[petsc-dev] Running on KNC
Barry Smith
bsmith at mcs.anl.gov
Thu Nov 6 07:01:32 CST 2014
> Matrix format mpiaij does not have a solver package superlu for LU.
SuperLU is not parallel, it does not work with mpiaij matrix.
Did you modify the runex52_superlu rule in the makefile or something to run on 2 processors? In master it looks like
runex52_superlu:
-@${MPIEXEC} -n 1 ./ex52 -use_superlu_ilu > ex52.tmp 2>&1;
If you want to run on two processors you need to use superlu_dist
Barry
> On Nov 6, 2014, at 5:54 AM, Mark Adams <mfadams at lbl.gov> wrote:
> I am running on KNC and ex52 is sort of running, SuperLU runs on one processor, but fails with this message on 2 procs. The error message suggests downloading superLU but you can see that it was downloaded. Any ideas?
> Mark
> 03:19 bc0915 master ~/petsc/src/ksp/ksp/examples/tutorials$ make runex52_superlu PETSC_DIR=/global/homes/m/madams/petsc
> make: Warning: File `makefile' has modification time 19 s in the future
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: Matrix format mpiaij does not have a solver package superlu for LU. Perhaps you must ./configure with --download-superlu
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.5-25-g0ace994 GIT Date: 2014-07-07 14:50:15 +0200
> [0]PETSC ERROR: ./ex52 on a arch-knc-opt named bc0915-mic0 by madams Thu Nov 6 03:20:04 2014
> [0]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1 --known-mpi-c-double-complex=1 --download-parmetis --download-metis --download-superlu_dist --download-superlu --with-batch=1 --CFLAGS="-mmic -mkl -fp-model precise" --CXXFLAGS="-mmic -mkl -fp-model precise" --FFLAGS="-mmic -mkl -fp-model precise" --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort --known-mpi-shared-libraries=1 --with-shared-libraries=0 --with-x=0 --with-debugging=0 PETSC_ARCH=arch-knc-opt PETSC_DIR=/global/homes/m/madams/petsc
> [0]PETSC ERROR: #1 MatGetFactor() line 3962 in /chos/global/u2/m/madams/petsc/src/mat/interface/matrix.c
> [0]PETSC ERROR: #2 PCFactorSetUpMatSolverPackage_Factor() line 16 in /chos/global/u2/m/madams/petsc/src/ksp/pc/impls/factor/factimpl.c
> [0]PETSC ERROR: #3 PCFactorSetUpMatSolverPackage() line 26 in /chos/global/u2/m/madams/petsc/src/ksp/pc/impls/factor/factor.c
> [0]PETSC ERROR: #4 main() line 209 in /global/homes/m/madams/petsc/src/ksp/ksp/examples/tutorials/ex52.c
> [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
> application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
> APPLICATION TERMINATED WITH THE EXIT STRING: Interrupt (signal 2)
