T_category_get_categories(int cat_index, int len, int indices[]);
int PMPI_T_category_changed(int *stamp);
int PMPIX_Comm_failure_ack(MPI_Comm comm);
int PMPIX_Comm_failure_get_acked(MPI_Comm comm, MPI_Group *failedgrp);
int PMPIX_Comm_revoke(MPI_Comm comm);
int PMPIX_Comm_shrink(MPI_Comm comm, MPI_Comm *newcomm);
int PMPIX_Comm_agree(MPI_Comm comm, int *flag);
# 2200 "/opt/mpich/include/mpi.h"
# 1 "/opt/mpich/include/mpio.h" 1
# 13 "/opt/mpich/include/mpio.h"
# 14 "/opt/mpich/include/mpio.h" 2
# 123 "/opt/mpich/include/mpio.h"
int MPI_File_open(MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh);
int MPI_File_close(MPI_File *fh);
int MPI_File_delete(const char *filename, MPI_Info info);
int MPI_File_set_size(MPI_File fh, MPI_Offset size);
int MPI_File_preallocate(MPI_File fh, MPI_Offset size);
int MPI_File_get_size(MPI_File fh, MPI_Offset *size);
int MPI_File_get_group(MPI_File fh, MPI_Group *group);
int MPI_File_get_amode(MPI_File fh, int *amode);
int MPI_File_set_info(MPI_File fh, MPI_Info info);
int MPI_File_get_info(MPI_File fh, MPI_Info *info_used);
int MPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype,
                      const char *datarep, MPI_Info info);
int MPI_File_get_view(MPI_File fh, MPI_Offset *disp, MPI_Datatype *etype, MPI_Datatype *filetype,
                      char *datarep);
int MPI_File_read_at(MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype,
int MPI_File_read_at_all(MPI_File fh, MPI_Offset offset, void * buf, int count,
                         MPI_Datatype datatype, MPI_Status *status)
int MPI_File_write_at(MPI_File fh, MPI_Offset offset, const void * buf, int count,
int MPI_File_write_at_all(MPI_File fh, MPI_Offset offset, const void *buf, int count,
int MPI_File_iread_at(MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype,
int MPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, const void *buf, int count,
                       MPI_Datatype datatype, MPI_Request *request)
int MPI_File_read(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status)
int MPI_File_read_all(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status)
int MPI_File_write(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_write_all(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_iread(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Request *request)
int MPI_File_iwrite(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_seek(MPI_File fh, MPI_Offset offset, int whence);
int MPI_File_get_position(MPI_File fh, MPI_Offset *offset);
int MPI_File_get_byte_offset(MPI_File fh, MPI_Offset offset, MPI_Offset *disp);
int MPI_File_read_shared(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int MPI_File_write_shared(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_iread_shared(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int MPI_File_iwrite_shared(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_read_ordered(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int MPI_File_write_ordered(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_seek_shared(MPI_File fh, MPI_Offset offset, int whence);
int MPI_File_get_position_shared(MPI_File fh, MPI_Offset *offset);
int MPI_File_read_at_all_begin(MPI_File fh, MPI_Offset offset, void *buf, int count,
                               MPI_Datatype datatype) ;
int MPI_File_read_at_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, const void *buf, int count,
int MPI_File_write_at_all_end(MPI_File fh, const void *buf, MPI_Status *status);
int MPI_File_read_all_begin(MPI_File fh, void *buf, int count, MPI_Datatype datatype)
int MPI_File_read_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_all_begin(MPI_File fh, const void *buf, int count, MPI_Datatype datatype)
int MPI_File_write_all_end(MPI_File fh, const void *buf, MPI_Status *status);
int MPI_File_read_ordered_begin(MPI_File fh, void *buf, int count, MPI_Datatype datatype)
int MPI_File_read_ordered_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_ordered_begin(MPI_File fh, const void *buf, int count, MPI_Datatype datatype)
int MPI_File_write_ordered_end(MPI_File fh, const void *buf, MPI_Status *status);
int MPI_File_get_type_extent(MPI_File fh, MPI_Datatype datatype, MPI_Aint *extent);
int MPI_Register_datarep(const char *datarep, MPI_Datarep_conversion_function *read_conversion_fn,
    MPI_Datarep_conversion_function *write_conversion_fn,
    MPI_Datarep_extent_function *dtype_file_extent_fn, void *extra_state);
int MPI_File_set_atomicity(MPI_File fh, int flag);
int MPI_File_get_atomicity(MPI_File fh, int *flag);
int MPI_File_sync(MPI_File fh);
# 268 "/opt/mpich/include/mpio.h"
MPI_File MPI_File_f2c(MPI_Fint file);
MPI_Fint MPI_File_c2f(MPI_File file);
# 329 "/opt/mpich/include/mpio.h"
int PMPI_File_open(MPI_Comm, const char *, int, MPI_Info, MPI_File *);
int PMPI_File_close(MPI_File *);
int PMPI_File_delete(const char *, MPI_Info);
int PMPI_File_set_size(MPI_File, MPI_Offset);
int PMPI_File_preallocate(MPI_File, MPI_Offset);
int PMPI_File_get_size(MPI_File, MPI_Offset *);
int PMPI_File_get_group(MPI_File, MPI_Group *);
int PMPI_File_get_amode(MPI_File, int *);
int PMPI_File_set_info(MPI_File, MPI_Info);
int PMPI_File_get_info(MPI_File, MPI_Info *);
int PMPI_File_set_view(MPI_File, MPI_Offset,
