[petsc-dev] Running on KNC
Mark Adams
mfadams at lbl.gov
Thu Nov 6 11:56:09 CST 2014
On Thu, Nov 6, 2014 at 12:40 PM, hong at aspiritech.org <hong at aspiritech.org>
wrote:
> I wrote runex52_superlu with '-use_superlu_ilu' because only superlu
> (sequential) supports ilu, not superlu_dist.
Thanks, the rest of the code is NP neutral. It is working now with command
line arguments.
Mar
> Hong
> On Thu, Nov 6, 2014 at 10:17 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> ex52 sets SuperLU explicitly (appended) and yes I did modify the runex52
>> rule. I have it running now with superlu_dist.
>> Thanks,
>> Mark
>> ierr = KSPSetType(ksp,KSPPREONLY);CHKERRQ(ierr);
>> PC pc;
>> Mat F;
>> ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>> if (flg) {
>> ierr = PCSetType(pc,PCLU);CHKERRQ(ierr);
>> } else if (flg_ilu) {
>> ierr = PCSetType(pc,PCILU);CHKERRQ(ierr);
>> ierr = PCFactorSetMatSolverPackage(pc,MATSOLVERSUPERLU);CHKERRQ(ierr);
>> ierr = PCFactorSetUpMatSolverPackage(pc);CHKERRQ(ierr); /* call
>> MatGetFactor() to create F */
>> ierr = PCFactorGetMatrix(pc,&F);CHKERRQ(ierr);
>> ierr = MatSuperluSetILUDropTol(F,1.e-8);CHKERRQ(ierr);
>> On Thu, Nov 6, 2014 at 8:01 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> > Matrix format mpiaij does not have a solver package superlu for LU.
>>> SuperLU is not parallel, it does not work with mpiaij matrix.
>>> Did you modify the runex52_superlu rule in the makefile or something
>>> to run on 2 processors? In master it looks like
>>> runex52_superlu:
>>> -@${MPIEXEC} -n 1 ./ex52 -use_superlu_ilu > ex52.tmp 2>&1;
>>> If you want to run on two processors you need to use superlu_dist
>>> Barry
>>> > On Nov 6, 2014, at 5:54 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>> > I am running on KNC and ex52 is sort of running, SuperLU runs on one
>>> processor, but fails with this message on 2 procs. The error message
>>> suggests downloading superLU but you can see that it was downloaded. Any
>>> ideas?
>>> > Mark
>>> > 03:19 bc0915 master ~/petsc/src/ksp/ksp/examples/tutorials$ make
>>> runex52_superlu PETSC_DIR=/global/homes/m/madams/petsc
>>> > make: Warning: File `makefile' has modification time 19 s in the future
>>> > [0]PETSC ERROR: --------------------- Error Message
>>> > [0]PETSC ERROR: No support for this operation for this object type
>>> > [0]PETSC ERROR: Matrix format mpiaij does not have a solver package
>>> superlu for LU. Perhaps you must ./configure with --download-superlu
>>> > [0]PETSC ERROR: See
>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>> shooting.
>>> > [0]PETSC ERROR: Petsc Development GIT revision: v3.5-25-g0ace994 GIT
>>> Date: 2014-07-07 14:50:15 +0200
>>> > [0]PETSC ERROR: ./ex52 on a arch-knc-opt named bc0915-mic0 by madams
>>> Thu Nov 6 03:20:04 2014
>>> > [0]PETSC ERROR: Configure options --known-level1-dcache-size=32768
>>> --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0
>>> --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8
>>> --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8
>>> --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8
>>> --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4
>>> --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1
>>> --known-mpi-c-double-complex=1 --download-parmetis --download-metis
>>> --download-superlu_dist --download-superlu --with-batch=1 --CFLAGS="-mmic
>>> -mkl -fp-model precise" --CXXFLAGS="-mmic -mkl -fp-model precise"
>>> --FFLAGS="-mmic -mkl -fp-model precise" --with-cc=mpiicc --with-cxx=mpiicpc
>>> --with-fc=mpiifort --known-mpi-shared-libraries=1 --with-shared-libraries=0
>>> --with-x=0 --with-debugging=0 PETSC_ARCH=arch-knc-opt
>>> > [0]PETSC ERROR: #1 MatGetFactor() line 3962 in
>>> /chos/global/u2/m/madams/petsc/src/mat/interface/matrix.c
>>> > [0]PETSC ERROR: #2 PCFactorSetUpMatSolverPackage_Factor() line 16 in
>>> /chos/global/u2/m/madams/petsc/src/ksp/pc/impls/factor/factimpl.c
>>> > [0]PETSC ERROR: #3 PCFactorSetUpMatSolverPackage() line 26 in
>>> /chos/global/u2/m/madams/petsc/src/ksp/pc/impls/factor/factor.c
>>> > [0]PETSC ERROR: #4 main() line 209 in
>>> /global/homes/m/madams/petsc/src/ksp/ksp/examples/tutorials/ex52.c
>>> > [0]PETSC ERROR: ----------------End of Error Message -------send
>>> entire error message to petsc-maint at mcs.anl.gov----------
>>> > application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
>>> > APPLICATION TERMINATED WITH THE EXIT STRING: Interrupt (signal 2)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141106/a01603a4/attachment.html>
