[petsc-dev] KNC build?
Satish Balay
balay at mcs.anl.gov
Tue Nov 4 17:30:54 CST 2014
Ah - didn't check the configure comand closely enough..
> --with-mpicc=/global/babbage/nsg/opt/intel/impi/5.0.1.035/intel64/bin/mpicc
> --with-mpicxx=/global/babbage/nsg/opt/intel/impi/5.0.1.035/intel64/bin/mpicxx
> --with-mpif90=/global/babbage/nsg/opt/intel/impi/5.0.1.035/intel64/bin/mpif90
petsc configure doesn't provide any such options..
> --with-mpi-lib=/global/babbage/nsg/opt/intel/impi/5.0.1.035/intel64/lib
This would be the wrong way to provide MPI lib.
The correct way to use Intel MPI is:
--with-cc=mpiipc --with-cxx=mpiicpc --with-fc=mpiifort [i.e no --with-mpi-include or --with-mpi-lib options]
But as Richard mentioned - the wrappers in intel impi-5 are
broken. Alternative is to use impi-4 as suggested.
Or something like the following (for compilers/mpi):
./configure --with-cc=icc --with-fc=ifort --with-cxx=0 --with-mpi-include=/global/babbage/nsg/opt/intel/impi/5.0.1.035/intel64/include --with-mpi-lib="-L/global/babbage/nsg/opt/intel/impi/5.0.1.035/intel64/lib/release -L/global/babbage/nsg/opt/intel/impi/5.0.1.035/intel64/lib -lmpifort -lmpi -lmpigi -ldl -lrt -lpthread"
Satish
On Tue, 4 Nov 2014, Richard Mills wrote:
> Hi Mark,
> I noticed that you are using the wrong compiler wrappers. Instead of
> 'mpicc', 'mpif90', and 'mpicxx' (which will invoke GNU compilers), you
> probably want 'mpiicc', 'mpiifort', and 'mpiicpc' (invoke the Intel
> compilers).
> You will probably also want to unload the IMPI 5.x and load the IMPI 4.1.3
> module right now because of a stupid bug in the compiler wrappers (for
> which I've filed a bug report--will be fixed in next IMPI release, sometime
> before SC14).
> --Richard
> On Tue, Nov 4, 2014 at 12:59 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > Thanks Victor,
> > I am getting cc error. Any ideas?
> > Mark
> > On Tue, Nov 4, 2014 at 12:38 PM, Victor Eijkhout <eijkhout at tacc.utexas.edu
> > > wrote:
> >> > On Nov 4, 2014, at 11:32 AM, Mark Adams <mfadams at lbl.gov> wrote:
> >> > Has anyone built PETSc on KNC (Babbage at NERSC to be specific)?
> >> At TACC under intel 14:
> >> CEE_OPTIONS="-mmic -mkl -fp-model precise"
> >> ./configure --PETSC_ARCH=mic --with-fc=0 --with-debug=0 \
> >> --with-batch=1 --CPPFLAGS=-mmic \
> >> --CFLAGS="${CEE_OPTIONS}" --CXXFLAGS="${CEE_OPTIONS}"
> >> --FFLAGS="${CEE_OPTIONS}" \
> >> --with-mpi=1 --known-mpi-shared-libraries=1 \
> >> --with-mpi-include=${MPICH_HOME}/mic/include \
> >> --with-mpi-lib=${MPICH_HOME}/mic/lib \
> >> --with-mpicc=/opt/apps/intel13/impi/4.1.0.030/intel64/bin/mpicc \
> >> --with-mpicxx=/opt/apps/intel13/impi/4.1.0.030/intel64/bin/mpicxx
> >> --with-mpif90=/opt/apps/intel13/impi/4.1.0.030/intel64/bin/mpif90
> >> That first line is still giving me problems. Just nix the fp-model.
> >> Victor.