    MPI_Datatype, MPI_Datatype, const char *, MPI_Info);
int PMPI_File_get_view(MPI_File, MPI_Offset *,
      MPI_Datatype *, MPI_Datatype *, char *);
int PMPI_File_read_at(MPI_File, MPI_Offset, void *,
       int, MPI_Datatype, MPI_Status *)
int PMPI_File_read_at_all(MPI_File, MPI_Offset, void *,
int PMPI_File_write_at(MPI_File, MPI_Offset, const void *,
int PMPI_File_write_at_all(MPI_File, MPI_Offset, const void *,
int PMPI_File_iread_at(MPI_File, MPI_Offset, void *,
       int, MPI_Datatype, MPI_Request *)
int PMPI_File_iwrite_at(MPI_File, MPI_Offset, const void *,
int PMPI_File_read(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_read_all(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write_all(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_iread(MPI_File, void *, int, MPI_Datatype, MPI_Request *)
int PMPI_File_iwrite(MPI_File, const void *, int, MPI_Datatype, MPI_Request *)
int PMPI_File_seek(MPI_File, MPI_Offset, int);
int PMPI_File_get_position(MPI_File, MPI_Offset *);
int PMPI_File_get_byte_offset(MPI_File, MPI_Offset, MPI_Offset *);
int PMPI_File_read_shared(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write_shared(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_iread_shared(MPI_File, void *, int,
int PMPI_File_iwrite_shared(MPI_File, const void *, int,
int PMPI_File_read_ordered(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write_ordered(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_seek_shared(MPI_File, MPI_Offset, int);
int PMPI_File_get_position_shared(MPI_File, MPI_Offset *);
int PMPI_File_read_at_all_begin(MPI_File, MPI_Offset, void *,
                               int, MPI_Datatype)
int PMPI_File_read_at_all_end(MPI_File, void *, MPI_Status *);
int PMPI_File_write_at_all_begin(MPI_File, MPI_Offset, const void *,
                                 int, MPI_Datatype)
int PMPI_File_write_at_all_end(MPI_File, const void *, MPI_Status *);
int PMPI_File_read_all_begin(MPI_File, void *, int, MPI_Datatype)
int PMPI_File_read_all_end(MPI_File, void *, MPI_Status *);
int PMPI_File_write_all_begin(MPI_File, const void *, int, MPI_Datatype)
int PMPI_File_write_all_end(MPI_File, const void *, MPI_Status *);
int PMPI_File_read_ordered_begin(MPI_File, void *, int, MPI_Datatype)
int PMPI_File_read_ordered_end(MPI_File, void *, MPI_Status *);
int PMPI_File_write_ordered_begin(MPI_File, const void *, int, MPI_Datatype)
int PMPI_File_write_ordered_end(MPI_File, const void *, MPI_Status *);
int PMPI_File_get_type_extent(MPI_File, MPI_Datatype, MPI_Aint *);
int PMPI_Register_datarep(const char *,
    MPI_Datarep_conversion_function *,
    MPI_Datarep_extent_function *,
    void *);
int PMPI_File_set_atomicity(MPI_File, int);
int PMPI_File_get_atomicity(MPI_File, int *);
int PMPI_File_sync(MPI_File);
# 467 "/opt/mpich/include/mpio.h"
MPI_File PMPI_File_f2c(MPI_Fint);
MPI_Fint PMPI_File_c2f(MPI_File);
# 2201 "/opt/mpich/include/mpi.h" 2
# 2222 "/opt/mpich/include/mpi.h"
typedef int MPIX_Grequest_class;
int MPIX_Grequest_class_create(MPI_Grequest_query_function *query_fn,
                               MPIX_Grequest_poll_function *poll_fn,
                               MPIX_Grequest_wait_function *wait_fn,
                               MPIX_Grequest_class *greq_class);
int MPIX_Grequest_class_allocate(MPIX_Grequest_class greq_class, void *extra_state,
int MPIX_Grequest_start(MPI_Grequest_query_function *query_fn,
                        MPIX_Grequest_wait_function *wait_fn, void *extra_state,
struct mpixi_mutex_s;
typedef struct mpixi_mutex_s * MPIX_Mutex;
int MPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
int MPIX_Mutex_free(MPIX_Mutex *hdl);
int MPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
int MPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
int PMPIX_Grequest_class_create(MPI_Grequest_query_function *query_fn,
int PMPIX_Grequest_class_allocate(MPIX_Grequest_class greq_class, void *extra_state,
int PMPIX_Grequest_start(MPI_Grequest_query_function *query_fn,
int PMPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
int PMPIX_Mutex_free(MPIX_Mutex *hdl);
int PMPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
int PMPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
# 4 "/tmp/petsc-lhuj9c/config.packages.MPI/conftest.c" 2
int mpich_ver = 30103300;
              Defined "HAVE_MPICH_NUMVERSION" to "30103300"
          Checking for functions [MPI_Alltoallw] in library [] []
            Pushing language C
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.libraries/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.packages.MPI  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.libraries/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
/* Override any gcc2 internal prototype to avoid an error. */
char MPI_Alltoallw();
static void _check_MPI_Alltoallw() { MPI_Alltoallw(); }
int main() {
_check_MPI_Alltoallw();;
  return 0;
                    Pushing language C
                    Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.libraries/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
            Popping language C
          Checking for functions [MPI_Type_create_indexed_block] in library [] []
            Pushing language C
Successful compile:
Source:
