[petsc-dev] PetscFinalize broken with -options_table ?
Barry Smith
bsmith at mcs.anl.gov
Tue Mar 18 22:46:18 CDT 2014
False alarm, problem is not as general as I stated.
I can reproduce the problem in maint with your example code when -breakme is on
Problem also happens in master
Still working on it.
Barry
On Mar 18, 2014, at 10:17 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> This looks like a problem unrelated to viewers, options, etc.
> In maint, 3.4.3 and 3.4.4 PetscFinalize() crashes if any PETSc object (like your viewer) is not destroyed before PetscFinalize(). This does not occur in master and is not suppose to happen.
> Trying to track it down but could take a while to determine what change broke this.
> Barry
> On Mar 18, 2014, at 6:20 PM, William Perkins <william.perkins at pnnl.gov> wrote:
>> All,
>> I also ran into this today.
>> Attached is a minimal program that exhibited the problem for me. Initially, I thought it was because I was using non-default formats (e.g. MATLAB) for VecView and MatView, but I think any Viewer use causes the problem.
>> Thanks.
>> Bill
>> P.S. I'm using 3.4.3 configured as follows:
>> python ./config/configure.py \
>> PETSC_ARCH=arch-macosx-complex-opt \
>> --with-prefix="$prefix" \
>> --with-mpi=1 \
>> --with-cc=mpicc \
>> --with-fc=mpif90 \
>> --with-cxx=mpicxx \
>> --with-c++-support=1 \
>> --with-c-support=0 \
>> --with-fortran=0 \
>> --with-scalar-type=complex \
>> --with-fortran-kernels=generic \
>> --with-valgrind=0 \
>> --download-superlu_dist \
>> --download-parmetis \
>> --download-metis \
>> --download-f2cblaslapack=1 \
>> --with-clanguage=c++ \
>> --with-shared-libraries=0 \
>> --with-dynamic-loading=0 \
>> --with-x=0 \
>> --with-mpirun=mpiexec \
>> --with-mpiexec=mpiexec \
>> --with-debugging=0
>> On 03/12/2014 04:30 AM, Matthew Knepley wrote:
>>> On Wed, Mar 12, 2014 at 4:52 AM, Václav Hapla <vaclav.hapla at vsb.cz
>>> <mailto:vaclav.hapla at vsb.cz>> wrote:
>>> You're right this is not happening with the petsc example. Thus it's
>>> probably problem in my code. I'll come back when I know what's the
>>> true reason.
>>> It could still be our bug. If you can strip down your code and send it,
>>> I will look at it.
>>> Thanks,
>>> Matt
>>> Matt, sorry for replying to your personal address only.
>>> Thank you,
>>> Vaclav
>>> Dne 11.3.2014 16:04, Matthew Knepley napsal(a):
>>>> On Tue, Mar 11, 2014 at 9:27 AM, Václav Hapla <vaclav.hapla at vsb.cz
>>>> FWICS PetscFinalize in petsc-current contains the following bug.
>>>> It calls
>>>> PetscObjectRegisterDestroyAll()
>>>> and after that, if -options_table is present, it calls
>>>> PetscViewerASCIIGetStdout(PETSC_COMM_WORLD,&viewer);
>>>> PetscOptionsView(viewer);
>>>> causing
>>>> [0]PETSC ERROR: No support for this operation for this
>>>> object type!
>>>> [0]PETSC ERROR: Only supports ASCII viewer!
>>>> because the viewer is destroyed already by
>>>> PetscObjectRegisterDestroyAll.
>>>> I haven't tested petsc-dev but I can see in it's the same
>>>> situation in the pinit.c source.
>>>> I cannot reproduce this on 'next':
>>>> next $:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$ ./ex19
>>>> -options_table -snes_monitor
>>>> PETSC_OPTIONS="-cublas 0" ./ex19 -options_table -snes_monitor
>>>> lid velocity = 0.0625, prandtl # = 1, grashof # = 1
>>>> 0 SNES Function norm 2.391552133017e-01
>>>> 1 SNES Function norm 6.839858507066e-05
>>>> 2 SNES Function norm 8.558777232425e-11
>>>> Number of SNES iterations = 2
>>>> #PETSc Option Table entries:
>>>> -options_table
>>>> -snes_monitor
>>>> #End of PETSc Option Table entries
>>>> Can you reproduce this with a PETSc example?
>>>> Thanks,
>>>> Matt
>>>> Best regards,
>>>> Vaclav
>>>> Vaclav Hapla
>>>> Junior researcher / PhD student
>>>> IT4Innovations <http://www.it4i.eu/> / Dept. of Applied
>>>> Mathematics <http://am.vsb.cz/>
>>>> _office PI 328_
>>>> tel.: (+420) 597 329 078 <tel:%28%2B420%29%20597%20329%20078>
>>>> Podnikatelsky inkubator VSB-TUO
>>>> Studentska 6202/17
>>>> 708 00 Ostrava-Poruba
>>>> Czech Republic
>>>> _contact address_
>>>> IT4Innovations
>>>> VSB - Technical University of Ostrava
>>>> 17. listopadu 15/2172
>>>> 708 33 Ostrava-Poruba
>>>> Czech Republic
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to
>>>> which their experiments lead.
>>>> -- Norbert Wiener
>>> Vaclav Hapla
>>> IT4Innovations <http://www.it4i.eu/> / Dept. of Applied Mathematics
>>> <http://am.vsb.cz/>
>>> _office PI 328_
>>> Studentska 6202/17
>>> Czech Republic
>>> _contact address_
>>> IT4Innovations
>>> Czech Republic
>>> experiments is infinitely more interesting than any results to which
>>> -- Norbert Wiener
>> Bill Perkins
>> Research Engineer
>> Hydrology Group
>> Pacific Northwest National Laboratory
>> 902 Battelle Boulevard
>> P.O. Box 999, MSIN K9-36
>> Richland, WA 99352 USA
>> Tel: 509-372-6131
>> Fax: 509-372-6089
>> www.pnnl.gov
>> <viewer.cpp><viewer.out>
