[petsc-dev] KNC build?
Mark Adams
mfadams at lbl.gov
Tue Nov 4 17:10:38 CST 2014
> Try expanding ${CEE_OPTIONS} env variable before configure script is
> called.. [or not use this env variable and pass in these options
> directly - assuming they are valid for this compiler]
I have tried this:
CEE_OPTIONS='-mmic -mkl -fp-model precise' ../arch-knc-dbg64.py
Is that what you mean?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141104/7c543fb8/attachment.html>