char MPI_Type_create_indexed_block();
static void _check_MPI_Type_create_indexed_block() { MPI_Type_create_indexed_block(); }
int main() {
_check_MPI_Type_create_indexed_block();;
  return 0;
                    Pushing language C
                    Popping language C
            Popping language C
          Defined "HAVE_MPI_ALLTOALLW" to "1"
          Checking for functions [MPI_Win_create] in library [] []
            Pushing language C
Successful compile:
Source:
char MPI_Win_create();
static void _check_MPI_Win_create() { MPI_Win_create(); }
int main() {
_check_MPI_Win_create();;
  return 0;
                    Pushing language C
                    Popping language C
            Popping language C
          Defined "HAVE_MPI_WIN_CREATE" to "1"
          Defined "HAVE_MPI_REPLACE" to "1"
                Checking for functions [MPI_Comm_spawn MPI_Type_get_envelope MPI_Type_get_extent MPI_Type_dup MPI_Init_thread MPI_Iallreduce MPI_Ibarrier MPI_Finalized MPI_Exscan] in library [] []
                  Pushing language C
Successful compile:
Source:
char MPI_Comm_spawn();
static void _check_MPI_Comm_spawn() { MPI_Comm_spawn(); }
char MPI_Type_get_envelope();
static void _check_MPI_Type_get_envelope() { MPI_Type_get_envelope(); }
char MPI_Type_get_extent();
static void _check_MPI_Type_get_extent() { MPI_Type_get_extent(); }
char MPI_Type_dup();
static void _check_MPI_Type_dup() { MPI_Type_dup(); }
char MPI_Init_thread();
static void _check_MPI_Init_thread() { MPI_Init_thread(); }
char MPI_Iallreduce();
static void _check_MPI_Iallreduce() { MPI_Iallreduce(); }
char MPI_Ibarrier();
static void _check_MPI_Ibarrier() { MPI_Ibarrier(); }
char MPI_Finalized();
static void _check_MPI_Finalized() { MPI_Finalized(); }
char MPI_Exscan();
static void _check_MPI_Exscan() { MPI_Exscan(); }
int main() {
_check_MPI_Comm_spawn();
_check_MPI_Type_get_envelope();
_check_MPI_Type_get_extent();
_check_MPI_Type_dup();
_check_MPI_Init_thread();
_check_MPI_Iallreduce();
_check_MPI_Ibarrier();
_check_MPI_Finalized();
_check_MPI_Exscan();;
  return 0;
                          Pushing language C
                          Popping language C
                  Popping language C
          Defined "HAVE_MPI_COMM_SPAWN" to "1"
          Defined "HAVE_MPI_TYPE_GET_ENVELOPE" to "1"
          Defined "HAVE_MPI_TYPE_GET_EXTENT" to "1"
          Defined "HAVE_MPI_TYPE_DUP" to "1"
          Defined "HAVE_MPI_INIT_THREAD" to "1"
          Defined "HAVE_MPI_IALLREDUCE" to "1"
          Defined "HAVE_MPI_IBARRIER" to "1"
          Defined "HAVE_MPI_FINALIZED" to "1"
          Defined "HAVE_MPI_EXSCAN" to "1"
          Checking for functions [MPIX_Iallreduce] in library [] []
            Pushing language C
Successful compile:
Source:
char MPIX_Iallreduce();
static void _check_MPIX_Iallreduce() { MPIX_Iallreduce(); }
int main() {
_check_MPIX_Iallreduce();;
  return 0;
                    Pushing language C
                    Popping language C
Possible ERROR while running linker: exit code 256
stderr:
/tmp/petsc-lhuj9c/config.libraries/conftest.o: In function `_check_MPIX_Iallreduce':
/tmp/petsc-lhuj9c/config.libraries/conftest.c:5: undefined reference to `MPIX_Iallreduce'
collect2: error: ld returned 1 exit status
            Popping language C
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.packages.MPI/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.packages.MPI  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  -I/opt/mpich/include -I/opt/mpich/include /tmp/petsc-lhuj9c/config.packages.MPI/conftest.c
Possible ERROR while running compiler:
stderr:
/tmp/petsc-lhuj9c/config.packages.MPI/conftest.c: In function ?main?:
/tmp/petsc-lhuj9c/config.packages.MPI/conftest.c:6:5: warning: unused variable ?combiner? [-Wunused-variable]
 int combiner = MPI_COMBINER_DUP;;
Source:
#include <mpi.h>
int main() {
  return 0;
          Defined "HAVE_MPI_COMBINER_DUP" to "1"
stderr:
 int combiner = MPI_COMBINER_CONTIGUOUS;;
Source:
#include <mpi.h>
int main() {
  return 0;
          Defined "HAVE_MPI_COMBINER_CONTIGUOUS" to "1"
          Checking for functions [MPIDI_CH3I_sock_set] in library [] []
            Pushing language C
Successful compile:
Source:
char MPIDI_CH3I_sock_set();
static void _check_MPIDI_CH3I_sock_set() { MPIDI_CH3I_sock_set(); }
int main() {
_check_MPIDI_CH3I_sock_set();;
  return 0;
                    Pushing language C
                    Popping language C
stderr:
/tmp/petsc-lhuj9c/config.libraries/conftest.o: In function `_check_MPIDI_CH3I_sock_set':
/tmp/petsc-lhuj9c/config.libraries/conftest.c:5: undefined reference to `MPIDI_CH3I_sock_set'
            Popping language C
          Checking for functions [MPIDI_CH3I_sock_fixed_nbc_progress] in library [] []
            Pushing language C
Successful compile:
Source:
char MPIDI_CH3I_sock_fixed_nbc_progress();
static void _check_MPIDI_CH3I_sock_fixed_nbc_progress() { MPIDI_CH3I_sock_fixed_nbc_progress(); }
int main() {
_check_MPIDI_CH3I_sock_fixed_nbc_progress();;
  return 0;
                    Pushing language C
                    Popping language C
stderr:
/tmp/petsc-lhuj9c/config.libraries/conftest.o: In function `_check_MPIDI_CH3I_sock_fixed_nbc_progress':
/tmp/petsc-lhuj9c/config.libraries/conftest.c:5: undefined reference to `MPIDI_CH3I_sock_fixed_nbc_progress'
