[petsc-dev] TAO data files
    Satish Balay
    balay at mcs.anl.gov
    Fri May 16 22:42:09 CDT 2014
for one - I didn't look closely at all files in tao. [I assumed
'src/docs/tex' on tao was similar to stuff on petsc side - and moved
it over to src/docs/tao_tex]
And secondly - I was preserving the tao repo history [in separate
branches].  So - unless I was purging stuff from tao history - this
would be in the repo anyway.. [even if it was removed before merge]
Satish
On Fri, 16 May 2014, Jed Brown wrote:
> Why did we merge this?
> -rwxr-xr-x 1 jed users 14M Apr  9 20:06 src/docs/tao_tex/tutorials/images/interpmodel.eps
> There's actually a number of multi-MB eps files that have found their
> way into the repository.
>   $ du -hs src/docs/*tex
>   37M     src/docs/tao_tex
>   3.8M    src/docs/tex
> This data is transferred every time someone clones the repository.
