[petsc-dev] Tao tron and ksp methods
Corrado Maurini corrado.maurini at upmc.fr
Thu Mar 13 11:17:40 CDT 2014
Running in petsc/src/tao/bound/examples/tutorials
./jbearing2 -tao_view -tao_type tron -ksp_type gmres
I get the error below. With tao 2.2 and petsc 3.4 and the same options, I did not get any error.
Now the TAO TRON method seems to work only with STCG as KSP. Is there any reason?
Corrado
---- Journal Bearing Problem SHB-----
mx: 50,  my: 50,  ecc: 0.1
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: Cannot locate function KSPSTCGSetRadius_C in object
[0]PETSC ERROR: See http://http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.4.3-3575-gf3e7060  GIT Date: 2014-03-11 19:24:46 -0500
[0]PETSC ERROR: ./jbearing2 on a arch-darwin-cxx-opt named muspratt by Maurini Thu Mar 13 17:16:30 2014
[0]PETSC ERROR: Configure options --download-blacs=1 --download-hypre=1 --download-metis=1 --download-ml=1 --download-mumps=1 --download-parmetis=1 --download-superlu_dist=1 --download-umfpack=1 --with-c-support=1 --with-clanguage=cxx --with-debugging=0 --with-scalapack-dir=/usr/local/ --with-scotch-dir=/usr/local/ --with-shared-libraries=1 --with-x11=1 COPTFLAGS=-O2 PETSC_ARCH=arch-darwin-cxx-opt
[0]PETSC ERROR: #1 KSPSTCGSetRadius() line 37 in /opt/HPC/petsc/src/ksp/ksp/impls/cg/stcg/stcg.c
[0]PETSC ERROR: #2 TaoSolve_TRON() line 170 in /opt/HPC/petsc/src/tao/bound/impls/tron/tron.c
[0]PETSC ERROR: #3 TaoSolve() line 192 in /opt/HPC/petsc/src/tao/interface/taosolver.c
[0]PETSC ERROR: #4 main() line 169 in /opt/HPC/petsc/src/tao/bound/examples/tutorials/jbearing2.c
[0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 56.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140313/e23892fa/attachment.html>