            Popping language C
TEST checkSharedLibrary from config.packages.MPI(/home/jed/petsc/config/BuildSystem/config/packages/MPI.py:124)
TESTING: checkSharedLibrary from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:124)
  Sets flag indicating if MPI libraries are shared or not and
    determines if MPI libraries CANNOT be used by shared libraries
TEST configureMPIEXEC from config.packages.MPI(/home/jed/petsc/config/BuildSystem/config/packages/MPI.py:137)
TESTING: configureMPIEXEC from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:137)
  Checking for mpiexec
              Pushing language C
              Popping language C
Checking for program /opt/mpich/bin/mpiexec...found
              Defined make macro "MPIEXEC" to "/opt/mpich/bin/mpiexec"
Successful compile:
Source:
#include <mpi.h>
#ifdef __cplusplus
extern "C"
#endif
int init(int argc,  char *argv[]) {
  int isInitialized;
  MPI_Init(&argc, &argv);
  MPI_Initialized(&isInitialized);
  return (int) isInitialized;
                      Pushing language C
                      Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.packages.MPI/libconftest.so  -shared  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.packages.MPI/conftest.o    -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
Successful compile:
Source:
#include <mpi.h>
#ifdef __cplusplus
extern "C"
#endif
int checkInit(void) {
  int isInitialized;
  if (isInitialized) MPI_Finalize();
                      Pushing language C
                      Popping language C
Successful compile:
Source:
#include <stdio.h>
#include <stdlib.h>
#ifdef PETSC_HAVE_DLFCN_H
#include <dlfcn.h>
#endif
int main() {
  int   argc    = 1;
  char *argv[2] = {(char *) "conftest", NULL};
  void *lib;
  int (*init)(int, char **);
  int (*checkInit)(void);
  lib = dlopen("/tmp/petsc-lhuj9c/config.libraries/lib1.so", RTLD_LAZY);
  if (!lib) {
    fprintf(stderr, "Could not open lib1.so: %s\n", dlerror());
    exit(1);
  init = (int (*)(int, char **)) dlsym(lib, "init");
  if (!init) {
    fprintf(stderr, "Could not find initialization function\n");
    exit(1);
  if (!(*init)(argc, argv)) {
    fprintf(stderr, "Could not initialize library\n");
    exit(1);
  lib = dlopen("/tmp/petsc-lhuj9c/config.libraries/lib2.so", RTLD_LAZY);
  if (!lib) {
    fprintf(stderr, "Could not open lib2.so: %s\n", dlerror());
    exit(1);
  checkInit = (int (*)(void)) dlsym(lib, "checkInit");
  if (!checkInit) {
    fprintf(stderr, "Could not find initialization check function\n");
    exit(1);
  if (!(*checkInit)()) {
    fprintf(stderr, "Did not link with shared library\n");
    exit(2);
  return 0;
                        Pushing language C
                        Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/config.libraries/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl  -ldl
Testing executable /tmp/petsc-lhuj9c/config.libraries/conftest to see if it can be run
Executing: /opt/mpich/bin/mpiexec /tmp/petsc-lhuj9c/config.libraries/conftest
          Library was shared
      Popping language C
TEST alternateConfigureLibrary from config.packages.p4est(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.p4est(config/BuildSystem/config/package.py:596)
  Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from config.packages.sprng(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.sprng(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.pami(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.pami(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.mpe(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.mpe(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.fftw(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.fftw(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.hdf5(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.hdf5(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.netcdf(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.netcdf(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.netcdf-cxx(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.netcdf-cxx(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.exodusii(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.exodusii(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.MOAB(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.MOAB(config/BuildSystem/config/package.py:596)
TEST configureScalarType from PETSc.options.scalarTypes(/home/jed/petsc/config/PETSc/options/scalarTypes.py:37)
TESTING: configureScalarType from PETSc.options.scalarTypes(config/PETSc/options/scalarTypes.py:37)
  Choose between real and complex numbers
          Defined "USE_SCALAR_REAL" to "1"
        Scalar type is real
          Pushing language C
                      All intermediate test results are stored in /tmp/petsc-lhuj9c/PETSc.options.scalarTypes
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/PETSc.options.scalarTypes/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/PETSc.options.scalarTypes -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.packages.MPI  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/PETSc.options.scalarTypes/conftest.c
stderr:
/tmp/petsc-lhuj9c/PETSc.options.scalarTypes/conftest.c: In function ?main?:
/tmp/petsc-lhuj9c/PETSc.options.scalarTypes/conftest.c:6:21: warning: unused variable ?a? [-Wunused-variable]
 double b = 2.0; int a = isnormal(b);
Source:
#include <math.h>
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: /opt/mpich/bin/mpicc  -o /tmp/petsc-lhuj9c/PETSc.options.scalarTypes/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /tmp/petsc-lhuj9c/PETSc.options.scalarTypes/conftest.o -Wl,-rpath,/opt/mpich/lib -L/opt/mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.9.1 -ldl -Wl,-rpath,/opt/mpich/lib -lmpi -lgcc_s -ldl
stderr:
/tmp/petsc-lhuj9c/PETSc.options.scalarTypes/conftest.o: In function `main':
/tmp/petsc-lhuj9c/PETSc.options.scalarTypes/conftest.c:6: undefined reference to `__fpclassify'
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/PETSc.options.scalarTypes/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.libraries -I/tmp/petsc-lhuj9c/config.packages.MPI -I/tmp/petsc-lhuj9c/PETSc.options.scalarTypes  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/PETSc.options.scalarTypes/conftest.c
stderr:
 double b = 2.0; int a = isnan(b);
Source:
#include <math.h>
int main() {
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_ISNAN" to "1"
stderr:
 double b = 2.0; int a = isinf(b);
Source:
#include <math.h>
int main() {
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_ISINF" to "1"
stderr:
/tmp/petsc-lhuj9c/PETSc.options.scalarTypes/conftest.c:6:1: warning: implicit declaration of function ?_isnan? [-Wimplicit-function-declaration]
 double b = 2.0;int a = _isnan(b);
/tmp/petsc-lhuj9c/PETSc.options.scalarTypes/conftest.c:6:20: warning: unused variable ?a? [-Wunused-variable]
Source:
#include <math.h>
int main() {
  return 0;
                  Pushing language C
                  Popping language C
stderr:
/tmp/petsc-lhuj9c/PETSc.options.scalarTypes/conftest.c:6: undefined reference to `_isnan'
stderr:
/tmp/petsc-lhuj9c/PETSc.options.scalarTypes/conftest.c:6:1: warning: implicit declaration of function ?_finite? [-Wimplicit-function-declaration]
 double b = 2.0;int a = _finite(b);
Source:
#include <math.h>
int main() {
  return 0;
                  Pushing language C
                  Popping language C
stderr:
/tmp/petsc-lhuj9c/PETSc.options.scalarTypes/conftest.c:6: undefined reference to `_finite'
          Popping language C
TEST configurePrecision from PETSc.options.scalarTypes(/home/jed/petsc/config/PETSc/options/scalarTypes.py:77)
TESTING: configurePrecision from PETSc.options.scalarTypes(config/PETSc/options/scalarTypes.py:77)
  Set the default real number precision for PETSc objects
          Defined "USE_REAL_DOUBLE" to "1"
        Precision is double
TEST alternateConfigureLibrary from config.packages.cuda(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.cuda(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.cusp(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.cusp(config/BuildSystem/config/package.py:596)
TEST configureLibraryOptions from PETSc.options.libraryOptions(/home/jed/petsc/config/PETSc/options/libraryOptions.py:38)
TESTING: configureLibraryOptions from PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:38)
  Sets PETSC_USE_DEBUG, PETSC_USE_INFO, PETSC_USE_LOG, PETSC_USE_CTABLE and PETSC_USE_FORTRAN_KERNELS
          Defined "USE_LOG" to "1"
          Defined "USE_DEBUG" to "1"
          Defined "USE_INFO" to "1"
          Defined "USE_CTABLE" to "1"
          **********Checking if running on BGL/IBM detected
            Checking for functions [bgl_perfctr_void] in library [''] []
              Pushing language C
Executing: /opt/mpich/bin/mpicc -c -o /tmp/petsc-lhuj9c/config.libraries/conftest.o -I/tmp/petsc-lhuj9c/config.setCompilers -I/tmp/petsc-lhuj9c/config.compilers -I/tmp/petsc-lhuj9c/config.utilities.closure -I/tmp/petsc-lhuj9c/config.headers -I/tmp/petsc-lhuj9c/config.utilities.cacheDetails -I/tmp/petsc-lhuj9c/config.utilities.featureTestMacros -I/tmp/petsc-lhuj9c/config.utilities.missing -I/tmp/petsc-lhuj9c/config.functions -I/tmp/petsc-lhuj9c/config.packages.valgrind -I/tmp/petsc-lhuj9c/config.atomics -I/tmp/petsc-lhuj9c/config.packages.pthread -I/tmp/petsc-lhuj9c/config.types -I/tmp/petsc-lhuj9c/config.packages.MPI -I/tmp/petsc-lhuj9c/PETSc.options.scalarTypes -I/tmp/petsc-lhuj9c/config.libraries  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /tmp/petsc-lhuj9c/config.libraries/conftest.c
Successful compile:
Source:
char bgl_perfctr_void();
static void _check_bgl_perfctr_void() { bgl_perfctr_void(); }
int main() {
_check_bgl_perfctr_void();;
  return 0;
                      Pushing language C
                      Popping language C
stderr:
/tmp/petsc-lhuj9c/config.libraries/conftest.o: In function `_check_bgl_perfctr_void':
/tmp/petsc-lhuj9c/config.libraries/conftest.c:5: undefined reference to `bgl_perfctr_void'
              Popping language C
            Checking for functions [ADIOI_BGL_Open] in library [''] []
              Pushing language C
Successful compile:
Source:
char ADIOI_BGL_Open();
static void _check_ADIOI_BGL_Open() { ADIOI_BGL_Open(); }
int main() {
_check_ADIOI_BGL_Open();;
  return 0;
                      Pushing language C
                      Popping language C
stderr:
/tmp/petsc-lhuj9c/config.libraries/conftest.o: In function `_check_ADIOI_BGL_Open':
/tmp/petsc-lhuj9c/config.libraries/conftest.c:5: undefined reference to `ADIOI_BGL_Open'
              Popping language C
          *********BGL/IBM test failure
          Defined "USE_BACKWARD_LOOP" to "1"
          Defined "Alignx(a,b)" to "  "
TEST configureISColorValueType from PETSc.options.libraryOptions(/home/jed/petsc/config/PETSc/options/libraryOptions.py:87)
TESTING: configureISColorValueType from PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:87)
  Sets PETSC_IS_COLOR_VALUE_TYPE, MPIU_COLORING_VALUE, IS_COLORING_MAX required by ISColor
          Defined "MPIU_COLORING_VALUE" to "MPI_UNSIGNED_SHORT"
          Defined "IS_COLORING_MAX" to "65535"
          Defined "IS_COLOR_VALUE_TYPE" to "short"
          Defined "IS_COLOR_VALUE_TYPE_SIZE" to "PETSC_SIZEOF_SHORT"
TEST alternateConfigureLibrary from config.packages.PTScotch(/home/jed/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.PTScotch(config/BuildSystem/config/package.py:596)
TEST locateCMake from config.packages.cmake(/home/jed/petsc/config/BuildSystem/config/packages/cmake.py:30)
TESTING: locateCMake from config.packages.cmake(config/BuildSystem/config/packages/cmake.py:30)
Looking for default CMake executable
Checking for program /home/jed/bin/cmake...not found
Checking for program /usr/bin/cmake...found
            Defined make macro "CMAKE" to "/usr/bin/cmake"
      Pushing language C
TEST configureLibrary from config.packages.metis(/home/jed/petsc/config/BuildSystem/config/package.py:538)
TESTING: configureLibrary from config.packages.metis(config/BuildSystem/config/package.py:538)
  Find an installation and check if it can work with PETSc
        Checking for a functional metis
**** Configure header /tmp/petsc-lhuj9c/confdefs.h ****
#if !defined(INCLUDED_UNKNOWN)
#define INCLUDED_UNKNOWN
#ifndef IS_COLORING_MAX
#define IS_COLORING_MAX 65535
#endif
#ifndef STDC_HEADERS
#define STDC_HEADERS 1
#endif
#ifndef MPIU_COLORING_VALUE
#define MPIU_COLORING_VALUE MPI_UNSIGNED_SHORT
#endif
#ifndef PETSC_HAVE_GZIP
#define PETSC_HAVE_GZIP 1
#endif
#ifndef PETSC_HAVE_STRING_H
#define PETSC_HAVE_STRING_H 1
#endif
#ifndef PETSC_HAVE_SYS_TYPES_H
#define PETSC_HAVE_SYS_TYPES_H 1
#endif
#ifndef PETSC_HAVE_ENDIAN_H
#define PETSC_HAVE_ENDIAN_H 1
#endif
#ifndef PETSC_HAVE_SYS_PROCFS_H
#define PETSC_HAVE_SYS_PROCFS_H 1
#endif
#ifndef PETSC_HAVE_DLFCN_H
#define PETSC_HAVE_DLFCN_H 1
#endif
#ifndef PETSC_HAVE_SCHED_H
#define PETSC_HAVE_SCHED_H 1
#endif
#ifndef PETSC_HAVE_STDINT_H
#define PETSC_HAVE_STDINT_H 1
#endif
#ifndef PETSC_HAVE_LINUX_KERNEL_H
#define PETSC_HAVE_LINUX_KERNEL_H 1
#endif
#ifndef PETSC_HAVE_TIME_H
#define PETSC_HAVE_TIME_H 1
#endif
#ifndef PETSC_HAVE_MATH_H
#define PETSC_HAVE_MATH_H 1
#endif
#ifndef PETSC_TIME_WITH_SYS_TIME
#define PETSC_TIME_WITH_SYS_TIME 1
#endif
#ifndef PETSC_HAVE_SYS_PARAM_H
#define PETSC_HAVE_SYS_PARAM_H 1
#endif
#ifndef PETSC_HAVE_PTHREAD_H
#define PETSC_HAVE_PTHREAD_H 1
#endif
#ifndef PETSC_HAVE_UNISTD_H
#define PETSC_HAVE_UNISTD_H 1
#endif
#ifndef PETSC_HAVE_STDLIB_H
#define PETSC_HAVE_STDLIB_H 1
#endif
#ifndef PETSC_HAVE_SYS_WAIT_H
#define PETSC_HAVE_SYS_WAIT_H 1
#endif
#ifndef PETSC_HAVE_SETJMP_H
#define PETSC_HAVE_SETJMP_H 1
#endif
#ifndef PETSC_HAVE_LIMITS_H
#define PETSC_HAVE_LIMITS_H 1
#endif
#ifndef PETSC_HAVE_SYS_UTSNAME_H
#define PETSC_HAVE_SYS_UTSNAME_H 1
#endif
#ifndef PETSC_HAVE_NETINET_IN_H
#define PETSC_HAVE_NETINET_IN_H 1
#endif
#ifndef PETSC_HAVE_SYS_SOCKET_H
#define PETSC_HAVE_SYS_SOCKET_H 1
#endif
#ifndef PETSC_HAVE_FLOAT_H
#define PETSC_HAVE_FLOAT_H 1
#endif
#ifndef PETSC_HAVE_SEARCH_H
#define PETSC_HAVE_SEARCH_H 1
#endif
#ifndef PETSC_HAVE_SYS_RESOURCE_H
#define PETSC_HAVE_SYS_RESOURCE_H 1
#endif
#ifndef PETSC_HAVE_SYS_TIMES_H
#define PETSC_HAVE_SYS_TIMES_H 1
#endif
#ifndef PETSC_HAVE_NETDB_H
#define PETSC_HAVE_NETDB_H 1
#endif
#ifndef PETSC_HAVE_MALLOC_H
#define PETSC_HAVE_MALLOC_H 1
#endif
#ifndef PETSC_HAVE_PWD_H
#define PETSC_HAVE_PWD_H 1
#endif
#ifndef PETSC_HAVE_FCNTL_H
#define PETSC_HAVE_FCNTL_H 1
#endif
#ifndef PETSC_HAVE_STRINGS_H
#define PETSC_HAVE_STRINGS_H 1
#endif
#ifndef PETSC_HAVE_SYS_SYSINFO_H
#define PETSC_HAVE_SYS_SYSINFO_H 1
#endif
#ifndef PETSC_HAVE_SYS_TIME_H
#define PETSC_HAVE_SYS_TIME_H 1
#endif
#ifndef PETSC_USING_F90
#define PETSC_USING_F90 1
#endif
#ifndef PETSC_USING_F2003
#define PETSC_USING_F2003 1
#endif
#ifndef PETSC_HAVE_RTLD_NOW
#define PETSC_HAVE_RTLD_NOW 1
#endif
#ifndef PETSC_HAVE_RTLD_LOCAL
#define PETSC_HAVE_RTLD_LOCAL 1
#endif
#ifndef PETSC_HAVE_RTLD_LAZY
#define PETSC_HAVE_RTLD_LAZY 1
#endif
#ifndef PETSC_C_STATIC_INLINE
#define PETSC_C_STATIC_INLINE static inline
#endif
#ifndef PETSC_HAVE_FORTRAN_UNDERSCORE
#define PETSC_HAVE_FORTRAN_UNDERSCORE 1
#endif
#ifndef PETSC_HAVE_CXX_NAMESPACE
#define PETSC_HAVE_CXX_NAMESPACE 1
#endif
#ifndef PETSC_HAVE_RTLD_GLOBAL
#define PETSC_HAVE_RTLD_GLOBAL 1
#endif
#ifndef PETSC_C_RESTRICT
#define PETSC_C_RESTRICT  __restrict__
#endif
#ifndef PETSC_CXX_RESTRICT
#define PETSC_CXX_RESTRICT  __restrict__
#endif
#ifndef PETSC_CXX_STATIC_INLINE
#define PETSC_CXX_STATIC_INLINE static inline
#endif
#ifndef PETSC_HAVE_LIBHWLOC
#define PETSC_HAVE_LIBHWLOC 1
#endif
#ifndef PETSC_HAVE_LIBZ
#define PETSC_HAVE_LIBZ 1
#endif
#ifndef PETSC_HAVE_LIBDL
#define PETSC_HAVE_LIBDL 1
#endif
#ifndef PETSC_HAVE_LIBM
#define PETSC_HAVE_LIBM 1
#endif
#ifndef PETSC_HAVE_LIBX11
#define PETSC_HAVE_LIBX11 1
#endif
#ifndef PETSC_HAVE_LIBPTHREAD
#define PETSC_HAVE_LIBPTHREAD 1
#endif
#ifndef PETSC_HAVE_LIBCRYPTO
#define PETSC_HAVE_LIBCRYPTO 1
#endif
#ifndef PETSC_HAVE_FENV_H
#define PETSC_HAVE_FENV_H 1
#endif
#ifndef PETSC_HAVE_ERF
#define PETSC_HAVE_ERF 1
#endif
#ifndef PETSC_HAVE_LIBSSL
#define PETSC_HAVE_LIBSSL 1
#endif
#ifndef PETSC_HAVE_TGAMMA
#define PETSC_HAVE_TGAMMA 1
#endif
#ifndef PETSC_ARCH
#define PETSC_ARCH "mpich-test"
#endif
#ifndef PETSC_CLANGUAGE_C
#define PETSC_CLANGUAGE_C 1
#endif
#ifndef PETSC_USE_ERRORCHECKING
#define PETSC_USE_ERRORCHECKING 1
#endif
#ifndef PETSC_SIZEOF_MPI_COMM
#define PETSC_SIZEOF_MPI_COMM 4
#endif
#ifndef PETSC_BITS_PER_BYTE
#define PETSC_BITS_PER_BYTE 8
#endif
#ifndef PETSC_SIZEOF_MPI_FINT
#define PETSC_SIZEOF_MPI_FINT 4
#endif
#ifndef PETSC_SIZEOF_VOID_P
#define PETSC_SIZEOF_VOID_P 8
#endif
#ifndef PETSC_RETSIGTYPE
#define PETSC_RETSIGTYPE void
#endif
#ifndef PETSC_HAVE_CXX_COMPLEX
#define PETSC_HAVE_CXX_COMPLEX 1
#endif
#ifndef PETSC_SIZEOF_LONG
#define PETSC_SIZEOF_LONG 8
#endif
#ifndef PETSC_USE_FORTRANKIND
#define PETSC_USE_FORTRANKIND 1
#endif
#ifndef PETSC_SIZEOF_SIZE_T
#define PETSC_SIZEOF_SIZE_T 8
#endif
#ifndef PETSC_HAVE_SIGINFO_T
#define PETSC_HAVE_SIGINFO_T 1
#endif
#ifndef PETSC_SIZEOF_CHAR
#define PETSC_SIZEOF_CHAR 1
#endif
#ifndef PETSC_SIZEOF_DOUBLE
#define PETSC_SIZEOF_DOUBLE 8
#endif
#ifndef PETSC_SIZEOF_FLOAT
#define PETSC_SIZEOF_FLOAT 4
#endif
#ifndef PETSC_HAVE_C99_COMPLEX
#define PETSC_HAVE_C99_COMPLEX 1
#endif
#ifndef PETSC_SIZEOF_INT
#define PETSC_SIZEOF_INT 4
#endif
#ifndef PETSC_SIZEOF_LONG_LONG
#define PETSC_SIZEOF_LONG_LONG 8
#endif
#ifndef PETSC_SIZEOF_SHORT
#define PETSC_SIZEOF_SHORT 2
#endif
#ifndef PETSC_HAVE_STRCASECMP
#define PETSC_HAVE_STRCASECMP 1
#endif
#ifndef PETSC_HAVE_GET_NPROCS
#define PETSC_HAVE_GET_NPROCS 1
#endif
#ifndef PETSC_HAVE_POPEN
#define PETSC_HAVE_POPEN 1
#endif
#ifndef PETSC_HAVE_SIGSET
#define PETSC_HAVE_SIGSET 1
#endif
#ifndef PETSC_HAVE_GETWD
#define PETSC_HAVE_GETWD 1
#endif
#ifndef PETSC_HAVE_VSNPRINTF
#define PETSC_HAVE_VSNPRINTF 1
#endif
#ifndef PETSC_HAVE_TIMES
#define PETSC_HAVE_TIMES 1
#endif
#ifndef PETSC_HAVE_DLSYM
#define PETSC_HAVE_DLSYM 1
#endif
#ifndef PETSC_HAVE_SNPRINTF
#define PETSC_HAVE_SNPRINTF 1
#endif
#ifndef PETSC_HAVE_GETHOSTBYNAME
#define PETSC_HAVE_GETHOSTBYNAME 1
#endif
#ifndef PETSC_HAVE_GETCWD
#define PETSC_HAVE_GETCWD 1
#endif
#ifndef PETSC_HAVE_DLERROR
#define PETSC_HAVE_DLERROR 1
#endif
#ifndef PETSC_HAVE_FORK
#define PETSC_HAVE_FORK 1
#endif
#ifndef PETSC_HAVE_RAND
#define PETSC_HAVE_RAND 1
#endif
#ifndef PETSC_HAVE_GETTIMEOFDAY
#define PETSC_HAVE_GETTIMEOFDAY 1
#endif
#ifndef PETSC_HAVE_DLCLOSE
#define PETSC_HAVE_DLCLOSE 1
#endif
#ifndef PETSC_HAVE_UNAME
#define PETSC_HAVE_UNAME 1
#endif
#ifndef PETSC_HAVE_GETHOSTNAME
#define PETSC_HAVE_GETHOSTNAME 1
#endif
#ifndef PETSC_HAVE_MKSTEMP
#define PETSC_HAVE_MKSTEMP 1
#endif
#ifndef PETSC_HAVE_SIGACTION
#define PETSC_HAVE_SIGACTION 1
#endif
#ifndef PETSC_HAVE_DRAND48
#define PETSC_HAVE_DRAND48 1
#endif
#ifndef PETSC_HAVE_MEMALIGN
#define PETSC_HAVE_MEMALIGN 1
#endif
#ifndef PETSC_HAVE_VA_COPY
#define PETSC_HAVE_VA_COPY 1
#endif
#ifndef PETSC_HAVE_CLOCK
#define PETSC_HAVE_CLOCK 1
#endif
#ifndef PETSC_HAVE_ACCESS
#define PETSC_HAVE_ACCESS 1
#endif
#ifndef PETSC_HAVE_SIGNAL
#define PETSC_HAVE_SIGNAL 1
#endif
#ifndef PETSC_HAVE_USLEEP
#define PETSC_HAVE_USLEEP 1
#endif
#ifndef PETSC_HAVE_GETRUSAGE
#define PETSC_HAVE_GETRUSAGE 1
#endif
#ifndef PETSC_HAVE_VFPRINTF
#define PETSC_HAVE_VFPRINTF 1
#endif
#ifndef PETSC_HAVE_NANOSLEEP
#define PETSC_HAVE_NANOSLEEP 1
#endif
#ifndef PETSC_HAVE_GETDOMAINNAME
#define PETSC_HAVE_GETDOMAINNAME 1
#endif
#define PETSC_HAVE_TIME 1
#endif
#ifndef PETSC_HAVE_LSEEK
#define PETSC_HAVE_LSEEK 1
#endif
#ifndef PETSC_HAVE_SOCKET
#define PETSC_HAVE_SOCKET 1
#endif
#ifndef PETSC_HAVE_SYSINFO
#define PETSC_HAVE_SYSINFO 1
#endif
#ifndef PETSC_HAVE_READLINK
#define PETSC_HAVE_READLINK 1
#endif
#ifndef PETSC_HAVE_REALPATH
#define PETSC_HAVE_REALPATH 1
#endif
#ifndef PETSC_HAVE_DLOPEN
#define PETSC_HAVE_DLOPEN 1
#endif
#ifndef PETSC_HAVE_MEMMOVE
#define PETSC_HAVE_MEMMOVE 1
#endif
#ifndef PETSC_HAVE__GFORTRAN_IARGC
#define PETSC_HAVE__GFORTRAN_IARGC 1
#endif
#ifndef PETSC_SIGNAL_CAST
#define PETSC_SIGNAL_CAST
#endif
#ifndef PETSC_HAVE_SLEEP
#define PETSC_HAVE_SLEEP 1
#endif
#ifndef PETSC_HAVE_VPRINTF
#define PETSC_HAVE_VPRINTF 1
#endif
#ifndef PETSC_HAVE_BZERO
#define PETSC_HAVE_BZERO 1
#endif
#ifndef PETSC_HAVE_GETPAGESIZE
#define PETSC_HAVE_GETPAGESIZE 1
#endif
#ifndef PETSC_WRITE_MEMORY_BARRIER
#define PETSC_WRITE_MEMORY_BARRIER() asm volatile("sfence":::"memory")
#endif
#ifndef PETSC_MEMORY_BARRIER
#define PETSC_MEMORY_BARRIER() asm volatile("mfence":::"memory")
#endif
#ifndef PETSC_READ_MEMORY_BARRIER
#define PETSC_READ_MEMORY_BARRIER() asm volatile("lfence":::"memory")
#endif
#ifndef PETSC_CPU_RELAX
#define PETSC_CPU_RELAX() asm volatile("rep; nop" ::: "memory")
#endif
#ifndef PETSC_HAVE_MPI_F90MODULE
#define PETSC_HAVE_MPI_F90MODULE 1
#endif
#ifndef PETSC_HAVE_MPI_IALLREDUCE
#define PETSC_HAVE_MPI_IALLREDUCE 1
#endif
#ifndef PETSC_HAVE_MPI_IN_PLACE
#define PETSC_HAVE_MPI_IN_PLACE 1
#endif
#ifndef PETSC_HAVE_MPI_COMM_C2F
#define PETSC_HAVE_MPI_COMM_C2F 1
#endif
#ifndef PETSC_HAVE_MPI_COMBINER_CONTIGUOUS
#define PETSC_HAVE_MPI_COMBINER_CONTIGUOUS 1
#endif
#ifndef PETSC_HAVE_MPI_INT64_T
#define PETSC_HAVE_MPI_INT64_T 1
#endif
#ifndef PETSC_HAVE_MPI_TYPE_GET_EXTENT
#define PETSC_HAVE_MPI_TYPE_GET_EXTENT 1
#endif
#ifndef PETSC_HAVE_MPI_WIN_CREATE
#define PETSC_HAVE_MPI_WIN_CREATE 1
#endif
#ifndef PETSC_HAVE_MPI_TYPE_DUP
#define PETSC_HAVE_MPI_TYPE_DUP 1
#endif
#ifndef PETSC_HAVE_MPI_INIT_THREAD
#define PETSC_HAVE_MPI_INIT_THREAD 1
#endif
#ifndef PETSC_HAVE_MPI_LONG_DOUBLE
#define PETSC_HAVE_MPI_LONG_DOUBLE 1
#endif
#ifndef PETSC_HAVE_MPI_COMM_F2C
#define PETSC_HAVE_MPI_COMM_F2C 1
#endif
#ifndef PETSC_HAVE_MPI_TYPE_GET_ENVELOPE
#define PETSC_HAVE_MPI_TYPE_GET_ENVELOPE 1
#endif
#ifndef PETSC_HAVE_MPI_COMBINER_DUP
#define PETSC_HAVE_MPI_COMBINER_DUP 1
#endif
#ifndef PETSC_HAVE_MPICH_NUMVERSION
#define PETSC_HAVE_MPICH_NUMVERSION 30103300
#endif
#ifndef PETSC_HAVE_MPIIO
#define PETSC_HAVE_MPIIO 1
#endif
#ifndef PETSC_HAVE_MPI_COMM_SPAWN
#define PETSC_HAVE_MPI_COMM_SPAWN 1
#endif
#ifndef PETSC_HAVE_MPI_FINT
#define PETSC_HAVE_MPI_FINT 1
#endif
#ifndef PETSC_HAVE_MPI_IBARRIER
#define PETSC_HAVE_MPI_IBARRIER 1
#endif
#ifndef PETSC_HAVE_MPI_ALLTOALLW
#define PETSC_HAVE_MPI_ALLTOALLW 1
#endif
#ifndef PETSC_HAVE_MPI_REPLACE
#define PETSC_HAVE_MPI_REPLACE 1
#endif
#ifndef PETSC_HAVE_MPI_EXSCAN
#define PETSC_HAVE_MPI_EXSCAN 1
#endif
#ifndef PETSC_HAVE_MPI_C_DOUBLE_COMPLEX
#define PETSC_HAVE_MPI_C_DOUBLE_COMPLEX 1
#endif
#ifndef PETSC_HAVE_MPI_FINALIZED
#define PETSC_HAVE_MPI_FINALIZED 1
#endif
#ifndef PETSC_USE_INFO
#define PETSC_USE_INFO 1
#endif
#ifndef PETSC_Alignx
#define PETSC_Alignx(a,b)
#endif
#ifndef PETSC_USE_BACKWARD_LOOP
#define PETSC_USE_BACKWARD_LOOP 1
#endif
#ifndef PETSC_USE_DEBUG
#define PETSC_USE_DEBUG 1
#endif
#ifndef PETSC_IS_COLOR_VALUE_TYPE_SIZE
#define PETSC_IS_COLOR_VALUE_TYPE_SIZE PETSC_SIZEOF_SHORT
#endif
#ifndef PETSC_USE_LOG
#define PETSC_USE_LOG 1
#endif
#define PETSC_IS_COLOR_VALUE_TYPE short
#endif
#ifndef PETSC_USE_CTABLE
#define PETSC_USE_CTABLE 1
#endif
#ifndef PETSC_USE_SCALAR_REAL
#define PETSC_USE_SCALAR_REAL 1
#endif
#ifndef PETSC_HAVE_ISINF
#define PETSC_HAVE_ISINF 1
#endif
#ifndef PETSC_HAVE_ISNAN
#define PETSC_HAVE_ISNAN 1
#endif
#ifndef PETSC_USE_REAL_DOUBLE
#define PETSC_USE_REAL_DOUBLE 1
#endif
#ifndef PETSC_MEMALIGN
#define PETSC_MEMALIGN 16
#endif
#ifndef PETSC_VERSION_DATE_GIT
#define PETSC_VERSION_DATE_GIT "2014-11-05 15:13:20 -0600"
#endif
#ifndef PETSC_VERSION_BRANCH_GIT
#define PETSC_VERSION_BRANCH_GIT "master"
#endif
#ifndef PETSC_VERSION_GIT
#define PETSC_VERSION_GIT "v3.5.2-939-geeb4e01"
#endif
#ifndef PETSC_HAVE_DYNAMIC_LIBRARIES
#define PETSC_HAVE_DYNAMIC_LIBRARIES 1
#endif
#ifndef PETSC_HAVE_SHARED_LIBRARIES
#define PETSC_HAVE_SHARED_LIBRARIES 1
#endif
#ifndef PETSC_USE_SHARED_LIBRARIES
#define PETSC_USE_SHARED_LIBRARIES 1
#endif
#ifndef PETSC_USE_GDB_DEBUGGER
#define PETSC_USE_GDB_DEBUGGER 1
#endif
#ifndef PETSC_LEVEL1_DCACHE_LINESIZE
#define PETSC_LEVEL1_DCACHE_LINESIZE 64
#endif
#ifndef PETSC_LEVEL1_DCACHE_SIZE
#define PETSC_LEVEL1_DCACHE_SIZE 32768
#endif
#ifndef PETSC_LEVEL1_DCACHE_ASSOC
#define PETSC_LEVEL1_DCACHE_ASSOC 8
#endif
#ifndef PETSC__GNU_SOURCE
#define PETSC__GNU_SOURCE 1
#endif
#ifndef PETSC__BSD_SOURCE
#define PETSC__BSD_SOURCE 1
#endif
#ifndef PETSC__DEFAULT_SOURCE
#define PETSC__DEFAULT_SOURCE 1
#endif
#ifndef PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT
#define PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT 1
#endif
#ifndef PETSC_HAVE_GFORTRAN_IARGC
#define PETSC_HAVE_GFORTRAN_IARGC 1
#endif
#ifndef PETSC_USE_PROC_FOR_SIZE
#define PETSC_USE_PROC_FOR_SIZE 1
#endif
#ifndef PETSC_HAVE_SCHED_CPU_SET_T
#define PETSC_HAVE_SCHED_CPU_SET_T 1
#endif
#ifndef PETSC_HAVE_PTHREAD_BARRIER_T
#define PETSC_HAVE_PTHREAD_BARRIER_T 1
#endif
#ifndef PETSC_HAVE_SYS_SYSCTL_H
#define PETSC_HAVE_SYS_SYSCTL_H 1
#endif
#endif
**** C specific Configure header /tmp/petsc-lhuj9c/conffix.h ****
#if defined(__cplusplus)
extern "C" {
#else
#endif
#endif
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
Unable to find metis in default locations!
Perhaps you can specify with --with-metis-dir=<directory>
If you do not want metis, then give --with-metis=0
You might also consider using --download-metis instead
  File "./config/configure.py", line 272, in petsc_configure
    framework.configure(out = sys.stdout)
  File "/home/jed/petsc/config/BuildSystem/config/framework.py", line 935, in configure
    child.configure()
  File "/home/jed/petsc/config/BuildSystem/config/package.py", line 636, in configure
    self.executeTest(self.configureLibrary)
  File "/home/jed/petsc/config/BuildSystem/config/base.py", line 126, in executeTest
    ret = test(*args,**kargs)
  File "/home/jed/petsc/config/BuildSystem/config/package.py", line 558, in configureLibrary
    for location, directory, lib, incl in self.generateGuesses():
  File "/home/jed/petsc/config/BuildSystem/config/package.py", line 378, in generateGuesses
    raise RuntimeError(mesg)
Finishing Configure Run at Thu Nov  6 23:44:56 2014
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141106/e23c98bf/attachment.sig>
